Eample using the GPU2D to overlay video stream before encoding via OpenGL?
1,403 次查看
Larry5335
I am looking for a method to do an accelerated, color keyed, blit onto a frame buffer prior to sending it to the video encoder.  We would use this to composite a graphic overlay onto the video stream.  I’ve read  http://cache.freescale.com/files/training/doc/ftf/2014/FTF-CON-F0223.pdf but I would need the IPU to deposit the result back into memory to be encoded instead of rendering it to an output.  Do you have an example using the GPU2D to do this via OpenGL?
标记 (2)
976 次查看
Bio_TICFSL
Please take a look at the IMX6_GPU_SDK, it includes sample codes and GPU2D similar that the one you are looking for:
i.MX6Q: i.MX 6Quad Processors – Quad Core
