iMX6DQ MAX9286 MIPI CSI2 720P camera surround view solution for Linux BSP
For iMX6DQ, there are two IPUs, so they can support up to 4 cameras at the same time. But the default BSP can only support up to two cameras at the same time.
The attached patch can make the BSP support up to 4 cameras based on 3.10.53 GA 1.1.0 BSP.
The 4 cameras can be:
- 1xCSI, 3xMIPI
- 2xCSI, 2xMIPI
- 4xMIPI
For 4xMIPI case, the four cameras should be combined on the single MIPI CSI2 interface, and each camera data should be transfered on a mipi virtual channel.
In this patch, we given the example driver for Maxim MAX9286, it was verified working on iMX6DQ SabreAuto board. The input to MAX9286 is four 720P30 cameras.
The verified camera boards:
    (1) Onsemi AR0140+AP0101+MAX9271 boards.
    (2) OmniVision OV10635+MAX9271 boards.
The MIPI CSI2 CVBS camera surround view solution can be found at: iMX6DQ ISL79985/79987 MIPI CSI2 CVBS camera surround view solution for Linux BSP
The MIPI CSI2 CVBS HD camera surround view solution can be found at: iMX6DQ TP2854 MIPI CSI2 720P CVBS camera surround view solution for Linux BSP
The kernel patches:
0001-IPU-update-IPU-capture-driver-to-support-up-to-four-.patch
     Updated IPU common code to support up to four cameras.
0002-Add-Max9286-support-on-SabreAuto-board-which-can-sup.patch
     MAX9286 driver, it includes MAX9271, AP0101 and AR0140 drivers.
0003-Remove-the-page-size-align-requirement-for-v4l2-capt.patch
     With this patch, the mxc_v4l2_tvin test application can use overlay framebuffer as V4l2 capture buffer directly.
0004-Max9286-skip-AP0101-camera-re-initialization.patch
     If the camera board's power had been kept after initialized, this patch will bypass the re-initialization to reduce the start up time.
0005-Max9286-set-I2C-speed-to-400Kbps.patch
    Set I2C to 400Kbps to reduce the AP0101+AR0140 initialization time.
0006-Max9286-add-retry-for-MAX9271-I2C-access.patch
    Added retry for MAX9271 I2C access.
0007-Max9286-Add-support-for-OV10635-camera.patch
    Updated code for OV10635 camera.
0008-Max9286-support-auto-detect-camera-number.patch
    Make the Max9286 driver can detect the camera number automatically.
How to builld the kernel with MAX9286 support:
      make imx_v7_defconfig
      make menuconfig (In this command, you should select the MAX9286 driver:
            Device Drivers  --->
                  <*> Multimedia support  --->
                        [*]   V4L platform devices  --->
                              <*>   MXC Video For Linux Video Capture
                                      MXC Camera/V4L2 PRP Features support  --->
                                          <*>Maxim max9286 GMSL Deserializer Input support
                                              Select Camera Sensor (OmniVision OV10635 camera sensor)  // Or (Onsemi AP0101 and AR0140 camera sensor)
                                          <*>mxc VADC support
                                          <*>Select Overlay Rounting (Queue ipu device for overlay library)
                                          <*>Pre-processor Encoder library
                                          <*>IPU CSI Encoder library)
      make zImage
      make dtbs
The built out image file:
      arch/arm/boot/dts/imx6q-sabreauto.dtb
      arch/arm/boot/zImage
"mxc_v4l2_tvin_max9286.tar.gz" is the test application, test command to capture the four cameras and render on 1080P HDMI display:
/mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960 -oh 540 -d 1 -x 0 -g2d &
/mxc_v4l2_tvin.out -ol 960 -ot 0 -ow 960 -oh 540 -d 1 -x 1 -g2d &
/mxc_v4l2_tvin.out -ol 0 -ot 540 -ow 960 -oh 540 -d 1 -x 2 -g2d &
/mxc_v4l2_tvin.out -ol 960 -ot 540 -ow 960 -oh 540 -d 1 -x 3 -g2d &
Some hardware check point on AR0140+AP0101+MAX9271 camera board (Please get MAX9286 and OV10635 schematics from Maxim):
1. In this patch, MAX9286's I2C address is 0x4D, so ADD0 and ADD1 should be connected to high.
AP0101's I2C address is 0xBA, so SADDR should be connected to high.
2. AP0101's DOUT0~DOUT7 should be connected to MAX9271's DIN7~DIN0, the order should be switched, MSB connected to LSB.
3. MAX9271's GPO pin should be connected to AP0101's FRAME_SYNC pin. The pull down resistance on FRAME_SYNC pin should not be 0 ohm.
Some known limitation:
1. AP0101's VSYNC invalid time, last video line's HSYNC to VSYNC porch's max value is 255 pixel clocks, it is not enough for MAX9286 to generate the Frame End MIPI packets for each camera. So in order to let iMX6DQ to capture 1280x720 video for each camera, we had let AP0101 output 1280*724 frame size, and iMX6 will only capture 720 lines, the remained video data and Frame End will be ignored.
This solution will not impact the function, but there will be "Error matching Frame Start with Frame End for Virtual Channel x" error reported from iMX6 MIPI_CSI_ERR1 register.
Maxim suggested to use MAX96705 to relace the MAX9271, it can delay the VSYNC invalid time, then the MIPI error will be fixed.
2015-11-17 update: Updated for OV10635 camera support.
File: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-11-17.zip
2015-12-04 update:
File: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-12-04.zip
Added patch 0009-Max9286-updated-PCLK-edge-setting-for-OV10635.patch to correct the OV10635 PCLK edge setting
2016-03-07 update:
File L3.14.38_GA_MAX9286_Surroundview_Patch_2016-03-07.zip
Added kernel patch for L3.14.38 GA 1.1.0 BSP.
2016-07-26 update:
Files: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip; L3.14.38_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip; L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip.
Added gstreamer support.
Added MAX96705 support.
Added patch for L3.14.52_GA1.1.0.
2017-12-11 update:
Added CVBS surround view link: iMX6DQ TP2854 MIPI CSI2 720P CVBS camera surround view solution for Linux BSP
2021-04-26 update:
Some customer reported, when system loading is heavy, sometimes, some camera will flicker left and right. It is caused by SFMC FIFO data lost. The original patch used IDMAC 0 and IDMAC 1 for two cameras on one IPU, this is not the best setting.
IDMAC 1 is fixed to use 1/4 SMFC FIFO and it will cause IDMAC 0 to use 1/4 SMFC FIFO too. And another 1/2 of SMFC FIFO can't be used in this case.
Some code update to improve it:
For each IPU, please use IDMAC 0 and IDMAC 2 to capture the two cameras.
This needs change the hard coding in "drivers\media\platform\mxc\capture\ipu_csi_enc.c",
"CSI_MEM1" and "IPU_IRQ_CSI1_OUT_EOF" should be changed to "CSI_MEM2" and "IPU_IRQ_CSI2_OUT_EOF". In this case, all SMFC FIFO can be used.
And in "ipu_common.c", function ipu_probe(), the followed code should be changed to make IDMAC2 use high priority too.
/* Set sync refresh channels and CSI->mem channel as high priority */
- ipu_idmac_write(ipu, 0x18800003L, IDMAC_CHA_PRI(0));
+ ipu_idmac_write(ipu, 0x1880000FL, IDMAC_CHA_PRI(0));
附件
评论
Hi Qiang Li:
I use the IMX6Q core board. Now when using both GC2000 and GC320, there are occasional image tears on the screen display.
The specific implementation is like this:
   Get the real-time video data of the 4-way camera, display it on the GPU and display it in real time on the lvds screen. At the same time, the 4 channels of video are called by g2d to call the g2g_blit function for resize. The image of each frame is 720P resize to 640*480, and then synthesized into one frame. Image so that 4 channels of video can be displayed in one frame.the spliced video is not display on the screen and saved directly into the video,but now it is found that the video displayed by the GPU rendering in real time will be torn. Playback of the saved video also found that the image has a tearing problem, affecting the viewing effect.
   If you test the GPU rendering display separately, or the video of 4 channels of video is saved by G2D synthesis, there will be no image tearing problem.
But as long as these two functions are combined into one project, the problem of image tearing will occur when displaying and the saving  video.
1. Can I use the GC2000 of IMX6 and GC320 at the same time? Is there a problem with GPU resource preemption?
2. Is there a problem with data conflicts in the GPU? I have already made the GC2000 and GC320 get data that cannot be bufed, but after the two functions are integrated, there will still be a problem of video tearing.
I have been plagued by this problem for several weeks, and there has been no good solution. I am very anxious.
Hi Qiang Li:
Hi, liqiang
In my local environment which using immunity mode, and do data line swap according to your suggestion,
which causes image color change but problem NOT solved.
(帖子里好像帖不了附件,单独像您提了一个问题。)
By the way, I am using leopardimaging LI-USB30-OV10635-SER camera as following:
https://www.leopardimaging.com/uploads/LI-OV10635-SER_datasheet.pdf
It works well when connecting to PC by USB 3.0.
please help check, thanks!
Hi,liqiang
I have solve the color fault problem, by swap data line using ov10635 register 0x4709, so thank you very much!!
This had been explained, g2d_blit target buffer should be the current displayed framebuffer:
The current mxc_v4l2_tvin demo application will render camera video to current frame buffer directly, so there will be tearing issue.
For real use case, you need use multi-buffers, for example, the virtual framebuffer size is 3 times of real display buffer, and each time only one buffer is showing on display, so when buffer 1 is showing on display, you can draw combined camera videos into buffer 2, after finished drawing, call ioctl FBIOPAN_DISPLAY to show buffer 2 on screen.
The color issue happens between MAX96705 and MAX9286 mapping, so PC USB has no use for reference.
There are several kind of mapping order on data line, 8 bits/10bits, MSB/LSB. You need fine tuning it based on the OV10635 and MAX96705 connecting.
Qiang_FSL‌
Hi, Liqiang
Could you please tell me what's the fps value
if we run the surroundview(4 camera 1280x720) application base your patch and  Imx6d processor?
whether he DDR bandwidth is enough? thank you!
以下中文:
如果使用这个patch并跑在imx6d的板子上,目前surroundview(基于4个720p的摄像头)能达到多少个fps,
内存带宽够用吗?谢谢!
Hi z dq,
Did you solve the instability problem? I got sensor clk error when connecting more than 2 cameras although MAX96705's GPO pin are connected to AP0101's FRAME_SYNC pin.
I rarely got the error with 2 cameras .
28.463487] max9286_mipi 1-006a: ap0101_initialize: AP0101 hasn't been found, reg = 0x0, index = 4.
[ 28.472625] max9286_mipi 1-006a: max9286_write_reg:write reg error:reg=34,val=b6
[ 28.673495] max9286_mipi 1-006a: max9271_write_reg:write reg error:reg= 4,val=83
[ 28.783553] max9286_mipi 1-006a: max9286_write_reg:write reg error:reg=15,val=9b
[ 29.403469] mipi csi2 can not receive sensor clk! MIPI_CSI_PHY_STATE = 0x6f0.
您好,能否请教个问题:1.我看FH8536好像只有模拟输出,您是怎么跟96705连接的;2.用IMX225+FH8536的话,四个镜头模组的图像如何同步?盼复,感谢!
96705有个GPO管脚,可以输出一个同步30HZ triger信号,可以直接接sensor的一个triger in 一起来同步。同时sensor 工作在slave模式下。
[email protected]
谢谢回复,我们现在用0143+0101+96705已经正常跑起来,0143的同步确实是sensor的trigger in来控制,但是IMX225貌似没看到有trigger这个pin,datasheet里面描述slave mode是需要提供VS和HS;另外,我看FH8536这个ISP只有模拟输出,96705好像也没法接模拟输入,不清楚IMX225+FH8536+MAX96705这个方案是怎么解决这两个问题的
Dear Qiang Li,
        Sorry, I am some confused, as you said, Imx6Q can support up to 4 cameras,
- 1xCSI, 3xMIPI
- 2xCSI, 2xMIPI
- 4xMIPI
what is the meaning of  1x CSI and 3x MIPI, etc? usually we say MIPI CSI-2 together,  CSI is the same thing as MIPI CSI-2?
BTW, how many BT656 interfaces can be directly supported by Imx6Q simultaneously?
Many thanks~~
Each IPU has two CSI modules, their input can be parallel CSI interface or MIPI CSI2 virtual channel. And for iMX6DQ, it can support up to two parallel CSI interfaces (BT656 interface). Both of them can work at the same time.
Thanks Qiang!
So can we have 2 x BT656 and 2 x MIPI CSI2 work together?  if yes , how many virtual channels(1~4) can each of the 2x MIPI CSI2 have?
2 x MIPI CSI2 means two MIPI virtual channels(VC1 and VC2) on one physical MIPI CSI2 interface.
Thanks a lot! Qiang Li.
Understand now.
你好,Qiang_FSL
目前我使用了adv7181d (格式:BT1120)和nextchip(N4)这两个IC
adv7180配置如下:
v4l2_cap_0 {
compatible = "fsl,imx6q-v4l2-capture";
      ipu_id = <0>;
      csi_id = <0>;
      mclk_source = <0>;
      status = "okay";
adv7180: adv7180@21 {
      compatible = "adv,adv7180";
      reg = <0x21>;
      pinctrl-names = "default";
      pinctrl-0 = <&pinctrl_ipu1_2>;
      clocks = <&clks IMX6QDL_CLK_CKO>;
      clock-names = "csi_mclk";
      pwn-gpios = <&gpio1 4 0>;
      reset-gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>;
      ipu_id = <0>;
      csi_id = <0>;
      mclk = <24000000>;
      mclk_source = <0>;
      cvbs = <1>;
nextchip(N4)本身可以接四个摄像头,但是我仅使用了 的的其中两路,分辨率是720p,然后配置如下:
mipi-csi2-channel@2 {
      ipu_id = <1>;
      csi_id = <0>;
      v_channel = <2>;
      status = "okay";
mipi-csi2-channel@3 {
      ipu_id = <1>;
      csi_id = <1>;
      v_channel = <3>;
      status = "okay";
v4l2_cap_1 {
      ipu_id = <1>;
      csi_id = <0>;
      mclk_source = <0>;
      status = "okay";
v4l2_cap_2 {
      ipu_id = <1>;
      csi_id = <1>;
      mclk_source = <0>;
      status = "okay";
目前三个摄像头都可以采到图像,但是 ipu_id = <1>;   csi_id = <1>;这一路的摄像头采集到的图像会闪动,看起来就像是图像断层,我用mxc-v4l2-tvin去打开不会闪
mxc-v4l2-tvin  -ol 0 -ot 0 -ow 1280 -oh 800 -d 1 -x 2
我调通了HAL层,我们应用给我写了一个demo去分别打开每个video,当打开video2( ipu_id = <1>;   csi_id = <1>;)的时候就出现闪动的情况,目前不知道从哪里分析,可否提供一点思路,谢谢!
我拍照的时候拍不到闪动断层的现象,我录制了一个MP4格式视频,但是在上传过程中提示格式不支持,请问我该上传什么格式的视频?
Excuse me, can I have another patch of Linux 3.14.38? That link failed
HI Liqiang:
您好!
  我这边使用imx6d + max9286 + max96705的方式进行三路camera同时预览。当接入2个或者三个camera的时候,预览画面就会有抖动,滚动现象出现;
我只接一个摄像头是正常的。
跟美信fae这边确认camera都是frame sync同步模式。
这个问题查了好久,麻烦帮忙看下
Hi 佳杰 吴
要看你用的什么camera sensor,如果买的现成的模组,一般都是带flash的,那么它的工作模式就是在flash ROM里面设置的,MAX9286这边即使设置了Frame Sync模式,也是没法改变camera的模式的。
另外有些camera sensor(比如AP0101+AR0130),最后一行的HSYNC to VSYNC 的时间少于255个pixel clock,也是会有问题的,这个时候需要让IPU CSI那边少抓几行数据,比如720行的输入,IPU CSI只抓712行。
我这边使用的感光sensors是AP0143;sensor这边确定已经做frame sync,因为之前的模式,多路sensor不能出图;
现在我抓320行,接三个sensor的时候,不会出现滚动,但是会出现横条,抖动现象。
你可以测量一下MAX9286的lock pin,它应该要一直是high,才能保证MIPI的数据是稳定输出的,如果camera和MAX9286没有设置好,就不能保持一直高电平,这样数据就不会完整。
从之前AP0101的测试结果看,MAX9286要设成manual模式,然后0x08那个寄存器,是要根据camera的设置帧率,做调整的:
#ifdef SENSOR_AP0101
 //Manual Mode
 max9286_write_reg(0x01, 0x00);
 max9286_write_reg(0x63, 0x00);
 max9286_write_reg(0x64, 0x00);
 max9286_write_reg(0x06, 0x00);
 max9286_write_reg(0x07, 0x00);
 max9286_write_reg(0x08, 0x26);
#endif
现在量了这个lock引脚一直都是低的,接一个sensor的时候也是低的;
max9286的模式已经改过,那几个参数也都调整过,但是没有效果;
现在想排除下是不是imx6 这边出了问题,该如何排查?
MAX9286 的lock pin不能保持高电平,表示它不能完全锁住camera信号,那么MIPI CSI2上的数据就一定是有问题的,这个和iMX6这边无关。
这个脚电平是低,但是读了下0x27寄存器的bit7却是1 :
这个是不是也不正常。
Hi Qiang Li,
I am using Imx6qp. With following commands, the system is working properly.
WIDTH=640
HEIGHT=240
./mxc_v4l2_tvin.out -ol 0 -ot 0 -ow ${WIDTH} -oh ${HEIGHT} -d 0 -x 0 -g2d &
./mxc_v4l2_tvin.out -ol ${WIDTH} -ot 0 -ow ${WIDTH} -oh ${HEIGHT} -d 0 -x 1 -g2d &
./mxc_v4l2_tvin.out -ol 0 -ot ${HEIGHT} -ow ${WIDTH} -oh ${HEIGHT} -d 0 -x 2 -g2d &
./mxc_v4l2_tvin.out -ol ${WIDTH} -ot ${HEIGHT} -ow ${WIDTH} -oh ${HEIGHT} -d 0 -x 3 -g2d &
When I try to use gstreamer with the following pipelines, third and forth cameras are jittering and scrolling.
WINDOW1="window-x-coord=0 window-y-coord=0 window-width=${WIDTH} window-height=${HEIGHT}"
WINDOW2="window-x-coord=${WIDTH} window-y-coord=0 window-width=${WIDTH} window-height=${HEIGHT}"
WINDOW3="window-x-coord=0 window-y-coord=${HEIGHT} window-width=${WIDTH} window-height=${HEIGHT}"
WINDOW4="window-x-coord=${WIDTH} window-y-coord=${HEIGHT} window-width=${WIDTH} window-height=${HEIGHT}"
gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video0 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false $WINDOW1 &
gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video1 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false $WINDOW2 &
gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video2 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false $WINDOW3 &
gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video3 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false $WINDOW4 &
v4l applications are working properly but gstreamer causes the problem seen above. Do you have any idea about this problem?
For gstreamer, when you render 4 cameras together, it needs combine the buffer 4 times and swap the buffer 4 times, this will impact the performance. For tvin test application, it just renders the cameras to target framebuffer directly, no buffer swap, this can cause sawtooth issue.
The best way for rendering: draw the 4 cameras to one target buffer, then swap it to frambuffer in one time.
hi liqiang:
   我现在在android6系统上面进行多路camera同时录像,用mMediaRecorder进行录制;
   录制一路的时候没有问题,但是录制两路的时候gpu报错:
   这个是什么原因?
Hi Qiang Li,
The following two pipelines work normally when run seperately.
  • gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video0 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false
  • gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video1 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false
However, each pipelines given below (especially with video3) cause sawtooth issue given as attached gif, even if they run seperately.
  • gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video2 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false
  • gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video3 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false
While twin app does not create any problem for each camera.
While using gstreamer, what can cause this situation? Is it about gstreamer patch or IPU2?
The log shows there is no enough memory, I think you need reserve more memory for GPU.
As I explained, this is the render issue, for 60fps display, the PAN display can only be up to 60fps, but for 4x720P30 camera, if you render them alone, there are total 120fps, so it can't work correctly. You need combine the 4 cameras together then render them once.
Hi Qiang Li,
Sorry for the confusion. I assumed that below single pipe which causes saw-tooth issue does not render all cameras.
#gst-launch-1.0 -v -e imxv4l2videosrc device=/dev/video2 ! imxg2dvideosink framebuffer=/dev/fb0 force-aspect-ratio=false
I am studying about gstreamer to draw 4 cameras to one target buffer.
