Android 11 Image.zl4 compression issue while building kernel
SL239
Has anyone else encountered this problem while trying to build Android 11 Automotive on Ubuntu for the iMX8 board?
It occurs when I run "./imx-make.sh -j4 2>&1 | tee build-log.txt" and prevents the kernel from being built.
Android 10 builds just fine.
Thanks.
SL239
So I was able to get around this issue. I was using the IMX8QM board, I was trying to run NXP's 11.0.0_2.4.0_ANDROID_SOURCE with an automotive build configuration. I guess automotive is not supported in this release. I ended up using NXP's automotive_11.0.0_2.3 instead and it built just fine. Thank you.
jimmychan
There are different version of Android Auto BSP.
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-automotive-os-for-i-mx-a...
Could you tell me which one are you using?
Which board are you using?
