How to install ubuntu on imx8mp
6,161件の閲覧回数
JROM
I want to install Ubuntu OS on imx8mp. I would like to ask if you can explain how to install it.
6 返答(返信)
6,137件の閲覧回数
Dhruvit
Hi @JROM,
I hope you are doing well.
Please refer to the below guide to enable the Ubuntu on i.MX8M series.
Thanks & Regards,
Dhruvit Vasavada
4,542件の閲覧回数
nicolam
Is it possible to install Ubuntu 24.04 on the IMX8mp dev-kit? I tried following the guide you posted but I am facing discrepancies
6,063件の閲覧回数
JROM
Thanks for your reply.
I would like to inquire because the following error occurred during yocto project build. I would appreciate it if you could tell me the solution.
kevin@ubuntu:~/imx/build$ bitbake core-image-minimal
ERROR: Unable to start bitbake server (None)
ERROR: Server log for this session (/home/kevin/imx/build/bitbake-cookerdaemon.log):
--- Starting bitbake server pid 4511 at 2023-11-05 08:53:42.495923 ---
ERROR: ParseError at /home/kevin/imx/sources/meta-openembedded/meta-oe/conf/layer.conf:106: unparsed line: 'DEFAULT_TEST_SUITES:pn-meta-oe-ptest-image = " ${PTESTTESTSUITE}"'
6,035件の閲覧回数
Dhruvit
Hi @JROM,
To avoid the parsing error kindly replace the below line and try.
--DEFAULT_TEST_SUITES:pn-meta-oe-ptest-image = " ${PTESTTESTSUITE}"
++DEFAULT_TEST_SUITES_pn-meta-oe-ptest-image = " ${PTESTTESTSUITE}"
Thanks & Regards,
Dhruvit Vasavada
5,994件の閲覧回数
JROM
 As shown in the attached picture, an error occurred during bitbake build and the process is stopped.
What should I do?
5,973件の閲覧回数
Dhruvit
Hi @JROM,
This issue is occurring while fetching linux-imx from github.
Please make sure that the firewall is not blocking that site.
Thanks & Regards,
Dhruvit Vasavada
