ADV7180 bridge driver
amonica
  I wanted to make a bridge driver for adv7180 to bind to the subdev driver. I have gone through the V4L2 doc and tried to make a bridge driver to register the adv7180 device driver as a video node in /dev/videoX .
  1.So my doubt first how does the bridge driver and adv7180 communicate?
  2.So have I to insert both if so which one first?
I have added both the code below
Agnes
Original Attachment has been moved to: adv7180.c.zip
Original Attachment has been moved to: bridge2.c.zip
Tags (2)
Hi AGNES
please check links below
TVP5150 on IMX6Q
Re: ADV7181 on IMX6Q board
shortly, one needs to use mxc_v4l2_tvin.out to capture video
registered as /dev/video17. Please check example codes of
mxc_v4l2_tvin.out in imx-test package (selected in ltib, below BSP link).
L3.0.35_4.1.0_ER_SOURCE_BSP :
chip
