Android 7.1.2 GSM sim setting and sim signal ui not getting
harishkumarts
Developing android 7.1.2, GSM sim5360e modem, GSM related all ril library's are loaded, But the (sim cards) setting and sim signals are not getting in android UI.
please find my radio log.
01-01 00:07:26.595 272 272 D RILD : **RIL Daemon Started**
01-01 00:07:26.595 272 272 D RILD : **RILd param count=6**
01-01 00:07:26.595 272 272 D use-Rlog/RLOG-RILD: simcom rilLibPath=/system/lib/libreference-ril.so
01-01 00:07:26.742 272 272 D RILD : RIL_Init argc = 5 clientId = 0
01-01 00:07:26.742 272 272 D use-Rlog/RLOG-RIL_SIMCOM: simcom android60 ril_init
01-01 00:07:26.742 272 272 I use-Rlog/RLOG-RIL_SIMCOM: -d Opening tty device /dev/ttyUSB2
01-01 00:07:26.742 272 272 I RIL_SIMCOM: Client id received 0
01-01 00:07:26.742 272 272 I use-Rlog/RLOG-RIL_SIMCOM: RIL_Init tty device: /dev/ttyUSB2
01-01 00:07:26.742 272 272 D RILD : RIL_Init rilInit completed
01-01 00:07:26.742 272 272 I RILC : SIM_COUNT: 1
01-01 00:07:26.743 272 272 E RILC : RIL_register: RIL version 11
01-01 00:07:26.743 272 272 I RILC : s_registerCalled flag set, 1
01-01 00:07:26.743 272 272 I RILC : Start to listen RIL_SOCKET_1
01-01 00:07:26.743 272 272 D use-Rlog/RLOG-RILC: sim60_rilcpp: rild.simcom.gps:
01-01 00:07:26.743 272 272 D RILD : RIL_Init RIL_register completed
01-01 00:07:26.743 272 272 D RILD : RIL_register_socket completed
01-01 00:07:26.743 272 272 D RILD : RIL_Init starting sleep loop
01-01 00:07:26.744 272 299 E use-Rlog/RLOG-RIL_SIMCOM: open devices: /dev/ttyUSB2
01-01 00:07:26.748 272 298 I use-Rlog/RLOG-RIL_RUNTIME: 3G modem monitor thread is start
01-01 00:07:26.752 272 299 E use-Rlog/RLOG-RIL_SIMCOM: open ok, init it.
01-01 00:07:26.753 272 297 D RIL_SIMCOM: setRadioState(0)
01-01 00:07:26.754 272 297 D use-Rlog/RLOG-RIL_SIMCOM: get currentState = 0
01-01 00:07:26.754 272 297 D use-Rlog/RLOG-RIL_SIMCOM: handshake start
01-01 00:07:26.754 272 297 D AT : AT> ATE0Q0V1
01-01 00:07:26.764 272 300 D AT : AT< ATE0Q0V1
01-01 00:07:26.764 272 300 D AT : AT< OK
01-01 00:07:26.765 272 301 D use-Rlog/RLOG-AT: pppcheckLoop start
01-01 00:07:26.765 272 301 D use-Rlog/RLOG-AT: pppcheckLoop listen s_fdPPP
01-01 00:07:26.765 272 301 D use-Rlog/RLOG-AT: pppcheckLoop start accept s_fdPPP
01-01 00:07:27.266 272 297 D use-Rlog/RLOG-RIL_SIMCOM: handshake end
01-01 00:07:27.266 272 297 D use-Rlog/RLOG-RIL_SIMCOM: InitString 2 start
01-01 00:07:27.266 272 297 D AT : AT> ATE0Q0V1
01-01 00:07:27.268 272 300 D AT : AT< OK
01-01 00:07:27.268 272 297 D AT : AT> AT+CMEE=1
01-01 00:07:27.269 272 300 D AT : AT< OK
01-01 00:07:28.269 272 297 D AT : AT> AT+CGMR
01-01 00:07:28.272 272 300 D AT : AT< +CGMR: 35316B08SIM5360E
01-01 00:07:28.272 272 300 D AT : AT< OK
01-01 00:07:28.272 272 297 E use-Rlog/RLOG-RIL_SIMCOM: initalizeMDMInfo supportedTechs 0x00000003 isMultimode 0, mProject = 4
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: get cust type = 0
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.gps:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.stk:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.ussd:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.switch:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: supportFeatures:0x0
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.tbmultisim:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.clvl:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.simcom.csdvc:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: rild.user.define:
01-01 00:07:28.273 272 297 D use-Rlog/RLOG-RIL_SIMCOM: user defined:0x0
01-01 00:07:28.273 272 297 D AT : AT> AT+SIMCOMATI
01-01 00:07:28.279 272 300 D AT : AT< Manufacturer: SIMCOM INCORPORATED
01-01 00:07:28.279 272 300 D AT : AT< Model: SIMCOM_SIM5360E
01-01 00:07:28.279 272 300 D AT : AT< Revision: 35316B08SIM5360E
01-01 00:07:28.279 272 300 D AT : AT< SIM5360E_35316_151208_V1.00
01-01 00:07:28.279 272 300 D AT : AT< QCN:
01-01 00:07:28.279 272 300 D AT : AT< IMEI: XXXXXXXXXXXXXXXXXX
01-01 00:07:28.279 272 300 D AT : AT< +GCAP: +CGSM,+FCLASS,+DS
01-01 00:07:28.279 272 300 D AT : AT< DeviceInfo: 200, 177
01-01 00:07:28.279 272 300 D AT : AT< OK
01-01 00:07:28.279 272 297 D AT : AT> AT+CSUB
01-01 00:07:28.283 272 300 D AT : AT< +CSUB: B08V01
01-01 00:07:28.283 272 300 D AT : AT< OK
01-01 00:07:28.284 272 297 D AT : AT> AT+CQCNV
01-01 00:07:28.287 272 300 D AT : AT< +CQCNV: "SIM5360E_P1.03_20150811"
01-01 00:07:28.287 272 300 D AT : AT< OK
01-01 00:07:28.287 272 297 D AT : AT> ATS0=0
01-01 00:07:28.289 272 300 D AT : AT< ERROR
01-01 00:07:28.289 272 297 D AT : AT> ATV1
01-01 00:07:28.290 272 300 D AT : AT< OK
01-01 00:07:28.291 272 297 D AT : AT> AT+CMEE=1
01-01 00:07:28.295 272 300 D AT : AT< OK
01-01 00:07:28.295 272 297 D AT : AT> AT+CRC=1
01-01 00:07:28.296 272 300 D AT : AT< ERROR
01-01 00:07:28.296 272 297 D AT : AT> AT+CR=1
01-01 00:07:28.300 272 300 D AT : AT< ERROR
01-01 00:07:28.300 272 297 D AT : AT> AT+CMOD=0
01-01 00:07:28.302 272 300 D AT : AT< ERROR
01-01 00:07:28.302 272 297 D AT : AT> AT+CREG=1
01-01 00:07:28.308 272 300 D AT : AT< OK
01-01 00:07:28.308 272 297 D AT : AT> AT+CGREG=1
01-01 00:07:28.309 272 300 D AT : AT< OK
01-01 00:07:28.310 272 297 D AT : AT> AT+CEREG=1
01-01 00:07:28.315 272 300 D AT : AT< ERROR
01-01 00:07:28.315 272 297 D AT : AT> AT+CCWA=1
01-01 00:07:28.316 272 300 D AT : AT< ERROR
01-01 00:07:28.316 272 297 D AT : AT> AT+COLP=0
01-01 00:07:28.320 272 300 D AT : AT< ERROR
01-01 00:07:28.320 272 297 D AT : AT> AT+FCLASS=0
01-01 00:07:28.321 272 300 D AT : AT< OK
01-01 00:07:28.321 272 297 D AT : AT> AT+CSCS="UCS2"
01-01 00:07:28.326 272 300 D AT : AT< ERROR
01-01 00:07:28.326 272 297 D AT : AT> AT+CNLSA=0
01-01 00:07:28.327 272 300 D AT : AT< OK
01-01 00:07:28.327 272 297 D AT : AT> AT+AUTOCSQ=0
01-01 00:07:28.331 272 300 D AT : AT< OK
01-01 00:07:28.331 272 297 D use-Rlog/RLOG-RIL_SIMCOM: custmer init parat 1
01-01 00:07:28.331 272 297 D AT : AT> AT+STK=0
01-01 00:07:28.337 272 300 D AT : AT< OK
01-01 00:07:28.337 272 297 D use-Rlog/RLOG-RIL_SIMCOM: custmer init parat 1 end
01-01 00:07:28.759 272 300 D AT : AT< ERROR
