i.MX6Q PCIe EP/RC Validation System
i.MX6Q PCIe EP/RC Validation and Throughput
Hardware setup
    * Two i.MX6Q SD boards, one is used as PCIe RC; the other one is used as PCIe EP. Connected by 2*mini_PCIe to standard_PCIe  adaptors, 2*PEX cable adaptors,  and one PCIe cable.
Software configurations
    * When building RC image, make sure that
        CONFIG_IMX_PCIE=y
        # CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS is not set
        CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS=y
    * When build EP image, make sure that
        CONFIG_IMX_PCIE=y
        CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS=y
        # CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS is not set
Features
    * Set-up link between RC and EP by their stand-alone 125MHz running internally.
* In EP's system, EP can access the reserved ddr memory    (default address:0x40000000) of PCIe RC's system, by the   interconnection between PCIe EP and PCIe RC.
NOTE: The layout of the 1G DDR memory on SD boards is 0x1000_0000 ~ 0x4FFF_FFFF)
Use mem=768M in the kernel command line to reserve the 0x4000_0000 ~ 0x4FFF_FFFF DDR memory  space used to do the EP access tests.
(The example of the RC’s cmd-line: Kernel command line: noinitrd console=ttymxc0,115200 mem=768M root=/dev/nfs nfsroot=10.192.225.216:/home/r65037/nfs/rootfs_mx5x_10.11,v3,tcp ip=dhcp rw)
Throughput results
ARM core used as the bus master, and cache is disabledARM core used as the bus master, and cache is enabledIPU used as the bus master(DMA)
Data size in one write tlp8 bytes32 bytes64 bytes
Write speed~109MB/s~298MB/s~344MB/s
Data size in one read tlp32 bytes64 bytes64 bytes
Read speed~29MB/s~100MB/s~211MB/s
Here is the summary of the PCIe throughput results tested by IPU.
Write speed is about 344 MB/s.
Read speed is about 211MB/s
ARM core used as the bus master (define EP_SELF_IO_TEST in pcie.c driver)
write speed ~300MB/s.
read speed ~100MB/s.
Cache is enabled.
PCIe EP: Starting data transfer...
PCIe EP: Data transfer is successful, tv_count1 54840us, tv_count2 162814us.
PCIe EP: Data write speed is 298MB/s.
PCIe EP: Data read speed is 100MB/s.
Regarding to the log, the data size of each TLP when cache is enabled, is about 4 times of the data size in write, and 2 times of the data size in read, when the cache is not enabled.
Cache is disabledCache is enabled
Cache is not enabled
PCIe EP: Data transfer is successful, tv_count1 149616us, tv_count2 552099us.
PCIe EP: Data write speed is 109MB/s.
PCIe EP: Data read speed is 29MB/s.
One simple method used to connect the imx6 pcie ep and rc
View of the whole solution:
HW materials:
2* iMX6Q SD boards,  2* Mini PCIe to STD PCIe adaptors, one SATA2 data cable.
the mini-pcie to standard pcie exchange adaptor.
Here is the URL:
http://www.bplus.com.tw/Adapter/PM2C.html
How to make it.
signals connections
Two adaptors, one is named as A, the other one is named as B.
A                  B
TXM <----> RXM
TXN <----> RXN
RXM <----> TXM
RXN <----> TXN
A1 connected to B3
A2 connected to B4
A3 connected to B1
A4 connected to B2
Connect the cable to the adaptor.
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (A)
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (B)
NOTE:
* Please keep length of Cable as short as possible.  Our cable is about 12cm.
* Please connect shield wire in SATA2 Cable to GND at both board.
* Please boot up PCIe EP system before booting PCIe RC system.
Base one imx_3.0.35 mainline, the patch, and the IPU test tools had been attached.
NOTE:
* IPU tests usage howto.
Unzip the xxx.zip, and run xxx_r.sh to do read tests, run xxx_w.sh to do the write tests.
Tests log:
EP:
root@freescale ~/pcie_ep_io_test$ ./pcie-r.sh
pass cmdline 14, ./pcie_ipudev_test.out
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=1024,h=1024,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
640,480,RGB4,0,0,0,0,0
new option : s
show to fb 0
new option : f
output file name ipu1-1st-ovfb
new option : ÿ
show_to_buf:0, input_paddr:0x1000000, output.paddr0x18800000
====== ipu task ======
input:
        foramt: 0x34424752
        width: 1024
        height: 1024
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 640
        height: 480
        roate: 0
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 19019 us, fps 52.579000
root@freescale ~/pcie_ep_io_test$ ./pcie-w.sh
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=640,h=480,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
1024,1024,RGB4,0,0,0,0,0
new option : s
show to fb 1
new option : f
new option : ÿ
show_to_buf:1, input_paddr:0x18a00000, output.paddr0x1000000
input:
        foramt: 0x34424752
        width: 640
        height: 480
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 1024
        height: 1024
        roate: 0
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 11751 us, fps 85.099140
root@freescale ~$ ./memtool -32 01000000=deadbeaf
Writing 32-bit value 0xDEADBEAF to address 0x01000000
RC:
Before run "./memtool -32 01000000=deadbeaf" at EP.
root@freescale ~$ ./memtool -32 40000000 10
Reading 0x10 count starting at address 0x40000000
0x40000000:  00000000 00000000 00000000 00000000
0x40000010:  00000000 00000000 00000000 00000000
0x40000020:  00000000 00000000 00000000 00000000
0x40000030:  00000000 00000000 00000000 00000000
After run "./memtool -32 01000000=deadbeaf" at EP.
0x40000000:  DEADBEAF 00000000 00000000 00000000
Labels parameters
Labels (2)
Comments
Can you re-try it after remove "
PCI Express support
x x
” in kernel configuration?
Richard
Regarding to the following dump,
"Code: e59f0010 e1a01003 eb133c07 e3a03000 (e5833000)
clk_enable cannot be called in an interrupt context
[<80049e34>] (unwind_backtrace+0x0/0xf8) from [<8006563c>] (clk_enable+0x88/0xa0)
It's strange that why there is the IPU related kernel dump when do RTL8111e operations.
Richard
Richard:
     I have been re-configure the kernel configure, and compile the kernel again. but the result is same.
     the kernel configure is:
       *** MX6 Options: ***
  x x  [*] PCI Express support
  x x    [ ]   PCI Express EP mode in the IMX6 RC/EP interconnection system
  x x    [ ]   PCI Express RC mode in the IMX6 RC/EP interconnection system
    and for another question of IPU related, I have don't run any other command,  just load driver modules, and configure eth1, then run PING command.
    By the way, RTL8111E is a PCIE nic, and I used a mini-PCIE to PCIE adapter , connect the RTL8111E nic and i.MX6-SebraSDP board.
HI Hongxing Zhu:
                        I have tested the imx6 platform sdk "pcie_test" in RC mode,is there any EP mode test                               sample  code in imx6 platform sdk,thank you!
Dear Zhu,
I have carefully read this topic, but I need your help because my system is not working.
First of all, let me explain my situation :
I have a video processing card connected to the iMX6 thanks to the PCIe slot. The video processing card takes physical address to write pictures into DDR of the iMX6. Such as you did I reduce the memory of the iMX6 (MEM=768M). Then, my driver uses address from 0x4000_0000 to write pictures. This works fine but my problem is that the maximum write speed is around 50MB/s. Can I use IPU as bus master to reach the speed of 344MB/s ? What do I have to do exactly ?
Yann Tinauus
Yes, there is ep mode test, you can refer to the fsl linux bsp release.
Richard.
Unfortunately, as I know that you can't use IPU DMA engine in your implementation, because that IPU DMA engine is dedicated design for IPU usage, and can't be used as genera DMA engine.
I'm curious that why the throughput of the data transfer at your side is such poor, can you make sure the quality of the connections
between imx6 pcie interface and your video process card?
There may be a lot of CRC and re-try operations if there are not a GOOD enough quality connection.
Good luck.
Richard.
Dear Zhu,
I don't really understand then what the IPU patch of this topic is for. I thought the IPU patch provided aimed to reconfigure IPU and use IPU DMA without image processing ?
And what if I do image processing in IPU, then I could use IPU DMA afterwards ? I mean, that I use the IPU for a tiny process that almost don't change picture (cropping 1 line for example) to access to the DMA and store picture at high rate (344MB/s) in DDR. Is that possible ?
I have a PHYFLEX carrier-board 1364.3 (development board) in between the iMX6 and my video processing card. It may be the reason of low data transfer... I will check connections to make sure everything is fine.
Thanks for your help.
Best regards.
Hi, Richard:
     There is a new problem that we have meet, on my board, rtl8111e nic can not excuted ping operation when ping packets >= 469bytes, In addition, when we download ubuntu 's rootfs, we can't login by ssh, this operation also will cause the rtl8111e's driver abnormal.
      On the other topic: mx6 + rtl8111e driver  it seems that Carmili Li and Pavel have meet the same problem with me. Alexander have refered to a patch: [PATCH - v4] PCI: keystone: add a pci quirk to limit mrrs -- Linux PCI, but in my kernel source, we don't have this file, "/drivers/pci/host/pci-keystone.c"
      kernel ver: Linux version 3.0.35-2666-gbdde708
      rtl8111e driver info:
      r8168: Realtek PCIe GBE Family Controller mcfg = 0014
      r8168 0000:01:00.0: no MSI. Back to INTx.
      r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
      r8168  Copyright (C) 2014  Realtek NIC software team <[email protected]>
      This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
      This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
ping operation:
root@freescale ~$ ping 192.168.1.5 -s 465
PING 192.168.1.5 (192.168.1.5): 465 data bytes
473 bytes from 192.168.1.5: seq=0 ttl=64 time=0.435 ms
473 bytes from 192.168.1.5: seq=1 ttl=64 time=0.518 ms
--- 192.168.1.5 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.435/0.476/0.518 ms
root@freescale ~$ ping 192.168.1.5 -s 468
PING 192.168.1.5 (192.168.1.5): 468 data bytes
476 bytes from 192.168.1.5: seq=0 ttl=64 time=0.440 ms
476 bytes from 192.168.1.5: seq=1 ttl=64 time=0.503 ms
round-trip min/avg/max = 0.440/0.471/0.503 ms
root@freescale ~$ ping 192.168.1.5 -s 469
PING 192.168.1.5 (192.168.1.5): 469 data bytes
34 packets transmitted, 0 packets received, 100% packet loss
root@freescale ~$
As I remember that more than 1000 bytes packets transmission is verified on INTEL e1000e NIC card before.
Can you make a double check on your NIC device/driver?
Here is just a reference log, FYI.
root@imx6sxsabresd:~# ping 192.168.1.253 -s 469
PING 192.168.1.253 (192.168.1.253): 469 data bytes
477 bytes from 192.168.1.253: seq=0 ttl=64 time=0.595 ms
477 bytes from 192.168.1.253: seq=1 ttl=64 time=0.482 ms
477 bytes from 192.168.1.253: seq=2 ttl=64 time=0.457 ms
477 bytes from 192.168.1.253: seq=3 ttl=64 time=0.450 ms
^C
--- 192.168.1.253 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.450/0.496/0.595 ms
root@imx6sxsabresd:~# lspci
00:00.0 PCI bridge: Device 16c3:abcd (rev 01)
01:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
root@imx6sxsabresd:~# ping 192.168.1.253 -s 1000
PING 192.168.1.253 (192.168.1.253): 1000 data bytes
1008 bytes from 192.168.1.253: seq=0 ttl=64 time=0.559 ms
1008 bytes from 192.168.1.253: seq=1 ttl=64 time=0.485 ms
1008 bytes from 192.168.1.253: seq=2 ttl=64 time=0.472 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.472/0.505/0.559 ms
hi, Richard:
     Thanks for you reply, We have checked our driver code, and it seems ok, and We did an experiment, driver the nic with r8169 what is the fsl‘s original code in linux bsp project, not r8168-8.039.00.
  x x                                  < >   Packet Engines Hamachi GNIC-II support                                                            x x
  x x                                  < >   Packet Engines Yellowfin Gigabit-NIC support (EXPERIMENTAL)                                       x x
  x x                                  <*>   Realtek 8169 gigabit ethernet support                                                             x x
  x x                                  < >   Realtek 8111E gigabit ethernet support
   and the problem is still the same.
Dear Richard,
I'm currently trying to transmit data from a iMX6 board to a Xilinx FPGA board through a pcie link x1, using the IPU DMA to have reasonable performance, given the PCIe RC in iMX6 doesn't have DMA.
To ahieve this I adapted your demo to my specific scenario. I didn't have any major problems in the adaptation process. The writing operations from the iMX6 to the FPGA seem to work fine but, in the same way as for Yann (although our scenarios are different), instead of reaching the 344 MB/s stated in the link of the demo, with TLP data size 64 bytes, I only get about 54MB/s due to the fact that the data size of the TLPs I receive in the FPGA side is only 16 bytes. The connector I'm using between the two boards is a mini pcie to pcie
Resultado de imagen de mini pcie to pcie connector
Which configuration parameters should i touch in the iMX6 side in order to increase the size of the TLPs transmitted?
Thanks very much in advance for your answer.
Eduardo.
richard.zhu
I'm having trouble getting the PCIE up on the i.MAX6 Quad Sabre Lite Development board (https://boundarydevices.com/product/sabre-lite-imx6-sbc/ ) and interfacing with TW6865 Intersil video chip and I couldn't find the sufficient details on how to connect REFCLK- and REFCLK+ of TW6865 with PCIE port of the i.MAX6Q Sabre Lite as it just have following pin connections.
Can you guide me to interface TW6865 with PCIE of Sabre Lite ? (Presently I'm working 3.14.52 kernel based system)
Thank You,
Peter.
i.max‌#i.mx6q pcie
Hi Eduardo,
Did you ever resolve this?
Brian
The attachments are no longer available.
Also what I didn't understand from reading the article is how to actually enable the caching/data size in one tlp.
Christoph
I am not able to access the mentioned files.
Can you please provide access for the same?
%3CLINGO-SUB%20id%3D%22lingo-sub-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-382516595%22%20id%3D%22toc-hId-1297691369%22%3Ei.MX6Q%20PCIe%20EP%2FRC%20Validation%20and%20Throughput%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1073078069%22%20id%3D%22toc-hId-1988252843%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--734376394%22%20id%3D%22toc-hId-180798380%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1753136439%22%20id%3D%22toc-hId--1626656083%22%3EHardware%20setup%3C%2FH2%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Two%20i.MX6Q%20SD%20boards%2C%20one%20is%20used%20as%20PCIe%20RC%3B%20the%20other%20one%20is%20used%20as%20PCIe%20EP.%20Connected%20by%202*mini_PCIe%20to%20standard_PCIe%26nbsp%3B%20adaptors%2C%202*PEX%20cable%20adaptors%2C%26nbsp%3B%20and%20one%20PCIe%20cable.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110864i0A900558E63E8936%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-03-21_10-24-40_704.jpg%22%20alt%3D%222013-03-21_10-24-40_704.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--54318024%22%20id%3D%22toc-hId-860856750%22%3ESoftware%20configurations%3C%2FH2%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20When%20building%20RC%20image%2C%20make%20sure%20that%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20When%20build%20EP%20image%2C%20make%20sure%20that%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1861772487%22%20id%3D%22toc-hId--946597713%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-625740346%22%20id%3D%22toc-hId-1540915120%22%3EFeatures%3C%2FH2%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Set-up%20link%20between%20RC%20and%20EP%20by%20their%20stand-alone%20125MHz%20running%20internally.%3C%2FP%3E%3CP%3E*%20In%20EP's%20system%2C%20EP%20can%20access%20the%20reserved%20ddr%20memory%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(default%20address%3A0x40000000)%20of%20PCIe%20RC's%20system%2C%20by%20the%26nbsp%3B%26nbsp%3B%20interconnection%20between%20PCIe%20EP%20and%20PCIe%20RC.%3C%2FP%3E%3CP%3ENOTE%3A%20The%20layout%20of%20the%201G%20DDR%20memory%20on%20SD%20boards%20is%200x1000_0000%20~%200x4FFF_FFFF)%3C%2FP%3E%3CP%3EUse%20mem%3D768M%20in%20the%20kernel%20command%20line%20to%20reserve%20the%200x4000_0000%20~%200x4FFF_FFFF%20DDR%20memory%26nbsp%3B%20space%20used%20to%20do%20the%20EP%20access%20tests.%3C%2FP%3E%3CP%3E(The%20example%20of%20the%20RC%E2%80%99s%20cmd-line%3A%20Kernel%20command%20line%3A%20noinitrd%20console%3Dttymxc0%2C115200%20%3CSTRONG%3Emem%3D768M%3C%2FSTRONG%3E%20root%3D%2Fdev%2Fnfs%20nfsroot%3D10.192.225.216%3A%2Fhome%2Fr65037%2Fnfs%2Frootfs_mx5x_10.11%2Cv3%2Ctcp%20ip%3Ddhcp%20rw)%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1181714117%22%20id%3D%22toc-hId--266539343%22%3E%3CA%20id%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20name%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1305798716%22%20id%3D%22toc-hId--2073993806%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--501655747%22%20id%3D%22toc-hId-413519027%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--635340471%22%20id%3D%22toc-hId-279834303%22%3EThroughput%20results%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22table-wrap%22%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20core%20used%20as%20the%20bus%20master%2C%20and%20cache%20is%20disabled%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20core%20used%20as%20the%20bus%20master%2C%20and%20cache%20is%20enabled%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EIPU%20used%20as%20the%20bus%20master(DMA)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EData%20size%20in%20one%20write%20tlp%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20bytes%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EWrite%20speed%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~%3CSTRONG%3E344MB%3C%2FSTRONG%3E%2Fs%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EData%20size%20in%20one%20read%20tlp%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20bytes%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3ERead%20speed%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~%3CSTRONG%3E211MB%3C%2FSTRONG%3E%2Fs%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1981255081%22%20id%3D%22toc-hId--1398537441%22%3EIPU%20used%20as%20the%20bus%20master(DMA)%3C%2FH3%3E%3CP%3EHere%20is%20the%20summary%20of%20the%20PCIe%20throughput%20results%20tested%20by%20IPU.%3C%2FP%3E%3CP%3EWrite%20speed%20is%20about%20344%20MB%2Fs.%3C%2FP%3E%3CP%3ERead%20speed%20is%20about%20211MB%2Fs%3C%2FP%3E%3CH3%20id%3D%22toc-hId-173800618%22%20id%3D%22toc-hId-1088975392%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--1633653845%22%20id%3D%22toc-hId--718479071%22%3EARM%20core%20used%20as%20the%20bus%20master%20(define%20EP_SELF_IO_TEST%20in%20pcie.c%20driver)%3C%2FH3%3E%3CP%3Ewrite%20speed%20~300MB%2Fs.%3C%2FP%3E%3CP%3Eread%20speed%20~100MB%2Fs.%3C%2FP%3E%3CH4%20id%3D%22toc-hId-982941707%22%20id%3D%22toc-hId-1898116481%22%3ECache%20is%20enabled.%3C%2FH4%3E%3CP%3EPCIe%20EP%3A%20Starting%20data%20transfer...%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20transfer%20is%20successful%2C%20tv_count1%2054840us%2C%20tv_count2%20162814us.%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20write%20speed%20is%20298MB%2Fs.%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20read%20speed%20is%20100MB%2Fs.%3C%2FP%3E%3CP%3ERegarding%20to%20the%20log%2C%20the%20data%20size%20of%20each%20TLP%20when%20cache%20is%20enabled%2C%20is%20about%204%20times%20of%20the%20data%20size%20in%20write%2C%20and%202%20times%20of%20the%20data%20size%20in%20read%2C%20when%20the%20cache%20is%20not%20enabled.%3C%2FP%3E%3CP%20class%3D%22table-wrap%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3ECache%20is%20disabled%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3ECache%20is%20enabled%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EData%20size%20in%20one%20write%20tlp%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%20bytes%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EWrite%20speed%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2Fs%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3EData%20size%20in%20one%20read%20tlp%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%20bytes%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20bytes%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3ERead%20speed%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2Fs%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2Fs%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId--824512756%22%20id%3D%22toc-hId-90662018%22%3ECache%20is%20not%20enabled%3C%2FH4%3E%3CP%3EPCIe%20EP%3A%20Starting%20data%20transfer...%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20transfer%20is%20successful%2C%20tv_count1%20149616us%2C%20tv_count2%20552099us.%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20write%20speed%20is%20109MB%2Fs.%3C%2FP%3E%3CP%3EPCIe%20EP%3A%20Data%20read%20speed%20is%2029MB%2Fs.%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1275751920%22%20id%3D%22toc-hId--2104040602%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--531702543%22%20id%3D%22toc-hId-383472231%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1955810290%22%20id%3D%22toc-hId--1423982232%22%3EOne%20simple%20method%20used%20to%20connect%20the%20imx6%20pcie%20ep%20and%20rc%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-277438546%22%20id%3D%22toc-hId-1192613320%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--831853976%22%20id%3D%22toc-hId-83320798%22%3EView%20of%20the%20whole%20solution%3A%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110861i2984C2608B437C9D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_15-43-46_818_small.jpg%22%20alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1655658857%22%20id%3D%22toc-hId--1724133665%22%3EHW%20materials%3A%3C%2FH2%3E%3CP%3E2*%20iMX6Q%20SD%20boards%2C%26nbsp%3B%202*%20Mini%20PCIe%20to%20STD%20PCIe%20adaptors%2C%20one%20SATA2%20data%20cable.%3C%2FP%3E%3CP%3Ethe%20mini-pcie%20to%20standard%20pcie%20exchange%20adaptor.%3C%2FP%3E%3CP%3EHere%20is%20the%20URL%3A%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110857i1C40DD0BB637386E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PM2C.png%22%20alt%3D%22PM2C.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--151795606%22%20id%3D%22toc-hId-763379168%22%3EHow%20to%20make%20it.%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--1830167350%22%20id%3D%22toc-hId--914992576%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-657345483%22%20id%3D%22toc-hId-1572520257%22%3Esignals%20connections%3C%2FH3%3E%3CP%3ETwo%20adaptors%2C%20one%20is%20named%20as%20A%2C%20the%20other%20one%20is%20named%20as%20B.%3C%2FP%3E%3CP%3EA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20B%3C%2FP%3E%3CP%3ETXM%20%26lt%3B----%26gt%3B%20RXM%3C%2FP%3E%3CP%3ETXN%20%26lt%3B----%26gt%3B%20RXN%3C%2FP%3E%3CP%3ERXM%20%26lt%3B----%26gt%3B%20TXM%3C%2FP%3E%3CP%3ERXN%20%26lt%3B----%26gt%3B%20TXN%3C%2FP%3E%3CP%3EA1%20connected%20to%20B3%3C%2FP%3E%3CP%3EA2%20connected%20to%20B4%3C%2FP%3E%3CP%3EA3%20connected%20to%20B1%3C%2FP%3E%3CP%3EA4%20connected%20to%20B2%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110851i98266B769FE82A21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-59_594_small.jpg%22%20alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1150108980%22%20id%3D%22toc-hId--234934206%22%3EConnect%20the%20cable%20to%20the%20adaptor.%3C%2FH3%3E%3CP%3EConnect%20the%20SATA2%20data%20cable%20to%20Mini%20PCIe%20to%20STD%20PCIe%20adaptor%20(A)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110849iE1ED638DC4B6F47A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-17_913_small.jpg%22%20alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EConnect%20the%20SATA2%20data%20cable%20to%20Mini%20PCIe%20to%20STD%20PCIe%20adaptor%20(B)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110848iAB15F6405BE2880B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-01-36_658_small.jpg%22%20alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ENOTE%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E*%20Please%20keep%20length%20of%20Cable%20as%20short%20as%20possible.%26nbsp%3B%20Our%20cable%20is%20about%2012cm.%3C%2FP%3E%3CP%3E*%20Please%20connect%20shield%20wire%20in%20SATA2%20Cable%20to%20GND%20at%20both%20board.%3CBR%20%2F%3E*%20Please%20boot%20up%20PCIe%20EP%20system%20before%20booting%20PCIe%20RC%20system.%3C%2FP%3E%3CP%3EBase%20one%20imx_3.0.35%20mainline%2C%20the%20patch%2C%20and%20the%20IPU%20test%20tools%20had%20been%20attached.%3C%2FP%3E%3CP%3ENOTE%3A%3C%2FP%3E%3CP%3E*%20IPU%20tests%20usage%20howto.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EUnzip%20the%20xxx.zip%2C%20and%20run%20xxx_r.sh%20to%20do%20read%20tests%2C%20run%20xxx_w.sh%20to%20do%20the%20write%20tests.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ETests%20log%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EEP%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%2Fpcie_ep_io_test%24%20.%2Fpcie-r.sh%3CBR%20%2F%3Epass%20cmdline%2014%2C%20.%2Fpcie_ipudev_test.out%3C%2FP%3E%3CP%3Enew%20option%20%3A%20c%3CBR%20%2F%3Eframe%20count%20set%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20l%3CBR%20%2F%3Eloop%20count%20set%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D1024%2Ch%3D1024%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3Enew%20option%20%3A%20O%3CBR%20%2F%3E640%2C480%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3Enew%20option%20%3A%20s%3CBR%20%2F%3Eshow%20to%20fb%200%3C%2FP%3E%3CP%3Enew%20option%20%3A%20f%3CBR%20%2F%3Eoutput%20file%20name%20ipu1-1st-ovfb%3C%2FP%3E%3CP%3Enew%20option%20%3A%20%C3%BF%3CBR%20%2F%3Eshow_to_buf%3A0%2C%20input_paddr%3A0x1000000%2C%20output.paddr0x18800000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20ipu%20task%20%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3Einput%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20foramt%3A%200x34424752%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20width%3A%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20height%3A%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.w%20%3D%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.h%20%3D%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.x%20%3D%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.y%20%3D%200%3CBR%20%2F%3Eoutput%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20foramt%3A%200x34424752%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20width%3A%20640%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20height%3A%20480%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20roate%3A%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.w%20%3D%20640%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.h%20%3D%20480%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.x%20%3D%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.y%20%3D%200%3CBR%20%2F%3Etotal%20frame%20count%201%20avg%20frame%20time%2019019%20us%2C%20fps%2052.579000%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%2Fpcie_ep_io_test%24%20.%2Fpcie-w.sh%3CBR%20%2F%3Epass%20cmdline%2014%2C%20.%2Fpcie_ipudev_test.out%3C%2FP%3E%3CP%3Enew%20option%20%3A%20c%3CBR%20%2F%3Eframe%20count%20set%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20l%3CBR%20%2F%3Eloop%20count%20set%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D640%2Ch%3D480%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3Enew%20option%20%3A%20O%3CBR%20%2F%3E1024%2C1024%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3Enew%20option%20%3A%20s%3CBR%20%2F%3Eshow%20to%20fb%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20f%3CBR%20%2F%3Eoutput%20file%20name%20ipu1-1st-ovfb%3C%2FP%3E%3CP%3Enew%20option%20%3A%20%C3%BF%3CBR%20%2F%3Eshow_to_buf%3A1%2C%20input_paddr%3A0x18a00000%2C%20output.paddr0x1000000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20ipu%20task%20%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3Einput%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20foramt%3A%200x34424752%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20width%3A%20640%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20height%3A%20480%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.w%20%3D%20640%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.h%20%3D%20480%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.x%20%3D%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.y%20%3D%200%3CBR%20%2F%3Eoutput%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20foramt%3A%200x34424752%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20width%3A%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20height%3A%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20roate%3A%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.w%20%3D%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.h%20%3D%201024%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.x%20%3D%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20crop.pos.y%20%3D%200%3CBR%20%2F%3Etotal%20frame%20count%201%20avg%20frame%20time%2011751%20us%2C%20fps%2085.099140%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool%20-32%2001000000%3Ddeadbeaf%3CBR%20%2F%3EWriting%2032-bit%20value%200xDEADBEAF%20to%20address%200x01000000%3C%2FP%3E%3CP%3ERC%3A%3C%2FP%3E%3CP%3EBefore%20run%20%22.%2Fmemtool%20-32%2001000000%3Ddeadbeaf%22%20at%20EP.%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool%20-32%2040000000%2010%3CBR%20%2F%3EReading%200x10%20count%20starting%20at%20address%200x40000000%3C%2FP%3E%3CP%3E0x40000000%3A%26nbsp%3B%20%3CSTRONG%3E00000000%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000010%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000020%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000030%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3EAfter%20run%20%22.%2Fmemtool%20-32%2001000000%3Ddeadbeaf%22%20at%20EP.