How to run and debug an example "hello world" program in FRDM IMX93 from VS Code with MCUXpresso
Shanmugapriya
I have successfully built the example Hello World code and would like to run and debug it on the Cortex-M33 core, validating the output in the console.
Based on the knowledge base, I removed the two resistors to enable the SWD debugger and reworked the board for a 1.8 V VTref. The boot switches are configured in 1001 mode.
I am encountering the attached error when using the J-Link Commander.
Additionally, when attempting to debug from VS Code, I encounter the same issue and the debug session fails.
Could you please help me identify and resolve these errors?
Thank you for your support.
Chavira
Hi @Shanmugapriya,
You can purchase a 10 k, 0402 resistor with ±1% tolerance from your local electronic components distributor.
There is nothing special or custom about this part, it is a standard 10 kΩ resistor.
Chavira
Chavira
Hi @Shanmugapriya,
Thank you for contacting NXP Support.
Please refer to this guide for detailed instructions. It includes a step-by-step procedure to debug the FRDM board.
Although the reference guide uses an MCU-Link Pro, the same steps apply when using J-Link debuggers, as the debugging process is equivalent.
If you have any questions while following the guide, please let us know.
Chavira
Shanmugapriya
Hi @Chavira ,
I am facing such an error when "fastboot 0" is commanded.
Shanmugapriya
Hi @Chavira
Could you please clarify the correct position of the boot switch SW1 for the steps mentioned in the link you shared: Getting Started with FRDM-IMX93 and MCU-LINK Pro for M Core Debugging - NXP Community
Thanks.
Chavira
Hi @Shanmugapriya,
The position of SW1 depends on whether the system is booting from eMMC or from the SD card. Please ensure SW1 is set according to the selected boot source.
The message “Failed to configure default pinctrl” is expected behavior and can be safely ignored. It does not indicate a functional issue.
On the FRDM board, the resistors that need to be removed are R3017 and R3018.
Please refer to the board image or schematic to verify their exact location before removal.
Chavira
Shanmugapriya
Thank you, @Chavira. If the error "Failed to configure default pinctrl" can be safely ignored, I will proceed with the steps and update the status.
Shanmugapriya
Shanmugapriya
Hi @Chavira ,
While checking the layout screenshot, I accidentally removed the wrong resistor — R403 (10 kΩ) instead of R3018. I seem to have misplaced the tiny resistor. Where can I source a replacement for this component?
Chavira
Hi @Shanmugapriya,
Chavira
Shanmugapriya
Hi @Chavira
Thank you. I will check and resolder the resistor.
Shanmugapriya
Hi @Chavira
I’ve followed the steps up to “Launch the M Core from U‑Boot Terminal”, and the output from that step matches what the guide describes.
After this, I connected a J-Link probe to the board using the pins specified in the guide: SWCLK, DIO, Vref (3.3 V), and GND.
Then, in VS Code, I selected the debug configuration.
Below is my launch.json:
This is my launch.json file contents
  "configurations": [
      "type": "mcuxpresso-debug",
      "name": "Debug",
      "request": "launch",
      "cwd": "${workspaceFolder}",
      "executable": {
        "elf": "D:/NXP_SDKs/SDK_25_12_00_MCIMX93-EVK/mcuxsdk/examples/demo_apps/hello_world/debug/hello_world_cm33.elf"
      // Launch mode = "load + reset + halt @ main"
      "isAttach": false,
      "stopAtSymbol": "main",
      "skipBuildBeforeDebug": false,
      // Your probe S/N
      "probeSerialNumber": "801023331",
      "gdbInitCommands": [
        "set remotetimeout 600",
        "set debug-file-directory",
        "set non-stop off"
        // Helpful with i.MX93/J-Link "no generic reset":
      "gdbServerConfigs": {
        "linkserver": {},
        "segger": {
          // i.MX93 M33 device name in J-Link
          "device": "MIMX9352_M33",
          "interface": "SWD",
          "speed": "1000",               // start conservative; increase later (e.g., 4000)
          "reset": "halt",
          "serialNumber": "801023331",
          "core": 0,
          "logFile": "${workspaceFolder}/.vscode/jlink_gdbserver.log"
        "pemicro": {}
      "showDevDebugOutput": "raw"
When I start debugging from VS Code, I get the following error:
 Note: For this test, both P1 and P16 USB ports were connected, along with the J-Link probe.
Please let me know if you need any additional details to help diagnose the issue.
Shanmugapriya
Hi @Chavira
Thanks for sharing the steps. While following them, I noticed that the resistor indicated by the red arrow does not have continuity to the SW_CLK pin. Earlier, based on a community post, I had already removed two resistors.
After checking continuity from the SW_CLK and SW_DIO pins, I found that the resistors actually connected to these lines are the ones marked with the yellow arrows, and I removed those instead.
Could someone please confirm which specific resistor(s) should be removed for SWD access—the ones marked in red, or the ones marked in yellow?