01-01 00:07:30.760 272 300 D AT : AT< ERROR
01-01 00:07:32.736 272 300 D AT : AT< +CPIN: READY
01-01 00:07:32.736 272 300 E use-Rlog/RLOG-RIL_SIMCOM: SIM STATUS CHANGED +CPIN: READY
01-01 00:07:32.737 272 300 D AT : AT< OPL UPDATING
01-01 00:07:32.738 272 300 D AT : AT< PNN UPDATING
01-01 00:07:33.253 275 275 D TelephonyManager: No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
01-01 00:07:33.253 275 275 D TelephonyManager: /proc/cmdline=
01-01 00:07:36.824 272 300 D AT : AT< SMS DONE
01-01 00:07:36.840 272 300 D AT : AT< +CREG: 5
01-01 00:07:36.841 272 297 D use-Rlog/RLOG-RIL_SIMCOM: onCregChanged
01-01 00:07:36.841 272 297 D use-Rlog/RLOG-RIL_SIMCOM: bIgnoreUnsol = 0
01-01 00:07:36.841 272 297 D use-Rlog/RLOG-RIL_SIMCOM: onCregChanged normal end
01-01 00:07:36.841 272 297 D use-Rlog/RLOG-RIL_SIMCOM: bIgnoreUnsol = 1
01-01 00:07:40.550 272 300 D AT : AT< +CGREG: 5
01-01 00:07:40.550 272 297 D use-Rlog/RLOG-RIL_SIMCOM: onCregChanged
01-01 00:07:40.550 272 297 D use-Rlog/RLOG-RIL_SIMCOM: bIgnoreUnsol = 1
01-01 00:07:40.551 272 297 D use-Rlog/RLOG-RIL_SIMCOM: onCregChanged ignore
01-01 00:07:43.205 556 567 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:44.233 556 568 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:44.290 556 556 D TelephonyRegistry: systemRunning register for intents
01-01 00:07:45.368 725 725 D TDC : updateOrInsert: inserting: Modem { uuid=modem, state=0, rilModel=0, rat={}, maxActiveVoiceCall=1, maxActiveDataCall=1, maxStandby=1 }
01-01 00:07:45.368 725 725 D TDC : updateOrInsert: inserting: Sim { uuid=sim, modemUuid=modem, state=0 }
01-01 00:07:45.393 725 725 D CdmaSSM : subscriptionSource from settings: 0
01-01 00:07:45.393 725 725 I PhoneFactory: Cdma Subscription set to 0
01-01 00:07:45.431 725 725 I PhoneFactory: Network Mode set to 0
01-01 00:07:45.436 725 725 D RILJ : RIL(context, preferredNetworkType=0 cdmaSubscription=0)
01-01 00:07:45.456 725 725 D RILJ : Not starting RILReceiver: wifi-only [SUB0]
01-01 00:07:45.457 725 725 D RILJ : [3648]> GET_HARDWARE_CONFIG [SUB0]
01-01 00:07:45.462 725 725 D RilRequest: [3648]< GET_HARDWARE_CONFIG error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:45.463 725 725 I PhoneFactory: Creating SubscriptionController
01-01 00:07:45.482 725 725 D SubscriptionController: [SubscriptionController] init by Context
01-01 00:07:45.485 725 725 D UiccController: Creating UiccController
01-01 00:07:45.500 556 556 D TelephonyRegistry: notifyCellLocationForSubscriber: subId=0 cellLocation=Bundle[{}]
01-01 00:07:45.502 725 740 D SubscriptionController: [getPhoneId]- no sims, returning default phoneId=2147483647
01-01 00:07:45.514 725 725 D Phone : mDoesRilSendMultipleCallRing=true
01-01 00:07:45.515 725 725 D Phone : mCallRingDelay=3000
01-01 00:07:45.532 725 725 D RILJ : [3649]> RIL_REQUEST_START_LCE [SUB0]
01-01 00:07:45.538 725 725 D RilRequest: [3649]< RIL_REQUEST_START_LCE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:45.553 725 725 E RIL_ImsSms: getFormat should never be called from here!
