Error building wifi module
rizwan_s
Hi Everyone,
I am working on wifi module for imx.6q nxp processor for android lollipop.
when i build the driver for wifi module, it shows the below error
receive.c:17:19: fatal error: stdio.h: No such file or directory
compilation terminated.
I am using arm cross compiler 4.6
Please suggest me, where am going wrong.
Rizwan Syed
Labels (2)
weidong_sun
Hello rizwan,
    It is too less information you submitted about your WIFI module, so it is very hard to give you corresponding advice for your question, but generally speaking, for compiling WIFI driver, steps are like below:
------Compiling it independently to be a module( .ko)
Copy WIFI driver's source code to a directory.
------Modifying Makefile of the driver.
(1) Modifying Cross Compiler path
(2) Modifying Linux kernel path
(3) run make command
If you have done it by using above similar steps, and met issue you said, you can check if there exists the file in source code.
Hope above information can help you!
Weidong
rizwan_s
Hi Weidong,
When am compiling the redpine wifi module independently , am getting the above error.
Thanks and Regards
Rizwan Syed