%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool%20-32%2040000000%2010%3CBR%20%2F%3EReading%200x10%20count%20starting%20at%20address%200x40000000%3C%2FP%3E%3CP%3E0x40000000%3A%26nbsp%3B%20%3CSTRONG%3EDEADBEAF%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000010%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000020%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000030%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3C%2FDIV%3E%3CSPAN%3ELabels%20parameters%3C%2FSPAN%3E%3CFORM%3E%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%3C%2FFORM%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20not%20able%20to%20access%20the%20mentioned%20files.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20958px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F107519i084603FDBC0E3527%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECan%20you%20please%20provide%20access%20for%20the%20same%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20attachments%20are%20no%20longer%20available.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlso%20what%20I%20didn't%20understand%20from%20reading%20the%20article%20is%20how%20to%20actually%26nbsp%3Benable%20the%20caching%2Fdata%20size%20in%20one%20tlp.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EChristoph%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Eduardo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDid%20you%20ever%20resolve%20this%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBrian%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20having%20trouble%20getting%20the%20PCIE%20up%20on%20the%20i.MAX6%20Quad%20Sabre%20Lite%20Development%20board%20(%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%3C%2FA%3E%26nbsp%3B)%20and%20interfacing%20with%20TW6865%20Intersil%20video%20chip%20and%20I%20couldn't%20find%20the%20sufficient%20details%20on%20how%20to%20connect%20REFCLK-%20and%20REFCLK%2B%20of%20TW6865%20with%20PCIE%20port%20of%20the%20i.MAX6Q%20Sabre%20Lite%20as%20it%20just%20have%20following%20pin%20connections.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%20style%3D%22width%3A%20249px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1894i97B4911B492CCAA1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_504.png%22%20alt%3D%22pastedImage_504.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECan%20you%20guide%20me%20to%20interface%20TW6865%20with%20PCIE%20of%20Sabre%20Lite%20%3F%20(Presently%20I'm%20working%203.14.52%20kernel%20based%20system)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20You%2C%3C%2FP%3E%3CP%3EPeter.%3C%2FP%3E%3CP%3Ei.max%E2%80%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Ftag%2Fi.mx6q%20pcie%2Ftg-p%22%20target%3D%22_blank%22%3E%23i.mx6q%20pcie%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Richard%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20currently%20trying%20to%20transmit%20data%20from%20a%20iMX6%20board%20to%20a%20Xilinx%20FPGA%20board%20through%20a%20pcie%20link%20x1%2C%20using%20the%20IPU%20DMA%20to%20have%20reasonable%20performance%2C%20given%20the%20PCIe%20RC%20in%20iMX6%20doesn't%20have%20DMA.%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETo%20ahieve%20this%20I%20adapted%20your%20demo%20to%20my%20specific%20scenario.%20I%20didn't%20have%20any%20major%20problems%20in%20the%20adaptation%20process.%20The%20writing%20operations%20from%20the%20iMX6%20to%20the%20FPGA%20seem%20to%20work%20fine%20but%2C%20in%20the%20same%20way%20as%20for%20Yann%20(although%20our%20scenarios%20are%20different)%2C%20instead%20of%20reaching%20the%20344%20MB%2Fs%20stated%20in%20the%20link%20of%20the%20demo%2C%20with%20TLP%20data%20size%2064%20bytes%2C%20I%20only%20get%20about%2054MB%2Fs%20due%20to%20the%20fact%20that%20the%20data%20size%20of%20the%20TLPs%20I%20receive%20in%20the%20FPGA%20side%20is%20only%2016%20bytes.%20The%20connector%20I'm%20using%20between%20the%20two%20boards%20is%20a%20mini%20pcie%20to%20pcie%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22Resultado%20de%20imagen%20de%20mini%20pcie%20to%20pcie%20connector%22%20height%3D%22194%22%20src%3D%22http%3A%2F%2Fi.ebayimg.com%2Fimages%2Fi%2F221160508053-0-1%2Fs-l1000.jpg%22%20width%3D%22281%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhich%20configuration%20parameters%20should%20i%20touch%20in%20the%20iMX6%20side%20in%20order%20to%20increase%20the%20size%20of%20the%20TLPs%20transmitted%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20very%20much%20in%20advance%20for%20your%20answer.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3CP%3EEduardo.%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Thanks%20for%20you%20reply%2C%20We%20have%20checked%20our%20driver%20code%2C%20and%20it%20seems%20ok%2C%20and%20We%20did%20an%20experiment%2C%20driver%20the%20nic%20with%20r8169%20what%20is%20the%20fsl%E2%80%98s%20original%20code%20in%20linux%20bsp%20project%2C%20not%20r8168-8.039.00.%3C%2FP%3E%3CP%3E%26nbsp%3B%20---------------------------------------------------------------%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%26nbsp%3B%26nbsp%3B%20Packet%20Engines%20Hamachi%20GNIC-II%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20x%20x%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%26nbsp%3B%26nbsp%3B%20Packet%20Engines%20Yellowfin%20Gigabit-NIC%20support%20(EXPERIMENTAL)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20x%20x%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%26nbsp%3B%26nbsp%3B%20Realtek%208169%20gigabit%20ethernet%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20x%20x%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%26nbsp%3B%26nbsp%3B%20Realtek%208111E%20gigabit%20ethernet%20support%20%3C%2FP%3E%3CP%3E-------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20and%20the%20problem%20is%20still%20the%20same.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EAs%20I%20remember%20that%20more%20than%201000%20bytes%20packets%20transmission%20is%20verified%20on%20INTEL%20e1000e%20NIC%20card%20before.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ECan%20you%20make%20a%20double%20check%20on%20your%20NIC%20device%2Fdriver%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHere%20is%20just%20a%20reference%20log%2C%20FYI.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20ping%20192.168.1.253%20-s%20469%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPING%20192.168.1.253%20(192.168.1.253)%3A%20469%20data%20bytes%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E477%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D0%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.595%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E477%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.482%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E477%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D2%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.457%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E477%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D3%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.450%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253%20ping%20statistics%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E4%20packets%20transmitted%2C%204%20packets%20received%2C%200%25%20packet%20loss%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eround-trip%20min%2F%3CSPAN%20class%3D%22SpellE%22%3Eavg%3C%2FSPAN%3E%2Fmax%20%3D%200.450%2F0.496%2F0.595%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%3A00.0%20PCI%20bridge%3A%20Device%2016c3%3Aabcd%20(rev%2001)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%3A00.0%20Ethernet%20controller%3A%20Intel%20Corporation%2082574L%20Gigabit%20Network%20Connection%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20ping%20192.168.1.253%20-s%201000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPING%20192.168.1.253%20(192.168.1.253)%3A%201000%20data%20bytes%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E1008%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D0%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.559%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E1008%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.485%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E1008%20bytes%20from%20192.168.1.253%3A%20%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D2%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.472%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253%20ping%20statistics%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E3%20packets%20transmitted%2C%203%20packets%20received%2C%200%25%20packet%20loss%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eround-trip%20min%2F%3CSPAN%20class%3D%22SpellE%22%3Eavg%3C%2FSPAN%3E%2Fmax%20%3D%200.472%2F0.505%2F0.559%20ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%3A00.0%20PCI%20bridge%3A%20Device%2016c3%3Aabcd%20(rev%2001)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%3A00.0%20Ethernet%20controller%3A%20Intel%20Corporation%2082574L%20Gigabit%20Network%20Connection%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20There%20is%20a%20new%20problem%20that%20we%20have%20meet%2C%20on%20my%20board%2C%20rtl8111e%20nic%20can%20not%20excuted%20ping%20operation%20when%20ping%20packets%20%26gt%3B%3D%20469bytes%2C%20In%20addition%2C%20when%20we%20download%20ubuntu%20's%20rootfs%2C%20we%20can't%20login%20by%20ssh%2C%20this%20operation%20also%20will%20cause%20the%20rtl8111e's%20driver%20abnormal.%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20On%20the%20other%20topic%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F393520%22%20target%3D%22_blank%22%3Emx6%20%2B%20rtl8111e%20driver%3C%2FA%3E%26nbsp%3B%20it%20seems%20that%20Carmili%20Li%20and%20Pavel%20have%20meet%20the%20same%20problem%20with%20me.%20Alexander%20have%20%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2014px%3B%20background-color%3A%20%23fefefe%3B%20font-family%3A%20arial%3B%22%3Erefered%20to%20a%20patch%3A%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwww.spinics.net%2Flists%2Flinux-pci%2Fmsg34379.html%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%5BPATCH%20-%20v4%5D%20PCI%3A%20keystone%3A%20add%20a%20pci%20quirk%20to%20limit%20mrrs%20--%20Linux%20PCI%3C%2FA%3E%3C%2FSPAN%3E%2C%20but%20in%20my%20kernel%20source%2C%20we%20don't%20have%20this%20file%2C%20%22%2Fdrivers%2Fpci%2Fhost%2Fpci-keystone.c%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20kernel%20ver%3A%20Linux%20version%203.0.35-2666-gbdde708%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rtl8111e%20driver%20info%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20r8168%3A%20Realtek%20PCIe%20GBE%20Family%20Controller%20mcfg%20%3D%200014%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20r8168%200000%3A01%3A00.0%3A%20no%20MSI.%20Back%20to%20INTx.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20r8168%3A%20This%20product%20is%20covered%20by%20one%20or%20more%20of%20the%20following%20patents%3A%20US6%2C570%2C884%2C%20US6%2C115%2C776%2C%20and%20US6%2C327%2C625.%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20r8168%26nbsp%3B%20Copyright%20(C)%202014%26nbsp%3B%20Realtek%20NIC%20software%20team%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20This%20program%20comes%20with%20ABSOLUTELY%20NO%20WARRANTY%3B%20for%20details%2C%20please%20see%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20This%20is%20free%20software%2C%20and%20you%20are%20welcome%20to%20redistribute%20it%20under%20certain%20conditions%3B%20see%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eping%20operation%3A%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5%20-s%20465%3C%2FP%3E%3CP%3EPING%20192.168.1.5%20(192.168.1.5)%3A%20465%20data%20bytes%3C%2FP%3E%3CP%3E473%20bytes%20from%20192.168.1.5%3A%20seq%3D0%20ttl%3D64%20time%3D0.435%20ms%3C%2FP%3E%3CP%3E473%20bytes%20from%20192.168.1.5%3A%20seq%3D1%20ttl%3D64%20time%3D0.518%20ms%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5%20ping%20statistics%20---%3C%2FP%3E%3CP%3E2%20packets%20transmitted%2C%202%20packets%20received%2C%200%25%20packet%20loss%3C%2FP%3E%3CP%3Eround-trip%20min%2Favg%2Fmax%20%3D%200.435%2F0.476%2F0.518%20ms%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5%20-s%20468%3C%2FP%3E%3CP%3EPING%20192.168.1.5%20(192.168.1.5)%3A%20468%20data%20bytes%3C%2FP%3E%3CP%3E476%20bytes%20from%20192.168.1.5%3A%20seq%3D0%20ttl%3D64%20time%3D0.440%20ms%3C%2FP%3E%3CP%3E476%20bytes%20from%20192.168.1.5%3A%20seq%3D1%20ttl%3D64%20time%3D0.503%20ms%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5%20ping%20statistics%20---%3C%2FP%3E%3CP%3E2%20packets%20transmitted%2C%202%20packets%20received%2C%200%25%20packet%20loss%3C%2FP%3E%3CP%3Eround-trip%20min%2Favg%2Fmax%20%3D%200.440%2F0.471%2F0.503%20ms%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5%20-s%20469%3C%2FP%3E%3CP%3EPING%20192.168.1.5%20(192.168.1.5)%3A%20469%20data%20bytes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5%20ping%20statistics%20---%3C%2FP%3E%3CP%3E34%20packets%20transmitted%2C%200%20packets%20received%2C%20100%25%20packet%20loss%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Zhu%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20don't%20really%20understand%20then%20what%20the%20IPU%20patch%20of%20this%20topic%20is%20for.%20I%20thought%20the%20IPU%20patch%20provided%20aimed%20to%20reconfigure%20IPU%20and%20use%20IPU%20DMA%20without%20image%20processing%20%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnd%20what%20if%20I%20do%20image%20processing%20in%20IPU%2C%20then%20I%20could%20use%20IPU%20DMA%20afterwards%20%3F%20I%20mean%2C%20that%20I%20use%20the%20IPU%20for%20a%20tiny%20process%20that%20almost%20don't%20change%20picture%20(cropping%201%20line%20for%20example)%20to%20access%20to%20the%20DMA%20and%20store%20picture%20at%20high%20rate%20(344MB%2Fs)%20in%20DDR.%20Is%20that%20possible%20%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20a%20PHYFLEX%20carrier-board%201364.3%20(development%20board)%20in%20between%20the%20iMX6%20and%20my%20video%20processing%20card.%20It%20may%20be%20the%20reason%20of%20low%20data%20transfer...%20I%20will%20check%20connections%20to%20make%20sure%20everything%20is%20fine.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%3C%2FP%3E%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EUnfortunately%2C%20as%20I%20know%20that%20you%20can't%20use%20IPU%20DMA%20engine%20in%20your%20implementation%2C%20because%20that%20IPU%20DMA%20engine%20is%20dedicated%20design%20for%20IPU%20usage%2C%20and%20can't%20be%20used%20as%20genera%20DMA%20engine.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EI'm%20curious%20that%20why%20the%20throughput%20of%20the%20data%20transfer%20at%20your%20side%20is%20such%20poor%2C%20can%20you%20make%20sure%20the%20quality%20of%20the%20connections%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Ebetween%20imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20interface%20and%20your%20video%20process%20card%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThere%20may%20be%20a%20lot%20of%20CRC%20and%20re-try%20operations%20if%20there%20are%20not%20a%20GOOD%20enough%20quality%20connection.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EGood%20luck.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EYes%2C%20there%20is%20%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%20mode%20test%2C%20you%20can%20refer%20to%20the%20%3CSPAN%20class%3D%22SpellE%22%3Efsl%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Ebsp%3C%2FSPAN%3E%20release.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Zhu%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20carefully%20read%20this%20topic%2C%20but%20I%20need%20your%20help%20because%20my%20system%20is%20not%20working.%20%3C%2FP%3E%3CP%3EFirst%20of%20all%2C%20let%20me%20explain%20my%20situation%20%3A%3C%2FP%3E%3CP%3EI%20have%20a%20video%20processing%20card%20connected%20to%20the%20iMX6%20thanks%20to%20the%20PCIe%20slot.%20The%20video%20processing%20card%20takes%20physical%20address%20to%20write%20pictures%20into%20DDR%20of%20the%20iMX6.%20Such%20as%20you%20did%20I%20reduce%20the%20memory%20of%20the%20iMX6%20(MEM%3D768M).%20Then%2C%20my%20driver%20uses%20address%20from%200x4000_0000%20to%20write%20pictures.%20This%20works%20fine%20but%20my%20problem%20is%20that%20the%20maximum%20write%20speed%20is%20around%2050MB%2Fs.%20Can%20I%20use%20IPU%20as%20bus%20master%20to%20reach%20the%20speed%20of%20344MB%2Fs%20%3F%20What%20do%20I%20have%20to%20do%20exactly%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYann%20Tinauus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%20HI%20Hongxing%20Zhu%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20have%20tested%20the%20imx6%20platform%20sdk%20%22pcie_test%22%20in%20RC%20mode%2Cis%20there%20any%20EP%20mode%20test%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sample%26nbsp%3B%20code%20in%20imx6%20platform%20sdk%2Cthank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERichard%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20have%20been%20re-configure%20the%20kernel%20configure%2C%20and%20compile%20the%20kernel%20again.%20but%20the%20result%20is%20same.%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20the%20kernel%20configure%20is%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20***%20MX6%20Options%3A%20***%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%20%5B*%5D%20PCI%20Express%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20EP%20mode%20in%20the%20IMX6%20RC%2FEP%20interconnection%20system%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20RC%20mode%20in%20the%20IMX6%20RC%2FEP%20interconnection%20system%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20and%20for%20another%20question%20of%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%22%3EIPU%20related%3C%2FSPAN%3E%2C%20I%20have%20don't%20run%20any%20other%20command%2C%26nbsp%3B%20just%20load%20driver%20modules%2C%20and%20configure%20eth1%2C%20then%20run%20PING%20command.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20By%20the%20way%2C%20RTL8111E%20is%20a%20PCIE%20nic%2C%20and%20I%20used%20a%20mini-PCIE%20to%20PCIE%20adapter%20%2C%20connect%20the%20RTL8111E%20nic%20and%20i.MX6-SebraSDP%20board.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERegarding%20to%20the%20following%20dump%2C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3ECode%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Arial%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20inherit%20%2C%20serif%3B%20%22%3Eclk_enable%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%20cannot%20be%20called%20in%20an%20interrupt%20context%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EIt's%20strange%20that%20why%20there%20is%20the%20IPU%20related%20kernel%20dump%20when%20do%20RTL8111e%20operations.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ECan%20you%20re-try%20it%20after%20remove%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border-collapse%3Acollapse%3Bmso-yfti-tbllook%3A1184%3Bmso-padding-alt%3A0in%200in%200in%200in%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A0%3Bmso-yfti-firstrow%3Ayes%3Bmso-yfti-lastrow%3Ayes%22%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3EPCI%20Express%20support%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3Ex%20%3CSPAN%20class%3D%22SpellE%22%3Ex%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E2%80%9D%20in%20kernel%20configuration%3F%3CBR%20%2F%3E%3CBR%20%2F%3ERichard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eadd%20kernel's%20configure%3A%3C%2FP%3E%3CTABLE%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%26lt%3B*%26gt%3B%20PCI%20Stub%20driver%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20PCI%20IOV%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B*%5D%20PCI%20Express%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B*%5D%26nbsp%3B%26nbsp%3B%20Root%20Port%20Advanced%20Error%20Reporting%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EPCI%20Express%20ECRC%20settings%20control%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%26lt%3B%20%26gt%3B%20%3C%2FTD%3E%3CTD%3EPCIe%20AER%20error%20injector%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B*%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20ASPM%20control%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20x%20x%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EDebug%20PCI%20Express%20ASPM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Ex%20x%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERichard%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20kernel%20version%20is%20%3ALinux%20version%203.0.35-2666-gbdde708%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20kernel%20boot%20log%20%3A%3C%2FP%3E%3CP%3EUncompressing%20Linux...%20done%2C%20booting%20the%20kernel.%3CBR%20%2F%3ELinux%20version%203.0.35-2666-gbdde708%20(user%40ubuntu)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2320%20SMP%20PREEMPT%20Sun%20Jan%2011%2002%3A32%3A04%20PST%202015%3CBR%20%2F%3ECPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3CBR%20%2F%3EMachine%3A%20Freescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20Board%3CBR%20%2F%3EIgnoring%20unrecognised%20tag%200x54410008%3CBR%20%2F%3EMemory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3CBR%20%2F%3ECPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3CBR%20%2F%3EPERCPU%3A%20Embedded%207%20pages%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3CBR%20%2F%3EBuilt%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20194560%3CBR%20%2F%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CBR%20%2F%3EPID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3EDentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3CBR%20%2F%3EInode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3CBR%20%2F%3EMemory%3A%20512MB%20256MB%20%3D%20768MB%20total%3CBR%20%2F%3EMemory%3A%20765672k%2F765672k%20available%2C%20282904k%20reserved%2C%200K%20highmem%3CBR%20%2F%3EVirtual%20kernel%20memory%20layout%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200x80000000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(1024%20MB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80aa54f0%26nbsp%3B%26nbsp%3B%20(10658%20kB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80aa6000%20-%200x80b0a660%26nbsp%3B%26nbsp%3B%20(%20402%20kB)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b0a684%20-%200x80b58b8c%26nbsp%3B%26nbsp%3B%20(%20314%20kB)%3CBR%20%2F%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3EPreemptible%20hierarchical%20RCU%20implementation.%3CBR%20%2F%3ENR_IRQS%3A624%3CBR%20%2F%3EMXC%20GPIO%20hardware%3CBR%20%2F%3Esched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3CBR%20%2F%3Earm_max_freq%3D1GHz%3CBR%20%2F%3EMXC_Early%20serial%20console%20at%20MMIO%200x2020000%20(options%20'115200')%3CBR%20%2F%3Ebootconsole%20%5Bttymxc0%5D%20enabled%3CBR%20%2F%3EConsole%3A%20colour%20dummy%20device%2080x30%3CBR%20%2F%3ECalibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3CBR%20%2F%3Epid_max%3A%20default%3A%2032768%20minimum%3A%20301%3CBR%20%2F%3EMount-cache%20hash%20table%20entries%3A%20512%3CBR%20%2F%3ECPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3CBR%20%2F%3Ehw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3CBR%20%2F%3ECPU1%3A%20Booted%20secondary%20processor%3CBR%20%2F%3ECPU2%3A%20Booted%20secondary%20processor%3CBR%20%2F%3ECPU3%3A%20Booted%20secondary%20processor%3CBR%20%2F%3EBrought%20up%204%20CPUs%3CBR%20%2F%3ESMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3CBR%20%2F%3Eprint_constraints%3A%20dummy%3A%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2016%3CBR%20%2F%3Eprint_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%20700%20mV%20fast%20normal%3CBR%20%2F%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%3CBR%20%2F%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%3CBR%20%2F%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%3CBR%20%2F%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%3CBR%20%2F%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%3CBR%20%2F%3Ehw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3CBR%20%2F%3Ehw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3CBR%20%2F%3Ehw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3CBR%20%2F%3EL310%20cache%20controller%20enabled%3CBR%20%2F%3El2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3CBR%20%2F%3Ebio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3CBR%20%2F%3Emxs-dma%20mxs-dma-apbh%3A%20initialized%3CBR%20%2F%3Eprint_constraints%3A%20SPKVDD%3A%204200%20mV%3CBR%20%2F%3Eprint_constraints%3A%20vmmc%3A%203300%20mV%3CBR%20%2F%3Evgaarb%3A%20loaded%3CBR%20%2F%3ESCSI%20subsystem%20initialized%3CBR%20%2F%3Espi_imx%20imx6q-ecspi.0%3A%20probed%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbfs%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20hub%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20device%20driver%20usb%3CBR%20%2F%3EFreescale%20USB%20OTG%20Driver%20loaded%2C%20%24Revision%3A%201.55%20%24%3CBR%20%2F%3Emc_pfuze%201-0008%3A%20ID%3A%200%2CFull%20lay%3A%201%20%2CMetal%20lay%3A%201%3CBR%20%2F%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%20300%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203300%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203150%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20at%205000%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20at%201800%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20at%20750%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202800%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203000%20mV%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203300%20mV%3CBR%20%2F%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3CBR%20%2F%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3CBR%20%2F%3EMIPI%20CSI2%20driver%20module%20loaded%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%20Driver%20Version%201.0.24.%3CBR%20%2F%3EBluetooth%3A%20Core%20ver%202.16%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2031%3CBR%20%2F%3EBluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3CBR%20%2F%3EBluetooth%3A%20HCI%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20SCO%20socket%20layer%20initialized%3CBR%20%2F%3Ecfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3CBR%20%2F%3Emax17135%202-0048%3A%20PMIC%20MAX17135%20for%20eInk%20display%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20suspend%20method%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20resume%20method%3CBR%20%2F%3ESwitching%20to%20clocksource%20mxc_timer1%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%202%3CBR%20%2F%3EIP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3CBR%20%2F%3ETCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3CBR%20%2F%3ETCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20786432%20bytes)%3CBR%20%2F%3ETCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3CBR%20%2F%3ETCP%20reno%20registered%3CBR%20%2F%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%201%3CBR%20%2F%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20udp%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20tcp%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3CBR%20%2F%3EPMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3CBR%20%2F%3EStatic%20Power%20Management%20for%20Freescale%20i.MX6%3CBR%20%2F%3Ewait%20mode%20is%20enabled%20for%20i.MX6%3CBR%20%2F%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3CBR%20%2F%3EPM%20driver%20module%20loaded%3CBR%20%2F%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3CBR%20%2F%3EPCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3CBR%20%2F%3EIMX%20PCIe%20port%3A%20link%20up.%3CBR%20%2F%3E%3CSTRONG%3EPCI%3A%20bus0%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%3A%20bus1%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1000000-0x10fffff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%209%3A%20assigned%20%5Bmem%200x01100000-0x011fffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%207%3A%20assigned%20%5Bio%26nbsp%3B%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20assigned%20%5Bmem%200x01100000-0x01103fff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20set%20to%20%5Bmem%200x01100000-0x01103fff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1100000-0x1103fff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20assigned%20%5Bmem%200x01104000-0x01104fff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20set%20to%20%5Bmem%200x01104000-0x01104fff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1104000-0x1104fff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bio%26nbsp%3B%200x1e00000-0x1e000ff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bio%26nbsp%3B%200x1e00000-0x1e000ff%5D%20(PCI%20address%20%5B0x1e00000-0x1e000ff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20PCI%20bridge%20to%20%5Bbus%2001-01%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bio%26nbsp%3B%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%20disabled%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%200x01100000-0x011fffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EIMX%20usb%20wakeup%20probe%3C%2FSTRONG%3E%3CBR%20%2F%3Eadd%20wake%20up%20source%20irq%2075%3CBR%20%2F%3EIMX%20usb%20wakeup%20probe%3CBR%20%2F%3Ecpu%20regulator%20mode%3Aldo_bypass%3CBR%20%2F%3E_regulator_get%3A%20get()%20with%20no%20identifier%3CBR%20%2F%3Emx6_cpu_regulator_init%3A%20failed%20to%20get%20pu%20regulator%3CBR%20%2F%3Ei.MXC%20CPU%20frequency%20driver%3CBR%20%2F%3EJFFS2%20version%202.2.