Difference between cold and warm reset
21,047件の閲覧回数
ko-hey
Senior Contributor II
Hi all I can't understand between cold and warm reset. In reference manual P5062, there is a table that is shown SRC reset functionality. However, there are no difference between cold and warm reset. http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf What is the difference between cold and warm reset? Best Regards,
タグ(1)
18,091件の閲覧回数
Actually there is always alternative: provide short and not
accurate answer and provide long and accurate. I would choose last. :smileyhappy:
6 返答(返信)
18,091件の閲覧回数
Hi ko-hey
difference is dscribed in sect.60.6.1.2.4 COLD RESET
60.6.1.2.5 WARM RESET IMX6DQRM
Probably main difference is that during warm reset MMDC
can put DDR in self refresh.
18,091件の閲覧回数
ko-hey
Hi Igor
Thank you for your replay.
However, it's not about sequence. I want to know about functionally difference.
Here is my understandings. Are these correct?
  • POR will erase all data including each register value
  • COLD reset will erase all data except each register value
  • WARM reset will do self-refresh to DDR
18,091件の閲覧回数
Hi ko-hey
I am not sure that such complex subject may be explained
in such simple manner. Please look carefully documentation
in particular Table 60-4. SRC reset functionality IMX6DQRM
~igor
18,091件の閲覧回数
ko-hey
Hi Igor
I apologized it. I think it is just as you say.
So let me talk about Table 60-4.
In Table 60-4, it looks no functionally difference between COLD and WARM reset.
What's the difference between COLD and WARM reset?
Is the main difference only self refresh?
ko-hey
18,092件の閲覧回数
18,091件の閲覧回数
ko-hey
Igor
I understood that WARM reset is similar to CLOD reset except to MMDC.
ko-hey
