Dual screens Single DRM
3,106件の閲覧回数
sebastian-verge
I have been following the Multi-display - Redirecting the output - one DRM interface document.
I can get each app working individually. For some reason I cannot get both applications to start at the same time.
I started by getting the wayland app-ids:
torizon@verdin-imx8mp-15207741:~$ docker compose run --rm -e WAYLAND_DEBUG=1 infotainment 2>&1 | grep set_app_id
[3625339.789]  -> [email protected]_app_id("StarOSApp")
^C
torizon@verdin-imx8mp-15207741:~$ docker compose run --rm -e WAYLAND_DEBUG=1 dash 2>&1 | grep set_app_id
[3645913.156]  -> [email protected]_app_id("StarDashApp")
I added these values to my weston.ini:
torizon@verdin-imx8mp-15207741:~$ cat weston.ini
[core]
idle-time=0
require-input=false
xwayland=true
modules=screen-share.so
shell=kiosk-shell.so
#require-outputs=all-found
[shell]
panel-position=top
locking=false
allow-zap=true
num-workspaces=1
[output]
name=HDMI-A-2
mode=preferred
app-ids=StarDashApp
[output]
name=HDMI-A-1
mode=preferred
app-ids=StarOSApp
The docker compose file I am using is as close to https://github.com/toradex/torizon-samples/blob/bookworm/multi-display/single-drm-interface/docker-c... as I can manage. I can post it if that helps?
When I try to start the second container I get the following:
torizon@verdin-imx8mp-15207741:~$ docker stats --no-stream
CONTAINER ID   NAME                  CPU %     MEM USAGE / LIMIT     MEM %     NET I/O       BLOCK I/O        PIDS
3a0b29ca1608   live-infotainment-1   44.68%    111MiB / 7.754GiB     1.40%     3.43kB / 0B   0B / 61.4kB      9
7e96d7a3546c   live-weston-1         16.12%    18.26MiB / 7.754GiB   0.23%     0B / 0B       32.8kB / 307kB   11
torizon@verdin-imx8mp-15207741:~$ docker compose up dash --no-deps
[+] Running 1/1
 ✔ dash Pulled    0.7s
[+] Running 1/0
 ✔ Container live-dash-1  Created    0.0s
Attaching to live-dash-1
live-dash-1  | Loaded language: "en"
live-dash-1  | Font "Inter-Bold.ttf" loaded
live-dash-1  | Font "Inter-Medium.ttf" loaded
live-dash-1  | Font "Inter-Regular.ttf" loaded
live-dash-1  | Font "Inter-SemiBold.ttf" loaded
live-dash-1 exited with code 139
I am really hoping you can point me to where I can even start to work out what is going on!
2,911件の閲覧回数
sebastian-verge
I asked over in the Toradex community: https://community.toradex.com/t/25126
You can see how our issues were resolved there.
Thank you!
3 返答(返信)
2,912件の閲覧回数
sebastian-verge
Thank you!
2,929件の閲覧回数
MaazPatni
Don't Know, @toradex  or or their develop partners like Silicon Signals can help i have seen there are various development done by them on this board.
Here's the reference: https://youtu.be/bUD6gcjBe2o?si=hZgK9GD6scdONsRG
Toradex page: https://www.toradex.com/support/partner-network/services/400014/silicon-signals-pvt-ltd
3,069件の閲覧回数
Bio_TICFSL
Do not know if it possible in your board, maybe Someone at @toradex can help.