Thanks and best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8EiMX6DQ%EF%BC%8C%E6%9C%89%E4%B8%A4%E4%B8%AAIPU%E5%8F%AF%E4%BB%A5%E5%90%8C%E6%97%B6%E6%94%AF%E6%8C%81%E6%9C%80%E5%A4%9A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%E4%BD%86%E9%BB%98%E8%AE%A4BSP%E5%8F%AA%E8%83%BD%E5%90%8C%E6%97%B6%E6%94%AF%E6%8C%81%E4%B8%A4%E5%8F%B0%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2287418_87418.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2287418_87418.png%22%20style%3D%22width%3A%20996px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118404i3F312F87BA942CD7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2287418_87418.png%22%20alt%3D%2287418_87418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22untitled.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22untitled.png%22%20style%3D%22width%3A%20996px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F102583i76B3FFFEF6E81A1B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22untitled.png%22%20alt%3D%22untitled.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E5%A2%9E%E8%A1%A5%E4%B8%81%E5%8F%AF%E4%BB%A5%E5%9F%BA%E4%BA%8E3.10.53%20GA%201.1.0%20BSP%E6%B7%BB%E5%8A%A0%E5%86%85%E6%A0%B8%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%8F%AF%E4%BB%A5%E6%98%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%0A%3CP%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%0A%3CP%3E-%204xMIPI%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%204xMIPI%20%E6%83%85%E5%86%B5%EF%BC%8C%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%BA%94%E7%BB%84%E5%90%88%E5%9C%A8%E5%8D%95%E4%B8%AA%20MIPI%20CSI2%20%E6%8E%A5%E5%8F%A3%E4%B8%8A%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%AF%8F%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%95%B0%E6%8D%AE%E5%BA%94%E5%9C%A8%20MIPI%20%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E4%B8%8A%E4%BC%A0%E8%BE%93%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%AD%A4%E8%A1%A5%E4%B8%81%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E4%BA%86Maxim%20MAX9286%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%9C%A8iMX6DQ%20SabreAuto%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E9%AA%8C%E8%AF%81%E9%80%9A%E8%BF%87%E3%80%82MAX9286%E7%9A%84%E8%BE%93%E5%85%A5%E6%98%AF%E5%9B%9B%E4%B8%AA720P30%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B7%B2%E9%AA%8C%E8%AF%81%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%EF%BC%881%EF%BC%89Onsemi%20AR0140%2BAP0101%2BMAX9271%20%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%EF%BC%882%EF%BC%89%20OmniVision%20OV10635%2BMAX9271%20%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMIPI%20CSI2%20CVBS%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E8%AF%A6%E8%A7%81%E6%AD%A4%E5%A4%84%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-158531%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3E%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20ISL79985%2F79987%20MIPI%20CSI2%20CVBS%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EMIPI%20CSI2%20CVBS%E9%AB%98%E6%B8%85%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E8%AF%A6%E8%A7%81%E6%AD%A4%E5%A4%84%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3E%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20TP2854%20MIPI%20CSI2%20720P%20CVBS%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%86%85%E6%A0%B8%E8%A1%A5%E4%B8%81%EF%BC%9A%3CBR%20%2F%3E0001-IPU-update-IPU-capture-driver-to-support-up-to-four-.patch%3CBR%20%2F%3E%E6%9B%B4%E6%96%B0%E4%BA%86%20IPU%20%E9%80%9A%E7%94%A8%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E6%94%AF%E6%8C%81%E6%9C%80%E5%A4%9A%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0002-Add-Max9286-support-on-SabreAuto-board-which-can-sup.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MAX9286%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E6%8B%ACMAX9271%E3%80%81AP0101%E5%92%8CAR0140%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0003-Remove-the-page-size-align-requirement-for-v4l2-capt.patch%3CBR%20%2F%3E%E5%80%9F%E5%8A%A9%E6%AD%A4%E8%A1%A5%E4%B8%81%EF%BC%8Cmxc_v4l2_tvin%E6%B5%8B%E8%AF%95%E5%BA%94%E7%94%A8%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E5%B0%86%E5%8F%A0%E5%8A%A0%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E7%94%A8%E4%BD%9CV4l2%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0004-Max9286-skip-AP0101-camera-re-initialization.patch%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%91%84%E5%83%8F%E5%A4%B4%E5%BC%80%E5%8F%91%E6%9D%BF%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%90%8E%E4%BF%9D%E6%8C%81%E4%BE%9B%E7%94%B5%EF%BC%8C%E6%AD%A4%E8%A1%A5%E4%B8%81%E5%B0%86%E8%B7%B3%E8%BF%87%E9%87%8D%E6%96%B0%E5%88%9D%E5%A7%8B%E5%8C%96%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BB%A5%E7%BC%A9%E7%9F%AD%E5%90%AF%E5%8A%A8%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0005-Max9286-set-I2C-speed-to-400Kbps.patch%3CBR%20%2F%3E%20%E5%B0%86I2C%E9%80%9F%E5%BA%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA400Kbps%E4%BB%A5%E5%87%8F%E5%B0%91AP0101%2BAR0140%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0006-Max9286-add-retry-for-MAX9271-I2C-access.patch%3CBR%20%2F%3E%20%E5%B7%B2%E4%B8%BAMAX9271%20I2C%E8%AE%BF%E9%97%AE%E6%B7%BB%E5%8A%A0%E9%87%8D%E8%AF%95%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0007-Max9286-%E6%B7%BB%E5%8A%A0%E5%AF%B9OV10635%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%94%AF%E6%8C%81.patch%3CBR%20%2F%3E%20%E6%9B%B4%E6%96%B0%E4%BA%86OV10635%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0008-Max9286-support-auto-detect-camera-number.patch%3CBR%20%2F%3E%20%E7%A1%AE%E4%BF%9DMax9286%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%83%BD%E5%A4%9F%E8%87%AA%E5%8A%A8%E6%A3%80%E6%B5%8B%E6%91%84%E5%83%8F%E5%A4%B4%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E4%BD%95%E6%9E%84%E5%BB%BA%E6%94%AF%E6%8C%81MAX9286%E7%9A%84%E5%86%85%E6%A0%B8%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20imx_v7_defconfig%3C%2FP%3E%0A%3CP%3E%E6%89%A7%E8%A1%8Cmenuconfig%E5%91%BD%E4%BB%A4%EF%BC%88%E5%9C%A8%E6%AD%A4%E5%91%BD%E4%BB%A4%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%BA%94%E9%80%89%E6%8B%A9MAX9286%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%20%E5%A4%9A%E5%AA%92%E4%BD%93%E6%94%AF%E6%8C%81%26nbsp%3B%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%5B*%5D%20V4L%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26lt%3B%20*%20%26gt%3B%20%E7%94%A8%E4%BA%8ELinux%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E7%9A%84MXC%E8%A7%86%E9%A2%91%3C%2FP%3E%0A%3CP%3EMXC%E6%91%84%E5%83%8F%E5%A4%B4%2FV4L2%20PRP%E5%8A%9F%E8%83%BD%E6%94%AF%E6%8C%81%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26lt%3B*%26gt%3BMaxim%20max9286%20GMSL%E8%A7%A3%E4%B8%B2%E5%99%A8%E8%BE%93%E5%85%A5%E6%94%AF%E6%8C%81%3C%2FP%3E%0A%3CP%3E%E9%80%89%E6%8B%A9%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88OmniVision%20OV10635%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%89%2F%2F%20%E6%88%96%EF%BC%88Onsemi%20AP0101%E5%92%8CAR0140%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%89%3C%2FP%3E%0A%3CP%3E%26lt%3B*%26gt%3Bmxc%20VADC%E6%94%AF%E6%8C%81%3C%2FP%3E%0A%3CP%3E%26lt%3B%20*%20%26gt%3B%20%E9%80%89%E6%8B%A9%E5%8F%A0%E5%8A%A0%E8%B7%AF%E7%94%B1%EF%BC%88%E5%B0%86ipu%E8%AE%BE%E5%A4%87%E6%8E%92%E5%85%A5%E5%8F%A0%E5%8A%A0%E5%BA%93%E9%98%9F%E5%88%97%EF%BC%89%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3BPre-processor%20Encoder%20library%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3BIPU%20CSI%20Encoder%20library)%3C%2FP%3E%0A%3CP%3E%E7%94%9F%E6%88%90%20zImage%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20dtbs%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E9%95%9C%E5%83%8F%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%0A%3CP%3Earch%2Farm%2Fboot%2Fdts%2Fimx6q-sabreauto.dtb%3C%2FP%3E%0A%3CP%3Earch%2Farm%2Fboot%2FzImage%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%22mxc_v4l2_tvin_max9286.tar.gz%22%E6%98%AF%E6%B5%8B%E8%AF%95%E5%BA%94%E7%94%A8%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E6%8D%95%E8%8E%B7%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%B9%B6%E5%9C%A81080P%20HDMI%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E6%B8%B2%E6%9F%93%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%200%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%20960%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%201%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%20540%20-ow%20960%20-oh%20540%20-d%201%20-x%202%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%20960%20-ot%20540%20-ow%20960%20-oh%20540%20-d%201%20-x%203%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EAR0140%2BAP0101%2BMAX9271%20%E6%91%84%E5%83%8F%E5%A4%B4%E6%9D%BF%E4%B8%8A%E7%9A%84%E4%B8%80%E4%BA%9B%E7%A1%AC%E4%BB%B6%E6%A3%80%E6%9F%A5%E7%82%B9%EF%BC%88%E8%AF%B7%E4%BB%8E%20Maxim%20%E8%8E%B7%E5%8F%96%20MAX9286%20%E5%92%8C%20OV10635%20%E7%9A%84%E7%94%B5%E8%B7%AF%E5%9B%BE%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%20%E5%9C%A8%E6%AD%A4%E8%A1%A5%E4%B8%81%E4%B8%AD%EF%BC%8CMAX9286%E7%9A%84I2C%E5%9C%B0%E5%9D%80%E4%B8%BA0x4D%EF%BC%8C%E5%9B%A0%E6%AD%A4ADD0%E5%92%8CADD1%E5%BA%94%E8%BF%9E%E6%8E%A5%E5%88%B0%E9%AB%98%E7%94%B5%E5%B9%B3%E3%80%82%3C%2FP%3E%0A%3CP%3EAP0101%E7%9A%84I2C%E5%9C%B0%E5%9D%80%E4%B8%BA0xBA%EF%BC%8C%E5%9B%A0%E6%AD%A4SADDR%E5%BA%94%E8%BF%9E%E6%8E%A5%E5%88%B0%E9%AB%98%E7%94%B5%E5%B9%B3%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2.%20AP0101%E7%9A%84DOUT0~DOUT7%E5%BA%94%E8%BF%9E%E6%8E%A5%E5%88%B0MAX9271%E7%9A%84DIN7~DIN0%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%AF%B9%E8%B0%83%E9%A1%BA%E5%BA%8F%EF%BC%8CMSB%E5%BA%94%E8%BF%9E%E6%8E%A5LSB%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E3.%20MAX9271%E7%9A%84GPO%E5%BC%95%E8%84%9A%E5%BA%94%E8%BF%9E%E6%8E%A5%E5%88%B0AP0101%E7%9A%84FRAME_SYNC%E5%BC%95%E8%84%9A%E3%80%82FRAME_SYNC%E5%BC%95%E8%84%9A%E7%9A%84%E4%B8%8B%E6%8B%89%E7%94%B5%E9%98%BB%E4%B8%8D%E5%BA%94%E4%B8%BA0ohm%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E4%B8%80%E4%BA%9B%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%99%90%E5%88%B6%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%20AP0101%E7%9A%84VSYNC%E6%97%A0%E6%95%88%E6%97%B6%E9%97%B4%EF%BC%8C%E6%9C%80%E5%90%8E%E4%B8%80%E6%9D%A1%E8%A7%86%E9%A2%91%E7%BA%BF%E7%9A%84HSYNC%E5%88%B0VSYNC%E5%89%8D%E8%BE%B9%E7%BC%98%E7%9A%84%E6%9C%80%E5%A4%A7%E5%80%BC%E4%B8%BA255%E4%B8%AA%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%EF%BC%8C%E8%BF%99%E4%B8%8D%E8%B6%B3%E4%BB%A5%E6%94%AF%E6%8C%81MAX9286%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%94%9F%E6%88%90%E5%B8%A7%E7%BB%93%E6%9D%9FMIPI%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%E8%A6%81%E7%A1%AE%E4%BF%9DiMX6DQ%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%8D%95%E8%8E%B71280x720%E7%9A%84%E8%A7%86%E9%A2%91%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E5%B0%86AP0101%E7%9A%84%E8%BE%93%E5%87%BA%E8%AE%BE%E7%BD%AE%E4%B8%BA1280%C3%97724%E7%9A%84%E5%B8%A7%E5%A4%A7%E5%B0%8F%EF%BC%8C%E8%80%8CiMX6%E5%B0%86%E4%BB%85%E6%8D%95%E8%8E%B7720%E8%A1%8C%EF%BC%8C%E5%89%A9%E4%BD%99%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E5%92%8C%E5%B8%A7%E7%BB%93%E6%9D%9F%E4%BF%A1%E6%81%AF%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8D%E8%AF%A5%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BD%86iMX6%20MIPI_CSI_ERR1%E5%AF%84%E5%AD%98%E5%99%A8%E5%B0%86%E6%8A%A5%E5%91%8A%E2%80%9C%3CSPAN%20style%3D%22font-family%3A%20HelveticaLTStd-Roman%3B%20font-size%3A%209pt%3B%20mso-fareast-font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20ZH-CN%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93x%E7%9A%84%E5%B8%A7%E5%BC%80%E5%A7%8B%E4%B8%8E%E5%B8%A7%E7%BB%93%E6%9D%9F%E5%8C%B9%E9%85%8D%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3EMaxim%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8MAX96705%E6%9B%BF%E6%8D%A2MAX9271%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%BB%B6%E8%BF%9FVSYNC%E6%97%A0%E6%95%88%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BB%8E%E8%80%8C%E4%BF%AE%E5%A4%8DMIPI%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2015%E5%B9%B411%E6%9C%8817%E6%97%A5%E6%9B%B4%E6%96%B0%EF%BC%9A%E6%9B%B4%E6%96%B0%E4%BA%86%E5%AF%B9%20OV10635%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9AL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-11-17.zip%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2015-12-04%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9AL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-12-04.zip%3C%2FP%3E%0A%3CP%3E%E5%B7%B2%E6%B7%BB%E5%8A%A0%E8%A1%A5%E4%B8%81%200009-Max9286-updated-PCLK-edge-setting-for-OV10635.patch%20%E4%BB%A5%E4%BF%AE%E6%AD%A3%20OV10635%20%E7%9A%84%20PCLK%20%E8%BE%B9%E7%BC%98%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2016-03-07%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%96%87%E4%BB%B6%20L3.14.38_GA_MAX9286_Surroundview_Patch_2016-03-07.zip%3C%2FP%3E%0A%3CP%3E%E5%B7%B2%E9%92%88%E5%AF%B9L3.14.38%20GA%201.1.0BSP%E6%B7%BB%E5%8A%A0%E5%86%85%E6%A0%B8%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2016-07-26%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFiles%3A%20L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3B%20L3.14.38_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3B%20L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip.%3C%2FP%3E%0A%3CP%3E%E6%B7%BB%E5%8A%A0%E4%BA%86%20gstreamer%20%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A2%9E%E5%8A%A0%E4%BA%86%E5%AF%B9MAX96705%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%20L3.14.52_GA1.1.0%20%E6%B7%BB%E5%8A%A0%E4%BA%86%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2017-12-11%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E5%B7%B2%E6%B7%BB%E5%8A%A0CVBS%E7%8E%AF%E8%A7%86%E9%93%BE%E6%8E%A5%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3E%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20TP2854%20MIPI%20CSI2%20720P%20CVBS%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E2021-04-26%26nbsp%3Bupdate%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E9%83%A8%E5%88%86%E5%AE%A2%E6%88%B7%E5%8F%8D%E9%A6%88%EF%BC%8C%E5%BD%93%E7%B3%BB%E7%BB%9F%E8%B4%9F%E8%BD%BD%E8%BE%83%E9%87%8D%E6%97%B6%EF%BC%8C%E6%9F%90%E4%BA%9B%E6%91%84%E5%83%8F%E5%A4%B4%E5%81%B6%E5%B0%94%E4%BC%9A%E5%B7%A6%E5%8F%B3%E9%97%AA%E7%83%81%E3%80%82%E8%BF%99%E6%98%AF%E7%94%B1SFMC%20FIFO%E6%95%B0%E6%8D%AE%E4%B8%A2%E5%A4%B1%E5%BC%95%E8%B5%B7%E7%9A%84%E3%80%82%E5%8E%9F%E5%A7%8B%E8%A1%A5%E4%B8%81%E5%9C%A8%E4%B8%80%E4%B8%AAIPU%E4%B8%8A%E4%B8%BA%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%BA%94%E7%94%A8IDMAC%200%E5%92%8CIDMAC%201%EF%BC%8C%E8%BF%99%E5%B9%B6%E9%9D%9E%E6%9C%80%E4%BD%B3%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3EIDMAC%201%E5%B7%B2%E5%9B%BA%E5%AE%9A%E4%B8%BA%E4%BD%BF%E7%94%A81%2F4%20SMFC%20FIFO%EF%BC%8C%E8%BF%99%E5%B0%86%E5%AF%BC%E8%87%B4IDMAC%200%E4%B9%9F%E4%BD%BF%E7%94%A81%2F4%20SMFC%20FIFO%E3%80%82%E5%9C%A8%E6%AD%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CSMFC%20FIFO%E7%9A%84%E5%8F%A6%E5%A4%961%2F2%E5%AE%B9%E9%87%8F%E5%B0%86%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F143217i8EDD1960CA9C3699%2Fimage-dimensions%2F733x303%3Fv%3Dv2%22%20width%3D%22733%22%20height%3D%22303%22%20role%3D%22button%22%20title%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B7%B2%E5%AE%8C%E6%88%90%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%E4%BB%BB%E5%8A%A1%E4%BB%A5%E4%BC%98%E5%8C%96%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%AF%8F%E4%B8%AAIPU%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8IDMAC%200%E5%92%8CIDMAC%202%E6%9D%A5%E6%8D%95%E8%8E%B7%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%E8%BF%99%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%22drivers%5Cmedia%5Cplatform%5Cmxc%5Ccapture%5Cipu_csi_enc.c%22%E4%B8%AD%E7%9A%84%E7%A1%AC%E7%BC%96%E7%A0%81%EF%BC%8C%3C%2FFONT%3E%3CFONT%20color%3D%22%230000FF%22%3E%E2%80%9CCSI_MEM1%E2%80%9D%E5%92%8C%E2%80%9CIPU_IRQ_CSI1_OUT_EOF%E2%80%9D%E5%BA%94%E6%9B%B4%E6%94%B9%E4%B8%BA%E2%80%9CCSI_MEM2%E2%80%9D%E5%92%8C%E2%80%9CIPU_IRQ_CSI2_OUT_EOF%E2%80%9D%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%89%80%E6%9C%89SMFC%20FIFO%E5%9D%87%E5%8F%AF%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E2%80%9Cipu_common.c%E2%80%9D%E4%B8%AD%EF%BC%8C%E5%87%BD%E6%95%B0ipu_probe()%E5%90%8E%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B9%9F%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%EF%BC%8C%E7%A1%AE%E4%BF%9DIDMAC2%E5%90%8C%E6%AD%A5%E4%BD%BF%E7%94%A8%E9%AB%98%E4%BC%98%E5%85%88%E7%BA%A7%E3%80%82%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%2F*%20%E8%AE%BE%E7%BD%AE%E5%90%8C%E6%AD%A5%E5%88%B7%E6%96%B0%E9%80%9A%E9%81%93%E5%92%8CCSI-%26gt%3B%E5%86%85%E5%AD%98%E9%80%9A%E9%81%93%E4%B8%BA%E9%AB%98%E4%BC%98%E5%85%88%E7%BA%A7%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E-%20ipu_idmac_write(ipu%2C%200x18800003L%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%2B%20ipu_idmac_write(ipu%2C%200x1880000FL%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E6%8A%B1%E6%AD%89%E9%80%A0%E6%88%90%E8%AF%AF%E8%A7%A3%E3%80%82%E6%88%91%E4%BB%A5%E4%B8%BA%E5%AF%BC%E8%87%B4%E9%94%AF%E9%BD%BF%E9%97%AE%E9%A2%98%E4%B8%8B%E6%96%B9%E7%9A%84%E5%8D%95%E4%B8%80%E7%AE%A1%E9%81%93%E4%B8%8D%E4%BC%9A%E6%B8%B2%E6%9F%93%E6%89%80%E6%9C%89%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23gst-launch-1.0%20-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo2%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6gstreamer%EF%BC%8C%E5%B0%86%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%BB%98%E5%88%B6%E5%88%B0%E4%B8%80%E4%B8%AA%E7%9B%AE%E6%A0%87%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E6%84%9F%E8%B0%A2%E5%B9%B6%E8%87%B4%E6%84%8F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E6%89%80%E8%A7%A3%E9%87%8A%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AF%E6%B8%B2%E6%9F%93%E9%97%AE%E9%A2%98%EF%BC%8C%E5%AF%B9%E4%BA%8E60fps%E6%98%BE%E7%A4%BA%EF%BC%8CPAN%E6%98%BE%E7%A4%BA%E5%8F%AA%E8%83%BD%E8%BE%BE%E5%88%B060fps%EF%BC%8C%E4%BD%86%E5%AF%B9%E4%BA%8E4x720P30%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8D%95%E7%8B%AC%E8%BF%9B%E8%A1%8C%E6%B8%B2%E6%9F%93%EF%BC%8C%E6%80%BB%E8%AE%A1%E5%88%99%E4%B8%BA120fps%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%BB%84%E5%90%88%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%B8%B2%E6%9F%93%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%E5%86%85%E5%AD%98%E4%B8%8D%E8%B6%B3%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%BAGPU%E9%A2%84%E7%95%99%E6%9B%B4%E5%A4%9A%E5%86%85%E5%AD%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20vertical-align%3A%20inherit%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BB%A5%E4%B8%8B%E4%B8%A4%E6%9D%A1%E7%AE%A1%E9%81%93%E5%9C%A8%E5%8D%95%E7%8B%AC%E8%BF%90%E8%A1%8C%E6%97%B6%E5%9D%87%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo0%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo1%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E4%BB%A5%E4%B8%8B%E5%90%84%E6%9D%A1%E7%AE%A1%E9%81%93%EF%BC%88%E5%B0%A4%E5%85%B6%E6%98%AF%E8%A7%86%E9%A2%913%EF%BC%89%E9%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%94%AF%E9%BD%BF%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82gif%E9%99%84%E4%BB%B6%E6%89%80%E7%A4%BA%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%85%B6%E5%8D%95%E7%8B%AC%E8%BF%90%E8%A1%8C%E4%B9%9F%E6%98%AF%E5%A6%82%E6%AD%A4%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%233d3d3d%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo2%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo3%EF%BC%81imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.gif%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114452iFEAC8ADBC91DC931%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.gif%22%20alt%3D%22pastedImage_2.