I.MX7 power sequencing
3,625 次查看
NIKHITHAANTONY
In the datasheet of I.MX7 it is given that, VDD_SOC should powerup before NVCC_DRAM and NVCC_DRAM_CKE. So whether it can be done by software. In hardware design, whether we need to take care anything for delaying NVCC_DRAM and NVCC_DRAM_CKE
5 回复数
3,607 次查看
NIKHITHAANTONY
Then How VDD_SOC will become high before NVCC_DRAM and NVCC_DRAM_CKE.
3,601 次查看
igorpadykov
in hardware. Use appropriate PMIC with power-up sequence compatible with i.MX7D datasheet
requirements.
3,593 次查看
NIKHITHAANTONY
We designed I.MX7 processor as per SABRE board. In that PMIC PF3000 is used.
So there will be correct power sequencing..right?
3,588 次查看
igorpadykov
right
3,613 次查看
igorpadykov
Hi NIKHITHA
>whether it can be done by software..
no
no need.
