iMX6QD How to Add 24-bit LVDS Support in Android
Introduction
LVDS display panel driving data flow:
Display quality:
To get the best display quality for 24bit LVDS display panel in Android, we should use 32bit framebuffer, make IPUv3 display Engine and LDB output 24bit pixels, since RGB component information is aligned from source to destination.
2 stages to enable display:
Uboot splash screen and Kernel framebuffer
Guidelines
Uboot splash screen:
   Change should be done in board file, like board/freescale/mx6q_sabresd/mx6q_sabresd.c:
   1. Set video mode in struct fb_videomode according to the new 24bit LVDS display panel’s spec(please, refer to the example at the end of this doc).
   2. Set up pwm, iomux/display related clock trees in lcd_enable(). Note that these should be aligned with Kernel settings to support smooth UI transition
       from Uboot splash screen to Kernel framebuffer.
   3. Set the output pixel format of IPUv3 display engine and LDB to IPU_PIX_FMT_RGB24 when calling ipuv3_fb_init().
   4. Set pixel clock according to the new 24bit LVDS display panel’s spec when calling ipuv3_fb_init().
   5. If dual LDB channels are needed to support tough display video mode(high resolution or high pixel clock frequency), we need to enable both of the two LDB
       channels and set LDB to work at split mode. LDB_CTRL register should be set accordingly in lcd_enable().
Kernel framebuffer:
   As we may add ‘video=‘  and ‘ldb=’ options in kernel bootup command line, Kernel code is more flexible to handle different LVDS display panels with various display color depth than Uboot code. For detail description of ‘video=’ and ‘ldb=’ option, please refer to MXC Linux BSP release notes and Android User Guide. Some known points are:
   1. Add a video mode in struct fb_videomode in drivers/video/mxc/ldb.c according to the new 24bit LVDS display panel’s spec(please, refer to the example at
   2. Set up pwm backlight/display related iomux in platform code.
  3. Set appropriate ‘video=‘ option in kernel bootup command line, for example:
       video=mxcfb0:dev=ldb,LDB-NEW,if=RGB24,fbpix=RGB32
    4. Set appropriate ‘ldb=‘ option in kernel bootup command line if dual LDB channels are needed to support tough display video mode, for example:
       ldb=spl0 (IPUv3 DI0 is used)  or  ldb=spl1 (IPUv3 DI1 is used)
   5. Set appropriate ‘fbmem=‘ option in kernel bootup command line to reserve enough memory for framebuffer. For example, if we use 1280x800 LVDS panel
       for fb0 and fb0 is in RGB32 pixel format, then ‘fbmem=12M’ should be used, since the formula is:
       fbmem= width*height*3(triple buf)*Bytes_per_pixel= 1280*800*3*4B=12MB
An Example to Set struct fb_videomode:
   Let’s take a look at the timing description quoted from a real 1280x800@60 24bit LVDS panel spec:
And, standard linux struct fb_videomode definition in include/linux/fb.h:
struct fb_videomode {
        const char *name;       /* optional */
        u32 refresh;            /* optional */
        u32 xres;
        u32 yres;
        u32 pixclock;
        u32 left_margin;
        u32 right_margin;
        u32 upper_margin;
        u32 lower_margin;
        u32 hsync_len;
        u32 vsync_len;
        u32 sync;
        u32 vmode;
        u32 flag;
   What we need to do is to set every field of struct fb_videomode correctly according to the timing description of LVDS display panel’s spec:
    1. name: we can set it to ‘LDB-WXGA’.
   2. refresh: though it’s optional, we can set it to typical value, that is, 60(60Hz refresh rate).
   3. xres: the active width, that is, 1280.
   4. yres: the active height, that is, 800.
   5. pixclock: calculate with this formula – pixclock=(10^12)/clk_freq. Here, typically, for this example, pixclock=(10^12)/71100000=14065.
