How to configure mfg tool?
3,929 次查看
bcan
Hello all,
We have a sabre automative board and we wanted to configure it for our own needs. So far we build these files on ubuntu by following  documents in nxp.
We build our own:
*imx6q-sabreauto.dtb
*rootfs.ext2
*rootfs.tar
*u-boot.imx
*uImage
files but we couldn't find how to add them to mfgtool.  What configuration we need to do mfg tool and its files?
标记 (1)
4 回复数
3,172 次查看
Rita_Wang
Hi Bahadir Can​,
Which version BSP are you using?
Have a nice day
Dan
3,172 次查看
bcan
I am using  FSL community BSP which can be found from here GitHub - Freescale/fsl-community-bsp-platform: BSP platform manifest
3,170 次查看
Rita_Wang
You can go to our website to download the Documents on this version BSP i.MX 6 Series Software and Development Tool|NXP .In our user guide documents you can see the details.
Take the L4.1.15 version BSP as an example, you can see the 4.2.1 Configuring MfgTool in the i.MX_Linux_User's_Guide.pdf. Any questions you can contact me easily.
Have a nice day
Dan
Note: If this post answers your question, please click the Mark Correct button. Thank you!
3,170 次查看
bcan
So we produced a build with buildroot which includes rootfs.tar, rootfs.ext2 , u-boot, uImage and zImage. According to pdf you added we didn't change any files in profiles>linux>firmware but changed the files in profiles>linux>files with rootfs.tar.bz2, u-boot-imx6qsabreauto_sd.imx, uImage, zImage-imx6q-sabreauto.dtb (by putting same names.)
We started mfg tool again(from mfgtool2-yocto-mx-sabreauto-sdcard-sd3). It worked to some degree then gave error on pushing mksdcard.sh .
What shoud we do now?
Update : We managed to send our rootfs to board with this way. But we aren't sure that board got our kernel since every qt demo comes with installation in it gives segmentation fault. So how we can test it?
