Any way to use hardware acceleration to encode/decode H.264 video stream while it supports AVTP?
2,789 次查看
killedByBugs
I am trying this TSN/AVB demo (link : https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/AVB-TSN-demo-on-i-MX8MP/ta-p/1123791#toc... ) with an imx8qxp MEK board.
I found the following content on that webpage:
Build H.264 SW plugins
AVTPDU uses H.264 as payload for streaming, this requires H.264 encoder/decoder plugins, either software or hardware accelerations. Since we upgrade the Gstreamer and its plugins to a new version, the VPU plugins cannot be used anymore. So software H.264 plugins are required: x264 for encoder, libav for decoder.
It says that VPU plugins cannot be used anymore, but I really want to use hardware acceleration. Also, that page was posted in 2021. Does any GStreamer have plugins which can do encoding/decoding hardware acceleration while it supports AVTP now? Please let me know if there is any.
Thank you in advance.
标记 (1)
2,759 次查看
brian14
Hi @killedByBugs,
Unfortunately, that reference it is outdated. Regarding H264 encoding and decoding you can use some options that are included on our BSP.
Please have a look on the following document at Chapter 3. Decode Examples and Chapter 4. Encode Examples:
i.MX 8 GStreamer User Guide - NXP Community
I hope this information will be helpful.
Have a great day!
2,760 次查看
brian14
Hi @killedByBugs,
Have a great day!
