Enabling TPM on A core imx8ulp
4,713 次查看
wendy-liu
Hi @Chavira
     I'm using iMX8ULP-evk to enable TPM in A core according to your article: https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-PWM-on-iMX93-EVK-board/ta-p/1...
    I chose PTF19 (J20 pin3) to generate PWM signal.
     After flashing, I open a terminal and execute the following commands:
cd /sys/class/pwm/pwmchip0;
echo 0 > export;
cd pwm0;
echo 400000 > period;
echo 200000 > duty_cycle;
echo 1 > enable;
    Then , I use oscilloscope to measure it waveform , and it keeps outputting a high-level signal.
    Could you give me some advice?
    My dts ,config, log are as below.
Best Regard!
4,573 次查看
Chavira
Hi @wendy-liu!
Try changing the driver from "fsl,imx7ulp-tpm" to "fsl,imx7ulp-pwm" in imx8ulp.dtsi.
tpm5: tpm@29340000 {
      compatible = "fsl,imx8ulp-tpm", "fsl,imx7ulp-pwm";
Additional you should disable the LPSPI5 since the LPSPI5 is using the pin PTF19.
Best Regards!]
Chavira
5 回复数
4,697 次查看
wendy-liu
@Chavira
Also, tpm_rpchip_0 is the node(/sys/class/pwm/pwmchip0/), but where is tpm5?
And, which TPM does tpm_rpchip_0 control?
There are some questions I would like to ask you.Hope your reply!Thanks a lot!
4,677 次查看
Chavira
HI @wendy-liu!
Thank you for contacting NXP Support!
I will start with the research of this issue.
It looks like the TPM only can be managed by M core and you can control the TPM module using rpmsg only.
I will give you an update as soon as possible.
Best Regards!
Chavira
4,669 次查看
wendy-liu
@Chavira
Looking forward your reply!
Thank you very much!
4,574 次查看
Chavira
Hi @wendy-liu!
Best Regards!]
Chavira
4,542 次查看
wendy-liu
Thanks! I have been solved!
Best Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2050363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20A%20%E6%A0%B8%20imx8ulp%20%E4%B8%8A%E5%90%AF%E7%94%A8%20TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E6%96%87%E7%AB%A0%E4%BD%BF%E7%94%A8%20iMX8ULP-evk%20%E5%9C%A8%20A%20%E6%A0%B8%E4%B8%AD%E5%90%AF%E7%94%A8%20TPM%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-use-PWM-on-iMX93-EVK-board%2Fta-p%2F1975410%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-use-PWM-on-iMX93-EVK-board%2Fta-p%2F1...%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E9%80%89%E6%8B%A9%20PTF19%EF%BC%88J20%20%E5%BC%95%E8%84%9A%203%EF%BC%89%E6%9D%A5%E7%94%9F%E6%88%90%20PWM%20%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22wendyliu_0-1740448715122.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wendyliu_0-1740448715122.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325441i1E271AF28C3BB287%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22wendyliu_0-1740448715122.png%22%20alt%3D%22wendyliu_0-1740448715122.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%97%AA%E7%83%81%E5%90%8E%EF%BC%8C%E6%88%91%3CSPAN%3E%E6%89%93%E5%BC%80%E7%BB%88%E7%AB%AF%E5%B9%B6%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Ecd%20%2Fsys%2Fclass%2Fpwm%2Fpwmchip0%3B%3CBR%20%2F%3Eecho%200%20%26gt%3B%20export%3B%3CBR%20%2F%3Ecd%20pwm0%3B%3CBR%20%2F%3Eecho%20400000%20%26gt%3B%20period%3B%3CBR%20%2F%3Eecho%20200000%20%26gt%3B%20duty_cycle%3B%3CBR%20%2F%3Eecho%201%20%26gt%3B%20enable%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%B5%8B%E9%87%8F%E5%AE%83%E7%9A%84%E6%B3%A2%E5%BD%A2%EF%BC%8C%E5%AE%83%E4%B8%80%E7%9B%B4%E8%BE%93%E5%87%BA%E9%AB%98%E7%94%B5%E5%B9%B3%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20dts%E3%80%81%E9%85%8D%E7%BD%AE%E3%80%81%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E8%89%AF%E5%A5%BD%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2050363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E5%9C%A8A%E6%A0%B8imx8ulp%E4%B8%8A%E5%90%AF%E7%94%A8TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E5%9C%A8A%E6%A0%B8imx8ulp%E4%B8%8A%E5%90%AF%E7%94%A8TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246604%22%20target%3D%22_blank%22%3E%40wendy-liu%3C%2FA%3E!%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E5%B0%86%20imx8ulp.dtsi%20%E4%B8%AD%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8E%3CSTRONG%3E%E2%80%9Cfsl%2Cimx7ulp-tpm%E2%80%9D%3C%2FSTRONG%3E%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSTRONG%3E%E2%80%9Cfsl%2Cimx7ulp-pwm%E2%80%9D%3C%2FSTRONG%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Fd23d64eea5111e1607efcce1d601834fceec92cb%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8ulp.dtsi%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Etpm5%3A%20tpm%4029340000%20%7B%0A%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cimx8ulp-tpm%22%2C%20%22fsl%2Cimx7ulp-pwm%22%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E7%A6%81%E7%94%A8%20LPSPI5%EF%BC%8C%E5%9B%A0%E4%B8%BA%20LPSPI5%20%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%BC%95%E8%84%9A%20PTF19%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%81%5D%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E5%9C%A8A%E6%A0%B8imx8ulp%E4%B8%8A%E5%90%AF%E7%94%A8TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2051940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E5%9C%A8A%E6%A0%B8imx8ulp%E4%B8%8A%E5%90%AF%E7%94%A8TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246604%22%20target%3D%22_blank%22%3E%40wendy-liu%3C%2FA%3E%20%EF%BC%81%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%81%94%E7%B3%BB%20NXP%20%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%85%88%E4%BB%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E7%A0%94%E7%A9%B6%E8%AF%B4%E8%B5%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%20TPM%20%E5%8F%AA%E8%83%BD%E7%94%B1%20M%20%E6%A0%B8%E5%BF%83%E7%AE%A1%E7%90%86%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E5%8F%AA%E8%83%BD%E4%BD%BF%E7%94%A8%20rpmsg%20%E6%8E%A7%E5%88%B6%20TPM%20%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E5%90%91%E4%BD%A0%E9%80%9A%E6%8A%A5%E6%9C%80%E6%96%B0%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%81%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E5%9C%A8A%E6%A0%B8imx8ulp%E4%B8%8A%E5%90%AF%E7%94%A8TPM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8Ctpm_rpchip_0%20%E6%98%AF%E8%8A%82%E7%82%B9%EF%BC%88%2Fsys%2Fclass%2Fpwm%2Fpwmchip0%2F%EF%BC%89%EF%BC%8C%E4%BD%86%E6%98%AF%20tpm5%20%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%3CSTRONG%3E%20tpm_rpchip_0%3C%2FSTRONG%3E%3CSPAN%3E%20%E6%8E%A7%E5%88%B6%20%E5%93%AA%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%3E%20TPM%20%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E6%88%91%E6%83%B3%E9%97%AE%E4%BD%A0%E3%80%82%E5%B8%8C%E6%9C%9B%E6%82%A8%E8%83%BD%E5%9B%9E%E5%A4%8D%EF%BC%81%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
