I try to use the IPU IC to convert images in the post-processor (fmem channel 11 -> fmem channel 22).
Things work as expected on an iMX6Q but operation is stuck on iMX6QPlus.
A simple reproducer on Linux (Kernel 6.1) is
gst-launch-1.0 videotestsrc num-buffers=1 \! \
"video/x-raw,format=NV12,width=256,height=128" \! \
v4l2convert \! "video/x-raw,width=128" \! \
filesink location=/tmp/a It finishes on iMX6Q but hangs on iMX6QPlus. It uses the
| # v4l2-ctl -d /dev/video8 --all
| Driver Info:
| Driver name : imx-csc-scaler
| Card type : imx-csc-scaler
| Bus info : platform:imx-csc-scaler
device.
iMX6QPlus has a new prefetcher unit but afais, it is related to the display related dma channels. What has been changed else resp. what must be done to use the IC again?
More examples: after
strace output
ioctl(6, VIDIOC_QUERYCAP, {driver="imx-csc-scaler", card="imx-csc-scaler", bus_info="platform:imx-csc-scaler", version=KERNEL_VERSION(6, 1, 8), capabilities=V4L2_CAP_VIDEO_M2M|V4L2_CAP_EXT_PIX_FORMAT|V4L2_CAP_STREAMING|V4L2_CAP_DEVICE_CAPS, device_caps=V4L2_CAP_VIDEO_M2M|V4L2_CAP_EXT_PIX_FORMAT|V4L2_CAP_STREAMING}) = 0
ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=720, height=576, pixelformat=v4l2_fourcc('Y', 'U', '1', '2') /* V4L2_PIX_FMT_YUV420 */, field=V4L2_FIELD_NONE, bytesperline=720, sizeimage=622080, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=720, height=576, pixelformat=v4l2_fourcc('Y', 'U', '1', '2') /* V4L2_PIX_FMT_YUV420 */, field=V4L2_FIELD_NONE, bytesperline=720, sizeimage=622080, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_S_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_ANY, bytesperline=0, sizeimage=0, colorspace=V4L2_COLORSPACE_DEFAULT}} => {fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_REQBUFS, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, memory=V4L2_MEMORY_MMAP, count=3 => 3}) = 0
ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0
ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=1, memory=V4L2_MEMORY_MMAP, m.offset=0x8000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0
ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=2, memory=V4L2_MEMORY_MMAP, m.offset=0x10000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0
ioctl(6, VIDIOC_S_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_ANY, bytesperline=0, sizeimage=0, colorspace=V4L2_COLORSPACE_DEFAULT}} => {fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_G_FMT, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, fmt.pix={width=128, height=128, pixelformat=v4l2_fourcc('Y', 'U', 'Y', 'V') /* V4L2_PIX_FMT_YUYV */, field=V4L2_FIELD_NONE, bytesperline=256, sizeimage=32768, colorspace=V4L2_COLORSPACE_SRGB}}) = 0
ioctl(6, VIDIOC_S_CTRL, {id=V4L2_CID_HFLIP, value=1 => 1}) = 0
ioctl(6, VIDIOC_REQBUFS, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, memory=V4L2_MEMORY_MMAP, count=1 => 1}) = 0
ioctl(6, VIDIOC_QUERYBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0x40000000, length=32768, flags=V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0
ioctl(6, VIDIOC_STREAMON, [V4L2_BUF_TYPE_VIDEO_CAPTURE]) = 0
ioctl(6, VIDIOC_STREAMON, [V4L2_BUF_TYPE_VIDEO_OUTPUT]) = 0
ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=107967}, sequence=0, ...}) = 0
ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=1, memory=V4L2_MEMORY_MMAP, m.offset=0x8000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=108260}, sequence=0, ...}) = 0
ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_OUTPUT, index=2, memory=V4L2_MEMORY_MMAP, m.offset=0x10000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, bytesused=32768, timestamp={tv_sec=1002, tv_usec=108451}, sequence=0, ...}) = 0
ioctl(6, VIDIOC_QBUF_TIME32, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE, index=0, memory=V4L2_MEMORY_MMAP, m.offset=0x40000000, length=32768, flags=V4L2_BUF_FLAG_MAPPED|V4L2_BUF_FLAG_QUEUED|V4L2_BUF_FLAG_TIMESTAMP_COPY|V4L2_BUF_FLAG_TSTAMP_SRC_EOF, ...}) = 0the IPU is configured with
0x02600000 CONF 0x0000'0004
CSI0_EN : false
CSI1_EN : false
IC_EN : true
IRT_EN : false
DP_EN : false
DI0_EN : false
DI1_EN : false
SMFC_EN : false
DC_EN : false
DMFC_EN : false
SISG_EN : false
VDI_EN : false
IDMAC_DIABLE : false
DMFC_SEL : IDMAC
DMFC_SYNC : async
CSI0_DAT_SOURCE : parallel
CSI1_DAT_SOURCE : parallel
IC_INPUT : CSI
CSI_SEL : CSI0
0x0260003c INT_CTRL_EOF_0 0x10c0'0800
0x02600040 INT_CTRL_EOF_1 0x0004'8000
0x02600200 INT_STAT_EOF_0 0x0000'0000
0x02600204 INT_STAT_EOF_1 0x0000'0000
0x02600208 INT_STAT_NFACK_0 0x0000'0800
0x0260020c INT_STAT_NFACK_1 0x0000'0000
0x02600210 INT_STAT_NFB4EOF_0 0x0000'0000
0x02600214 INT_STAT_NFB4EOF_1 0x0000'0000
0x02600218 INT_STAT_EOS_0 0x0000'0000
0x0260021c INT_STAT_EOS_1 0x0000'0000
0x02600220 INT_STAT_9 0x0000'0000
0x02600224 INT_STAT_10 0x0000'0000
0x02600228 INT_STAT_EOBND_0 0x0000'0000
0x0260022c INT_STAT_EOBND_1 0x0000'0000
0x02600230 INT_STAT_TH_0 0x0000'0000
0x02600234 INT_STAT_TH_1 0x0000'0000
0x02600238 INT_STAT_15 0x0000'0000
0x0260023c CUR_BUF_0 0x0000'0000
0x02600240 CUR_BUF_1 0x0000'0000
0x02600268 CH_BUF0_RDY0 0x0040'0800
0x0260026c CH_BUF0_RDY1 0x0000'0000
0x02600270 CH_BUF1_RDY0 0x0000'0000
0x02600274 CH_BUF1_RDY1 0x0000'0000
======================== IPU1-IDMAC ==============================
0x02608000 CONF 0x0000'002f
MAX_REQ_READ : 7
WIDPT : 1
RDI : true
P_ENIAN : false
USED_BUFS_MAX_W : 0
USED_BUFS_EN_W : false
USED_BUFS_MAX_R : 0
USED_BUFS_EN_R : false
0x02608004 CH_EN_1 0x0040'0800
0x02608100 CH_BUSY_1 0x0000'0000
0x02608104 CH_BUSY_2 0x0000'0000
======================== IPU1-IC ==============================
0x02620000 CONF 0x0001'0000
PRPENC_EN : false
PRPENC_CSC1_EN : false
PRPENC_ROT_EN : false
PRPVF_EN : false
PRPVF_CSC1 : false
PRPVF_CSC2 : false
PRPVF_CMB : false
PRPVF_ROT_EN : false
PP_EN : true
PP_CSC1 : false
PP_CSC2 : false
PP_CMB : false
PP_ROT_EN : false
IC_GLB_LOC_A : false
IC_KEY_COLOR_EN : false
RWS_EN : false
CSI_MEM_WR_EN : false
0x02620018 IDMAC_1 0x0040'0024
CB0_BURST_16 : burst 8 px
CB1_BURST_16 : burst 8 px
CB2_BURST_16 : burst 16 px
CB3_BURST_16 : burst 8 px
CB4_BURST_16 : burst 8 px
CB5_BURST_16 : burst 16 px
CB6_BURST_16 : burst 8 px
CB7_BURST_16 : burst 8 px
ENC_ROT : false
ENC_FLIP_LR : false
ENC_FLIP_UD : false
VF_ROT : false
VF_FLIP_LR : false
VF_FLIP_UD : false
PP_ROT : false
PP_FLIP_LR : false
PP_FLIP_UD : false
ENC_FLIP_RS : false
VF_FLIP_RS : false
PP_FLIP_RS : true
0x0262001c IDMAC_2 0x07f0'0000
enc_fr_height : 0
vf_fr_height : 0
pp_fr_height : 127
0x02620020 IDMAC_3 0x07f0'0000
enc_fr_width : 0
vf_fr_width : 0
pp_fr_width : 127
======================== IPU1-CPMEM ==============================
0x027002c0 CH-I#11_0 0x0001fc0f'e0001800'00000000'00000000'00000000
XV : 0
YV : 0
XB : 0
YB : 0
NSB_B : false
CF : even
SX : 0
SY : 0
NS : 0
SDX : 0
SM : 0
SCC : false
SCE : false
SDY : 0
SDRX : false
SDRY : false
BPP : 16 bpp
DEC_SEL : 0-15
DIM : 2d
SO : progressive
BNDM : no bands
BM : no block mode
ROT : false
HFLIP : false
VFLIP : false
THE : false
CAP : false
CAE : false
FW : 127
FH : 127
EOLI : false
0x027002e0 CH-I#11_1 0x00000000'00003fc0'0103c000'00000000'06027000
EBA0 : 0x06027000
EBA1 : 0x00000000
ILO : 0
NPB : 15
PFS : interleaved 4:2:2 Y1U1Y2V1
ALU : false
ALBM : 0
THRESHOLD : 0
SLY : 255
WID0 : 0
WID1 : 0
WID2 : 0
WID3 : 0
OFS0 : 0
OFS1 : 0
OFS2 : 0
OFS3 : 0
SXYS : false
CRE : false
DEC_SEL2 : false
0x02700580 CH-I#22_0 0x0001fc0f'e1001800'00000000'00000000'00000000
XV : 0
YV : 0
XB : 0
YB : 0
NSB_B : false
CF : even
SX : 0
SY : 0
NS : 0
SDX : 0
SM : 0
SCC : false
SCE : false
SDY : 0
SDRX : false
SDRY : false
BPP : 16 bpp
DEC_SEL : 0-15
DIM : 2d
SO : progressive
BNDM : no bands
BM : no block mode
ROT : false
HFLIP : true
VFLIP : false
THE : false
CAP : false
CAE : false
FW : 127
FH : 127
EOLI : false
0x027005a0 CH-I#22_1 0x00000000'00003fc0'0103c000'00000000'06039000
EBA0 : 0x06039000
EBA1 : 0x00000000
ILO : 0
NPB : 15
ALU : false
ALBM : 0
THRESHOLD : 0
SLY : 255
WID0 : 0
WID1 : 0
WID2 : 0
WID3 : 0
OFS0 : 0
OFS1 : 0
OFS2 : 0
OFS3 : 0
SXYS : false
CRE : false
DEC_SEL2 : false