%3CLINGO-SUB%20id%3D%22lingo-sub-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20have%20successfully%20built%20the%20example%20%3C%2FSPAN%3E%3CEM%3E%3CSPAN%3EHello%20World%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%3E%20code%20and%20would%20like%20to%20run%20and%20debug%20it%20on%20the%20Cortex-M33%20core%2C%20validating%20the%20output%20in%20the%20console.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBased%20on%20the%20knowledge%20base%2C%20I%20removed%20the%20two%20resistors%20to%20enable%20the%20SWD%20debugger%20and%20reworked%20the%20board%20for%20a%201.8%20V%20VTref.%20The%20boot%20switches%20are%20configured%20in%20%3CSTRONG%3E1001%3C%2FSTRONG%3E%20mode.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20am%20encountering%20the%20attached%20error%20when%20using%20the%20J-Link%20Commander.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374614i317AA68D3CDAB842%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769601176741.png%22%20alt%3D%22Shanmugapriya_0-1769601176741.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_0-1769601176741.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAdditionally%2C%20when%20attempting%20to%20debug%20from%20VS%20Code%2C%20I%20encounter%20the%20same%20issue%20and%20the%20debug%20session%20fails.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374615i6A374C33FC692B2B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1769601243673.png%22%20alt%3D%22Shanmugapriya_1-1769601243673.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_1-1769601243673.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20you%20please%20help%20me%20identify%20and%20resolve%20these%20errors%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%20for%20your%20support.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CDIV%3ECould%20you%20please%20clarify%20the%20correct%20position%20of%20the%20boot%20switch%20%3CSTRONG%3ESW1%3C%2FSTRONG%3E%20for%20the%20steps%20mentioned%20in%20the%20link%20you%20shared%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_blank%22%3EGetting%20Started%20with%20FRDM-IMX93%20and%20MCU-LINK%20Pro%20for%20M%20Core%20Debugging%20-%20NXP%20Community%3C%2FA%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CDIV%3E%3CP%3EThanks%20for%20sharing%20the%20steps.%20While%20following%20them%2C%20I%20noticed%20that%20the%20resistor%20indicated%20by%20the%20red%20arrow%20does%20%3CSTRONG%3Enot%3C%2FSTRONG%3E%20have%20continuity%20to%20the%20%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%20pin.%20Earlier%2C%20based%20on%20a%20community%20post%2C%20I%20had%20already%20removed%20two%20resistors.%3C%2FP%3E%3CP%3EAfter%20checking%20continuity%20from%20the%20%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ESW_DIO%3C%2FSTRONG%3E%20pins%2C%20I%20found%20that%20the%20resistors%20actually%20connected%20to%20these%20lines%20are%20the%20ones%20marked%20with%20the%20%3CSTRONG%3Eyellow%20arrows%3C%2FSTRONG%3E%2C%20and%20I%20removed%20those%20instead.%3C%2FP%3E%3CP%3ECould%20someone%20please%20confirm%20which%20specific%20resistor(s)%20should%20be%20removed%20for%20SWD%20access%E2%80%94the%20ones%20marked%20in%20%3CSTRONG%3Ered%3C%2FSTRONG%3E%2C%20or%20the%20ones%20marked%20in%20%3CSTRONG%3Eyellow%3C%2FSTRONG%3E%3F%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374703i5AE2F02D72990C4E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769664672182.png%22%20alt%3D%22Shanmugapriya_0-1769664672182.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_0-1769664672182.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20NXP%20Support.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EPlease%20refer%20to%20this%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_self%22%3Eguide%3C%2FA%3E%20for%20detailed%20instructions.%20It%20includes%20a%20step-by-step%20procedure%20to%20debug%20the%20FRDM%20board.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EAlthough%20the%20reference%20guide%20uses%20an%20MCU-Link%20Pro%2C%20the%20same%20steps%20apply%20when%20using%20J-Link%20debuggers%2C%20as%20the%20debugging%20process%20is%20equivalent.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EIf%20you%20have%20any%20questions%20while%20following%20the%20guide%2C%20please%20let%20us%20know.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20regards%2C%3CBR%20%2F%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20am%20facing%20such%20an%20error%20when%20%22fastboot%200%22%20is%20commanded.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374802iCB7327A1ACF222A2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769685894527.png%22%20alt%3D%22Shanmugapriya_0-1769685894527.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_0-1769685894527.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20position%20of%20SW1%20depends%20on%20whether%20the%20system%20is%20booting%20from%20eMMC%20or%20from%20the%20SD%20card.%20Please%20ensure%20SW1%20is%20set%20according%20to%20the%20selected%20boot%20source.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EThe%20message%20%E2%80%9CFailed%20to%20configure%20default%20pinctrl%E2%80%9D%20is%20expected%20behavior%20and%20can%20be%20safely%20ignored.%20It%20does%20not%20indicate%20a%20functional%20issue.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EOn%20the%20FRDM%20board%2C%20the%20resistors%20that%20need%20to%20be%20removed%20are%20R3017%20and%20R3018.%3CBR%20%2F%3EPlease%20refer%20to%20the%20board%20image%20or%20schematic%20to%20verify%20their%20exact%20location%20before%20removal.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375171i2CD2530B0AE4D723%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1770039931783.png%22%20alt%3D%22Chavira_1-1770039931783.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChavira_1-1770039931783.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThank%20you%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E.%20If%20the%20error%20%22%3CSPAN%3EFailed%20to%20configure%20default%20pinctrl%22%20can%20be%20safely%20ignored%2C%20I%20will%20proceed%20with%20the%20steps%20and%20update%20the%20status.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20Regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EShanmugapriya%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYou%20can%20purchase%20a%2010%20k%2C%200402%20resistor%20with%20%C2%B11%25%20tolerance%20from%20your%20local%20electronic%20components%20distributor.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EThere%20is%20nothing%20special%20or%20custom%20about%20this%20part%2C%20it%20is%20a%20standard%2010%20k%CE%A9%20resistor.