iMX8QXP: Use JPEG decoder in M4 SDK
iMX8QXP/iMX8QM have hardware JPEG decoder: The JPEG-D-X core. This is the example code to use this hw decoder in M4 SDK to decode JPEG files.
M4_JPEG_DECODER_SDK_2.5.1.7z
The attached "rear_view_camera_jpegdec.tar.bz2" is the updated source code for "SDK\boards\mekmimx8qx\demo_apps\rear_view_camera". It is based on SDK 2.5.1 for iMX8QXP MEK.
The "rear_view_camera_jpegdec.patch" is the modified code, it hasn't included the added "fsl_jpeg_dec.c" and "fsl_jpeg_dec.h".
The testing used two 256*256 JPEG files, they are RGB color space. We used followed commands to build them into flash.bin:
./mkimage_imx8 -soc QX -rev B0 -append ahab-container.img -c -scfw scfw_tcm.bin -m4 m4_rear_view_camera.bin 0 0x34FE0000 --data demo_rgb.jpg 0x84000000 --data demo_rgb2.jpg 0x84008000 -out flash.bin
If customer need change the JPEG resoluion, they can change them in file "fsl_jpeg_dec.h", APP_JPEG_SIZE_OF_KB is the JPEG file length in memory, aligned in KB.
#define APP_JPEG_WIDTH (256)
#define APP_JPEG_HEIGHT (256)
#define APP_JPEG_SIZE_OF_KB (32)
#define APP_JPEG_FORMAT JPEG_RGB
#define APP_JPEG_BUFFER (0x84000000)
To created RGB format JPEG file from RGB data, the customer can use linux unit test application "/unit_tests/JPEG/encoder_test.out".
M4_JPEG_DECODER_WINDOW_MODE_SDK_2.5.1.7z
Based on JEPG decoder, added DPU CSC support and render JEPG decoded video in overlay window.
The architecture is followed: NXP logo is put in FetchLayer0 with RGB565 format, after LayerBlend0, it will be the prim layer for LayberBlend1 (FetchLayer0 can't be used as prim layer for LayerBlend), the JPEG decoder output is put to FetchDecoder0. RGB888 format, and it will be resize to 640*480, and put to x=100, y=100 of the display. (Only the sec layer of LayerBlend can be window mode).
Some limitation for layer selection in LayerBlend:
タグ(2)
添付
コメント
I am using the Media SDK 2014 R2 for Clients that I recently downloaded from the Intel site.  I also downloaded the Intel Media SDK Samples and built the Video Decoding Sample and was able to successfully decode and render an output image as well as convert the resulting output to YUV frames My Lowes Life.
This reference decoder code is based on the hardware JPEG decoder in iMX8QXP chip, it is not software based decoder.
where can get the tools("/unit_tests/JPEG/encoder_test.out").
If you had built the Yocto BSP successfully, in the download folder, there is a package "linux-test-xxx.tar.gz", it includes all unit tests codes.
I am porting according to your patch. Found that M4 is directly attached to APP_InitJpeg_Dec(), then I applied for SC_R_MJPEG_DEC_MP and SC_R_MJPEG_DEC_S0 in scfw. M4 can run, but there is no picture display, and the JPEG interrupt program does not run.
The memory buffer used in M4 for jpeg file and decoder should also be checked. They should be assigned to M4 in SCFW too.
Can you send me the relevant configuration of SCFW?
For shared memory related issue, you can reference to Android BSP and https://community.nxp.com/docs/DOC-343706.
I found that after decoding the jpg image, the color of the displayed image is incorrect
There are many different kinds of JPEG files, you use set the correct one in M4:
 JPEG_YUV420 = 0x0, /* 2 Plannar, Y=1st plane UV=2nd plane */
 JPEG_YUV422 = 0x1, /* 1 Plannar, YUYV sequence */
 JPEG_RGB = 0x2, /* RGBRGB packed format */
 JPEG_YUV444 = 0x3, /* 1 Plannar, YUVYUV sequence */
 JPEG_GRAY = 0x4, /* Y8 or Y12 or Single Component */
 JPEG_RESERVED = 0x5,
 JPEG_ARGB = 0x6,
Are there any patch for imx8qm-mek?
Hi Chen King
The JPEG module is same in iMX8QM and iMX8QXP, so the code can be used on iMX8QM too.
Thank you @qiang_li-mpu_se for sharing, works like a charm.