   6. left_margin/right_margin/hsync_len:
       They are the same to HS Back Porch(HBP)/HS Front Porch(HFP)/HS Width(HW) in the spec. Since the spec only tells us that typically
       HBP+HFP+HW=160. We may set left_margin=40, right_margin=40, hsync_len=80.
   7. upper_margin/lower_margin/vsync_len:
       Similar to horizontal timing, the vertical ones can be set to upper_margin=10, lower_margin=3, vsync_len=10.
   8. sync: Since the timing chart tells us that hsync/vsync are active low, so we don’t need to set FB_SYNC_HOR_HIGH_ACT or
       FB_SYNC_VERT_HIGH_ACT. Moreover, clock polarity and data polarity are invalid, so we set sync to be zero here.
   9. vmode: this is a progressive video mode, so set vmode to FB_VMODE_NONINTERLACED.
   10. flag: the video mode is provided by driver, so set flag to FB_MODE_IS_DETAILED.
标签 (3)
评论
Hi There,
Thanks for this detailed guide, very helpful!
However I can't seem to see any changes to my pixel clock, can you please elaborate on your u-boot step #4 "  4. Set pixel clock according to the new 24bit LVDS display panel’s spec when calling ipuv3_fb_init()."
How is this actually done?  Which file should we be modifying in u-boot.  Anything we change it always seems to output 75MHz.   We are using the mainline u-boot 2014-10 source.
Patrick
Thank you for the tutorial. But as i see, it is not applicable in Android Lollipop release, because the "ldb.c" is different.
In my case the timings are fine. I have a LVDS panel that does not support EDID. I just want to change the default resolution from 1024x768 to 1024x600. My lvds panel works fine but the bottom stays outside of the panel. How can i fix this in Android Lollipop?
LCD:CHIMEI G070Y2-L01
MCU:IMX6D
{“LBD-CHIMEI”,60,800,480,33898,
190,0,
14,14,
2,2,
0,
FB_VMODE_NONINTERLACED,
BF_MODE_IS_DETAILED,
LCD AA084BX01 works fine
please help
I have found the problem,it seems pixclock can only be set to up 40MHz,lower then 40MHz it's always output 40MHz,and my lcd can only works in 27MHz to 32Mhz
%3CLINGO-SUB%20id%3D%22lingo-sub-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6QD%E5%A6%82%E4%BD%95%E5%9C%A8Android%E4%B8%AD%E6%B7%BB%E5%8A%A024%E4%BD%8DLVDS%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380605108%22%20id%3D%22toc-hId-1304187641%22%3E%E7%AE%80%E4%BB%8B%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ELVDS%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E9%A9%B1%E5%8A%A8%E6%95%B0%E6%8D%AE%E6%B5%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38257i3412AADD37D3D9C4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture2.png%22%20alt%3D%22Picture2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%98%BE%E7%A4%BA%E8%B4%A8%E9%87%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E4%B8%BA%E4%BA%86%E5%9C%A8%20Android%20%E4%B8%AD%E8%8E%B7%E5%BE%97%2024%20%E4%BD%8D%20LVDS%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E7%9A%84%E6%9C%80%E4%BD%B3%E6%98%BE%E7%A4%BA%E8%B4%A8%E9%87%8F%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%2032%20%E4%BD%8D%E5%B8%A7%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%E4%BD%BF%20IPUv3%20%E6%98%BE%E7%A4%BA%E5%BC%95%E6%93%8E%E5%92%8C%20LDB%20%E8%BE%93%E5%87%BA%2024%20%E4%BD%8D%E5%83%8F%E7%B4%A0%EF%BC%8C%E5%9B%A0%E4%B8%BA%20RGB%20%E7%BB%84%E4%BB%B6%E4%BF%A1%E6%81%AF%E4%BB%8E%E6%BA%90%E5%88%B0%E7%9B%AE%E6%A0%87%E6%98%AF%E5%AF%B9%E9%BD%90%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%90%AF%E7%94%A8%E6%98%BE%E7%A4%BA%E7%9A%84%202%20%E4%B8%AA%E9%98%B6%E6%AE%B5%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EUboot%20%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%E5%92%8C%E5%86%85%E6%A0%B8%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426849355%22%20id%3D%22toc-hId--503266822%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%8C%87%E5%8D%97%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f7f7f%3B%20font-family%3A%20Arial%3B%20font-size%3A%2037px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--736287881%22%20id%3D%22toc-hId-187294652%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EUboot%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%BA%94%E5%9C%A8%E6%9D%BF%E6%96%87%E4%BB%B6%E4%B8%AD%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%EF%BC%8C%E4%BE%8B%E5%A6%82%20board%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efreescale%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2Fmx6q_sabresd%2Fmx6q_sabresd.c%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E1.