How to run and debug an example "hello world" program in FRDM IMX93 from VS Code with MCUXpresso
3,476 次查看
Shanmugapriya
I have successfully built the example Hello World code and would like to run and debug it on the Cortex-M33 core, validating the output in the console.
Based on the knowledge base, I removed the two resistors to enable the SWD debugger and reworked the board for a 1.8 V VTref. The boot switches are configured in 1001 mode.
I am encountering the attached error when using the J-Link Commander.
Additionally, when attempting to debug from VS Code, I encounter the same issue and the debug session fails.
Could you please help me identify and resolve these errors?
Thank you for your support.
标记 (1)
3,243 次查看
Chavira
Hi @Shanmugapriya,
You can purchase a 10 k, 0402 resistor with ±1% tolerance from your local electronic components distributor.
There is nothing special or custom about this part, it is a standard 10 kΩ resistor.
Chavira
10 回复数
3,450 次查看
Chavira
Hi @Shanmugapriya,
Thank you for contacting NXP Support.
Please refer to this guide for detailed instructions. It includes a step-by-step procedure to debug the FRDM board.
Although the reference guide uses an MCU-Link Pro, the same steps apply when using J-Link debuggers, as the debugging process is equivalent.
If you have any questions while following the guide, please let us know.
Chavira
3,423 次查看
Shanmugapriya
Hi @Chavira ,
I am facing such an error when "fastboot 0" is commanded.
3,433 次查看
Shanmugapriya
Hi @Chavira
Could you please clarify the correct position of the boot switch SW1 for the steps mentioned in the link you shared: Getting Started with FRDM-IMX93 and MCU-LINK Pro for M Core Debugging - NXP Community
Thanks.
3,384 次查看
Chavira
Hi @Shanmugapriya,
The position of SW1 depends on whether the system is booting from eMMC or from the SD card. Please ensure SW1 is set according to the selected boot source.
The message “Failed to configure default pinctrl” is expected behavior and can be safely ignored. It does not indicate a functional issue.
On the FRDM board, the resistors that need to be removed are R3017 and R3018.
Please refer to the board image or schematic to verify their exact location before removal.
Chavira
3,372 次查看
Shanmugapriya
Thank you, @Chavira. If the error "Failed to configure default pinctrl" can be safely ignored, I will proceed with the steps and update the status.
Shanmugapriya
3,278 次查看
Shanmugapriya
Hi @Chavira ,
While checking the layout screenshot, I accidentally removed the wrong resistor — R403 (10 kΩ) instead of R3018. I seem to have misplaced the tiny resistor. Where can I source a replacement for this component?
3,244 次查看
Chavira
Hi @Shanmugapriya,
Chavira
3,200 次查看
Shanmugapriya
Hi @Chavira
Thank you. I will check and resolder the resistor.
3,033 次查看
Shanmugapriya
Hi @Chavira
I’ve followed the steps up to “Launch the M Core from U‑Boot Terminal”, and the output from that step matches what the guide describes.
After this, I connected a J-Link probe to the board using the pins specified in the guide: SWCLK, DIO, Vref (3.3 V), and GND.
Then, in VS Code, I selected the debug configuration.
Below is my launch.json:
This is my launch.json file contents
  "configurations": [
      "type": "mcuxpresso-debug",
      "name": "Debug",
      "request": "launch",
      "cwd": "${workspaceFolder}",
      "executable": {
        "elf": "D:/NXP_SDKs/SDK_25_12_00_MCIMX93-EVK/mcuxsdk/examples/demo_apps/hello_world/debug/hello_world_cm33.elf"
      // Launch mode = "load + reset + halt @ main"
      "isAttach": false,
      "stopAtSymbol": "main",
      "skipBuildBeforeDebug": false,
      // Your probe S/N
      "probeSerialNumber": "801023331",
      "gdbInitCommands": [
        "set remotetimeout 600",
        "set debug-file-directory",
        "set non-stop off"
        // Helpful with i.MX93/J-Link "no generic reset":
      "gdbServerConfigs": {
        "linkserver": {},
        "segger": {
          // i.MX93 M33 device name in J-Link
          "device": "MIMX9352_M33",
          "interface": "SWD",
          "speed": "1000",               // start conservative; increase later (e.g., 4000)
          "reset": "halt",
          "serialNumber": "801023331",
          "core": 0,
          "logFile": "${workspaceFolder}/.vscode/jlink_gdbserver.log"
        "pemicro": {}
      "showDevDebugOutput": "raw"
When I start debugging from VS Code, I get the following error:
 Note: For this test, both P1 and P16 USB ports were connected, along with the J-Link probe.