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E5%8F%8C%E5%BA%94%E7%94%A8%E4%B8%8D%E4%BC%9A%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E9%80%A0%E6%88%90%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E5%9C%A8%E4%BD%BF%E7%94%A8gstreamer%E6%97%B6%EF%BC%8C%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8Egstreamer%E8%A1%A5%E4%B8%81%E8%BF%98%E6%98%AFIPU2%E7%9B%B8%E5%85%B3%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20GStreamer%EF%BC%8C%E5%BD%93%E6%82%A8%E5%90%8C%E6%97%B6%E6%B8%B2%E6%9F%93%204%20%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%B6%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%E7%BC%93%E5%86%B2%E5%8C%BA%E5%90%88%E5%B9%B6%204%20%E6%AC%A1%E5%B9%B6%E4%BA%A4%E6%8D%A2%204%20%E6%AC%A1%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%BD%B1%E5%93%8D%E6%80%A7%E8%83%BD%E3%80%82%E5%AF%B9%E4%BA%8E%20tvin%20%E6%B5%8B%E8%AF%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%AE%83%E7%9B%B4%E6%8E%A5%E5%B0%86%E6%91%84%E5%83%8F%E5%A4%B4%E6%B8%B2%E6%9F%93%E5%88%B0%E7%9B%AE%E6%A0%87%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%E4%B8%8D%E8%BF%9B%E8%A1%8C%E7%BC%93%E5%86%B2%E5%8C%BA%E4%BA%A4%E6%8D%A2%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E9%94%AF%E9%BD%BF%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E4%BD%B3%E6%B8%B2%E6%9F%93%E6%96%B9%E5%BC%8F%EF%BC%9A%E5%B0%864%E4%B8%AA%E6%91%84%E5%83%8F%E6%9C%BA%E6%B8%B2%E6%9F%93%E5%88%B0%E4%B8%80%E4%B8%AA%E7%9B%AE%E6%A0%87%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%85%B6%E4%B8%80%E6%AC%A1%E6%80%A7%E4%BA%A4%E6%8D%A2%E5%88%B0%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8Imx6qp%E3%80%82%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%8C%E7%B3%BB%E7%BB%9F%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%AE%BD%E5%BA%A6%3D640%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3D240%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%200%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%20%24%7BWIDTH%7D%20-ot%200%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%201%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%20%24%7BHEIGHT%7D%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%202%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%20%24%7BWIDTH%7D%20-ot%20%24%7BHEIGHT%7D%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%203%20-g2d%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114357i7D5C1A40743AC888%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E7%AE%A1%E9%81%93%E8%BF%90%E8%A1%8C%20GStreamer%20%E6%97%B6%EF%BC%8C%E7%AC%AC%E4%B8%89%E5%92%8C%E7%AC%AC%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%87%BA%E7%8E%B0%E6%8A%96%E5%8A%A8%E5%92%8C%E6%BB%9A%E5%8A%A8%E7%8E%B0%E8%B1%A1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWINDOW1%3D%22%E7%AA%97%E5%8F%A3x%E5%9D%90%E6%A0%87%3D0%20%E7%AA%97%E5%8F%A3y%E5%9D%90%E6%A0%87%3D0%20%E7%AA%97%E5%8F%A3%E5%AE%BD%E5%BA%A6%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3%E9%AB%98%E5%BA%A6%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW2%3D%22%E7%AA%97%E5%8F%A3x%E5%9D%90%E6%A0%87%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3y%E5%9D%90%E6%A0%87%3D0%20%E7%AA%97%E5%8F%A3%E5%AE%BD%E5%BA%A6%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3%E9%AB%98%E5%BA%A6%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW3%3D%22%E7%AA%97%E5%8F%A3x%E5%9D%90%E6%A0%87%3D0%20%E7%AA%97%E5%8F%A3y%E5%9D%90%E6%A0%87%3D%24%7BHEIGHT%7D%20%E7%AA%97%E5%8F%A3%E5%AE%BD%E5%BA%A6%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3%E9%AB%98%E5%BA%A6%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW4%3D%22%E7%AA%97%E5%8F%A3x%E5%9D%90%E6%A0%87%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3y%E5%9D%90%E6%A0%87%3D%24%7BHEIGHT%7D%20%E7%AA%97%E5%8F%A3%E5%AE%BD%E5%BA%A6%3D%24%7BWIDTH%7D%20%E7%AA%97%E5%8F%A3%E9%AB%98%E5%BA%A6%3D%24%7BHEIGHT%7D%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo0%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%20%24WINDOW1%20%26amp%3B%3CBR%20%2F%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo1%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%20%24WINDOW2%20%26amp%3B%3CBR%20%2F%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo2%20!%20imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%20%24WINDOW3%20%26amp%3B%3CBR%20%2F%3Egst-launch-1.0%20-v%20-e%20imxv4l2videosrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo3%EF%BC%81imxg2dvideosink%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%3D%2Fdev%2Ffb0%20%E5%BC%BA%E5%88%B6%E9%AB%98%E5%AE%BD%E6%AF%94%3Dfalse%20%24WINDOW4%20%26amp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.gif%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114358iD7BDF0F348BD58C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.gif%22%20alt%3D%22pastedImage_1.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3Ev4l%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%20gstreamer%20%E5%AF%BC%E8%87%B4%E4%BA%86%E4%B8%8A%E9%9D%A2%E6%89%80%E8%A7%81%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%9C%89%E4%BB%BB%E4%BD%95%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116726%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116726%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%AA%E8%84%9A%E7%94%B5%E5%B9%B3%E6%98%AF%E4%BD%8E%EF%BC%8C%E4%BD%86%E6%98%AF%E8%AF%BB%E4%BA%86%E4%B8%8B0x27%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84bit7%E5%8D%B4%E6%98%AF1%20%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20841px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114285i52DBBA6FB9A56961%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E6%98%AF%E4%B8%8D%E6%98%AF%E4%B9%9F%E4%B8%8D%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%9C%89%E4%BA%9B%E5%9B%B0%E6%83%91%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E8%AF%B4%EF%BC%8CImx6Q%E6%94%AF%E6%8C%81%E6%9C%80%E5%A4%9A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%BF%99%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%8F%AF%E4%BB%A5%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%204xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E1x%20%3CSTRONG%3ECSI%3C%2FSTRONG%3E%E5%92%8C3x%20%3CSTRONG%3EMIPI%3C%2FSTRONG%3E%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%E9%80%9A%E5%B8%B8%E6%88%91%E4%BB%AC%E4%BC%9A%E7%BB%93%E5%90%88%3CSTRONG%3EMIPI%20CSI-2%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%EF%BC%8CCSI%E6%98%AF%E5%90%A6%E7%AD%89%E5%90%8C%E4%BA%8EMIPI%20CSI-2%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8CImx6Q%20%E5%90%8C%E6%97%B6%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E6%94%AF%E6%8C%81%E5%A4%9A%E5%B0%91%E4%B8%AA%20BT656%20%E6%8E%A5%E5%8F%A3%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8~~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20z%20dq%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B7%B2%E8%A7%A3%E5%86%B3%E4%B8%8D%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%9F%E5%9C%A8%E8%BF%9E%E6%8E%A5%E8%B6%85%E8%BF%872%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F%E9%94%99%E8%AF%AF%EF%BC%8C%E5%B0%BD%E7%AE%A1%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMAX96705%E7%9A%84GPO%E5%BC%95%E8%84%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%88%B0AP0101%E7%9A%84FRAME_SYNC%E5%BC%95%E8%84%9A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E5%BE%88%E5%B0%91%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%B6%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E28.463487%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E6%9C%AA%E6%89%BE%E5%88%B0%2C%20reg%20%3D%200x0%2C%20%E7%B4%A2%E5%BC%95%20%3D%204.%3CBR%20%2F%3E%5B%2028.472625%5D%20max9286_mipi%201-006a%3A%20max9286_write_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%3Areg%3D34%2Cval%3Db6%3CBR%20%2F%3E%5B%2028.673495%5D%20max9286_mipi%201-006a%3A%20max9271_write_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%3Areg%3D%204%2Cval%3D83%3CBR%20%2F%3E%5B%2028.783553%5D%20max9286_mipi%201-006a%3A%20max9286_write_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%3Areg%3D15%2Cval%3D9b%3CBR%20%2F%3E%5B%2029.403469%5D%20mipi%20csi2%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F!%20MIPI_CSI_PHY_STATE%20%3D%200x6f0.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%9D%8E%E5%BC%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E5%85%B7%E4%BD%93%E7%9A%84fps%E5%80%BC%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%9F%BA%E4%BA%8E%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E5%92%8CImx6d%E5%A4%84%E7%90%86%E5%99%A8%E8%BF%90%E8%A1%8C%E7%8E%AF%E8%A7%86%EF%BC%884%E6%91%84%E5%83%8F%E5%A4%B41280x720%EF%BC%89%E5%BA%94%E7%94%A8%EF%BC%9F%3C%2FP%3E%3CP%3EDDR%E5%B8%A6%E5%AE%BD%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E4%B8%AD%E6%96%87%EF%BC%9A%3C%2FP%3E%3CP%3E-----------------%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AApatch%E5%B9%B6%E8%B7%91%E5%9C%A8imx6d%E7%9A%84%E6%9D%BF%E5%AD%90%E4%B8%8A%EF%BC%8C%E7%9B%AE%E5%89%8Dsurroundview%EF%BC%88%E5%9F%BA%E4%BA%8E4%E4%B8%AA720p%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%89%E8%83%BD%E8%BE%BE%E5%88%B0%E5%A4%9A%E5%B0%91%E4%B8%AAfps%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E5%B8%A6%E5%AE%BD%E5%A4%9F%E7%94%A8%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%3E---------------%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%20liqiang%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%9C%AC%E5%9C%B0%E7%8E%AF%E5%A2%83%E4%B8%AD%E4%BD%BF%E7%94%A8%E6%8A%97%E6%89%B0%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%95%B0%E6%8D%AE%E7%BA%BF%E8%B7%AF%E4%BA%A4%E6%8D%A2%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%BF%99%E5%AF%BC%E8%87%B4%E5%9B%BE%E5%83%8F%E8%89%B2%E5%BD%A9%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E6%9C%AA%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E5%B8%96%E5%AD%90%E9%87%8C%E5%A5%BD%E5%83%8F%E5%B8%96%E4%B8%8D%E4%BA%86%E9%99%84%E4%BB%B6%EF%BC%8C%E5%8D%95%E7%8B%AC%E5%83%8F%E6%82%A8%E6%8F%90%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E4%B8%80%E6%8F%90%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8leopardimaging%20LI-USB30-OV10635-SER%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E5%85%B7%E4%BD%93%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.leopardimaging.com%2Fuploads%2FLI-OV10635-SER_datasheet.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.leopardimaging.com%2Fuploads%2FLI-OV10635-SER_datasheet.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87USB%203.0%E8%BF%9E%E6%8E%A5%E5%88%B0PC%E6%97%B6%EF%BC%8C%E8%AF%A5%E6%91%84%E5%83%8F%E5%A4%B4%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86IMX6Q%E5%86%85%E6%A0%B8%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%E5%BD%93%E5%89%8D%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8GC2000%E5%92%8CGC320%E6%97%B6%EF%BC%8C%E5%B1%8F%E5%B9%95%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E5%81%B6%E5%B0%94%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%9B%BE%E5%83%8F%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%E5%85%B7%E4%BD%93%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%20%E8%8E%B7%E5%8F%96%E5%9B%9B%E8%B7%AF%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E5%AE%9E%E6%97%B6%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B0%86%E5%85%B6%E6%98%BE%E7%A4%BA%E5%9C%A8GPU%E4%B8%8A%EF%BC%8C%E5%B9%B6%E5%90%8C%E6%AD%A5%E5%88%B0LVDS%E5%B1%8F%E5%B9%95%E3%80%82%E5%90%8C%E6%97%B6%EF%BC%8Cg2d%E8%B0%83%E7%94%A8g2g_blit%E5%87%BD%E6%95%B0%E5%AF%B94%E4%B8%AA%E8%A7%86%E9%A2%91%E9%80%9A%E9%81%93%E8%BF%9B%E8%A1%8C%E7%BC%A9%E6%94%BE%E3%80%82%E6%AF%8F%E5%B8%A7%E5%9B%BE%E5%83%8F%E7%94%B1720P%E7%BC%A9%E6%94%BE%E4%B8%BA640*480%EF%BC%8C%E7%84%B6%E5%90%8E%E5%90%88%E6%88%90%E4%B8%BA%E4%B8%80%E5%B8%A7%E3%80%82%E5%B0%86%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%E4%B8%BA%E4%B8%80%E5%B8%A7%E6%98%BE%E7%A4%BA%E5%9B%9B%E8%B7%AF%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%E3%80%82%E6%8B%BC%E6%8E%A5%E5%90%8E%E7%9A%84%E8%A7%86%E9%A2%91%E4%B8%8D%E4%BC%9A%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E6%98%BE%E7%A4%BA%EF%BC%8C%E8%80%8C%E6%98%AF%E7%9B%B4%E6%8E%A5%E4%BF%9D%E5%AD%98%E5%88%B0%E8%A7%86%E9%A2%91%E4%B8%AD%E3%80%82%E4%BD%86%E7%9B%AE%E5%89%8D%E5%8F%91%E7%8E%B0%EF%BC%8C%E9%80%9A%E8%BF%87GPU%E6%B8%B2%E6%9F%93%E5%AE%9E%E6%97%B6%E6%98%BE%E7%A4%BA%E7%9A%84%E8%A7%86%E9%A2%91%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E7%8E%B0%E8%B1%A1%E3%80%82%E6%92%AD%E6%94%BE%E5%B7%B2%E4%BF%9D%E5%AD%98%E7%9A%84%E8%A7%86%E9%A2%91%E6%97%B6%E4%B9%9F%E5%87%BA%E7%8E%B0%E4%BA%86%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BD%B1%E5%93%8D%E8%A7%82%E7%9C%8B%E6%95%88%E6%9E%9C%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%E5%A6%82%E6%9E%9C%E5%8D%95%E7%8B%AC%E6%B5%8B%E8%AF%95GPU%E6%B8%B2%E6%9F%93%E6%98%BE%E7%A4%BA%EF%BC%8C%E6%88%96%E8%80%854%E9%80%9A%E9%81%93%E8%A7%86%E9%A2%91%E7%9A%84%E8%A7%86%E9%A2%91%E9%80%9A%E8%BF%87G2D%E5%90%88%E6%88%90%E4%BF%9D%E5%AD%98%EF%BC%8C%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%9B%BE%E5%83%8F%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%E4%BD%86%E5%8F%AA%E8%A6%81%E5%B0%86%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%8A%9F%E8%83%BD%E7%BB%84%E5%90%88%E5%88%B0%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%92%8C%E4%BF%9D%E5%AD%98%E8%A7%86%E9%A2%91%E6%97%B6%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%9B%BE%E5%83%8F%E6%92%95%E8%A3%82%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E1.IMX6%E7%9A%84GC2000%E5%92%8CGC320%E5%8F%AF%E4%BB%A5%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E5%90%97%EF%BC%9FGPU%E8%B5%84%E6%BA%90%E6%8A%A2%E5%8D%A0%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%202.GPU%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E6%95%B0%E6%8D%AE%E5%86%B2%E7%AA%81%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%91%E5%B7%B2%E7%BB%8F%E8%AE%A9GC2000%E5%92%8CGC320%E8%8E%B7%E5%8F%96%E5%88%B0%E6%97%A0%E6%B3%95bufed%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%A4%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%95%B4%E5%90%88%E4%B9%8B%E5%90%8E%EF%BC%8C%E8%BF%98%E6%98%AF%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%A7%86%E9%A2%91%E6%92%95%E8%A3%82%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A2%AB%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%9B%B0%E6%89%B0%E4%BA%86%E5%A5%BD%E5%87%A0%E4%B8%AA%E6%98%9F%E6%9C%9F%EF%BC%8C%E8%87%B3%E4%BB%8A%E4%BB%8D%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E5%A5%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E6%88%91%E9%9D%9E%E5%B8%B8%E7%84%A6%E8%99%91%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86IMX6Q%E5%86%85%E6%A0%B8%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%E7%9B%AE%E5%89%8D%E5%9C%A8%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8GC2000%E5%92%8CGC320%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E5%81%B6%E5%B0%94%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%9B%BE%E5%83%8F%E6%92%95%E8%A3%82%E7%8E%B0%E8%B1%A1%E3%80%82%E5%85%B7%E4%BD%93%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%20%E8%8E%B7%E5%8F%96%E5%9B%9B%E8%B7%AF%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E5%AE%9E%E6%97%B6%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B0%86%E5%85%B6%E6%98%BE%E7%A4%BA%E5%9C%A8GPU%E4%B8%8A%EF%BC%8C%E5%B9%B6%E5%AE%9E%E6%97%B6%E5%90%8C%E6%AD%A5%E5%88%B0lvds%E5%B1%8F%E5%B9%95%E3%80%82%E5%90%8C%E6%97%B6%EF%BC%8Cg2d%E8%B0%83%E7%94%A8g2g_blit%E5%87%BD%E6%95%B0%E5%AF%B94%E4%B8%AA%E8%A7%86%E9%A2%91%E9%80%9A%E9%81%93%E8%BF%9B%E8%A1%8C%E7%BC%A9%E6%94%BE%E3%80%82%E6%AF%8F%E5%B8%A7%E5%9B%BE%E5%83%8F%E7%94%B1720P%E7%BC%A9%E6%94%BE%E4%B8%BA640*480%EF%BC%8C%E7%84%B6%E5%90%8E%E5%90%88%E6%88%90%E4%B8%BA%E4%B8%80%E5%B8%A7%E3%80%82%E5%B0%86%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%E4%B8%BA%E4%B8%80%E5%B8%A7%E6%98%BE%E7%A4%BA%E5%9B%9B%E8%B7%AF%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%E3%80%82%E6%8B%BC%E6%8E%A5%E5%90%8E%E7%9A%84%E8%A7%86%E9%A2%91%E4%B8%8D%E4%BC%9A%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E6%98%BE%E7%A4%BA%EF%BC%8C%E8%80%8C%E6%98%AF%E7%9B%B4%E6%8E%A5%E4%BF%9D%E5%AD%98%E5%88%B0%E8%A7%86%E9%A2%91%E4%B8%AD%E3%80%82%E4%BD%86%E7%9B%AE%E5%89%8D%E5%8F%91%E7%8E%B0%EF%BC%8C%E9%80%9A%E8%BF%87GPU%E6%B8%B2%E6%9F%93%E5%AE%9E%E6%97%B6%E6%98%BE%E7%A4%BA%E7%9A%84%E8%A7%86%E9%A2%91%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E7%8E%B0%E8%B1%A1%E3%80%82%E6%92%AD%E6%94%BE%E5%B7%B2%E4%BF%9D%E5%AD%98%E7%9A%84%E8%A7%86%E9%A2%91%E6%97%B6%E4%B9%9F%E5%87%BA%E7%8E%B0%E4%BA%86%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BD%B1%E5%93%8D%E8%A7%82%E7%9C%8B%E6%95%88%E6%9E%9C%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8D%95%E7%8B%AC%E6%B5%8B%E8%AF%95GPU%E6%B8%B2%E6%9F%93%E6%98%BE%E7%A4%BA%EF%BC%8C%E6%88%96%E8%80%85%E9%80%9A%E8%BF%87G2D%E5%90%88%E6%88%90%E4%BF%9D%E5%AD%984%E8%B7%AF%E8%A7%86%E9%A2%91%EF%BC%8C%E5%88%99%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E5%8F%AA%E8%A6%81%E5%B0%86%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%8A%9F%E8%83%BD%E5%90%88%E5%B9%B6%E5%88%B0%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%92%8C%E4%BF%9D%E5%AD%98%E8%A7%86%E9%A2%91%E6%97%B6%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%94%BB%E9%9D%A2%E6%92%95%E8%A3%82%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E1.%20%E6%88%91%E8%83%BD%E5%90%A6%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8IMX6%E5%92%8CGC320%E7%9A%84GC2000%EF%BC%9FGPU%E8%B5%84%E6%BA%90%E6%8A%A2%E5%8D%A0%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20%2F%3E2.%20GPU%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E6%95%B0%E6%8D%AE%E5%86%B2%E7%AA%81%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%91%E5%B7%B2%E7%A1%AE%E4%BF%9DGC2000%E5%92%8CGC320%E8%8E%B7%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%E6%97%A0%E6%B3%95%E7%BC%93%E5%86%B2%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%B0%86%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%8A%9F%E8%83%BD%E9%9B%86%E6%88%90%E5%90%8E%EF%BC%8C%E8%A7%86%E9%A2%91%E6%92%95%E8%A3%82%E7%9A%84%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A2%AB%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%9B%B0%E6%89%B0%E4%BA%86%E5%A5%BD%E5%87%A0%E4%B8%AA%E6%98%9F%E6%9C%9F%EF%BC%8C%E8%87%B3%E4%BB%8A%E4%BB%8D%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E5%A5%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E6%88%91%E9%9D%9E%E5%B8%B8%E7%84%A6%E8%99%91%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%96%E8%AE%B8%E6%88%91%E6%9C%AA%E6%B8%85%E6%99%B0%E6%8F%8F%E8%BF%B0%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E1.