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%A0%B9%E6%8D%AE%E6%96%B0%E7%9A%84%2024%20%E4%BD%8D%20LVDS%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E7%9A%84%20%E8%A7%84%E6%A0%BC%E5%9C%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20struct%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20fb_videomode%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%20%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E6%96%87%E6%A1%A3%E6%9C%AB%E5%B0%BE%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E2.%20%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20lcd_enable%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20()%20%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E8%AE%BE%E7%BD%AE%20pwm%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20iomux%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%2Fdisplay%20%E7%9B%B8%E5%85%B3%E7%9A%84%E6%97%B6%E9%92%9F%E6%A0%91%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20%E3%80%82%20%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%BA%94%E4%B8%8E%E5%86%85%E6%A0%B8%E8%AE%BE%E7%BD%AE%E4%BF%9D%E6%8C%81%E4%B8%80%E8%87%B4%EF%BC%8C%E4%BB%A5%E6%94%AF%E6%8C%81%E6%B5%81%E7%95%85%E7%9A%84%20UI%20%E8%BF%87%E6%B8%A1%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E4%BB%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EUboot%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%E5%88%B0%E5%86%85%E6%A0%B8%E5%B8%A7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E3.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20%E8%B0%83%E7%94%A8ipuv3_fb_init()%E6%97%B6%EF%BC%8C%20%E5%B0%86IPUv3%E6%98%BE%E7%A4%BA%E5%BC%95%E6%93%8E%E5%92%8CLDB%E7%9A%84%E8%BE%93%E5%87%BA%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%E8%AE%BE%E7%BD%AE%E4%B8%BAIPU_PIX_FMT_RGB24%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E4.%20%E8%B0%83%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20ipuv3_fb_init()%20%E6%97%B6%E6%A0%B9%E6%8D%AE%E6%96%B0%E7%9A%8424%E4%BD%8DLVDS%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E7%9A%84%E8%A7%84%E6%A0%BC%E8%AE%BE%E7%BD%AE%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E5.%20%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E5%8F%8CLDB%E9%80%9A%E9%81%93%E6%9D%A5%E6%94%AF%E6%8C%81Tough%20Display%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%EF%BC%88%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E6%88%96%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E9%AB%98%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%EF%BC%89%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%90%8C%E6%97%B6%E5%90%AF%E7%94%A8%E4%B8%A4%E4%B8%AALDB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E9%80%9A%E9%81%93%E5%B9%B6%E8%AE%BE%E7%BD%AELDB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%B7%A5%E4%BD%9C%E5%9C%A8%E5%88%86%E5%89%B2%E6%A8%A1%E5%BC%8F%E3%80%82%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elcd_enable%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E()%E4%B8%AD%E5%BA%94%E7%9B%B8%E5%BA%94%E5%9C%B0%E8%AE%BE%E7%BD%AELDB_CTRL%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751224952%22%20id%3D%22toc-hId--1620159811%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EKernel%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eframebuffer%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E7%94%B1%E4%BA%8E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E5%90%AF%E5%8A%A8%20%E5%91%BD%E4%BB%A4%E8%A1%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E4%B8%AD%20%E6%B7%BB%E5%8A%A0%E2%80%9Cvideo%3D%E2%80%9D%E5%92%8C%E2%80%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3D%E2%80%9D%E9%80%89%E9%A1%B9%20%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%E6%AF%94%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20Uboot%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E4%BB%A3%E7%A0%81%E6%9B%B4%E7%81%B5%E6%B4%BB%E5%9C%B0%E5%A4%84%E7%90%86%E5%85%B7%E6%9C%89%E4%B8%8D%E5%90%8C%E6%98%BE%E7%A4%BA%E8%89%B2%E6%B7%B1%E7%9A%84%E4%B8%8D%E5%90%8C%20LVDS%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E3%80%82%E6%9C%89%E5%85%B3%E2%80%9Cvideo%3D%E2%80%9D%E5%92%8C%E2%80%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3D%E2%80%9D%E9%80%89%E9%A1%B9%20%E7%9A%84%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%20%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20MXC%20Linux%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20BSP%20%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E5%92%8C%20Android%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%82%E4%B8%80%E4%BA%9B%E5%B7%B2%E7%9F%A5%E8%A6%81%E7%82%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E1.