Please let me know if you need any additional details to help diagnose the issue.
3,434 次查看
Shanmugapriya
Hi @Chavira
Thanks for sharing the steps. While following them, I noticed that the resistor indicated by the red arrow does not have continuity to the SW_CLK pin. Earlier, based on a community post, I had already removed two resistors.
After checking continuity from the SW_CLK and SW_DIO pins, I found that the resistors actually connected to these lines are the ones marked with the yellow arrows, and I removed those instead.
Could someone please confirm which specific resistor(s) should be removed for SWD access—the ones marked in red, or the ones marked in yellow?
%3CLINGO-SUB%20id%3D%22lingo-sub-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E4%BB%8E%20VS%20%E4%BB%A3%E7%A0%81%E5%9C%A8%20FRDM%20IMX93%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E5%92%8C%E8%B0%83%E8%AF%95%22hello%20world%22%20%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%E4%BA%86%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%20%3CEM%3E%3CSPAN%3EHello%20World%3C%2FSPAN%3E%3C%2FEM%3E%20%3CSPAN%3E%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B9%B6%E6%83%B3%E5%9C%A8%20Cortex-M33%20%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%92%8C%E8%B0%83%E8%AF%95%E5%AE%83%EF%BC%8C%E9%AA%8C%E8%AF%81%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E7%9A%84%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%A0%B9%E6%8D%AE%E7%9F%A5%E8%AF%86%E5%BA%93%EF%BC%8C%E6%88%91%E7%A7%BB%E9%99%A4%E4%BA%86%E4%B8%A4%E4%B8%AA%E7%94%B5%E9%98%BB%E5%99%A8%E4%BB%A5%E5%90%AF%E7%94%A8%20SWD%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E5%B9%B6%E5%B0%86%E6%9D%BF%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%E4%B8%BA%201.8%20V%20VTref%E3%80%82%E5%90%AF%E5%8A%A8%E4%BA%A4%E6%8D%A2%E6%9C%BA%E9%85%8D%E7%BD%AE%E4%B8%BA%20%3CSTRONG%3E1001%3C%2FSTRONG%3E%20%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%20J-Link%20Commander%20%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E6%89%80%E9%99%84%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374614i317AA68D3CDAB842%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769601176741.png%22%20alt%3D%22Shanmugapriya_0-1769601176741.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%20VS%20%E4%BB%A3%E7%A0%81%E4%B8%AD%E8%B0%83%E8%AF%95%E6%97%B6%EF%BC%8C%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374615i6A374C33FC692B2B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1769601243673.png%22%20alt%3D%22Shanmugapriya_1-1769601243673.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E6%88%91%E8%AF%86%E5%88%AB%E5%B9%B6%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%E5%AF%B9%E4%BA%8E%E4%BD%A0%E5%88%86%E4%BA%AB%E7%9A%84%E9%93%BE%E6%8E%A5%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%90%A6%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%E5%90%AF%E5%8A%A8%E5%BC%80%E5%85%B3%20%3CSTRONG%3ESW1%3C%2FSTRONG%3E%20%E7%9A%84%E6%AD%A3%E7%A1%AE%E4%BD%8D%E7%BD%AE%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_blank%22%3E%E7%94%A8%E4%BA%8E%20M%20Core%20%E8%B0%83%E8%AF%95%E7%9A%84%20FRDM-IMX93%20%E5%92%8C%20MCU-LINK%20Pro%20%E5%85%A5%E9%97%A8%E2%80%94%E2%80%94%E6%81%A9%E6%99%BA%3C%2FA%3E%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%88%86%E4%BA%AB%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E3%80%82%E5%9C%A8%E8%B7%9F%E8%B8%AA%E5%AE%83%E4%BB%AC%E6%97%B6%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E7%BA%A2%E8%89%B2%E7%AE%AD%E5%A4%B4%E6%89%80%E6%8C%87%E7%9A%84%E7%94%B5%E9%98%BB%E4%B8%8E%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%E5%BC%95%E8%84%9A%3CSTRONG%3E%E4%B8%8D%3C%2FSTRONG%3E%E8%BF%9E%E7%BB%AD%E3%80%82%E6%97%A9%E4%BA%9B%E6%97%B6%E5%80%99%EF%BC%8C%E6%A0%B9%E6%8D%AE%E4%B8%80%E4%B8%AA%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8B%86%E9%99%A4%E4%BA%86%E4%B8%A4%E4%B8%AA%E7%94%B5%E9%98%BB%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%A3%80%E6%9F%A5%E4%BA%86%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3ESW_DIO%3C%2FSTRONG%3E%E5%BC%95%E8%84%9A%E7%9A%84%E8%BF%9E%E7%BB%AD%E6%80%A7%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