I.MX7 power sequencing
2,441件の閲覧回数
NIKHITHAANTONY
In the datasheet of I.MX7 it is given that, VDD_SOC should powerup before NVCC_DRAM and NVCC_DRAM_CKE. So whether it can be done by software. In hardware design, whether we need to take care anything for delaying NVCC_DRAM and NVCC_DRAM_CKE
5 返答(返信)
2,423件の閲覧回数
NIKHITHAANTONY
Then How VDD_SOC will become high before NVCC_DRAM and NVCC_DRAM_CKE.
2,417件の閲覧回数
igorpadykov
in hardware. Use appropriate PMIC with power-up sequence compatible with i.MX7D datasheet
requirements.
2,409件の閲覧回数
NIKHITHAANTONY
We designed I.MX7 processor as per SABRE board. In that PMIC PF3000 is used.
So there will be correct power sequencing..right?
2,404件の閲覧回数
igorpadykov
right
2,429件の閲覧回数
igorpadykov
Hi NIKHITHA
>whether it can be done by software..
no
no need.