%20%E6%A0%B9%E6%8D%AE%E6%96%B0%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%2024%20%E4%BD%8D%20LVDS%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E7%9A%84%E8%A7%84%E6%A0%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%EF%BC%8C%E5%9C%A8%20drivers%2Fvideo%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20mxc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb.c%20%E4%B8%AD%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20struct%20fb_videomode%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%20%EF%BC%88%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%E6%9C%AB%E5%B0%BE%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E2.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%9C%A8%E5%B9%B3%E5%8F%B0%E4%BB%A3%E7%A0%81%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20pwm%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E8%83%8C%E5%85%89%2F%E6%98%BE%E7%A4%BA%E7%9B%B8%E5%85%B3%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20iomux%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E3.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%9C%A8%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E8%AE%BE%E7%BD%AE%E9%80%82%E5%BD%93%E7%9A%84%E2%80%9Cvideo%3D%E2%80%9D%E9%80%89%E9%A1%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20video%3Dmxcfb0%3Adev%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%2CLDB-NEW%2Cif%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3DRGB24%2Cfbpix%3DRGB32%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E4.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E5%8F%8C%20LDB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E%20%E9%80%9A%E9%81%93%E6%9D%A5%E6%94%AF%E6%8C%81%20Tough%20Display%20%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%EF%BC%8C%E8%AF%B7%E5%9C%A8%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%20%E4%B8%AD%20%E8%AE%BE%E7%BD%AE%E9%80%82%E5%BD%93%E7%9A%84%E2%80%98%20ldb%20%3D%E2%80%99%E9%80%89%E9%A1%B9%20%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3Dspl0%EF%BC%88%E4%BD%BF%E7%94%A8IPUv3%20DI0%EF%BC%89%E6%88%96%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3Dspl1%EF%BC%88%E4%BD%BF%E7%94%A8IPUv3%20DI1%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E5.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E5%9C%A8%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%22%3E%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E5%91%BD%E4%BB%A4%E8%A1%8C%20%E4%B8%AD%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E8%AE%BE%E7%BD%AE%E9%80%82%E5%BD%93%E7%9A%84%E2%80%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20fbmem%20%3D%E2%80%9D%E9%80%89%E9%A1%B9%EF%BC%8C%E4%BB%A5%E4%BF%9D%E7%95%99%E8%B6%B3%E5%A4%9F%E7%9A%84%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E7%9A%84%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%201280x800%20LVDS%20%E9%9D%A2%E6%9D%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%AF%B9%E4%BA%8E%20fb0%20%E4%B8%94%20fb0%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E9%87%87%E7%94%A8%20RGB32%20%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%8C%E5%88%99%E5%BA%94%E4%BD%BF%E7%94%A8%E2%80%9C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efbmem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D12M%E2%80%9D%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%85%AC%E5%BC%8F%E4%B8%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efbmem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%20%E5%AE%BD%E5%BA%A6*%E9%AB%98%E5%BA%A6*3%EF%BC%88%E4%B8%89%E9%87%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%89*%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%AF%8F%E5%83%8F%E7%B4%A0%E5%AD%97%E8%8A%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%201280*800*3*4B%3D12MB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--56229511%22%20id%3D%22toc-hId-867