%20(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3Emsgmni%20has%20been%20set%20to%201495%3CBR%20%2F%3Ealg%3A%20No%20test%20for%20stdrng%20(krng)%3CBR%20%2F%3Eio%20scheduler%20noop%20registered%3CBR%20%2F%3Eio%20scheduler%20deadline%20registered%3CBR%20%2F%3Eio%20scheduler%20cfq%20registered%20(default)%3CBR%20%2F%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20driver%20probed%3CBR%20%2F%3EMIPI%20DSI%20driver%20module%20loaded%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%20register%20mxc%20display%20driver%20hdmi%3CBR%20%2F%3Emxc_hdmi%20mxc_hdmi%3A%20Detected%20HDMI%20controller%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%20Name%20-%202.073M9%3CBR%20%2F%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3EConsole%3A%20switching%20to%20colour%20frame%20buffer%20device%20240x67%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20register%20mxc%20display%20driver%20ldb%3CBR%20%2F%3E_regulator_get%3A%20get()%20with%20no%20identifier%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20register%20mxc%20display%20driver%20lcd%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20ipu0-di0%20already%20in%20use%3CBR%20%2F%3Emxc_sdc_fb%3A%20probe%20of%20mxc_sdc_fb.2%20failed%20with%20error%20-16%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20register%20mxc%20display%20driver%20ldb%3CBR%20%2F%3Eimx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3CBR%20%2F%3Eimx-sdma%20imx-sdma%3A%20initialized%3CBR%20%2F%3ESerial%3A%20IMX%20driver%3CBR%20%2F%3Eimx-uart.2%3A%20ttymxc2%20at%20MMIO%200x21ec000%20(irq%20%3D%2060)%20is%20a%20IMX%3CBR%20%2F%3Eimx-uart.0%3A%20ttymxc0%20at%20MMIO%200x2020000%20(irq%20%3D%2058)%20is%20a%20IMX%3CBR%20%2F%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3CBR%20%2F%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3CBR%20%2F%3Eloop%3A%20module%20loaded%3CBR%20%2F%3ENo%20sata%20disk.%3CBR%20%2F%3Em25p80%20spi0.0%3A%20found%20m25p32%2C%20expected%20sst25vf016b%3CBR%20%2F%3Em25p80%20spi0.0%3A%20m25p32%20(4096%20Kbytes)%3CBR%20%2F%3ECreating%202%20MTD%20partitions%20on%20%22m25p80%22%3A%3CBR%20%2F%3E0x000000000000-0x000000100000%20%3A%20%22bootloader%22%3CBR%20%2F%3E0x000000100000-0x000000400000%20%3A%20%22kernel%22%3CBR%20%2F%3EGPMI%20NAND%20driver%20registered.%20(IMX)%3CBR%20%2F%3Evcan%3A%20Virtual%20CAN%20interface%20driver%3CBR%20%2F%3ECAN%20device%20driver%20interface%3CBR%20%2F%3Eflexcan%20netdevice%20driver%3CBR%20%2F%3EFEC%20Ethernet%20Driver%3CBR%20%2F%3Efec_enet_mii_bus%3A%20probed%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3Ehub%201-0%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3Ehub%201-0%3A1.0%3A%201%20port%20detected%3CBR%20%2F%3Eadd%20wake%20up%20source%20irq%2072%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3Ehub%202-0%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3Ehub%202-0%3A1.0%3A%201%20port%20detected%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_acm%3CBR%20%2F%3Ecdc_acm%3A%20USB%20Abstract%20Control%20Model%20driver%20for%20USB%20modems%20and%20ISDN%20adapters%3CBR%20%2F%3EInitializing%20USB%20Mass%20Storage%20driver...%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3CBR%20%2F%3EUSB%20Mass%20Storage%20support%20registered.%3CBR%20%2F%3EARC%20USBOTG%20Device%20Controller%20driver%20(1%20August%202005)%3CBR%20%2F%3Emousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3CBR%20%2F%3Einput%3A%20gpio-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3CBR%20%2F%3Einput%3A%20max11801_ts%20as%20%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3CBR%20%2F%3Eegalax_ts%201-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3CBR%20%2F%3Eegalax_ts%3A%20probe%20of%201-0004%20failed%20with%20error%20-5%3CBR%20%2F%3Einput%3A%20eGalax%20Touch%20Screen%20as%20%2Fdevices%2Fplatform%2Fimx-i2c.2%2Fi2c-2%2F2-0004%2Finput%2Finput2%3CBR%20%2F%3Eelan%20-%20Read%20Hello%20Packet%20Failed%3CBR%20%2F%3Eelan-touch%3A%20probe%20of%202-0010%20failed%20with%20error%20-22%3CBR%20%2F%3Einput%3A%20isl29023%20light%20sensor%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput3%3CBR%20%2F%3Eisl29023%202-0044%3A%20driver%20version%201.0%20enabled%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20suspend%20method%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20resume%20method%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%3A%20rtc%20core%3A%20registered%20snvs_rtc%20as%20rtc0%3CBR%20%2F%3Ei2c%20%2Fdev%20entries%20driver%3CBR%20%2F%3ELinux%20video%20capture%20interface%3A%20v2.00%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video16%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video17%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video18%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video19%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video20%3CBR%20%2F%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3CBR%20%2F%3Einput%3A%20mag3110%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput4%3CBR%20%2F%3Emag3110%202-000e%3A%20mag3110%20is%20probed%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20suspend%20method%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20resume%20method%3CBR%20%2F%3Einput%3A%20mma845x%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput5%3CBR%20%2F%3Eimx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3CBR%20%2F%3EBluetooth%3A%20Virtual%20HCI%20driver%20ver%201.3%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20driver%20ver%202.2%3CBR%20%2F%3EBluetooth%3A%20HCIATH3K%20protocol%20initialized%3CBR%20%2F%3EBluetooth%3A%20Generic%20Bluetooth%20USB%20driver%20ver%200.6%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20btusb%3CBR%20%2F%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3CBR%20%2F%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Emmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.3%5D%20using%20DMA%3CBR%20%2F%3Emmc1%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.1%5D%20using%20DMA%3CBR%20%2F%3Emmc2%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.2%5D%20using%20DMA%3CBR%20%2F%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3CBR%20%2F%3EVPU%20initialized%3CBR%20%2F%3Emxc_asrc%20registered%3CBR%20%2F%3EGalcore%20version%204.6.9.6622%3CBR%20%2F%3EThermal%20calibration%20data%20is%200x55c4af7d%3CBR%20%2F%3EThermal%20sensor%20with%20ratio%20%3D%20176%3CBR%20%2F%3EAnatop%20Thermal%20registered%20as%20thermal_zone0%3CBR%20%2F%3Eanatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbhid%3CBR%20%2F%3Eusbhid%3A%20USB%20HID%20core%20driver%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3CBR%20%2F%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3A%20MXC%20HDMI%20Audio%3CBR%20%2F%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20Codec%20Driver%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20suspend%20method%3CBR%20%2F%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20resume%20method%3CBR%20%2F%3Ewm8962%200-001a%3A%20customer%20id%200%20revision%20D%3CBR%20%2F%3Einput%3A%20WM8962%20Beep%20Generator%20as%20%2Fdevices%2Fplatform%2Fimx-i2c.0%2Fi2c-0%2F0-001a%2Finput%2Finput6%3CBR%20%2F%3Easoc%3A%20wm8962%20%26lt%3B-%26gt%3B%20imx-ssi.1%20mapping%20ok%3CBR%20%2F%3Einput%3A%20wm8962-audio%20DMIC%20as%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput7%3CBR%20%2F%3Einput%3A%20wm8962-audio%20Ext%20Spk%20as%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput8%3CBR%20%2F%3Eimx_3stack%20asoc%20driver%3CBR%20%2F%3Easoc%3A%20mxc-hdmi-soc%20%26lt%3B-%26gt%3B%20imx-hdmi-soc-dai.0%20mapping%20ok%3CBR%20%2F%3EALSA%20device%20list%3A%3CBR%20%2F%3E%26nbsp%3B%20%230%3A%20wm8962-audio%3CBR%20%2F%3E%26nbsp%3B%20%231%3A%20imx-hdmi-soc%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2026%3CBR%20%2F%3ETCP%20cubic%20registered%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2017%3CBR%20%2F%3Ecan%3A%20controller%20area%20network%20core%20(rev%2020090105%20abi%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2029%3CBR%20%2F%3Ecan%3A%20raw%20protocol%20(rev%2020090105)%3CBR%20%2F%3Ecan%3A%20broadcast%20manager%20protocol%20(rev%2020090105%20t)%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20ver%201.11%3CBR%20%2F%3EBluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3CBR%20%2F%3Emmc0%3A%20new%20high%20speed%20DDR%20MMC%20card%20at%20address%200001%3CBR%20%2F%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%3CBR%20%2F%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20partition%201%202.00%20MiB%3CBR%20%2F%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM08G%20partition%202%202.00%20MiB%3CBR%20%2F%3E%20mmcblk0%3A%20p1%3CBR%20%2F%3EBluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3CBR%20%2F%3E%20mmcblk0boot1%3A%20unknown%20partition%20table%3CBR%20%2F%3EBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3CBR%20%2F%3E%20mmcblk0boot0%3A%20unknown%20partition%20table%3CBR%20%2F%3Elib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3CBR%20%2F%3EVFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3CBR%20%2F%3EBus%20freq%20driver%20module%20loaded%3CBR%20%2F%3EBus%20freq%20driver%20Enabled%3CBR%20%2F%3Emxc_dvfs_core_probe%3CBR%20%2F%3EDVFS%20driver%20module%20loaded%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20incomplete%20constraints%2C%20leaving%20on%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20incomplete%20constraints%2C%20leaving%20on%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20incomplete%20constraints%2C%20leaving%20on%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20incomplete%20constraints%2C%20leaving%20on%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%3A%20setting%20system%20clock%20to%201970-01-01%2000%3A00%3A01%20UTC%20(1)%3CBR%20%2F%3EWaiting%20for%20root%20device%20%2Fdev%2Fmmcblk1p1...%3CBR%20%2F%3Emmc2%3A%20new%20high%20speed%20SDHC%20card%20at%20address%201234%3CBR%20%2F%3Emmcblk1%3A%20mmc2%3A1234%20SA04G%203.63%20GiB%3CBR%20%2F%3E%20mmcblk1%3A%20p1%3CBR%20%2F%3EEXT3-fs%3A%20barriers%20not%20enabled%3CBR%20%2F%3Ekjournald%20starting.%26nbsp%3B%20Commit%20interval%205%20seconds%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20using%20internal%20journal%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20recovery%20complete%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20mounted%20filesystem%20with%20writeback%20data%20mode%3CBR%20%2F%3EVFS%3A%20Mounted%20root%20(ext3%20filesystem)%20on%20device%20179%3A25.%3CBR%20%2F%3EFreeing%20init%20memory%3A%20212K%3CBR%20%2F%3Estarting%20pid%201468%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3CBR%20%2F%3EMounting%20%2Fproc%20and%20%2Fsys%3CBR%20%2F%3EStarting%20the%20hotplug%20events%20dispatcher%20udevd%3CBR%20%2F%3Eudevd%20(1477)%3A%20%2Fproc%2F1477%2Foom_adj%20is%20deprecated%2C%20please%20use%20%2Fproc%2F1477%2Foom_score_adj%20instead.%3CBR%20%2F%3ESynthesizing%20initial%20hotplug%20events%3CBR%20%2F%3ESetting%20the%20hostname%20to%20freescale%3CBR%20%2F%3EMounting%20filesystems%3CBR%20%2F%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3CBR%20%2F%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3CBR%20%2F%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3CBR%20%2F%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3CBR%20%2F%3Emount%3A%20mounting%20usbfs%20on%20%2Fproc%2Fbus%2Fusb%20failed%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Estarting%20pid%203292%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3CBR%20%2F%3Estarting%20pid%203298%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%204.6.2%2020110630%20(prerelease)%3CBR%20%2F%3Eroot%20filesystem%20built%20on%20Wed%2C%2031%20Dec%202014%2021%3A03%3A35%20-0800%3CBR%20%2F%3EFreescale%20Semiconductor%2C%20Inc.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20command%3CSTRONG%3E%20lspci%3C%2FSTRONG%3E%20output%20%3A%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20Class%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20Class%200200%3A%2010ec%3A8168%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Then%20I%20load%20the%20RTL8111E%20driver%2C%20and%20config%20the%20interface%20eth1%3A%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20insmod%20r8168.ko%3C%2FP%3E%3CP%3Er8168%20Gigabit%20Ethernet%20driver%208.039.00-NAPI%20loaded%3C%2FP%3E%3CP%3Er8168%200000%3A01%3A00.0%3A%20no%20MSI.%20Back%20to%20INTx.%3C%2FP%3E%3CP%3Er8168%3A%20This%20product%20is%20covered%20by%20one%20or%20more%20of%20the%20following%20patents%3A%20US6%2C570%2C884%2C%20US6%2C115%2C776%2C%20and%20US6%2C327%2C625.%3C%2FP%3E%3CP%3E%3CSPAN%3Er8168%26nbsp%3B%20Copyright%20(C)%202014%26nbsp%3B%20Realtek%20NIC%20software%20team%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20This%20program%20comes%20with%20ABSOLUTELY%20NO%20WARRANTY%3B%20for%20details%2C%20please%20see%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20This%20is%20free%20software%2C%20and%20you%20are%20welcome%20to%20redistribute%20it%20under%20certain%20conditions%3B%20see%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CVERS%3E%3C%2FVERS%3Eeth1%3A%200xc0b86000%2C%2000%3Ae0%3A4c%3A68%3Aa2%3A04%2C%20IRQ%20155%3CBR%20%2F%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20r8168%3A%20eth1%3A%20link%20up%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20ifconfig%3CBR%20%2F%3Eeth1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20inet%20addr%3A192.168.0.2%26nbsp%3B%20Bcast%3A192.168.0.255%26nbsp%3B%20Mask%3A255.255.255.0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20UP%20BROADCAST%20RUNNING%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Interrupt%3A155%20Base%20address%3A0x6000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20kernel%20coredump%20when%20I%20run%20the%20command%20%22PING%20192.168.0.1%22%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20ping%20192.168.0.1%3C%2FP%3E%3CP%3EPING%20192.168.0.1%20(192.168.0.1)%3A%205kernel%20BUG%20at%20arch%2Farm%2Fmm%2Fdma-mapping.c%3A478!%3C%2FP%3E%3CP%3E6%20data%20bytes%3C%2FP%3E%3CP%3EUnable%20to%20handle%20kernel%20NULL%20pointer%20dereference%20at%20virtual%20address%2000000000%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3CP%3EInternal%20error%3A%20Oops%3A%20817%20%5B%231%5D%20PREEMPT%20SMP%3C%2FP%3E%3CP%3EModules%20linked%20in%3A%20r8168%20%5Blast%20unloaded%3A%20r8168%5D%3C%2FP%3E%3CP%3ECPU%3A%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Not%20tainted%26nbsp%3B%20(3.0.35-2666-gbdde708%20%2320)%3C%2FP%3E%3CP%3EPC%20is%20at%20__bug%2B0x1c%2F0x28%3C%2FP%3E%3CP%3ELR%20is%20at%20__bug%2B0x18%2F0x28%3C%2FP%3E%3CP%3Epc%20%3A%20%5B%26lt%3B800462c8%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lr%20%3A%20%5B%26lt%3B800462c4%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20psr%3A%2060000193%3C%2FP%3E%3CP%3Esp%20%3A%20bffb5dc8%26nbsp%3B%20ip%20%3A%20c097a000%26nbsp%3B%20fp%20%3A%20bfb80000%3C%2FP%3E%3CP%3Er10%3A%200000021c%26nbsp%3B%20r9%20%3A%207f084544%26nbsp%3B%20r8%20%3A%20ff9f2000%3C%2FP%3E%3CP%3Er7%20%3A%20ff9f8000%26nbsp%3B%20r6%20%3A%2000000001%26nbsp%3B%20r5%20%3A%2000000012%26nbsp%3B%20r4%20%3A%20ff9f2000%3C%2FP%3E%3CP%3Er3%20%3A%2000000000%26nbsp%3B%20r2%20%3A%2080ad329c%26nbsp%3B%20r1%20%3A%2060000193%26nbsp%3B%20r0%20%3A%2000000033%3C%2FP%3E%3CP%3EFlags%3A%20nZCv%26nbsp%3B%20IRQs%20off%26nbsp%3B%20FIQs%20on%26nbsp%3B%20Mode%20SVC_32%26nbsp%3B%20ISA%20ARM%26nbsp%3B%20Segment%20kernel%3C%2FP%3E%3CP%3EControl%3A%2010c53c7d%26nbsp%3B%20Table%3A%204a70404a%26nbsp%3B%20DAC%3A%2000000015%3C%2FP%3E%3CP%3EProcess%20swapper%20(pid%3A%200%2C%20stack%20limit%20%3D%200xbffb42f0)%3C%2FP%3E%3CP%3EStack%3A%20(0xbffb5dc8%20to%200xbffb6000)%3C%2FP%3E%3CP%3E5dc0%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b16930%208004cb08%2000000012%2000400000%200000002a%207f0489f8%3C%2FP%3E%3CP%3E5de0%3A%2000000000%2080000000%2000000000%20bfcbfd80%20bfb804b4%20ff9f8000%20ff9f8000%2080000113%3C%2FP%3E%3CP%3E5e00%3A%20c0b86000%20ba14f090%2000000000%2060004980%20bfcbfd80%20bfb80000%2000000000%2080abc11c%3C%2FP%3E%3CP%3E5e20%3A%207f084544%20bfdb8a20%2080439354%208042f11c%2000000006%20bfb8018c%20bfcd0608%20bfe7ed02%3C%2FP%3E%3CP%3E5e40%3A%20bfb80000%20bfe7ef00%20bfb80000%20bfe7ef5c%20bfcbfd80%20bfdb8a20%2000000000%2000000002%3C%2FP%3E%3CP%3E5e60%3A%2080439354%208044a694%20bfdb8a20%20bfe7ef00%20bfcbfd80%20bfb80000%20bfdb8a20%20bfe7ef5c%3C%2FP%3E%3CP%3E5e80%3A%2000000000%208042f5a0%20bfe7ef5c%20bfe7ee00%2000000000%2000000000%2000000000%20bfcbfb40%3C%2FP%3E%3CP%3E5ea0%3A%20bfb80000%200100a8c0%200200a8c0%2000000000%20bfe7ee00%208047d8fc%200200a8c0%2000000000%3C%2FP%3E%3CP%3E5ec0%3A%20bfcd0608%2000000000%2000000010%20bfcbfb40%20bfcbfb5c%20bfcbfb54%20bfcbfcc0%2000000000%3C%2FP%3E%3CP%3E5ee0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3C%2FP%3E%3CP%3E5f00%3A%200000024e%207abe5a80%20bffb5f08%20bffb5f08%2000000000%2000000141%2080aa8044%20bffb4000%3C%2FP%3E%3CP%3E5f20%3A%2000000103%2080b102e0%2000000002%2080aa8040%2000000001%208007d078%207a264549%200000024e%3C%2FP%3E%3CP%3E5f40%3A%207a264549%200000000a%207a264549%20bffb4000%20bffb4000%208003bc00%2000000000%2000000002%3C%2FP%3E%3CP%3E5f60%3A%20bffb4000%2000000000%2000000000%208007d5b4%2080abbcc0%208003d2e0%20ffffffff%20f2a00100%3C%2FP%3E%3CP%3E5f80%3A%2000000002%2000000002%2000000001%2080042a0c%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3C%2FP%3E%3CP%3E5fe0%3A%204ffb806a%2000000015%2010c03c7d%2080b0a8f8%201000406a%2010511694%2081022cce%2022705254%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3EException%20stack(0xbffb5f90%20to%200xbffb5fd8)%3C%2FP%3E%3CP%3E5f80%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3ECode%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3C%2FP%3E%3CP%3Eclk_enable%20cannot%20be%20called%20in%20an%20interrupt%20context%3C%2FP%3E%3CP%3E%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%20from%20%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%20from%20%5B%26lt%3B8039c4bc%26gt%3B%5D%20(ipu_clear_irq%2B0x18%2F0x8c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8039c4bc%26gt%3B%5D%20(ipu_clear_irq%2B0x18%2F0x8c)%20from%20%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%3C%2FP%3E%3CP%3E%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%20from%20%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%3C%2FP%3E%3CP%3E%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%20from%20%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%3C%2FP%3E%3CP%3E%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%20from%20%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%3C%2FP%3E%3CP%3E%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%20from%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%3C%2FP%3E%3CP%3E%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%20from%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%20from%20%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%3C%2FP%3E%3CP%3E%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%20from%20%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%3C%2FP%3E%3CP%3E%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%20from%20%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%20from%20%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%20from%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3C%2FP%3E%3CP%3EException%20stack(0xbffb5d80%20to%200xbffb5dc8)%3C%2FP%3E%3CP%3E5d80%3A%2000000033%2060000193%2080ad329c%2000000000%20ff9f2000%2000000012%2000000001%20ff9f8000%3C%2FP%3E%3CP%3E5da0%3A%20ff9f2000%207f084544%200000021c%20bfb80000%20c097a000%20bffb5dc8%20800462c4%20800462c8%3C%2FP%3E%3CP%3E5dc0%3A%2060000193%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%20from%20%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3EException%20stack(0xbffb5f90%20to%200xbffb5fd8)%3C%2FP%3E%3CP%3E5f80%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3Ekernel%20BUG%20at%20arch%2Farm%2Fplat-mxc%2Fclock.c%3A101!%3C%2FP%3E%3CP%3EUnable%20to%20handle%20kernel%20NULL%20pointer%20dereference%20at%20virtual%20address%2000000000%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EWhat's%20kernel%20version%20used%20by%20customer%20and%20what's%20the%20activities%20of%20the%20RTL8111e%20when%20it%20report%20the%20kernel%20panic%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOne%20customer%20uses%20RTL8111e%20and%20reported%20kernel%20panic%20issue%2C%20%3C%2FP%3E%3CP%3Eeth1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20inet%20addr%3A192.168.0.2%26nbsp%3B%20Bcast%3A192.168.0.255%26nbsp%3B%20Mask%3A255.255.255.0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20UP%20BROADCAST%20RUNNING%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RX%20packets%3A12%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RX%20bytes%3A1002%20(1002.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Interrupt%3A155%20Base%20address%3A0xe000%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20ping%20192.168.0.1%3CBR%20%2F%3EPING%20192.168.0.1%20(192.168.0.1)%3A%2056%20data%20bytes%3CBR%20%2F%3Ekernel%20BUG%20at%20arch%2Farm%2Fmm%2Fdma-mapping.c%3A478!%3CBR%20%2F%3EUnable%20to%20handle%20kernel%20NULL%20pointer%20dereference%20at%20virtual%20address%2000000000%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%5B00000000%5D%20*pgd%3D00000000%3CBR%20%2F%3EInternal%20error%3A%20Oops%3A%20817%20%5B%231%5D%20PREEMPT%20SMP%3CBR%20%2F%3EModules%20linked%20in%3A%20r8168%3CBR%20%2F%3ECPU%3A%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Not%20tainted%26nbsp%3B%20(3.0.35-2666-gbdde708%20%2320)%3CBR%20%2F%3EPC%20is%20at%20__bug%2B0x1c%2F0x28%3CBR%20%2F%3ELR%20is%20at%20__bug%2B0x18%2F0x28%3CBR%20%2F%3Epc%20%3A%20%5B%26lt%3B800462c8%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lr%20%3A%20%5B%26lt%3B800462c4%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20psr%3A%2060000193%3CBR%20%2F%3Esp%20%3A%20bffb5dc8%26nbsp%3B%20ip%20%3A%20c097a000%26nbsp%3B%20fp%20%3A%20ba074000%3CBR%20%2F%3Er10%3A%200000021c%26nbsp%3B%20r9%20%3A%207f03d544%26nbsp%3B%20r8%20%3A%20ff9f2000%3CBR%20%2F%3Er7%20%3A%20ff9f8000%26nbsp%3B%20r6%20%3A%2000000001%26nbsp%3B%20r5%20%3A%2000000012%26nbsp%3B%20r4%20%3A%20ff9f2000%3CBR%20%2F%3Er3%20%3A%2000000000%26nbsp%3B%20r2%20%3A%2080ad329c%26nbsp%3B%20r1%20%3A%2060000193%26nbsp%3B%20r0%20%3A%2000000033%3CBR%20%2F%3EFlags%3A%20nZCv%26nbsp%3B%20IRQs%20off%26nbsp%3B%20FIQs%20on%26nbsp%3B%20Mode%20SVC_32%26nbsp%3B%20ISA%20ARM%26nbsp%3B%20Segment%20kernel%3CBR%20%2F%3EControl%3A%2010c53c7d%26nbsp%3B%20Table%3A%204a2b404a%26nbsp%3B%20DAC%3A%2000000015%3CBR%20%2F%3EProcess%20swapper%20(pid%3A%200%2C%20stack%20limit%20%3D%200xbffb42f0)%3CBR%20%2F%3EStack%3A%20(0xbffb5dc8%20to%200xbffb6000)%3CBR%20%2F%3E5dc0%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b16930%208004cb08%2000000012%2000400000%200000002a%207f0019f8%3CBR%20%2F%3E5de0%3A%2000000000%2080000000%2000000000%20bfd92480%20ba0744b4%20ff9f8000%20ff9f8000%2080000113%3CBR%20%2F%3E5e00%3A%20c0b7e000%20bfc938a0%2000000000%2060004980%20bfd92480%20ba074000%2000000000%2080abc11c%3CBR%20%2F%3E5e20%3A%207f03d544%20bfd82480%2080439354%208042f11c%2000000006%20ba07418c%20bfc1ec08%20bfd3dd02%3CBR%20%2F%3E5e40%3A%20ba074000%20bfd3df00%20ba074000%20bfd3df5c%20bfd92480%20bfd82480%2000000000%2000000002%3CBR%20%2F%3E5e60%3A%2080439354%208044a694%20bfd82480%20bfd3df00%20bfd92480%20ba074000%20bfd82480%20bfd3df5c%3CBR%20%2F%3E5e80%3A%2000000000%208042f5a0%20bfd3df5c%20bfd3de00%2000000000%2000000000%2000000000%20bfd92240%3CBR%20%2F%3E5ea0%3A%20ba074000%200100a8c0%200200a8c0%2000000000%20bfd3de00%208047d8fc%200200a8c0%2000000000%3CBR%20%2F%3E5ec0%3A%20bfc1ec08%2000000000%2000000010%20bfd92240%20bfd9225c%20bfd92254%20bfd923c0%2000000000%3CBR%20%2F%3E5ee0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3CBR%20%2F%3E5f00%3A%20000000fa%208436ae00%20bffb5f08%20bffb5f08%2000000000%2000000141%2080aa8044%20bffb4000%3CBR%20%2F%3E5f20%3A%2000000103%2080b102e0%2000000002%2080aa8040%2000000001%208007d078%20839e72da%20000000fa%3CBR%20%2F%3E5f40%3A%20839e72da%200000000a%20839e72da%20bffb4000%20bffb4000%208003bc00%2000000000%2000000002%3CBR%20%2F%3E5f60%3A%20bffb4000%2000000000%2000000000%208007d5b4%2080abbcc0%208003d2e0%20ffffffff%20f2a00100%3CBR%20%2F%3E5f80%3A%2000000002%2000000002%2000000001%2080042a0c%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3CBR%20%2F%3E5fe0%3A%204ffb806a%2000000015%2010c03c7d%2080b0a8f8%201000406a%2010511694%208102080c%2022705244%3CBR%20%2F%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3CBR%20%2F%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3CBR%20%2F%3E%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3EException%20stack(0xbffb5f90%20to%200xbffb5fd8)%3CBR%20%2F%3E5f80%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3ECode%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3CBR%20%2F%3E%20clk_enable%20cannot%20be%20called%20in%20an%20interrupt%20context%3CBR%20%2F%3E%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3CBR%20%2F%3E%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%20from%20%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%3CBR%20%2F%3E%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%20from%20%5B%26lt%3B8039c4bc%26gt%3B%5D%20(ipu_clear_irq%2B0x18%2F0x8c)%3CBR%20%2F%3E%5B%26lt%3B8039c4bc%26gt%3B%5D%20(ipu_clear_irq%2B0x18%2F0x8c)%20from%20%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%3CBR%20%2F%3E%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%20from%20%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%3CBR%20%2F%3E%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%20from%20%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%3CBR%20%2F%3E%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%20from%20%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%3CBR%20%2F%3E%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%20from%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%3CBR%20%2F%3E%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%20from%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3CBR%20%2F%3E%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%20from%20%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%3CBR%20%2F%3E%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%20from%20%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%3CBR%20%2F%3E%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%20from%20%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%3CBR%20%2F%3E%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%20from%20%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%3CBR%20%2F%3E%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%20from%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3CBR%20%2F%3EException%20stack(0xbffb5d80%20to%200xbffb5dc8)%3CBR%20%2F%3E5d80%3A%2000000033%2060000193%2080ad329c%2000000000%20ff9f2000%2000000012%2000000001%20ff9f8000%3CBR%20%2F%3E5da0%3A%20ff9f2000%207f03d544%200000021c%20ba074000%20c097a000%20bffb5dc8%20800462c4%20800462c8%3CBR%20%2F%3E5dc0%3A%2060000193%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%20from%20%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3CBR%20%2F%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3CBR%20%2F%3E%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3EException%20stack(0xbffb5f90%20to%200xbffb5fd8)%3CBR%20%2F%3E5f80%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5fa0%3A%20bffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3Ekernel%20BUG%20at%20arch%2Farm%2Fplat-mxc%2Fclock.c%3A101!%3CBR%20%2F%3EUnable%20to%20handle%20kernel%20NULL%20pointer%20dereference%20at%20virtual%20address%2000000000%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHW%20modifications%20is%20mandatory%20required%2C%20since%20the%20REF%20CLK%20is%20sourced%20from%20%3CSPAN%20class%3D%22SpellE%22%3Epll%3C%2FSPAN%3E%20in%20the%20original%20imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20hw%20design.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20successfully%20run%20the%20validation%20system%20with%20the%20two%20Sabre_Lite%20boards.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENow%20I%20am%20trying%20to%20run%20PCIe%20endpoint%20(Sabre_Lite)%20with%20other%20Root%20Complexes%20(like%20PC).%20My%20link%20is%20not%20up%20when%20I%20connect%20my%20EP%20to%20other%20RC%20than%20the%20Sabre_Lite.%20Is%20using%20internal%20ref%20125Mhz%20clock%20be%20the%20issue.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESince%20Sabre_Lite%20PCIe%20connector%20does%20not%20have%20input%20CLK%20signal%2C%20will%20I%20be%20a%20needing%20hardware%20modification%20If%20I%20have%20to%20pass%20RC%20reference%20clock%20to%20EP%3F.%3C%2FP%3E%3CP%3EIf%20yes%2C%20can%20hardware%20modification%20be%20prevented.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EHaider%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3CBR%20%2F%3EAs%20I%20know%20that%20the%20MAX_PAY_LOAD_SIZE%20of%20imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20is%20128bytes.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThe%20actual%20data%20size%20on%20one%20%3CSPAN%20class%3D%22SpellE%22%3Etlp%3C%2FSPAN%3E%20is%20decided%20by%20the%20cache-burst%20capability%20of%20the%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20master.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThat's%20why%20the%20data%20size%20in%20the%20imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%2F%3CSPAN%20class%3D%22SpellE%22%3Erc%3C%2FSPAN%3E%20validation%20is%2032%20when%20arm%20core%20is%20used%20as%20the%20bus%20master.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EAnd%20the%20data%20size%20is%2064%20when%20IPU(DMA)%20used%20as%20the%20bus%20master.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20using%20the%20same%20setup%20to%20validate%20PCIe%20througput%20from%20imx6%20end%20point%20to%20root%20complex.%20I%20want%20to%20know%20how%20can%20we%20change%20TLP%20size%20when%20arm%20core%20is%20used%20as%20bus%20master.%20More%20importantly%2C%20how%20tlp%20paload%20size%20can%20have%20any%20impact%20on%20read%20throughput%20when%20arm%20core%20can%20only%20read%204%20bytes%20at%20a%20time.%20Why%20are%20we%20setting%20TLP%20size%20to%2032%20bytes%20when%20arm%20core%20is%20used%20as%20bus%20master%3F%20Does%20it%20have%20any%20affect%20on%20read%20performance%3F%20or%20we%20just%20get%20same%20numbers%20irrespective%20of%20TLP%20size%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI've%20been%20trying%20to%20repeat%20this%20validation%20on%20an%20i.MX6DL%20setup%20but%20failed%20so%20far.%20Can%20you%20see%20any%20reason%20why%20such%20setup%20fails%3F%20It%20looks%20like%20it%20fails%20on%20hardware%20access%20after%20link%20training%20has%20been%20started.