%E5%BD%93%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8-g2d%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E7%94%BB%E9%9D%A2%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%97%A0%E5%B1%8F%E5%B9%95%E6%92%95%E8%A3%82%E3%80%82%E5%B9%B6%E4%B8%94%E6%BC%94%E7%A4%BA%E4%BB%A3%E7%A0%81%E7%A1%AE%E5%AE%9E%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EFBIOPAN_DISPLAY%E6%9D%A5%E6%9B%B4%E6%94%B9%E6%98%BE%E7%A4%BA%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%EF%BC%9B%3C%2FP%3E%3CP%3E2.%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20-g2d%20%E6%97%B6%3CSPAN%3E%EF%BC%8C%E5%B1%8F%E5%B9%95%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%92%95%E8%A3%82%E7%8E%B0%E8%B1%A1%E3%80%82%E8%80%8C%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%20g2d_blit%20%E8%BF%9B%E8%A1%8C%E6%98%BE%E7%A4%BA%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color%20error.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color%20error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71472i0FC9B4C09D43C3F0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22color%20error.png%22%20alt%3D%22color%20error.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3Eov10635%20%E5%92%8C%20max9286%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8D%95%E8%8E%B7%E7%9A%84%E5%B8%A7%E6%A0%BC%E5%BC%8F%E6%98%AF%20YUYV%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E6%98%AF%20YUYV%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%A4%84%E7%90%86%E5%85%B6%E4%BB%96%E6%A0%BC%E5%BC%8F%EF%BC%8C%E4%BE%8B%E5%A6%82%20RGB565%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%E9%A2%9C%E8%89%B2%E9%94%99%E8%AF%AF%E9%97%AE%E9%A2%98%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E9%9D%A2%E5%9B%BE%E7%89%87%E6%98%AF%E4%BD%BF%E7%94%A87yuv%E6%9F%A5%E7%9C%8B%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8C%E9%80%89%E6%8B%A9%E7%9A%84%E6%A0%BC%E5%BC%8F%E6%98%AFYUYV%EF%BC%9B%E5%9B%BE%E5%83%8F%E9%A2%9C%E8%89%B2%E4%B8%8D%E5%AF%B9%E3%80%82%E6%89%80%E4%BB%A5%E4%B8%8D%E6%98%AF%E6%98%BE%E7%A4%BA%E6%A0%BC%E5%BC%8F%E4%B8%8D%E5%8C%B9%E9%85%8D%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26gt%3B%E5%8F%A6%E5%A4%96%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8CMAX96705%E5%8F%AF%E4%BB%A5%E4%BA%A4%E6%8D%A2%E6%95%B0%E6%8D%AE%E8%A1%8C%E9%A1%BA%E5%BA%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%E9%94%99%E8%AF%AF%EF%BC%8C%E8%89%B2%E5%BD%A9%E5%B0%B1%E4%BC%9A%E5%87%BA%E9%94%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E7%9F%A5%E9%81%93%E9%A9%B1%E5%8A%A8%E9%82%A3%E9%87%8C%E5%8F%AF%E4%BB%A5swap%20dataline%20order%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELiqiang%EF%BC%8C%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%80%E6%AC%BE%E5%9F%BA%E4%BA%8Eimx6d%2FOV10635%2FMAX96705%2FMAX9286%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%E5%9B%9B%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E5%BA%94%E7%94%A8%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%BA%94%E7%94%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E6%98%AF%20L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9B%BE%E5%83%8F%E8%89%B2%E5%BD%A9%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color-error.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color-error.png%22%20style%3D%22width%3A%20804px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71301iE6667237C9E1F67B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22color-error.png%22%20alt%3D%22color-error.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%3CP%3E1.%20%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%BE%93%E5%85%A5%E5%88%86%E8%BE%A8%E7%8E%87%E5%92%8C%E6%A0%BC%E5%BC%8F%E4%B8%8E%E8%BE%93%E5%87%BA%E6%95%B0%E6%8D%AE%E7%9B%B8%E5%90%8C%EF%BC%8CIPU%E5%B0%86%E4%B8%8D%E4%BA%88%E5%A4%84%E7%90%86%E3%80%82%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%20%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20-g2d%3CSPAN%3E%20%E5%8F%82%E6%95%B0%E7%9A%84%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Eroot%40imx6qsabresd%3A%2F%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%26nbsp%3B%3C%2FSPAN%3E720%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-d%201%20-x%200%20-g2d%EF%BC%8C%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%B1%8F%E5%B9%95%E6%92%95%E8%A3%82%E7%8E%B0%E8%B1%A1%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tearing.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tearing.png%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71335i32BD58F756C4DD71%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tearing.png%22%20alt%3D%22tearing.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%E6%82%A8%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E6%97%B6%E6%9C%AA%E6%B7%BB%E5%8A%A0-g2d%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Eroot%40imx6qsabresd%3A%2F%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%20%3CSTRONG%3E720%3C%2FSTRONG%3E%20-d%201%20-x%200%20%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP3%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x26700000%2C%20smem_len%20%3D%200xa8c000.%3CBR%20%2F%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x1c2000%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%201280.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20720.%3CBR%20%2F%3EIPU_CHECK_TASK%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%20%3CSPAN%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%3CSTRONG%3E%20719%3C%2FSTRONG%3E%20-d%201%20-x%200%20%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%9B%BE%E5%83%8F%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8Yocto%E4%B8%AD%E4%B8%BAi.MX6%20QuadPLUS%E6%9E%84%E5%BB%BA%E2%80%9C%E7%8E%AF%E8%A7%86%E5%BA%94%E7%94%A8%E2%80%9D%E5%8F%8A%E5%85%B6%E6%89%80%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%BE%97%E5%88%B0%E6%9B%B4%E6%98%8E%E7%A1%AE%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EBala%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8CQiang%20Li%EF%BC%8C%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E7%8E%B0%E5%9C%A8%E7%A1%AE%E5%AE%9E%E6%98%AF%E9%95%9C%E5%A4%B4%E6%A8%A1%E7%BB%84%E4%B8%8A%E6%8C%82%E4%BA%86%E4%B8%AAflash%EF%BC%8C%E4%B8%8D%E8%BF%87flash%E9%87%8C%E9%9D%A2%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%98%AF%E5%AE%89%E6%A3%AE%E7%BE%8E%E7%9A%84%E4%BB%A3%E7%90%86%E5%95%86%E6%8F%90%E4%BE%9B%E7%9A%84%EF%BC%8C%E4%BB%96%E4%BB%AC%E7%A1%AE%E8%AE%A4%E5%B7%B2%E7%BB%8F%E5%B7%A5%E4%BD%9C%E5%9C%A8framesync%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%BF%99%E4%B8%AA%E5%9B%BA%E4%BB%B6%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%88%AB%E7%9A%84%E5%AE%A2%E6%88%B7%E5%9C%A8%E9%87%8F%E4%BA%A7%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AF%BB%E5%87%BAAP0101%E7%9A%840xC88C%EF%BC%8C0xC88D%EF%BC%8C0xC88E%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%80%BC%E5%88%86%E5%88%AB%E6%98%AF0x03%2C0x03%2C0x00%EF%BC%8C%E5%90%8C%E6%97%B6%E9%80%9A%E8%BF%87%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E5%88%86%E6%9E%90AP0101%E5%AF%B9AR0143%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%84%9F%E8%A7%89%E4%B9%9F%E5%BA%94%E8%AF%A5%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%9Bmax9286%E8%BF%99%E7%AB%AF%E5%B7%B2%E7%BB%8F%E7%A1%AE%E8%AE%A4%E7%94%9F%E6%88%90%E7%9A%84framesync%E4%BF%A1%E5%8F%B7%E6%9C%89%E4%BC%A0%E8%BE%93%E5%88%B0AP0101%EF%BC%8C%E7%8E%B0%E5%9C%A8sensor%E5%87%BA%E6%9D%A5%E7%9A%84%E5%B8%A7%E7%8E%87%E6%98%AF25fps%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E9%92%88%E5%AF%B925fps%EF%BC%8Cmax9286%E8%BF%99%E8%BE%B9%E7%9A%84%E9%85%8D%E7%BD%AE%E5%BA%94%E8%AF%A5%E5%A6%82%E6%9E%9C%E4%BF%AE%E6%94%B9%EF%BC%8C%E7%9B%BC%E5%A4%8D%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%88%91%E6%9B%B4%E6%96%B0%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%E5%90%8E%EF%BC%8CVIDIOC_DQBUF%E9%94%99%E8%AF%AF%E6%B6%88%E5%A4%B1%E3%80%82%E6%88%91%E5%B0%86%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%EF%BC%8C%E4%BD%86%E7%9B%AE%E5%89%8D%E7%9C%8B%E6%9D%A5%E4%BC%BC%E4%B9%8E%E6%98%AF%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E3%80%82%E5%B0%BD%E7%AE%A1%E6%9C%89%E6%97%B6%E4%BB%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EVIDIOC_DQBUF%E5%92%8CMIPI%20CLK%E9%94%99%E8%AF%AF%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3E%E4%BD%86%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%8E%B7%E5%8F%96%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EAR0140%20%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLI%3E%3CLI%3EAP0101%20ISP%3C%2FLI%3E%3CLI%3EMAX96705%20%E4%B8%B2%E8%A1%8C%E5%99%A8%3C%2FLI%3E%3CLI%3EMAX9286%E8%A7%A3%E4%B8%B2%E5%99%A8%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E8%AE%BE%E8%AE%A1%E7%9A%84%E5%AD%90%E6%9D%BF%E4%BB%8B%E4%BA%8EMAX9286%20EVM%E5%92%8CiMX6%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B9%8B%E9%97%B4%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B84.1.15%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%B8%8B%E4%BA%A4%E6%8D%A2%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%2B%20max9271_write_reg(i%2C%200x20%2C%200x07)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x21%2C%200x06)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x22%2C%200x05)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x23%2C%200x04)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x24%2C%200x03)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x25%2C%200x02)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x26%2C%200x01)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x27%2C%200x00)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x30%2C%200x17)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x31%2C%200x16)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x32%2C%200x15)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x33%2C%200x14)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x34%2C%200x13)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x35%2C%200x12)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x36%2C%200x11)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x37%2C%200x10)%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22after_patch.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22after_patch.jpg%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74688i185EB5054F16D904%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22after_patch.jpg%22%20alt%3D%22after_patch.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%B0%A2%E8%B0%A2%E5%B9%B6%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%A0%E9%9C%80%E6%AD%A4%E5%BC%80%E5%85%B3%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%A1%A5%E4%B8%81%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%9B%B8%E5%85%B3%E4%BB%A3%E7%A0%81%E3%80%82%E4%B8%8D%E8%BF%87%E6%88%91%E5%B7%B2%E7%BB%8F%E5%90%91%E6%82%A8%E5%B1%95%E7%A4%BA%E4%BA%86%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%85%B3%E4%BA%8EMAX96705%E5%BC%80%E5%85%B3%E7%9A%84%E8%AF%A6%E7%BB%86%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%B7%E5%92%A8%E8%AF%A2Maxim%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%9C%A8%E8%A1%A5%E4%B8%81%E6%96%87%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%A4%E6%8D%A2%E4%BB%A3%E7%A0%81%E3%80%82%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B0%86%E9%93%BE%E6%8E%A5%E6%9B%B4%E6%96%B0%E4%B8%BA%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B9%B6%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20DONGON%20KIM%2C%3C%2FP%3E%3CP%3E%E9%83%A8%E5%88%86%E8%A7%86%E9%A2%91%E5%90%88%E6%88%90%E8%8A%AF%E7%89%87%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AF%8F%E8%A1%8C%E8%A7%86%E9%A2%91%E4%B8%AD%E6%8F%92%E5%85%A5%E7%89%B9%E5%AE%9A%E5%AD%97%E8%8A%82%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BD%AF%E4%BB%B6%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5%E8%BF%99%E4%BA%9B%E6%8F%92%E5%85%A5%E7%9A%84%E6%95%B0%E6%8D%AE%E6%9D%A5%E8%AF%86%E5%88%AB%E6%91%84%E5%83%8F%E5%A4%B4%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BA%A4%E6%8D%A2%E6%9C%BA%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x20%2C%200x09)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x21%2C%200x08)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x22%2C%200x07)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x23%2C%200x06)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x24%2C%200x05)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x25%2C%200x04)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x26%2C%200x03)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x27%2C%200x02)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x28%2C%200x01)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x29%2C%200x00)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x30%2C%200x19)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x31%2C%200x18)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x32%2C%200x17)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x33%2C%200x16)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x34%2C%200x15)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x35%2C%200x14)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x36%2C%200x13)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x37%2C%200x12)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x38%2C%200x11)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x39%2C%200x10)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%A1%A5%E4%B8%81%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%ABMAX96705%E7%9A%84%E4%BA%A4%E6%8D%A2%E8%AE%BE%E7%BD%AE%EF%BC%9F%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8MAX96705%EF%BC%8C%E4%B8%8D%E9%80%9A%E8%BF%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%89%A7%E8%A1%8C%E6%AD%A4%E7%B1%BB%E4%BA%A4%E6%8D%A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%2C%3C%2FP%3E%3CP%3EMAX9286%E7%9A%84%E6%95%B0%E6%8D%AE%E6%98%A0%E5%B0%84%E9%9C%80%E8%A6%81%E5%B0%86MSB%E4%BA%A4%E6%8D%A2%E4%B8%BALSB%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8MAX96705%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%E5%AE%9E%E7%8E%B0%E4%BA%A4%E6%8D%A2%EF%BC%8C%E4%BD%86MAX9271%E4%B8%8D%E6%94%AF%E6%8C%81%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82AP0101%E4%B9%9F%E4%B8%8D%E6%94%AF%E6%8C%81%E6%AD%A4%E7%B1%BB%E4%BA%A4%E6%8D%A2%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E5%AF%B9%E7%A1%AC%E4%BB%B6%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dongoh%2C%3C%2FP%3E%3CP%3EiMX8MQ%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%A4%9A%E4%B8%AA%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E6%8E%A5%E6%94%B6%E8%A7%86%E9%A2%91%EF%BC%8C%E4%BD%86%E6%9A%82%E6%97%A0%E7%A1%AC%E4%BB%B6%E6%A8%A1%E5%9D%97%E5%8F%AF%E5%88%86%E7%A6%BB%E6%AF%8F%E4%B8%AA%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E7%9A%84%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E8%BD%AF%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%88%86%E5%89%B2%EF%BC%8C%E5%B9%B6%E4%B8%94MIPI%E5%8F%91%E9%80%81%E6%96%B9%E9%9C%80%E8%A6%81%E6%8F%92%E5%85%A5%E4%B8%80%E4%BA%9B%E6%A0%87%E5%BF%97%E6%9D%A5%E8%AF%86%E5%88%AB%E6%AF%8F%E4%B8%AA%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AEi.MX8MQ%E4%B8%BA%E4%BD%95%E4%B8%8D%E6%94%AF%E6%8C%81%E5%A4%9A%E4%B8%AA%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%EF%BC%9F%E6%A0%B9%E6%8D%AEi.MX8M%20Quad%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E5%85%B3%E4%BA%8EMIPI-CSI2%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E7%89%B9%E6%80%A7%E5%92%8C%E5%8A%9F%E8%83%BD%E6%8F%8F%E8%BF%B0%EF%BC%8C%3C%2FP%3E%3CP%3Ei.MX8M%20%E4%BC%BC%E4%B9%8E%E6%94%AF%E6%8C%81%E5%A4%9A%E4%B8%AA%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%EF%BC%8813.6.1.1%E5%92%8C13.6.3%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BA%86%E8%A7%A3%E6%82%A8%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%E4%BB%A5%E4%B8%8B%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E2%80%9C2)%20AP0101%E7%9A%84DOUT0~DOUT7%E5%BA%94%E8%BF%9E%E6%8E%A5%E8%87%B3MAX9271%E7%9A%84DIN7~DIN0%EF%BC%8C%E8%BF%9E%E6%8E%A5%E9%A1%BA%E5%BA%8F%E9%9C%80%E8%B0%83%E6%8D%A2%EF%BC%8CMSB%E8%BF%9E%E6%8E%A5%E8%87%B3LSB%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9C%A8%E7%94%B1Onsemi%EF%BC%88MARS%E6%A8%A1%E5%9D%97%EF%BC%89%E6%8F%90%E4%BE%9B%E7%9A%84%E5%8F%82%E8%80%83%E6%91%84%E5%83%8F%E5%A4%B4%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%BC%95%E8%84%9A%E5%B7%B2%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%EF%BC%88DOUT0-DOUT7%E8%87%B3DIN0-DIN7%EF%BC%89%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E9%80%9A%E8%BF%87%E8%BD%AF%E4%BB%B6%E8%B0%83%E6%8D%A2%E8%BF%99%E4%BA%9B%E8%BF%9E%E6%8E%A5%EF%BC%9F%E6%88%91%E5%9C%A8MAX96705%E5%92%8CAP0101%E7%9A%84%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E4%B8%AD%E5%B9%B6%E6%9C%AA%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%B0%A2%E8%B0%A2%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E8%BF%9E%E6%8E%A5%E5%88%B0max9286%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%B0%86%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E5%BA%94%E7%94%A8%E5%88%B04.1.15%E5%86%85%E6%A0%B8%EF%BC%9B%E7%84%B6%E8%80%8C%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%AC%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22image-1%20jive-image%20j-img-original%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CIMG%20alt%3D%22%22%20class%3D%22image-3%20jive-image%22%20src%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B5HptjiQQyECUG93YXNsSjR6cjlVR0x1SER1a0ZiSTVLUC1R%22%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220180831_104651(0).jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220180831_104651(0).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F67813i70D174B44B428AD6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220180831_104651(0).jpg%22%20alt%3D%2220180831_104651(0).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40esomimx6q%3A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20400%20-oh%20240%20-d%201%20-x%200%3CBR%20%2F%3E%5B%203144.243857%5D%20max9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%201.%3CBR%20%2F%3E%5B%203144.248939%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3E%5B%203144.257446%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20%E5%80%BC%20%3D%200x42.%3CBR%20%2F%3E%5B%203144.743416%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E5%B7%B2%E6%89%BE%E5%88%B0%2C%20%E7%B4%A2%E5%BC%95%20%3D%201.%3CBR%20%2F%3E%5B%203144.751541%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x6a100000%2C%20smem_len%20%3D%200x8ca00.%3CBR%20%2F%3Efb%3A%20%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x2ee00%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%20400%2C%20g_screen_info.yres%20%3D%20240.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20400.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20240.%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201535715437%E7%A7%92%EF%BC%8C436911%E5%BE%AE%E7%A7%92%3CBR%20%2F%3E%5B%203154.993386%5D%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_dqueue%E8%B6%85%E6%97%B6%EF%BC%8Cenc_counter%200%3CBR%20%2F%3EVIDIOC_DQBUF%E5%A4%B1%E8%B4%A5.