How to enable core1 on i.MX7D
542 次查看
tamotsu
Hi.
Which register should I set to enable core1 on i.MX7D?
Even if I set bit 2 of 6.2.7.3 A7 Reset Control Register in the Reference Manual to '1', there is no response.
Thank yoi.
513 次查看
joanxie
refer to the schematic, the pull-up is DNP, When JTAG_MOD is low, the JTAG interface is configured for common software debug,
535 次查看
joanxie
is it your typo? bit2 is for reserved, should be bit1
522 次查看
tamotsu
Hi.
I'm sorry.
Bit 1 is correct.
The JTAG_MOD pin on the i.MX7D SABRE board  is connected to a 10K pull-up register and a 4.7K pull-down register, but is the MPU in JTAG mode or SW mode?
Thank you.
514 次查看
joanxie
