How about the real-time monitoring ADC sensor application on the M33 (iMX93)?
1,498 次查看
charleshuang
Senior Contributor II
Hi NXP
Our applicaition is real time mointoring ADC.
(1) How about the real-time monitoring ADC sensor application on the M33 (iMX93)?
Do you have any example code to referenece it?
(2) About real time mointoring on M33, How about the response time?   Is it under 50ms?
Thanks.
5 回复数
1,482 次查看
jimmychan
Which interface to connect the ADC sensor? Could you tell me more about the application?
1,457 次查看
charleshuang
Hi Jimmy
The application is the EV charging.
We will be to monitor PT1000 ADC Thermal Sensor.
1,422 次查看
jimmychan
You could check the timing of different interface (e.g. spi, I2c) in the datasheet.
https://www.nxp.com.cn/docs/en/data-sheet/IMX93AEC.pdf
1,417 次查看
charleshuang
Hello @jimmychan
Andy Chien feedback PM James, he will be check ADC/ PWM sample code with NXP Team.
So nxp and Andy.Chien have any feedback ?
1,414 次查看
jimmychan
Basically, for the M33 example code, you could download the SDK from here.
https://mcuxpresso.nxp.com/en/select
Select the i.MX93 EVK. Then click the "Build MCUXpresso SDK".