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E7%90%86%E8%A7%A3%E9%97%AE%E9%A2%98%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%88%E6%88%91%E4%BB%AC%E5%B7%B2%E5%B0%86gpr1%E5%BC%95%E8%84%9A19%E5%92%8C20%E8%B0%83%E6%95%B4%E4%B8%BA0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%2Fdev%2Fvideo1%E5%92%8C%2Fdev%2Fvideo3%E5%9C%A8csi%E9%80%9A%E9%81%93%E6%96%B9%E9%9D%A2%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B0%BD%E7%AE%A1%2Fdev%2Fvideo0%E5%92%8C%2Fdev%2Fvideo2%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%89%80%E6%9C%89%E8%AE%BE%E5%A4%87%E5%9D%87%E5%87%BA%E7%8E%B0%E8%B6%85%E6%97%B6%E9%94%99%E8%AF%AF%EF%BC%88%E6%B3%A8%E6%84%8F%EF%BC%8C%E7%94%B1%E4%BA%8E%E4%BB%85%E8%BF%9E%E6%8E%A5%E4%B8%80%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AA%E6%9C%89%22cat%20%2Fdev%2Fvideo0%22%E5%91%BD%E4%BB%A4%E5%8F%AF%E5%88%9D%E5%A7%8B%E5%8C%96ap0101%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo0%3CBR%20%2F%3E%5B%203313.913877%5D%20max9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%201.%3CBR%20%2F%3E%5B%203313.918963%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3E%5B%203313.926941%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20%E5%80%BC%20%3D%200x42.%3CBR%20%2F%3E%5B%203314.413402%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E5%B7%B2%E6%89%BE%E5%88%B0%2C%20%E7%B4%A2%E5%BC%95%20%3D%201.%3CBR%20%2F%3E%5B%203314.421469%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3E%5B%203324.583392%5D%20%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_read%E8%B6%85%E6%97%B6%20%E8%AE%A1%E6%95%B0%E5%99%A8%200%3CBR%20%2F%3Ecat%EF%BC%9A%E8%AF%BB%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%E5%B7%B2%E8%BF%87%E6%9C%9F%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo1%3CBR%20%2F%3E%5B%203%2C337.083393%5D%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_read%20%E8%B6%85%E6%97%B6%20%E8%AE%A1%E6%95%B0%E5%99%A8%200%3CBR%20%2F%3E%5B%203337.089359%5D%20imx-ipuv3%202400000.ipu%EF%BC%9A%E9%9D%9ECSI%E9%80%9A%E9%81%93%3CBR%20%2F%3Ecat%3A%20%E8%AF%BB%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%E5%B7%B2%E8%BF%87%E6%9C%9F%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo2%3CBR%20%2F%3E%5B%203%2C351.493394%5D%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_read%20%E8%B6%85%E6%97%B6%20%E8%AE%A1%E6%95%B0%E5%99%A8%200%3CBR%20%2F%3Ecat%EF%BC%9A%E8%AF%BB%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%E5%B7%B2%E8%BF%87%E6%9C%9F%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo3%3CBR%20%2F%3E%5B%203403.463393%5D%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_read%20%E8%B6%85%E6%97%B6%20%E8%AE%A1%E6%95%B0%E5%99%A8%200%3CBR%20%2F%3E%5B%203403.469360%5D%20imx-ipuv3%202800000.ipu%3A%E9%9D%9ECSI%E9%80%9A%E9%81%93%3CBR%20%2F%3Ecat%3A%20%E8%AF%BB%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%E5%B7%B2%E8%BF%87%E6%9C%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%90%97%EF%BC%9F%E8%A7%86%E9%A2%911%E5%92%8C%E8%A7%86%E9%A2%913%E4%B8%8A%E5%87%BA%E7%8E%B0%E2%80%9C%E9%9D%9Ecsi%E9%80%9A%E9%81%93%E9%94%99%E8%AF%AF%E2%80%9D%EF%BC%8C%E8%80%8C%E5%85%B6%E4%BB%96%E8%A7%86%E9%A2%91%E5%B9%B6%E6%9C%AA%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%AD%A4%E5%A4%96%EF%BC%8C%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E6%9B%B4%E4%B8%BA%E9%87%8D%E8%A6%81%EF%BC%8C%E5%8D%B3%E2%80%9Cvidioc_dqbuf%20%E5%A4%B1%E8%B4%A5%E2%80%9D%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%A6%82%E4%B8%8B%EF%BC%8C%E8%83%BD%E5%90%A6%E5%8D%8F%E5%8A%A9%E5%A4%84%E7%90%86%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20547px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F68151i926039B7A9A1744B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%B5%8B%E8%AF%95%E5%BA%94%E7%94%A8%E6%96%87%E4%BB%B6%E4%B8%8D%E5%8C%85%E5%90%AB%22%3CSPAN%3Eg2d.h%3C%2FSPAN%3E%22%EF%BC%8C%E4%BD%86%E2%80%9Cmxc_v4l2_tvin.c%E2%80%9D%E4%B8%AD%E5%8C%85%E5%90%AB%E4%BB%A3%E7%A0%81%23include%20%E2%80%9Cg2d.h%E2%80%9D%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BD%93%E6%88%91%E7%BC%96%E8%AF%91%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%83%B3%E6%82%A8%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Qiang%20Li%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E2%80%9C%E8%A1%A5%E4%B8%81%E2%80%9D%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BAkernel-3.10.53%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%3CSPAN%3Ekernel-3.10.53%E5%92%8CL3.10.53_1.1.0-GA%3C%2FSPAN%3E%E4%B9%8B%E9%97%B4%E6%9C%89%E4%BD%95%E5%8C%BA%E5%88%AB%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E4%B8%8D%E5%90%8C%E7%9A%84%E8%A7%86%E8%A7%92%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi%20Li%20Qiang%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%22%E8%A1%A5%E4%B8%81%22%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%BA%E6%88%91%E7%BC%96%E5%86%99%E4%B8%80%E4%BB%BD%E6%89%8B%E5%86%8C%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E7%90%86%E8%A7%A3%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E2%80%9C%E8%A1%A5%E4%B8%81%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%88%98%E5%BF%A0%E8%8C%82%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi.%20Qiang%20Li%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E8%A7%86%E9%A2%91%E5%9D%87%E5%8F%AF%E5%9C%A81080P%20HDMI%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E6%B8%B2%E6%9F%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%8E%AF%E8%A7%86%E7%AE%97%E6%B3%95%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%B8%80%E4%BA%9B%E5%A5%BD%E4%B8%BB%E6%84%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%20!%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E2%80%9C60-persistent-v4l.rules%E2%80%9D%E6%96%87%E4%BB%B6%EF%BC%9F%E5%AE%83%E5%BA%94%E8%AF%A5%E5%9C%A8%2Flib%2Fudev%2Frules.d%E4%B8%AD%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EGokcen%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi!%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA1280x720%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%B9%B6%E9%9D%9E%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%E6%88%91%E4%BB%AC%E5%BD%93%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC4.1.15%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E5%8F%AF%E8%83%BD%E4%B8%8E%E6%AD%A4%E6%9C%89%E5%85%B3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%2036.921793%5D%20v4l2_int_device%20wlcore_sdio%20mxc_dcic%3CBR%20%2F%3E%5B%2036.926813%5D%20CPU%3A%203%20PID%3A%20399%20Comm%3A%20v4l_id%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%204.1.15%20%231%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%5B%2094.823493%5D%20udevd%5B215%5D%3A%20%E5%B7%A5%E4%BD%9C%E8%BF%9B%E7%A8%8B%20%5B230%5D%20%2Fdevices%2Fsoc0%2Fv4l2_cap_1%2Fvideo4linux%2Fvideo1%E8%80%97%E6%97%B6%E8%BF%87%E9%95%BF%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%5B%2095.098316%5D%20udevd%5B230%5D%3A%20%E6%85%A2%EF%BC%9A%E2%80%98v4l_id%20%2Fdev%2Fvideo1%E2%80%99%20%5B402%5D%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebootlogd%3A%20%E6%97%A0%E6%B3%95%E5%88%86%E9%85%8D%E4%BC%AA%E7%BB%88%E7%AB%AF%EF%BC%9A%E6%B2%A1%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A5%9D%E4%BD%A0%E4%BB%8A%E5%A4%A9%E8%BF%87%E5%BE%97%E6%84%89%E5%BF%AB%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FP%3E%3CP%3EONSEMI%20MARS%20%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%EF%BC%88MAX96705%EF%BC%8CAP0101%EF%BC%8CAR0140%EF%BC%89%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%E4%B8%AD%E5%8C%85%E5%90%AB30%20cm%20RG174%EF%BC%88%E4%BB%A5%E5%8F%8A3m%E5%90%8C%E8%BD%B4%E7%94%B5%E7%BC%86%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3EMAX9286S32V%E5%AD%90%E6%9D%BF%E5%8F%AF%E7%94%A8%E4%BA%8E%E8%BF%9E%E6%8E%A5iMX6%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E9%80%9A%E8%BF%87%E7%A7%BB%E9%99%A4%E9%97%AA%E5%AD%98%E5%B0%86AP0101%E8%AE%BE%E4%B8%BA%E4%B8%BB%E6%9C%BA%E9%85%8D%E7%BD%AE%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E6%88%91%E5%B0%860x36%E5%86%99%E5%85%A5MAX9286%E7%9A%84%E7%AC%AC34%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E4%BB%A5%E7%A6%81%E7%94%A8%E6%9C%AC%E5%9C%B0%E8%87%AA%E5%8A%A8%E7%A1%AE%E8%AE%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BD%86%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0SCL%E7%9A%84%E7%AC%AC9%E4%BD%8D%E7%B4%A7%E9%9A%8F%E7%AC%AC8%E4%BD%8D%E4%B9%8B%E5%90%8E%E5%87%BA%E7%8E%B0%E3%80%82%E8%AF%A6%E8%A7%81%E9%9A%8F%E9%99%84%E7%A4%BA%E6%B3%A2%E5%99%A8%E8%A7%86%E5%9B%BE%E3%80%82%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E7%9A%84%E4%BD%8D%E5%9D%87%E4%BB%A5%E7%BA%A2%E8%89%B2%E6%A0%87%E6%B3%A8%E3%80%82%3C%2FP%3E%3CP%3EMAX9286%20LFLT%20%E6%8C%87%E7%A4%BA%E7%81%AF%E4%BA%AE%E8%B5%B7%EF%BC%8CLOCK%20%E6%8C%87%E7%A4%BA%E7%81%AF%E7%86%84%E7%81%AD%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00002.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00002.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66105i41676A217FBC9F2A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tek00002.png%22%20alt%3D%22tek00002.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BB%8EAP0101%EF%BC%88%E5%9C%B0%E5%9D%80%EF%BC%9A0x92%EF%BC%89%E8%AF%BB%E5%8F%96%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00003.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00003.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66119i638B78663985C83C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tek00003.png%22%20alt%3D%22tek00003.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%8F%AF%E4%BB%A5%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%3CP%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%3CP%3E-%204xMIPI%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E4%B8%8A%E9%9D%A2%E7%9A%84CSI%E5%92%8CMIPI%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%E5%90%97%EF%BC%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AAcsi%E6%98%AF%E6%8C%87ipu%E5%86%85%E9%83%A8%E7%9A%84csi0-3%20%E8%BF%98%E6%98%AFcamera%20mipi%E6%80%BB%E7%BA%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1xCSI%EF%BC%8C3xMIPI%EF%BC%8C%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%20%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E2%80%9Cmx8_v4l2_cap_drm.out%E2%80%9D%E6%B5%8B%E8%AF%95%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BD%86%E6%B5%8B%E8%AF%95%E8%BF%9B%E5%BA%A6%E5%9C%A8'start_capturing'%E5%87%BD%E6%95%B0%E4%B8%AD%E5%81%9C%E6%BB%9E%E3%80%82%E6%9C%80%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%AE%83%E5%AE%9E%E9%99%85%E4%B8%8A%E5%81%9C%E6%BB%9E%E5%9C%A8'ioctl(fd_v4l%2C%20VIDIOC_DQBUF%2C%20%26amp%3Bbuf)'%E5%87%BD%E6%95%B0%E4%B8%AD%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86max9286%E7%9A%84%E5%9B%9B%E4%B8%AA%E8%BE%93%E5%87%BA%E4%BF%A1%E5%8F%B7%EF%BC%8CDout0~Dout3%E5%9D%87%E6%9C%89%E4%BF%A1%E5%8F%B7%EF%BC%8C%E6%B5%8B%E8%AF%95%E7%9A%84%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E4%B8%BA295MHz%EF%BC%8C%E8%BE%93%E5%85%A5%E7%AB%AF%E4%B9%9F%E6%9C%89%E4%BF%A1%E5%8F%B7%E3%80%82max9286%E5%92%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BC%BC%E4%B9%8E%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%B1%8F%E5%B9%95%E4%B8%8A%E5%B9%B6%E6%9C%AA%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E8%AE%A9%E6%88%91%E5%9B%B0%E6%83%91%E4%BA%86%E5%A5%BD%E5%87%A0%E5%A4%A9%E3%80%82%E6%82%A8%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%E9%9A%8F%E9%99%84%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx8mqevk%3A~%23%20.%2Fmx8_v4l2_cap_drm.out%20-cam%203%3CBR%20%2F%3Einit_video_channel%EF%BC%8C%2Fdev%2Fvideo0%20init%200%3CBR%20%2F%3Einit_video_channel%EF%BC%8C%2Fdev%2Fvideo1%20init%201%3CBR%20%2F%3E%E6%89%93%E5%BC%80%2Fdev%2Fdri%2Fcard0%E6%88%90%E5%8A%9F%3CBR%20%2F%3Efb%E6%95%B0%E9%87%8F%EF%BC%9A0%3CBR%20%2F%3Ecrtc%E6%95%B0%E9%87%8F%EF%BC%9A2%3CBR%20%2F%3E%E7%BC%96%E7%A0%81%E5%99%A8%E6%95%B0%E9%87%8F%EF%BC%9A1%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%95%B0%E9%87%8F%EF%BC%9A1%3CBR%20%2F%3E%E6%A8%A1%E5%BC%8F%E6%95%B0%E9%87%8F%20%3D%201%3CBR%20%2F%3E%E7%BC%96%E7%A0%81%E5%99%A8%E6%95%B0%E9%87%8F%20%3D%201%3CBR%20%2F%3E%E5%B1%9E%E6%80%A7%E6%95%B0%E9%87%8F%20%3D%202%5B21.059227%5D%20mxc-mipi-csi2%2058227000.csi%3A%E5%AE%BD%E5%BA%A6%3D1280%EF%BC%8C%E9%AB%98%E5%BA%A6%3D800%EF%BC%8Cfmt.code%3D0x2011%3C%2FP%3E%3CP%3E%E6%A8%A1%E5%BC%8F%5B0%5D%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%88%86%E8%BE%A8%E7%8E%87%3D1024*600%E5%83%8F%E7%B4%A0%3CBR%20%2F%3Ekms%E4%BF%A1%E6%81%AF%EF%BC%9Afb_base%20%3D%200%5B%2021.071187%5D%20%E8%BE%93%E5%85%A5%E6%A0%BC%E5%BC%8F%20YUV4%3CBR%20%2F%3Ex789b3000%3CBR%20%2F%3E%E5%AE%BD%2F%E9%AB%98%3D(1024%2C600)%3CBR%20%2F%3E%E6%AF%8F%E5%83%8F%E7%B4%A0%E4%BD%8D%E6%95%B0%3D4%3CBR%20%2F%3Ebpp%3D32%3CBR%20%2F%3Escreen_buf_s%5B%2021.079551%5D%20%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%20RGB4%3CBR%20%2F%3E%E5%A4%A7%E5%B0%8F%3D2457600%3CBR%20%2F%3Exres%3D1024%EF%BC%8Cy_res%3D600%3CBR%20%2F%3Ech_id%3D0%2C%20w%3D512%2C%20h%3D300%2C%20x_offs%5B%2021.088947%5D%20mxc-isi%2058100000.isi%3A%20input_size%EF%BC%88800%2C1280%EF%BC%89%EF%BC%8Coutput_size%EF%BC%88300%2C512%EF%BC%89%3CBR%20%2F%3Eet%3D0%EF%BC%8Cy_offset%3D0%3CBR%20%2F%3Ech_id%3D1%EF%BC%8Cw%3D512%EF%BC%8Ch%3D300%EF%BC%8Cx_offset%3D512%EF%BC%8Cy_offset%3D0%5B%2021.105981%5D%20mxc-mipi-csi2%2058227000.csi%EF%BC%9A%E5%AE%BD%E5%BA%A6%3D1280%EF%BC%8C%E9%AB%98%E5%BA%A6%3D800%EF%BC%8Cfmt.code%3D0x2011%3C%2FP%3E%3CP%3E%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%E8%AE%BE%E5%A4%87%20%2Fdev%2Fvideo0%3CBR%20%2F%3Ecap%3D0x84201000%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D0%3CBR%20%2F%3Epixelf%5B%2021.113602%5D%20%E8%BE%93%E5%85%A5%E6%A0%BC%E5%BC%8F%20YUV4%3CBR%20%2F%3Eormat%20(%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA)%3A%20RGBP%3CBR%20%2F%3Eindex%3D1%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%20(%E7%94%B1c%5B%2021.121958%5D%E8%BE%93%E5%87%BA%20%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%20RGB4%3CBR%20%2F%3Eamera)%3A%20RGB3%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D2%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%20(%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA)%3A%20RGB4%3CBR%20%2F%3Einde%5B%2021.130400%5D%20mxc-isi%2058110000.isi%3A%20input_size%EF%BC%88800%2C1280%EF%BC%89%EF%BC%8Coutput_size%EF%BC%88300%2C512%EF%BC%89%3CBR%20%2F%3Ex%3D3%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ABGR3%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D4%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ABA24%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D5%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%5B%2021.150628%5D%20mxc-mipi-csi2%2058227000.csi%EF%BC%9A%E5%AE%BD%E5%BA%A6%3D1280%EF%BC%8C%E9%AB%98%E5%BA%A6%3D800%EF%BC%8C%E6%A0%BC%E5%BC%8F%E4%BB%A3%E7%A0%81%3D0x2011%3CBR%20%2F%3E%3A%20YUYV%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D6%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9AYUV4%3CBR%20%2F%3EVIDIOC%20ENUM%20FMT%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%B4%A2%E5%BC%95%3D7%3CBR%20%2F%3Evideo_ch%3D0%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D512%EF%BC%8C%E9%AB%98%E5%BA%A6%3D300%EF%BC%8C%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%9ARGB4%3CBR%20%2F%3E%20WxH%40fps%20%3D%20512x300%4030%20%E5%9B%BE%E5%83%8F%E5%A4%A7%E5%B0%8F%20%3D%20614%2C400%3CBR%20%2F%3Ev4l_capture_setup%2C%20%E6%89%93%E5%BC%80v4l_dev%3D0x4%2C%20%E9%80%9A%E9%81%93%3D0%3CBR%20%2F%3E%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%E8%AE%BE%E5%A4%87%2Fdev%2Fvideo1%3CBR%20%2F%3Ecap%3D0x84201000%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D0%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ARGBP%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D1%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ARGB3%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D2%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ARGB4%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D3%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ABGR3%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D4%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9ABA24%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D5%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9AYUYV%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%3D6%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%88%E7%94%B1%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA%EF%BC%89%EF%BC%9AYUV4%3CBR%20%2F%3EVIDIOC%20ENUM%20FMT%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%B4%A2%E5%BC%95%3D7%3CBR%20%2F%3Evideo_ch%3D1%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D512%EF%BC%8C%E9%AB%98%E5%BA%A6%3D300%EF%BC%8C%3CBR%20%2F%3E%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%9ARGB4%3CBR%20%2F%3E%20WxH%40fps%20%3D%20512x300%4030%20%E5%9B%BE%E5%83%8F%E5%A4%A7%E5%B0%8F%20%3D%20614%2C400%3CBR%20%2F%3Ev4l_capture_setup%2C%20%E6%89%93%E5%BC%80v4l_dev%3D0x5%2C%20%E9%80%9A%E9%81%93%3D1%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B0%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x7891d000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x0%2C%20buf_size%3D614%2C400%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B1%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x78887000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x96000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B2%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x787f1000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x12c000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B0%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x7875b000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x0%2C%20buf_size%3D614400%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B1%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x786c5000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x96000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E7%BC%93%E5%86%B2%E5%8C%BA%5B2%5D%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%3D0x7862f000%2C%20%E5%81%8F%E7%A7%BB%E9%87%8F%3D0x12c000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E6%8D%95%E8%8E%B7%20%E9%80%9A%E9%81%93%3D0%2C%20v4l_dev%3D0x4%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E6%8D%95%E8%8E%B7%20%E9%80%9A%E9%81%93%3D1%2C%20v4l_dev%3D0x5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9F%A5%E9%81%93i.MX8M%E7%9A%84%E6%AD%A3%E7%A1%AE%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E6%98%AF%E5%93%AA%E4%B8%80%E4%B8%AA%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CIMG%20data-custom%3D%22AAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%22%20data-downloadimage%3D%22service.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%22%20data-imagetype%3D%22AttachmentByCid%22%20data-thumbnailimage%3D%22https%3A%2F%2Fattachment.outlook.office.net%2Fowa%2Fhuang.benson%40inventec.com%2Fservice.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%26amp%3Btoken%3DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6IkJnRDU5blJpQnpmbk5BVGloOFJhZ1l5M3pyZyJ9.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.qaxYVZySJYx1QE_ZEsX5P-EA3YJzdm2uvF9VrbUOXEO_I9ssi_mWH9Kv6lR6GGBbV8F2l1zsYVflAUCXjyU2POUC_X1GT0aXdrSiPHcOVbdmTpmLmuHPC_X1E-2pEWOAT9msbbiqVmfdqIa3RG_HfUE5I69Bffx_OJj0mb89ShVowrVOuyuMYufSdps3Cz90U_zru7HkcKxW8l4GBR2u21x2r78ZAak8X0AWJO9-tAI-_lq7uTde9n3wmJo7JDYVVCiI5RTfl4eNmjQYs9J8ZwgwoIAakW1NqDI27DYraQuxslAWHLPK8nr5j42O0HfI4bV1FN-autCgjLg_bgsMjQ%26amp%3Bowa%3Doutlook.office.com%26amp%3BisImagePreview%3DTrue%22%20src%3D%22https%3A%2F%2Fattachment.outlook.office.net%2Fowa%2Fhuang.benson%40inventec.com%2Fservice.