HAB4 Authentication - Configuration
tadeuszgozdek
Can anyone explain what does it exactly means this 2 highlighted lines:
[Header]
Version = 4.1
Security Configuration = Open
and what effect gives us changing it other values.
I use the CST tool version 3.1.0 and I've checked Version = 4.0 and disabling line Security Configuration
but everything works (correctly) same way like before. Board has enabled secure boot only:
Secure boot enabled
HAB Configuration: 0xcc, HAB State: 0x99
No HAB Events Found!
The documentation says only that Security Configuration = Open is optional for HAB4 (which is in my iMX6DP according docs) but no word about what is this and how it works.
Yuri
  the following may be helpful:
https://community.nxp.com/message/652279
Yuri.
