I.MX7 power sequencing
Search instead for
NIKHITHAANTONY
In the datasheet of I.MX7 it is given that, VDD_SOC should powerup before NVCC_DRAM and NVCC_DRAM_CKE. So whether it can be done by software. In hardware design, whether we need to take care anything for delaying NVCC_DRAM and NVCC_DRAM_CKE
NIKHITHAANTONY
Then How VDD_SOC will become high before NVCC_DRAM and NVCC_DRAM_CKE.
in hardware. Use appropriate PMIC with power-up sequence compatible with i.MX7D datasheet
requirements.
NIKHITHAANTONY
We designed I.MX7 processor as per SABRE board. In that PMIC PF3000 is used.
So there will be correct power sequencing..right?
right
Hi NIKHITHA
>whether it can be done by software..
no
no need.