For those using windows/WSL, you can convert the 2 patched file in Linux text format, in Linux fil format, in your WSL Linux:
$ sudo apt-get install dos2unix
$ dos2unix devices/MIMX8QX6/drivers/fsl_dpu.c
$ dos2unix devices/MIMX8QX6/drivers/fsl_dpu.h
$ patch -p1 < mcu_sdk_dpu_driver.patch
If you use a Lauterbach probe you can also avoid using mkimage, but just load jpeg images thru JTAG by adding the following command in your cmm file:
data.load.binary "256x256_1.jpg" 0x84000000
data.load.binary "256x256_2.jpg" 0x84008000
I have monitored the decode time for a 1280x480 file and it is quite fast, including OS overhead and display, it last #5.1ms:
%3CLINGO-SUB%20id%3D%22lingo-sub-1101663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8QXP%3AM4SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EiMX8QXP%20%2F%20iMX8QM%E3%81%AB%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2JPEG-D-X%E3%82%B3%E3%82%A2%E3%81%AEJPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81M4%20SDK%E3%81%A7%E3%81%93%E3%81%AEhw%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6JPEG%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EM4_JPEG_DECODER_SDK_2.5.1.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%8Crear_view_camera_jpegdec.tar.bz2%E3%80%8D%E3%81%AF%E3%80%81%E3%80%8CSDK%5Cboards%5Cmekmimx8qx%5Cdemo_apps%5Crear_view_camera%E3%80%8D%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81iMX8QXP%20MEK%E7%94%A8%E3%81%AESDK%202.5.1%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8Crear_view_camera_jpegdec.patch%E3%80%8D%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%80%8Cfsl_jpeg_dec.c%E3%80%8D%E3%81%A8%E3%80%8Cfsl_jpeg_dec.h%E3%80%8D%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81RGB%E8%89%B2%E7%A9%BA%E9%96%93%E3%81%A7%E3%81%82%E3%82%8B2%E3%81%A4%E3%81%AE256%20*%20256%20JPEG%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92flash.bin%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E.%2Fmkimage_imx8%20-soc%20QX%20-rev%20B0%20-append%20ahab-container.img%20-c%20-scfw%20scfw_tcm.bin%20-m4%20m4_rear_view_camera.bin%200%200x34FE0000%20--data%20demo_rgb.jpg%200x84000000%20--data%20demo_rgb2.jpg%200x84008000%20-out%20flash.bin%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8CJPEG%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cfsl_jpeg_dec.h%E3%80%8D%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82APP_JPEG_SIZE_OF_KB%20%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%20JPEG%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E9%95%B7%E3%81%95%E3%81%A7%E3%80%81KB%20%E5%8D%98%E4%BD%8D%E3%81%A7%E6%95%B4%E5%88%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%23define%20APP_JPEG_WIDTH%20(256)%3CBR%20%2F%3E%23define%20APP_JPEG_HEIGHT%20(256)%3CBR%20%2F%3E%23define%20APP_JPEG_SIZE_OF_KB%20(32)%3CBR%20%2F%3E%23define%20APP_JPEG_FORMAT%20JPEG_RGB%3C%2FP%3E%3CP%3E%23define%20APP_JPEG_BUFFER%20(0x84000000)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERGB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89RGB%E5%BD%A2%E5%BC%8F%E3%81%AEJPEG%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Linux%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8C%2Funit_tests%2FJPEG%2Fencoder_test.out%E3%80%8D%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EM4_JPEG_DECODER_WINDOW_MODE_SDK_2.5.1.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EJEPG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81DPU%20CSC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7JEPG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%200cm%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%3ANXP%E3%83%AD%E3%82%B4%E3%81%AFRGB565%E5%BD%A2%E5%BC%8F%E3%81%AEFetchLayer0%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%80%81LayerBlend0%E3%81%AE%E5%BE%8C%E3%80%81LayberBlend1%E3%81%AE%E3%83%97%E3%83%AA%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99(FetchLayer0%E3%81%AFLayerBlend%E3%81%AE%E3%83%97%E3%83%AA%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%81JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E5%87%BA%E5%8A%9B%E3%81%AFFetchDecoder0%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82RGB888%20%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%80%81640*480%20%E3%81%AB%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%20x%3D100%E3%80%81y%3D100%20%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82(LayerBlend%E3%81%AEsec%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E3%81%BF%E3%81%8C%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2202.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2202.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F116531iACBB3D151E273992%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2202.png%22%20alt%3D%2202.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E02.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%200cm%200pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20font-size%3A%2010.5pt%3B%22%3ELayerBlend%E3%81%A7%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E9%81%B8%E6%8A%9E%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2201.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2201.jpg%22%20style%3D%22width%3A%20768px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F116532i1B4B0968C1E4CB2F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2201.jpg%22%20alt%3D%2201.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E01.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1101663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1209023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1209023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F4760%22%20target%3D%22_blank%22%3E%40qiang_li-mpu_se%3C%2FA%3E%E3%80%81%E9%AD%85%E5%8A%9B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EWindows%20%2F%20WSL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92Linux%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%80%81Linuxfil%E5%BD%A2%E5%BC%8F%E3%81%A7WSLLinux%E3%81%A7%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3E%24%20sudo%20apt-get%20install%20dos2unix%3CBR%20%2F%3E%24%20dos2unix%20devices%2FMIMX8QX6%2Fdrivers%2Ffsl_dpu.c%3CBR%20%2F%3E%24%20dos2unix%20devices%2FMIMX8QX6%2Fdrivers%2Ffsl_dpu.h%3CBR%20%2F%3E%24%20patch%20-p1%20%26lt%3B%20mcu_sdk_dpu_driver.patch%3C%2FPRE%3E%0A%3CP%3ELauterbach%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81mkimage%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81cmm%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81JTAG%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6jpeg%E7%94%BB%E5%83%8F%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Edata.load.binary%20%22256x256_1.jpg%22%200x84000000%3CBR%20%2F%3Edata.load.binary%20%22256x256_2.jpg%22%200x84008000%3C%2FPRE%3E%0A%3CP%3E%E7%A7%81%E3%81%AF1280x480%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E6%99%82%E9%96%93%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81OS%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%82%92%E5%90%AB%E3%82%81%E3%81%A6%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%AB%98%E9%80%9F%E3%81%A7%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AF%235.1ms%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vincent_aubinea_0-1610032404655.