353022%22%3E%3CSPAN%20style%3D%22color%3A%20%237f7f7f%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E8%AE%BE%E7%BD%AE%20struct%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20fb_videomode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E7%9A%84%20%E7%A4%BA%E4%BE%8B%20%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E7%9C%8B%E4%B8%80%E4%B8%8B%E4%BB%8E%E7%9C%9F%E5%AE%9E%E7%9A%84%201280x800%4060%2024bit%20LVDS%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E9%9D%A2%E6%9D%BF%E8%A7%84%E6%A0%BC%E4%B8%AD%E5%BC%95%E7%94%A8%E7%9A%84%E6%97%B6%E5%BA%8F%E6%8F%8F%E8%BF%B0%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture3.png%22%20style%3D%22width%3A%20735px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38259i2340E2097AE2E05E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture3.png%22%20alt%3D%22Picture3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture4.png%22%20style%3D%22width%3A%20693px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38305i5F14991D91287EE7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture4.png%22%20alt%3D%22Picture4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%B9%B6%E4%B8%94%EF%BC%8C%E6%A0%87%E5%87%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Estruct%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efb_videomode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%AE%9A%E4%B9%89%E5%9C%A8%20include%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efb.h%3C%2FSPAN%3E%E4%B8%AD%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E7%BB%93%E6%9E%84%20fb_videomode%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Econst%20char%20*name%3B%20%2F*%20%E5%8F%AF%E9%80%89%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Eu32%20%E5%88%B7%E6%96%B0%EF%BC%9B%2F*%E5%8F%AF%E9%80%89*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20xres%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20yres%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Eu32%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20left_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Eu32%20%E5%8F%B3%E8%BE%B9%E8%B7%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20upper_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Eu32%20%E4%B8%8B%E8%BE%B9%E7%95%8C%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20hsync_len%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20vsync_len%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Eu32%E5%90%8C%E6%AD%A5%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20vmode%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20flag%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%81%9A%E7%9A%84%E5%B0%B1%E6%98%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E6%A0%B9%E6%8D%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20LVDS%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E8%A7%84%E8%8C%83%E7%9A%84%E6%97%B6%E5%BA%8F%E6%8F%8F%E8%BF%B0%EF%BC%8C%20%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20struct%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20fb_videomode%20%E7%9A%84%E6%AF%8F%E4%B8%AA%E5%AD%97%E6%AE%B5%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E1.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%90%8D%E7%A7%B0%EF%BC%9A%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9CLDB-WXGA%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E2.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Erefresh%EF%BC%9A%E8%99%BD%E7%84%B6%E5%AE%83%E6%98%AF%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%85%B8%E5%9E%8B%E5%80%BC%EF%BC%8C%E5%8D%B360%EF%BC%8860Hz%E5%88%B7%E6%96%B0%E7%8E%87%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E3.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Exres%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%9A%E6%9C%89%E6%95%88%E5%AE%BD%E5%BA%A6%EF%BC%8C%E5%8D%B31280%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E4.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eyres%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%9A%E6%B4%BB%E5%8A%A8%E9%AB%98%E5%BA%A6%EF%BC%8C%E5%8D%B3%20800%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E5.