DDR3 routing, length matching
已解决
跳至解决方案
2,529 次查看
celiley
There is a point I'm not sure about DDR3 routing. I'm following "Hardware Development Guide for
i.MX 6Quad" and this document says that the address signals must match 25 mils. When calculating the length of each signal, must we add the vias' length in the z direction to the total length? In my design, each address signal has the same number of vias but I drew some of the signals on different intermediate layers. When I add the depth of the via to the total length, there is a difference of about 150 mils. What do you suggest about it, what is the correct calculation in DDR3 routing?
Thanks, regards,
Celile
标签 (1)
1 解答
2,479 次查看
Hi Celile
yes vias length must be added to calculation. In general also may be recommended to perform
ibis modelling.
在原帖中查看解决方案
2 回复数
2,480 次查看
Hi Celile
ibis modelling.
2,469 次查看
celiley
Thank you @igorpadykov