%AE%9E%E9%99%85%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BF%99%E4%BA%9B%E7%BA%BF%E8%B7%AF%E4%B8%8A%E7%9A%84%E7%94%B5%E9%98%BB%E5%99%A8%E6%98%AF%3CSTRONG%3E%E9%BB%84%E8%89%B2%E7%AE%AD%E5%A4%B4%3C%2FSTRONG%3E%E6%A0%87%E8%AE%B0%E7%9A%84%E9%82%A3%E4%BA%9B%EF%BC%8C%E4%BA%8E%E6%98%AF%E6%88%91%E6%8B%86%E9%99%A4%E4%BA%86%E8%BF%99%E4%BA%9B%E7%94%B5%E9%98%BB%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%81%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%8E%A5%E5%85%A5%20SWD%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%8B%86%E9%99%A4%E5%93%AA%E4%B8%AA%E7%94%B5%E9%98%BB%E5%99%A8--%3CSTRONG%3E%E7%BA%A2%E8%89%B2%3C%2FSTRONG%3E%E6%A0%87%E8%AE%B0%E7%9A%84%E7%94%B5%E9%98%BB%E5%99%A8%EF%BC%8C%E8%BF%98%E6%98%AF%3CSTRONG%3E%E9%BB%84%E8%89%B2%3C%2FSTRONG%3E%E6%A0%87%E8%AE%B0%E7%9A%84%E7%94%B5%E9%98%BB%E5%99%A8%EF%BC%9F%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374703i5AE2F02D72990C4E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769664672182.png%22%20alt%3D%22Shanmugapriya_0-1769664672182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%81%94%E7%B3%BB%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%B8%AD%E5%BF%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_self%22%3E%E6%8C%87%E5%8D%97%3C%2FA%3E%E3%80%82%E5%AE%83%E5%8C%85%E6%8B%AC%E8%B0%83%E8%AF%95%20FRDM%20%E6%9D%BF%E7%9A%84%E5%88%86%E6%AD%A5%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E5%B0%BD%E7%AE%A1%E5%8F%82%E8%80%83%E6%8C%87%E5%8D%97%E4%BD%BF%E7%94%A8%E4%BA%86%20MCU-Link%20Pro%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%BD%BF%E7%94%A8%20J-Link%20%E8%B0%83%E8%AF%95%E5%99%A8%E6%97%B6%EF%BC%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E6%AD%A5%E9%AA%A4%E4%B9%9F%E9%80%82%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%B0%83%E8%AF%95%E8%BF%87%E7%A8%8B%E6%98%AF%E7%AD%89%E6%95%88%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E9%81%B5%E5%BE%AA%E6%8C%87%E5%8D%97%E6%97%B6%E6%9C%89%E4%BB%BB%E4%BD%95%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40%20Chavira%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E5%BD%93%E5%91%BD%E4%BB%A4%22fastboot%200%22%20%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374802iCB7327A1ACF222A2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769685894527.png%22%20alt%3D%22Shanmugapriya_0-1769685894527.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%E3%80%82%E5%A6%82%E6%9E%9C%3CSPAN%3E%E5%8F%AF%E4%BB%A5%E5%AE%89%E5%85%A8%E5%9C%B0%E5%BF%BD%E7%95%A5%3C%2FSPAN%3E%20%22Failedto%20configure%20default%20pinctrl%22%20%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E5%B0%86%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E6%AD%A5%E9%AA%A4%E5%B9%B6%E6%9B%B4%E6%96%B0%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EShanmugapriya%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ESW1%20%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%8F%96%E5%86%B3%E4%BA%8E%E7%B3%BB%E7%BB%9F%E6%98%AF%E4%BB%8E%20eMMC%20%E8%BF%98%E6%98%AF%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E3%80%82%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%A0%B9%E6%8D%AE%E9%80%89%E5%AE%9A%E7%9A%84%E5%90%AF%E5%8A%A8%E6%BA%90%E8%AE%BE%E7%BD%AE%20SW1%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E9%85%8D%E7%BD%AE%E9%BB%98%E8%AE%A4%20pinctrl%20%E5%A4%B1%E8%B4%A5%20%22%E6%B6%88%E6%81%AF%E6%98%AF%E9%A2%84%E6%9C%9F%E8%A1%8C%E4%B8%BA%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%94%BE%E5%BF%83%E5%BF%BD%E7%95%A5%E3%80%82%E8%BF%99%E5%B9%B6%E4%B8%8D%E8%A1%A8%E6%98%8E%E5%AD%98%E5%9C%A8%E5%8A%9F%E8%83%BD%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E5%9C%A8%20FRDM%20%E6%9D%BF%E4%B8%8A%EF%BC%8C%E9%9C%80%E8%A6%81%E7%A7%BB%E9%99%A4%E7%9A%84%E7%94%B5%E9%98%BB%E5%99%A8%E6%98%AF%20R3017%20%E5%92%8C%20R3018%E3%80%82%3CBR%20%2F%3E%E6%8B%86%E5%8D%B8%E5%89%8D%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E6%9D%BF%E5%9B%BE%E5%83%8F%E6%88%96%E7%A4%BA%E6%84%8F%E5%9B%BE%E4%BB%A5%E9%AA%8C%E8%AF%81%E5%85%B6%E7%A1%AE%E5%88%87%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375171i2CD2530B0AE4D723%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1770039931783.png%22%20alt%3D%22Chavira_1-1770039931783.