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epixclock%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%9A%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%85%AC%E5%BC%8F%E8%AE%A1%E7%AE%97%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epixclock%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D(10%5E12)%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eclk_freq%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%EF%BC%8C%E9%80%9A%E5%B8%B8%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epixclock%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D(10%5E12)%2F71100000%3D14065%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%26nbsp%3B%26nbsp%3B%206.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eleft_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eright_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync_len%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%AE%83%E4%BB%AC%E4%B8%8E%E8%A7%84%E6%A0%BC%E4%B9%A6%E4%B8%AD%E7%9A%84%20HS%20%E5%90%8E%E5%BB%8A%20(HBP)%2FHS%20%E5%89%8D%E5%BB%8A%20(HFP)%2FHS%20%E5%AE%BD%E5%BA%A6%20(HW)%20%E7%9B%B8%E5%90%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%E7%94%B1%E4%BA%8E%E8%A7%84%E6%A0%BC%E4%B9%A6%E4%B8%AD%E5%8F%AA%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E9%80%9A%E5%B8%B8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EHBP%2BHFP%2BHW%3D160%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%3C%2FSPAN%3E%E8%AE%BE%E7%BD%AE%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eleft_margin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D40%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eright_margin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D40%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync_len%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D80%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%26nbsp%3B%26nbsp%3B%207.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eupper_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elower_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync_len%3C%2FSPAN%3E%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E4%B8%8E%E6%B0%B4%E5%B9%B3%E6%97%B6%E5%BA%8F%E7%B1%BB%E4%BC%BC%EF%BC%8C%E5%9E%82%E7%9B%B4%E6%97%B6%E5%BA%8F%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eupper_margin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D10%3C%2FSPAN%3E%20%EF%BC%8C%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elower_margin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D3%20%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync_len%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D10%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E8.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%90%8C%E6%AD%A5%EF%BC%9A%E7%94%B1%E4%BA%8E%E6%97%B6%E5%BA%8F%E5%9B%BE%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E4%B8%BA%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E4%B8%8D%E9%9C%80%E8%A6%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E8%AE%BE%E7%BD%AE%20FB_SYNC_HOR_HIGH_ACT%20%E6%88%96%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EFB_SYNC_VERT_HIGH_ACT%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%3C%2FSPAN%3E%E6%97%B6%E9%92%9F%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%9E%81%E6%80%A7%E5%92%8C%E6%95%B0%E6%8D%AE%E6%9E%81%E6%80%A7%E6%97%A0%E6%95%88%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E5%9C%A8%E8%BF%99%E9%87%8C%E5%B0%86%E5%90%8C%E6%AD%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%9B%B6%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E9.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evmode%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%EF%BC%9A%E8%BF%99%E6%98%AF%E4%B8%80%E7%A7%8D%E6%B8%90%E8%BF%9B%E5%BC%8F%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B0%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evmode%3C%2FSPAN%3E%E8%AE%BE%E7%BD%AE%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EFB_VMODE_NONINTERLACED%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2016.0pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E10.