Configuration of LPDDR
1,986 次查看
Vivekdutt
NXP,
  I'm using i.MX8M Mini EVK board which is very new for me. I want to know which are the things required to change the SIZE of the LPDDR4. And how to configure the LPDDR. Below the tool i'm using.
1. I'm using DDR_MSCALE_tool_V_3.20
2. RPA for register configuration V18.
But i want to change the RAM from 2GB to 1GB.
I want to know to generate the .ds file.
1,980 次查看
Hi Vivek
for different memory size recommended to run DDR Test (and use RPA tool) on below
link and change image as described in document: MSCALE_DDR_Tool_User_Guide
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8M-Family-DDR-Tool-Release/ta-p/110...
also use #define PHYS_SDRAM_SIZE in  uboot-imx/tree/include/configs/imx8mm_evk.h
https://source.codeaurora.org/external/imx/uboot-imx/tree/include/configs/imx8mm_evk.h?h=imx_v2020.0...
