Gstreamer1.0 plugins without X11/Wayland (dizzy )
2,829 次查看
caiopereira
It's possible to compile the gstreamer1.0-plugins (base/good/bad) without X11/Wayland?
I saw that there's a dependency of gdk-pixbuf that depends x11.
I would like to use only QT5.4 with eglfs without windows manager and to decode videos (h264, RTP ).
The libx11-diet could supply this dependency?
Thank you very much.
2,482 次查看
caiopereira
Thanks!
I already use DISTRO_remove = " x11"
But the gstreamer-plugins-good include as a default dependency with gdk-pixbuf virtua/x11.
To solve this question is needed.
PACKAGECONFIG_remove_pn-gstreamer1.0-plugins-good = " gdk-pixbuf "
2,482 次查看
joanxie
yocto can build different image, you can choose the image which doesn't include x11, for more detailed information, pls refer to the Yocto User Guide.
2,483 次查看
caiopereira
Thanks!