%20A%20lot%20of%20code%20is%20%22labeled%22%20iMX6Q%20but%20used%20for%20iMX6DL%2C%20I've%20reviewed%20it%20and%20can't%20find%20anything%20obvious%20wrong%2C%20most%20differences%20are%20handled%20by%20if%20iMX6Q%20or%20iMX6DL%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMy%20community%20post%20on%20the%20matter.%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F330406%22%20target%3D%22_blank%22%3EHave%20anyone%20successfully%20reproduced%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%20on%20an%20i.MX6DL%20setup%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAny%20feedback%20is%20appreciated.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ERegards%3C%2FP%3E%3CP%3EAndreas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3EWe%20currently%20try%20to%20archive%20high%20bandwidth%20data%20transfers%20from%20a%20Xilinx%20Artix7%20FPGA%20to%20the%20DDR%20of%20the%20iMX6.%20We%20finally%20got%20something%20running%20but%20unfortunately%20the%20data%20transfer%20bandwidth%20was%20not%20as%20good%20as%20we%20would%20have%20expected%20on%20the%20i.MX6.%20We%20generate%20a%20data%20stream%20within%20the%20FPGA%20using%20a%20clock%20counter%20and%20send%20it%20using%20the%20FPGA%20as%20a%20bus%20master%20to%20the%20iMX6%20RC.%20By%20subtracting%20the%20last%20transferred%20data%20word%20from%20the%20first%20we%20calculated%20the%20data%20transfer%20speed%2C%20so%20calculation%20should%20not%20depend%20on%20any%20CPU%20latencies.%20Some%20precision%20might%20get%20lost%2C%20as%20we%20currently%20sending%20the%20generated%20clock%20values%20to%20the%20PCIe%20core%20of%20the%20FPGA%20that%20buffers%20them.%20As%20we%20could%20see%20in%20chipscope%20the%20iMX6%20always%20has%20some%20stalls%20on%20the%20PCIe%20bus%20after%20128bytes%20(probably%20the%20payload%20size%20limitation)%2C%20but%20we%20can%20only%20see%20gaps%20in%20the%20received%20data%20words%20on%20the%20iMX6'%20DDR%20after%20about%202048%20bytes%20so%20there%20seem%20to%20be%20a%20buffer%20in%20the%20Xilinx%20PCIe%20core%2C%20that%20makes%20the%20timing%20values%20not%20synchronous%20to%20the%20real%20PCIe%20data%20packages.%20But%20it%20shouldn't%20have%20a%20big%20impact%20on%20the%20overall%20calculation%20of%20bandwidth%20speed.%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3ENevertheless%20when%20transferring%20a%20512KByte%20buffer%20from%20the%20FPGA%20to%20the%20i.MX6%20we%20got%20270MB%2Fs%20while%20we%20got%20~400MB%2Fs%20on%20an%20x86%20system%20with%20one%20PCIe%202.0%20lane.%20%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3EIs%20there%20any%20obvious%20reason%20(apart%20from%20the%20maximum%20payload%20size%20of%20128byte%20on%20the%20i.MX6)%20that%20the%20transfer%20rate%20is%20only%20that%20low%3F%20As%20the%20maximum%20payload%20size%20on%20the%20FPGA%20is%20currently%20limited%20to%20256%20bytes%20anyway%20it%20shouldn't%20have%20a%20very%20big%20effect%20in%20comparison%20to%20the%20x86%20system.%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3EI'm%20also%20wondering%20why%20in%20your%20case%20you%20only%20reach%20344MB%2Fs%20as%20a%20maximum.%20Shouldn't%20the%20PCIe%20interface%20allow%20a%20bit%20higher%20bandwidth%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAnother%20question%20%3A%20any%20example%20on%20how%20to%20sent%20PCIe%20interrupt%20from%20the%20EP%20to%20the%20RC%20%3F%20I%20have%20tested%20various%20settings%20with%20the%20iATU%2C%20but%20no%20result%20up%20to%20now.%20Any%20ideas%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20this%20post%2C%20works%20perfectly.%3C%2FP%3E%3CP%3ELittle%20question%20%3A%20if%20i%20create%20some%204K%20IO%20in%20BAR0%2C%20they%20are%20seen%20at%200x1E00000%20on%20RC.%20Thats'%20fine.%20But%20how%20to%20read%2Fwrite%20the%20IO%20space%20from%20the%20endpoint%20itself%20%3F%20Where%20is%20it%20allocated%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3A%3C%2FP%3E%3CP%3EImx%20pcie%20can%20use%20external%20100m%20ref%20clk%2C%20after%20the%20responding%20sw%20modifications.%3C%2FP%3E%3CP%3EThe%20modifications%20can%20be%20made%20reference%20to%20the%20external%20OSC%20usage%20topic%20in%20this%20community.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3CP%3ERichard%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESent%20from%20Huawei%20Mobile%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ealeksandr%20Muraviov%20%3CADMIN%3E%E7%BC%96%E5%86%99%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enew%20comment%20by%20aleksandr%20Muraviov%26lt%3B%26gt%3B%20View%20all%20comments%20on%20this%20document%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20PCIe%20from%20the%20PC%20always%20sends%20the%20CLK%20signal%2C%20it's%20not%20an%20option%2C%20it's%20mandatory%20!%3C%2FP%3E%3CP%3EThe%20EP%20can%20use%20this%20CLK%20signal%2C%20or%20can%20use%20it's%20internal%20clock%2C%20and%20relay%20on%20the%208b10b%20clock%20recovery.%3C%2FP%3E%3CP%3EIn%20the%20case%20of%20the%20MX6Q%2C%20the%20way%20it%20is%20implemented%20currently%20in%20the%20kernel%2C%20it%20uses%20it's%20internal%20clock.%3C%2FP%3E%3CP%3EIt%20is%20also%20possible%20to%20give%20the%20MX6%20an%20external%20clock%20(coming%20from%20the%20PC)%20but%20in%20this%20case%20you%20need%20to%20patch%20the%20kernel%20in%20order%20to%20use%20the%20external%20clock%20!%3C%2FP%3E%3CP%3EI%20suggest%20you%20to%20run%20%22%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ewhile(true)%20%3B%20do%20sleep%201%20%3B%20.%2Fmemtool%20-32%2001ffc72c%201%20%7C%20grep%20-v%20add%20%7C%20grep%200x%3B%20done%3C%2FSPAN%3E%22%20and%20see%20the%20value%20you%20get.%20if%20it's%20something%20like%20%22xxxxxx1x%22%20then%20the%20link%20is%20up%2C%20if%20it's%20something%20like%20%22xxxxxx0x%22%20then%20the%20link%20is%20down%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20%3CA%20_jive_internal%3D%22true%22%20data-avatarid%3D%221013%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%22207066%22%20data-username%3D%22richard.zhu%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2012px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%238b8b8b%3B%20background-color%3A%20%23f6f6f6%3B%22%20target%3D%22_blank%22%3EHongxing%20Zhu%3C%2FA%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20mean%20that%20PC%20not%20provide%20LVDS%20differencial%20clock%20that%20required%20by%20freescale%3F%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20make%20PC%20provide%20this%20signal%3F%20I%20can%20not%20find%20anything%20relation%20option%20in%20kernel%20menuconfig%20of%20PC.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%2C%3C%2FP%3E%3CP%3Eit's%20true%20it%20doesn't%20matter%20if%20EP%20and%20RC%20use%20each%20of%20them%20an%20internal%20clock%2C%20but%20in%20the%20case%20of%20a%20PC%2C%20the%20PC%20acting%20as%20a%20RC%20is%20providing%20the%20CLK%20to%20the%20EP%20(here%20the%20imx)%20and%20I%20believe%20this%20clock%20is%20100Mhz%20as%20it's%20standard.%20(unless%20i'm%20wrong%3F)%3C%2FP%3E%3CP%3ESo%20here%20the%20problem%20is%20that%20if%20the%20IMX%20is%20set%20at%20125Mhz%2C%20that%20it%20only%20uses%20TX%2FRX%20but%20NOT%20the%20CLK%20coming%20from%20the%20RC%20which%20is%20at%20100Mhz.%20what%20happens%20%3F%20%3C%2FP%3E%3CP%3ECould%20it%20be%20the%20reason%20it%20works%20only%20in%201%20PC%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20key%20two%3A%3C%2FP%3E%3CP%3EIt's%20great%20that%20you%20can%20look%20at%20imx%20ep%20at%20one%20of%20your%20pc.%3C%2FP%3E%3CP%3ESorry%2C%20I'm%20busy%20on%20one%20internal%20critical%20release%20in%20these%20days%2C%20don't%20have%20much%20time%20here.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EImx6q%20pcie%20uses%20125mhz%20as%20internal%20ref%20clk.%3C%2FP%3E%3CP%3EActually%2C%20it's%20doesn't%20matter%20when%20the%20standalone%20ref%20clk%20is%20used%20by%20ep%20and%20rc.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnother%20ref%20clk%20solution%2C%20imx6q%20pcie%20ep%20can%20use%20the%20100m%20clk%20provided%20by%20pc%20pcie%20rc%20in%20theory.%3C%2FP%3E%3CP%3EBut%20some%20configurations%20are%20required%2Cyou%20can%20make%20a%20reference%20to%20the%20topic%20when%20the%20100m%20external%20OSC%20is%20implemented%20in%20this%20community.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3ERichard%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%202013-11-28%EF%BC%8C%E4%B8%8B%E5%8D%886%3A38%EF%BC%8C%22key%20two%22%20%3CADMIN%3E%26gt%3B%20%E5%86%99%E9%81%93%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enew%20comment%20by%20key%20two%26lt%3B%26gt%3B%20View%20all%20comments%20on%20this%20document%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20checking%20the%20uplink%20register%20on%20a%20while%20loop%2C%20i%20realized%20that%20my%20device%20was%20in%20fact%20loosing%20the%20link%20up.%3C%2FP%3E%3CP%3ESo%20i%20decided%20to%20make%20a%20new%20cable%2C%20where%20I%20respect%20the%20proximity%20of%20the%20TX%2FRX%20lines%20by%20putting%20the%20track%20right%20next%20to%20eachother%2C%20with%20a%20new%20type%20of%20connector%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42393i9068253606BDD390%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(2).jpeg%22%20alt%3D%22image%20(2).jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eso%20on%20one%20side%20I%20come%20from%20the%20SABRE%20Lite%20J23%20connector%2C%20to%20my%20little%20adapter%2C%20and%20that%20goes%20to%20a%20KZ-B21%20(%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%3C%2FA%3E%20)%3C%2FP%3E%3CP%3EI%20tested%20this%20one%20on%20several%20PC%2C%20and%20on%20one%20of%20them%20(just%20one)%20when%20I%20do%20a%20%22lspci%22%20i%20see%20my%20dead%3Abeaf%20device%20as%20a%20RAM%20pcie%20card.%3C%2FP%3E%3CP%3EOn%20the%20Sabrelite%2C%20the%20link%20stays%20UP%20(0x00000310)%20It%20looks%20like%20the%20cable%20was%20really%20an%20issue%20here.%3C%2FP%3E%3CP%3EI%20still%20can%20not%20read%20the%20PC's%20memmory.%3C%2FP%3E%3CP%3EI%20still%20don't%20know%20if%20the%20device%20is%20working%20on%20100Mhz%20or%20125Mhz%20and%20if%20I%20don't%20have%20a%20clock%20problem.%20What%20I%20know%20for%20sure%20is%20that%20on%20another%20PC%2C%20the%20link%20gets%20UP%20and%20Down%20non%20stop.%20So%20I%20still%20wonder%20if%20I%20don't%20have%20a%20clock%20issue.%3C%2FP%3E%3CP%3Emaybe%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%20could%20tell%20us%20more%20about%20it%20%3F%20What%20i%20know%20is%20that%20on%20some%20EP%20implementation%2C%20it%20activates%20the%20CLK1%20of%20LVDS%20port%20in%20input.%20is%20it%20switching%20into%20external%20clock%20%3F%3C%2FP%3E%3CP%3EAs%20of%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%20could%20you%20tell%20me%20more%20about%20the%20board%20you%20are%20using%20%3F%20(btw%2C%20to%20post%20a%20picture%20here%2C%20just%20drag%20and%20drop)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3Ethat%20is%20-%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98614%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-98614%3C%2FA%3E%3C%2FP%3E%3CP%3ESorry%2C%20but%20i%20cannot%20paste%20image%20right%20here.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20situation%20that%20i%20am%20writing%20about%20were%20without%20pink%20and%20orange%20plug%20on%20the%20adapter.%3C%2FP%3E%3CP%3EI%20added%20it%20in%20hope%20to%20it%20will%20provide%20clock%20to%20the%20board.%20But%20now%20i%20have%20no%20any%20signals%20from%20root%20complex.%20Kernel%20load%20hang%20up%20on%20the%20message%20%22PCIe%20EP%3A%20waiting%20for%20link%20up...%22.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20just%20checked%20my%20register%20with%20memtool.%20%22while(true)%20%3B%20do%20sleep%201%20%3B%20.%2Fmemtool%20-32%2001ffc72c%201%20%7C%20grep%20-v%20add%20%7C%20grep%200x%3B%20done%22%3C%2FP%3E%3CP%3Ein%20fact%20the%204th%20bit%20switches%20from%201%20to%200%20then%201%20again..%20randomly.%3C%2FP%3E%3CP%3Eso%20maybe%20something%20is%20wrong%20with%20my%20cable.%20or%2C%20it's%20the%20fact%20that%20my%20device%20might%20be%20sync%20at%20125Mhz%20while%20the%20normal%20PCI%20bus%20is%20sync%20at%20100Mhz%20therefor%20it%20desync%20and%20link%20goes%20down.%20%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%20How%20do%20I%20know%20if%20I'm%20in%20125Mhz%20or%20100Mhz%20%3F%3C%2FP%3E%3CP%3EToo%20bad%20there%20is%20no%20demonstration%20of%20how%20to%20turn%20the%20device%20into%20EP%20with%20a%20normal%20PC%20instead%20of%202%20Sabre%20boards.%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20Could%20you%20post%20a%20pic%20of%20your%20setup%20%3F%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EOn%20the%20board%20i'm%20using%2C%20the%20TX%2B%2FTX-%20signals%20get%20separated%20for%20a%20couple%20of%20centimeters%20because%20i%20was%20doing%20single%20face%20PCB%2C%20so%20that%20might%20be%20the%20reason%20it%20doesnt%20work.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20same%20issue%20as%20%22%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E.%3C%2FP%3E%3CP%3EShort%20cable%20help%20me%20avoid%20the%20problem%20when%20kernel%20hang%20up%20after%20message%20%22PCIE%3A%20Waiting%20for%20link%20up...%22%20(or%20something%20like%20this).%3C%2FP%3E%3CP%3ENow%20kernel%20booting%20right%2C%20but%20i%20have%20no%20%22dead_beaf%22%20device%20on%20root%20complex.%3C%2FP%3E%3CP%3EI%20use%20PC%20on%20root%20complex%20side.%20%3CSTRONG%3EMy%20question%20is%3C%2FSTRONG%3E%20%22Is%20it%20possible%20to%20make%20the%20board%20working%20as%20EP%20with%20usual%20PC%20with%20usual%20linux%203.11%3F%22%20I%20have%20no%20more%20freescale%20boards.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20thx%20for%20your%20answer.%20My%20question%20was%20more%3A%20If%20it%20says%20link%20is%20UP%2C%20is%20it%20really%20UP%20%3F%20or%20is%20it%20just%20because%20there%20is%20some%20electrical%20activity%20on%20the%20RX%20path%20%3F%3C%2FP%3E%3CP%3ERight%20now%2C%20I%20believe%20the%20board%20is%20at%20125Mhz%20and%20not%20100Mhz%20(how%20can%20I%20check%20that%3F)%20and%20since%20it's%20inserted%20inside%20a%20PC%2C%20the%20freq%20of%20the%20bus%20in%20a%20PC%20should%20be%20100Mhz%2C%20no%20%3F%20in%20this%20case%20how%20would%20the%20link%20be%20up%20%3F%3C%2FP%3E%3CP%3EAlso%2C%20on%20the%20PC%20side%2C%20I%20don't%20see%20any%20PCI%20interface%20corresponding%20to%20the%20board%20as%20a%20memory%20device%20when%20I%20issue%20a%20%22lspci%22.%20So%20does%20your%20patch%20for%20EP%20and%20%22emulating%20a%20memory%20device%22%20work%20for%20beeing%20seen%20as%20a%20memory%20device%20on%20the%20other%20side%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eregards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EWow%2C%20It's%20amazing%2C%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20link%20is%20still%20up%2C%20cable%20of%20the%20connector%20is%20a%20little%20long%20of%20your%20HW.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EAbout%20link%20is%20up%20or%20not%2C%20you%20can%20make%20a%20double%20check%20on%20the%20bit4%20of%20Debug%20Register%201(0x01ff_c72c)%2C%20link%20is%20up%20if%20this%20bit%20is%20set.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Richard%3C%2FP%3E%3CP%3EI'm%20trying%20to%20use%20a%20Sabrelite%20board%20with%20IMX6Q%20as%20a%20PCIe%20EP.%3C%2FP%3E%3CP%3EI%20Created%20a%20PCIe%20Cable%20that%20goes%20from%20the%20PCIe%20Port%20(j23)%20to%20a%20little%20board%20where%20I%20have%20a%20molex%20connector%2C%20and%20that%20gets%20rooted%20to%20a%20FPC%20Flex%20connector%20all%20the%20way%20to%20the%20PCIe%20Goldfinger%20using%20one%20of%20those%20Raiser%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%3C%2FA%3E%20The%20schematic%20of%20this%20raiser%20can%20be%20found%20here%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3EBasically%20I%20Connect%20on%20the%20PCIe%20Goldfinger%20part%20the%26nbsp%3B%20PRSNT1%23%26nbsp%3B%20--%26nbsp%3B%20PRSNT2%23%20to%20tell%20the%20HOST%20PC%20that%20it's%20a%20x1%20pcie%3A%3C%2FP%3E%3CP%3Ethen%20my%20setup%20could%20be%20resumed%20as%3A%3C%2FP%3E%3CP%3EGND%20--%26nbsp%3B%20GND%3C%2FP%3E%3CP%3ETXP%20--%20RXP%3C%2FP%3E%3CP%3ETXM%20--%20RXM%3C%2FP%3E%3CP%3ERXP%20--%20TXP%3C%2FP%3E%3CP%3ERXM%20--%20TXM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41453iBEAB397888E054DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(1).jpeg%22%20alt%3D%22image%20(1).jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(%3CA%20href%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20title%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%3C%2FA%3E)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHere%20is%20a%20view%20to%20the%20BOOT%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUncompressing%20Linux...%20done%2C%20booting%20the%20kernel.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Linux%20version%203.0.35-2508-g54750ff%20(xavier%40ubuntu)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2324%20SMP%20PREEMPT%20Sun%20Nov%203%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Machine%3A%20Freescale%20i.MX%206Quad%20Sabre-Lite%20Board%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20PERCPU%3A%20Embedded%207%20pages%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Built%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20227328%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Kernel%20command%20line%3A%20enable_wait_mode%3Doff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20console%3Dttymxc1%2C115200%20vmalloc%3D400M%20consoleblank%3D0%20rootwait%20root%3D%2Fdev%2Fmmcblk0p1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20PID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Dentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Inode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%3A%20640MB%20256MB%20%3D%20896MB%20total%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%3A%20896756k%2F896756k%20available%2C%20151820k%20reserved%2C%200K%20highmem%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Virtual%20kernel%20memory%20layout%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200x80000000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(1024%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003b000%26nbsp%3B%26nbsp%3B%20(%20204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003b000%20-%200x80aa62cc%26nbsp%3B%26nbsp%3B%20(10669%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80aa8000%20-%200x80b072c0%26nbsp%3B%26nbsp%3B%20(%20381%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b072e4%20-%200x80b556ac%26nbsp%3B%26nbsp%3B%20(%20313%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20SLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Preemptible%20hierarchical%20RCU%20implementation.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20MXC%20GPIO%20hardware%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20sched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20MXC_Early%20serial%20console%20at%20MMIO%200x21e8000%20(options%20'115200')%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20bootconsole%20%5Bttymxc1%5D%20enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Console%3A%20colour%20dummy%20device%2080x30%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.224540%5D%20Calibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.312867%5D%20pid_max%3A%20default%3A%2032768%20minimum%3A%20301%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.317802%5D%20Mount-cache%20hash%20table%20entries%3A%20512%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.323097%5D%20CPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.328254%5D%20hw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.428774%5D%20CPU1%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.508778%5D%20CPU2%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.588792%5D%20CPU3%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.628290%5D%20Brought%20up%204%20CPUs%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.644115%5D%20SMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.667822%5D%20print_constraints%3A%20dummy%3A%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.671823%5D%20NET%3A%20Registered%20protocol%20family%2016%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.680477%5D%20print_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.688013%5D%20print_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.695751%5D%20print_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.703438%5D%20print_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.711197%5D%20print_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.718839%5D%20print_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.727742%5D%20**DEBUG%20mx6_sabrelite_board_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.790388%5D%20**DEBUG%20imx_add_pcie%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.793966%5D%20hw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.800798%5D%20hw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.808143%5D%20hw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.814042%5D%20L310%20cache%20controller%20enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.818071%5D%20l2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.849718%5D%20bio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.857066%5D%20mxs-dma%20mxs-dma-apbh%3A%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.861759%5D%20print_constraints%3A%20vmmc%3A%203300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.866817%5D%20vgaarb%3A%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.870369%5D%20SCSI%20subsystem%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.874931%5D%20spi_imx%20imx6q-ecspi.0%3A%20probed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.879688%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbfs%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.885314%5D%20usbcore%3A%20registered%20new%20interface%20driver%20hub%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.890798%5D%20usbcore%3A%20registered%20new%20device%20driver%20usb%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.895867%5D%20Freescale%20USB%20OTG%20Driver%20loaded%2C%20%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.918287%5D%20imx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.938282%5D%20imx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.946109%5D%20mxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.952586%5D%20mxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.960308%5D%20MIPI%20CSI2%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.964632%5D%20Advanced%20Linux%20Sound%20Architecture%20Driver%20Version%201.0.24.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.971833%5D%20Bluetooth%3A%20Core%20ver%202.16%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.975533%5D%20NET%3A%20Registered%20protocol%20family%2031%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.980001%5D%20Bluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.986377%5D%20Bluetooth%3A%20HCI%20socket%20layer%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.991277%5D%20Bluetooth%3A%20L2CAP%20socket%20layer%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.996429%5D%20Bluetooth%3A%20SCO%20socket%20layer%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.001760%5D%20cfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.008652%5D%20i2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.014941%5D%20i2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.021168%5D%20Switching%20to%20clocksource%20mxc_timer1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.037670%5D%20NET%3A%20Registered%20protocol%20family%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.042238%5D%20IP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.050180%5D%20TCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.059505%5D%20TCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20786432%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.067234%5D%20TCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.073869%5D%20TCP%20reno%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.077034%5D%20UDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.082999%5D%20UDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.089789%5D%20NET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.094454%5D%20RPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.100408%5D%20RPC%3A%20Registered%20udp%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.105126%5D%20RPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.109852%5D%20RPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.117195%5D%20Static%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.122438%5D%20wait%20mode%20is%20disabled%20for%20i.MX6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.126812%5D%20cpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.132223%5D%20PM%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.135722%5D%20**DEBUG%20imx_pcie_drv_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.174919%5D%20**DEBUG%20imx_pcie_pltfm_probe%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.178171%5D%20iMX6%20PCIe%20PCIe%20EP%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.184380%5D%20PCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.189459%5D%20PCIe%20EP%3A%20waiting%20for%20link%20up...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%2015.540166%5D%20PCIe%20EP%3A%20link%20up.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.543512%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.547195%5D%20add%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.554446%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.557952%5D%20cpu%20regulator%20mode%3Aldo_enable%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.562170%5D%20i.MXC%20CPU%20frequency%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.590899%5D%20JFFS2%20version%202.2.%20(NAND)%20%EF%BF%BD%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.597527%5D%20msgmni%20has%20been%20set%20to%201751%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.602766%5D%20alg%3A%20No%20test%20for%20stdrng%20(krng)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.607030%5D%20io%20scheduler%20noop%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.610966%5D%20io%20scheduler%20deadline%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.615331%5D%20io%20scheduler%20cfq%20registered%20(default)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.621043%5D%20MIPI%20DSI%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.625229%5D%20mxc_sdc_fb%20mxc_sdc_fb.0%3A%20Can't%20get%20fb%20option%20for%20mxcfb0!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.631641%5D%20mxc_sdc_fb%20mxc_sdc_fb.1%3A%20Can't%20get%20fb%20option%20for%20mxcfb1!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.638041%5D%20mxc_sdc_fb%20mxc_sdc_fb.2%3A%20Can't%20get%20fb%20option%20for%20mxcfb2!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.644430%5D%20mxc_sdc_fb%20mxc_sdc_fb.3%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.650830%5D%20_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.667087%5D%20Console%3A%20switching%20to%20colour%20frame%20buffer%20device%20160x50%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.682241%5D%20imx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.690972%5D%20imx-sdma%20imx-sdma%3A%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.814091%5D%20Serial%3A%20IMX%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.817281%5D%20imx-uart.0%3A%20ttymxc0%20at%20MMIO%200x2020000%20(irq%20%3D%2058)%20is%20a%20IMX%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.824129%5D%20imx-uart.1%3A%20ttymxc1%20at%20MMIO%200x21e8000%20(irq%20%3D%2059)%20is%20a%20IMX%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.830620%5D%20console%20%5Bttymxc1%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.830620%5D%20console%20%5Bttymxc1%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.846998%5D%20loop%3A%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.884600%5D%20No%20sata%20disk.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.888429%5D%20m25p80%20spi0.0%3A%20sst25vf016b%20(2048%20Kbytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.893400%5D%20Creating%202%20MTD%20partitions%20on%20%22m25p80%22%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.898209%5D%200x000000000000-0x000000100000%20%3A%20%22bootloader%22%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.904579%5D%200x000000100000-0x000000200000%20%3A%20%22kernel%22%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.910711%5D%20GPMI%20NAND%20driver%20registered.%20(IMX)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.916014%5D%20vcan%3A%20Virtual%20CAN%20interface%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.920464%5D%20CAN%20device%20driver%20interface%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.924304%5D%20flexcan%20netdevice%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.928752%5D%20flexcan%20imx6q-flexcan.0%3A%20device%20registered%20(reg_base%3Dc09e8000%2C%20irq%3D142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.936542%5D%20FEC%20Ethernet%20Driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.941717%5D%20fec_enet_mii_bus%3A%20probed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.946292%5D%20ehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.952944%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.959594%5D%20fsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.995767%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.015757%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.022008%5D%20hub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.025780%5D%20hub%201-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.029901%5D%20add%20wake%20up%20source%20irq%2072%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.033602%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.040243%5D%20fsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.075767%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.095755%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.101938%5D%20hub%202-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.105702%5D%20hub%202-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.109947%5D%20Initializing%20USB%20Mass%20Storage%20driver...