Dual screens Single DRM
sebastian-verge
I have been following the Multi-display - Redirecting the output - one DRM interface document.
I can get each app working individually. For some reason I cannot get both applications to start at the same time.
I started by getting the wayland app-ids:
torizon@verdin-imx8mp-15207741:~$ docker compose run --rm -e WAYLAND_DEBUG=1 infotainment 2>&1 | grep set_app_id
[3625339.789]  -> [email protected]_app_id("StarOSApp")
^C
torizon@verdin-imx8mp-15207741:~$ docker compose run --rm -e WAYLAND_DEBUG=1 dash 2>&1 | grep set_app_id
[3645913.156]  -> [email protected]_app_id("StarDashApp")
I added these values to my weston.ini:
torizon@verdin-imx8mp-15207741:~$ cat weston.ini
[core]
idle-time=0
require-input=false
xwayland=true
modules=screen-share.so
shell=kiosk-shell.so
#require-outputs=all-found
[shell]
panel-position=top
locking=false
allow-zap=true
num-workspaces=1
[output]
name=HDMI-A-2
mode=preferred
app-ids=StarDashApp
[output]
name=HDMI-A-1
mode=preferred
app-ids=StarOSApp
The docker compose file I am using is as close to https://github.com/toradex/torizon-samples/blob/bookworm/multi-display/single-drm-interface/docker-c... as I can manage. I can post it if that helps?
When I try to start the second container I get the following:
torizon@verdin-imx8mp-15207741:~$ docker stats --no-stream
CONTAINER ID   NAME                  CPU %     MEM USAGE / LIMIT     MEM %     NET I/O       BLOCK I/O        PIDS
3a0b29ca1608   live-infotainment-1   44.68%    111MiB / 7.754GiB     1.40%     3.43kB / 0B   0B / 61.4kB      9
7e96d7a3546c   live-weston-1         16.12%    18.26MiB / 7.754GiB   0.23%     0B / 0B       32.8kB / 307kB   11
torizon@verdin-imx8mp-15207741:~$ docker compose up dash --no-deps
[+] Running 1/1
 ✔ dash Pulled    0.7s
[+] Running 1/0
 ✔ Container live-dash-1  Created    0.0s
Attaching to live-dash-1
live-dash-1  | Loaded language: "en"
live-dash-1  | Font "Inter-Bold.ttf" loaded
live-dash-1  | Font "Inter-Medium.ttf" loaded
live-dash-1  | Font "Inter-Regular.ttf" loaded
live-dash-1  | Font "Inter-SemiBold.ttf" loaded
live-dash-1 exited with code 139
I am really hoping you can point me to where I can even start to work out what is going on!
sebastian-verge
I asked over in the Toradex community: https://community.toradex.com/t/25126
You can see how our issues were resolved there.
Thank you!
sebastian-verge
Thank you!
MaazPatni
Don't Know, @toradex  or or their develop partners like Silicon Signals can help i have seen there are various development done by them on this board.
Here's the reference: https://youtu.be/bUD6gcjBe2o?si=hZgK9GD6scdONsRG
Toradex page: https://www.toradex.com/support/partner-network/services/400014/silicon-signals-pvt-ltd
Bio_TICFSL
Do not know if it possible in your board, maybe Someone at @toradex can help.
regards
%3CLINGO-SUB%20id%3D%22lingo-sub-1959654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDual%20screens%20Single%20DRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20been%20following%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fdeveloper.toradex.com%2Ftorizon%2Fapplication-development%2Fprovided-containers%2Fworking-with-weston-on-torizoncore%2F%23redirecting-the-output---one-drm-interface%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMulti-display%20-%20Redirecting%20the%20output%20-%20one%20DRM%20interface%3C%2FA%3E%26nbsp%3Bdocument.%3C%2FP%3E%3CP%3EI%20can%20get%20each%20app%20working%20individually.%20For%20some%20reason%20I%20cannot%20get%20both%20applications%20to%20start%20at%20the%20same%20time.%3C%2FP%3E%3CP%3EI%20started%20by%20getting%20the%20wayland%20app-ids%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20run%20--rm%20-e%20WAYLAND_DEBUG%3D1%20infotainment%202%26gt%3B%26amp%3B1%20%7C%20grep%20set_app_id%0A%5B3625339.789%5D%20%20-%26gt%3B%20xdg_toplevel%4024.set_app_id(%22StarOSApp%22)%0A%5EC%0Atorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20run%20--rm%20-e%20WAYLAND_DEBUG%3D1%20dash%202%26gt%3B%26amp%3B1%20%7C%20grep%20set_app_id%0A%5B3645913.156%5D%20%20-%26gt%3B%20xdg_toplevel%4024.set_app_id(%22StarDashApp%22)%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EI%20added%20these%20values%20to%20my%20weston.ini%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20cat%20weston.ini%20%0A%5Bcore%5D%0Aidle-time%3D0%0Arequire-input%3Dfalse%0Axwayland%3Dtrue%0Amodules%3Dscreen