IMX7D ENET1 questions
1,369 次查看
xingjianliao
I want to configure ENET1 as MII mode;
but i have some questions
1.which pad configure as MII_TXEN
2.which pad configure as MII_RXDV
The following picture shows the PADS configuration in MII mode,is that correct?
标记 (1)
1,287 次查看
igorpadykov
Hi Xingjian
1,288 次查看
igorpadykov
Hi Xingjian
1,287 次查看
xingjianliao
Hi  igorpadykov
Thanks so much for your answer!
