Getting started using the EIM in the iMX50
2,621 次查看
jedrumh
I just need some help getting started. I have to use the EIM, in an iMX50, to talk to an FPGA (Stratix IV). Can someone please give me a place to get started? The EIM needs to be in asynchronous mode and the FPGA will be on CS1. I'm running Linux. I'm assuming I have to setup the EIM pins in mx50_rdp.c (I did this for GPIO) but how do I know what the base address is? How do I configure the bus? I can't seem to find a straight answer in any of the documentation. Any help would be greatly appreciated.
Thanks!
标签 (2)
标记 (4)
2,207 次查看
jimmychan
You can find the EIM base address in i.MX50 Reference manual chapter 2 "Memory Map".
For the EIM details, please read the Chapter 23.
IMX50RM
2,208 次查看
jimmychan
IMX50RM
2,207 次查看
JithCR
Is there any EIM driver support available in Linux?