01-01 00:07:45.553 725 725 D SMSDispatcher: SMSDispatcher: ctor mSmsCapable=true format=unknown mSmsSendDisabled=false
01-01 00:07:45.553 725 725 D RIL_ImsSms: ImsSMSDispatcher created
01-01 00:07:45.558 725 725 D SMSDispatcher: SMSDispatcher: ctor mSmsCapable=true format=3gpp2 mSmsSendDisabled=false
01-01 00:07:45.558 725 725 D CdmaSMSDispatcher: CdmaSMSDispatcher created
01-01 00:07:45.585 725 725 D GsmInboundSmsHandler: created InboundSmsHandler
01-01 00:07:45.600 725 725 D CdmaInboundSmsHandler: created InboundSmsHandler
01-01 00:07:45.608 725 725 D SMSDispatcher: SMSDispatcher: ctor mSmsCapable=true format=3gpp mSmsSendDisabled=false
01-01 00:07:45.609 725 725 D GsmSMSDispatcher: GsmSMSDispatcher created
01-01 00:07:45.613 725 785 D GsmInboundSmsHandler: StartupState.processMessage:6
01-01 00:07:45.613 725 787 D CdmaInboundSmsHandler: StartupState.processMessage:6
01-01 00:07:45.615 725 785 D GsmInboundSmsHandler: entering Idle state
01-01 00:07:45.615 725 787 D CdmaInboundSmsHandler: entering Idle state
01-01 00:07:45.619 725 725 D IccCardProxy: ctor: ci=com.android.internal.telephony.RIL@8399bf6 phoneId=0
01-01 00:07:45.620 725 725 D CdmaSSM : subscriptionSource from settings: 0
01-01 00:07:45.620 725 725 D CdmaSSM : cdmaSSM constructor: 0
01-01 00:07:45.620 725 725 D IccCardProxy: update icc_operator_numeric=
01-01 00:07:45.620 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.sim.operator.numeric value: propVal=
01-01 00:07:45.622 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.sim.operator.iso-country value: propVal=
01-01 00:07:45.624 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.sim.operator.alpha value: propVal=
01-01 00:07:45.625 725 725 E IccCardProxy: setExternalState: set mPhoneId=0 mExternalState=NOT_READY
01-01 00:07:45.625 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.sim.state value: NOT_READY propVal=NOT_READY
01-01 00:07:45.630 725 725 D IccCardProxy: broadcastIccStateChangedIntent intent ACTION_SIM_STATE_CHANGED value=NOT_READY reason=null for mPhoneId=0
01-01 00:07:45.675 725 725 D RILJ : setPhoneType=1 old value=0 [SUB0]
01-01 00:07:45.676 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.current.phone-type value: 1 propVal=1
01-01 00:07:45.679 725 725 D IccCardProxy: Setting radio tech UMTS
01-01 00:07:45.679 725 725 D IccCardProxy: updateQuietMode: 3GPP subscription -> newQuietMode=false
01-01 00:07:45.679 725 725 D IccCardProxy: updateQuietMode: no changes don't setExternalState
01-01 00:07:45.679 725 725 D IccCardProxy: updateQuietMode: QuietMode is false (app_type=1 cdmaSource=-1)
01-01 00:07:45.694 725 725 W CarrierConfigManager: Error getting config for subId -1 ICarrierConfigLoader is null
01-01 00:07:45.697 556 567 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:45.726 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.network.type value: Unknown propVal=Unknown
01-01 00:07:45.729 725 725 D RILJ : [3650]> SIGNAL_STRENGTH [SUB0]
01-01 00:07:45.730 725 725 D RilRequest: [3650]< SIGNAL_STRENGTH error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:45.731 725 725 D SST : notifyDataRegStateRilRadioTechnologyChanged: drs=1 rat=0
01-01 00:07:45.732 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.network.type value: Unknown propVal=Unknown
01-01 00:07:45.744 725 725 D DCT : [0]DCT.constructor
01-01 00:07:45.755 556 567 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:45.759 725 725 D Dcc : E ctor
01-01 00:07:45.759 725 725 D Dcc : X ctor
01-01 00:07:45.764 725 725 D SubscriptionController: [getPhoneId] asked for default subId=-1
01-01 00:07:45.773 725 725 D SST : notifyDataRegStateRilRadioTechnologyChanged: drs=1 rat=0
01-01 00:07:45.774 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.network.type value: Unknown propVal=Unknown
01-01 00:07:45.776 725 725 D DCT : [0]update sub = -2
01-01 00:07:45.776 725 725 D DCT : [0]update(): Active DDS, register for all events now!
01-01 00:07:45.778 725 725 D GsmCdmaPhone: [GsmCdmaPhone] updateCurrentCarrierInProvider: mSubId = -2 currentDds = -1 operatorNumeric = null
01-01 00:07:45.783 725 725 D DCT : [0]initApnContexts: E
01-01 00:07:45.784 725 725 D DCT : [0]initApnContexts: skipping unknown type=1
01-01 00:07:45.784 725 725 D DCT : [0]initApnContexts: skipping unknown type=7
01-01 00:07:45.785 725 725 D DCT : [0]initApnContexts: skipping unknown type=9
01-01 00:07:45.829 725 725 D GsmCdmaPhone: [GsmCdmaPhone] GsmCdmaPhone: constructor: sub = 0
01-01 00:07:45.829 725 725 I PhoneFactory: Creating Phone with type = 1 sub = 0
01-01 00:07:45.841 725 725 I PhoneFactory: defaultSmsApplication: NONE
01-01 00:07:45.853 725 725 I PhoneFactory: Creating SubInfoRecordUpdater
01-01 00:07:45.855 725 725 D SubscriptionInfoUpdater: Constructor invoked
01-01 00:07:46.001 556 567 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:46.006 556 687 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:46.017 725 725 D PhoneSwitcher: PhoneSwitcher started
01-01 00:07:46.018 725 725 D ProxyController: Constructor - Enter
01-01 00:07:46.034 725 725 D ProxyController: clearTransaction
01-01 00:07:46.034 725 725 D ProxyController: clearTransaction: phoneId=0 status=IDLE
01-01 00:07:46.034 725 725 D ProxyController: Constructor - Exit
01-01 00:07:46.035 725 725 D TelephonyNetworkFactory[0]: Registering NetworkFactory
01-01 00:07:46.047 725 725 D CallManager: registerPhone(GSM Handler (com.android.internal.telephony.GsmCdmaPhone) {967d494})
01-01 00:07:46.056 556 566 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:46.112 556 566 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:46.156 725 725 D RILJ : [3651]> RIL_REQUEST_SET_TTY_MODE : 0 [SUB0]
01-01 00:07:46.158 725 725 D RilRequest: [3651]< RIL_REQUEST_SET_TTY_MODE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:46.169 556 655 D TelephonyRegistry: listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
01-01 00:07:46.173 725 725 D SubscriptionController: [getPhoneId] asked for default subId=-1
01-01 00:07:46.177 725 725 D UiccController: EVENT_RADIO_UNAVAILABLE, dispose card
01-01 00:07:46.178 725 725 D Phone : config LCE service failed: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE
01-01 00:07:46.179 725 725 D RILJ : [3652]> GET_CURRENT_CALLS [SUB0]
01-01 00:07:46.179 725 725 D RilRequest: [3652]< GET_CURRENT_CALLS error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:46.179 725 725 D GsmSMSDispatcher: GsmSMSDispatcher: subId = -2 slotId = 0
01-01 00:07:46.180 725 725 E IccCardProxy: setExternalState: !override and newstate unchanged from NOT_READY
01-01 00:07:46.180 725 725 D GsmCdmaPhone: [GsmCdmaPhone] Event EVENT_RADIO_OFF_OR_NOT_AVAILABLE Received
01-01 00:07:46.180 725 725 D SST : mDeviceShuttingDown=false, mDesiredPowerState=true, getRadioState=RADIO_UNAVAILABLE, mPowerOffDelayNeed=true, mAlarmSwitch=false, mRadioDisabledByCarrier=false
01-01 00:07:46.181 725 725 D SST : useDataRegStateForDataOnlyDevice: VoiceRegState=1 DataRegState=1
01-01 00:07:46.182 725 725 D SST : Poll ServiceState done: oldSS=[1 1 voice home data home null null null null null null Unknown Unknown CSS not supported 0 0 RoamInd=0 DefRoamInd=0 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false] newSS=[1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false] oldMaxDataCalls=1 mNewMaxDataCalls=1 oldReasonDataDenied=-1 mNewReasonDataDenied=-1
01-01 00:07:46.182 725 725 D SST : updateSpnDisplay: radio is on but out of service, set plmn='No service'
01-01 00:07:46.184 725 725 D SST : updateSpnDisplay: changed sending intent rule=0 showPlmn='true' plmn='No service' showSpn='false' spn='' dataSpn='' subId='-2'