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eflag%EF%BC%9A%E8%A7%86%E9%A2%91%E6%A8%A1%E5%BC%8F%E7%94%B1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8F%90%E4%BE%9B%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B0%86%20flag%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20FB_MODE_IS_DETAILED%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6QD%E5%A6%82%E4%BD%95%E5%9C%A8Android%E4%B8%AD%E6%B7%BB%E5%8A%A024%E4%BD%8DLVDS%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%8C%E4%BC%BC%E4%B9%8E%20pixclock%20%E5%8F%AA%E8%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9C%80%E9%AB%98%2040MHz%EF%BC%8C%E4%BD%8E%E4%BA%8E%2040MHz%20%E6%97%B6%E6%80%BB%E6%98%AF%E8%BE%93%E5%87%BA%2040MHz%EF%BC%8C%E8%80%8C%E6%88%91%E7%9A%84%20lcd%20%E5%8F%AA%E8%83%BD%E5%B7%A5%E4%BD%9C%E5%9C%A8%2027MHz%20%E5%88%B0%2032MHz%20%E4%B9%8B%E9%97%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6QD%E5%A6%82%E4%BD%95%E5%9C%A8Android%E4%B8%AD%E6%B7%BB%E5%8A%A024%E4%BD%8DLVDS%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220160624143341.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220160624143341.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F60343iA24647D399F51CC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220160624143341.png%22%20alt%3D%2220160624143341.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20160624143341.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20style%3D%22width%3A%20831px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F60373iDD56DB8663F1E476%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EQQ%E5%9B%BE%E7%89%8720160624143437.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6QD%E5%A6%82%E4%BD%95%E5%9C%A8Android%E4%B8%AD%E6%B7%BB%E5%8A%A024%E4%BD%8DLVDS%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%95%99%E7%A8%8B%E3%80%82%E4%BD%86%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E5%AE%83%3CSTRONG%3E%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%20Android%20Lollipop%3C%2FSTRONG%3E%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9B%A0%E4%B8%BA%E2%80%9Cldb.c%E2%80%9D%E6%98%AF%E4%B8%8D%E5%90%8C%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%3CSTRONG%3E%E6%97%B6%E9%97%B4%E5%AE%89%E6%8E%92%E5%BE%88%E5%A5%BD%3C%2FSTRONG%3E%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E4%B8%8D%E6%94%AF%E6%8C%81%20EDID%20%E7%9A%84%20LVDS%20%E9%9D%A2%E6%9D%BF%3C%2FSTRONG%3E%E3%80%82%E6%88%91%E5%8F%AA%E6%98%AF%E6%83%B3%E5%B0%86%3CSTRONG%3E%E9%BB%98%E8%AE%A4%E5%88%86%E8%BE%A8%E7%8E%87%E4%BB%8E%201024x768%20%E6%9B%B4%E6%94%B9%E4%B8%BA%201024x600%3C%2FSTRONG%3E%20%E3%80%82%E6%88%91%E7%9A%84%20lvds%20%E9%9D%A2%E6%9D%BF%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E5%BA%95%E9%83%A8%E4%BB%8D%E7%84%B6%E5%9C%A8%E9%9D%A2%E6%9D%BF%E5%A4%96%E9%9D%A2%E3%80%82%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E5%9C%A8%3CSTRONG%3EAndroid%20Lollipop%20%E4%B8%AD%E4%BF%AE%E5%A4%8D%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6QD%E5%A6%82%E4%BD%95%E5%9C%A8Android%E4%B8%AD%E6%B7%BB%E5%8A%A024%E4%BD%8DLVDS%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E5%91%80%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E8%BF%99%E4%BB%BD%E8%AF%A6%E7%BB%86%E7%9A%84%E6%8C%87%E5%8D%97%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%81%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E4%BC%BC%E4%B9%8E%E7%9C%8B%E4%B8%8D%E5%88%B0%E6%88%91%E7%9A%84%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%20u-boot%20%E6%AD%A5%E9%AA%A4%EF%BC%834%E2%80%9C4.%E5%9C%A8%E8%B0%83%E7%94%A8%3CSPAN%20style%3D%22font-size%3A%2013.63636302948px%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ipuv3_fb_init()%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013.63636302948px%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E6%97%B6%E6%A0%B9%E6%8D%AE%E6%96%B0%E7%9A%84%2024%20%E4%BD%8D%20LVDS%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E7%9A%84%E8%A7%84%E6%A0%BC%E8%AE%BE%E7%BD%AE%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%20%E3%80%82%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF%E5%A6%82%E4%BD%95%E5%81%9A%E5%88%B0%E7%9A%84%EF%BC%9F%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%9C%A8%20u-boot%20%E4%B8%AD%E4%BF%AE%E6%94%B9%E5%93%AA%E4%B8%AA%E6%96%87%E4%BB%B6%E3%80%82%E6%97%A0%E8%AE%BA%E6%88%91%E4%BB%AC%E5%81%9A%E5%87%BA%E4%BB%80%E4%B9%88%E6%94%B9%E5%8F%98%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%80%BB%E6%98%AF%E8%BE%93%E5%87%BA%2075MHz%E3%80%82%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%BB%E7%BA%BF%20u-boot%202014-10%20%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%B8%95%E7%89%B9%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-14-2012 11:52 PM
更新人:
