How to run and debug an example "hello world" program in FRDM IMX93 from VS Code with MCUXpresso
3,373件の閲覧回数
Shanmugapriya
I have successfully built the example Hello World code and would like to run and debug it on the Cortex-M33 core, validating the output in the console.
Based on the knowledge base, I removed the two resistors to enable the SWD debugger and reworked the board for a 1.8 V VTref. The boot switches are configured in 1001 mode.
I am encountering the attached error when using the J-Link Commander.
Additionally, when attempting to debug from VS Code, I encounter the same issue and the debug session fails.
Could you please help me identify and resolve these errors?
Thank you for your support.
タグ(1)
3,140件の閲覧回数
Chavira
Hi @Shanmugapriya,
You can purchase a 10 k, 0402 resistor with ±1% tolerance from your local electronic components distributor.
There is nothing special or custom about this part, it is a standard 10 kΩ resistor.
Chavira
10 返答(返信)
3,347件の閲覧回数
Chavira
Hi @Shanmugapriya,
Thank you for contacting NXP Support.
Please refer to this guide for detailed instructions. It includes a step-by-step procedure to debug the FRDM board.
Although the reference guide uses an MCU-Link Pro, the same steps apply when using J-Link debuggers, as the debugging process is equivalent.
If you have any questions while following the guide, please let us know.
Chavira
3,320件の閲覧回数
Shanmugapriya
Hi @Chavira ,
I am facing such an error when "fastboot 0" is commanded.
3,330件の閲覧回数
Shanmugapriya
Hi @Chavira
Could you please clarify the correct position of the boot switch SW1 for the steps mentioned in the link you shared: Getting Started with FRDM-IMX93 and MCU-LINK Pro for M Core Debugging - NXP Community
Thanks.
3,281件の閲覧回数
Chavira
Hi @Shanmugapriya,
The position of SW1 depends on whether the system is booting from eMMC or from the SD card. Please ensure SW1 is set according to the selected boot source.
The message “Failed to configure default pinctrl” is expected behavior and can be safely ignored. It does not indicate a functional issue.
On the FRDM board, the resistors that need to be removed are R3017 and R3018.
Please refer to the board image or schematic to verify their exact location before removal.
Chavira
3,269件の閲覧回数
Shanmugapriya
Thank you, @Chavira. If the error "Failed to configure default pinctrl" can be safely ignored, I will proceed with the steps and update the status.
Shanmugapriya
3,175件の閲覧回数
Shanmugapriya
Hi @Chavira ,
While checking the layout screenshot, I accidentally removed the wrong resistor — R403 (10 kΩ) instead of R3018. I seem to have misplaced the tiny resistor. Where can I source a replacement for this component?
3,141件の閲覧回数
Chavira
Hi @Shanmugapriya,
Chavira
3,097件の閲覧回数
Shanmugapriya
Hi @Chavira
Thank you. I will check and resolder the resistor.
2,930件の閲覧回数
Shanmugapriya
Hi @Chavira
I’ve followed the steps up to “Launch the M Core from U‑Boot Terminal”, and the output from that step matches what the guide describes.
After this, I connected a J-Link probe to the board using the pins specified in the guide: SWCLK, DIO, Vref (3.3 V), and GND.
Then, in VS Code, I selected the debug configuration.
Below is my launch.json:
This is my launch.json file contents
  "configurations": [
      "type": "mcuxpresso-debug",
      "name": "Debug",
      "request": "launch",
      "cwd": "${workspaceFolder}",
      "executable": {
        "elf": "D:/NXP_SDKs/SDK_25_12_00_MCIMX93-EVK/mcuxsdk/examples/demo_apps/hello_world/debug/hello_world_cm33.elf"
      // Launch mode = "load + reset + halt @ main"
      "isAttach": false,
      "stopAtSymbol": "main",
      "skipBuildBeforeDebug": false,
      // Your probe S/N
      "probeSerialNumber": "801023331",
      "gdbInitCommands": [
        "set remotetimeout 600",
        "set debug-file-directory",
        "set non-stop off"
        // Helpful with i.MX93/J-Link "no generic reset":
      "gdbServerConfigs": {
        "linkserver": {},
        "segger": {
          // i.MX93 M33 device name in J-Link
          "device": "MIMX9352_M33",
          "interface": "SWD",
          "speed": "1000",               // start conservative; increase later (e.g., 4000)
          "reset": "halt",
          "serialNumber": "801023331",
          "core": 0,
          "logFile": "${workspaceFolder}/.vscode/jlink_gdbserver.log"
        "pemicro": {}
      "showDevDebugOutput": "raw"
When I start debugging from VS Code, I get the following error:
 Note: For this test, both P1 and P16 USB ports were connected, along with the J-Link probe.
Please let me know if you need any additional details to help diagnose the issue.
3,331件の閲覧回数
Shanmugapriya
Hi @Chavira
Thanks for sharing the steps. While following them, I noticed that the resistor indicated by the red arrow does not have continuity to the SW_CLK pin. Earlier, based on a community post, I had already removed two resistors.
After checking continuity from the SW_CLK and SW_DIO pins, I found that the resistors actually connected to these lines are the ones marked with the yellow arrows, and I removed those instead.
Could someone please confirm which specific resistor(s) should be removed for SWD access—the ones marked in red, or the ones marked in yellow?
%3CLINGO-SUB%20id%3D%22lingo-sub-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20VS%20Code%20%E3%81%8B%E3%82%89%20FRDM%20IMX93%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%80%8Chello%20world%E3%80%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%3C%2FSPAN%3E%3CEM%3E%3CSPAN%3EHello%20World%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81Cortex-M33%20%E3%82%B3%E3%82%A2%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E5%87%BA%E5%8A%9B%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%9F%A5%E8%AD%98%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81SWD%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%811.8%20V%20VTref%20%E7%94%A8%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E3%82%8A%E7%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AF%3CSTRONG%3E1001%3C%2FSTRONG%3E%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EJ-Link%20Commander%20%E3%81%AE%E4%BD%BF%E7%94%A8%E6%99%82%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769601176741.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374614i317AA68D3CDAB842%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769601176741.png%22%20alt%3D%22Shanmugapriya_0-1769601176741.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81VS%20Code%20%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1769601243673.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374615i6A374C33FC692B2B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1769601243673.png%22%20alt%3D%22Shanmugapriya_1-1769601243673.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3CSTRONG%3ESW1%3C%2FSTRONG%3E%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E4%BD%8D%E7%BD%AE%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_blank%22%3EFRDM-IMX93%E3%81%A8MCU-LINK%20Pro%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FM%E3%82%B3%E3%82%A2%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E9%96%8B%E5%A7%8B%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E6%89%8B%E9%A0%86%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E8%BF%BD%E3%81%A3%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A8%E3%80%81%E8%B5%A4%E3%81%84%E7%9F%A2%E5%8D%B0%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%8C%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%E3%83%94%E3%83%B3%E3%81%AB%E5%B0%8E%E9%80%9A%E3%81%97%E3%81%A6%3CSTRONG%3E%E3%81%84%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E5%89%8D%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3ESW_CLK%3C%2FSTRONG%3E%E3%83%94%E3%83%B3%E3%81%A8%3CSTRONG%3ESW_DIO%3C%2FSTRONG%3E%E3%83%94%E3%83%B3%E3%81%8B%E3%82%89%E3%81%AE%E5%B0%8E%E9%80%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%AE%9F%E9%9A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AF%3CSTRONG%3E%E9%BB%84%E8%89%B2%E3%81%AEARROW%3C%2FSTRONG%3E%E3%81%A7%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ESWD%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%20(%3CSTRONG%3E%E8%B5%A4%3C%2FSTRONG%3E%E3%81%A7%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%3CSTRONG%3E%E9%BB%84%E8%89%B2%3C%2FSTRONG%3E%E3%81%A7%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE)%20%E3%82%92%E8%AA%B0%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769664672182.png%22%20style%3D%22width%3A%20390px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374703i5AE2F02D72990C4E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769664672182.png%22%20alt%3D%22Shanmugapriya_0-1769664672182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGetting-Started-with-FRDM-IMX93-and-MCU-LINK-Pro-for-M-Core%2Fta-p%2F2108089%22%20target%3D%22_self%22%3E%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%AF%20MCU-Link%20Pro%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E5%90%8C%E7%AD%89%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81J-Link%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%82%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%86%E9%9A%9B%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%80%8Cfastboot%200%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1769685894527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374802iCB7327A1ACF222A2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1769685894527.png%22%20alt%3D%22Shanmugapriya_0-1769685894527.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3ESW1%20%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%20eMMC%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%20SW1%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%80%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20pinctrl%20%E3%82%92%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%82%8B%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%A9%9F%E8%83%BD%E4%B8%8A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%99%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EFRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AF%20R3017%20%E3%81%A8%20R3018%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%99%E5%89%8D%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%BE%E3%81%9F%E3%81%AF%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E6%AD%A3%E7%A2%BA%E3%81%AA%E4%BD%8D%E7%BD%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1770039931783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375171i2CD2530B0AE4D723%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1770039931783.png%22%20alt%3D%22Chavira_1-1770039931783.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%3CSPAN%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20pinctrl%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%AE%89%E5%85%A8%E3%81%ABCAN%E7%84%A1%E8%A6%96%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%89%8B%E9%A0%86%E3%82%92%E7%B6%9A%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%A0%E3%82%AC%E3%83%97%E3%83%AA%E3%83%A4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CDIV%3E%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%A6%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E6%8A%B5%E6%8A%97%E5%99%A8%EF%BC%88R3018%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20R403%20(10%20k%CE%A9)%EF%BC%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%B0%8F%E3%81%95%E3%81%AA%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E7%BD%AE%E3%81%8D%E5%BF%98%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E4%BA%A4%E6%8F%9B%E5%93%81%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2308812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258983%22%20target%3D%22_blank%22%3E%40Shanmugapriya%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A8%B1%E5%AE%B9%E8%AA%A4%E5%B7%AE%20%C2%B11%25%20%E3%81%AE%2010%20k%CE%A9%E3%80%810402%20%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AF%E3%80%81%E3%81%8A%E8%BF%91%E3%81%8F%E3%81%AE%E9%9B%BB%E5%AD%90%E9%83%A8%E5%93%81%E4%BB%A3%E7%90%86%E5%BA%97%E3%81%8B%E3%82%89%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E9%83%A8%E5%93%81%E3%81%AB%E3%81%AF%E7%89%B9%E5%88%A5%E3%81%AA%E3%82%82%E3%81%AE%E3%82%84%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE%2010%20k%CE%A9%20%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20run%20and%20debug%20an%20example%20%22hello%20world%22%20program%20in%20FRDM%20IMX93%20from%20VS%20Code%20with%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CSTRONG%3E%E3%80%8CU-Boot%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%8B%E3%82%89%20M%20Core%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%80%8D%3C%2FSTRONG%3E%E3%81%BE%E3%81%A7%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_0-1771417183138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377145i0E7DF4711A1108FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_0-1771417183138.png%22%20alt%3D%22Shanmugapriya_0-1771417183138.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%94%E3%83%B3%3CSTRONG%3E%EF%BC%88SWCLK%E3%80%81DIO%E3%80%81Vref%EF%BC%883.3%20V%EF%BC%89%E3%80%81GND%EF%BC%89%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81J-Link%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81VS%20Code%20%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_1-1771417284863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377146i082D12C04DB96668%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_1-1771417284863.png%22%20alt%3D%22Shanmugapriya_1-1771417284863.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AElaunch.json%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E6%A7%8B%E6%88%90%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%BF%E3%82%A4%E3%83%97%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8Cmcuxpresso-debug%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E5%90%8D%E5%89%8D%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8C%E8%B5%B7%E5%8B%95%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22cwd%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BworkspaceFolder%7D%20%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%22%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%A8%E3%83%AB%E3%83%95%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8CD%3A%2FNXP_SDKs%2FSDK_25_12_00_MCIMX93-EVK%2Fmcuxsdk%2Fexamples%2Fdemo_apps%2Fhello_world%2Fdebug%2Fhello_world_cm33.elf%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E8%B5%B7%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%22load%20%2B%20reset%20%2B%20halt%20%40%20main%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22isAttach%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Efalse%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22stopAtSymbol%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22main%22%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22skipBuildBeforeDebug%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Efalse%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AES%2FN%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22801023331%22%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbInitCommands%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92600%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%8E%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E5%87%BA%E7%99%BA%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20i.MX93%2FJ-Link%20%E3%81%AE%E3%80%8C%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AA%E3%81%97%E3%80%8D%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerConfigs%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%7B%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%BB%E3%82%AC%E3%83%BC%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20J-Link%20%E3%81%A7%E3%81%AE%20i.MX93%20M33%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8CMIMX9352_M33%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8CSWD%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22speed%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%221000%22%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%9C%80%E5%88%9D%E3%81%AF%E6%8E%A7%E3%81%88%E3%82%81%E3%81%AB%E3%80%81%E5%BE%8C%E3%81%A7%E5%A2%97%E5%8A%A0%E3%81%95%E3%81%9B%E3%82%8B%EF%BC%88%E4%BE%8B%EF%BC%9A4000%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8C%E5%81%9C%E6%AD%A2%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%8C801023331%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%82%B3%E3%82%A2%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BworkspaceFolder%7D%20%2F.vscode%2Fjlink_gdbserver.log%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%E3%83%9A%E3%83%9F%E3%82%AF%E3%83%AD%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20%7B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22showDevDebugOutput%22%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E%22raw%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3EVS%20Code%20%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_2-1771417393340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377148iF43078ECB46E7718%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_2-1771417393340.png%22%20alt%3D%22Shanmugapriya_2-1771417393340.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_3-1771417442590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377149i3593B0330A6CD6E4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_3-1771417442590.png%22%20alt%3D%22Shanmugapriya_3-1771417442590.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Shanmugapriya_4-1771417459147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377150i847ACA5E6D011DFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Shanmugapriya_4-1771417459147.png%22%20alt%3D%22Shanmugapriya_4-1771417459147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%20%3CSTRONG%3EJ-Link%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FSTRONG%3E%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E3%80%81%20%3CSTRONG%3EP1%20%E3%81%A8%20P16%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%20USB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%3C%2FSTRONG%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A8%BA%E6%96%AD%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