%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.114988%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.121010%5D%20USB%20Mass%20Storage%20support%20registered.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.125632%5D%20ARC%20USBOTG%20Device%20Controller%20driver%20(1%20August%202005)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.132344%5D%20mousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.138373%5D%20input%3A%20gpio-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.145762%5D%20egalax_ts%202-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.152477%5D%20egalax_ts%3A%20probe%20of%202-0004%20failed%20with%20error%20-5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.158557%5D%20i2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.164830%5D%20i2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.171586%5D%20snvs_rtc%20snvs_rtc.0%3A%20rtc%20core%3A%20registered%20snvs_rtc%20as%20rtc0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.178258%5D%20i2c%20%2Fdev%20entries%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.182461%5D%20Linux%20video%20capture%20interface%3A%20v2.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.187446%5D%20mxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video16%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.195068%5D%20mxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video17%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.202918%5D%20i2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.209139%5D%20i2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.215645%5D%20imx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.223761%5D%20Bluetooth%3A%20Virtual%20HCI%20driver%20ver%201.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.228680%5D%20Bluetooth%3A%20HCI%20UART%20driver%20ver%202.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.233128%5D%20Bluetooth%3A%20HCIATH3K%20protocol%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.238105%5D%20Bluetooth%3A%20Generic%20Bluetooth%20USB%20driver%20ver%200.6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.243804%5D%20usbcore%3A%20registered%20new%20interface%20driver%20btusb%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.249437%5D%20sdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.255623%5D%20sdhci%3A%20Copyright(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.260386%5D%20mmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.3%5D%20using%20DMA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.267756%5D%20mmc1%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.2%5D%20using%20DMA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.275002%5D%20mxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.286210%5D%20VPU%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.289955%5D%20mxc_asrc%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.317073%5D%20Thermal%20calibration%20data%20is%200x5874c87d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.321870%5D%20Thermal%20sensor%20with%20ratio%20%3D%20183%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.345881%5D%20Anatop%20Thermal%20registered%20as%20thermal_zone0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.351169%5D%20anatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.358317%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbhid%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.363893%5D%20usbhid%3A%20USB%20HID%20core%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.368144%5D%20usbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.374848%5D%20mxc_hdmi_soc%20mxc_hdmi_soc.0%3A%20MXC%20HDMI%20Audio%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.380296%5D%20Cirrus%20Logic%20CS42888%20ALSA%20SoC%20Codec%20Driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.385539%5D%20i2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.387149%5D%20mmc0%3A%20new%20high%20speed%20SDHC%20card%20at%20address%200001%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.397244%5D%20i2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.403550%5D%20mmcblk0%3A%20mmc0%3A0001%2000000%207.44%20GiB%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.404126%5D%20imx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%20Failed%3A%20Load%20HDMI-video%20first.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.404881%5D%20imx_3stack%20asoc%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405497%5D%20Initialize%20HDMI-audio%20failed.%20Load%20HDMI-video%20first!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405505%5D%20ALSA%20device%20list%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405510%5D%26nbsp%3B%26nbsp%3B%20No%20soundcards%20found.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405716%5D%20NET%3A%20Registered%20protocol%20family%2026%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406295%5D%20TCP%20cubic%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406303%5D%20NET%3A%20Registered%20protocol%20family%2017%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406320%5D%20can%3A%20controller%20area%20network%20core%20(rev%2020090105%20abi%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406391%5D%20NET%3A%20Registered%20protocol%20family%2029%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406407%5D%20can%3A%20raw%20protocol%20(rev%2020090105)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406413%5D%20can%3A%20broadcast%20manager%20protocol%20(rev%2020090105%20t)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.425829%5D%20usb%202-1%3A%20new%20high%20speed%20USB%20device%20number%202%20using%20fsl-ehci%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.470303%5D%20Bluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.471595%5D%26nbsp%3B%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.477735%5D%20Bluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.482876%5D%20Bluetooth%3A%20RFCOMM%20ver%201.11%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.486635%5D%20Bluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.491949%5D%20Bluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.497189%5D%20Bluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.503241%5D%20lib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.508958%5D%20VFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.516994%5D%20Bus%20freq%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.521011%5D%20Bus%20freq%20driver%20Enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.526514%5D%20mxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.529846%5D%20DVFS%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.535886%5D%20snvs_rtc%20snvs_rtc.0%3A%20setting%20system%20clock%20to%201970-01-01%2005%3A59%3A54%20UTC%20(21594)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.549411%5D%20EXT3-fs%3A%20barriers%20not%20enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.554225%5D%20kjournald%20starting.%26nbsp%3B%20Commit%20interval%205%20seconds%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.558984%5D%20EXT3-fs%20(mmcblk0p1)%3A%20using%20internal%20journal%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.558996%5D%20EXT3-fs%20(mmcblk0p1)%3A%20mounted%20filesystem%20with%20writeback%20data%20mode%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.559027%5D%20VFS%3A%20Mounted%20root%20(ext3%20filesystem)%20on%20device%20179%3A1.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.559086%5D%20Freeing%20init%20memory%3A%20204K%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.648921%5D%20hub%202-1%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.652848%5D%20hub%202-1%3A1.0%3A%203%20ports%20detected%3C%2FP%3E%3CP%3Estarting%20pid%201354%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3EMounting%20%2Fproc%20and%20%2Fsys%20%3C%2FP%3E%3CP%3EStarting%20the%20hotplug%20events%20dispatcher%20udevd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.886688%5D%20udevd%20(1372)%3A%20%2Fproc%2F1372%2Foom_adj%20is%20deprecated%2C%20please%20use%20%2Fproc%2F1372%2Foom_score_adj%20instead.%3C%2FP%3E%3CP%3ESynthesizing%20initial%20hotplug%20events%3C%2FP%3E%3CP%3ESetting%20the%20hostname%20to%20boundary%3C%2FP%3E%3CP%3EMounting%20filesystems%3C%2FP%3E%3CP%3Emount%3A%20mounting%20usbfs%20on%20%2Fproc%2Fbus%2Fusb%20failed%3A%20No%20such%20file%20or%20directory%3C%2FP%3E%3CP%3ERunning%20sysctl%3C%2FP%3E%3CP%3ESetting%20up%20networking%20on%20loopback%20device%3A%20%3C%2FP%3E%3CP%3ESetting%20up%20networking%20on%20eth0%3A%20%3C%2FP%3E%3CP%3Eudhcpc%20(v1.20.2)%20started%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2019.039687%5D%20eth0%3A%20Freescale%20FEC%20PHY%20driver%20%5BMicrel%20KSZ9021%20Gigabit%20PHY%5D%20(mii_bus%3Aphy_addr%3D1%3A06%2C%20irq%3D-1)%3C%2FP%3E%3CP%3ESending%20discover...%3C%2FP%3E%3CP%3ESending%20discover...%3C%2FP%3E%3CP%3ESending%20discover...%3C%2FP%3E%3CP%3ENo%20lease%2C%20forking%20to%20background%3C%2FP%3E%3CP%3EStarting%20the%20dropbear%20ssh%20server%3A%20%3C%2FP%3E%3CP%3Estarting%20pid%203060%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3Estarting%20pid%203068%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%204.6.2%2020110630%20(prerelease)%3C%2FP%3E%3CP%3Eroot%20filesystem%20built%20on%20Tue%2C%2018%20Jun%202013%2012%3A28%3A53%20-0700%3C%2FP%3E%3CP%3EFreescale%20Semiconductor%2C%20Inc.%3C%2FP%3E%3CP%3Eboundary%20login%3A%20%3C%2FP%3E%3CP%3EU-Boot%202013.01-rc1-00120-g7c28db0%20(Nov%2012%202012%20-%2009%3A15%3A04)%3C%2FP%3E%3CP%3ECPU%3A%26nbsp%3B%26nbsp%3B%20Freescale%20i.MX6Q%20rev1.2%20at%20792%20MHz%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESo%20the%20behaviour%20is%20that%20the%20board%20boots%2C%20and%20blocks%20at%3A%20%22%3CSTRONG%3EPCIe%20EP%3A%20waiting%20for%20link%20up...%3C%2FSTRONG%3E%22%20and%20as%20soon%20as%20I%20switch%20on%20the%20PC%2C%20it%20goes%20on%20all%20the%20way%20to%20the%20login%20prompt.%3C%2FP%3E%3CP%3EAt%20that%20stage%2C%20knowing%20that%20by%20default%20the%20IMX6q%20is%20at%20125Mhz%20and%20that%20the%20CLK%20signal%20are%20not%20connected%20on%20the%20PCIe%20connector%20of%20the%20board%2C%20so%20it%20uses%20internal%20PLL%2C%20and%20that%20the%20standard%20for%20PCIe%20is%20100Mhz.%20Is%20it%20sure%20that%20the%20link%20isr%20really%20UP%20%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EObviously%20on%20the%20PC%20side%2C%20if%20I%20issue%20a%20%22lspci%22%20I%20don't%20see%20anything.%20%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20thing%20is%20that%20according%20to%20the%20patch%2C%20it's%20supposed%20to%20set%20the%20VID%2FPID%20to%20%22DEADBEAF%22%20but%20when%20I%20look%20at%20the%20memory%2C%20I%20see%20the%20default%20VID%2FPID%3A%3C%2FP%3E%3CP%3E%24%20.%2Fmemtool%20-32%2001FFC000%2020%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EReading%200x20%20count%20starting%20at%20address%200x01FFC000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E0x01FFC000%3A%26nbsp%3B%20%3CSTRONG%3EABCD16C3%3C%2FSTRONG%3E%2000100000%2000000001%2000000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0x01FFC010%3A%26nbsp%3B%200000000C%2000000000%2000000008%2000000001%3C%2FP%3E%3CP%3E0x01FFC020%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC030%3A%26nbsp%3B%2000000000%2000000040%2000000000%20000001FF%3C%2FP%3E%3CP%3E0x01FFC040%3A%26nbsp%3B%20DBC35001%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC050%3A%26nbsp%3B%2001807005%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC060%3A%26nbsp%3B%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC070%3A%26nbsp%3B%2000020010%2000008700%2000102010%200001CC12%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESo%20I%20must%20be%20doing%20something%20wrong.%20any%20help%20would%20be%20welcome.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ejust%20for%20info%2C%20i%20even%20patched%20my%20sabrelite%20files%20like%20that%3A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-mx6%2Fboard-mx6q_sabrelite.c%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_MAX7310_1_BASE_ADDR%26nbsp%3B%26nbsp%3B%20IMX_GPIO_NR(8%2C%200)%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_PCIE_RST_B_REVB%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(SABREAUTO_MAX7310_1_BASE_ADDR%20%2B%202)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Bstatic%20const%20struct%20imx_pcie_platform_data%20mx6_sabrelite_pcie_data%20__initconst%20%3D%20%7B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_pwr_en%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_rst%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20SABREAUTO_PCIE_RST_B_REVB%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_wake_up%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_dis%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%23ifdef%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.type_ep%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%201%2C%3C%2FP%3E%3CP%3E%2B%23else%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.type_ep%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200%2C%3C%2FP%3E%3CP%3E%2B%23endif%3C%2FP%3E%3CP%3E%2B%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Estatic%20void%20__init%20mx6_sabrelite_board_init(void)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20Add%20PCIe%20RC%20interface%20support%20*%2F%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_pcie(%26amp%3Bmx6_sabrelite_pcie_data)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(0)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(1)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(2)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eregards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20my%20new%20topic%20%3A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F362575%23362575%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F362575%23362575%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3CBR%20%2F%3ECan%20you%20please%20issue%20one%20new%20topic%20to%20discuss%20your%20problem%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EI%20think%20that%20your%20problem%20is%20not%20related%20to%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%2FRC%20validation%20at%20all.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPlease%20make%20sure%20that%20the%20release%20version%20used%20by%20you%20support%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%20or%20not.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EAs%20I%20remember%20that%20the%201.1.0%20release%20doesn't%20support%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%20yet.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ewhen%20I%20select%20%2Cthere%20is%20wrong%20.i%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%20In%20function%20%60default_setup_msi_irqs'%3A%3C%2FP%3E%3CP%3Eclkdev.c%3A(.text%2B0x10ca4)%3A%20undefined%20reference%20to%20%60arch_setup_msi_irq'%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%20In%20function%20%60default_teardown_msi_irqs'%3A%3C%2FP%3E%3CP%3Eclkdev.c%3A(.text%2B0x10d18)%3A%20undefined%20reference%20to%20%60arch_teardown_msi_irq'%3C%2FP%3E%3CP%3Emake%3A%20***%20%5B.tmp_vmlinux1%5D%20Error%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%5B%20%5D%20Message%20Signaled%20Interrupts%20(MSI%20and%20MSI-X)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%20in%20make%20menuconfig%26nbsp%3B%26nbsp%3B%26nbsp%3B%20need%20select%20%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eroot%40freescale%20~%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20Class%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20Class%200400%3A%2014f1%3A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20Class%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20Class%200400%3A%2014f1%3A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%26nbsp%3B%26nbsp%3B%20my%20device%20is%3C%2FP%3E%3CP%3Estatic%20struct%20pci_device_id%20cx25858_pci_tbl%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CX25858%20Atlas%20Plus%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.vendor%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x14f1%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.device%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x8580%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.subvendor%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x14f1%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.subdevice%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x0950%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%2C%20%3C%2FP%3E%3CP%3Eit%26nbsp%3B%20seem%20id%20is%20right%EF%BC%8Cbut%20you%20can%20see%20from%20log%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ecx25858%20driver%20version%202.0.111%20loaded%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ecx25858%20driver%20unsuccess%3C%2FP%3E%3CP%3E%20I%20print%20the%20message%20in%20the%20driver%20%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20if%20(!pci_register_driver(%26amp%3Bcx25858_pci_driver))%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pci_unregister_driver(%26amp%3Bcx25858_pci_driver)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20printk(KERN_INFO%20%22cx25858%20driver%20unsuccess%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20-ENODEV%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%26nbsp%3B%20printk(KERN_INFO%20%22cx25858%20driver%20success%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20why%20register%20wrong%EF%BC%8Ccan%20you%20give%20any%20suggest%EF%BC%9F%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2F*%20return%20pci_register_driver(%26amp%3Bcx25858_pci_driver)%3B*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3CBR%20%2F%3EIt%20seems%20that%20the%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20is%20right%2C%20the%20memory%20space%20required%20by%20EP%20device%20had%20been%20allocated%20by%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20RC.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EYou%20can%20get%20the%20detailed%20info%20by%20the%20%22%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%20-v%E2%80%9D%20command%2C%20after%20you%20login%20the%20console.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ehi%20%2C%20we%20want%20to%20stdpci%20and%20use%20the%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMini%20PCIe%20to%20STD%20PCIe%20adaptors%2C%2C%3C%2FSPAN%3E%20i%20use%20Linux%203.0.35_1.1.0_121218%20download%20from%20freescale%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20the%20log%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%20(Sep%2017%202013%20-%2020%3A02%3A02)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6%20family%20TO1.2%20at%20792%20MHz%3C%2FP%3E%3CP%3ETemperature%3A%26nbsp%3B%26nbsp%3B%2029%20C%2C%20calibration%20data%200x5784c37d%3C%2FP%3E%3CP%3Emx6q%20pll1%3A%20792MHz%3C%2FP%3E%3CP%3Emx6q%20pll2%3A%20528MHz%3C%2FP%3E%3CP%3Emx6q%20pll3%3A%20480MHz%3C%2FP%3E%3CP%3Emx6q%20pll8%3A%2050MHz%3C%2FP%3E%3CP%3Eipg%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Euart%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2080000000Hz%3C%2FP%3E%3CP%3Ecspi%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2060000000Hz%3C%2FP%3E%3CP%3Eahb%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20132000000Hz%3C%2FP%3E%3CP%3Eaxi%20clock%26nbsp%3B%26nbsp%3B%20%3A%20264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%20clock%3A%20132000000Hz%3C%2FP%3E%3CP%3Eddr%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20528000000Hz%3C%2FP%3E%3CP%3Eusdhc1%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FP%3E%3CP%3Eusdhc2%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FP%3E%3CP%3Eusdhc3%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FP%3E%3CP%3Eusdhc4%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FP%3E%3CP%3Enfc%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2024000000Hz%3C%2FP%3E%3CP%3EBoard%3A%20i.MX6Q-SABRESD%3A%20unknown-board%20Board%3A%200x63012%20%5BPOR%20%5D%3C%2FP%3E%3CP%3EBoot%20Device%3A%20MMC%3C%2FP%3E%3CP%3EI2C%3A%26nbsp%3B%26nbsp%3B%20ready%3C%2FP%3E%3CP%3EDRAM%3A%26nbsp%3B%26nbsp%3B%201%20GB%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%2CFSL_USDHC%3A%202%2CFSL_USDHC%3A%203%3C%2FP%3E%3CP%3E%23%23%23%20Inside%20lcd_enable%3C%2FP%3E%3CP%3EIn%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3EOut%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3EFound%20PFUZE100!%20deviceid%3D10%2Crevid%3D11%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20got%20MAC%20address%20from%20IIM%3A%2000%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3EHit%20any%20key%20to%20stop%20autoboot%3A%26nbsp%3B%200%20%3C%2FP%3E%3CP%3Emmc3(part%200)%20is%20current%20device%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMC%20read%3A%20dev%20%23%203%2C%20block%20%23%202048%2C%20count%208192%20...%208192%20blocks%20read%3A%20OK%3C%2FP%3E%3CP%3E%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2010800000%20...%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Image%20Name%3A%26nbsp%3B%26nbsp%3B%20Linux-3.0.35-2310-gc27cb38%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Image%20Type%3A%26nbsp%3B%26nbsp%3B%20ARM%20Linux%20Kernel%20Image%20(uncompressed)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Data%20Size%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%204147924%20Bytes%20%3D%26nbsp%3B%204%20MB%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Load%20Address%3A%2010008000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Entry%20Point%3A%26nbsp%3B%2010008000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Verifying%20Checksum%20...%20OK%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Loading%20Kernel%20Image%20...%20OK%3C%2FP%3E%3CP%3EOK%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20version%203.0.35-2310-gc27cb38%20(lyc%40ubuntu)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2322%20SMP%20PREEMPT%20Wed%20Nov%2013%2000%3A56%3A32%20PST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3EMachine%3A%20Freescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20Board%3C%2FP%3E%3CP%3EIgnoring%20unrecognised%20tag%200x54410008%3C%2FP%3E%3CP%3EMemory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3C%2FP%3E%3CP%3ECPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3C%2FP%3E%3CP%3EPERCPU%3A%20Embedded%207%20pages%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3EBuilt%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20227328%3C%2FP%3E%3CP%3EKernel%20command%20line%3A%20console%3Dttymxc2%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20ldb%3Dsin0%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-WXGA%2Cif%3DRGB666%3C%2FP%3E%3CP%3EPID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EDentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3EInode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3C%2FP%3E%3CP%3EMemory%3A%20640MB%20256MB%20%3D%20896MB%20total%3C%2FP%3E%3CP%3EMemory%3A%20896280k%2F896280k%20available%2C%20152296k%20reserved%2C%200K%20highmem%3C%2FP%3E%3CP%3EVirtual%20kernel%20memory%20layout%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200x80000000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80b1309c%26nbsp%3B%26nbsp%3B%20(11097%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80b14000%20-%200x80b7e0c0%26nbsp%3B%26nbsp%3B%20(%20425%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b7e0e4%20-%200x80bccfec%26nbsp%3B%26nbsp%3B%20(%20316%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3EPreemptible%20hierarchical%20RCU%20implementation.%3C%2FP%3E%3CP%3ENR_IRQS%3A496%3C%2FP%3E%3CP%3EMXC%20GPIO%20hardware%3C%2FP%3E%3CP%3Esched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3C%2FP%3E%3CP%3Earm_max_freq%3D2%3C%2FP%3E%3CP%3EMXC_Early%20serial%20console%20at%20MMIO%200x21ec000%20(options%20'115200')%3C%2FP%3E%3CP%3Ebootconsole%20%5Bttymxc2%5D%20enabled%3C%2FP%3E%3CP%3EConsole%3A%20colour%20dummy%20device%2080x30%3C%2FP%3E%3CP%3ECalibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3C%2FP%3E%3CP%3Epid_max%3A%20default%3A%2032768%20minimum%3A%20301%3C%2FP%3E%3CP%3EMount-cache%20hash%20table%20entries%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3C%2FP%3E%3CP%3ECPU1%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU2%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU3%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3EBrought%20up%204%20CPUs%3C%2FP%3E%3CP%3ESMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3C%2FP%3E%3CP%3Eprint_constraints%3A%20dummy%3A%20%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2016%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%20700%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3EInside%20mx6_sabresd_board_init%20line%3A1809%3C%2FP%3E%3CP%3EInside%20mx6_sabresd_board_init%20line%3A1832%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3C%2FP%3E%3CP%3EL310%20cache%20controller%20enabled%3C%2FP%3E%3CP%3El2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3C%2FP%3E%3CP%3Ebio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%3A%20initialized%3C%2FP%3E%3CP%3Eprint_constraints%3A%20SPKVDD%3A%204200%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vmmc%3A%203300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20loaded%3C%2FP%3E%3CP%3ESCSI%20subsystem%20initialized%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%20probed%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbfs%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20hub%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20device%20driver%20usb%3C%2FP%3E%3CP%3EFreescale%20USB%20OTG%20Driver%20loaded%2C%20%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2CFull%20lay%3A%201%20%2CMetal%20lay%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%20300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20at%205000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20at%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20claimed%20irq%2069%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20device%20resources%20from%200x21a4000%20to%200x21a4fff%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20allocated%204096%20bytes%20at%200x21a4000%20%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20adapter%20name%3A%20%22imx-i2c%22%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20IMX%20I2C%20adapter%20registered%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20claimed%20irq%2070%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20device%20resources%20from%200x21a8000%20to%200x21a8fff%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20allocated%204096%20bytes%20at%200x21a8000%20%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20adapter%20name%3A%20%22imx-i2c%22%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20IMX%20I2C%20adapter%20registered%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20driver%20module%20loaded%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%20Driver%20Version%201.0.24.%3C%2FP%3E%3CP%3EBluetooth%3A%20Core%20ver%202.16%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2031%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20L2CAP%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20SCO%20socket%20layer%20initialized%3C%2FP%3E%3CP%3Ecfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3ESwitching%20to%20clocksource%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%202%3C%2FP%3E%3CP%3EIP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3C%2FP%3E%3CP%3ETCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3C%2FP%3E%3CP%3ETCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20786432%20bytes)%3C%2FP%3E%3CP%3ETCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3C%2FP%3E%3CP%3ETCP%20reno%20registered%3C%2FP%3E%3CP%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20udp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3EPMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3C%2FP%3E%3CP%3EStatic%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3Ewait%20mode%20is%20enabled%20for%20i.MX6%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EIMX%20PCIe%20port%3A%20link%20up.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%3A%20bus0%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%3A%20bus1%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%20BAR%2014%3A%20assigned%20%5Bmem%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1100000-0x11fffff%5D)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01400000-0x0140ffff%20pref%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01200000-0x013fffff%2064bit%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01200000-0x013fffff%2064bit%5D%20(PCI%20address%20%5B0x1200000-0x13fffff%5D)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%20PCI%20bridge%20to%20%5Bbus%2001-01%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bio%26nbsp%3B%20disabled%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%20pref%20disabled%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Ecpu%20regulator%20init%20ldo%3D1%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%20failed%20to%20get%20pu%20regulator%3C%2FP%3E%3CP%3Ei.MXC%20CPU%20frequency%20driver%3C%2FP%3E%3CP%3EJFFS2%20version%202.2.