I would like to use only QT5.4 with eglfs without windows manager and to decode videos (h264, RTP ).
The libx11-diet could supply this dependency?
Thank you very much.
Solved! Go to Solution.
Thanks!
I already use DISTRO_remove = " x11"
But the gstreamer-plugins-good include as a default dependency with gdk-pixbuf virtua/x11.
To solve this question is needed.
PACKAGECONFIG_remove_pn-gstreamer1.0-plugins-good = " gdk-pixbuf "
yocto can build different image, you can choose the image which doesn't include x11, for more detailed information, pls refer to the Yocto User Guide.
Thanks!
