This document also mentions only I.MX8 Quad Max EVK, but it has images for the MEK board also.
1. Can I follow the same steps mentioned in the document to run android and linux on the I.MX Quad Max MEK ?
A: Yes, you can use this version and following the document but you need to run the Android P9.0.0_1.0.2-AUTO version BSP.
2. What is the latest android version for android automotive that will support xen with linux on I.MX Quad Max MEK?
A:Just stop at the version mentioned in the document.