%20(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20has%20been%20set%20to%201750%3C%2FP%3E%3CP%3Ealg%3A%20No%20test%20for%20stdrng%20(krng)%3C%2FP%3E%3CP%3Eio%20scheduler%20noop%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20deadline%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20cfq%20registered%20(default)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20driver%20probed%3C%2FP%3E%3CP%3EMIPI%20DSI%20driver%20module%20loaded%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20ldb_clk%20to%20di%20clk%3A%20ldb_di0_clk%20-%26gt%3B%20ipu1_di0_clk%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20Single%20mode%20channel%200%20route%20to%20IPU0-DI0%3C%2FP%3E%3CP%3EInside%20ldb_disp_setup%20pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%26nbsp%3B%20%23%23%23%20fb_blank%20line%3A1039%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%20blank%20%3D%200%3C%2FP%3E%3CP%3EInside%20ldb_disp_setup%20pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3EConsole%3A%20switching%20to%20colour%20frame%20buffer%20device%20170x48%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%26nbsp%3B%20mxcfb_pan_display%20line%3A1399%3C%2FP%3E%3CP%3E%23%23%23%20Called%20fb_pan_display%20err%3A-22%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20register%20mxc%20display%20driver%20lcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20ipu0-di0%20already%20in%20use%3C%2FP%3E%3CP%3Emxc_sdc_fb%3A%20probe%20of%20mxc_sdc_fb.2%20failed%20with%20error%20-16%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20initialized%3C%2FP%3E%3CP%3ESerial%3A%20IMX%20driver%3C%2FP%3E%3CP%3Eimx-uart.2%3A%20ttymxc2%20at%20MMIO%200x21ec000%20(irq%20%3D%2060)%20is%20a%20IMX%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc2%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc2%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Eloop%3A%20module%20loaded%3C%2FP%3E%3CP%3ECan't%20recover%20from%20RESET%20HBA!%3C%2FP%3E%3CP%3ENo%20sata%20disk.%3C%2FP%3E%3CP%3Em25p80%20spi0.0%3A%20unrecognized%20JEDEC%20id%20206a56%3C%2FP%3E%3CP%3EGPMI%20NAND%20driver%20registered.%20(IMX)%3C%2FP%3E%3CP%3Evcan%3A%20Virtual%20CAN%20interface%20driver%3C%2FP%3E%3CP%3ECAN%20device%20driver%20interface%3C%2FP%3E%3CP%3Eflexcan%20netdevice%20driver%3C%2FP%3E%3CP%3EFEC%20Ethernet%20Driver%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%20probed%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3C%2FP%3E%3CP%3Ewait%20otg%20vbus%20change%20timeout!%20%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3EInitializing%20USB%20Mass%20Storage%20driver...%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3C%2FP%3E%3CP%3EUSB%20Mass%20Storage%20support%20registered.%3C%2FP%3E%3CP%3EARC%20USBOTG%20Device%20Controller%20driver%20(1%20August%202005)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3C%2FP%3E%3CP%3Einput%3A%20gpio-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20rtc%20core%3A%20registered%20snvs_rtc%20as%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20driver%3C%2FP%3E%3CP%3Elirc_dev%3A%20IR%20Remote%20Control%20driver%20registered%2C%20major%20252%20%3C%2FP%3E%3CP%3EIR%20NEC%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20RC5(x)%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20RC6%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20JVC%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20Sony%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20RC5%20(streamzap)%20protocol%20handler%20initialized%3C%2FP%3E%3CP%3EIR%20LIRC%20bridge%20handler%20initialized%3C%2FP%3E%3CP%3ELinux%20video%20capture%20interface%3A%20v2.00%3C%2FP%3E%3CP%3EIn%20MVC%3A%20init_camera_struct%3C%2FP%3E%3CP%3EIn%20MVC%3A%20init_camera_struct%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20Inside%20prp_enc_init%20line%3A584%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20Inside%20csi_enc_init%20line%3A423%3C%2FP%3E%3CP%3EIn%20adv7180_init%3C%2FP%3E%3CP%3EDBG%20sensor%20data%20is%20at%2080b9f718%3C%2FP%3E%3CP%3EIn%20adv7180_probe%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A564%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A577%20init%20high%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A581%20set%20low%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A588%20set%20high%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_cam_powerdown_adv7441%20line%3A559%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180_probe%3Aadv7180%20probe%20i2c%20address%20is%200x21%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180_probe%3AAnalog%20Device%20adv7%2000%20detected!%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20In%20adv7180%3Aadv7180_hard_reset%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x0%20val%3A0xe%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x3%20val%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x4%20val%3A0x47%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x5%20val%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x3c%20val%3A0xad%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x17%20val%3A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x67%20val%3A0x2%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x68%20val%3A0xf0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x1d%20val%3A0x40%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x31%20val%3A0x1a%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x32%20val%3A0x81%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x33%20val%3A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x34%20val%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x35%20val%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x36%20val%3A0x7d%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x37%20val%3A0xa1%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x3a%20val%3A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x3c%20val%3A0xa8%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x47%20val%3A0xa%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xba%20val%3A0xa0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xf3%20val%3A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x69%20val%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe8%20val%3A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe9%20val%3A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xea%20val%3A0x6%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20type%20is%202%20(expect%202)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20num%20ioctls%20is%2011%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180%3Aioctl_s_power%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180%3Aioctl_g_fmt_cap%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20Returning%20size%20of%20720x625%3C%2FP%3E%3CP%3EEnd%20of%20mxc_v4l2_master_attach%3A%20device_type%201%3C%2FP%3E%3CP%3EEnd%20of%20mxc_v4l2_master_attach%3A%20v2f%20pix%20widthxheight%20288%20x%20352%3C%2FP%3E%3CP%3EEnd%20of%20mxc_v4l2_master_attach%3A%20crop_bounds%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3EEnd%20of%20mxc_v4l2_master_attach%3A%20crop_defrect%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3EEnd%20of%20mxc_v4l2_master_attach%3A%20crop_current%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video17%3C%2FP%3E%3CP%3Egspca%3A%20v2.13.0%20registered%3C%2FP%3E%3CP%3Ecx25858%20driver%20version%202.0.111%20loaded%3C%2FP%3E%3CP%3Ecx25858%20driver%20unsuccess%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20uvcvideo%3C%2FP%3E%3CP%3EUSB%20Video%20Class%20driver%20(v1.1.0)%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%20Virtual%20HCI%20driver%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20UART%20driver%20ver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20protocol%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20Generic%20Bluetooth%20USB%20driver%20ver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20btusb%3C%2FP%3E%3CP%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.3%3A%20support_8bit%3A1%3C%2FP%3E%3CP%3Emmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.3%5D%20using%20DMA%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.1%3A%20support_8bit%3A1%3C%2FP%3E%3CP%3Emmc1%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.1%5D%20using%20DMA%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.2%3A%20support_8bit%3A1%3C%2FP%3E%3CP%3Emmc2%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.2%5D%20using%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3C%2FP%3E%3CP%3EVPU%20initialized%3C%2FP%3E%3CP%3Emxc_asrc%20registered%3C%2FP%3E%3CP%3EThermal%20calibration%20data%20is%200x5784c37d%3C%2FP%3E%3CP%3EAnatop%20Thermal%20registered%20as%20thermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbhid%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20core%20driver%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3A%20MXC%20HDMI%20Audio%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20Codec%20Driver%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%3A%20probe%20of%20imx-hdmi-soc-dai.0%20failed%20with%20error%20-12%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20driver%3C%2FP%3E%3CP%3EALSA%20device%20list%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20No%20soundcards%20found.%3C%2FP%3E%3CP%3Emmc0%3A%20new%20high%20speed%20DDR%20MMC%20card%20at%20address%200001%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2026%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20partition%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM08G%20partition%202%202.00%20MiB%3C%2FP%3E%3CP%3ETCP%20cubic%20registered%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2017%3C%2FP%3E%3CP%3Ecan%3A%20controller%20area%20network%20core%20(rev%2020090105%20abi%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2029%3C%2FP%3E%3CP%3Ecan%3A%20raw%20protocol%20(rev%2020090105)%3C%2FP%3E%3CP%3Ecan%3A%20broadcast%20manager%20protocol%20(rev%2020090105%20t)%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20ver%201.11%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3C%2FP%3E%3CP%3EBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3C%2FP%3E%3CP%3EVFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3EBus%20freq%20driver%20module%20loaded%3C%2FP%3E%3CP%3EBus%20freq%20driver%20Enabled%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%20driver%20module%20loaded%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20SPKVDD%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20setting%20system%20clock%20to%201970-01-01%2008%3A04%3A21%20UTC%20(29061)%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20warning%3A%20mounting%20unchecked%20fs%2C%20running%20e2fsck%20is%20recommended%3C%2FP%3E%3CP%3EVFS%3A%20Mounted%20root%20(ext2%20filesystem)%20on%20device%20179%3A1.%3C%2FP%3E%3CP%3EFreeing%20init%20memory%3A%20212K%3C%2FP%3E%3CP%3Estarting%20pid%201440%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3EMounting%20%2Fproc%20and%20%2Fsys%20%3C%2FP%3E%3CP%3EStarting%20the%20hotplug%20events%20dispatcher%20udevd%3C%2FP%3E%3CP%3Eudevd%20(1449)%3A%20%2Fproc%2F1449%2Foom_adj%20is%20deprecated%2C%20please%20use%20%2Fproc%2F1449%2Foom_score_adj%20instead.%3C%2FP%3E%3CP%3ESynthesizing%20initial%20hotplug%20events%3C%2FP%3E%3CP%3Emmc2%3A%20new%20high%20speed%20SDHC%20card%20at%20address%201234%3C%2FP%3E%3CP%3Emmcblk1%3A%20mmc2%3A1234%20SA08G%207.28%20GiB%20%3C%2FP%3E%3CP%3E%20mmcblk1%3A%20p1%3C%2FP%3E%3CP%3ESetting%20the%20hostname%20to%20freescale%3C%2FP%3E%3CP%3EMounting%20filesystems%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20EXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20234449%3C%2FP%3E%3CP%3ENo%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20deviceEXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20234449%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20EXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20234449%3C%2FP%3E%3CP%3Eon%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Ecp%3A%20write%20error%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Eln%3A%20%2Fetc%2Fmtab%3A%20Input%2Foutput%20error%3C%2FP%3E%3CP%3Emount%3A%20mounting%20usbfs%20on%20%2Fproc%2Fbus%2Fusb%20failed%3A%20No%20such%20file%20or%20directory%3C%2FP%3E%3CP%3EStarting%20the%20port%20mapper%3A%20%3C%2FP%3E%3CP%3EStarting%20the%20boa%20webserver%3A%20%3C%2FP%3E%3CP%3Erebuilding%20rpm%20database%3C%2FP%3E%3CP%3Erpmdb%3A%20write%3A%200x7e977654%2C%208192%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Eerror%3A%20db4%20error(28)%20from%20dbenv-%26gt%3Bopen%3A%20No%20space%20left%20on%20device%3C%2FP%3E%3CP%3Eerror%3A%20cannot%20open%20Packages%20index%3C%2FP%3E%3CP%3Estarting%20pid%202772%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20363702%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20363702%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20error%3A%20ext2_lookup%3A%20deleted%20inode%20referenced%3A%20363702%3C%2FP%3E%3CP%3Eln%3A%20%2Fusr%2Flib%2FlibOpenVG.so%3A%20Input%2Foutput%20error%3C%2FP%3E%3CP%3Estarting%20pid%202779%2C%20tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%204.6.2%2020110630%20(prerelease)%3C%2FP%3E%3CP%3Eroot%20filesystem%20built%20on%20Sun%2C%2028%20Jul%202013%2002%3A45%3A43%20%2B0800%3C%2FP%3E%3CP%3EFreescale%20Semiconductor%2C%20Inc.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efreescale%20login%3A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eis%20pcie%20right%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20guys.%3C%2FP%3E%3CP%3EI%20have%20some%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20create%20Route%20Complex%20Integrated%20End%20Point%20on%20RC%20board%3F%3C%2FP%3E%3CP%3EOr%20can%20you%20explain%20how%20did%20you%20get%20acces%20to%20RC%20board%20memory%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20for%20you%20help.%3C%2FP%3E%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20we%20want%20to%20extend%20the%20usb%20via%20pcie%20with%20chip%20(mcs9990).%20There%20is%20a%20strange%20thing%2C%20if%20the%20pcie%20setup%20up%20good%2C%20then%20the%20system%20stop%20after%20about%2010s%20and%20then%20restart%20with%20%22pcie%20link%20up%20failed%22.%20Here%20is%20the%20log%20if%20pcie%20setups%20ok.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Initializing%20cgroup%20subsys%20cpu%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Linux%20version%203.0.35-2666-gbdde708%20(oser%40macbook)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%3C%2FP%3E%3CP%3E%2F10%2009%3A20)%20)%20%236%20SMP%20Tue%20Sep%2017%2009%3A04%3A37%20CEST%202013%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c5387d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Machine%3A%20Dynsense%20DS7109%20Board%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20CPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20PERCPU%3A%20Embedded%207%20pages%2Fcpu%20%40cc006000%20s5728%20r8192%20d14752%20u32768%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Built%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20260096%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Kernel%20command%20line%3A%20console%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk0p3%20rootwait%20rw%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20PID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Dentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Inode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%3A%201024MB%20%3D%201024MB%20total%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Memory%3A%201033972k%2F1033972k%20available%2C%2014604k%20reserved%2C%20360448K%20highmem%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Virtual%20kernel%20memory%20layout%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xea800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20120%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200xc0000000%20-%200xea000000%26nbsp%3B%26nbsp%3B%20(%20672%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200xbfe00000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200xbf000000%20-%200xbfe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200xc0008000%20-%200xc0033000%26nbsp%3B%26nbsp%3B%20(%20172%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200xc0033000%20-%200xc04ce188%26nbsp%3B%26nbsp%3B%20(4717%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200xc04d0000%20-%200xc05149e0%26nbsp%3B%26nbsp%3B%20(%20275%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200xc0514a04%20-%200xc05570a8%26nbsp%3B%26nbsp%3B%20(%20266%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20SLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Hierarchical%20RCU%20implementation.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20MXC%20GPIO%20hardware%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20sched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20MXC_Early%20serial%20console%20at%20MMIO%200x21f0000%20(options%20'115200')%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20bootconsole%20%5Bttymxc3%5D%20enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20Console%3A%20colour%20dummy%20device%2080x30%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.217079%5D%20Calibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.305391%5D%20pid_max%3A%20default%3A%2032768%20minimum%3A%20301%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.310317%5D%20Mount-cache%20hash%20table%20entries%3A%20512%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.315667%5D%20CPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.320824%5D%20hw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.330207%5D%20CPU1%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.361619%5D%20CPU2%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.401646%5D%20CPU3%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.440862%5D%20Brought%20up%204%20CPUs%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.456684%5D%20SMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.463648%5D%20devtmpfs%3A%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.485974%5D%20print_constraints%3A%20dummy%3A%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.489947%5D%20NET%3A%20Registered%20protocol%20family%2016%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.498839%5D%20print_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.506463%5D%20print_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.514251%5D%20print_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.521978%5D%20print_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.529772%5D%20print_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.537479%5D%20print_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.549656%5D%20hw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.556488%5D%20hw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.563843%5D%20hw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.569727%5D%20L310%20cache%20controller%20enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.573764%5D%20l2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.583862%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.587238%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.599086%5D%20bio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.606129%5D%20mxs-dma%20mxs-dma-apbh%3A%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.610956%5D%20print_constraints%3A%20vmmc%3A%203300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.616092%5D%20SCSI%20subsystem%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.620426%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbfs%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.626188%5D%20usbcore%3A%20registered%20new%20interface%20driver%20hub%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.631680%5D%20usbcore%3A%20registered%20new%20device%20driver%20usb%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.638581%5D%20Switching%20to%20clocksource%20mxc_timer1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.643177%5D%20cfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.657854%5D%20NET%3A%20Registered%20protocol%20family%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.662438%5D%20IP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.670374%5D%20TCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.679660%5D%20TCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.687383%5D%20TCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.694025%5D%20TCP%20reno%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.697184%5D%20UDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.703180%5D%20UDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.710009%5D%20NET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.714674%5D%20RPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.720613%5D%20RPC%3A%20Registered%20udp%20transport%20module.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.725342%5D%20RPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.730061%5D%20RPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.737627%5D%20PMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.742741%5D%20Static%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.747994%5D%20wait%20mode%20is%20enabled%20for%20i.MX6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.752315%5D%20cpaddr%20%3D%20ea880000%20suspend_iram_base%3Dea828000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.757735%5D%20PM%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761300%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.873230%5D%20PCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.896452%5D%20IMX%20PCIe%20port%3A%20link%20up.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.900472%5D%20PCI%3A%20bus0%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.923438%5D%20PCI%3A%20bus1%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.931153%5D%20pci%200000%3A00%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.938948%5D%20pci%200000%3A00%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1000000-0x10fffff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.949687%5D%20pci%200000%3A00%3A00.0%3A%20BAR%208%3A%20assigned%20%5Bmem%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.956506%5D%20pci%200000%3A00%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.963769%5D%20pci%200000%3A01%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01100000-0x01100fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.970587%5D%20pci%200000%3A01%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01100000-0x01100fff%5D%20(PCI%20address%20%5B0x1100000-0x1100fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.980365%5D%20pci%200000%3A01%3A00.1%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01101000-0x01101fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.987190%5D%20pci%200000%3A01%3A00.1%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01101000-0x01101fff%5D%20(PCI%20address%20%5B0x1101000-0x1101fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.996968%5D%20pci%200000%3A01%3A00.2%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01102000-0x01102fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.003804%5D%20pci%200000%3A01%3A00.2%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01102000-0x01102fff%5D%20(PCI%20address%20%5B0x1102000-0x1102fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.013582%5D%20pci%200000%3A01%3A00.3%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01103000-0x01103fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.020399%5D%20pci%200000%3A01%3A00.3%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01103000-0x01103fff%5D%20(PCI%20address%20%5B0x1103000-0x1103fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.030177%5D%20pci%200000%3A01%3A00.4%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01104000-0x01104fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.037001%5D%20pci%200000%3A01%3A00.4%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01104000-0x01104fff%5D%20(PCI%20address%20%5B0x1104000-0x1104fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.046779%5D%20pci%200000%3A01%3A00.5%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01105000-0x01105fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.053603%5D%20pci%200000%3A01%3A00.5%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01105000-0x01105fff%5D%20(PCI%20address%20%5B0x1105000-0x1105fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.063380%5D%20pci%200000%3A01%3A00.6%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01106000-0x01106fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.070198%5D%20pci%200000%3A01%3A00.6%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01106000-0x01106fff%5D%20(PCI%20address%20%5B0x1106000-0x1106fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.079976%5D%20pci%200000%3A01%3A00.7%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01107000-0x01107fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.086799%5D%20pci%200000%3A01%3A00.7%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01107000-0x01107fff%5D%20(PCI%20address%20%5B0x1107000-0x1107fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.096577%5D%20pci%200000%3A00%3A00.0%3A%20PCI%20bridge%20to%20%5Bbus%2001-01%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.101819%5D%20pci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bio%26nbsp%3B%20disabled%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.107509%5D%20pci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.114327%5D%20pci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%20pref%20disabled%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.120837%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.124593%5D%20IMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.128126%5D%20cpu%20regulator%20mode%3Aldo_enable%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.132342%5D%20i.MXC%20CPU%20frequency%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.151254%5D%20highmem%20bounce%20pool%20size%3A%2064%20pages%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.169381%5D%20msgmni%20has%20been%20set%20to%201315%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.174837%5D%20alg%3A%20No%20test%20for%20stdrng%20(krng)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.179101%5D%20io%20scheduler%20noop%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.183040%5D%20io%20scheduler%20deadline%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.187408%5D%20io%20scheduler%20cfq%20registered%20(default)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.192486%5D%20IMX-PCIe%3A%20MSI%200x3f00%20%400x0%3A0x1ff8000%2C%20irq%20%3D%20496%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.199230%5D%20imx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.208696%5D%20imx-sdma%20imx-sdma%3A%20initialized%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.350226%5D%20Serial%3A%20IMX%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.353438%5D%20imx-uart.3%3A%20ttymxc3%20at%20MMIO%200x21f0000%20(irq%20%3D%2061)%20is%20a%20IMX%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.359919%5D%20console%20%5Bttymxc3%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.359919%5D%20console%20%5Bttymxc3%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.376725%5D%20loop%3A%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.381551%5D%20usbcore%3A%20registered%20new%20interface%20driver%20asix%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.387076%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ether%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.393037%5D%20usbcore%3A%20registered%20new%20interface%20driver%20smsc75xx%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.398920%5D%20usbcore%3A%20registered%20new%20interface%20driver%20smsc95xx%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.404788%5D%20usbcore%3A%20registered%20new%20interface%20driver%20net1080%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.410575%5D%20usbcore%3A%20registered%20new%20interface%20driver%20rndis_host%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.416620%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_subset%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.422669%5D%20usbcore%3A%20registered%20new%20interface%20driver%20zaurus%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.428266%5D%20cdc_ncm%3A%2004-Aug-2011%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.431611%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ncm%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.437410%5D%20usbcore%3A%20registered%20new%20interface%20driver%20rndis_wlan%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.443872%5D%20ehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.450527%5D%20add%20wake%20up%20source%20irq%2073%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.454227%5D%20fsl-ehci%20fsl-ehci.2%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.461279%5D%20fsl-ehci%20fsl-ehci.2%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.493211%5D%20fsl-ehci%20fsl-ehci.2%3A%20irq%2073%2C%20io%20base%200x02184400%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.513186%5D%20fsl-ehci%20fsl-ehci.2%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.518851%5D%20usb%20usb1%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.525654%5D%20usb%20usb1%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.532881%5D%20usb%20usb1%3A%20Product%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.539331%5D%20usb%20usb1%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.545955%5D%20usb%20usb1%3A%20SerialNumber%3A%20fsl-ehci.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.551056%5D%20hub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.554824%5D%20hub%201-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.559261%5D%20add%20wake%20up%20source%20irq%2074%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.562943%5D%20fsl-ehci%20fsl-ehci.3%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.569893%5D%20fsl-ehci%20fsl-ehci.3%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.603198%5D%20fsl-ehci%20fsl-ehci.3%3A%20irq%2074%2C%20io%20base%200x02184600%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.623181%5D%20fsl-ehci%20fsl-ehci.3%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.628832%5D%20usb%20usb2%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.635632%5D%20usb%20usb2%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.642858%5D%20usb%20usb2%3A%20Product%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.649306%5D%20usb%20usb2%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.655934%5D%20usb%20usb2%3A%20SerialNumber%3A%20fsl-ehci.