Android build problem
1,959 次查看
eddiehuang
In imx6dl-sabresd platform, sometimes I might run into errors in the build after modifying some files(before file changed, it was a successful build). Then I undo changes and rebuild, it still fails. I have to remove whole "out" folder to regain a successful build. What could cause this and is there any faster way for recovering a successful build? I'll be appreciated for your replies, thank you.
1,905 次查看
jimmychan
have you try 'make clean'?
1,905 次查看
eddiehuang
Yes, I have tried 'make clean' also. But my problem is, there was a successful build there. Then I modified a file and build again and get an error as a result. Thus I undo that file and built again, it still failed (Isn't it supposed to be built successfully?).