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%26amp%3Btoken%3DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6IkJnRDU5blJpQnpmbk5BVGloOFJhZ1l5M3pyZyJ9.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.qaxYVZySJYx1QE_ZEsX5P-EA3YJzdm2uvF9VrbUOXEO_I9ssi_mWH9Kv6lR6GGBbV8F2l1zsYVflAUCXjyU2POUC_X1GT0aXdrSiPHcOVbdmTpmLmuHPC_X1E-2pEWOAT9msbbiqVmfdqIa3RG_HfUE5I69Bffx_OJj0mb89ShVowrVOuyuMYufSdps3Cz90U_zru7HkcKxW8l4GBR2u21x2r78ZAak8X0AWJO9-tAI-_lq7uTde9n3wmJo7JDYVVCiI5RTfl4eNmjQYs9J8ZwgwoIAakW1NqDI27DYraQuxslAWHLPK8nr5j42O0HfI4bV1FN-autCgjLg_bgsMjQ%26amp%3Bowa%3Doutlook.office.com%26amp%3BisImagePreview%3DTrue%22%20style%3D%22max-width%3A%20525px%3B%20max-height%3A%20244px%3B%20width%3A%20100%25%3B%20cursor%3A%20pointer%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A7%BB%E6%A4%8D%E5%9F%BA%E4%BA%8Eimx8qxp%E7%9A%84360%E5%BA%A6%E7%8E%AF%E8%A7%86%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%85%B6%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA4.9.51%EF%BC%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E5%9E%8B%E5%8F%B7%E4%B8%BAap0101%2BAR0140%EF%BC%8C%E5%8F%A6%E4%B8%80%E7%BB%84%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%BAmax9286%2Bmax96705%E3%80%82%E6%88%91%E5%B7%B2%E5%B0%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8Eimx6q%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%A7%BB%E6%A4%8D%E5%88%B0imx8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E6%97%A5%E5%BF%97%E4%B8%AD%E5%B7%B2%E6%88%90%E5%8A%9F%E6%89%BE%E5%88%B0mxa9286%E5%92%8C%E5%9B%9B%E4%B8%AAap0101%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8imx6%E7%9A%84%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81'mxc_v4l2_tvin.out'%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E2%80%98%E6%9C%AA%E6%89%BE%E5%88%B0%E6%AD%A4%E6%96%87%E4%BB%B6%E2%80%99%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9Aimx6%E7%9A%84%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8Eimx8qxp%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E9%92%88%E5%AF%B9imx8%E7%9A%84%E4%BB%BB%E4%BD%95%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%EF%BC%9F%EF%BC%9F%E5%A6%82%E6%9C%89%EF%BC%8C%E8%83%BD%E5%90%A6%E4%B8%BA%E6%88%91%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%EF%BC%9F%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E6%E6%9C%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJianfeng%EF%BC%8C%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E2%80%9C%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%22335803%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%235e89c1%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%3C%2FA%3E%E2%80%9D%E4%B8%AD%E7%9A%84mxc_v4l2_tvin%EF%BC%8C%E6%88%91%E6%9C%AA%E8%83%BD%E5%A4%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9mxc_v4l2_tvin.c%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BB%A5%E6%8D%95%E8%8E%B7%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E5%B9%B6%E4%BF%9D%E5%AD%98%E5%88%B0%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E9%9A%8F%E5%90%8E%E5%9C%A8PC%E4%B8%8A%E4%BD%BF%E7%94%A8YUVPlayer%E7%AD%89%E8%BD%AF%E4%BB%B6%E6%9F%A5%E7%9C%8B%E8%AF%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BB%A5%E6%A3%80%E6%9F%A5%E6%8D%95%E8%8E%B7%E7%9A%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E%26nbsp%3Bchar%20still_file%5B100%5D%20%3D%20%22.%2Fstill.yuv%22%3B%3CBR%20%2F%3E%26nbsp%3Bint%20fd_still%20%3D%200%3B%3CBR%20%2F%3E%26nbsp%3Bif%20((fd_still%20%3D%20open(still_file%2C%20O_RDWR%20%7C%20O_CREAT%20%7C%20O_TRUNC%2C%200x0666))%20%26lt%3B%200)%3CBR%20%2F%3E%26nbsp%3B%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Bprintf(%22%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BAy%E5%B8%A7%E5%BD%95%E5%88%B6%E6%96%87%E4%BB%B6%5Cn%22)%3B%3CBR%20%2F%3E%26nbsp%3B%7D%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E...%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%26nbsp%3B%26nbsp%3Bif(i%26gt%3B100%20%26amp%3B%26amp%3B%20i%26lt%3B120)%3CBR%20%2F%3E%2F%2F%26nbsp%3B%26nbsp%3B%26nbsp%3Bwrite(fd_still%2C%20capture_buffers%5Bcapture_buf.index%5D.start%2C%20720*240*2)%3B%3C%2FP%3E%3CP%3E...%20...%3C%2FP%3E%3CP%3E%2F%2F%20%E5%85%B3%E9%97%AD(fd_still)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ehi%20liqiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFimx6q%E8%80%8C%E9%9D%9Eimx6d%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%80%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%83%E6%98%AF%E5%BA%94%E7%94%A8%E9%97%AE%E9%A2%98%E8%BF%98%E6%98%AF%E5%86%85%E6%A0%B8%E9%97%AE%E9%A2%98%EF%BC%9F%E8%AF%B7%E4%BA%88%E4%BB%A5%E5%8D%8F%E5%8A%A9%EF%BC%8C%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20liqiang%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86imx6d%EF%BC%8C%E8%80%8C%E9%9D%9Eimx6Q%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8imx6D%EF%BC%8C%E8%AF%A5%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%80%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20liqiang%2C%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E6%B5%8B%E8%AF%95%E6%96%87%E4%BB%B6%20mxc_v4l2_tvin_max9286.tar%20%E7%9A%84%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B1%8F%E5%B9%95%E5%88%86%E8%BE%A8%E7%8E%87%E6%98%AF%20800x480%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9Cmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20800%20-oh%20480%20-d%201%20-x%200%E2%80%9D%E6%97%B6%EF%BC%8C%E6%91%84%E5%83%8F%E5%A4%B4%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20905px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22728i37DD38904104B984%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1.%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9C%3CSPAN%3Emxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20400%20-oh%20240%20-d%201%20-x%200%3C%2FSPAN%3E%E2%80%9D%E6%97%B6%EF%BC%8C%E5%B1%8F%E5%B9%95%E4%BC%9A%E6%BB%9A%E5%8A%A8%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20950px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22562i380E0C90D2FAF4C3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9C%3CSPAN%3E%20mxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20800%20-oh%20480%20-d%201%20-x%200%20-g2d%E2%80%9D%E6%97%B6%EF%BC%8C%E5%B1%8F%E5%B9%95%E6%98%BE%E7%A4%BA%E9%97%AA%E7%83%81%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20974px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22616i7656661182A8D79E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E6%88%91%E4%BB%AC%E7%9F%A5%E9%81%93IMX8%20BSP%E6%94%AF%E6%8C%81MAX9286%EF%BC%8C%E4%BD%86%E4%BC%BC%E4%B9%8E%E5%8F%AA%E6%94%AF%E6%8C%81%3CSTRONG%3Ei.MX8Q%3C%2FSTRONG%3E%E3%80%82%20%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3EMAX9286%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E4%B8%8EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E5%9C%A8i.MX8Q%E8%AE%BE%E5%A4%87%E6%A0%91(fsl-imx8qm-mek.dts)%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E5%AE%83%E5%B7%B2%E9%93%BE%E6%8E%A5'fsl%2Cmxc-mipi-csi2'%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F(drivers%2Fmedia%2Fplatform%2Fimx8%2Fmxc-mipi-csi2.c)%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E4%BD%86%E5%9C%A8%3CSTRONG%3Ei.MX8M%3C%2FSTRONG%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%EF%BC%8CMIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E2%80%9Cfsl%2Cmxc-mipi-csi2_yav%E2%80%9D%EF%BC%88drivers%2Fmedia%2Fplatform%2Fimx8%2Fmxc-mipi-csi2-yav.c%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E6%AF%94%E8%BE%83%E8%BF%99%E4%B8%A4%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E4%B8%BB%E8%A6%81%E5%8C%BA%E5%88%AB%E5%9C%A8%E4%BA%8E%E7%A1%AC%E4%BB%B6%E6%93%8D%E4%BD%9C%E5%92%8CV4L2%E5%AA%92%E4%BD%93%E6%8E%A7%E5%88%B6%E6%9D%BF%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E6%88%91%E4%BB%AC%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E1.%20'fsl%2Cmxc-mipi-csi2'%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%83%BD%E5%90%A6%E5%9C%A8%3CSTRONG%3Ei.MX8M%3C%2FSTRONG%3E%E4%B8%8A%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E2.%E5%90%A6%E5%88%99%EF%BC%8C%E2%80%98fsl%2Cmxc-mipi-csi2_yav%E2%80%99%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%83%BD%E5%90%A6%E6%AD%A3%E5%B8%B8%E6%94%AF%E6%8C%81%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%EF%BC%9F%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E3.%20%E6%AD%A4%E5%A4%96%EF%BC%8C%3CSTRONG%3E%E5%A6%82%E4%BD%95%E5%9C%A8'fsl%2Cmxc-mipi-csi2_yav'%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%94%AF%E6%8C%81%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E5%8A%9F%E8%83%BD%EF%BC%9F%3C%2FSTRONG%3E%EF%BC%88i.MX8M%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E5%85%B3%E4%BA%8EMIPI%20CSI2%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E7%9A%84%E4%BF%A1%E6%81%AF%E4%B8%8D%E8%B6%B3%EF%BC%89%EF%BC%9F%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%23545454%3B%20background-color%3A%20%23ffffff%3B%22%3ELI-USB30-OV10635-SER%E9%80%9A%E8%BF%87usb%203.0%E8%BF%9E%E6%8E%A5%E5%88%B0PC%EF%BC%8C%E5%B7%A5%E5%85%B7%E4%B8%8A%E7%9A%84%E6%8D%95%E8%8E%B7%E6%98%BE%E7%A4%BA%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AE%A4%E4%B8%BAov10635%E6%A8%A1%E5%9D%97%E5%A4%84%E4%BA%8E%E6%AD%A3%E5%B8%B8%E7%8A%B6%E6%80%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23545454%3B%20background-color%3A%20%23ffffff%3B%22%3Emax9286%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%EF%BC%8Cmax9286%20%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20I2C%20%E8%AE%BF%E9%97%AE%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20I2C%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%91%E4%BB%AC%E5%AF%B9%3CSPAN%3Emax9286%E5%92%8Cmax96705%E7%9A%84%3C%2FSPAN%3E%E9%85%8D%E7%BD%AE%E5%AD%98%E6%9C%89%E7%96%91%E9%97%AE%EF%BC%8C%E8%BF%99%E4%B8%80%E7%BB%84%E5%90%88%E8%83%BD%E5%90%A6%E5%9C%A8imx8x%204.9.51%E7%89%88%E6%9C%AC%E4%B8%AD%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E6%88%91%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9C%A8imx8x%E4%B8%8A%E4%BD%BF%E7%94%A8max9286%E5%92%8Cmax96705%2Bov10635%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%EF%BC%8C%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA4.9.51%EF%BC%8C%E6%AD%A4%E7%89%88%E6%9C%AC%E6%9C%89%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%204.9.51%20%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%20max9286%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8A%A0%E8%BD%BD%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3Eov10635%E4%BC%BC%E4%B9%8E%E5%87%BA%E7%8E%B0I2C%E9%80%9A%E4%BF%A1%E6%95%85%E9%9A%9C%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86max9286%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84I2C%E6%8E%A5%E5%8F%A3%E6%88%90%E5%8A%9F%E9%80%9A%E4%BF%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.525043%5D%20mxc-mipi-csi2%2058227000.csi%3A%20mipi_csi2_probe%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.549343%5D%20mxc-mipi-csi2%2058227000.csi%3A%20lanes%3A%204%2C%20name%3A%20mxc-mipi-csi2.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.556705%5Dmax9286_mipi%200-006a%EF%BC%9A%E5%9C%A8max9286_hardware_preinit()%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.854197%5Dmax9286_mipi%3A%20reg%20%3D%200xf0.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.857870%5Dmax9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%204.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.862158%5Dmax9286_mipi%200-006a%EF%BC%9A%E5%9C%A8max9286_hardware_init()%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B2.893273%5Dmax9286_mipi%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BC%A0%E6%84%9F%E5%99%A8%20%3D%200x01.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B2.921271%5Dmax9286_mipi%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BC%A0%E6%84%9F%E5%99%A8%20%3D%200x02.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.949272%5Dmax9286_mipi%3A%20%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BC%A0%E6%84%9F%E5%99%A8%20%3D%200x03.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%202.977271%5Dmax9286_mipi%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BC%A0%E6%84%9F%E5%99%A8%20%3D%200x04.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.145279%5Dmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9Areg%3D0x300a.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.152433%5Dmax9286_mipi%200-006a%3A%20ov10635_check_device%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0OV10635%EF%BC%8Creg%5B0x300a%5D%20%3D%200x0.%2C%20%E7%B4%A2%E5%BC%95%3D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.321275%5Dmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9Areg%3D0x300a.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.328419%5Dmax9286_mipi%200-006a%3A%20ov10635_check_device%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0OV10635%EF%BC%8Creg%5B0x300a%5D%20%3D%200x0%EF%BC%8C%E7%B4%A2%E5%BC%95%3D2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.497275%20%5Dmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9Areg%3D0x300a.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.504421%5Dmax9286_mipi%200-006a%EF%BC%9Aov10635_check_device%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0OV10635%EF%BC%8Creg%5B0x300a%5D%20%3D%200x0.%EF%BC%8C%E7%B4%A2%E5%BC%95%3D3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B3.673275%5Dmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9Areg%3D0x300a.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%203.680420%5Dmax9286_mipi%200-006a%3A%20ov10635_check_device%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0OV10635%EF%BC%8Creg%5B0x300a%5D%20%3D%200x0.%2C%20%E7%B4%A2%E5%BC%95%3D4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%204.752679%20%5Dmax9286_mipi%200-006a%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0max9286_mipi%EF%BC%8C%E5%90%8D%E7%A7%B0%E4%B8%BAmax9286_mipi%200-006a%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E7%9C%8B%E7%9C%8B%E5%93%AA%E4%B8%AA%E9%83%A8%E4%BB%B6%E7%9A%84%E9%94%99%E8%AF%AF%E4%BC%9A%E5%AF%BC%E8%87%B4ov10635%E8%AE%BF%E9%97%AE%E5%A4%B1%E8%B4%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E4%BF%A1%E6%81%AF%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%81%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AACSI2%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E8%83%BD%E5%90%A6%E5%B0%86%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%88%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%97%B6%E9%92%9F%E5%AF%B9%EF%BC%9F%EF%BC%89%EF%BC%8C%E8%BF%98%E6%98%AF%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E4%BF%A1%E5%8F%B7%E8%81%9A%E5%90%88%E5%99%A8%E5%B0%86%E6%91%84%E5%83%8F%E5%A4%B4%E5%90%88%E5%B9%B6%E4%B8%BA%E4%B8%80%E4%B8%AA%E6%8E%A5%E5%8F%A3%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20li%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20max9286%20%E5%92%8C%20max96705%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E8%BF%9E%E6%8E%A5%E4%B8%8D%E5%A4%AA%E7%A8%B3%E5%AE%9A%EF%BC%8C%E6%9C%89%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E2%80%9Cmipi%20csi2%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F%E2%80%A6%E2%80%9D%20%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E6%89%80%E6%9C%89%E9%85%8D%E7%BD%AE%E5%9D%87%E5%B7%B2%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E8%A1%A5%E4%B8%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-390480%2FL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%22%20target%3D%22_blank%22%3E%3CSTRONG%20style%3D%22color%3A%20%235e89c1%3B%22%3EL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3C%2FSTRONG%3E%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%A1%A5%E4%B8%81%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%82%A8%E9%85%8D%E7%BD%AE%E4%BA%86max9286%E5%AF%84%E5%AD%98%E5%99%A80x3f%200x3b%EF%BC%8C%E4%BD%86%E6%88%91%E6%9C%AA%E8%83%BD%E6%89%BE%E5%88%B0%E5%85%B3%E4%BA%8E%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BB%8B%E7%BB%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%E5%BC%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%83%E6%95%B4%20TI%20%E8%AE%BE%E7%BD%AE%E5%90%8E%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E6%8E%A5%E6%94%B6%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E5%AF%B9%E4%BA%8E1%2F2%2F3%E5%8F%B7%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E6%8E%A5%E6%94%B6%E5%88%B0%E5%83%8F%E7%B4%A0%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%AF%B9%E4%BA%8E4%E4%B8%AA%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%83%8F%E7%B4%A0%E6%95%B0%E6%8D%AE%E5%AD%98%E5%9C%A8%E7%BA%BF%E8%B7%AF%E6%8D%9F%E5%9D%8F%EF%BC%88%E8%A7%81%E4%B8%8B%E5%9B%BE%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F28151iDC414904E44DC5E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error_2.png%22%20alt%3D%22error_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8TI%E7%AB%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E6%95%B0%E9%87%8F%E5%92%8C%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E9%80%9F%E7%8E%87%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E9%80%9F%E7%8E%87%E5%8F%AA%E6%9C%89%E4%B8%89%E4%B8%AA%E9%80%89%E9%A1%B9%EF%BC%88400M%E3%80%81800M%E3%80%811.6G%EF%BC%89%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%E4%B8%8D%E5%90%8C%E7%9A%84%E9%80%9F%E7%8E%87%2B%E9%80%9A%E9%81%93%E6%95%B0%E9%87%8F%EF%BC%8C1%2F2%2F3%E5%8F%B7%E4%BC%A0%E6%84%9F%E5%99%A8%E5%9D%87%E5%8F%AF%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E4%E4%B8%AA%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%8F%AA%E6%9C%89800M%2B4%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E6%95%B0%E6%8D%AE%E5%AD%98%E5%9C%A8%E9%83%A8%E5%88%86%E6%8D%9F%E5%9D%8F%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FP%3E%3CP%3E1%EF%BC%89%E5%AF%B9%E4%BA%8Eimx6%20mipi%20csi2%E6%8E%A5%E6%94%B6%E5%99%A8%EF%BC%8C%E9%80%9F%E7%8E%87%E5%92%8C%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E8%AE%BE%E7%BD%AE%E6%9C%89%E4%BB%80%E4%B9%88%E7%89%B9%E6%AE%8A%E8%A6%81%E6%B1%82%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E2)%20%E5%AF%B9%E4%BA%8E%20IMX6%20MIPI%20CSI%EF%BC%8C%E5%AE%9E%E9%99%85%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87%E4%B8%8E%E6%80%BB%E6%95%B0%E6%8D%AE%E5%A4%84%E7%90%86%E8%83%BD%E5%8A%9B%E4%B9%8B%E9%97%B4%E7%9A%84%E5%90%88%E9%80%82%E6%AF%94%E4%BE%8B%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3CP%3E2%EF%BC%89%E6%9C%89%E4%BD%95%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMustafa%EF%BC%8C%E6%82%A8%E5%A5%BD%E3%80%82%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E8%AF%A6%E8%A7%81MIPI%20CSI2%E8%A7%84%E8%8C%83%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19379i48079F224D67B17C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20593px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19241iFEA60F46F5860C8A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.jpg%22%20style%3D%22width%3A%20506px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19291i0F83D65DC84678B0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.jpg%22%20alt%3D%223.