i.MX8M resets
i.MX8M resets
vadimaleynikov
Which internal i.MX8M resets can be routed outside the chip?
Bio_TICFSL
Hi Vadim,
The RTC_POR_B con be routed outside the chip.
vadimaleynikov
The IMX8M Reference Manual doesn't contain this name. Maybe you referred to snvsmix.RTC_POR_B in the following IMX8M datasheet row (Table 82):
but this is an input, not an internally generated reset. Please explain what you meant.
Vadim Aleynikov