01-01 00:07:46.188 725 725 D SubscriptionController: [setPlmnSpn] No valid subscription to store info
01-01 00:07:46.189 725 725 D SubscriptionController: notifySubscriptionInfoChanged:
01-01 00:07:46.190 556 688 D TelephonyRegistry: notifySubscriptionInfoChanged: first invocation mRecords.size=14
01-01 00:07:46.195 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.operator.alpha value: propVal=
01-01 00:07:46.197 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.operator.numeric value: propVal=
01-01 00:07:46.199 725 725 D SST : operatorNumeric is null
01-01 00:07:46.200 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.operator.iso-country value: propVal=
01-01 00:07:46.201 725 725 D TelephonyManager: setTelephonyProperty: success phoneId=0 property=gsm.operator.isroaming value: false propVal=false
01-01 00:07:46.203 725 725 D SST : Broadcasting ServiceState : 1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false
01-01 00:07:46.203 725 725 D DefaultPhoneNotifier: nofityServiceState: mRegistry=com.android.internal.telephony.ITelephonyRegistry$Stub$Proxy@571222c ss=1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false sender=Handler (com.android.internal.telephony.GsmCdmaPhone) {967d494} phondId=0 subId=-2
01-01 00:07:46.208 725 725 D SubscriptionController: [getSlotId]- subId invalid
01-01 00:07:46.215 556 687 D TelephonyManager: getSimState: default sim:-1, sim state for slotIdx=0 is 6, return state as unknown
01-01 00:07:46.234 725 725 D SST : mDeviceShuttingDown=false, mDesiredPowerState=true, getRadioState=RADIO_UNAVAILABLE, mPowerOffDelayNeed=true, mAlarmSwitch=false, mRadioDisabledByCarrier=false
01-01 00:07:46.235 725 725 D SST : useDataRegStateForDataOnlyDevice: VoiceRegState=1 DataRegState=1
01-01 00:07:46.235 725 725 D SST : Poll ServiceState done: oldSS=[1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false] newSS=[1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false] oldMaxDataCalls=1 mNewMaxDataCalls=1 oldReasonDataDenied=-1 mNewReasonDataDenied=-1
01-01 00:07:46.239 725 725 D DCT : [0]onRadioOffOrNotAvailable: is off and clean up all connections
01-01 00:07:46.239 725 725 D DCT : [0]cleanUpAllConnections: tearDown=false reason=radioTurnedOff
01-01 00:07:46.239 725 725 D DCT : [0]stopNetStatPoll
01-01 00:07:46.245 725 725 D DCT : [0]cleanUpConnection: mDisconnectPendingCount = 0
01-01 00:07:46.247 725 725 D DCT : [0]isDataAllowed: No - defaultDataSelected= false - SIM not loaded - Not attached
01-01 00:07:46.248 725 725 D DCT : [0]onDataConnectionDetached: stop polling and notify detached
01-01 00:07:46.248 725 725 D DCT : [0]stopNetStatPoll
01-01 00:07:46.252 725 725 D DCT : [0]notifyDataConnection: reason=dataDetached
01-01 00:07:46.253 725 725 D DCT : [0]isDataAllowed: No - defaultDataSelected= false - SIM not loaded - Not attached
01-01 00:07:46.253 725 725 D DCT : [0]onRoamingOff
01-01 00:07:46.253 725 725 D DCT : [0]setDataProfilesAsNeeded mSetDataProfileStatus: 0
01-01 00:07:46.255 725 725 D DCT : [0]isDataAllowed: No - defaultDataSelected= false - SIM not loaded - Not attached
01-01 00:07:46.256 725 725 D DCT : [0]setupDataOnConnectableApns: roamingOff
01-01 00:07:46.256 725 725 D DCT : [0]setupDataOnConnectableApns: nwTypeChanged
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: [Receiver]+
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: Action: android.intent.action.SIM_STATE_CHANGED
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: slotId: 0
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: simStatus: NOT_READY
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: Ignoring simStatus: NOT_READY