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Flionwei%22%20target%3D%22_blank%22%3Elionwei%3C%2FA%3E%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%26nbsp%3B%3B%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AEiMX6%20CSI2IPU%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%88%9B%E5%BB%BA%E7%9F%AD%E4%BB%A3%E7%A0%81%E5%8C%85%E6%88%96%E9%95%BF%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E5%90%8C%E6%97%B6%E8%BF%98%E9%9C%80%E8%A6%81%E4%BC%A0%E8%BE%93%E5%BC%80%E5%A7%8B%E4%BB%A3%E7%A0%81%E5%8C%85%E5%92%8C%E4%BC%A0%E8%BE%93%E7%BB%93%E6%9D%9F%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20527px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18280i3186E2657EDB4F66%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%8F%91%E9%80%81%E8%BF%99%E4%BA%9B%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%9F%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%E6%91%84%E5%83%8F%E5%A4%B4%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E8%AF%A5%E4%BB%A3%E7%A0%81%E5%8C%85%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%E5%B9%B6%E5%8F%91%E9%80%81%E8%BF%99%E4%BA%9B%E6%95%B0%E6%8D%AE%E7%B1%BB%E5%9E%8B%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%E8%BF%99%E4%BA%9B%E5%80%BC%E5%AE%9A%E4%B9%89%E5%88%B0%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9FSoT%E5%92%8CEoT%E4%BB%A3%E7%A0%81%E5%8C%85%E7%9A%84%E6%A0%BC%E5%BC%8F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20588px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18334iAD0E1FA2A7D1B2FE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E7%BB%99%E6%88%91%E4%B8%BE%E4%B8%AA%E4%BE%8B%E5%AD%90%E5%90%97%EF%BC%9F%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%8A%AA%E5%8A%9B%E8%A7%A3%E5%86%B3csi2%E6%A0%BC%E5%BC%8Fmipi%E6%97%B6%E9%92%9F%E5%92%8C%E6%95%B0%E6%8D%AE%E9%80%9A%E9%81%93%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%863%E5%91%A8%E4%BB%A5%E6%9D%A5%E6%88%91%E9%83%BD%E6%97%A0%E6%B3%95%E5%AE%9A%E4%B9%89iMX6Q%E5%A4%84%E7%90%86%E5%99%A8%E5%AE%9A%E5%88%B6%E6%9D%BF%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%E5%BC%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E7%A1%AC%E4%BB%B6%E5%9C%A8linux%203.14.52%E4%B8%8B%E5%AE%9E%E7%8E%B0%E7%B1%BB%E4%BC%BC%E7%9A%84%E7%8E%AF%E8%A7%86%E5%8A%9F%E8%83%BD%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%20DS90ub964-q%20%26lt%3B-----%26gt%3B%20imx6q%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%20%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%A1%A5%E4%B8%81%E4%B8%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%87%A0%E4%B9%8E%E7%9B%B8%E5%90%8C%3CBR%20%2F%3E%E7%9B%AE%E5%89%8D%EF%BC%8Cmipi-csi2%20%E8%83%BD%E5%A4%9F%E6%88%90%E5%8A%9F%E6%A3%80%E6%B5%8B%E5%88%B0%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8Cmipi-csi2%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E4%B8%8A%E7%9A%84%E6%B3%A2%E5%BD%A2%E4%BC%BC%E4%B9%8E%E4%B9%9F%E6%AD%A3%E7%A1%AE%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E6%91%84%E5%83%8F%E5%A4%B40-2%E7%9A%84camera_callback%EF%BC%8C%E5%8F%AA%E8%83%BD%E6%8E%A5%E6%94%B6%E6%91%84%E5%83%8F%E5%A4%B43%E7%9A%84camera_callback%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E9%98%85%E8%AF%BB%E4%B8%8A%E8%BF%B0%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%EF%BC%8C%E4%BD%86%E6%89%BE%E4%B8%8D%E5%88%B0%E7%B1%BB%E4%BC%BC%E7%9A%84%E5%8E%9F%E5%9B%A0%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E6%A3%80%E6%9F%A5%E4%BB%A5%E4%B8%8B%E4%BA%8B%E9%A1%B9%3CBR%20%2F%3E1%EF%BC%89MIPI_IPU1_MUX%20%E5%92%8C%20MIPI_IPU2_MUX%20%E5%9C%A8%20mipi_csi%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%3CBR%20%2F%3E2%EF%BC%89%E5%AF%84%E5%AD%98%E5%99%A8%E8%BD%AC%E5%82%A8%EF%BC%9A%3CBR%20%2F%3EIPU1_CSI0_SENSE_CONF(0x2630000)%EF%BC%9A0x04008a00%3CBR%20%2F%3EIPU1_CSI1_SENSE_CONF(0x2638000)%EF%BC%9A0x04008a00%3CBR%20%2F%3EIPU2_CSI0_SENSE_CONF(0x2a30000)%EF%BC%9A0x04008a00%3CBR%20%2F%3EIPU2_CSI1_SENSE_CONF(0x2a38000)%EF%BC%9A0x04008a00%3C%2FP%3E%3CP%3EIPU1_IDMAC_CH_EN_1(0x2608004)%3A%200x00000003%3CBR%20%2F%3EIPU1_IDMAC_CH_EN_2(0x2608008)%3A%200x00000000%3CBR%20%2F%3EIPU2_IDMAC_CH_EN_1(0x2a08004)%3A%200x00800003%3CBR%20%2F%3EIPU2_IDMAC_CH_EN_2(0x2a08008)%3A%200x00000000%3C%2FP%3E%3CP%3EIPU1_IDMAC_CH_BUSY_1(0x2608100)%3A%200x00000003%3CBR%20%2F%3EIPU2_IDMAC_CH_BUSY_1(0x2a08100)%3A%200x00800002%3C%2FP%3E%3CP%3EIPU1_SMFC_MAP(0x2650000)%3A%200x00000020%3CBR%20%2F%3EIPU2_SMFC_MAP(0x2a50000)%3A%200x00000020%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3CBR%20%2F%3E1)%20%E8%BF%99%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84smfc%E5%92%8C%20idmac%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3CBR%20%2F%3E2)%20%E6%A0%B9%E6%8D%AE%E8%A7%84%E6%A0%BC%EF%BC%8Cipu%20mipi%E5%BA%94%E9%87%87%E7%94%A8%E9%9D%9E%E9%97%A8%E6%8E%A7%E6%A8%A1%E5%BC%8F%EF%BC%8C%E4%BD%86mxc_v4l2_capture.c%E5%9C%A8mxc_v4l2_s_param%E4%B8%AD%E9%87%87%E7%94%A8%E9%97%A8%E6%8E%A7%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E5%93%AA%E7%A7%8D%E6%A8%A1%E5%BC%8F%EF%BC%88%E6%88%91%E5%B7%B2%E5%B0%9D%E8%AF%95%E8%BF%99%E4%B8%A4%E7%A7%8D%E6%A8%A1%E5%BC%8F%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BB%AC%E9%83%BD%E4%B8%8D%E9%80%82%E5%90%88%EF%BC%89%3CBR%20%2F%3E3)%20%E5%93%AA%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E6%88%91%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AEhsync_pol%E5%92%8Cvsync_pol%EF%BC%9F%3CBR%20%2F%3E4)%20%E9%92%88%E5%AF%B9%E6%AD%A4%E9%97%AE%E9%A2%98%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E5%87%BA%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E7%A5%9D%E6%82%A8%E5%81%87%E6%9C%9F%E6%84%89%E5%BF%AB%E3%80%82%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E5%87%BA%E4%BA%86%E7%82%B9%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%82%E8%80%83sabresd%E5%92%8Cmax9286%2Bmax96705%2Bap%200101%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%BA%863.14.52%20BSP%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%9D%87%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%B5%8B%E8%AF%95%E5%91%BD%E4%BB%A4%E4%B8%AD%E4%BD%BF%E7%94%A8'-g2d'%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E2%80%9C%E6%AE%B5%E7%A0%81%E6%95%85%E9%9A%9C%E2%80%9D%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%8F%AF%E8%83%BD%E8%AF%B4%E6%98%8E%E6%88%91%E7%9A%84GPU%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%E5%85%B7%E4%BD%93%E6%97%A5%E5%BF%97%E8%AE%B0%E5%BD%95%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Eroot%40imx6qdlsolo%EF%BC%9A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%200%20-x%200%20%3CBR%20%2F%3E------------------------------%E8%BF%99%E6%98%AFAP0101--------------------------------%3CBR%20%2F%3Emax9286_mipi%EF%BC%9A%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%204.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%EF%BC%9Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20594%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%EF%BC%9A%E5%80%BC%20%3D%200x2e.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%20%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E5%B1%9E%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%203.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%204.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E5%B1%9E%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20BG.%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E8%83%8C%E6%99%AF%E5%B1%8F%E5%B9%95%EF%BC%8C%E4%BB%85%E6%94%AF%E6%8C%81%E5%85%A8%E5%B1%8F%E9%BB%98%E8%AE%A4%E6%A0%BC%E5%BC%8F%E3%80%82%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x25600000%2C%20smem_len%20%3D%200x546000.%3CBR%20%2F%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x1c2000%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%201280.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20720.%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201449238585%E7%A7%92%EF%BC%8C124037%E5%BE%AE%E7%A7%92%3CBR%20%2F%3E%5EC%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_dqueue()%20%E6%8E%A5%E6%94%B6%E5%88%B0%E4%B8%AD%E6%96%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6qdlsolo%EF%BC%9A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%200%20-x%200%20-g2d%3CBR%20%2F%3E------------------------------%E8%BF%99%E6%98%AFAP0101--------------------------------%3CBR%20%2F%3Emax9286_mipi%EF%BC%9A%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%204.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%EF%BC%9A.mipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20594%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%EF%BC%9A%E5%80%BC%20%3D%200x2e.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%20%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E5%B1%9E%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%203.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%204.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E5%B1%9E%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20BG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x25600000%2C%20smem_len%20%3D%200x546000.%3CBR%20%2F%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x1c2000%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20960.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20540.%3CBR%20%2F%3E%E6%AE%B5%E7%A0%81%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E6%E6%9C%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Yu%20fe%2C%3C%2FP%3E%3CP%3E%E6%AD%A4%E9%94%99%E8%AF%AF%E8%A1%A8%E7%A4%BAMAX9286%E6%97%A0%E6%B3%95%E6%A3%80%E6%B5%8B%E5%88%B0%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E6%A3%80%E6%9F%A5MAX9286%E4%B8%8EMAX96705%E4%B9%8B%E9%97%B4%E7%9A%84%E7%A1%AC%E4%BB%B6%E4%BF%A1%E5%8F%B7%E5%92%8C%E7%94%B5%E6%BA%90%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%AE%9A%E5%88%B6%E5%BC%80%E5%8F%91%E6%9D%BF%E5%8F%82%E8%80%83saresd%E3%80%81max9286%2Bmax96705%2Bap010%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84yocto%E7%89%88%E6%9C%AC%E6%98%AF3.14.52%EF%BC%8C%E4%BF%AE%E8%A1%A5%E5%86%85%E6%A0%B8%E5%90%8E%E6%94%B6%E5%88%B0%E5%A6%82%E4%B8%8B%E6%B6%88%E6%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epr_info(%22max9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%20%25d.%5Cn%22%2Cg_sensor_num)%3B%3C%2FP%3E%3CP%3Eif%20(g_sensor_num%20%3D%3D%200)%20%7B%3CBR%20%2F%3E%20pr_err(%22%25s%3A%20%E6%9C%AA%E8%BF%9E%E6%8E%A5%E6%91%84%E5%83%8F%E5%A4%B4.%5Cn%22%2C%20__func__)%3B%3CBR%20%2F%3E%20return%20-1%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E6%9F%A5%E6%89%BE%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%82%A8%E5%9C%A81280*720%E5%B8%A7%E4%B8%8A%E4%BD%BF%E7%94%A8IPU%E8%BF%9B%E8%A1%8CCSC%E6%97%B6%EF%BC%8CIPU%E8%BF%87%E8%BD%BD%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4IPU%E6%97%A0%E6%B3%95%E5%8F%8A%E6%97%B6%E5%A4%84%E7%90%86%E6%8D%95%E8%8E%B7%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%A6%81%E6%94%B9%E8%BF%9B%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8IDMAC%200%E5%92%8CIDMAC%202%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%80%E6%9C%89FIFO%E5%9D%87%E5%8F%AF%E7%94%A8%E4%BA%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29543i5665BB537284462F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8ipu_common.c%E4%B8%AD%EF%BC%8C%E5%87%BD%E6%95%B0ipu_probe()%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%89%80%E6%9C%89CSI-%26gt%3BMEM%E9%80%9A%E9%81%93%E5%9D%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%AB%98%E4%BC%98%E5%85%88%E7%BA%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%2F*%20%E8%AE%BE%E7%BD%AE%E5%90%8C%E6%AD%A5%E5%88%B7%E6%96%B0%E9%80%9A%E9%81%93%E5%92%8CCSI-%26gt%3B%E5%86%85%E5%AD%98%E9%80%9A%E9%81%93%E4%B8%BA%E9%AB%98%E4%BC%98%E5%85%88%E7%BA%A7%20*%2F-%20ipu_idmac_write(ipu%2C%200x18800003L%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FP%3E%3CP%3E%2B%20ipu_idmac_write(ipu%2C%200x1880000FL%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Brave%2C%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%94%99%E8%AF%AF%E8%A1%A8%E7%A4%BAIMX6%E6%9C%AA%E6%8E%A5%E6%94%B6%E5%88%B0%E6%9C%89%E6%95%88%E7%9A%84MIPI%20CSI2%E4%BF%A1%E5%8F%B7%E3%80%82%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%82%A8%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%E6%A8%A1%E5%9D%97%E4%B8%AD%E5%AD%98%E5%9C%A8%E9%97%AA%E5%85%89%E7%81%AF%E3%80%82%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E9%97%AA%E5%85%89%E7%81%AF%E8%AE%BE%E7%BD%AE%E5%BA%94%E4%B8%8Emax9286.c%E4%B8%AD%E7%9A%84AP0101%E8%AE%BE%E7%BD%AE%E4%BF%9D%E6%8C%81%E4%B8%80%E8%87%B4%EF%BC%8C%E6%91%84%E5%83%8F%E5%A4%B4%E5%BA%94%E8%83%BD%E5%9C%A8%E5%B8%A7%E5%90%8C%E6%AD%A5%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3EMax9286%E4%B8%8A%E6%9C%89%E4%B8%80%E4%B8%AA%E9%94%81%E5%AE%9A%E5%BC%95%E8%84%9A%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%BD%93%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E4%BB%A5%E5%B8%A7%E5%90%8C%E6%AD%A5%E6%A8%A1%E5%BC%8F%E8%BF%90%E8%A1%8C%E4%B8%94%E7%94%B1MAX9286%E9%94%81%E5%AE%9A%E6%97%B6%EF%BC%8C%E6%89%8D%E4%BC%9A%E5%90%91iMX6%E8%BE%93%E5%87%BA%E6%9C%89%E6%95%88%E7%9A%84MIPI%20CSI2%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%90%8C%E6%AD%A5MAX9296%20%2B%204%2096705%20%2B4%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%A4%E4%BD%8D%E5%AE%A2%E6%88%B7%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8IMX.6%20%2B%20MAX9268%20%2B%204%E4%B8%AAMAX96705---%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%82%E8%83%BD%E5%90%A6%E5%BB%BA%E8%AE%AE%E5%A6%82%E4%BD%95%E5%90%8C%E6%AD%A5%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116569%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116569%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3Ehello%20yu%20%26nbsp%3B%EF%BC%9A%20%26nbsp%3B%E8%83%BD%E5%90%A6%E5%B0%86l3.0.35%E7%9A%84%E8%A1%A5%E4%B8%81%E7%BB%99%E6%88%91%E4%B8%80%E4%BB%BD%EF%BC%8C%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3A455030349%40qq.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E455030349%40qq.com%3C%2FA%3E%3CSPAN%3E%E3%80%82%E6%84%9F%E6%BF%80%E4%B8%8D%E5%B0%BD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%2C%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E4%BD%BF%E7%94%A8grecorder%E5%B7%A5%E5%85%B7%E6%97%B6%E9%9C%80%E8%A6%81%E5%B0%86%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA4%20(UYVY)%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8h.264%EF%BC%8C%3C%2FP%3E%3CP%3E.%2Fmxc_vpu_test.out%20-E%20%22-x%200%20-f%200%20-c%201800%20-a%2030%20-w%201280%20-h%20792%20-o%20ss.mp4%20-l%200%20-b%205204%22%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E7%94%B5%E8%84%91%E4%B8%8A%E6%92%AD%E6%94%BEss.mp4%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E5%BC%82%E5%B8%B8%EF%BC%8C%E7%B3%BB%E7%BB%9F%E6%98%BE%E7%A4%BA%E8%AF%A5mp4%E6%96%87%E4%BB%B6%E5%A4%B4%E7%BC%BA%E5%A4%B1%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E4%BD%BF%E7%94%A8H.264%E5%BD%95%E5%83%8F%E6%9C%BA%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E6%97%B6%E5%88%9B%E5%BB%BAmp4%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Li%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8VPU%E6%9D%A5%E7%BC%96%E7%A0%81%E6%91%84%E5%83%8F%E5%A4%B4%E6%95%B0%E6%8D%AE%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8MJPEG%E6%A0%BC%E5%BC%8F%EF%BC%8C%E4%B8%8D%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E6%A0%87%E5%87%86%EF%BC%88%E5%A6%82H.263%E3%80%81H.264%EF%BC%89%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%AF%A5%E6%96%87%E4%BB%B6%E5%A4%AA%E5%A4%A7%EF%BC%8C100%E5%B8%A7%E5%B0%86%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E5%A4%A7%E7%BA%A611M%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E7%BC%A9%E5%B0%8FMJPEG%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20li%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8gstreamer%E8%AE%B0%E5%BD%954%E9%80%9A%E9%81%93%E6%91%84%E5%83%8F%E5%A4%B4%E6%95%B0%E6%8D%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%26nbsp%3B%20%40%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22285749%22%20data-username%3D%22zhanghongliang%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fzhanghongliang%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%20large%3B%22%3Ezhang%20hongliang%3C%2FSPAN%3E%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E5%B0%86%E5%9B%9B%E4%B8%AA%E7%8B%AC%E7%AB%8B%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%95%B0%E6%8D%AE%E6%95%B4%E5%90%88%E5%88%B0ipu%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E4%BB%A5%E4%BE%BF%E7%94%A8%E6%88%B7%E8%B0%83%E7%94%A8%E4%B8%80%E6%AC%A1DQBUF%E5%8D%B3%E5%8F%AF%E8%8E%B7%E5%8F%96%E5%9B%9B%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E6%89%80%E6%9C%89%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcn.bing.com%2Fdict%2Fclientsearch%3Fmkt%3Dzh-CN%26amp%3BsetLang%3Dzh%26amp%3Bform%3DBDVEHC%26amp%3BClientVer%3DBDDTV3.5.1.4320%26amp%3Bq%3D%25E4%25BD%25A0%25E6%259C%2589%25E4%25BB%2580%25E4%25B9%2588%25E5%25BB%25BA%25E8%25AE%25AE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%E6%9C%89%E4%BD%95%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcn.bing.com%2Fdict%2Fclientsearch%3Fmkt%3Dzh-CN%26amp%3BsetLang%3Dzh%26amp%3Bform%3DBDVEHC%26amp%3BClientVer%3DBDDTV3.5.1.4320%26amp%3Bq%3D%25E4%25BD%25A0%25E6%259C%2589%25E4%25BB%2580%25E4%25B9%2588%25E5%25BB%25BA%25E8%25AE%25AE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%E5%BB%BA%E8%AE%AE%3C%2FSPAN%3E%3C%2FA%3E%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20style%3D%22width%3A%20881px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18582iEB0FC3DC4D6CDAFB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18633iE8789A0170FAC82D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%3C%2FDIV%3E%3CDIV%3E%E7%9B%B8%E6%9C%BA%E6%AD%A3%E5%9C%A8%E5%90%8C%E6%AD%A5%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%9C%89%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%BF%9E%E6%8E%A5%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%9A%3C%2FDIV%3E%3CDIV%3Emax9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%202.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20336%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20%E5%80%BC%20%3D%200x2a.%3CBR%20%2F%3Emax9286_mipi%201-006a%EF%BC%9Aap0101_initialize%EF%BC%9AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%EF%BC%9Aap0101_initialize%EF%BC%9AAP0101%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3Emax9286_mipi%201-006a%EF%BC%9Aap0101_initialize%EF%BC%9AAP0101%E5%B7%B2%E6%89%BE%E5%88%B0%EF%BC%8C%E7%B4%A2%E5%BC%95%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%EF%BC%9Aap0101_initialize%EF%BC%9AAP0101%20%E5%B7%B2%E5%A4%84%E4%BA%8E%E4%BB%8E%E6%9C%BA%EF%BC%88%E5%BF%AB%E9%97%A8%E5%90%8C%E6%AD%A5%EF%BC%89%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%8E%B7%E5%8F%96%E5%9B%BE%E5%83%8F%E6%97%B6%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%87%BA%E7%8E%B0%E5%BC%82%E5%B8%B8%EF%BC%8C%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18547iB356B38924454BFE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20style%3D%22width%3A%20712px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18602iA829D84D887281A4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9Fg_sensor_num%20%3D%202%26nbsp%3B%20%E9%80%9A%E9%81%93%26nbsp%3B%3D%203%3C%2FDIV%3E%3CDIV%3Emipi_csi2_reset(mipi_csi2_info%2C%20(672*%20g_sensor_num)%20%2F%20(%E9%80%9A%E9%81%93%E6%95%B0%20%2B%201))%3B%3C%2FDIV%3E%3CDIV%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9B%AE%E5%89%8D%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFBSP%203.10.53%EF%BC%8Cmax9286%2Bmax96707%2BISX016%3C%2FP%3E%3CP%3E%E5%BD%93%E8%BF%9E%E6%8E%A5%E4%B8%80%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%8E%B7%E5%8F%96%E5%9B%BE%E5%83%8F%EF%BC%8C%E4%BD%86%E5%BD%93%E8%BF%9E%E6%8E%A5%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%B6%EF%BC%8C%E6%88%91%E6%80%BB%E6%98%AF%E6%94%B6%E5%88%B0%E2%80%9Cmipi%20csi2%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F%EF%BC%81MIPI_CSI_PHY_STATE%20%3D%200x6f0%E2%80%9D%E7%9A%84%E9%94%99%E8%AF%AF%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-390480%2FL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%22%20target%3D%22_blank%22%3E%3CSTRONG%20style%3D%22color%3A%20%235e89c1%3B%22%3EL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3C%2FSTRONG%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x40%2C%200x2F)%3B%3CBR%20%2F%3E%20msleep(2)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x97%2C%200x5F)%3B%3C%2FP%3E%3CP%3E....