How about the real-time monitoring ADC sensor application on the M33 (iMX93)?
charleshuang
Senior Contributor II
Hi NXP
Our applicaition is real time mointoring ADC.
(1) How about the real-time monitoring ADC sensor application on the M33 (iMX93)?
Do you have any example code to referenece it?
(2) About real time mointoring on M33, How about the response time?   Is it under 50ms?
Thanks.
jimmychan
Which interface to connect the ADC sensor? Could you tell me more about the application?
charleshuang
Hi Jimmy
The application is the EV charging.
We will be to monitor PT1000 ADC Thermal Sensor.
jimmychan
You could check the timing of different interface (e.g. spi, I2c) in the datasheet.
https://www.nxp.com.cn/docs/en/data-sheet/IMX93AEC.pdf
charleshuang
Hello @jimmychan
Andy Chien feedback PM James, he will be check ADC/ PWM sample code with NXP Team.
So nxp and Andy.Chien have any feedback ?
jimmychan
Basically, for the M33 example code, you could download the SDK from here.
https://mcuxpresso.nxp.com/en/select
Select the i.MX93 EVK. Then click the "Build MCUXpresso SDK".