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E6%9F%A5%E7%BB%B4%E6%8B%89%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E5%BD%93%E5%9C%B0%E7%9A%84%E7%94%B5%E5%AD%90%E5%85%83%E5%99%A8%E4%BB%B6%E4%BB%A3%E7%90%86%E5%95%86%E5%A4%84%E8%B4%AD%E4%B9%B0%E5%AE%B9%E5%B7%AE%E4%B8%BA%C2%B1%201%25%20%E7%9A%84%2010%20k%2C%200402%20%E7%94%B5%E9%98%BB%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E9%83%A8%E4%BB%B6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E7%89%B9%E6%AE%8A%E6%88%96%E5%AE%9A%E5%88%B6%E4%B9%8B%E5%A4%84%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E6%A0%87%E5%87%86%E7%9A%84%2010%20k%CE%A9%20%E7%94%B5%E9%98%BB%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40%20Chavira%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CDIV%3E%E5%9C%A8%E6%A3%80%E6%9F%A5%E5%B8%83%E5%B1%80%E6%88%AA%E5%9B%BE%E6%97%B6%EF%BC%8C%E6%88%91%E4%B8%8D%E5%B0%8F%E5%BF%83%E7%A7%BB%E9%99%A4%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E7%9A%84%E7%94%B5%E9%98%BB%20-%20R403%EF%BC%8810%20k%CE%A9%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20R3018%E3%80%82%E6%88%91%E5%A5%BD%E5%83%8F%E6%8A%8A%E5%B0%8F%E7%94%B5%E9%98%BB%E6%94%BE%E9%94%99%E4%BA%86%E5%9C%B0%E6%96%B9%E3%80%82%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E8%BF%99%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%9F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%E6%88%91%E4%BC%9A%E6%A3%80%E6%9F%A5%E5%B9%B6%E9%87%8D%E6%96%B0%E7%84%8A%E6%8E%A5%E7%94%B5%E9%98%BB%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8C%89%E7%85%A7%E4%BA%86%20%3CSTRONG%3E%E2%80%9C%E4%BB%8E%20U%E2%80%91Boot%20%E7%BB%88%E7%AB%AF%E5%90%AF%E5%8A%A8%20M%20Core%E2%80%9D%3C%2FSTRONG%3E%20%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E8%AF%A5%E6%AD%A5%E9%AA%A4%E7%9A%84%E8%BE%93%E5%87%BA%E4%B8%8E%E6%8C%87%E5%8D%97%E6%8F%8F%E8%BF%B0%E7%9A%84%E7%9B%B8%E7%AC%A6%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377145i0E7DF4711A1108FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1771417183138.png%22%20alt%3D%22Shanmugapriya_0-1771417183138.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E6%8C%87%E5%8D%97%E4%B8%AD%E6%8C%87%E5%AE%9A%E7%9A%84%E5%BC%95%E8%84%9A%E5%B0%86%20J-Link%20%E6%8E%A2%E5%A4%B4%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%9A%3CSTRONG%3ESWCLK%E3%80%81DIO%E3%80%81Vref%20(3.3%20V)%3C%2FSTRONG%3E%20%E5%92%8C%20GND%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E5%9C%A8%20VS%20%E4%BB%A3%E7%A0%81%E4%B8%AD%E9%80%89%E6%8B%A9%E4%BA%86%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377146i082D12C04DB96668%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1771417284863.png%22%20alt%3D%22Shanmugapriya_1-1771417284863.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%20%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%20launch.json%20%E6%96%87%E4%BB%B6%E5%86%85%E5%AE%B9%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E9%85%8D%E7%BD%AE%22%3C%2FSPAN%3E%3CSPAN%3E%3A%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E7%B1%BB%E5%9E%8B%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22mcuxpresso-debug%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%90%8D%E7%A7%B0%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%E8%B0%83%E8%AF%95%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%22%20%E8%AF%B7%E6%B1%82%20%22%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%E4%B8%8A%E5%B8%82%20%22%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22cwd%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BworkspaceFolder%7D%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%8F%AF%E6%89%A7%E8%A1%8C%22%3C%2FSPAN%3E%3CSPAN%3E%3A%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%B0%8F%E7%B2%BE%E7%81%B5%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22D%3A%2FNXP_SDKs%2FSDK_25_12_00_MCIMX93-EVK%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%2Fdebug%2Fhello_world_cm33.elf%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%20%3D%20%22%20%E5%8A%A0%E8%BD%BD%20%2B%20%E9%87%8D%E7%BD%AE%20%2B%20%E6%9A%82%E5%81%9C%20%40%20main%20%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22isAttach%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%81%9C%E6%AD%A2%E7%AC%A6%E5%8F%B7%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22main%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E8%B7%B3%E8%BF%87%E8%B0%83%E8%AF%95%E5%89%8D%E6%9E%84%E5%BB%BA%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%82%A8%E7%9A%84%E6%8E%A2%E6%B5%8B%E5%99%A8%E7%BC%96%E5%8F%B7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%8E%A2%E9%92%88%E5%BA%8F%E5%88%97%E5%8F%B7%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22801023331%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbInitCommands%22%3C%2FSPAN%3E%3CSPAN%3E%3A%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20remotetimeout%20600%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E8%AE%BE%E7%BD%AE%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%9B%AE%E5%BD%95%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%8D%E5%81%9C%E7%94%B5%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%AF%B9%20i.mx93%2FJ-Link%20%E6%9C%89%E5%B8%AE%E5%8A%A9%20%22%20%E6%B2%A1%E6%9C%89%E9%80%9A%E7%94%A8RESET%20%22%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerConfigs%22%3C%2FSPAN%3E%3CSPAN%3E%3A%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E9%93%BE%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%22%3C%2FSPAN%3E%3CSPAN%3E%3A%7B%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22segger%22%3C%2FSPAN%3E%3CSPAN%3E%3A%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%2F%2FJ-Link%20%E4%B8%AD%E7%9A%84%20i.mx93%20M33%20%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%22%20%E8%AE%BE%E5%A4%87%20%22%3A%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%22%20MIMX9%20352_M33%20%22%2C%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%8E%A5%E5%8F%A3%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%8E%A5%E5%8F%A3%EF%BC%9A%20SWD%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E9%80%9F%E5%BA%A6%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%221000%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%BC%80%E5%A7%8B%E6%97%B6%E6%AF%94%E8%BE%83%E4%BF%9D%E5%AE%88%EF%BC%9B%E4%BB%A5%E5%90%8E%E5%86%8D%E5%A2%9E%E5%8A%A0%EF%BC%88%E4%BE%8B%E5%A6%82%204000%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22RESET%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%20%E6%9A%82%E5%81%9C%20%22%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%BA%8F%E5%88%97%E5%8F%B7%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22801023331%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%A0%B8%E5%BF%83%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BworkspaceFolder%7D%2F.vscode%2Fjlink_gdbserver.log%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22pemicro%22%3C%2FSPAN%3E%3CSPAN%3E%3A%7B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%98%BE%E7%A4%BA%E8%B0%83%E8%AF%95%E8%BE%93%E5%87%BA%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%E7%94%9F%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%E5%BD%93%E6%88%91%E4%BB%8E%20VS%20Code%20%E5%BC%80%E5%A7%8B%E8%B0%83%E8%AF%95%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377148iF43078ECB46E7718%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_2-1771417393340.png%22%20alt%3D%22Shanmugapriya_2-1771417393340.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377149i3593B0330A6CD6E4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_3-1771417442590.png%22%20alt%3D%22Shanmugapriya_3-1771417442590.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377150i847ACA5E6D011DFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_4-1771417459147.png%22%20alt%3D%22Shanmugapriya_4-1771417459147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E6%B3%A8%EF%BC%9A%E6%9C%AC%E6%AC%A1%E6%B5%8B%E8%AF%95%E8%BF%9E%E6%8E%A5%E4%BA%86%3CSTRONG%3EP1%20%E5%92%8C%20P16%20USB%20%E7%AB%AF%E5%8F%A3%3C%2FSTRONG%3E%E4%BB%A5%E5%8F%8A%3CSTRONG%3EJ-Link%20%E6%8E%A2%E5%A4%B4%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%E6%9D%A5%E5%B8%AE%E5%8A%A9%E8%AF%8A%E6%96%AD%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