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20regards%2C%3CBR%20%2F%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CDIV%3EWhile%20checking%20the%20layout%20screenshot%2C%20I%20accidentally%20removed%20the%20wrong%20resistor%20%E2%80%94%20R403%20(10%20k%CE%A9)%20instead%20of%20R3018.%20I%20seem%20to%20have%20misplaced%20the%20tiny%20resistor.%20Where%20can%20I%20source%20a%20replacement%20for%20this%20component%3F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you.%20I%20will%20check%20and%20resolder%20the%20resistor.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CDIV%3EI%E2%80%99ve%20followed%20the%20steps%20up%20to%20%3CSTRONG%3E%E2%80%9CLaunch%20the%20M%20Core%20from%20U%E2%80%91Boot%20Terminal%E2%80%9D%3C%2FSTRONG%3E%2C%20and%20the%20output%20from%20that%20step%20matches%20what%20the%20guide%20describes.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377145i0E7DF4711A1108FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1771417183138.png%22%20alt%3D%22Shanmugapriya_0-1771417183138.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_0-1771417183138.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CP%3EAfter%20this%2C%20I%20connected%20a%20J-Link%20probe%20to%20the%20board%20using%20the%20pins%20specified%20in%20the%20guide%3A%20%3CSTRONG%3ESWCLK%2C%20DIO%2C%20Vref%20(3.3%20V)%2C%20and%20GND%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EThen%2C%20in%20VS%20Code%2C%20I%20selected%20the%20debug%20configuration.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377146i082D12C04DB96668%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1771417284863.png%22%20alt%3D%22Shanmugapriya_1-1771417284863.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_1-1771417284863.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBelow%20is%20my%20%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%3A%3C%2FP%3E%3CP%3EThis%20is%20my%20launch.json%20file%20contents%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22configurations%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22type%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22mcuxpresso-debug%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22name%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22Debug%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22request%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22launch%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22cwd%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BworkspaceFolder%7D%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22executable%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22elf%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22D%3A%2FNXP_SDKs%2FSDK_25_12_00_MCIMX93-EVK%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%2Fdebug%2Fhello_world_cm33.elf%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20Launch%20mode%20%3D%20%22load%20%2B%20reset%20%2B%20halt%20%40%20main%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22isAttach%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22stopAtSymbol%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22main%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22skipBuildBeforeDebug%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20Your%20probe%20S%2FN%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22probeSerialNumber%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22801023331%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbInitCommands%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20remotetimeout%20600%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20debug-file-directory%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20non-stop%20off%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20Helpful%20with%20i.MX93%2FJ-Link%20%22no%20generic%20reset%22%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerConfigs%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22linkserver%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22segger%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20i.MX93%20M33%20device%20name%20in%20J-Link%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22device%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22MIMX9352_M33%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22interface%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22SWD%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22speed%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%221000%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20start%20conservative%3B%20increase%20later%20(e.g.%2C%204000)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22reset%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22halt%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22serialNumber%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22801023331%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22core%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22logFile%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BworkspaceFolder%7D%2F.vscode%2Fjlink_gdbserver.log%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22pemicro%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22showDevDebugOutput%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22raw%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3EWhen%20I%20start%20debugging%20from%20VS%20Code%2C%20I%20get%20the%20following%20error%3A%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377148iF43078ECB46E7718%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_2-1771417393340.png%22%20alt%3D%22Shanmugapriya_2-1771417393340.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_2-1771417393340.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377149i3593B0330A6CD6E4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_3-1771417442590.png%22%20alt%3D%22Shanmugapriya_3-1771417442590.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_3-1771417442590.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377150i847ACA5E6D011DFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_4-1771417459147.png%22%20alt%3D%22Shanmugapriya_4-1771417459147.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EShanmugapriya_4-1771417459147.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3BNote%3A%26nbsp%3BFor%20this%20test%2C%20both%20%3CSTRONG%3EP1%20and%20P16%20USB%20ports%3C%2FSTRONG%3E%20were%20connected%2C%20along%20with%20the%20%3CSTRONG%3EJ-Link%20probe%3C%2FSTRONG%3E.%3C%2FP%3E%3CDIV%3E%3CDIV%3EPlease%20let%20me%20know%20if%20you%20need%20any%20additional%20details%20to%20help%20diagnose%20the%20issue.%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