regards
%3CLINGO-SUB%20id%3D%22lingo-sub-1959654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABDRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fdeveloper.toradex.com%2Ftorizon%2Fapplication-development%2Fprovided-containers%2Fworking-with-weston-on-torizoncore%2F%23redirecting-the-output---one-drm-interface%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20-%20%E5%87%BA%E5%8A%9B%E3%81%AE%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%20-%201%E3%81%A4%E3%81%AEDRM%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%3C%2FA%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFwayland%E3%81%AEapp-ids%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20run%20--rm%20-e%20WAYLAND_DEBUG%3D1%20infotainment%202%26gt%3B%26amp%3B1%20%7C%20grep%20set_app_id%0A%5B3625339.789%5D%20%20-%26gt%3B%20xdg_toplevel%4024.set_app_id(%22StarOSApp%22)%0A%5EC%0Atorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20run%20--rm%20-e%20WAYLAND_DEBUG%3D1%20dash%202%26gt%3B%26amp%3B1%20%7C%20grep%20set_app_id%0A%5B3645913.156%5D%20%20-%26gt%3B%20xdg_toplevel%4024.set_app_id(%22StarDashApp%22)%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%82%92weston.ini%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20cat%20weston.ini%20%0A%5Bcore%5D%0Aidle-time%3D0%0Arequire-input%3Dfalse%0Axwayland%3Dtrue%0Amodules%3Dscreen-share.so%0Ashell%3Dkiosk-shell.so%0A%23require-outputs%3Dall-found%0A%0A%5Bshell%5D%0Apanel-position%3Dtop%0Alocking%3Dfalse%0Aallow-zap%3Dtrue%0Anum-workspaces%3D1%0A%0A%5Boutput%5D%0Aname%3DHDMI-A-2%0Amode%3Dpreferred%0Aapp-ids%3DStarDashApp%0A%0A%5Boutput%5D%0Aname%3DHDMI-A-1%0Amode%3Dpreferred%0Aapp-ids%3DStarOSApp%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bdocker%20compose%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E7%AE%A1%E7%90%86%E3%81%A7%E3%81%8D%E3%82%8B%E9%99%90%E3%82%8A%20%3CA%20href%3D%22github%3Atoradex%2Ftorizon-samples%23%2Fmulti-display%2Fsingle-drm-interface%2Fdocker-compose.arm64.yml%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Ftoradex%2Ftorizon-samples%2Fblob%2Fbookworm%2Fmulti-display%2Fsingle-drm-interface%2Fdocker-compose.arm64.yml%3C%2FA%3E%20%E3%81%AB%E8%BF%91%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%AA%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-csharp%22%3E%3CCODE%20translate%3D%22no%22%3Etorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20stats%20--no-stream%0ACONTAINER%20ID%20%20%20NAME%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CPU%20%25%20%20%20%20%20MEM%20USAGE%20%2F%20LIMIT%20%20%20%20%20MEM%20%25%20%20%20%20%20NET%20I%2FO%20%20%20%20%20%20%20BLOCK%20I%2FO%20%20%20%20%20%20%20%20PIDS%0A3a0b29ca1608%20%20%20live-infotainment-1%20%20%2044.68%25%20%20%20%20111MiB%20%2F%207.754GiB%20%20%20%20%201.40%25%20%20%20%20%203.43kB%20%2F%200B%20%20%200B%20%2F%2061.4kB%20%20%20%20%20%209%0A7e96d7a3546c%20%20%20live-weston-1%20%20%20%20%20%20%20%20%2016.12%25%20%20%20%2018.26MiB%20%2F%207.754GiB%20%20%200.23%25%20%20%20%20%200B%20%2F%200B%20%20%20%20%20%20%2032.8kB%20%2F%20307kB%20%20%2011%0Atorizon%40verdin-imx8mp-15207741%3A~%24%20docker%20compose%20up%20dash%20--no-deps%0A%5B%2B%5D%20Running%201%2F1%0A%20%E2%9C%94%20dash%20Pulled%20%20%20%200.7s%0A%5B%2B%5D%20Running%201%2F0%0A%20%E2%9C%94%20Container%20live-dash-1%20%20Created%20%20%20%200.0s%0AAttaching%20to%20live-dash-1%0Alive-dash-1%20%20%7C%20Loaded%20language%3A%20%22en%22%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Bold.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Medium.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-Regular.ttf%22%20loaded%0Alive-dash-1%20%20%7C%20Font%20%22Inter-SemiBold.ttf%22%20loaded%0Alive-dash-1%20exited%20with%20code%20139%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E7%A7%81%E3%81%8C%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E6%8C%87%E3%81%97%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABDRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EToradex%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E5%B0%8B%E3%81%AD%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.toradex.com%2Ft%2F25126%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.toradex.com%2Ft%2F25126%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABDRM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9F%A5%E3%82%89%E3%81%AA%E3%81%84%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5672%22%20target%3D%22_blank%22%3E%40toradex%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%BD%BC%E3%82%89%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%BD%BC%E3%82%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9F%E6%A7%98%E3%80%85%E3%81%AA%E9%96%8B%E7%99%BA%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%8D%E3%81%9F%E3%81%AE%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fyoutu.be%2FbUD6gcjBe2o%3Fsi%3DhZgK9GD6scdONsRG%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fyoutu.be%2FbUD6gcjBe2o%3Fsi%3DhZgK9GD6scdONsRG%3C%2FA%3E%3C%2FP%3E%3CP%3EToradex%E3%83%9A%E3%83%BC%E3%82%B8%3A%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%2Fpartner-network%2Fservices%2F400014%2Fsilicon-signals-pvt-ltd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.toradex.com%2Fsupport%2Fpartner-network%2Fservices%2F400014%2Fsilicon-signals-pvt-ltd%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