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vincent_aubinea_0-1610032404655.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F134349i8806E43EC8C8870B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22vincent_aubinea_0-1610032404655.png%22%20alt%3D%22vincent_aubinea_0-1610032404655.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Evincent_aubinea_0-1610032404655.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vincent_aubinea_1-1610032478634.png%22%20style%3D%22width%3A%20466px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vincent_aubinea_1-1610032478634.png%22%20style%3D%22width%3A%20466px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F134350iD399CE6EBB39AEE0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22vincent_aubinea_1-1610032478634.png%22%20alt%3D%22vincent_aubinea_1-1610032478634.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Evincent_aubinea_1-1610032478634.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JPEG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JPEG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F105663i4E3591E1D400C3BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22JPEG.jpg%22%20alt%3D%22JPEG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJPEG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%8F%E3%82%A4%E3%83%BB%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22346412%22%20data-username%3D%22jinchen1227%40qq.com%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjinchen1227%40qq.com%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%230066cc%3B%20text-decoration%3A%20underline%3B%22%3E%E3%83%81%E3%82%A7%E3%83%B3%E3%83%BB%E3%82%AD%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3EiMX8QM%E3%81%A8iMX8QXP%E3%81%A7%E3%81%AFJPEG%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81iMX8QM%E3%81%A7%E3%82%82%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eimx8qm-mek%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJPEG%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E7%A8%AE%E9%A1%9E%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81M4%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJPEG_YUV420%20%3D%200x0%2C%20%2F*%202%20%E5%B9%B3%E9%9D%A2%2C%20Y%3D1%20%E5%B9%B3%E9%9D%A2%20UV%3D2%20%E5%B9%B3%E9%9D%A2%20*%2F%3CBR%20%2F%3EJPEG_YUV422%20%3D%200x1%2C%20%2F*%201%20Plannar%2C%20YUYV%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%20*%2F%3CBR%20%2F%3EJPEG_RGB%20%3D%200x2%2C%20%2F*%20RGBRGB%20%E3%83%91%E3%83%83%E3%82%AF%E5%BD%A2%E5%BC%8F%20*%2F%3CBR%20%2F%3EJPEG_YUV444%20%3D%200x3%2C%20%2F*%201%20Plannar%2C%20YUVYUV%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%20*%2F%3CBR%20%2F%3EJPEG_GRAY%20%3D%200x4%2C%20%2F*%20Y8%20%E3%81%BE%E3%81%9F%E3%81%AF%20Y12%20%E3%81%BE%E3%81%9F%E3%81%AF%E5%8D%98%E4%B8%80%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%20*%2F%3CBR%20%2F%3EJPEG_RESERVED%20%3D%200x5%E3%80%81%3CBR%20%2F%3EJPEG_ARGB%20%3D%200x6%E3%80%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ejpg%E7%94%BB%E5%83%8F%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150635.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150635.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97165iB2BAAFF4393B39AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150635.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150635.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150635.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150629.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150629.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97034iB2BA3563214DC138%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150629.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150629.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20200119150629.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E9%96%A2%E9%80%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Android%20BSP%20%E3%81%A8%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343706%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343706%3C%2FA%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESCFW%E3%81%AE%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%A7%8B%E6%88%90%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EM4%E3%81%A7jpeg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%BD%BC%E3%82%89%E3%82%82SCFW%E3%81%AEM4%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82M4%E3%81%8CAPP_InitJpeg_Dec()%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81scfw%E3%81%A7SC_R_MJPEG_DEC_MP%E3%81%A8SC_R_MJPEG_DEC_S0%E3%82%92%E7%94%B3%E8%AB%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82M4%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81JPEG%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EYocto%20BSP%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%80%8Clinux-test-xxx.tar.gz%E3%80%8D%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%84%E3%83%BC%E3%83%AB(%20%22%2F%20unit_tests%2F%20JPEG%20%2F%20encoder_test.out%22)%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E5%8F%82%E7%85%A7%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81iMX8QXP%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8QXP%3AM4%20SDK%E3%81%A7JPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2353575e%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012px%3B%22%3E%E6%9C%80%E8%BF%91%20Intel%20%E3%81%AE%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%20Media%20SDK%202014%20R2%20for%20Clients%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81Intel%20Media%20SDK%20Samples%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%20Video%20Decoding%20Sample%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E5%87%BA%E5%8A%9B%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E7%B5%90%E6%9E%9C%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.myloweslife.us%2F%22%20style%3D%22color%3A%20%23000000%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EYUV%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20My%20Lowes%20Life%3C%2FA%3E%3C%2FSPAN%3E%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-31-2019 07:55 PM
更新者:
