IMX8MM-EVK audio jack
2,665 次查看
saurabhprajapati
Hi, I am working on IMX8MM-EVK(lpddr4) board, with Yocto build of 6.1.55-2.2.0 kernel version,
I am working on audio codec(audio Jack(J401)) on the EVK board
While Booting the board I am getting below log in the picture "No soundcards found"
Can I get a help to enable audio card, so that I can play an audio file and can here over audio jack J401 using head phone.
4 回复数
2,611 次查看
JorgeCas
The process will be similar, there is no need to use the i.MX 8MIC-RPI-MX8 board, just use the default device tree on the demo image.
You should use "wm8524-audio" card.
The TLV320AIC31XX audio CODEC is not supported by default on our BSP. To use this CODEC to your system, you need to add a third-party driver provided by Texas Instruments and configure your device tree.
Unfortunately, there is not a guide to port this specific CODEC to the BSP. The references we have are the i.MX porting guide and EVK device tree (WM8524).
Best regards.
2,622 次查看
saurabhprajapati
I want to configure tlv320aic31xx audio codec on IMX8MM-EVK(lpddr4)  board, to work on Voice Intelligent Technology  application. So can I get to know what are the change I have to make in Device Tree & Kernel.
Kernel Version: 6.1.55-2.2.0
2,628 次查看
saurabhprajapati
I am not using i.MX 8MIC-RPI-MX8 Board,  I am just trying to play an audio file using aplay command, and trying to listen using headphone over 3.5mm audio jack (j401) on the board.
2,643 次查看
JorgeCas
I suggest you take a look on the next post.
Best regards.