01-01 00:07:46.257 725 725 D SubscriptionInfoUpdater: [Receiver]-
01-01 00:07:46.259 725 725 D TelephonyNetworkFactory[0]: onSubIdChange -1->-2
01-01 00:07:46.259 725 725 D TelephonyNetworkFactory[0]: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:07:46.261 725 725 D DebugService: DebugService DebugService:
01-01 00:07:46.266 725 725 D RILJ : [3653]> RIL_REQUEST_QUERY_TTY_MODE [SUB0]
01-01 00:07:46.266 725 725 D RilRequest: [3653]< RIL_REQUEST_QUERY_TTY_MODE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
01-01 00:07:46.267 725 725 D GsmSMSDispatcher: GsmSMSDispatcher: subId = -2 slotId = 0
01-01 00:07:46.267 725 725 E IccCardProxy: setExternalState: !override and newstate unchanged from NOT_READY
01-01 00:07:46.267 725 725 D GsmCdmaCallTracker: Event EVENT_POLL_CALLS_RESULT Received
01-01 00:07:46.268 725 725 D GsmCdmaCallTracker: [GsmCdmaCallTracker] update phone state, old=IDLE new=IDLE
01-01 00:07:46.268 725 725 D SST : SubscriptionListener.onSubscriptionInfoChanged
01-01 00:07:46.268 725 725 E Phone : getStoredVoiceMessageCount: invalid subId -2
01-01 00:07:46.268 725 725 D GsmCdmaPhone: [GsmCdmaPhone] updateVoiceMail countVoiceMessages = 0 subId -2
01-01 00:07:46.268 725 725 E Phone : setVoiceMessageCount in sharedPreference: invalid subId -2
01-01 00:07:46.268 725 725 D DCT : [0]SubscriptionListener.onSubscriptionInfoChanged
01-01 00:07:46.269 725 725 D PhoneSwitcher: evaluating due to subChanged default 0->-1 phone[0] 0->-2
01-01 00:07:46.271 725 725 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:46.273 725 725 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:46.369 725 725 D PhoneSwitcher: evaluating due to netRequest
01-01 00:07:46.373 725 725 D TelephonyNetworkFactory[0]: not acting - isApp=false, isAct=false NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
01-01 00:07:47.164 272 300 D AT : AT< CALL READY
01-01 00:07:47.165 272 300 D AT : AT< PB DONE
01-01 00:07:47.371 725 740 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:47.386 725 739 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:47.402 725 739 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:47.608 725 740 D SubscriptionController: [getPhoneId] asked for default subId=-1
01-01 00:07:48.583 725 784 D GsmCellBroadcastHandler: mWakeLock released
01-01 00:07:48.600 725 786 D CellBroadcastHandler: mWakeLock released
01-01 00:07:48.609 725 788 D CdmaServiceCategoryProgramHandler: mWakeLock released
01-01 00:07:48.616 725 787 D CdmaInboundSmsHandler: IdleState.processMessage:5
01-01 00:07:48.616 725 787 D CdmaInboundSmsHandler: Idle state processing message type 5
01-01 00:07:48.619 725 785 D GsmInboundSmsHandler: IdleState.processMessage:5
01-01 00:07:48.619 725 785 D GsmInboundSmsHandler: Idle state processing message type 5
01-01 00:07:48.621 725 787 D CdmaInboundSmsHandler: mWakeLock released
01-01 00:07:48.623 725 785 D GsmInboundSmsHandler: mWakeLock released
01-01 00:07:50.661 725 725 D WAP PUSH: Received broadcast android.intent.action.USER_UNLOCKED
01-01 00:07:50.665 725 725 D WAP PUSH: Received broadcast android.intent.action.USER_UNLOCKED
01-01 00:07:50.667 725 725 D SmsBroadcastUndelivered: Received broadcast android.intent.action.USER_UNLOCKED
01-01 00:07:50.671 725 725 D SubscriptionInfoUpdater: [Receiver]+
01-01 00:07:50.672 725 725 D SubscriptionInfoUpdater: Action: android.intent.action.USER_UNLOCKED
01-01 00:07:50.673 725 725 D SubscriptionInfoUpdater: Broadcasting intent ACTION_SIM_STATE_CHANGED for mCardIndex: 0
01-01 00:07:50.685 725 725 D SubscriptionInfoUpdater: [Receiver]-
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: [Receiver]+
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: Action: android.intent.action.SIM_STATE_CHANGED
