Image shift right for LVDS
1,400 次查看
hankwang
Contributor V
Hi, I have a problem.  I use the sn65dsi8x dirver to enable LVDS signal. I can see the image, but image shift right.
I can modify which parameter to fix this problem ? I have tried the hfront_porch , hback_porch, but the problem is not fix.
991 次查看
sabidi
I'am working with imx8mm using sn65dsi83 and ihave the same issue, can you please share the solution?
1,332 次查看
igorpadykov
Hi hank
one can look at below variscite guidelines for adding custom panel. also
pay attention to proper panel initialization, function rad_panel_push_cmd_list() in
panel-raydium-rm67191.c\panel\drm\gpu\drivers - linux-imx - i.MX Linux kernel
DART-MX8M Display - Variscite Wiki