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.660988%5D%20hub%202-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.664755%5D%20hub%202-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.669192%5D%20add%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.677670%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.684575%5D%20fsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%203%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.713200%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.733180%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.738830%5D%20usb%20usb3%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.745631%5D%20usb%20usb3%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.752859%5D%20usb%20usb3%3A%20Product%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.759307%5D%20usb%20usb3%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.765934%5D%20usb%20usb3%3A%20SerialNumber%3A%20fsl-ehci.0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.770988%5D%20hub%203-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.774755%5D%20hub%203-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.779164%5D%20add%20wake%20up%20source%20irq%2072%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.782865%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.789777%5D%20fsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.823201%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.843185%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.848835%5D%20usb%20usb4%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.855637%5D%20usb%20usb4%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.862863%5D%20usb%20usb4%3A%20Product%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.869312%5D%20usb%20usb4%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.875940%5D%20usb%20usb4%3A%20SerialNumber%3A%20fsl-ehci.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.880997%5D%20hub%204-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.884765%5D%20hub%204-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.889282%5D%20PCI%3A%20enabling%20device%200000%3A01%3A00.1%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.894989%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.900490%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%205%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.908034%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20applying%20MosChip%20frame-index%20workaround%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.943222%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20irq%20155%2C%20io%20mem%200x01101000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.963182%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.969010%5D%20usb%20usb5%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.975816%5D%20usb%20usb5%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.983043%5D%20usb%20usb5%3A%20Product%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.987930%5D%20usb%20usb5%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.994553%5D%20usb%20usb5%3A%20SerialNumber%3A%200000%3A01%3A00.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999488%5D%20%2B%2B%2B%20hub_port_connect_change%3Audev-%26gt%3Blevel%20%3A1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999747%5D%20hub%205-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999759%5D%20hub%205-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000187%5D%20PCI%3A%20enabling%20device%200000%3A01%3A00.3%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000214%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000509%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%206%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000737%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20applying%20MosChip%20frame-index%20workaround%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.023241%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20irq%20154%2C%20io%20mem%200x01103000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043189%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043272%5D%20usb%20usb6%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043280%5D%20usb%20usb6%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043287%5D%20usb%20usb6%3A%20Product%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043293%5D%20usb%20usb6%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043300%5D%20usb%20usb6%3A%20SerialNumber%3A%200000%3A01%3A00.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043862%5D%20hub%206-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043875%5D%20hub%206-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044307%5D%20PCI%3A%20enabling%20device%200000%3A01%3A00.5%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044334%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044597%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%207%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044811%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20applying%20MosChip%20frame-index%20workaround%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.113240%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20irq%20153%2C%20io%20mem%200x01105000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.223212%5D%20usb%203-1%3A%20new%20high%20speed%20USB%20device%20number%202%20using%20fsl-ehci%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.243203%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.249029%5D%20usb%20usb7%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.255832%5D%20usb%20usb7%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.263059%5D%20usb%20usb7%3A%20Product%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.267946%5D%20usb%20usb7%3A%20Manufacturer%3A%20Linux%203.0.35-2666-gbdde708%20ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.274570%5D%20usb%20usb7%3A%20SerialNumber%3A%200000%3A01%3A00.5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.279804%5D%20hub%207-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.283572%5D%20hub%207-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.287948%5D%20PCI%3A%20enabling%20device%200000%3A01%3A00.7%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.293641%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.299165%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%208%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.306717%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20applying%20MosChip%20frame-index%20workaround%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.343213%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20request%20interrupt%20152%20failed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.349138%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20USB%20bus%208%20deregistered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.354820%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20init%200000%3A01%3A00.7%20fail%2C%20-22%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.360665%5D%20ehci_hcd%3A%20probe%20of%200000%3A01%3A00.7%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.366899%5D%20usb%20register%20error%20with%200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.370703%5D%20usbcore%3A%20registered%20new%20interface%20driver%20arc%20hset%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.376462%5D%20usb%20hset%20init%20succeed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.380273%5D%20imx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.388450%5D%20cpuidle%3A%20using%20governor%20ladder%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.392551%5D%20cpuidle%3A%20using%20governor%20menu%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.394974%5D%20unsupported%20device%3A%20not%20in%20white%20list%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.395019%5D%20%2B%2B%2B%20hub_port_connect_change%3Audev-%26gt%3Blevel%20%3A1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.406435%5D%20sdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.412619%5D%20sdhci%3A%20Copyright(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.417084%5D%20sdhci%20sdhci-esdhc-imx.1%3A%20no%20write-protect%20pin%20available!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.423491%5D%20mmc0%3A%20no%20vmmc%20regulator%20found%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.427681%5D%20mmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.1%5D%20using%20DMA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.434999%5D%20Thermal%20calibration%20data%20is%200x59c50d69%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.439791%5D%20Thermal%20sensor%20with%20ratio%20%3D%20186%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.463188%5D%20Anatop%20Thermal%20registered%20as%20thermal_zone0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.468495%5D%20anatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.475415%5D%20NET%3A%20Registered%20protocol%20family%2026%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.480355%5D%20TCP%20cubic%20registered%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.483599%5D%20NET%3A%20Registered%20protocol%20family%2017%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.488055%5D%20lib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.494497%5D%20VFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.502176%5D%20ThumbEE%20CPU%20extension%20supported.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.506470%5D%20Registering%20SWP%2FSWPB%20emulation%20handler%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.511407%5D%20Bus%20freq%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.513199%5D%20usb%204-1%3A%20new%20high%20speed%20USB%20device%20number%202%20using%20fsl-ehci%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.521949%5D%20Bus%20freq%20driver%20Enabled%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.527136%5D%20DVFS%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.532045%5D%20regulator_init_complete%3A%20vmmc%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%20hang%20and%20reboot%2C%20pci%20linkup%20failed%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761407%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.873253%5D%20PCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.483143%5D%20link%20up%20failed%2C%20DB_R0%3A0xdc998200%2C%20DB_R1%3A0x0820f700!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.489108%5D%20IMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EBut%20now%20the%20system%20works%20ok.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20do%20you%20think%20it's%20the%20problem%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20a%20lot.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20very%20mach.I'll%20do%20some%20test%20about%20pcie%20switch%20on%20imx6.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EGreat.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EOne%20%3CSPAN%20class%3D%22SpellE%22%3EPericom%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20switch(PI7C9X2G303EL)%20had%20been%20verified%20on%20imx_3.0.35.4.0%20and%204.1.0%20releases.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EGood%20luck.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regadrs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ehi%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EThanks%20for%20your%20reply.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EI%20have%20solved%20the%20problem.My%20power%20supply%20capacity%20is%20insufficient%2CTherefore%2C%20the%20device%20is%20not%20detected.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Enow%20here%20is%20the%20log%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3ECLK%20setup%2Cby%20OpenEmbed---%3C%2FP%3E%3CP%3ECLK%20setup%2Cby%20OpenEmbed%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%200.%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%201.%3C%2FP%3E%3CP%3EPCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20up.%3C%2FP%3E%3CP%3EPCI%3A%20bus0%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FP%3E%3CP%3EPCI%3A%20bus1%3A%20Fast%20back%20to%20back%20transfers%20disabled%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1100000-0x11fffff%5D)%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20BAR%209%3A%20assigned%20%5Bmem%200x01200000-0x012fffff%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01300000-0x0130ffff%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20BAR%207%3A%20assigned%20%5Bio%26nbsp%3B%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20assigned%20%5Bmem%200x01200000-0x0120ffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20set%20to%20%5Bmem%200x01200000-0x0120ffff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1200000-0x120ffff%5D)%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01210000-0x0121ffff%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20assigned%20%5Bmem%200x01220000-0x01220fff%2064bit%20pref%5D%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20set%20to%20%5Bmem%200x01220000-0x01220fff%2064bit%20pref%5D%20(PCI%20address%20%5B0x1220000-0x1220fff%5D)%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20assigned%20%5Bio%26nbsp%3B%200x1000000-0x10000ff%5D%3C%2FP%3E%3CP%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20set%20to%20%5Bio%26nbsp%3B%200x1000000-0x10000ff%5D%20(PCI%20address%20%5B0x1000000-0x10000ff%5D)%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%20PCI%20bridge%20to%20%5Bbus%2001-01%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bio%26nbsp%3B%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%20disabled%5D%3C%2FP%3E%3CP%3Epci%200000%3A00%3A00.0%3A%26nbsp%3B%26nbsp%3B%20bridge%20window%20%5Bmem%200x01200000-0x012fffff%20pref%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Er8169%20Gigabit%20Ethernet%20driver%202.3LK-NAPI%20loaded%3C%2FP%3E%3CP%3EPCI%3A%20enabling%20device%200000%3A01%3A00.0%20(0140%20-%26gt%3B%200143)%3C%2FP%3E%3CP%3EIMX-PCIe%3A%20MSI%200x3f01%20%400x0%3A0x1ff8000%2C%20irq%20%3D%20497%3C%2FP%3E%3CP%3Er8169%200000%3A01%3A00.0%3A%20eth1%3A%20RTL8168c%2F8111c%20at%200xc09e4000%2C%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%2C%20XID%201c4000c0%20IRQ%20497%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20Class%200604%3A%20Device%2016c3%3Aabcd%20(rev%2001)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Flags%3A%20bus%20master%2C%20fast%20devsel%2C%20latency%200%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Memory%20at%2001100000%20(64-bit%2C%20prefetchable)%20%5Bsize%3D1M%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bus%3A%20primary%3D00%2C%20secondary%3D01%2C%20subordinate%3D01%2C%20sec-latency%3D0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%2FO%20behind%20bridge%3A%2000000000-00000fff%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Prefetchable%20memory%20behind%20bridge%3A%2001200000-012fffff%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5Bvirtual%5D%20Expansion%20ROM%20at%2001300000%20%5Bdisabled%5D%20%5Bsize%3D64K%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B40%5D%20Power%20Management%20version%203%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B50%5D%20MSI%3A%20Enable%2B%20Count%3D1%2F1%20Maskable%2B%2064bit%2B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B70%5D%20Express%20Root%20Port%20(Slot-)%2C%20MSI%2000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B100%5D%20Advanced%20Error%20Reporting%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B140%5D%20Virtual%20Channel%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Kernel%20driver%20in%20use%3A%20pcieport%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E01%3A00.0%20Class%200200%3A%20Device%2010ec%3A8168%20(rev%2002)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Subsystem%3A%20Device%2010ec%3A8168%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Flags%3A%20bus%20master%2C%20fast%20devsel%2C%20latency%200%2C%20IRQ%20497%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%2FO%20ports%20at%201000000%20%5Bsize%3D256%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Memory%20at%2001220000%20(64-bit%2C%20prefetchable)%20%5Bsize%3D4K%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Memory%20at%2001200000%20(64-bit%2C%20prefetchable)%20%5Bsize%3D64K%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5Bvirtual%5D%20Expansion%20ROM%20at%2001210000%20%5Bdisabled%5D%20%5Bsize%3D64K%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B40%5D%20Power%20Management%20version%203%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B50%5D%20MSI%3A%20Enable%2B%20Count%3D1%2F2%20Maskable-%2064bit%2B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B70%5D%20Express%20Endpoint%2C%20MSI%2001%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5Bb0%5D%20MSI-X%3A%20Enable-%20Count%3D2%20Masked-%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5Bd0%5D%20Vital%20Product%20Data%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B100%5D%20Advanced%20Error%20Reporting%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B140%5D%20Virtual%20Channel%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Capabilities%3A%20%5B160%5D%20Device%20Serial%20Number%2000-00-00-00-00-00-00-00%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Kernel%20driver%20in%20use%3A%20r8169%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20Class%200604%3A%20Device%2016c3%3Aabcd%20(rev%2001)%3C%2FP%3E%3CP%3E01%3A00.0%20Class%200200%3A%20Device%2010ec%3A8168%20(rev%2002)%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20long-term%20support%2CNow%20I%20wont%20to%20use%20pcie%20switch%20pex8608%2CHave%20you%20done%20similar%20tests%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ECan%20you%26nbsp%3B%20send%20a%20business%20card%20to%20my%20e-mail%3F%20Mailing%20BCM5751%20need%20to%20fill%20in%20your%20telephone%20number.My%20e-mail%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aluhao89%40me.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eluhao89%40me.com%3C%2FA%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHere%20is%20my%20address%3A%3CBR%20%2F%3EShanghai%20%3CSPAN%20class%3D%22SpellE%22%3EPuDong%3C%2FSPAN%3E%20new%20district%20LiangJing%20Road%20192%23%20building%20A%202F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPostcode%20201203.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eyes%2CI%20use%20the%20standard%20PCIE%20EP%20device.%3C%2FP%3E%3CP%3EBut%20the%20board%20of%20imx6%20is%20our%20own%20design.so%20i%20does%20not%20need%20to%20convert.%3C%2FP%3E%3CP%3ENow%20I%20think%20the%20pcie%20bus%20not%20up%20yet.No%20relationship%20with%20the%20PCIE%20NIC%20device.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EO%2C%20I%20see.%3CBR%20%2F%3EDo%20you%20use%20the%20standard%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20device%3F%3CBR%20%2F%3EThe%20mini-%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20to%20STD-%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20convertor%20is%20required%20if%20the%20STD-%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20is%20used%20by%20you%2C%20right%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThe%20convertor%20would%20impact%20the%20quality%20of%20the%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20deeply%2C%20please%20pay%20attention%20to%20it.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHere%20is%20one%20recommended%20convertor.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%3CBR%20%2F%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%3CP%3EI%20have%20several%20pcie%20nic%20inside.such%20as%20BCM5751.I%20will%20be%20mailed%20to%20you%2C%20please%20give%20me%20your%20address.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFor%20pcie%20nic%20use%2CI've%20realized%20on%20TI's%20DM8168.However%2C%20the%20power%20consumption%20is%20too%20high.So%20I%20intend%20to%20replace%20IMX6.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERegarding%20to%20the%20your%20logs%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EPM%20driver%20module%20loaded%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3Elink%20up%20failed%2C%20DB_R0%3A0x00b4f900%2C%20DB_R1%3A0x08200000!%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EIMX%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20port%3A%20link%20down!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThe%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20link%20is%20still%20failed%20to%20be%20setup%20properly.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EDo%20you%20provide%20the%20mandatory%20requirements%20required%20by%20your%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20device%2C%20such%20as%20external%20power%20supply%20and%20so%20on%20%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EOr%2C%20can%20you%20ship%20one%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20used%20by%20you%20to%20me%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThen%20I%20can%20try%20to%20re-produce%20this%20problem%20at%20my%20side.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBest%20Regards%3CBR%20%2F%3ERichard%20Zhu.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUncompressing%20Linux...%20done%2C%20booting%20the%20kernel.%3C%2FP%3E%3CP%3ELinux%20version%203.0.35-2508-g54750ff%20(root%40ubuntu)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%231%20SMP%20PREEMPT%20Thu%20Sep%205%2012%3A46%3A34%20CST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3EMachine%3A%20Freescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20Board%3C%2FP%3E%3CP%3EIgnoring%20unrecognised%20tag%200x54410008%3C%2FP%3E%3CP%3EMemory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3C%2FP%3E%3CP%3ECPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3C%2FP%3E%3CP%3EPERCPU%3A%20Embedded%207%20pages%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3EBuilt%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20227328%3C%2FP%3E%3CP%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EDentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3EInode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3C%2FP%3E%3CP%3EMemory%3A%20640MB%20256MB%20%3D%20896MB%20total%3C%2FP%3E%3CP%3EMemory%3A%20896688k%2F896688k%20available%2C%20151888k%20reserved%2C%200K%20highmem%3C%2FP%3E%3CP%3EVirtual%20kernel%20memory%20layout%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200x80000000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80ab36f8%26nbsp%3B%26nbsp%3B%20(10714%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80ab4000%20-%200x80b18300%26nbsp%3B%26nbsp%3B%20(%20401%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b18324%20-%200x80b6678c%26nbsp%3B%26nbsp%3B%20(%20314%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3EPreemptible%20hierarchical%20RCU%20implementation.%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%20hardware%3C%2FP%3E%3CP%3Esched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMXC_Early%20serial%20console%20at%20MMIO%200x2020000%20(options%20'115200')%3C%2FP%3E%3CP%3Ebootconsole%20%5Bttymxc0%5D%20enabled%3C%2FP%3E%3CP%3EConsole%3A%20colour%20dummy%20device%2080x30%3C%2FP%3E%3CP%3ECalibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3C%2FP%3E%3CP%3Epid_max%3A%20default%3A%2032768%20minimum%3A%20301%3C%2FP%3E%3CP%3EMount-cache%20hash%20table%20entries%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3C%2FP%3E%3CP%3ECPU1%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU2%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU3%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3EBrought%20up%204%20CPUs%3C%2FP%3E%3CP%3ESMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3C%2FP%3E%3CP%3Eprint_constraints%3A%20dummy%3A%20%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2016%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%20700%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3C%2FP%3E%3CP%3EL310%20cache%20controller%20enabled%3C%2FP%3E%3CP%3El2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3C%2FP%3E%3CP%3Ebio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%3A%20initialized%3C%2FP%3E%3CP%3Eprint_constraints%3A%20SPKVDD%3A%204200%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vmmc%3A%203300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20loaded%3C%2FP%3E%3CP%3ESCSI%20subsystem%20initialized%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%20probed%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbfs%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20hub%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20device%20driver%20usb%3C%2FP%3E%3CP%3EFreescale%20USB%20OTG%20Driver%20loaded%2C%20%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2CFull%20lay%3A%201%20%2CMetal%20lay%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%20300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20at%205000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20at%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20driver%20module%20loaded%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%20Driver%20Version%201.0.24.%3C%2FP%3E%3CP%3EBluetooth%3A%20Core%20ver%202.16%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2031%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20L2CAP%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20SCO%20socket%20layer%20initialized%3C%2FP%3E%3CP%3Ecfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3C%2FP%3E%3CP%3Emax17135%202-0048%3A%20PMIC%20MAX17135%20for%20eInk%20display%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3ESwitching%20to%20clocksource%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%202%3C%2FP%3E%3CP%3EIP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3C%2FP%3E%3CP%3ETCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3C%2FP%3E%3CP%3ETCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20786432%20bytes)%3C%2FP%3E%3CP%3ETCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3C%2FP%3E%3CP%3ETCP%20reno%20registered%3C%2FP%3E%3CP%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20udp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3EPMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3C%2FP%3E%3CP%3EStatic%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3Ewait%20mode%20is%20enabled%20for%20i.MX6%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20driver%20module%20loaded%3C%2FP%3E%3CP%3Elink%20up%20failed%2C%20DB_R0%3A0x00b4f900%2C%20DB_R1%3A0x08200000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Ecpu%20regulator%20mode%3Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%20failed%20to%20get%20pu%20regulator%3C%2FP%3E%3CP%3Ei.MXC%20CPU%20frequency%20driver%3C%2FP%3E%3CP%3EJFFS2%20version%202.2.%20(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20has%20been%20set%20to%201751%3C%2FP%3E%3CP%3Ealg%3A%20No%20test%20for%20stdrng%20(krng)%3C%2FP%3E%3CP%3Eio%20scheduler%20noop%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20deadline%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20cfq%20registered%20(default)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20driver%20probed%3C%2FP%3E%3CP%3EMIPI%20DSI%20driver%20module%20loaded%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20change%20IPU%20DI1%20to%20IPU%20DI0%20for%20LDB%20channel0.%3C%2FP%3E%3CP%3Efbcvt%3A%20Aspect%20ratio%20not%20CVT%20standard%3C%2FP%3E%3CP%3Efbcvt%3A%201024x600%4060%3A%20CVT%20Name%20-%20Not%20a%20CVT%20standard%20-%200.614%20Mega%20Pixel%20Image%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3EConsole%3A%20switching%20to%20colour%20frame%20buffer%20device%20128x37%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20register%20mxc%20display%20driver%20lcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20initialized%3C%2FP%3E%3CP%3ESerial%3A%20IMX%20driver%3C%2FP%3E%3CP%3Eimx-uart.2%3A%20ttymxc2%20at%20MMIO%200x21ec000%20(irq%20%3D%2060)%20is%20a%20IMX%3C%2FP%3E%3CP%3Eimx-uart.0%3A%20ttymxc0%20at%20MMIO%200x2020000%20(irq%20%3D%2058)%20is%20a%20IMX%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Eloop%3A%20module%20loaded%3C%2FP%3E%3CP%3Eahci%3A%20SSS%20flag%20set%2C%20parallel%20bus%20scan%20disabled%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20AHCI%200001.0300%2032%20slots%201%20ports%203%20Gbps%200x1%20impl%20platform%20mode%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_platform%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3Em25p80%20spi0.0%3A%20unrecognized%20JEDEC%20id%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%20driver%20registered.%20(IMX)%3C%2FP%3E%3CP%3Evcan%3A%20Virtual%20CAN%20interface%20driver%3C%2FP%3E%3CP%3ECAN%20device%20driver%20interface%3C%2FP%3E%3CP%3Eflexcan%20netdevice%20driver%3C%2FP%3E%3CP%3EFEC%20Ethernet%20Driver%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%20probed%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3EInitializing%20USB%20Mass%20Storage%20driver...%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3C%2FP%3E%3CP%3EUSB%20Mass%20Storage%20support%20registered.