Multiple PCIe endpoint devices. How to connecto to IMX8MPLUS EVK
nachus001
Dear technical team
Dear technical team
I'm designing hardware for the IMX8MPLUS processor and in this stage I'm working with the devkit.
I need to know how can I connect PCIe devices to the 8MPLUSLPD4-EVK. My idea is to use an ASIX AX99100A multiport PCIe device, a Microchip LAN7430 PCIe ethernet IC and probably 2 or more M.2 2230 flash SSD (NVM PCIe, not SATA)
From the devkit schematics is not very clear how to do this. I know that I will need some sort of adaptor, but I can't realize what other IC's or connections I will need. Do you have an app note about the IMX8 PCIe ports and how to add peripherals?
Thanks in advance
Ignacio