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: slotId: 0
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: simStatus: NOT_READY
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: Ignoring simStatus: NOT_READY
01-01 00:07:50.690 725 725 D SubscriptionInfoUpdater: [Receiver]-
01-01 00:07:50.721 725 1002 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:50.765 725 1005 E WAP PUSH: bindService() for wappush manager failed
01-01 00:07:50.774 725 1007 D SmsBroadcastUndelivered: scanning raw table for undelivered messages
01-01 00:07:50.778 725 1006 E WAP PUSH: bindService() for wappush manager failed
01-01 00:07:51.097 725 1007 D SmsBroadcastUndelivered: finished scanning raw table in 322 ms
01-01 00:07:57.256 725 739 D SubscriptionController: [getActiveSubInfoList] Sub Controller not ready
01-01 00:07:58.497 725 725 D SubscriptionController: [getPhoneId] asked for default subId=-1
01-01 00:07:58.825 725 725 D GsmCdmaPhone: mBroadcastReceiver: action android.telephony.action.CARRIER_CONFIG_CHANGED
01-01 00:07:58.831 725 725 I CSST : reading time to delay notification: -1
01-01 00:07:58.852 725 725 D ImsManager: updateVolteFeatureValue: available = false, enabled = true, nonTTY = true
01-01 00:07:58.853 725 725 E ImsManager: updateImsServiceConfig:
01-01 00:07:58.853 725 725 E ImsManager: com.android.ims.ImsException: Service is unavailable, code = 106
01-01 00:07:58.853 725 725 E ImsManager: at com.android.ims.ImsManager.checkAndThrowExceptionIfServiceUnavailable(ImsManager.java:1316)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.ims.ImsManager.getConfigInterface(ImsManager.java:1198)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.ims.ImsManager.updateVolteFeatureValue(ImsManager.java:780)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.ims.ImsManager.updateImsServiceConfig(ImsManager.java:740)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.internal.telephony.GsmCdmaPhone.handleMessage(GsmCdmaPhone.java:2084)
01-01 00:07:58.853 725 725 E ImsManager: at android.os.Handler.dispatchMessage(Handler.java:102)
01-01 00:07:58.853 725 725 E ImsManager: at android.os.Looper.loop(Looper.java:154)
01-01 00:07:58.853 725 725 E ImsManager: at android.app.ActivityThread.main(ActivityThread.java:6121)
01-01 00:07:58.853 725 725 E ImsManager: at java.lang.reflect.Method.invoke(Native Method)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:890)
01-01 00:07:58.853 725 725 E ImsManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:780)
01-01 00:07:58.855 725 725 D GsmCdmaPhone: [GsmCdmaPhone] broadcastEmergencyCallStateChanges = false
01-01 00:07:58.856 725 725 E GsmCdmaPhone: [GsmCdmaPhone] Invalid cdma_roaming_mode settings: -1
01-01 00:07:58.856 725 725 D EriManager: loadEriFileFromXml: check for alternate file
01-01 00:07:58.857 725 725 D EriManager: loadEriFileFromXml: no alternate file
01-01 00:07:58.858 725 725 D EriManager: eriFile = eri.xml
01-01 00:07:58.885 725 725 D EriManager: loadEriFileFromXml: eri parsing successful, file loaded. ver = 1357, # of entries = 176
01-01 00:07:58.886 725 725 D GsmCdmaPhone: [GsmCdmaPhone] ERI read, notify registrants
01-01 00:11:44.996 272 300 D AT : AT< +CGPS: 0
01-01 00:37:18.039 725 725 D RILJ : [3654]> RIL_REQUEST_GET_ACTIVITY_INFO [SUB0]
01-01 00:37:18.040 725 725 D RilRequest: [3654]< RIL_REQUEST_GET_ACTIVITY_INFO error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret=
Please give me solution to resolve this issue.
Regards, Harish.
b36401
I see such messages in the log:
So please doublecheck sim-card connection.
Victor
harishkumarts
How can I debug this
Please give me your support to get the sim status.
