HAB4 Authentication - Configuration
3,764 次查看
tadeuszgozdek
Can anyone explain what does it exactly means this 2 highlighted lines:
[Header]
Version = 4.1
Security Configuration = Open
and what effect gives us changing it other values.
I use the CST tool version 3.1.0 and I've checked Version = 4.0 and disabling line Security Configuration
but everything works (correctly) same way like before. Board has enabled secure boot only:
Secure boot enabled
HAB Configuration: 0xcc, HAB State: 0x99
No HAB Events Found!
The documentation says only that Security Configuration = Open is optional for HAB4 (which is in my iMX6DP according docs) but no word about what is this and how it works.
标记 (1)
3,682 次查看
Yuri
  the following may be helpful:
https://community.nxp.com/message/652279
Yuri.