-share.so%0Ashell%3Dkiosk-shell.so%0A%23require-outputs%3Dall-found%0A%0A%5Bshell%5D%0Apanel-position%3Dtop%0Alocking%3Dfalse%0Aallow-zap%3Dtrue%0Anum-workspaces%3D1%0A%0A%5Boutput%5D%0Aname%3DHDMI-A-2%0Amode%3Dpreferred%0Aapp-ids%3DStarDashApp%0A%0A%5Boutput%5D%0Aname%3DHDMI-A-1%0Amode%3Dpreferred%0Aapp-ids%3DStarOSApp%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EThe%20docker%20compose%20file%20I%20am%20using%20is%20as%20close%20to%26nbsp%3B%3CA%20href%3D%22github%3Atoradex%2Ftorizon-samples%23%2Fmulti-display%2Fsingle-drm-interface%2Fdocker-compose.arm64.yml%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Ftoradex%2Ftorizon-samples%2Fblob%2Fbookworm%2Fmulti-display%2Fsingle-drm-interface%2Fdocker-compose.arm64.yml%3C%2FA%3E%20as%20I%20can%20manage.%20I%20can%20post%20it%20if%20that%20helps%3F%3C%2FP%3E%3CP%3EWhen%20I%20try%20to%20start%20the%20second%20container%20I%20get%20the%20following%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-csharp%22%3E%3CCODE%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20stats%20--no-stream%0ACONTAINER%20ID%20%20%20NAME%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CPU%20%25%20%20%20%20%20MEM%20USAGE%20%2F%20LIMIT%20%20%20%20%20MEM%20%25%20%20%20%20%20NET%20I%2FO%20%20%20%20%20%20%20BLOCK%20I%2FO%20%20%20%20%20%20%20%20PIDS%0A3a0b29ca1608%20%20%20live-infotainment-1%20%20%2044.68%25%20%20%20%20111MiB%20%2F%207.754GiB%20%20%20%20%201.40%25%20%20%20%20%203.43kB%20%2F%200B%20%20%200B%20%2F%2061.4kB%20%20%20%20%20%209%0A7e96d7a3546c%20%20%20live-weston-1%20%20%20%20%20%20%20%20%2016.12%25%20%20%20%2018.26MiB%20%2F%207.754GiB%20%20%200.23%25%20%20%20%20%200B%20%2F%200B%20%20%20%20%20%20%2032.8kB%20%2F%20307kB%20%20%2011%0Atorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20up%20dash%20--no-deps%0A%5B%2B%5D%20Running%201%2F1%0A%20%E2%9C%94%20dash%20Pulled%20%20%20%200.7s%0A%5B%2B%5D%20Running%201%2F0%0A%20%E2%9C%94%20Container%20live-dash-1%20%20Created%20%20%20%200.0s%0AAttaching%20to%20live-dash-1%0Alive-dash-1%20%20%7C%20Loaded%20language%3A%20%22en%22%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Bold.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Medium.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Regular.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-SemiBold.ttf%22%20loaded%0Alive-dash-1%20exited%20with%20code%20139%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EI%20am%20really%20hoping%20you%20can%20point%20me%20to%20where%20I%20can%20even%20start%20to%20work%20out%20what%20is%20going%20on!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Dual%20screens%20Single%20DRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20asked%20over%20in%20the%20Toradex%20community%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.toradex.com%2Ft%2F25126%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.toradex.com%2Ft%2F25126%3C%2FA%3E%3C%2FP%3E%3CP%3EYou%20can%20see%20how%20our%20issues%20were%20resolved%20there.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Dual%20screens%20Single%20DRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDon't%20Know%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5672%22%20target%3D%22_blank%22%3E%40toradex%3C%2FA%3E%26nbsp%3B%20or%20or%20their%20develop%20partners%20like%20Silicon%20Signals%20can%20help%20i%20have%20seen%20there%20are%20various%20development%20done%20by%20them%20on%20this%20board.%3CBR%20%2F%3EHere's%20the%20reference%3A%20%3CA%20href%3D%22https%3A%2F%2Fyoutu.be%2FbUD6gcjBe2o%3Fsi%3DhZgK9GD6scdONsRG%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fyoutu.be%2FbUD6gcjBe2o%3Fsi%3DhZgK9GD6scdONsRG%3C%2FA%3E%3C%2FP%3E%3CP%3EToradex%20page%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%2Fpartner-network%2Fservices%2F400014%2Fsilicon-signals-pvt-ltd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.toradex.com%2Fsupport%2Fpartner-network%2Fservices%2F400014%2Fsilicon-signals-pvt-ltd%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1959961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Dual%20screens%20Single%20DRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EDo%20not%20know%20if%20it%20possible%20in%20your%20board%2C%20maybe%20Someone%20at%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5672%22%20target%3D%22_blank%22%3E%40toradex%3C%2FA%3E%20can%20help.%3C%2FP%3E%0A%3CP%3Eregards%3C%2FP%3E%3C%2FLINGO-BODY%3E