%3C%2FP%3E%3CP%3Emax9286_write_reg(0x01%2C%200x00)%3B%3CBR%20%2F%3E%20max9286_write_reg(0x63%2C%200x00)%3B%3CBR%20%2F%3E%20max9286_write_reg(0x64%2C%200x00)%3B%3C%2FP%3E%3CP%3Emax9286_write_reg(0x06%2C%200x00)%3B%3CBR%20%2F%3E%20max9286_write_reg(0x07%2C%200x00)%3B%3CBR%20%2F%3E%20max9286_write_reg(0x08%2C%200x26)%3B%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3Emipi_csi2_reset(mipi_csi2_info%2C%20(576%20*%20g_sensor_num)%20%2F%20(%E9%80%9A%E9%81%93%E6%95%B0%20%2B%201))%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%8F%82%E8%80%83%E5%AE%A2%E6%88%B7MIPI%E4%BC%A0%E6%84%9F%E5%99%A8%E8%B0%83%E8%AF%95%E6%AD%A5%E9%AA%A4.docx%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E6%88%91%E7%9A%84%E7%96%91%E9%97%AE%E6%98%AF%EF%BC%8C%E5%A6%82%E4%BD%95%E7%A1%AE%E8%AE%A4hsp_clk%E5%92%8Cccm_pixel_clkm%EF%BC%8C%E4%BB%A5%E5%8F%8A%3CSPAN%20style%3D%22font-size%3A%20medium%3B%22%3Ehsp_clk%E5%92%8Cccm_pixel_clkm%3C%2FSPAN%3E%E7%9A%84%E9%85%8D%E7%BD%AE%E5%8C%BA%E5%9F%9F%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E5%85%B3%E4%BA%8EMAX9286%EF%BC%88%3CSPAN%20style%3D%22color%3A%20%23231f20%3B%20font-family%3A%20ArialMT%3B%20font-size%3A%209pt%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%22%3E%E5%AF%84%E5%AD%98%E5%99%A80x31%E4%B8%AD%E7%9A%84FSYN%20CLOCKED%3C%2FSPAN%3E%EF%BC%89%EF%BC%8C%E8%AF%BB%E5%8F%96%E6%97%B6%E6%89%80%E7%A4%BA%E8%AF%BB%E6%95%B0%E4%B8%BA0x0%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%A4%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%3CSPAN%20style%3D%22color%3A%20%23231f20%3B%20font-family%3A%20ArialMT%3B%20font-size%3A%209pt%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%22%3EFSYNC%20LOCKED%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F%E5%90%97%EF%BC%9F%3CBR%20style%3D%22text-transform%3A%20none%3B%20line-height%3A%20normal%3B%20text-indent%3A%200px%3B%20letter-spacing%3A%20normal%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20word-spacing%3A%200px%3B%20white-space%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-size-adjust%3A%20auto%3B%20-webkit-text-stroke-width%3A%200px%3B%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E8%B0%A2%E8%B0%A2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELi%EF%BC%8C%E6%82%A8%E5%A5%BD%E3%80%82%E5%BD%93%E6%88%91%E6%9E%84%E5%BB%BABSP%20L3.14.52.1.1%E6%97%B6%EF%BC%8C%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E7%BB%99%E4%BA%88%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3Ebitback%20fsl-image-gui%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20style%3D%22width%3A%20992px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3302i28168E5CE22CB08C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82OV10635%20%E6%9D%BF%E4%B8%8A%E6%B2%A1%E6%9C%89%E9%97%AA%E5%AD%98ROM%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AFFSIN%E3%80%81HRFE%E5%92%8CVSYNC%E7%9A%84%E6%B3%A2%E5%BD%A2%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8EOV10635%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E3%80%82%E6%88%91%E7%9A%84OV10635%E7%94%9F%E4%BA%A7%E4%BA%8E2014%E5%B9%B4%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%9C%A82014%E5%B9%B4%E7%89%88%E6%9C%AC%E7%9A%84%E8%8A%AF%E7%89%87%E4%B8%8A%E6%B5%8B%E8%AF%95%E8%BF%87%E8%AF%A5%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS1.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2374iD859654232EAC2D4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FSIN-VS1.JPG%22%20alt%3D%22FSIN-VS1.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS2.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS2.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2415iEEFFB224294A9992%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FSIN-VS2.JPG%22%20alt%3D%22FSIN-VS2.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSTRONG%3E%E6%B3%A8%E9%87%8A%EF%BC%9A%E9%BB%84%E8%89%B2%E4%B8%BAFSIN%EF%BC%8C%E8%93%9D%E8%89%B2%E4%B8%BAVSYNC%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS1.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2459i7C23CEC4E4A8ED79%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22HREF-VS1.JPG%22%20alt%3D%22HREF-VS1.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS2.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS2.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2498i825C64F8793FA088%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22HREF-VS2.JPG%22%20alt%3D%22HREF-VS2.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%A4%87%E6%B3%A8%EF%BC%9A%E9%BB%84%E8%89%B2%E6%98%AFHREF%EF%BC%8C%E8%93%9D%E8%89%B2%E6%98%AFVSYNC%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E5%9C%A8I.MX6qp-sabreauto%E4%B8%8A%E6%B5%8B%E8%AF%95%E4%BA%86HD%20720p%E9%9F%B3%E9%A2%91%E8%A7%86%E5%9B%BE%E8%A1%A5%E4%B8%81%E3%80%82%E4%BD%86%E7%9B%AE%E5%89%8D%E6%88%91%E4%BB%AC%E5%9F%BA%E4%BA%8EI.mx6qsabresd%E8%AE%BE%E8%AE%A1%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%85%B6BSP%E7%89%88%E6%9C%AC%E4%B8%BAL3.14.52%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8Eimx6qsabresd%EF%BC%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%BA%E6%88%91%E4%BB%AC%E5%8F%91%E9%80%81imx6qsabresd%20%E7%9A%84L3.14.52%E8%A1%A5%E4%B8%81%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi~Li%20Qiang!%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81~%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E6%9D%A5%E4%BF%AE%E5%A4%8D%E6%88%91%E7%9A%84%E7%9B%B8%E6%9C%BA%20OV10635%20%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0OV10635%E7%9A%84VSYNC%E4%B8%8D%E8%BF%9E%E7%BB%AD%EF%BC%8C%E8%80%8CHREF%E6%AD%A3%E5%B8%B8%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%A4%A7%E7%BA%A6%E4%B8%BA30%E5%B8%A7%E6%AF%8F%E7%A7%92%EF%BC%88fps%EF%BC%89%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E5%A4%84%E7%B2%98%E8%B4%B4%E6%82%A8%E7%9A%84%20VSYNC%20%E6%B3%A2%E5%BD%A2%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E6%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3BLi%20Qiang%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%B7%B2%E6%9B%B4%E6%94%B9%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%91%E7%8E%B0%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%8F%AA%E6%9C%89AP0101%E8%80%8C%E6%B2%A1%E6%9C%89AR0140%E3%80%82%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20426px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F5203i8FC86447DC8D50A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3BLi%20qiang%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%E6%98%AFAR0140%EF%BC%8C%E8%80%8C%E9%9D%9EOV10635%EF%BC%8C%E8%AF%B7%E9%97%AE%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E4%BF%AE%E6%94%B9%EF%BC%9F%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3Bqiang%20li%3A%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8MAX9286%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%8F%91%E7%8E%B0%E8%AF%A5%E6%9D%BF%E9%87%87%E7%94%A8Maxim%E7%9A%845V%E4%BE%9B%E7%94%B5%E7%94%B5%E6%BA%90%EF%BC%8C%E4%B8%94%E4%B8%93%E4%B8%BAI.mx6%E8%AE%BE%E8%AE%A1%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2261600121988173929.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2261600121988173929.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2668i9665C55642DCE1BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2261600121988173929.jpg%22%20alt%3D%2261600121988173929.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2717i3EF186C49B5B7191%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2738iAFA18967749D04B9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Einux_3.10.35%2Farch%2Farm%2Fboot%2Fdts%2Fimx6q-sabreauto.dts%20%26nbsp%3B%E4%B8%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%26amp%3Bmipi_csi%20%7B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20lanes%20%3D%20%26lt%3B4%26gt%3B%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%400%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%401%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%402%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%403%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%80%E6%AE%B5%E5%9C%A83.0.35%E4%B8%AD%E6%80%8E%E4%B9%88%E5%A4%84%E7%90%86%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Edear%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2236648%22%20data-username%3D%22Qiang_FSL%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%238ca9cd%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EQiang%20Li%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%82%A8%E5%B0%9D%E8%AF%95%E8%BF%87imx6q-sabreauto%E5%BC%80%E5%8F%91%E6%9D%BF%E5%90%97%EF%BC%9F%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8sabreauto%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8max9286%EF%BC%8C%E4%B8%94%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E1%20-x%200%20-g2d%20%26amp%3Blo%3A%2Funit_tests%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%20%3CBR%20%2F%3E%5B1%5D%20845%3CBR%20%2F%3Eroot%40imx6qdlsolo%3A%2Funit_tests%23%20max9286_mipi%3A%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%8F%B7%20%3D%201.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%EF%BC%9Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20192%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20%E5%80%BC%20%3D%200x44.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ov10635_read_reg%3A%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%3A%20reg%3D0x300a.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ov10635_check_device%3A%20OV10635%E6%9C%AA%E6%89%BE%E5%88%B0%2C%20reg%5B0x300a%5D%20%3D%200x0.%3CBR%20%2F%3Emipi%20csi2%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%E9%92%9F!%20MIPI_CSI_PHY_STATE%20%3D%200x6f0.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20800.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x73600000%2C%20smem_len%20%3D%200x480000.%3CBR%20%2F%3Efb%3A%20%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x180000%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201024%2C%20g_screen_info.yres%20%3D%20768.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20960.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20540.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Edear%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86L3.14.52%EF%BC%8C%E5%9C%A8mxc_v4l2_tvin_max9286.tar.gz%E4%BD%BF%E7%94%A8%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%8C%E5%85%B7%E4%BD%93%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E.%2Fmxc_v4l2_tvin.out%3A%20%E5%8A%A0%E8%BD%BD%E5%85%B1%E4%BA%AB%E5%BA%93%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9Alibg2d.so.0.8%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3EHi%20Qiang%20Li%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%E6%88%91%E4%BD%BF%E7%94%A8de%203.14.52%EF%BC%8C%E4%B8%94%E5%BA%94%E7%94%A8%E6%89%80%E6%9C%89%E8%A1%A5%E4%B8%81%EF%BC%8C%E4%BD%86%E5%B0%9A%E6%9C%AA%E5%9C%A8rootfs%E4%B8%AD%E4%BD%BF%E7%94%A8%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-363516%2Fmxc_v4l2_tvin_max9286.tar.gz%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%20background-color%3A%20%23fdfdfd%3B%22%20target%3D%22_blank%22%3Emxc_v4l2_tvin_max9286.tar.gz%3C%2FA%3E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86unit_tests%2F%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3Emxc_v4l2_tvin.out%EF%BC%8C%E5%B9%B6%E6%9C%AA%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%8C%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E7%BB%99%E4%BA%88%E5%B8%AE%E5%8A%A9%EF%BC%9F%E5%9C%A83.14.52%20yocto%E4%B8%AD%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E7%BC%96%E8%AF%91%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-363516%2Fmxc_v4l2_tvin_max9286.tar.gz%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%20background-color%3A%20%23fdfdfd%3B%22%20target%3D%22_blank%22%3Emxc_v4l2_tvin_max9286.tar.gz%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FA%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3Eadv7180%20%E5%BA%94%E5%9C%A8%20imx6qdl-sabreauto.dtsi%20%E6%96%87%E4%BB%B6%E4%B8%AD%E8%A2%AB%E6%B3%A8%E9%87%8A%E6%8E%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EZongbiaoLiao%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E---------------------------------------%3C%2FP%3E%3CP%3Eroot%40imx6qsabreauto%3A%2Funit_tests%23%20.%2Fmax9286.sh%3C%2FP%3E%3CP%3Eroot%40imx6qsabreauto%3A%2Funit_tests%23%20g_in_width%20%3D%201280%EF%BC%8Cg_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Eg_in_width%20%3D%201280%EF%BC%8Cg_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Eg_in_width%20%3D%201280%EF%BC%8Cg_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%EF%BC%8Csmem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x3f4800%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9Ag_screen_info.xres%20%3D%201920%EF%BC%8Cg_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%20960.%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%200.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%EF%BC%8Csmem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201457509993%20%E7%A7%92%EF%BC%8C697691%20%E5%BE%AE%E7%A7%92%3C%2FP%3E%3CP%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x3f4800%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9Ag_screen_info.xres%20%3D%201920%EF%BC%8Cg_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%200%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%20540.%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%EF%BC%8Csmem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x3f4800%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9Ag_screen_info.xres%20%3D%201920%EF%BC%8Cg_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%20960.%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%20540.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201457509993%20%E7%A7%92%EF%BC%8C717597%20%E5%BE%AE%E7%A7%92%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201457509993%20%E7%A7%92%EF%BC%8C717698%20%E5%BE%AE%E7%A7%92%3C%2FP%3E%3CP%3Eg_in_width%20%3D%20720%EF%BC%8Cg_in_height%20%3D%20624%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%EF%BC%8Csmem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9A%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%A7%E5%B0%8F%20%3D%200x3f4800%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3Efb%EF%BC%9Ag_screen_info.xres%20%3D%201920%EF%BC%8Cg_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%200%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%200.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%201457509994%20%E7%A7%92%EF%BC%8C45827%20%E5%BE%AE%E7%A7%92%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_dqueue%20%E8%B6%85%E6%97%B6%20enc_counter%200%3C%2FP%3E%3CP%3EVIDIOC_DQBUF%20%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%E6%98%BE%E7%A4%BA%E5%99%A8%E6%89%80%E7%A4%BA%E5%86%85%E5%AE%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_0587.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_0587.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1492i4FA85BE853664257%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_0587.JPG%22%20alt%3D%22IMG_0587.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%B9%B6%E6%9C%AA%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E7%94%BB%E9%9D%A2%EF%BC%8C%E5%87%A0%E7%A7%92%E9%92%9F%E5%90%8E%E8%BE%93%E5%87%BA%E2%80%98%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20capture%3A%20mxc_v4l_dqueue%20%E8%B6%85%E6%97%B6%20enc_counter%200%E2%80%99%EF%BC%8C%20%3C%2FP%3E%3CP%3E%E5%85%B6%E4%BB%96%E4%B8%89%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E4%B9%9F%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%B8%94%E6%9C%AA%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E7%94%BB%E9%9D%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EZongbiaoLiao%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EMAX9271%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E9%99%A4%E4%BA%86%E7%AC%AC%E4%B8%80%E5%8F%B0%E6%91%84%E5%83%8F%E5%A4%B4%E5%A4%96%EF%BC%8C%E5%85%B6%E4%BB%96%E4%B8%89%E5%8F%B0%E6%91%84%E5%83%8F%E5%A4%B4%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EZongbiaoLiao%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%8F%91%E5%B8%83%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EL3.14.52_GA1.1.0%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%88%91%E5%B7%B2%E6%B5%8B%E8%AF%95%E8%AF%A5%E8%A1%A5%E4%B8%81%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%88%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Emxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%200%20-g2d%20%26amp%3B%3C%2FSPAN%3E%EF%BC%89%E6%9C%AA%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%8C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E5%87%A0%E7%A7%92%E9%92%9F%E5%90%8E%EF%BC%8C%E5%87%BA%E7%8E%B0%E2%80%9CVIDIOC_DQBUF%20failed%E2%80%9D%E9%94%99%E8%AF%AF%EF%BC%8C%E5%85%B6%E4%BB%96%E4%B8%89%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E4%B9%9F%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%863.10.53%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%8C%E6%89%80%E6%9C%89%E6%91%84%E5%83%8F%E5%A4%B4%E5%9D%87%E6%97%A0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E4%BD%A0%E8%83%BD%E5%B9%AB%E6%88%91%E5%97%8E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EZongbiaoLiao%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8ELinux%20BSP%E7%9A%84iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%E6%91%84%E5%83%8F%E5%A4%B4%E7%8E%AF%E8%A7%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi~Li%20Qiang!%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81~%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E4%BB%AC%E7%9A%84cpu%E6%98%AF%3CSTRONG%3EIMX6Q-Sabresd%3C%2FSTRONG%3E%EF%BC%8C%E6%91%84%E5%83%8F%E5%A4%B4%E5%88%99%E6%98%AF%3CSTRONG%3EOv10635%3C%2FSTRONG%3E%E3%80%82LTIB%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%20text-align%3A%20justify%3B%22%3E%E6%98%AF%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%20text-align%3A%20justify%3B%22%3EL3.0.35_4.1.0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%94%AF%E6%8C%81%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2~~%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-26-2021 01:39 AM
更新人:
