IMX8QXP - Configuring A35 as RPMSG Slave
1,477 次查看
jithesh77
Please confirm on the procedure IMX8QXP - Configuring A35 core as RPMSG Slave. I am planning to use M4 core as Master. Is it possible . Could you please confirm the procedure.
Jithesh
1,461 次查看
igorpadykov
Hi Jithesh
currently nxp linux bsps support only A35 as master (linux side), though seems in theory
it is possible to use A35 as slave. Also from rpmsg documentation on below link it is possible
to initiate transfer from slave side too:
https://www.programmersought.com/article/16266958328/
1,450 次查看
jithesh77
Hi Igor,
Thanks for the quick update .
Regarding Name Service Announce message, currently nxp linux bsps support  NS Announcement handling by default? . In my understanding linux side is supporting only dynamic channel creation through NS Announcements from remote core. Is my understanding correct ?
Is it possible to initiate NS Announcement from Slave M4 . Linux bsp accepts the Announcement from slave even if it act as RPMsg master.
Could you please confirm.
Jithesh
