GPMI NAND Mode
GPMI NAND Mode
2,408 次查看
takashitakahash
Dear community.
i.MX6DQ RM of 29.4 GPMI NAND Mode Describes on Check Status-The Read-and-Compare mode allows the GPMI to check NAND status against a reference.
What check is this?
Will check the verify the written data ?
标签 (2)
2,213 次查看
igorpadykov
Hi Takashi
this command compares read data (usually NAND status)
with REFERENCE data as described in
IMX6DQRM 29.6.2 GPMI Compare Register Description (GPMI_COMPARE)
2,214 次查看
igorpadykov
Hi Takashi