%3C%2FP%3E%3CP%3EARC%20USBOTG%20Device%20Controller%20driver%20(1%20August%202005)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3C%2FP%3E%3CP%3Einput%3A%20gpio-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3Einput%3A%20max11801_ts%20as%20%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3C%2FP%3E%3CP%3Eegalax_ts%3A%20probe%20of%201-0004%20failed%20with%20error%20-5%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3C%2FP%3E%3CP%3Eegalax_ts%3A%20probe%20of%202-0004%20failed%20with%20error%20-5%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20link%20up%203.0%20Gbps%20(SStatus%20123%20SControl%20300)%3C%2FP%3E%3CP%3Eata1.00%3A%20ATA-8%3A%20WDC%20WD3200BPVT-00JJ5T0%2C%2001.01A01%2C%20max%20UDMA%2F133%3C%2FP%3E%3CP%3Eata1.00%3A%20625142448%20sectors%2C%20multi%200%3A%20LBA48%20NCQ%20(depth%2031%2F32)%3C%2FP%3E%3CP%3Eata1.00%3A%20configured%20for%20UDMA%2F133%3C%2FP%3E%3CP%3Escsi%200%3A0%3A0%3A0%3A%20Direct-Access%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20WDC%20WD3200BPVT-0%2001.0%20PQ%3A%200%20ANSI%3A%205%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20625142448%20512-byte%20logical%20blocks%3A%20(320%20GB%2F298%20GiB)%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%204096-byte%20physical%20blocks%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20Write%20Protect%20is%20off%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20Write%20cache%3A%20enabled%2C%20read%20cache%3A%20enabled%2C%20doesn't%20support%20DPO%20or%20FUA%3C%2FP%3E%3CP%3E%20sda%3A%20sda1%20sda2%20sda3%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20Attached%20SCSI%20disk%3C%2FP%3E%3CP%3Eusb%202-1%3A%20new%20full%20speed%20USB%20device%20number%202%20using%20fsl-ehci%3C%2FP%3E%3CP%3Eelan%20-%20Read%20Hello%20Packet%20Failed%3C%2FP%3E%3CP%3Eelan-touch%3A%20probe%20of%202-0010%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20rtc%20core%3A%20registered%20snvs_rtc%20as%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20driver%3C%2FP%3E%3CP%3ELinux%20video%20capture%20interface%3A%20v2.00%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video17%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video18%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video19%3C%2FP%3E%3CP%3Ehub%202-1%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%202-1%3A1.0%3A%204%20ports%20detected%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20read%20chip%20ID%200xfffffffb%20is%20not%20equal%20to%200xc4!%3C%2FP%3E%3CP%3Emag3110%3A%20probe%20of%202-000e%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20read%20chip%20ID%200x1%20is%20not%20equal%20to%200x1a%20or%200x2a!%3C%2FP%3E%3CP%3Emma8451%3A%20probe%20of%200-001c%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%20Virtual%20HCI%20driver%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20UART%20driver%20ver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20protocol%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20Generic%20Bluetooth%20USB%20driver%20ver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20btusb%3C%2FP%3E%3CP%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Emmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.3%5D%20using%20DMA%3C%2FP%3E%3CP%3Emmc1%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.1%5D%20using%20DMA%3C%2FP%3E%3CP%3Emmc2%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.2%5D%20using%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3C%2FP%3E%3CP%3EVPU%20initialized%3C%2FP%3E%3CP%3Emxc_asrc%20registered%3C%2FP%3E%3CP%3EThermal%20calibration%20data%20is%200x5894f069%3C%2FP%3E%3CP%3EThermal%20sensor%20with%20ratio%20%3D%20183%3C%2FP%3E%3CP%3EAnatop%20Thermal%20registered%20as%20thermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbhid%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20core%20driver%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3A%20MXC%20HDMI%20Audio%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20Codec%20Driver%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%20Failed%3A%20Load%20HDMI-video%20first.%3C%2FP%3E%3CP%3Emmc0%3A%20new%20high%20speed%20DDR%20MMC%20card%20at%20address%200001%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM04G%20partition%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM04G%20partition%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3Eusb%202-1.3%3A%20new%20low%20speed%20USB%20device%20number%203%20using%20fsl-ehci%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20Device%20is%20not%20a%20WM8962%2C%20ID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20failed%20to%20probe%20CODEC%20wm8962.0-001a%3A%20-22%3C%2FP%3E%3CP%3Easoc%3A%20failed%20to%20instantiate%20card%20wm8962-audio%3A%20-22%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20driver%3C%2FP%3E%3CP%3EInitialize%20HDMI-audio%20failed.%20Load%20HDMI-video%20first!%3C%2FP%3E%3CP%3EALSA%20device%20list%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20No%20soundcards%20found.%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2026%3C%2FP%3E%3CP%3ETCP%20cubic%20registered%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2017%3C%2FP%3E%3CP%3Ecan%3A%20controller%20area%20network%20core%20(rev%2020090105%20abi%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2029%3C%2FP%3E%3CP%3Ecan%3A%20raw%20protocol%20(rev%2020090105)%3C%2FP%3E%3CP%3Ecan%3A%20broadcast%20manager%20protocol%20(rev%2020090105%20t)%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20ver%201.11%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3C%2FP%3E%3CP%3Einput%3A%20HID%2004b3%3A310d%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3Egeneric-usb%200003%3A04B3%3A310D.0001%3A%20input%2Chidraw0%3A%20USB%20HID%20v1.11%20Mouse%20%5BHID%2004b3%3A310d%5D%20on%20usb-fsl-ehci.1-1.3%2Finput0%3C%2FP%3E%3CP%3EBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3C%2FP%3E%3CP%3EVFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3EBus%20freq%20driver%20module%20loaded%3C%2FP%3E%3CP%3EBus%20freq%20driver%20Enabled%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%20driver%20module%20loaded%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20setting%20system%20clock%20to%201970-01-01%2000%3A00%3A00%20UTC%20(0)%3C%2FP%3E%3CP%3Eusb%202-1.4%3A%20new%20low%20speed%20USB%20device%20number%204%20using%20fsl-ehci%3C%2FP%3E%3CP%3EEXT3-fs%3A%20barriers%20not%20enabled%3C%2FP%3E%3CP%3Ekjournald%20starting.%26nbsp%3B%20Commit%20interval%205%20seconds%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EEXT3-fs%20(mmcblk0p1)%3A%20warning%3A%20maximal%20mount%20count%20reached%2C%20running%20e2fsck%20is%20recommended%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20using%20internal%20journal%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20recovery%20complete%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20mounted%20filesystem%20with%20writeback%20data%20mode%3C%2FP%3E%3CP%3EVFS%3A%20Mounted%20root%20(ext3%20filesystem)%20on%20device%20179%3A1.%3C%2FP%3E%3CP%3EFreeing%20init%20memory%3A%20212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20is%20a%20new%20uImage.It%20does%20not%20make%20any%20patch.And%20just%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3Efollowed%20the%20following%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Econfiguration%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3ECONFIG_IMX_PCIE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3Ebut%20pcie%20does%20not%20work.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3Ethere%20is%20nothing%20output%20followed%20the%20commend%20lspci.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EI%20followed%20your%20configureatin%2Cbut%20always%20the%20same%20log%3A%3C%2FP%3E%3CP%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20udp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3EPMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3C%2FP%3E%3CP%3EStatic%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3Ewait%20mode%20is%20enabled%20for%20i.MX6%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20driver%20module%20loaded%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EPCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FP%3E%3CP%3Elink%20up%20failed%2C%20DB_R0%3A0x00ff5100%2C%20DB_R1%3A0x08200000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20***%20MX6%20Options%3A%20***%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20PCI%20Express%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20EP%20mode%20in%20the%20IMX6%20RC%2FEP%20interconnection%20system%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20RC%20mode%20in%20the%20IMX6%20RC%2FEP%20interconnection%20system%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%20USB%20Host%201%20support%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Message%20Signaled%20Interrupts%20(MSI%20and%20MSI-X)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%20PCI%20Stub%20driver%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20PCI%20IOV%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20PCI%20Express%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20Root%20Port%20Advanced%20Error%20Reporting%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PCI%20Express%20ECRC%20settings%20control%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PCIe%20AER%20error%20injector%20support%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20PCI%20Express%20ASPM%20control%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Debug%20PCI%20Express%20ASPM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eare%20there%20any%20other%20need%20to%20modify%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EHi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EOk%2C%20got%20that.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EYou%20shouldn%E2%80%98t%20enable%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EIn%20the%20kernel%20configuration.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EThe%20following%20is%20the%20correct%20configuration.%20Just%20FYI.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20is%20not%20set%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22outline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBS%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3EHi%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3EI%20want%20to%20connect%20a%20PCIE%20card%20%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%3B%20font-size%3A%2012px%3B%22%3E%3CSTRONG%3EGigabit%20Ethernet%20Controller%20such%20as%26nbsp%3B%20RTL8111E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20text-decoration%3A%20underline%3B%22%3Ethrough%20PCIE%20on%20IMX6.%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3Ebut%20my%20imx6%20pcie%20does%20not%20work%20.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3CBR%20%2F%3ERegarding%20to%20the%20log%2C%20the%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20link%20is%20not%20setup%20at%20your%20side%20at%20all.%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EThis%20validation%20system%20I%20pasted%20here%20is%20mainly%20used%20to%20verify%20the%20i.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20mode%2C%20and%20test%20the%20i.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Ethrought%3C%2FSPAN%3E-put.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3EBut%20I%20don%E2%80%98t%20know%20the%20scenario%20of%20what%20you%20said%20%E2%80%9D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EI%20want%20to%20turn%20a%20PCIE%20Gigabit%20Ethernet%20ports.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ECan%20you%20describe%20the%20details%20of%20your%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20implementation%20%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3EBest%20Regard%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%3C%2FP%3E%3CP%3EI%20got%20problem%20about%20pcie%20mode%20for%20rc.here%20is%20my%20log%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUncompressing%20Linux...%20done%2C%20booting%20the%20kernel.%3C%2FP%3E%3CP%3ELinux%20version%203.0.35%20(root%40ubuntu)%20(gcc%20version%204.6.2%2020110630%20(prerelease)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%233%20SMP%20PREEMPT%20Wed%20Sep%204%2014%3A20%3A01%20CST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3EMachine%3A%20Freescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20Board%3C%2FP%3E%3CP%3EIgnoring%20unrecognised%20tag%200x54410008%3C%2FP%3E%3CP%3EMemory%20policy%3A%20ECC%20disabled%2C%20Data%20cache%20writealloc%3C%2FP%3E%3CP%3ECPU%20identified%20as%20i.MX6Q%2C%20silicon%20rev%201.2%3C%2FP%3E%3CP%3EPERCPU%3A%20Embedded%207%20pages%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3EBuilt%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%26nbsp%3B%20Total%20pages%3A%20227328%3C%2FP%3E%3CP%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EDentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3C%2FP%3E%3CP%3EInode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3C%2FP%3E%3CP%3EMemory%3A%20640MB%20256MB%20%3D%20896MB%20total%3C%2FP%3E%3CP%3EMemory%3A%20896372k%2F896372k%20available%2C%20152204k%20reserved%2C%200K%20highmem%3C%2FP%3E%3CP%3EVirtual%20kernel%20memory%20layout%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vector%26nbsp%3B%20%3A%200xffff0000%20-%200xffff1000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%200xf4600000%20-%200xffe00000%26nbsp%3B%26nbsp%3B%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200x80000000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80b01d14%26nbsp%3B%26nbsp%3B%20(11028%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80b02000%20-%200x80b67420%26nbsp%3B%26nbsp%3B%20(%20406%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b67444%20-%200x80bb58ec%26nbsp%3B%26nbsp%3B%20(%20314%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3EPreemptible%20hierarchical%20RCU%20implementation.%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%20hardware%3C%2FP%3E%3CP%3Esched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%201431655ms%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMXC_Early%20serial%20console%20at%20MMIO%200x2020000%20(options%20'115200')%3C%2FP%3E%3CP%3Ebootconsole%20%5Bttymxc0%5D%20enabled%3C%2FP%3E%3CP%3EConsole%3A%20colour%20dummy%20device%2080x30%3C%2FP%3E%3CP%3ECalibrating%20delay%20loop...%201581.05%20BogoMIPS%20(lpj%3D7905280)%3C%2FP%3E%3CP%3Epid_max%3A%20default%3A%2032768%20minimum%3A%20301%3C%2FP%3E%3CP%3EMount-cache%20hash%20table%20entries%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20enabled%20with%20ARMv7%20Cortex-A9%20PMU%20driver%2C%207%20counters%20available%3C%2FP%3E%3CP%3ECPU1%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU2%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3ECPU3%3A%20Booted%20secondary%20processor%3C%2FP%3E%3CP%3EBrought%20up%204%20CPUs%3C%2FP%3E%3CP%3ESMP%3A%20Total%20of%204%20processors%20activated%20(6324.22%20BogoMIPS).%3C%2FP%3E%3CP%3Eprint_constraints%3A%20dummy%3A%20%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2016%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddpu%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%20700%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201200%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202775%20mV%20at%202400%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20at%201100%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20at%203000%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20found%206%20breakpoint%20and%201%20watchpoint%20registers.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%201%20breakpoint(s)%20reserved%20for%20watchpoint%20single-step.%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3C%2FP%3E%3CP%3EL310%20cache%20controller%20enabled%3C%2FP%3E%3CP%3El2x0%3A%2016%20ways%2C%20CACHE_ID%200x410000c7%2C%20AUX_CTRL%200x02070000%2C%20Cache%20size%3A%201048576%20B%3C%2FP%3E%3CP%3Ebio%3A%20create%20slab%20%3CBIO-0%3E%20at%200%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%3A%20initialized%3C%2FP%3E%3CP%3Eprint_constraints%3A%20SPKVDD%3A%204200%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vmmc%3A%203300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20loaded%3C%2FP%3E%3CP%3ESCSI%20subsystem%20initialized%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%20probed%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbfs%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20hub%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20device%20driver%20usb%3C%2FP%3E%3CP%3EFreescale%20USB%20OTG%20Driver%20loaded%2C%20%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2CFull%20lay%3A%201%20%2CMetal%20lay%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%20300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20at%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20at%205000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20at%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203000%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20driver%20module%20loaded%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%20Driver%20Version%201.0.24.%3C%2FP%3E%3CP%3EBluetooth%3A%20Core%20ver%202.16%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2031%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20L2CAP%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20SCO%20socket%20layer%20initialized%3C%2FP%3E%3CP%3Ecfg80211%3A%20Calling%20CRDA%20to%20update%20world%20regulatory%20domain%3C%2FP%3E%3CP%3Emax17135%202-0048%3A%20PMIC%20MAX17135%20for%20eInk%20display%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmax17135%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3ESwitching%20to%20clocksource%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%202%3C%2FP%3E%3CP%3EIP%20route%20cache%20hash%20table%20entries%3A%2032768%20(order%3A%205%2C%20131072%20bytes)%3C%2FP%3E%3CP%3ETCP%20established%20hash%20table%20entries%3A%20131072%20(order%3A%208%2C%201048576%20bytes)%3C%2FP%3E%3CP%3ETCP%20bind%20hash%20table%20entries%3A%2065536%20(order%3A%207%2C%20786432%20bytes)%3C%2FP%3E%3CP%3ETCP%3A%20Hash%20tables%20configured%20(established%20131072%20bind%2065536)%3C%2FP%3E%3CP%3ETCP%20reno%20registered%3C%2FP%3E%3CP%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%201%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20udp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20transport%20module.%3C%2FP%3E%3CP%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3C%2FP%3E%3CP%3EPMU%3A%20registered%20new%20PMU%20device%20of%20type%200%3C%2FP%3E%3CP%3EStatic%20Power%20Management%20for%20Freescale%20i.MX6%3C%2FP%3E%3CP%3Ewait%20mode%20is%20enabled%20for%20i.MX6%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20driver%20module%20loaded%3C%2FP%3E%3CP%3E%3CSTRONG%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Elink%20up%20failed%2C%20DB_R0%3A0x009d9700%2C%20DB_R1%3A0x08200000!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2075%3C%2FP%3E%3CP%3EIMX%20usb%20wakeup%20probe%3C%2FP%3E%3CP%3Ecpu%20regulator%20mode%3Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%20failed%20to%20get%20pu%20regulator%3C%2FP%3E%3CP%3Ei.MXC%20CPU%20frequency%20driver%3C%2FP%3E%3CP%3EJFFS2%20version%202.2.%20(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20has%20been%20set%20to%201750%3C%2FP%3E%3CP%3Ealg%3A%20No%20test%20for%20stdrng%20(krng)%3C%2FP%3E%3CP%3Eio%20scheduler%20noop%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20deadline%20registered%3C%2FP%3E%3CP%3Eio%20scheduler%20cfq%20registered%20(default)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20driver%20probed%3C%2FP%3E%3CP%3EMIPI%20DSI%20driver%20module%20loaded%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3E_regulator_get%3A%20get()%20with%20no%20identifier%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20change%20IPU%20DI1%20to%20IPU%20DI0%20for%20LDB%20channel0.%3C%2FP%3E%3CP%3Efbcvt%3A%20Aspect%20ratio%20not%20CVT%20standard%3C%2FP%3E%3CP%3Efbcvt%3A%201024x600%4060%3A%20CVT%20Name%20-%20Not%20a%20CVT%20standard%20-%200.614%20Mega%20Pixel%20Image%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3EConsole%3A%20switching%20to%20colour%20frame%20buffer%20device%20128x37%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3A%20register%20mxc%20display%20driver%20lcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20register%20mxc%20display%20driver%20ldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%20for%20second%20ldb%20displdb%20mode%20should%20in%20separate%20mode%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3A%20NO%20mxc%20display%20driver%20found!%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20loaded%20firmware%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%3A%20initialized%3C%2FP%3E%3CP%3ESerial%3A%20IMX%20driver%3C%2FP%3E%3CP%3Eimx-uart.2%3A%20ttymxc2%20at%20MMIO%200x21ec000%20(irq%20%3D%2060)%20is%20a%20IMX%3C%2FP%3E%3CP%3Eimx-uart.0%3A%20ttymxc0%20at%20MMIO%200x2020000%20(irq%20%3D%2058)%20is%20a%20IMX%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Econsole%20%5Bttymxc0%5D%20enabled%2C%20bootconsole%20disabled%3C%2FP%3E%3CP%3Eloop%3A%20module%20loaded%3C%2FP%3E%3CP%3Eahci%3A%20SSS%20flag%20set%2C%20parallel%20bus%20scan%20disabled%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20AHCI%200001.0300%2032%20slots%201%20ports%203%20Gbps%200x1%20impl%20platform%20mode%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_platform%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3Em25p80%20spi0.0%3A%20unrecognized%20JEDEC%20id%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%20driver%20registered.%20(IMX)%3C%2FP%3E%3CP%3Ee1000e%3A%20Intel(R)%20PRO%2F1000%20Network%20Driver%20-%201.3.10-k2%3C%2FP%3E%3CP%3Ee1000e%3A%20Copyright(c)%201999%20-%202011%20Intel%20Corporation.%3C%2FP%3E%3CP%3Evcan%3A%20Virtual%20CAN%20interface%20driver%3C%2FP%3E%3CP%3ECAN%20device%20driver%20interface%3C%2FP%3E%3CP%3Eflexcan%20netdevice%20driver%3C%2FP%3E%3CP%3EFEC%20Ethernet%20Driver%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%20probed%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%201-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3Eadd%20wake%20up%20source%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%202-0%3A1.0%3A%201%20port%20detected%3C%2FP%3E%3CP%3EInitializing%20USB%20Mass%20Storage%20driver...%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3C%2FP%3E%3CP%3EUSB%20Mass%20Storage%20support%20registered.%3C%2FP%3E%3CP%3EARC%20USBOTG%20Device%20Controller%20driver%20(1%20August%202005)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3C%2FP%3E%3CP%3Einput%3A%20gpio-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3Einput%3A%20max11801_ts%20as%20%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3C%2FP%3E%3CP%3Eegalax_ts%3A%20probe%20of%201-0004%20failed%20with%20error%20-5%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%3A%20egalax_ts%3A%20failed%20to%20read%20firmware%20version%3C%2FP%3E%3CP%3Eegalax_ts%3A%20probe%20of%202-0004%20failed%20with%20error%20-5%3C%2FP%3E%3CP%3Eusb%202-1%3A%20new%20full%20speed%20USB%20device%20number%202%20using%20fsl-ehci%3C%2FP%3E%3CP%3Eelan%20-%20Read%20Hello%20Packet%20Failed%3C%2FP%3E%3CP%3Eelan-touch%3A%20probe%20of%202-0010%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bisl29023%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20rtc%20core%3A%20registered%20snvs_rtc%20as%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20driver%3C%2FP%3E%3CP%3ELinux%20video%20capture%20interface%3A%20v2.00%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video17%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video18%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%20V4L2%20device%20registered%20as%20video19%3C%2FP%3E%3CP%3Ehub%202-1%3A1.0%3A%20USB%20hub%20found%3C%2FP%3E%3CP%3Ehub%202-1%3A1.0%3A%204%20ports%20detected%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20read%20chip%20ID%200xfffffffb%20is%20not%20equal%20to%200xc4!%3C%2FP%3E%3CP%3Emag3110%3A%20probe%20of%202-000e%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bmag3110%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20read%20chip%20ID%200x1%20is%20not%20equal%20to%200x1a%20or%200x2a!%3C%2FP%3E%3CP%3Emma8451%3A%20probe%20of%200-001c%20failed%20with%20error%20-22%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%3A%20IMX2%2B%20Watchdog%20Timer%20enabled.%20timeout%3D60s%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%20Virtual%20HCI%20driver%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20HCI%20UART%20driver%20ver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20protocol%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20Generic%20Bluetooth%20USB%20driver%20ver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20btusb%3C%2FP%3E%3CP%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Emmc0%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.3%5D%20using%20DMA%3C%2FP%3E%3CP%3Emmc1%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.1%5D%20using%20DMA%3C%2FP%3E%3CP%3Emmc2%3A%20SDHCI%20controller%20on%20platform%20%5Bsdhci-esdhc-imx.2%5D%20using%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3C%2FP%3E%3CP%3EVPU%20initialized%3C%2FP%3E%3CP%3Emxc_asrc%20registered%3C%2FP%3E%3CP%3EThermal%20calibration%20data%20is%200x5894f069%3C%2FP%3E%3CP%3EThermal%20sensor%20with%20ratio%20%3D%20183%3C%2FP%3E%3CP%3EAnatop%20Thermal%20registered%20as%20thermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%20default%20cooling%20device%20is%20cpufreq!%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbhid%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20core%20driver%3C%2FP%3E%3CP%3Eusbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3A%20MXC%20HDMI%20Audio%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20Codec%20Driver%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20suspend%20method%3C%2FP%3E%3CP%3Ei2c-core%3A%20driver%20%5Bcs42888%5D%20using%20legacy%20resume%20method%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%20Failed%3A%20Load%20HDMI-video%20first.%3C%2FP%3E%3CP%3Emmc0%3A%20new%20high%20speed%20DDR%20MMC%20card%20at%20address%200001%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM04G%20partition%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM04G%20partition%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20unknown%20partition%20table%3C%2FP%3E%3CP%3Eusb%202-1.3%3A%20new%20low%20speed%20USB%20device%20number%203%20using%20fsl-ehci%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20Device%20is%20not%20a%20WM8962%2C%20ID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20failed%20to%20probe%20CODEC%20wm8962.0-001a%3A%20-22%3C%2FP%3E%3CP%3Easoc%3A%20failed%20to%20instantiate%20card%20wm8962-audio%3A%20-22%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20driver%3C%2FP%3E%3CP%3EInitialize%20HDMI-audio%20failed.%20Load%20HDMI-video%20first!%3C%2FP%3E%3CP%3EALSA%20device%20list%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20No%20soundcards%20found.%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2026%3C%2FP%3E%3CP%3ETCP%20cubic%20registered%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2017%3C%2FP%3E%3CP%3Ecan%3A%20controller%20area%20network%20core%20(rev%2020090105%20abi%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20Registered%20protocol%20family%2029%3C%2FP%3E%3CP%3Ecan%3A%20raw%20protocol%20(rev%2020090105)%3C%2FP%3E%3CP%3Ecan%3A%20broadcast%20manager%20protocol%20(rev%2020090105%20t)%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3C%2FP%3E%3CP%3EBluetooth%3A%20RFCOMM%20ver%201.11%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3C%2FP%3E%3CP%3EBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3C%2FP%3E%3CP%3EVFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3Einput%3A%20HID%2004b3%3A310d%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3EBus%20freq%20driver%20module%20loaded%3C%2FP%3E%3CP%3Egeneric-usb%200003%3A04B3%3A310D.0001%3A%20input%2Chidraw0%3A%20USB%20HID%20v1.11%20Mouse%20%5BHID%2004b3%3A310d%5D%20on%20usb-fsl-ehci.1-1.3%2Finput0%3C%2FP%3E%3CP%3EBus%20freq%20driver%20Enabled%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%20driver%20module%20loaded%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20incomplete%20constraints%2C%20leaving%20on%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%20setting%20system%20clock%20to%201970-01-01%2000%3A00%3A00%20UTC%20(0)%3C%2FP%3E%3CP%3Eusb%202-1.4%3A%20new%20low%20speed%20USB%20device%20number%204%20using%20fsl-ehci%3C%2FP%3E%3CP%3Einput%3A%26nbsp%3B%26nbsp%3B%20USB%20Keyboard%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.0%2Finput%2Finput3%3C%2FP%3E%3CP%3Egeneric-usb%200003%3A04D9%3A1702.0002%3A%20input%2Chidraw1%3A%20USB%20HID%20v1.10%20Keyboard%20%5B%26nbsp%3B%20USB%20Keyboard%5D%20on%20usb-fsl-ehci.1-1.4%2Finput0%3C%2FP%3E%3CP%3Einput%3A%26nbsp%3B%26nbsp%3B%20USB%20Keyboard%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.1%2Finput%2Finput4%3C%2FP%3E%3CP%3Egeneric-usb%200003%3A04D9%3A1702.0003%3A%20input%2Chidraw2%3A%20USB%20HID%20v1.10%20Device%20%5B%26nbsp%3B%20USB%20Keyboard%5D%20on%20usb-fsl-ehci.1-1.4%2Finput1%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20link%20down%20(SStatus%201%20SControl%20300)%3C%2FP%3E%3CP%3EEXT3-fs%3A%20barriers%20not%20enabled%3C%2FP%3E%3CP%3Ekjournald%20starting.%26nbsp%3B%20Commit%20interval%205%20seconds%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20using%20internal%20journal%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20recovery%20complete%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20mounted%20filesystem%20with%20writeback%20data%20mode%3C%2FP%3E%3CP%3EVFS%3A%20Mounted%20root%20(ext3%20filesystem)%20on%20device%20179%3A1.%3C%2FP%3E%3CP%3EFreeing%20init%20memory%3A%20212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20follow%20you%20hit%20a%20patch%20to%20the%20kernel%20%EF%BC%880001-ENGR00257661-pcie-imx-pcie-ep-rc-validation.patch%EF%BC%89.%3C%2FP%3E%3CP%3Eand%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EI%20want%20to%20turn%20a%20PCIE%20Gigabit%20Ethernet%20ports.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ehelp%20please.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWelcome.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3CP%3ERichard%20Zhu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20You%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%2C%20for%20this%20great%20answer.%3C%2FP%3E%3CP%3EWas%20vers%20helpful%20to%20find%20an%20entry%20to%20this%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%20Dirk%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎06-20-2013 06:36 PM
Updated by:
