i.MX6Q PCIe EP/RC Validation System
i.MX6Q PCIe EP/RC Validation and Throughput
Hardware setup
    * Two i.MX6Q SD boards, one is used as PCIe RC; the other one is used as PCIe EP. Connected by 2*mini_PCIe to standard_PCIe  adaptors, 2*PEX cable adaptors,  and one PCIe cable.
Software configurations
    * When building RC image, make sure that
        CONFIG_IMX_PCIE=y
        # CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS is not set
        CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS=y
    * When build EP image, make sure that
        CONFIG_IMX_PCIE=y
        CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS=y
        # CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS is not set
Features
    * Set-up link between RC and EP by their stand-alone 125MHz running internally.
* In EP's system, EP can access the reserved ddr memory    (default address:0x40000000) of PCIe RC's system, by the   interconnection between PCIe EP and PCIe RC.
NOTE: The layout of the 1G DDR memory on SD boards is 0x1000_0000 ~ 0x4FFF_FFFF)
Use mem=768M in the kernel command line to reserve the 0x4000_0000 ~ 0x4FFF_FFFF DDR memory  space used to do the EP access tests.
(The example of the RC’s cmd-line: Kernel command line: noinitrd console=ttymxc0,115200 mem=768M root=/dev/nfs nfsroot=10.192.225.216:/home/r65037/nfs/rootfs_mx5x_10.11,v3,tcp ip=dhcp rw)
Throughput results
ARM core used as the bus master, and cache is disabledARM core used as the bus master, and cache is enabledIPU used as the bus master(DMA)
Data size in one write tlp8 bytes32 bytes64 bytes
Write speed~109MB/s~298MB/s~344MB/s
Data size in one read tlp32 bytes64 bytes64 bytes
Read speed~29MB/s~100MB/s~211MB/s
Here is the summary of the PCIe throughput results tested by IPU.
Write speed is about 344 MB/s.
Read speed is about 211MB/s
ARM core used as the bus master (define EP_SELF_IO_TEST in pcie.c driver)
write speed ~300MB/s.
read speed ~100MB/s.
Cache is enabled.
PCIe EP: Starting data transfer...
PCIe EP: Data transfer is successful, tv_count1 54840us, tv_count2 162814us.
PCIe EP: Data write speed is 298MB/s.
PCIe EP: Data read speed is 100MB/s.
Regarding to the log, the data size of each TLP when cache is enabled, is about 4 times of the data size in write, and 2 times of the data size in read, when the cache is not enabled.
Cache is disabledCache is enabled
Cache is not enabled
PCIe EP: Data transfer is successful, tv_count1 149616us, tv_count2 552099us.
PCIe EP: Data write speed is 109MB/s.
PCIe EP: Data read speed is 29MB/s.
One simple method used to connect the imx6 pcie ep and rc
View of the whole solution:
HW materials:
2* iMX6Q SD boards,  2* Mini PCIe to STD PCIe adaptors, one SATA2 data cable.
the mini-pcie to standard pcie exchange adaptor.
Here is the URL:
http://www.bplus.com.tw/Adapter/PM2C.html
How to make it.
signals connections
Two adaptors, one is named as A, the other one is named as B.
A                  B
TXM <----> RXM
TXN <----> RXN
RXM <----> TXM
RXN <----> TXN
A1 connected to B3
A2 connected to B4
A3 connected to B1
A4 connected to B2
Connect the cable to the adaptor.
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (A)
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (B)
NOTE:
* Please keep length of Cable as short as possible.  Our cable is about 12cm.
* Please connect shield wire in SATA2 Cable to GND at both board.
* Please boot up PCIe EP system before booting PCIe RC system.
Base one imx_3.0.35 mainline, the patch, and the IPU test tools had been attached.
NOTE:
* IPU tests usage howto.
Unzip the xxx.zip, and run xxx_r.sh to do read tests, run xxx_w.sh to do the write tests.
Tests log:
EP:
root@freescale ~/pcie_ep_io_test$ ./pcie-r.sh
pass cmdline 14, ./pcie_ipudev_test.out
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=1024,h=1024,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
640,480,RGB4,0,0,0,0,0
new option : s
show to fb 0
new option : f
output file name ipu1-1st-ovfb
new option : ÿ
show_to_buf:0, input_paddr:0x1000000, output.paddr0x18800000
====== ipu task ======
input:
        foramt: 0x34424752
        width: 1024
        height: 1024
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 640
        height: 480
        roate: 0
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 19019 us, fps 52.579000
root@freescale ~/pcie_ep_io_test$ ./pcie-w.sh
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=640,h=480,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
1024,1024,RGB4,0,0,0,0,0
new option : s
show to fb 1
new option : f
new option : ÿ
show_to_buf:1, input_paddr:0x18a00000, output.paddr0x1000000
input:
        foramt: 0x34424752
        width: 640
        height: 480
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 1024
        height: 1024
        roate: 0
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 11751 us, fps 85.099140
root@freescale ~$ ./memtool -32 01000000=deadbeaf
Writing 32-bit value 0xDEADBEAF to address 0x01000000
RC:
Before run "./memtool -32 01000000=deadbeaf" at EP.
root@freescale ~$ ./memtool -32 40000000 10
Reading 0x10 count starting at address 0x40000000
0x40000000:  00000000 00000000 00000000 00000000
0x40000010:  00000000 00000000 00000000 00000000
0x40000020:  00000000 00000000 00000000 00000000
0x40000030:  00000000 00000000 00000000 00000000
After run "./memtool -32 01000000=deadbeaf" at EP.
0x40000000:  DEADBEAF 00000000 00000000 00000000
Labels parameters
标签 (2)
附件
评论
Can you re-try it after remove "
PCI Express support
x x
” in kernel configuration?
Richard
Regarding to the following dump,
"Code: e59f0010 e1a01003 eb133c07 e3a03000 (e5833000)
clk_enable cannot be called in an interrupt context
[<80049e34>] (unwind_backtrace+0x0/0xf8) from [<8006563c>] (clk_enable+0x88/0xa0)
It's strange that why there is the IPU related kernel dump when do RTL8111e operations.
Richard
Richard:
     I have been re-configure the kernel configure, and compile the kernel again. but the result is same.
     the kernel configure is:
       *** MX6 Options: ***
  x x  [*] PCI Express support
  x x    [ ]   PCI Express EP mode in the IMX6 RC/EP interconnection system
  x x    [ ]   PCI Express RC mode in the IMX6 RC/EP interconnection system
    and for another question of IPU related, I have don't run any other command,  just load driver modules, and configure eth1, then run PING command.
    By the way, RTL8111E is a PCIE nic, and I used a mini-PCIE to PCIE adapter , connect the RTL8111E nic and i.MX6-SebraSDP board.
HI Hongxing Zhu:
                        I have tested the imx6 platform sdk "pcie_test" in RC mode,is there any EP mode test                               sample  code in imx6 platform sdk,thank you!
Dear Zhu,
I have carefully read this topic, but I need your help because my system is not working.
First of all, let me explain my situation :
I have a video processing card connected to the iMX6 thanks to the PCIe slot. The video processing card takes physical address to write pictures into DDR of the iMX6. Such as you did I reduce the memory of the iMX6 (MEM=768M). Then, my driver uses address from 0x4000_0000 to write pictures. This works fine but my problem is that the maximum write speed is around 50MB/s. Can I use IPU as bus master to reach the speed of 344MB/s ? What do I have to do exactly ?
Yann Tinauus
Yes, there is ep mode test, you can refer to the fsl linux bsp release.
Richard.
Unfortunately, as I know that you can't use IPU DMA engine in your implementation, because that IPU DMA engine is dedicated design for IPU usage, and can't be used as genera DMA engine.
I'm curious that why the throughput of the data transfer at your side is such poor, can you make sure the quality of the connections
between imx6 pcie interface and your video process card?
There may be a lot of CRC and re-try operations if there are not a GOOD enough quality connection.
Good luck.
Richard.
Dear Zhu,
I don't really understand then what the IPU patch of this topic is for. I thought the IPU patch provided aimed to reconfigure IPU and use IPU DMA without image processing ?
And what if I do image processing in IPU, then I could use IPU DMA afterwards ? I mean, that I use the IPU for a tiny process that almost don't change picture (cropping 1 line for example) to access to the DMA and store picture at high rate (344MB/s) in DDR. Is that possible ?
I have a PHYFLEX carrier-board 1364.3 (development board) in between the iMX6 and my video processing card. It may be the reason of low data transfer... I will check connections to make sure everything is fine.
Thanks for your help.
Best regards.
Hi, Richard:
     There is a new problem that we have meet, on my board, rtl8111e nic can not excuted ping operation when ping packets >= 469bytes, In addition, when we download ubuntu 's rootfs, we can't login by ssh, this operation also will cause the rtl8111e's driver abnormal.
      On the other topic: mx6 + rtl8111e driver  it seems that Carmili Li and Pavel have meet the same problem with me. Alexander have refered to a patch: [PATCH - v4] PCI: keystone: add a pci quirk to limit mrrs -- Linux PCI, but in my kernel source, we don't have this file, "/drivers/pci/host/pci-keystone.c"
      kernel ver: Linux version 3.0.35-2666-gbdde708
      rtl8111e driver info:
      r8168: Realtek PCIe GBE Family Controller mcfg = 0014
      r8168 0000:01:00.0: no MSI. Back to INTx.
      r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
      r8168  Copyright (C) 2014  Realtek NIC software team <[email protected]>
      This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
      This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
ping operation:
root@freescale ~$ ping 192.168.1.5 -s 465
PING 192.168.1.5 (192.168.1.5): 465 data bytes
473 bytes from 192.168.1.5: seq=0 ttl=64 time=0.435 ms
473 bytes from 192.168.1.5: seq=1 ttl=64 time=0.518 ms
--- 192.168.1.5 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.435/0.476/0.518 ms
root@freescale ~$ ping 192.168.1.5 -s 468
PING 192.168.1.5 (192.168.1.5): 468 data bytes
476 bytes from 192.168.1.5: seq=0 ttl=64 time=0.440 ms
476 bytes from 192.168.1.5: seq=1 ttl=64 time=0.503 ms
round-trip min/avg/max = 0.440/0.471/0.503 ms
root@freescale ~$ ping 192.168.1.5 -s 469
PING 192.168.1.5 (192.168.1.5): 469 data bytes
34 packets transmitted, 0 packets received, 100% packet loss
root@freescale ~$
As I remember that more than 1000 bytes packets transmission is verified on INTEL e1000e NIC card before.
Can you make a double check on your NIC device/driver?
Here is just a reference log, FYI.
root@imx6sxsabresd:~# ping 192.168.1.253 -s 469
PING 192.168.1.253 (192.168.1.253): 469 data bytes
477 bytes from 192.168.1.253: seq=0 ttl=64 time=0.595 ms
477 bytes from 192.168.1.253: seq=1 ttl=64 time=0.482 ms
477 bytes from 192.168.1.253: seq=2 ttl=64 time=0.457 ms
477 bytes from 192.168.1.253: seq=3 ttl=64 time=0.450 ms
^C
--- 192.168.1.253 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.450/0.496/0.595 ms
root@imx6sxsabresd:~# lspci
00:00.0 PCI bridge: Device 16c3:abcd (rev 01)
01:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
root@imx6sxsabresd:~# ping 192.168.1.253 -s 1000
PING 192.168.1.253 (192.168.1.253): 1000 data bytes
1008 bytes from 192.168.1.253: seq=0 ttl=64 time=0.559 ms
1008 bytes from 192.168.1.253: seq=1 ttl=64 time=0.485 ms
1008 bytes from 192.168.1.253: seq=2 ttl=64 time=0.472 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.472/0.505/0.559 ms
hi, Richard:
     Thanks for you reply, We have checked our driver code, and it seems ok, and We did an experiment, driver the nic with r8169 what is the fsl‘s original code in linux bsp project, not r8168-8.039.00.
  x x                                  < >   Packet Engines Hamachi GNIC-II support                                                            x x
  x x                                  < >   Packet Engines Yellowfin Gigabit-NIC support (EXPERIMENTAL)                                       x x
  x x                                  <*>   Realtek 8169 gigabit ethernet support                                                             x x
  x x                                  < >   Realtek 8111E gigabit ethernet support
   and the problem is still the same.
Dear Richard,
I'm currently trying to transmit data from a iMX6 board to a Xilinx FPGA board through a pcie link x1, using the IPU DMA to have reasonable performance, given the PCIe RC in iMX6 doesn't have DMA.
To ahieve this I adapted your demo to my specific scenario. I didn't have any major problems in the adaptation process. The writing operations from the iMX6 to the FPGA seem to work fine but, in the same way as for Yann (although our scenarios are different), instead of reaching the 344 MB/s stated in the link of the demo, with TLP data size 64 bytes, I only get about 54MB/s due to the fact that the data size of the TLPs I receive in the FPGA side is only 16 bytes. The connector I'm using between the two boards is a mini pcie to pcie
Resultado de imagen de mini pcie to pcie connector
Which configuration parameters should i touch in the iMX6 side in order to increase the size of the TLPs transmitted?
Thanks very much in advance for your answer.
Eduardo.
richard.zhu
I'm having trouble getting the PCIE up on the i.MAX6 Quad Sabre Lite Development board (https://boundarydevices.com/product/sabre-lite-imx6-sbc/ ) and interfacing with TW6865 Intersil video chip and I couldn't find the sufficient details on how to connect REFCLK- and REFCLK+ of TW6865 with PCIE port of the i.MAX6Q Sabre Lite as it just have following pin connections.
Can you guide me to interface TW6865 with PCIE of Sabre Lite ? (Presently I'm working 3.14.52 kernel based system)
Thank You,
Peter.
i.max‌#i.mx6q pcie
Hi Eduardo,
Did you ever resolve this?
Brian
The attachments are no longer available.
Also what I didn't understand from reading the article is how to actually enable the caching/data size in one tlp.
Christoph
I am not able to access the mentioned files.
Can you please provide access for the same?
%3CLINGO-SUB%20id%3D%22lingo-sub-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%20PCIe%20EP%2FRC%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382516595%22%20id%3D%22toc-hId-1304071511%22%3Ei.MX6Q%20PCIe%20EP%2FRC%20%E9%AA%8C%E8%AF%81%E5%92%8C%E5%90%9E%E5%90%90%E9%87%8F%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1073078069%22%20id%3D%22toc-hId-1994632985%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--734376394%22%20id%3D%22toc-hId-187178522%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1753136439%22%20id%3D%22toc-hId--1620275941%22%3E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%3C%2FH2%3E%3CP%3E*%20%E4%B8%A4%E5%9D%97%20i.MX6Q%20SD%20%E6%9D%BF%EF%BC%8C%E4%B8%80%E5%9D%97%E7%94%A8%E4%BD%9C%20PCIe%20RC%EF%BC%9B%E5%8F%A6%E4%B8%80%E5%9D%97%E7%94%A8%E4%BD%9C%20PCIe%20EP%E3%80%82%E9%80%9A%E8%BF%87%202*mini_PCIe%20%E8%87%B3%20standard_PCIe%20%E9%80%82%E9%85%8D%E5%99%A8%E3%80%812*PEX%20%E7%94%B5%E7%BC%86%E9%80%82%E9%85%8D%E5%99%A8%E5%92%8C%E4%B8%80%E6%A0%B9%20PCIe%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110864i0A900558E63E8936%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-03-21_10-24-40_704.jpg%22%20alt%3D%222013-03-21_10-24-40_704.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2013-03-21_10-24-40_704.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--54318024%22%20id%3D%22toc-hId-867236892%22%3E%E8%BD%AF%E4%BB%B6%E9%85%8D%E7%BD%AE%20%3C%2FH2%3E%3CP%3E*%20%E6%9E%84%E5%BB%BA%20RC%20%E6%98%A0%E5%83%8F%E6%97%B6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%23CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E*%20%E6%9E%84%E5%BB%BA%20EP%20%E6%98%A0%E5%83%8F%E6%97%B6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E%23CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1861772487%22%20id%3D%22toc-hId--940217571%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-625740346%22%20id%3D%22toc-hId-1547295262%22%3E%E7%89%B9%E6%80%A7%3C%2FH2%3E%3CP%3E*%20%E9%80%9A%E8%BF%87%E5%86%85%E9%83%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E7%8B%AC%E7%AB%8B%20125MHz%20%E5%BB%BA%E7%AB%8B%20RC%20%E5%92%8C%20EP%20%E4%B9%8B%E9%97%B4%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%9C%A8EP%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E9%80%9A%E8%BF%87PCIe%20EP%E5%92%8CPCIe%20RC%E4%B9%8B%E9%97%B4%E7%9A%84%E4%BA%92%E8%BF%9E%EF%BC%8CEP%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AEPCIe%20RC%E7%B3%BB%E7%BB%9F%E4%BF%9D%E7%95%99%E7%9A%84ddr%E5%86%85%E5%AD%98%EF%BC%88%E9%BB%98%E8%AE%A4%E5%9C%B0%E5%9D%80%EF%BC%9A0x40000000%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9ASD%20%E6%9D%BF%E4%B8%8A%201G%20DDR%20%E5%86%85%E5%AD%98%E7%9A%84%E5%B8%83%E5%B1%80%E4%B8%BA%200x1000_0000%20~%200x4FFF_FFFF)%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E4%BD%BF%E7%94%A8mem%3D768M%E6%9D%A5%E4%BF%9D%E7%95%99%E7%94%A8%E4%BA%8E%E8%BF%9B%E8%A1%8CEP%E8%AE%BF%E9%97%AE%E6%B5%8B%E8%AF%95%E7%9A%840x4000_0000~0x4FFF_FFFF%20DDR%E5%86%85%E5%AD%98%E7%A9%BA%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88RC%20%E7%9A%84%20cmd-line%20%E7%A4%BA%E4%BE%8B%EF%BC%9A%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Anoinitrd%20console%3Dttymxc0%2C115200%20%3CSTRONG%3Emem%3D768M%3C%2FSTRONG%3E%20root%3D%2Fdev%2Fnfs%20nfsroot%3D10.192.225.216%3A%2Fhome%2Fr65037%2Fnfs%2Frootfs_mx5x_10.11%2Cv3%2Ctcpip%3Ddhcp%20%E8%AF%BB%E5%86%99%EF%BC%89%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1181714117%22%20id%3D%22toc-hId--260159201%22%3E%3CA%20id%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20name%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1305798716%22%20id%3D%22toc-hId--2067613664%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--501655747%22%20id%3D%22toc-hId-419899169%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--635340471%22%20id%3D%22toc-hId-286214445%22%3E%E5%90%9E%E5%90%90%E9%87%8F%E7%BB%93%E6%9E%9C%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22table-wrap%22%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20%E5%86%85%E6%A0%B8%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%BC%93%E5%AD%98%E8%A2%AB%E7%A6%81%E7%94%A8%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20%E5%86%85%E6%A0%B8%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EIPU%E7%94%A8%E4%BD%9C%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%EF%BC%88DMA%EF%BC%89%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E4%B8%80%E6%AC%A1%E5%86%99%E5%85%A5%20tlp%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%E5%AD%97%E8%8A%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E7%BA%A6%3CSTRONG%3E344MB%3C%2FSTRONG%3E%20%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E4%B8%80%E6%AC%A1%E8%AF%BB%E5%8F%96%20tlp%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%E5%AD%97%E8%8A%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E7%BA%A6%3CSTRONG%3E211MB%3C%2FSTRONG%3E%20%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1981255081%22%20id%3D%22toc-hId--1392157299%22%3EIPU%E7%94%A8%E4%BD%9C%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%EF%BC%88DMA%EF%BC%89%3C%2FH3%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AFIPU%E6%B5%8B%E8%AF%95%E7%9A%84PCIe%E5%90%9E%E5%90%90%E9%87%8F%E7%BB%93%E6%9E%9C%E7%9A%84%E6%91%98%E8%A6%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%E7%BA%A6%E4%B8%BA344MB%2Fs%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6%E7%BA%A6%E4%B8%BA211MB%2Fs%3C%2FP%3E%3CH3%20id%3D%22toc-hId-173800618%22%20id%3D%22toc-hId-1095355534%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--1633653845%22%20id%3D%22toc-hId--712098929%22%3EARM%20%E5%86%85%E6%A0%B8%E7%94%A8%E4%BD%9C%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%EF%BC%88%E5%9C%A8%20pcie.c%20%E4%B8%AD%E5%AE%9A%E4%B9%89%20EP_SELF_IO_TEST%E5%8F%B8%E6%9C%BA%EF%BC%89%3C%2FH3%3E%3CP%3E%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6~300MB%2Fs%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6~100MB%2Fs%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-982941707%22%20id%3D%22toc-hId-1904496623%22%3E%E7%BC%93%E5%AD%98%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%3C%2FH4%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%A7%8B%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93...%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E6%88%90%E5%8A%9F%EF%BC%8Ctv_count1%2054840us%EF%BC%8Ctv_count2%20162814us%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%E4%B8%BA298MB%2Fs%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6%E4%B8%BA100MB%2Fs%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8E%E6%97%A5%E5%BF%97%E4%B8%8A%E7%9C%8B%EF%BC%8C%E5%BC%80%E5%90%AF%E7%BC%93%E5%AD%98%E6%97%B6%E6%AF%8F%E4%B8%AATLP%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E5%A4%A7%E7%BA%A6%E6%98%AF%E6%9C%AA%E5%BC%80%E5%90%AF%E7%BC%93%E5%AD%98%E6%97%B6%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E7%9A%844%E5%80%8D%EF%BC%8C%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E7%9A%842%E5%80%8D%E3%80%82%3C%2FP%3E%3CP%20class%3D%22table-wrap%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E7%BC%93%E5%AD%98%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E5%B7%B2%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E4%B8%80%E6%AC%A1%E5%86%99%E5%85%A5%20tlp%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E5%AD%97%E8%8A%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E4%B8%80%E6%AC%A1%E8%AF%BB%E5%8F%96%20tlp%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E5%AD%97%E8%8A%82%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%E5%AD%97%E8%8A%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId--824512756%22%20id%3D%22toc-hId-97042160%22%3E%E6%9C%AA%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%3C%2FH4%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%A7%8B%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93...%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E6%88%90%E5%8A%9F%EF%BC%8Ctv_count1%20149616us%EF%BC%8Ctv_count2%20552099us%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%E4%B8%BA109MB%2Fs%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%EF%BC%9A%E6%95%B0%E6%8D%AE%E8%AF%BB%E5%8F%96%E9%80%9F%E5%BA%A6%E4%B8%BA29MB%2Fs%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1275751920%22%20id%3D%22toc-hId--2097660460%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--531702543%22%20id%3D%22toc-hId-389852373%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1955810290%22%20id%3D%22toc-hId--1417602090%22%3E%E4%B8%80%E7%A7%8D%E7%94%A8%E4%BA%8E%E8%BF%9E%E6%8E%A5imx6%20pcie%20ep%E5%92%8Crc%E7%9A%84%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-277438546%22%20id%3D%22toc-hId-1198993462%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--831853976%22%20id%3D%22toc-hId-89700940%22%3E%E6%95%B4%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E7%9A%84%E8%A7%86%E5%9B%BE%EF%BC%9A%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110861i2984C2608B437C9D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_15-43-46_818_small.jpg%22%20alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2013-04-07_15-43-46_818_small.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1655658857%22%20id%3D%22toc-hId--1717753523%22%3E%E7%A1%AC%E4%BB%B6%E6%9D%90%E6%96%99%EF%BC%9A%3C%2FH2%3E%3CP%3E2*%20iMX6Q%20SD%20%E6%9D%BF%E3%80%812*%20Mini%20PCIe%20%E8%87%B3%20STD%20PCIe%20%E9%80%82%E9%85%8D%E5%99%A8%E3%80%81%E4%B8%80%E6%A0%B9%20SATA2%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E3%80%82%3C%2FP%3E%3CP%3Emini-pcie%20%E5%88%B0%E6%A0%87%E5%87%86%20pcie%20%E4%BA%A4%E6%8D%A2%E9%80%82%E9%85%8D%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3EHere%20is%20the%20URL%3A%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110857i1C40DD0BB637386E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PM2C.png%22%20alt%3D%22PM2C.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPM2C.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--151795606%22%20id%3D%22toc-hId-769759310%22%3E%E5%A6%82%E4%BD%95%E5%88%B6%E4%BD%9C%E5%AE%83%E3%80%82%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--1830167350%22%20id%3D%22toc-hId--908612434%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-657345483%22%20id%3D%22toc-hId-1578900399%22%3E%E4%BF%A1%E5%8F%B7%E8%BF%9E%E6%8E%A5%3C%2FH3%3E%3CP%3E%E4%B8%A4%E4%B8%AA%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BAA%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BAB%E3%80%82%3C%2FP%3E%3CP%3EA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20B%3C%2FP%3E%3CP%3ETXM%20%26lt%3B----%26gt%3B%20RXM%3C%2FP%3E%3CP%3ETXN%20%26lt%3B----%26gt%3B%20RXN%3C%2FP%3E%3CP%3E%E6%8E%A5%E6%94%B6%26lt%3B----%26gt%3B%E5%8F%91%E9%80%81%3C%2FP%3E%3CP%3ERXN%20%26lt%3B----%26gt%3B%20TXN%3C%2FP%3E%3CP%3EA1%E8%BF%9E%E6%8E%A5%E8%87%B3B3%3C%2FP%3E%3CP%3EA2%E8%BF%9E%E6%8E%A5%E8%87%B3B4%3C%2FP%3E%3CP%3EA3%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20B1%3C%2FP%3E%3CP%3EA4%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20B2%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110851i98266B769FE82A21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-59_594_small.jpg%22%20alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2013-04-07_16-02-59_594_small.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1150108980%22%20id%3D%22toc-hId--228554064%22%3E%E5%B0%86%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E9%80%82%E9%85%8D%E5%99%A8%E3%80%82%3C%2FH3%3E%3CP%3E%E5%B0%86%20SATA2%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20Mini%20PCIe%20%E8%BD%AC%20STD%20PCIe%20%E9%80%82%E9%85%8D%E5%99%A8%20(A)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110849iE1ED638DC4B6F47A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-17_913_small.jpg%22%20alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2013-04-07_16-02-17_913_small.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%B0%86%20SATA2%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20Mini%20PCIe%20%E8%BD%AC%20STD%20PCIe%20%E9%80%82%E9%85%8D%E5%99%A8%20(B)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110848iAB15F6405BE2880B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-01-36_658_small.jpg%22%20alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2013-04-07_16-01-36_658_small.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20*%20%E8%AF%B7%E5%B0%BD%E9%87%8F%E7%BC%A9%E7%9F%AD%E7%94%B5%E7%BC%86%E7%9A%84%E9%95%BF%E5%BA%A6%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E7%94%B5%E7%BC%86%E9%95%BF%E7%BA%A612%E5%8E%98%E7%B1%B3%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AF%B7%E5%B0%86%20SATA2%20%E7%94%B5%E7%BC%86%E4%B8%AD%E7%9A%84%E5%B1%8F%E8%94%BD%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%A4%E4%B8%AA%E6%9D%BF%E4%B8%8A%E7%9A%84%20GND%E3%80%82%3CBR%20%2F%3E*%20%E8%AF%B7%E5%9C%A8%E5%90%AF%E5%8A%A8%20PCIe%20RC%20%E7%B3%BB%E7%BB%9F%E4%B9%8B%E5%89%8D%E5%90%AF%E5%8A%A8%20PCIe%20EP%20%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%BA%E7%A1%80%E7%89%88%20imx_3.0.35%20%E4%B8%BB%E7%BA%BF%E3%80%81%E8%A1%A5%E4%B8%81%E5%92%8C%20IPU%20%E6%B5%8B%E8%AF%95%E5%B7%A5%E5%85%B7%E5%B7%B2%E9%99%84%E5%8A%A0%E3%80%82%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FP%3E%3CP%3E*%20IPU%20%E6%B5%8B%E8%AF%95%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E8%A7%A3%E5%8E%8Bxxx.zip%EF%BC%8C%E8%BF%90%E8%A1%8Cxxx_r.sh%E8%BF%9B%E8%A1%8C%E8%AF%BB%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%BF%90%E8%A1%8Cxxx_w.sh%E8%BF%9B%E8%A1%8C%E5%86%99%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%B5%8B%E8%AF%95%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EEP%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale~%2Fpcie_ep_io_test%24.%2Fpcie-r.sh%3C%2FA%3E%3CBR%20%2F%3E%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%2014%EF%BC%8C.%2Fpcie_ipudev_test.out%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Ac%3CBR%20%2F%3E%E5%B8%A7%E8%AE%A1%E6%95%B0%E8%AE%BE%E7%BD%AE%201%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Al%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%E8%AE%A1%E6%95%B0%E8%AE%BE%E7%BD%AE%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D1024%2Ch%3D1024%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9AO%3CBR%20%2F%3E%20640%2C480%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9As%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%E8%87%B3%20fb%200%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Af%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E5%90%8D%20ipu1-1st-ovfb%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9A%C3%BF%3CBR%20%2F%3E%20show_to_buf%3A0%EF%BC%8C%E8%BE%93%E5%85%A5paddr%3A0x1000000%EF%BC%8C%E8%BE%93%E5%87%BApaddr0x18800000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20ipu%20%E4%BB%BB%E5%8A%A1%20%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%3CBR%20%2F%3E%E6%A0%BC%E5%BC%8F%EF%BC%9A0x34424752%3CBR%20%2F%3E%E5%AE%BD%E5%BA%A6%EF%BC%9A1024%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%EF%BC%9A1024%3CBR%20%2F%3E%20crop.w%3D%201024%3CBR%20%2F%3E%E4%BD%9C%E7%89%A9.h%3D%201024%3CBR%20%2F%3E%20crop.pos.x%3D%200%3CBR%20%2F%3E%20crop.pos.y%3D%200%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%3CBR%20%2F%3E%E6%A0%BC%E5%BC%8F%EF%BC%9A0x34424752%3CBR%20%2F%3E%E5%AE%BD%E5%BA%A6%EF%BC%9A640%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%EF%BC%9A480%3CBR%20%2F%3E%E6%97%8B%E8%BD%AC%EF%BC%9A0%3CBR%20%2F%3E%20crop.w%3D%20640%3CBR%20%2F%3E%E4%BD%9C%E7%89%A9.h%3D%20480%3CBR%20%2F%3E%20crop.pos.x%3D%200%3CBR%20%2F%3E%20crop.pos.y%3D%200%3CBR%20%2F%3E%E6%80%BB%E5%B8%A7%E6%95%B0%201%20%E5%B9%B3%E5%9D%87%E5%B8%A7%E6%97%B6%E9%95%BF%2019019%20us%EF%BC%8Cfps%2052.579000%3CBR%20%2F%3E%20%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale~%2Fpcie_ep_io_test%24.%2Fpcie-w.sh%3C%2FA%3E%3CBR%20%2F%3E%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%2014%EF%BC%8C.%2Fpcie_ipudev_test.out%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Ac%3CBR%20%2F%3E%E5%B8%A7%E8%AE%A1%E6%95%B0%E8%AE%BE%E7%BD%AE%201%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Al%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%E8%AE%A1%E6%95%B0%E8%AE%BE%E7%BD%AE%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D640%2Ch%3D480%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9AO%3CBR%20%2F%3E%201024%2C1024%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9As%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%E8%87%B3%20Facebook%201%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9Af%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E5%90%8D%20ipu1-1st-ovfb%3C%2FP%3E%3CP%3E%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9A%C3%BF%3CBR%20%2F%3E%20show_to_buf%3A1%EF%BC%8C%E8%BE%93%E5%85%A5paddr%3A0x18a00000%EF%BC%8C%E8%BE%93%E5%87%BA.paddr0x1000000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20ipu%20%E4%BB%BB%E5%8A%A1%20%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%3CBR%20%2F%3E%E6%A0%BC%E5%BC%8F%EF%BC%9A0x34424752%3CBR%20%2F%3E%E5%AE%BD%E5%BA%A6%EF%BC%9A640%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%EF%BC%9A480%3CBR%20%2F%3E%20crop.w%3D%20640%3CBR%20%2F%3E%E4%BD%9C%E7%89%A9.h%3D%20480%3CBR%20%2F%3E%20crop.pos.x%3D%200%3CBR%20%2F%3E%20crop.pos.y%3D%200%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%3CBR%20%2F%3E%E6%A0%BC%E5%BC%8F%EF%BC%9A0x34424752%3CBR%20%2F%3E%E5%AE%BD%E5%BA%A6%EF%BC%9A1024%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%EF%BC%9A1024%3CBR%20%2F%3E%E6%97%8B%E8%BD%AC%EF%BC%9A0%3CBR%20%2F%3E%20crop.w%3D%201024%3CBR%20%2F%3E%E4%BD%9C%E7%89%A9.h%3D%201024%3CBR%20%2F%3E%20crop.pos.x%3D%200%3CBR%20%2F%3E%20crop.pos.y%3D%200%3CBR%20%2F%3E%E6%80%BB%E5%B8%A7%E6%95%B0%201%20%E5%B9%B3%E5%9D%87%E5%B8%A7%E6%97%B6%E9%95%BF%2011751%20us%EF%BC%8Cfps%2085.099140%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale~%24.%2Fmemtool%3C%2FA%3E-32%2001000000%3D%E6%AD%BB%E6%8E%89%3CBR%20%2F%3E%E5%B0%86%2032%20%E4%BD%8D%E5%80%BC%200xDEADBEAF%20%E5%86%99%E5%85%A5%E5%9C%B0%E5%9D%80%200x01000000%3C%2FP%3E%3CP%3ERC%3A%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%90%E8%A1%8C%E2%80%9C.%2Fmemtool%E2%80%9D%E4%B9%8B%E5%89%8D-32%2001000000%3Ddeadbeaf%E2%80%9D%20%E5%9C%A8%20EP%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale~%24.%2Fmemtool%3C%2FA%3E-32%2040000000%2010%3CBR%20%2F%3E%E4%BB%8E%E5%9C%B0%E5%9D%80%200x40000000%20%E5%BC%80%E5%A7%8B%E8%AF%BB%E5%8F%96%200x10%20%E8%AE%A1%E6%95%B0%3C%2FP%3E%3CP%3E0x40000000%3A%20%3CSTRONG%3E00000000%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000010%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000020%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000030%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E%E8%BF%90%E8%A1%8C%E2%80%9C.%2Fmemtool%E2%80%9D%E5%90%8E-32%2001000000%3Ddeadbeaf%E2%80%9D%20%E5%9C%A8%20EP%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale~%24.%2Fmemtool%3C%2FA%3E-32%2040000000%2010%3CBR%20%2F%3E%E4%BB%8E%E5%9C%B0%E5%9D%80%200x40000000%20%E5%BC%80%E5%A7%8B%E8%AF%BB%E5%8F%96%200x10%20%E8%AE%A1%E6%95%B0%3C%2FP%3E%3CP%3E0x40000000%3A%20%3CSTRONG%3EDEADBEAF%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000010%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000020%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%200x40000030%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3C%2FDIV%3E%3CSPAN%3ELabels%20parameters%3C%2FSPAN%3E%3CFORM%3E%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%3C%2FFORM%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E4%B8%8A%E8%BF%B0%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20958px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F107519i084603FDBC0E3527%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E7%9B%B8%E5%90%8C%E7%9A%84%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%99%84%E4%BB%B6%E4%B8%8D%E5%86%8D%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E4%BB%8E%E9%98%85%E8%AF%BB%E6%96%87%E7%AB%A0%E4%B8%AD%E4%B8%8D%E6%98%8E%E7%99%BD%E7%9A%84%E6%98%AF%E5%A6%82%E4%BD%95%E5%9C%A8%E4%B8%80%E4%B8%AA%20tlp%20%E4%B8%AD%E5%AE%9E%E9%99%85%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%2F%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EChristoph%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eduardo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%A7%A3%E5%86%B3%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBrian%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%86%20PCIE%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20i.MAX6%20Quad%20Sabre%20Lite%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%88%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%3C%2FA%3E%20%EF%BC%89%E4%BB%A5%E5%8F%8A%E4%B8%8E%20TW6865%20Intersil%20%E8%A7%86%E9%A2%91%E8%8A%AF%E7%89%87%E8%BF%9E%E6%8E%A5%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%B0%86%20TW6865%20%E7%9A%84%20REFCLK-%20%E5%92%8C%20REFCLK%2B%20%E4%B8%8E%20i.MAX6Q%20Sabre%20Lite%20%E7%9A%84%20PCIE%20%E7%AB%AF%E5%8F%A3%E8%BF%9E%E6%8E%A5%E7%9A%84%E8%B6%B3%E5%A4%9F%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%8F%AA%E6%9C%89%E4%BB%A5%E4%B8%8B%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%20style%3D%22width%3A%20249px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1894i97B4911B492CCAA1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_504.png%22%20alt%3D%22pastedImage_504.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_504.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E6%8C%87%E5%AF%BC%E6%88%91%E5%B0%86%20TW6865%20%E4%B8%8E%20Sabre%20Lite%20%E7%9A%84%20PCIE%20%E8%BF%9E%E6%8E%A5%E8%B5%B7%E6%9D%A5%E5%90%97%EF%BC%9F%EF%BC%88%E7%9B%AE%E5%89%8D%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%203.14.52%20%E5%86%85%E6%A0%B8%E7%9A%84%E7%B3%BB%E7%BB%9F%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%3C%2FP%3E%3CP%3EPeter%3C%2FP%3E%3CP%3Ei.max%E2%80%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Ftag%2Fi.mx6q%20pcie%2Ftg-p%22%20target%3D%22_blank%22%3E%23i.mx6q%20pcie%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E7%90%86%E6%9F%A5%E5%BE%B7%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20pcie%20%E9%93%BE%E8%B7%AF%20x1%20%E5%B0%86%E6%95%B0%E6%8D%AE%E4%BB%8E%20iMX6%20%E6%9D%BF%E4%BC%A0%E8%BE%93%E5%88%B0%20Xilinx%20FPGA%20%E6%9D%BF%EF%BC%8C%E4%BD%BF%E7%94%A8%20IPU%20DMA%20%E8%8E%B7%E5%BE%97%E5%90%88%E7%90%86%E7%9A%84%E6%80%A7%E8%83%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%20iMX6%20%E4%B8%AD%E7%9A%84%20PCIe%20RC%20%E6%B2%A1%E6%9C%89%20DMA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E5%85%B7%E4%BD%93%E6%83%85%E5%86%B5%E8%B0%83%E6%95%B4%E4%BA%86%E6%82%A8%E7%9A%84%E6%BC%94%E7%A4%BA%E3%80%82%E6%88%91%E5%9C%A8%E9%80%82%E5%BA%94%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E4%BB%80%E4%B9%88%E5%A4%A7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BB%8E%20iMX6%20%E5%88%B0%20FPGA%20%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%BC%BC%E4%B9%8E%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E4%B8%8E%20Yann%20%E4%B8%80%E6%A0%B7%EF%BC%88%E5%B0%BD%E7%AE%A1%E6%88%91%E4%BB%AC%E7%9A%84%E5%9C%BA%E6%99%AF%E4%B8%8D%E5%90%8C%EF%BC%89%EF%BC%8C%E6%B2%A1%E6%9C%89%E8%BE%BE%E5%88%B0%E6%BC%94%E7%A4%BA%E9%93%BE%E6%8E%A5%E4%B8%AD%E6%89%80%E8%BF%B0%E7%9A%84%20344%20MB%2Fs%EF%BC%8CTLP%20%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E4%B8%BA%2064%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%88%91%E5%9C%A8%20FPGA%20%E7%AB%AF%E6%8E%A5%E6%94%B6%E7%9A%84%20TLP%20%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E5%8F%AA%E6%9C%89%2016%20%E5%AD%97%E8%8A%82%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AA%E5%BE%97%E5%88%B0%E5%A4%A7%E7%BA%A6%2054MB%2Fs%E3%80%82%E6%88%91%E5%9C%A8%E4%B8%A4%E5%9D%97%E6%9D%BF%E4%B9%8B%E9%97%B4%E4%BD%BF%E7%94%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%98%AF%20mini%20pcie%20%E5%88%B0%20pcie%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22Resultado%20de%20imagen%20de%20mini%20pcie%20to%20pcie%20connector%22%20height%3D%22194%22%20src%3D%22http%3A%2F%2Fi.ebayimg.com%2Fimages%2Fi%2F221160508053-0-1%2Fs-l1000.jpg%22%20width%3D%22281%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%A2%9E%E5%8A%A0%E4%BC%A0%E8%BE%93%E7%9A%84%20TLP%20%E7%9A%84%E5%A4%A7%E5%B0%8F%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%20iMX6%20%E7%AB%AF%E8%A7%A6%E7%A2%B0%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EEduardo.%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E4%BA%86%E6%88%91%E4%BB%AC%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E5%81%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E5%AE%9E%E9%AA%8C%EF%BC%8C%E7%94%A8%20r8169%20%E9%A9%B1%E5%8A%A8%20nic%EF%BC%8Clinux%20bsp%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%20fsl%20%E7%9A%84%E5%8E%9F%E5%A7%8B%E4%BB%A3%E7%A0%81%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20r8168-8.039.00%E3%80%82%3C%2FP%3E%3CP%3E----------------------------------------------------------------%3C%2FP%3E%3CP%3Exx%20%26lt%3B%20%26gt%3B%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%BC%95%E6%93%8E%20Hamachi%20GNIC-II%20%E6%94%AF%E6%8C%81%20xx%3C%2FP%3E%3CP%3Exx%20%26lt%3B%20%26gt%3B%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%BC%95%E6%93%8E%20Yellowfin%20%E5%8D%83%E5%85%86%E7%BD%91%E5%8D%A1%E6%94%AF%E6%8C%81%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89xx%3C%2FP%3E%3CP%3Exx%20%26lt%3B*%26gt%3B%20Realtek%208169%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%94%AF%E6%8C%81%20xx%3C%2FP%3E%3CP%3Exx%20%26lt%3B%20%26gt%3B%20Realtek%208111E%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%94%AF%E6%8C%81%20%3C%2FP%3E%3CP%3E-------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%91%E8%AE%B0%E5%BE%97%E4%B9%8B%E5%89%8D%E5%9C%A8%20INTEL%20e1000e%20NIC%20%E5%8D%A1%E4%B8%8A%E9%AA%8C%E8%AF%81%E8%BF%87%E8%B6%85%E8%BF%87%201000%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%E5%8C%85%E4%BC%A0%E8%BE%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%82%A8%E8%83%BD%E5%86%8D%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%20NIC%20%E8%AE%BE%E5%A4%87%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E5%8F%82%E8%80%83%E6%97%A5%E5%BF%97%EF%BC%8C%E4%BB%85%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20ping%20192.168.1.253-s%20469%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPING%20192.168.1.253%EF%BC%88192.168.1.253%EF%BC%89%EF%BC%9A469%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%20477%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D0%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.595%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%20477%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D1%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.482%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%20477%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D2%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.457%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%20477%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D3%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%20%3D0.450%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253ping%E7%BB%9F%E8%AE%A1---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%8F%91%E9%80%81%E4%BA%86%204%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E6%8E%A5%E6%94%B6%E4%BA%86%204%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C0%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BE%80%E8%BF%94%E6%9C%80%E5%B0%8F%2F%3CSPAN%20class%3D%22SpellE%22%3E%E5%B9%B3%E5%9D%87%3C%2FSPAN%3E%2F%E6%9C%80%E5%A4%A7%20%3D%200.450%2F0.496%2F0.595%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%EF%BC%9A00.0%20PCI%20%E6%A1%A5%EF%BC%9A%E8%AE%BE%E5%A4%87%2016c3%EF%BC%9Aabcd%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2001%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%EF%BC%9A00.0%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9AIntel%20Corporation%2082574L%20%E5%8D%83%E5%85%86%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20ping%20192.168.1.253-s%201000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EPING%20192.168.1.253%EF%BC%88192.168.1.253%EF%BC%89%EF%BC%9A1000%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%201008%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D0%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.559%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%201008%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D1%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.485%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9D%A5%E8%87%AA%20192.168.1.253%20%E7%9A%84%201008%20%E5%AD%97%E8%8A%82%EF%BC%9A%3CSPAN%20class%3D%22SpellE%22%3E%E5%BA%8F%E5%88%97%E5%8F%B7%3C%2FSPAN%3E%3D2%3CSPAN%20class%3D%22SpellE%22%3E%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3D64%20%E6%97%B6%E9%97%B4%3D0.472%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253ping%E7%BB%9F%E8%AE%A1---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%8F%91%E9%80%81%203%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E6%8E%A5%E6%94%B6%203%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C0%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BE%80%E8%BF%94%E6%9C%80%E5%B0%8F%2F%3CSPAN%20class%3D%22SpellE%22%3E%E5%B9%B3%E5%9D%87%3C%2FSPAN%3E%2F%E6%9C%80%E5%A4%A7%20%3D%200.472%2F0.505%2F0.559%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%EF%BC%9A00.0%20PCI%20%E6%A1%A5%EF%BC%9A%E8%AE%BE%E5%A4%87%2016c3%EF%BC%9Aabcd%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2001%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%EF%BC%9A00.0%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9AIntel%20Corporation%2082574L%20%E5%8D%83%E5%85%86%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%8F%88%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%EF%BC%8Crtl8111e%E7%BD%91%E5%8D%A1%E5%9C%A8ping%E5%8C%85%26gt%3B%3D469bytes%E7%9A%84%E6%97%B6%E5%80%99%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8Cping%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%AC%E4%B8%8B%E8%BD%BDubuntu%E7%9A%84rootfs%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87ssh%E7%99%BB%E5%BD%95%EF%BC%8C%E8%BF%99%E4%B8%AA%E6%93%8D%E4%BD%9C%E4%B9%9F%E4%BC%9A%E5%AF%BC%E8%87%B4rtl8111e%E7%9A%84%E9%A9%B1%E5%8A%A8%E5%BC%82%E5%B8%B8%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E5%8F%A6%E4%B8%80%E4%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F393520%22%20target%3D%22_blank%22%3Emx6%20%2B%20rtl8111e%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%3C%2FA%3E%E4%BC%BC%E4%B9%8E%20Carmili%20Li%20%E5%92%8C%20Pavel%20%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%8E%E6%88%91%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82Alexander%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2014px%3B%20background-color%3A%20%23fefefe%3B%20font-family%3A%20arial%3B%22%3E%E6%8F%90%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E8%A1%A5%E4%B8%81%EF%BC%9A%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwww.spinics.net%2Flists%2Flinux-pci%2Fmsg34379.html%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5BPATCH%20-%20v4%5D%20PCI%3A%20keystone%3A%20%E6%B7%BB%E5%8A%A0%20pci%20%E6%80%AA%E7%99%96%E4%BB%A5%E9%99%90%E5%88%B6%20mrrs%20--%20Linux%20PCI%3C%2FA%3E%3C%2FSPAN%3E%20%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E2%80%9C%2Fdrivers%2Fpci%2Fhost%2Fpci-keystone.c%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20kernel%20ver%3A%20Linux%20version%203.0.35-2666-gbdde708%3C%2FP%3E%3CP%3Ertl8111e%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Er8168%3A%20Realtek%20PCIe%20GBE%20%E7%B3%BB%E5%88%97%E6%8E%A7%E5%88%B6%E5%99%A8%20mcfg%20%3D%200014%3C%2FP%3E%3CP%3Er8168%200000%3A01%3A00.0%EF%BC%9A%E6%B2%A1%E6%9C%89%20MSI%E3%80%82%E8%BF%94%E5%9B%9E%20INTx%E3%80%82%3C%2FP%3E%3CP%3Er8168%EF%BC%9A%E6%9C%AC%E4%BA%A7%E5%93%81%E5%8F%97%E4%BB%A5%E4%B8%8B%E4%B8%80%E9%A1%B9%E6%88%96%E5%A4%9A%E9%A1%B9%E4%B8%93%E5%88%A9%E4%BF%9D%E6%8A%A4%EF%BC%9AUS6%2C570%2C884%E3%80%81US6%2C115%2C776%20%E5%92%8C%20US6%2C327%2C625%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Er8168%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(C)%202014%20Realtek%20NIC%20%E8%BD%AF%E4%BB%B6%E5%9B%A2%E9%98%9F%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E7%A8%8B%E5%BA%8F%E7%BB%9D%E5%AF%B9%E4%B8%8D%E9%99%84%E5%B8%A6%E4%BB%BB%E4%BD%95%E6%8B%85%E4%BF%9D%EF%BC%9B%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%E5%85%8D%E8%B4%B9%E8%BD%AF%E4%BB%B6%EF%BC%8C%E6%AC%A2%E8%BF%8E%E6%82%A8%E5%9C%A8%E7%89%B9%E5%AE%9A%E6%9D%A1%E4%BB%B6%E4%B8%8B%E9%87%8D%E6%96%B0%E5%88%86%E5%8F%91%E5%AE%83%EF%BC%9B%E8%AF%B7%E5%8F%82%E9%98%85%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eping%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-s%20465%3C%2FP%3E%3CP%3EPING%20192.168.1.5%EF%BC%88192.168.1.5%EF%BC%89%EF%BC%9A465%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20192.168.1.5%20%E7%9A%84%20473%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%3D0%20%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3D64%20%E6%97%B6%E9%97%B4%3D0.435%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20192.168.1.5%20%E7%9A%84%20473%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%3D1%20%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3D64%20%E6%97%B6%E9%97%B4%3D0.518%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5ping%E7%BB%9F%E8%AE%A1---%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8F%91%E9%80%81%202%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E5%B7%B2%E6%8E%A5%E6%94%B6%202%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C0%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%3C%2FP%3E%3CP%3E%E5%BE%80%E8%BF%94%E6%9C%80%E5%B0%8F%2F%E5%B9%B3%E5%9D%87%2F%E6%9C%80%E5%A4%A7%20%3D%200.435%2F0.476%2F0.518%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-s%20468%3C%2FP%3E%3CP%3EPING%20192.168.1.5%EF%BC%88192.168.1.5%EF%BC%89%EF%BC%9A468%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20192.168.1.5%20%E7%9A%84%20476%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%3D0%20%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3D64%20%E6%97%B6%E9%97%B4%3D0.440%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20192.168.1.5%20%E7%9A%84%20476%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%3D1%20%E7%94%9F%E5%AD%98%E6%97%B6%E9%97%B4%3D64%20%E6%97%B6%E9%97%B4%3D0.503%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5ping%E7%BB%9F%E8%AE%A1---%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8F%91%E9%80%81%202%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E5%B7%B2%E6%8E%A5%E6%94%B6%202%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C0%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%3C%2FP%3E%3CP%3E%E5%BE%80%E8%BF%94%E6%9C%80%E5%B0%8F%2F%E5%B9%B3%E5%9D%87%2F%E6%9C%80%E5%A4%A7%20%3D%200.440%2F0.471%2F0.503%E5%A4%9A%E5%8F%91%E6%80%A7%E7%A1%AC%E5%8C%96%E7%97%87%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-s%20469%3C%2FP%3E%3CP%3EPING%20192.168.1.5%EF%BC%88192.168.1.5%EF%BC%89%EF%BC%9A469%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5ping%E7%BB%9F%E8%AE%A1---%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8F%91%E9%80%81%2034%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E5%B7%B2%E6%8E%A5%E6%94%B6%200%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%E7%8E%87%E4%B8%BA%20100%25%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%9C%B1%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E5%A4%AA%E6%98%8E%E7%99%BD%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E7%9A%84%20IPU%20%E8%A1%A5%E4%B8%81%E6%98%AF%E7%94%A8%E6%9D%A5%E5%81%9A%E4%BB%80%E4%B9%88%E7%9A%84%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%8F%90%E4%BE%9B%E7%9A%84%20IPU%20%E8%A1%A5%E4%B8%81%E6%97%A8%E5%9C%A8%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%20IPU%20%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%B8%8D%E8%BF%9B%E8%A1%8C%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%E7%9A%84%20IPU%20DMA%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20IPU%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%EF%BC%8C%E9%82%A3%E4%B9%88%E4%B9%8B%E5%90%8E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20IPU%20DMA%20%E5%90%97%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20IPU%20%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%B8%AA%E5%87%A0%E4%B9%8E%E4%B8%8D%E6%94%B9%E5%8F%98%E5%9B%BE%E7%89%87%E7%9A%84%E5%BE%AE%E5%B0%8F%E8%BF%87%E7%A8%8B%EF%BC%88%E4%BE%8B%E5%A6%82%E8%A3%81%E5%89%AA%201%20%E8%A1%8C%EF%BC%89%E6%9D%A5%E8%AE%BF%E9%97%AE%20DMA%20%E5%B9%B6%E4%BB%A5%E9%AB%98%E9%80%9F%E7%8E%87%EF%BC%88344MB%2Fs%EF%BC%89%E5%9C%A8%20DDR%20%E4%B8%AD%E5%AD%98%E5%82%A8%E5%9B%BE%E7%89%87%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20iMX6%20%E5%92%8C%E6%88%91%E7%9A%84%E8%A7%86%E9%A2%91%E5%A4%84%E7%90%86%E5%8D%A1%E4%B9%8B%E9%97%B4%E6%9C%89%E4%B8%80%E4%B8%AA%20PHYFLEX%20%E8%BD%BD%E6%9D%BF%201364.3%EF%BC%88%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%89%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E7%8E%87%E4%BD%8E%E7%9A%84%E5%8E%9F%E5%9B%A0...%E6%88%91%E5%B0%86%E6%A3%80%E6%9F%A5%E8%BF%9E%E6%8E%A5%E4%BB%A5%E7%A1%AE%E4%BF%9D%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E6%82%A8%E4%B8%8D%E8%83%BD%E5%9C%A8%E6%82%A8%E7%9A%84%E5%AE%9E%E7%8E%B0%E4%B8%AD%E4%BD%BF%E7%94%A8%20IPU%20DMA%20%E5%BC%95%E6%93%8E%EF%BC%8C%E5%9B%A0%E4%B8%BA%20IPU%20DMA%20%E5%BC%95%E6%93%8E%E6%98%AF%E4%B8%93%E9%97%A8%E4%B8%BA%20IPU%20%E4%BD%BF%E7%94%A8%E8%80%8C%E8%AE%BE%E8%AE%A1%E7%9A%84%EF%BC%8C%E4%B8%8D%E8%83%BD%E7%94%A8%E4%BD%9C%E9%80%9A%E7%94%A8%20DMA%20%E5%BC%95%E6%93%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%91%E5%BE%88%E5%A5%BD%E5%A5%87%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%A0%E4%BB%AC%E9%82%A3%E8%BE%B9%E7%9A%84%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E5%90%9E%E5%90%90%E9%87%8F%E8%BF%99%E4%B9%88%E5%B7%AE%EF%BC%8C%E4%BD%A0%E8%83%BD%E7%A1%AE%E4%BF%9D%E8%BF%9E%E6%8E%A5%E7%9A%84%E8%B4%A8%E9%87%8F%E5%90%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eimx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%E6%8E%A5%E5%8F%A3%E5%92%8C%E4%BD%A0%E7%9A%84%E8%A7%86%E9%A2%91%E5%A4%84%E7%90%86%E5%8D%A1%E4%B9%8B%E9%97%B4%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%E8%B4%A8%E9%87%8F%E4%B8%8D%E5%A4%9F%E5%A5%BD%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%BF%9B%E8%A1%8C%E5%A4%A7%E9%87%8F%E7%9A%84%20CRC%20%E5%92%8C%E9%87%8D%E8%AF%95%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%A5%9D%E6%82%A8%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%9C%89%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%E6%A8%A1%E5%BC%8F%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%3CSPAN%20class%3D%22SpellE%22%3Efsl%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Ebsp%3C%2FSPAN%3E%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%9C%B1%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BB%94%E7%BB%86%E9%98%85%E8%AF%BB%E4%BA%86%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E7%9A%84%E7%B3%BB%E7%BB%9F%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E3%80%82%20%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%E6%88%91%E5%85%88%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%BC%A0%E8%A7%86%E9%A2%91%E5%A4%84%E7%90%86%E5%8D%A1%EF%BC%8C%E9%80%9A%E8%BF%87%20PCIe%20%E6%8F%92%E6%A7%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20iMX6%E3%80%82%E8%A7%86%E9%A2%91%E5%A4%84%E7%90%86%E5%8D%A1%E5%8F%96%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%E5%B0%86%E5%9B%BE%E7%89%87%E5%86%99%E5%85%A5iMX6%E7%9A%84DDR%E4%B8%AD%E3%80%82%E5%B0%B1%E5%83%8F%E4%BD%A0%E6%89%80%E5%81%9A%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%8C%E6%88%91%E5%87%8F%E5%B0%91%E4%BA%86iMX6%E7%9A%84%E5%86%85%E5%AD%98%EF%BC%88MEM%3D768M%EF%BC%89%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%E4%BB%8E%200x4000_0000%20%E5%BC%80%E5%A7%8B%E7%9A%84%E5%9C%B0%E5%9D%80%E6%9D%A5%E5%86%99%E5%85%A5%E5%9B%BE%E7%89%87%E3%80%82%E8%BF%99%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E6%9C%80%E5%A4%A7%E5%86%99%E5%85%A5%E9%80%9F%E5%BA%A6%E7%BA%A6%E4%B8%BA%2050MB%2Fs%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20IPU%20%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E6%9D%A5%E8%BE%BE%E5%88%B0%20344MB%2Fs%20%E7%9A%84%E9%80%9F%E5%BA%A6%E5%90%97%EF%BC%9F%E6%88%91%E5%88%B0%E5%BA%95%E8%AF%A5%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EYann%20Tinauus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%20%E6%9C%B1%E7%BA%A2%E6%98%9F%E6%82%A8%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8RC%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%B5%8B%E8%AF%95%E4%BA%86imx6%E5%B9%B3%E5%8F%B0sdk%E2%80%9Cpcie_test%E2%80%9D%EF%BC%8Cimx6%E5%B9%B3%E5%8F%B0sdk%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89EP%E6%A8%A1%E5%BC%8F%E6%B5%8B%E8%AF%95%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%90%86%E6%9F%A5%E5%BE%B7%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E4%BA%86%E5%86%85%E6%A0%B8configure%EF%BC%8C%E5%B9%B6%E5%86%8D%E6%AC%A1%E7%BC%96%E8%AF%91%E4%BA%86%E5%86%85%E6%A0%B8%E3%80%82%E4%BD%86%E7%BB%93%E6%9E%9C%E6%98%AF%E4%B8%80%E6%A0%B7%E7%9A%84%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E***%20MX6%20%E9%80%89%E9%A1%B9%EF%BC%9A***%20%3C%2FP%3E%3CP%3Exx%20%5B*%5D%20PCI%20Express%20%E6%94%AF%E6%8C%81%20%3C%2FP%3E%3CP%3Exx%20%5B%20%5D%20IMX6%20RC%2FEP%20%E4%BA%92%E8%BF%9E%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%20PCI%20Express%20EP%20%E6%A8%A1%E5%BC%8F%20%3C%2FP%3E%3CP%3Exx%20%5B%20%5D%20IMX6%20RC%2FEP%20%E4%BA%92%E8%BF%9E%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%20PCI%20Express%20RC%20%E6%A8%A1%E5%BC%8F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E4%B8%8E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%22%3EIPU%20%E7%9B%B8%E5%85%B3%3C%2FSPAN%3E%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%8F%AA%E6%98%AF%E5%8A%A0%E8%BD%BD%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%EF%BC%8C%E9%85%8D%E7%BD%AE%20eth1%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20PING%20%E5%91%BD%E4%BB%A4%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8CRTL8111E%20%E6%98%AF%E4%B8%80%E4%B8%AA%20PCIE%20%E7%BD%91%E5%8D%A1%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%80%E4%B8%AA%20mini-PCIE%20%E5%88%B0%20PCIE%20%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%E8%BF%9E%E6%8E%A5%20RTL8111E%20%E7%BD%91%E5%8D%A1%E5%92%8C%20i.MX6-SebraSDP%20%E6%9D%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%85%B3%E4%BA%8E%E4%BB%A5%E4%B8%8B%E8%BD%AC%E5%82%A8%EF%BC%8C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E2%80%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%E4%BB%A3%E7%A0%81%EF%BC%9Ae59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%E4%B8%8D%E8%83%BD%E5%9C%A8%E4%B8%AD%E6%96%AD%E4%B8%8A%E4%B8%8B%E6%96%87%E4%B8%AD%E8%B0%83%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Arial%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20inherit%20%2C%20serif%3B%20%22%3E%20clk_enable%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%A5%87%E6%80%AA%E7%9A%84%E6%98%AF%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E6%89%A7%E8%A1%8C%20RTL8111e%20%E6%93%8D%E4%BD%9C%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%8E%20IPU%20%E7%9B%B8%E5%85%B3%E7%9A%84%E5%86%85%E6%A0%B8%E8%BD%AC%E5%82%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%88%A0%E9%99%A4%E5%90%8E%E6%82%A8%E8%83%BD%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%E2%80%9C%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border-collapse%3Acollapse%3Bmso-yfti-tbllook%3A1184%3Bmso-padding-alt%3A0in%200in%200in%200in%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A0%3Bmso-yfti-firstrow%3Ayes%3Bmso-yfti-lastrow%3Ayes%22%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3EPCI%20Express%E6%94%AF%E6%8C%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3E%3CSPAN%20class%3D%22SpellE%22%3Exx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E2%80%9C%E5%9C%A8%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B7%BB%E5%8A%A0%E5%86%85%E6%A0%B8%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CTABLE%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%26lt%3B*%26gt%3B%20PCI%20Stub%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20PCI%20IOV%20%E6%94%AF%E6%8C%81%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B*%5D%20PCI%20Express%E6%94%AF%E6%8C%81%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B*%5D%20%E6%A0%B9%E7%AB%AF%E5%8F%A3%E9%AB%98%E7%BA%A7%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E6%94%AF%E6%8C%81%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EPCI%20Express%20ECRC%20%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%26lt%3B%20%26gt%3B%20%3C%2FTD%3E%3CTD%3EPCIe%20AER%20%E9%94%99%E8%AF%AF%E6%B3%A8%E5%85%A5%E5%99%A8%E6%94%AF%E6%8C%81%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B*%5D%20PCI%20Express%20ASPM%20%E6%8E%A7%E5%88%B6%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Exx%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EDebug%20PCI%20Express%20ASPM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA%EF%BC%9ALinux%20%E7%89%88%E6%9C%AC%203.0.35-2666-gbdde708%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%8E%8B%20Linux...%E5%AE%8C%E6%88%90%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ELinux%20%E7%89%88%E6%9C%AC%203.0.35-2666-gbdde708(user%40ubuntu)%20(gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%89%EF%BC%89%2320%20SMP%20PREEMPT%202015%20%E5%B9%B4%201%20%E6%9C%88%2011%20%E6%97%A5%E6%98%9F%E6%9C%9F%E6%97%A5%2002%3A32%3A04%20PST%3CBR%20%2F%3E%20CPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c53c7d%3CBR%20%2F%3E%20CPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%EF%BC%9AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20%E4%B8%BB%E6%9D%BF%3CBR%20%2F%3E%E5%BF%BD%E7%95%A5%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%E6%A0%87%E7%AD%BE%200x54410008%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3CBR%20%2F%3E%20CPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3CBR%20%2F%3E%20PERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3CBR%20%2F%3E%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A194560%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CBR%20%2F%3E%20PID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20Dentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20Inode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A512MB%20256MB%20%3D%20%E5%85%B1768MB%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A765672k%2F765672k%E5%8F%AF%E7%94%A8%EF%BC%8C282904k%E4%BF%9D%E7%95%99%EF%BC%8C0K%20highmem%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3CBR%20%2F%3E%E4%BF%AE%E5%A4%8D%E6%98%A0%E5%B0%84%EF%BC%9A0xfff00000%20-%200xfffe0000%EF%BC%88896%20kB%EF%BC%89%3CBR%20%2F%3E%20DMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%3CBR%20%2F%3E%20vmalloc%EF%BC%9A0xc0800000-0xf2000000%EF%BC%88792%20MB%EF%BC%89%3CBR%20%2F%3E%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xc0000000%EF%BC%881024%20MB%EF%BC%89%3CBR%20%2F%3E%E5%8C%85%E6%98%A0%E5%B0%84%EF%BC%9A0x7fe00000%20-%200x80000000%EF%BC%882%20MB%EF%BC%89%3CBR%20%2F%3E%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3CBR%20%2F%3E%20.%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9A0x80008000-0x8003d000%EF%BC%88212%20KB%EF%BC%89%3CBR%20%2F%3E%20%E3%80%82%E6%96%87%E6%9C%AC%3A%200x8003d000%20-%200x80aa54f0%20(10658%20KB)%3CBR%20%2F%3E%20%E3%80%82%E6%95%B0%E6%8D%AE%EF%BC%9A0x80aa6000-0x80b0a660%EF%BC%88402%20KB%EF%BC%89%3CBR%20%2F%3E%20.bss%EF%BC%9A0x80b0a684-0x80b58b8c%EF%BC%88314%20KB%EF%BC%89%3CBR%20%2F%3E%20SLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3CBR%20%2F%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E7%9A%84%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3ENR_IRQS%EF%BC%9A624%3CBR%20%2F%3E%20MXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3CBR%20%2F%3Esched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3CBR%20%2F%3Earm_max_freq%3D1GHz%3CBR%20%2F%3E%20MXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x2020000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc0%5D%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3CBR%20%2F%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3CBR%20%2F%3E%20pid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3CBR%20%2F%3E%20CPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Ehw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3ECPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3E%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3CBR%20%2F%3E%20SMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3CBR%20%2F%3E%20print_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%EF%BC%8C700%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Ehw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3El2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3CBR%20%2F%3E%20bio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3CBR%20%2F%3E%20mxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9ASPKVDD%EF%BC%9A4200%20mV%3CBR%20%2F%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%3CBR%20%2F%3E%20vgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3ESCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Espi_imx%20imx6q-ecspi.0%EF%BC%9A%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3CBR%20%2F%3E%20usbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3CBR%20%2F%3E%E5%B7%B2%E5%8A%A0%E8%BD%BD%20Freescale%20USB%20OTG%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%24Revision%3A%201.55%20%24%3CBR%20%2F%3E%20mc_pfuze%201-0008%3A%20ID%3A%200%2C%E5%85%A8%E5%B1%82%3A%201%2C%E9%87%91%E5%B1%9E%E5%B1%82%3A%201%3CBR%20%2F%3E%20mc_pfuze%201-0008%3A%20FAB%3A%200%2CFIN%3A%200%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%20300%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203300%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203150%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20%E5%9C%A8%205000%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20%E8%87%B3%201800%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VREFDDR%3A%20750%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%202800%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%201800%20mV%3CBR%20%2F%3E%20print_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203000%20mV%20%E5%A4%84%3CBR%20%2F%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203300%20mV%3CBR%20%2F%3E%20imx-ipuv3%20imx-ipuv3.0%EF%BC%9AIPU%20DMFC%20%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%E3%80%815B(4%2C5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%20imx-ipuv3%20imx-ipuv3.1%EF%BC%9AIPU%20DMFC%20%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%E3%80%815B(4%2C5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%20mxc_mipi_csi2%20mxc_mipi_csi2%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%20i.MX%20MIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%E7%89%88%E6%9C%AC%E4%B8%BA0x3130302a%3CBR%20%2F%3E%20MIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0.24%E3%80%82%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.16%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F31%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3CBR%20%2F%3Emax17135%202-0048%EF%BC%9A%E7%94%A8%E4%BA%8E%E7%94%B5%E5%AD%90%E5%A2%A8%E6%B0%B4%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%20PMIC%20MAX17135%3CBR%20%2F%3E%20i2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmax17135%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3CBR%20%2F%3E%20IP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20TCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20TCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20TCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3CBR%20%2F%3E%20TCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20UDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3CBR%20%2F%3E%20RPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3EPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3CBR%20%2F%3Ei.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3CBR%20%2F%3E%20PM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3EiMX6%20PCIe%20PCIe%20RC%20%E6%A8%A1%E5%BC%8F%20imx_pcie_pltfm_probe%20%E6%AD%A3%E5%9C%A8%E8%BF%9B%E5%85%A5%E3%80%82%3CBR%20%2F%3EPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20%2F%3EIMX%20PCIe%20%E7%AB%AF%E5%8F%A3%EF%BC%9A%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3EPCI%EF%BC%9Abus0%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%EF%BC%9A%E6%80%BB%E7%BA%BF1%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01000000-0x010fffff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%20(PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1000000-0x10fffff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9ABAR%209%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01100000-0x011fffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9ABAR%206%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9ABAR%207%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bio%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%204%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01100000-0x01103fff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%204%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%5Bmem%200x01100000-0x01103fff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1100000-0x1103fff%5D%EF%BC%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01104000-0x01104fff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%202%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%5Bmem%200x01104000-0x01104fff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1104000-0x1104fff%5D%EF%BC%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bio%200x1e00000-0x1e000ff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%5Bio%200x1e00000-0x1e000ff%5D%20(PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1e00000-0x1e000ff%5D)%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20PCI%20%E6%A1%A5%E8%87%B3%20%5B%E6%80%BB%E7%BA%BF%2001-01%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bio%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%20%5Bmem%20%E5%B7%B2%E7%A6%81%E7%94%A8%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Epci%200000%EF%BC%9A00%EF%BC%9A00.0%EF%BC%9A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bmem%200x01100000-0x011fffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FSTRONG%3E%3CBR%20%2F%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3CBR%20%2F%3E%20IMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3CBR%20%2F%3ECPU%E8%B0%83%E8%8A%82%E6%A8%A1%E5%BC%8F%EF%BC%9Aldo_bypass%3CBR%20%2F%3E%20_regulator_get%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3CBR%20%2F%3E%20mx6_cpu_regulator_init%3A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96pu%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3Ei.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3CBR%20%2F%3EJFFS2%20%E7%89%88%E6%9C%AC%202.2%E3%80%82%EF%BC%88NAND%EF%BC%89%20%C2%A9%202001-2006%20%E7%BA%A2%E5%B8%BD%E5%85%AC%E5%8F%B8%3CBR%20%2F%3Emsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201495%3CBR%20%2F%3E%20alg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3CBR%20%2F%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%20mxc_mipi_dsi%20mxc_mipi_dsi%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%E7%9A%84%20i.MX%20MIPI%20DSI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fhdmi%3CBR%20%2F%3E%20mxc_hdmi%20mxc_hdmi%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0HDMI%E6%8E%A7%E5%88%B6%E5%99%A80x13%EF%BC%9A0xa%EF%BC%9A0xa0%EF%BC%9A0xc1%3CBR%20%2F%3E%20fbcvt%EF%BC%9A1920x1080%4060%EF%BC%9ACVT%E5%90%8D%E7%A7%B0%20-%202.073M9%3CBR%20%2F%3E%20imx-ipuv3%20imx-ipuv3.0%EF%BC%9AIPU%20DMFC%20DP%20%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%9A1(0%2C1)%E3%80%815B(2~5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E8%AE%BE%E5%A4%87%20240x67%3CBR%20%2F%3E%20mxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3E%20_regulator_get%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3CBR%20%2F%3E%20mxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Flcd%3CBR%20%2F%3E%20mxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9Aipu0-di0%20%E5%B7%B2%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3Emxc_sdc_fb%EF%BC%9Amxc_sdc_fb.2%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-16%3CBR%20%2F%3E%20mxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3E%20imx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3CBR%20%2F%3E%20imx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EIMX-UART.2%EF%BC%9Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21ec000%20(irq%20%3D%2060)%20%E6%98%AF%E4%B8%80%E4%B8%AA%20IMX%3CBR%20%2F%3E%20IMX-UART.0%EF%BC%9AMMIO%200x2020000%20(irq%20%3D%2058)%20%E5%A4%84%E7%9A%84%20ttymxc0%20%E6%98%AF%20IMX%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E6%B2%A1%E6%9C%89%20SATA%20%E7%A3%81%E7%9B%98%E3%80%82%3CBR%20%2F%3Em25p80%20spi0.0%EF%BC%9A%E6%89%BE%E5%88%B0%20m25p32%EF%BC%8C%E9%A2%84%E6%9C%9F%E4%B8%BA%20sst25vf016b%3CBR%20%2F%3E%20m25p80%20spi0.0%EF%BC%9Am25p32%EF%BC%884096%20KB%EF%BC%89%3CBR%20%2F%3E%E5%9C%A8%E2%80%9Cm25p80%E2%80%9D%E4%B8%8A%E5%88%9B%E5%BB%BA%202%20%E4%B8%AA%20MTD%20%E5%88%86%E5%8C%BA%EF%BC%9A%3CBR%20%2F%3E%200x000000000000-0x000000100000%EF%BC%9A%E2%80%9C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E2%80%9D%3CBR%20%2F%3E%200x000000100000-0x000000400000%EF%BC%9A%E2%80%9C%E5%86%85%E6%A0%B8%E2%80%9D%3CBR%20%2F%3E%20GPMI%20NAND%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%EF%BC%88IMX%EF%BC%89%3CBR%20%2F%3E%20vcan%EF%BC%9A%E8%99%9A%E6%8B%9F%20CAN%20%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3Eflexcan%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EFEC%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Efec_enet_mii_bus%EF%BC%9A%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3CBR%20%2F%3E%20fsl-ehci%20fsl-ehci.0%EF%BC%9Airq%2075%EF%BC%8Cio%E5%9F%BA%E5%9D%800x02184000%3CBR%20%2F%3E%20fsl-ehci%20fsl-ehci.0%EF%BC%9AUSB%202.0%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3CBR%20%2F%3E%20fsl-ehci%20fsl-ehci.1%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Efsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3CBR%20%2F%3E%20fsl-ehci%20fsl-ehci.1%EF%BC%9Airq%2072%EF%BC%8Cio%E5%9F%BA%E5%9D%800x02184200%3CBR%20%2F%3E%20fsl-ehci%20fsl-ehci.1%EF%BC%9AUSB%202.0%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fcdc_acm%3CBR%20%2F%3E%20cdc_acm%EF%BC%9A%E7%94%A8%E4%BA%8E%20USB%20%E8%B0%83%E5%88%B6%E8%A7%A3%E8%B0%83%E5%99%A8%E5%92%8C%20ISDN%20%E9%80%82%E9%85%8D%E5%99%A8%E7%9A%84%20USB%20%E6%8A%BD%E8%B1%A1%E6%8E%A7%E5%88%B6%E6%A8%A1%E5%9E%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3CBR%20%2F%3E%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3EARC%20USBOTG%20%E8%AE%BE%E5%A4%87%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%882005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5%EF%BC%89%3CBR%20%2F%3E%20mousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84%20PS%2F2%20%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amax11801_ts%E4%BD%9C%E4%B8%BA%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3CBR%20%2F%3E%20egalax_ts%201-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3CBR%20%2F%3Eegalax_ts%EF%BC%9A1-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9AeGalax%20%E8%A7%A6%E6%91%B8%E5%B1%8F%E4%B8%BA%20%2Fdevices%2Fplatform%2Fimx-i2c.2%2Fi2c-2%2F2-0004%2Finput%2Finput2%3CBR%20%2F%3E%20elan-%E8%AF%BB%E5%8F%96%20Hello%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Eelan-touch%EF%BC%9A2-0010%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Aisl29023%20%E5%85%89%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fvirtual%2Finput%2Finput3%3CBR%20%2F%3E%20isl29023%202-0044%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0%3CBR%20%2F%3E%20i2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9Artc%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B0%86%20snvs_rtc%20%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3CBR%20%2F%3E%20i2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ELinux%E8%A7%86%E9%A2%91%E9%87%87%E9%9B%86%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3CBR%20%2F%3E%20mxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video16%3CBR%20%2F%3E%20mxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video17%3CBR%20%2F%3E%20mxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video18%3CBR%20%2F%3E%20mxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video19%3CBR%20%2F%3E%20mxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video20%3CBR%20%2F%3E%20mag3110%202-000e%EF%BC%9A%E6%A3%80%E6%9F%A5mag3110%E8%8A%AF%E7%89%87ID%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amag3110%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fvirtual%2Finput%2Finput4%3CBR%20%2F%3E%20mag3110%202-000e%EF%BC%9Amag3110%20%E8%A2%AB%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amma845x%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fvirtual%2Finput%2Finput5%3CBR%20%2F%3E%20imx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E8%99%9A%E6%8B%9F%20HCI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E9%80%9A%E7%94%A8%E8%93%9D%E7%89%99%20USB%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.6%3CBR%20%2F%3E%20usbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3CBR%20%2F%3E%20sdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Esdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3CBR%20%2F%3E%20mmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.3%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3CBR%20%2F%3E%20mmc1%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.1%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3CBR%20%2F%3E%20mmc2%3A%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5Bsdhci-esdhc-imx.2%5D%E4%BD%BF%E7%94%A8%20DMA%3CBR%20%2F%3E%20mxc_vdoa%20mxc_vdoa%EF%BC%9A%E6%8E%A2%E6%B5%8Bi.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%88VDOA%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EVPU%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Emxc_asrc%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EGalcore%20%E7%89%88%E6%9C%AC%204.6.9.6622%3CBR%20%2F%3E%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x55c4af7d%3CBR%20%2F%3E%E6%AF%94%E7%8E%87%20%3D%20176%20%E7%9A%84%E7%83%AD%E4%BC%A0%E6%84%9F%E5%99%A8%3CBR%20%2F%3EAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3CBR%20%2F%3E%20anatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3CBR%20%2F%3E%20usbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3CBR%20%2F%3E%20usbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20snd-usb-audio%3CBR%20%2F%3E%20mxc_hdmi_soc%20mxc_hdmi_soc.0%EF%BC%9AMXC%20HDMI%20%E9%9F%B3%E9%A2%91%3CBR%20%2F%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ewm8962%200-001a%EF%BC%9A%E5%AE%A2%E6%88%B7%20ID%200%20%E4%BF%AE%E8%AE%A2%E7%89%88%20D%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9AWM8962%20%E8%9C%82%E9%B8%A3%E5%99%A8%E5%8F%91%E7%94%9F%E5%99%A8%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fimx-i2c.0%2Fi2c-0%2F0-001a%2Finput%2Finput6%3CBR%20%2F%3E%20asoc%3A%20wm8962%20%26lt%3B-%26gt%3B%20imx-ssi.1%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Awm8962-audio%20DMIC%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput7%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Awm8962-audio%20Ext%20Spk%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput8%3CBR%20%2F%3Eimx_3stack%20asoc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Easoc%3A%20mxc-hdmi-soc%20%26lt%3B-%26gt%3B%20imx-hdmi-soc-dai.0%E6%98%A0%E5%B0%84%E6%88%90%E5%8A%9F%3CBR%20%2F%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E%20%230%EF%BC%9Awm8962-%E9%9F%B3%E9%A2%91%3CBR%20%2F%3E1%3AIMX%20HDMI%20SOC%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3CBR%20%2F%3E%20TCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3CBR%20%2F%3E%20CAN%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E6%A0%B8%E5%BF%83%EF%BC%88rev%2020090105%20abi%208%EF%BC%89%3CBR%20%2F%3E%20NET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2029%3CBR%20%2F%3E%20can%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%EF%BC%89%3CBR%20%2F%3E%20can%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%20t%EF%BC%89%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3CBR%20%2F%3E%20mmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E5%8D%A1%3CBR%20%2F%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%3CBR%20%2F%3E%20mmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20%E5%88%86%E5%8C%BA%201%202.00%20MiB%3CBR%20%2F%3E%20mmcblk0boot1%EF%BC%9Ammc0%EF%BC%9A0001%20SEM08G%20%E5%88%86%E5%8C%BA%202%202.00%20MiB%3CBR%20%2F%3E%20mmcblk0%3A%20p1%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3CBR%20%2F%3Emmcblk0boot1%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E7%95%8C%E9%9D%A2%E6%A8%A1%E6%8B%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3CBR%20%2F%3E%20mmcblk0boot0%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3CBR%20%2F%3Elib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3CBR%20%2F%3EVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3Emxc_dvfs_core_probe%3CBR%20%2F%3E%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3CBR%20%2F%3Eregulate_init_complete%3A%20PFUZE100_VGEN6%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3CBR%20%2F%3Eregulate_init_complete%3A%20PFUZE100_VGEN3%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3CBR%20%2F%3Eregulate_init_complete%3A%20PFUZE100_VGEN2%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3CBR%20%2F%3Eregulate_init_complete%3A%20PFUZE100_VGEN1%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01%2000%3A00%3A01%20UTC%20(1)%3CBR%20%2F%3E%E7%AD%89%E5%BE%85%E6%A0%B9%E8%AE%BE%E5%A4%87%20%2Fdev%2Fmmcblk1p1...%3CBR%20%2F%3E%20mmc2%EF%BC%9A%E5%9C%B0%E5%9D%80%201234%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20SDHC%20%E5%8D%A1%3CBR%20%2F%3Emmcblk1%EF%BC%9Ammc2%EF%BC%9A1234%20SA04G%203.63%20GiB%3CBR%20%2F%3E%20mmcblk1%3A%20p1%3CBR%20%2F%3E%20EXT3-fs%EF%BC%9A%E6%9C%AA%E5%90%AF%E7%94%A8%E5%B1%8F%E9%9A%9C%3CBR%20%2F%3Ekjournald%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%94%205%20%E7%A7%92%3CBR%20%2F%3EEXT3-fs%EF%BC%88mmcblk1p1%EF%BC%89%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3CBR%20%2F%3EEXT3-fs%EF%BC%88mmcblk1p1%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3CBR%20%2F%3EEXT3-fs%EF%BC%88mmcblk1p1%EF%BC%89%EF%BC%9A%E4%BB%A5%E5%9B%9E%E5%86%99%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E6%8C%82%E8%BD%BD%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3EVFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%20179%3A25%20%E4%B8%8A%E6%8C%82%E8%BD%BD%E6%A0%B9%EF%BC%88ext3%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E9%87%8A%E6%94%BE%E5%88%9D%E5%A7%8B%E5%86%85%E5%AD%98%EF%BC%9A212K%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20pid%201468%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2FrcS'%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%20%2Fproc%20%E5%92%8C%20%2Fsys%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20udevd%3CBR%20%2F%3E%20udevd%EF%BC%881477%EF%BC%89%EF%BC%9A%2Fproc%2F1477%2Foom_adj%20%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E6%94%B9%E7%94%A8%2Fproc%2F1477%2Foom_score_adj%E3%80%82%3CBR%20%2F%3E%E5%90%88%E6%88%90%E5%88%9D%E5%A7%8B%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3E%E5%B0%86%E4%B8%BB%E6%9C%BA%E5%90%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%20freescale%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3CBR%20%2F%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3CBR%20%2F%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3CBR%20%2F%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3CBR%20%2F%3Emount%EF%BC%9A%E5%9C%A8%20%2Fproc%2Fbus%2Fusb%20%E4%B8%8A%E5%AE%89%E8%A3%85%20usbfs%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20pid%203292%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_gpu.S'%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20pid%203298%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%894.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%3CBR%20%2F%3E%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%9E%84%E5%BB%BA%E4%BA%8E%202014%20%E5%B9%B4%2012%20%E6%9C%88%2031%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%2021%3A03%3A35%20-0800%3CBR%20%2F%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%8D%8A%E5%AF%BC%E4%BD%93%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%91%BD%E4%BB%A4%3CSTRONG%3Elspci%3C%2FSTRONG%3E%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E7%B1%BB%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%EF%BC%9A00.0%20%E7%B1%BB%200200%EF%BC%9A10ec%EF%BC%9A8168%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E5%8A%A0%E8%BD%BDRTL8111E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B9%B6%E9%85%8D%E7%BD%AE%E6%8E%A5%E5%8F%A3eth1%EF%BC%9A%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20insmod%20r8168.ko%3C%2FP%3E%3CP%3Er8168%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%208.039.00-NAPI%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Er8168%200000%3A01%3A00.0%EF%BC%9A%E6%B2%A1%E6%9C%89%20MSI%E3%80%82%E8%BF%94%E5%9B%9E%20INTx%E3%80%82%3C%2FP%3E%3CP%3Er8168%EF%BC%9A%E6%9C%AC%E4%BA%A7%E5%93%81%E5%8F%97%E4%BB%A5%E4%B8%8B%E4%B8%80%E9%A1%B9%E6%88%96%E5%A4%9A%E9%A1%B9%E4%B8%93%E5%88%A9%E4%BF%9D%E6%8A%A4%EF%BC%9AUS6%2C570%2C884%E3%80%81US6%2C115%2C776%20%E5%92%8C%20US6%2C327%2C625%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Er8168%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(C)%202014%20Realtek%20NIC%20%E8%BD%AF%E4%BB%B6%E5%9B%A2%E9%98%9F%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E7%A8%8B%E5%BA%8F%E7%BB%9D%E5%AF%B9%E4%B8%8D%E9%99%84%E5%B8%A6%E4%BB%BB%E4%BD%95%E6%8B%85%E4%BF%9D%EF%BC%9B%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%E5%85%8D%E8%B4%B9%E8%BD%AF%E4%BB%B6%EF%BC%8C%E6%AC%A2%E8%BF%8E%E6%82%A8%E5%9C%A8%E7%89%B9%E5%AE%9A%E6%9D%A1%E4%BB%B6%E4%B8%8B%E9%87%8D%E6%96%B0%E5%88%86%E5%8F%91%E5%AE%83%EF%BC%9B%E8%AF%B7%E5%8F%82%E9%98%85%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CVERS%3E%3C%2FVERS%3Eeth1%3A%200xc0b86000%2C%2000%3Ae0%3A4c%3A68%3Aa2%3A04%2C%20IRQ%20155%3CBR%20%2F%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20r8168%3A%20eth1%3A%20link%20up%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2F%E5%86%85%E6%A0%B8%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E7%BD%91%E7%BB%9C%2Fr8168-8.039.00%24ifconfig%3CBR%20%2F%3E%20eth1%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3E%20inet%E5%9C%B0%E5%9D%80%EF%BC%9A192.168.0.2%E5%B9%BF%E6%92%AD%EF%BC%9A192.168.0.255%E6%8E%A9%E7%A0%81%EF%BC%9A255.255.255.0%3CBR%20%2F%3E%E4%B8%8A%E8%A1%8C%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E5%BA%A6%E9%87%8F%3A1%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3CBR%20%2F%3E%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%3CBR%20%2F%3E%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3CBR%20%2F%3E%E4%B8%AD%E6%96%AD%EF%BC%9A155%20%E5%9F%BA%E5%9D%80%EF%BC%9A0x6000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%E2%80%9CPING%20192.168.0.1%E2%80%9D%E6%97%B6%E5%86%85%E6%A0%B8%E6%A0%B8%E5%BF%83%E8%BD%AC%E5%82%A8%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20ping%20192.168.0.1%3C%2FP%3E%3CP%3EPING%20192.168.0.1%20(192.168.0.1)%3A%205%E5%86%85%E6%A0%B8%E9%94%99%E8%AF%AF%E4%BD%8D%E4%BA%8E%20arch%2Farm%2Fmm%2Fdma-mapping.c%3A478%EF%BC%81%3C%2FP%3E%3CP%3E6%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80%2000000000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E7%A9%BA%E6%8C%87%E9%92%88%E5%8F%96%E6%B6%88%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3CP%3E%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E5%93%8E%E5%91%80%EF%BC%9A817%20%5B%231%5D%20PREEMPT%20SMP%3C%2FP%3E%3CP%3E%E9%93%BE%E6%8E%A5%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9Ar8168%20%5B%E6%9C%80%E5%90%8E%E5%8D%B8%E8%BD%BD%EF%BC%9Ar8168%5D%3C%2FP%3E%3CP%3ECPU%EF%BC%9A2%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%EF%BC%883.0.35-2666-gbdde708%20%2320%EF%BC%89%3C%2FP%3E%3CP%3EPC%20%E4%BD%8D%E4%BA%8E%20__bug%2B0x1c%2F0x28%3C%2FP%3E%3CP%3ELR%20%E4%BD%8D%E4%BA%8E%20__bug%2B0x18%2F0x28%3C%2FP%3E%3CP%3Epc%20%3A%20%5B%26lt%3B800462c8%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lr%20%3A%20%5B%26lt%3B800462c4%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20psr%3A%2060000193%3C%2FP%3E%3CP%3Esp%20%3A%20bffb5dc8%26nbsp%3B%20ip%20%3A%20c097a000%26nbsp%3B%20fp%20%3A%20bfb80000%3C%2FP%3E%3CP%3Er10%EF%BC%9A0000021c%20r9%EF%BC%9A7f084544%20r8%EF%BC%9Aff9f2000%3C%2FP%3E%3CP%3Er7%EF%BC%9Aff9f8000%20r6%EF%BC%9A00000001%20r5%EF%BC%9A00000012%20r4%EF%BC%9Aff9f2000%3C%2FP%3E%3CP%3Er3%EF%BC%9A00000000%20r2%EF%BC%9A80ad329c%20r1%EF%BC%9A60000193%20r0%EF%BC%9A00000033%3C%2FP%3E%3CP%3E%E6%A0%87%E5%BF%97%EF%BC%9AnZCv%20IRQ%20%E5%85%B3%E9%97%AD%20FIQ%20%E5%BC%80%E5%90%AF%20%E6%A8%A1%E5%BC%8F%20SVC_32%20ISA%20ARM%20%E6%AE%B5%E5%86%85%E6%A0%B8%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%EF%BC%9A10c53c7d%20%E8%A1%A8%EF%BC%9A4a70404a%20DAC%EF%BC%9A00000015%3C%2FP%3E%3CP%3E%E8%BF%9B%E7%A8%8B%E4%BA%A4%E6%8D%A2%E5%99%A8%EF%BC%88pid%EF%BC%9A0%EF%BC%8C%E5%A0%86%E6%A0%88%E9%99%90%E5%88%B6%3D0xbffb42f0%EF%BC%89%3C%2FP%3E%3CP%3E%E5%A0%86%E6%A0%88%EF%BC%9A%EF%BC%880xbffb5dc8%20%E5%88%B0%200xbffb6000%EF%BC%89%3C%2FP%3E%3CP%3E5dc0%EF%BC%9A80b16930%208004cb08%2000000012%2000400000%200000002a%207f0489f8%3C%2FP%3E%3CP%3E5de0%3A%2000000000%2080000000%2000000000%20bfcbfd80%20bfb804b4%20ff9f8000%20ff9f8000%2080000113%3C%2FP%3E%3CP%3E5e00%3A%20c0b86000%20ba14f090%2000000000%2060004980%20bfcbfd80%20bfb80000%2000000000%2080abc11c%3C%2FP%3E%3CP%3E5e20%3A%207f084544%20bfdb8a20%2080439354%208042f11c%2000000006%20bfb8018c%20bfcd0608%20bfe7ed02%3C%2FP%3E%3CP%3E5e40%3A%20bfb80000%20bfe7ef00%20bfb80000%20bfe7ef5c%20bfcbfd80%20bfdb8a20%2000000000%2000000002%3C%2FP%3E%3CP%3E5e60%3A%2080439354%208044a694%20bfdb8a20%20bfe7ef00%20bfcbfd80%20bfb80000%20bfdb8a20%20bfe7ef5c%3C%2FP%3E%3CP%3E5e80%3A%2000000000%208042f5a0%20bfe7ef5c%20bfe7ee00%2000000000%2000000000%2000000000%20bfcbfb40%3C%2FP%3E%3CP%3E5ea0%3A%20bfb80000%200100a8c0%200200a8c0%2000000000%20bfe7ee00%208047d8fc%200200a8c0%2000000000%3C%2FP%3E%3CP%3E5ec0%3A%20bfcd0608%2000000000%2000000010%20bfcbfb40%20bfcbfb5c%20bfcbfb54%20bfcbfcc0%2000000000%3C%2FP%3E%3CP%3E5ee0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3C%2FP%3E%3CP%3E5f00%3A%200000024e%207abe5a80%20bffb5f08%20bffb5f08%2000000000%2000000141%2080aa8044%20bffb4000%3C%2FP%3E%3CP%3E5f20%3A%2000000103%2080b102e0%2000000002%2080aa8040%2000000001%208007d078%207a264549%200000024e%3C%2FP%3E%3CP%3E5f40%3A%207a264549%200000000a%207a264549%20bffb4000%20bffb4000%208003bc00%2000000000%2000000002%3C%2FP%3E%3CP%3E5f60%3A%20bffb4000%2000000000%2000000000%208007d5b4%2080abbcc0%208003d2e0%20ffffffff%20f2a00100%3C%2FP%3E%3CP%3E5f80%3A%2000000002%2000000002%2000000001%2080042a0c%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3C%2FP%3E%3CP%3E5fe0%3A%204ffb806a%2000000015%2010c03c7d%2080b0a8f8%201000406a%2010511694%2081022cce%2022705254%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5f90%20%E8%87%B3%200xbffb5fd8%EF%BC%89%3C%2FP%3E%3CP%3E5f80%3A%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3E%E4%BB%A3%E7%A0%81%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%83%BD%E5%9C%A8%E4%B8%AD%E6%96%AD%E4%B8%8A%E4%B8%8B%E6%96%87%E4%B8%AD%E8%B0%83%E7%94%A8%20clk_enable%3C%2FP%3E%3CP%3E%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8006563c%26gt%3B%5D%EF%BC%88clk_enable%2B0x88%2F0xa0%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B8039b608%26gt%3B%5D%EF%BC%88_ipu_get%2B0xc%2F0x24%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26lt%3B8039b608%26gt%3B%5D%EF%BC%88_ipu_get%2B0xc%2F0x24%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B8039c4bc%26gt%3B%5D%EF%BC%88ipu_clear_irq%2B0x18%2F0x8c%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26lt%3B8039c4bc%26gt%3B%5D%EF%BC%88ipu_clear_irq%2B0x18%2F0x8c%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B802714bc%26gt%3B%5D%EF%BC%88mxcfb_set_par%2B0xb8%2F0x6d0%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26lt%3B802714bc%26gt%3B%5D%EF%BC%88mxcfb_set_par%2B0xb8%2F0x6d0%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B80271b78%26gt%3B%5D%EF%BC%88mxcfb_blank%2B0xa4%2F0xb8%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26lt%3B80271b78%26gt%3B%5D%EF%BC%88mxcfb_blank%2B0xa4%2F0xb8%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B80259d24%26gt%3B%5D%EF%BC%88fb_blank%2B0x3c%2F0x68%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%3C%2FP%3E%3CP%3E%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%3C%2FP%3E%3CP%3E%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%3C%2FP%3E%3CP%3E%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%3C%2FP%3E%3CP%3E%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3C%2FP%3E%3CP%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5d80%20%E8%87%B3%200xbffb5dc8%EF%BC%89%3C%2FP%3E%3CP%3E5d80%3A%2000000033%2060000193%2080ad329c%2000000000%20ff9f2000%2000000012%2000000001%20ff9f8000%3C%2FP%3E%3CP%3E5da0%3A%20ff9f2000%207f084544%200000021c%20bfb80000%20c097a000%20bffb5dc8%20800462c4%20800462c8%3C%2FP%3E%3CP%3E5dc0%3A%2060000193%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5f90%20%E8%87%B3%200xbffb5fd8%EF%BC%89%3C%2FP%3E%3CP%3E5f80%3A%2080b11c40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E9%94%99%E8%AF%AF%E4%BD%8D%E4%BA%8E%20arch%2Farm%2Fplat-mxc%2Fclock.c%3A101%EF%BC%81%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80%2000000000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E7%A9%BA%E6%8C%87%E9%92%88%E5%8F%96%E6%B6%88%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%AE%A2%E6%88%B7%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9FRTL8111e%20%E6%8A%A5%E5%91%8A%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%E6%97%B6%E7%9A%84%E6%B4%BB%E5%8A%A8%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%80%E4%BD%8D%E5%AE%A2%E6%88%B7%E4%BD%BF%E7%94%A8%20RTL8111e%20%E5%B9%B6%E6%8A%A5%E5%91%8A%E4%BA%86%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%E9%97%AE%E9%A2%98%EF%BC%8C%20%3C%2FP%3E%3CP%3Eeth1%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3E%20inet%E5%9C%B0%E5%9D%80%EF%BC%9A192.168.0.2%E5%B9%BF%E6%92%AD%EF%BC%9A192.168.0.255%E6%8E%A9%E7%A0%81%EF%BC%9A255.255.255.0%3CBR%20%2F%3E%E4%B8%8A%E8%A1%8C%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E5%BA%A6%E9%87%8F%3A1%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A12%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3CBR%20%2F%3E%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%3CBR%20%2F%3E%20RX%E5%AD%97%E8%8A%82%EF%BC%9A1002%EF%BC%881002.0B%EF%BC%89TX%E5%AD%97%E8%8A%82%EF%BC%9A0%EF%BC%880.0%20B%EF%BC%89%3CBR%20%2F%3E%E4%B8%AD%E6%96%AD%EF%BC%9A155%20%E5%9F%BA%E5%9D%80%EF%BC%9A0xe000%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2F%E5%86%85%E6%A0%B8%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E7%BD%91%E7%BB%9C%2Fr8168-8.039.00%24ping%20192.168.0.1%3CBR%20%2F%3EPING%20192.168.0.1%20(192.168.0.1)%3A%2056%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E9%94%99%E8%AF%AF%E4%BD%8D%E4%BA%8E%20arch%2Farm%2Fmm%2Fdma-mapping.c%3A478%EF%BC%81%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80%2000000000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E7%A9%BA%E6%8C%87%E9%92%88%E5%8F%96%E6%B6%88%E5%BC%95%E7%94%A8%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%20%5B00000000%5D%20*pgd%3D00000000%3CBR%20%2F%3E%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E5%93%8E%E5%91%80%EF%BC%9A817%20%5B%231%5D%20PREEMPT%20SMP%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%9D%97%EF%BC%9Ar8168%3CBR%20%2F%3E%20CPU%EF%BC%9A2%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%EF%BC%883.0.35-2666-gbdde708%20%2320%EF%BC%89%3CBR%20%2F%3E%20PC%20%E4%BD%8D%E4%BA%8E__bug%2B0x1c%2F0x28%3CBR%20%2F%3ELR%20is%20at%20__%20bug%2B0x18%2F0x28%3CBR%20%2F%3E%20pc%EF%BC%9A%5B%26lt%3B800462c8%26gt%3B%5D%20lr%EF%BC%9A%5B%26lt%3B800462c4%26gt%3B%5D%20psr%EF%BC%9A60000193%3CBR%20%2F%3E%20sp%EF%BC%9Abffb5dc8%20ip%EF%BC%9Ac097a000%20fp%EF%BC%9Aba074000%3CBR%20%2F%3E%20r10%EF%BC%9A0000021c%20r9%EF%BC%9A7f03d544%20r8%EF%BC%9Aff9f2000%3CBR%20%2F%3E%20r7%EF%BC%9Aff9f8000%20r6%EF%BC%9A00000001%20r5%EF%BC%9A00000012%20r4%EF%BC%9Aff9f2000%3CBR%20%2F%3E%20r3%EF%BC%9A00000000%20r2%EF%BC%9A80ad329c%20r1%EF%BC%9A60000193%20r0%EF%BC%9A00000033%3CBR%20%2F%3E%E6%A0%87%E5%BF%97%EF%BC%9AnZCv%20IRQ%20%E5%85%B3%E9%97%AD%20FIQ%20%E5%BC%80%E5%90%AF%20%E6%A8%A1%E5%BC%8F%20SVC_32%20ISA%20ARM%20%E6%AE%B5%E5%86%85%E6%A0%B8%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%EF%BC%9A10c53c7d%20%E8%A1%A8%EF%BC%9A4a2b404a%20DAC%EF%BC%9A00000015%3CBR%20%2F%3E%E8%BF%9B%E7%A8%8B%E4%BA%A4%E6%8D%A2%E5%99%A8%EF%BC%88pid%EF%BC%9A0%EF%BC%8C%E5%A0%86%E6%A0%88%E9%99%90%E5%88%B6%3D0xbffb42f0%EF%BC%89%3CBR%20%2F%3E%E5%A0%86%E6%A0%88%EF%BC%9A%EF%BC%880xbffb5dc8%20%E5%88%B0%200xbffb6000%EF%BC%89%3CBR%20%2F%3E%205dc0%EF%BC%9A80b16930%208004cb08%2000000012%2000400000%200000002a%207f0019f8%3CBR%20%2F%3E%205de0%3A%2000000000%2080000000%2000000000%20bfd92480%20ba0744b4%20ff9f8000%20ff9f8000%2080000113%3CBR%20%2F%3E%205e00%EF%BC%9Ac0b7e000%20bfc938a0%2000000000%2060004980%20bfd92480%20ba074000%2000000000%2080abc11c%3CBR%20%2F%3E%205e20%EF%BC%9A7f03d544%20bfd82480%2080439354%208042f11c%2000000006%20ba07418c%20bfc1ec08%20bfd3dd02%3CBR%20%2F%3E%205e40%EF%BC%9Aba074000%20bfd3df00%20ba074000%20bfd3df5c%20bfd92480%20bfd82480%2000000000%2000000002%3CBR%20%2F%3E%205e60%EF%BC%9A80439354%208044a694%20bfd82480%20bfd3df00%20bfd92480%20ba074000%20bfd82480%20bfd3df5c%3CBR%20%2F%3E%205e80%3A%2000000000%208042f5a0%20bfd3df5c%20bfd3de00%2000000000%2000000000%2000000000%20bfd92240%3CBR%20%2F%3E%205ea0%EF%BC%9Aba074000%200100a8c0%200200a8c0%2000000000%20bfd3de00%208047d8fc%200200a8c0%2000000000%3CBR%20%2F%3E%205ec0%EF%BC%9Abfc1ec08%2000000000%2000000010%20bfd92240%20bfd9225c%20bfd92254%20bfd923c0%2000000000%3CBR%20%2F%3E%205ee0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3CBR%20%2F%3E%205f00%EF%BC%9A000000fa%208436ae00%20bffb5f08%20bffb5f08%2000000000%2000000141%2080aa8044%20bffb4000%3CBR%20%2F%3E%205f20%3A%2000000103%2080b102e0%2000000002%2080aa8040%2000000001%208007d078%20839e72da%20000000fa%3CBR%20%2F%3E%205f40%3A%20839e72da%200000000a%20839e72da%20bffb4000%20bffb4000%208003bc00%2000000000%2000000002%3CBR%20%2F%3E%205f60%3A%20bffb4000%2000000000%2000000000%208007d5b4%2080abbcc0%208003d2e0%20ffffffff%20f2a00100%3CBR%20%2F%3E%205f80%3A%2000000002%2000000002%2000000001%2080042a0c%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E%205fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E%205fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3CBR%20%2F%3E%205fe0%3A%204ffb806a%2000000015%2010c03c7d%2080b0a8f8%201000406a%2010511694%208102080c%2022705244%3CBR%20%2F%3E%20%5B%26lt%3B800462c8%26gt%3B%5D%EF%BC%88%20__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(__%20_dma_single_cpu_to_dev%2B0x94%2F0xa4%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3CBR%20%2F%3E%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5f90%20%E8%87%B3%200xbffb5fd8%EF%BC%89%3CBR%20%2F%3E%205f80%3A%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E%205fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E%205fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3E%E4%BB%A3%E7%A0%81%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3CBR%20%2F%3E%E4%B8%8D%E8%83%BD%E5%9C%A8%E4%B8%AD%E6%96%AD%E4%B8%8A%E4%B8%8B%E6%96%87%E4%B8%AD%E8%B0%83%E7%94%A8%20clk_enable%3CBR%20%2F%3E%20%5B%26lt%3B80049e34%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xf8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3CBR%20%2F%3E%20%5B%26lt%3B8006563c%26gt%3B%5D%EF%BC%88clk_enable%2B0x88%2F0xa0%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B8039b608%26gt%3B%5D%EF%BC%88_ipu_get%2B0xc%2F0x24%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B8039b608%26gt%3B%5D%EF%BC%88_ipu_get%2B0xc%2F0x24%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B8039c4bc%26gt%3B%5D%EF%BC%88ipu_clear_irq%2B0x18%2F0x8c%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B8039c4bc%26gt%3B%5D%EF%BC%88ipu_clear_irq%2B0x18%2F0x8c%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B802714bc%26gt%3B%5D%EF%BC%88mxcfb_set_par%2B0xb8%2F0x6d0%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B802714bc%26gt%3B%5D%EF%BC%88mxcfb_set_par%2B0xb8%2F0x6d0%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B80271b78%26gt%3B%5D%EF%BC%88mxcfb_blank%2B0xa4%2F0xb8%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B80271b78%26gt%3B%5D%EF%BC%88mxcfb_blank%2B0xa4%2F0xb8%EF%BC%89%E6%9D%A5%E8%87%AA%5B%26lt%3B80259d24%26gt%3B%5D%EF%BC%88fb_blank%2B0x3c%2F0x68%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%3CBR%20%2F%3E%20%5B%26lt%3B80263b18%26gt%3B%5D%20(fbcon_blank%2B0x1c4%2F0x258)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80297fa0%26gt%3B%5D%EF%BC%88do_unblank_screen%2B0x94%2F0x194%EF%BC%89%3CBR%20%2F%3E%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3CBR%20%2F%3E%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%3CBR%20%2F%3E%20%5B%26lt%3B800465c0%26gt%3B%5D%20(die%2B0xa8%2F0x284)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%3CBR%20%2F%3E%5B%26lt%3B8051464c%26gt%3B%5D%20(__do_kernel_fault.part.4%2B0x54%2F0x74)%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%3CBR%20%2F%3E%20%5B%26lt%3B8004da68%26gt%3B%5D%20(do_page_fault%2B0x2b4%2F0x31c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%3CBR%20%2F%3E%20%5B%26lt%3B8003d384%26gt%3B%5D%20(do_DataAbort%2B0x34%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5d80%20%E8%87%B3%200xbffb5dc8%EF%BC%89%3CBR%20%2F%3E%205d80%3A%2000000033%2060000193%2080ad329c%2000000000%20ff9f2000%2000000012%2000000001%20ff9f8000%3CBR%20%2F%3E%205da0%EF%BC%9Aff9f2000%207f03d544%200000021c%20ba074000%20c097a000%20bffb5dc8%20800462c4%20800462c8%3CBR%20%2F%3E%205dc0%3A%2060000193%20ffffffff%3CBR%20%2F%3E%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B800462c8%26gt%3B%5D%20(%20__bug%2B0x1c%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__%20bug%2B0x1c%2F0x28)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3CBR%20%2F%3E%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%3CBR%20%2F%3E%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5Br8168%5D)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88%EF%BC%880xbffb5f90%20%E8%87%B3%200xbffb5fd8%EF%BC%89%3CBR%20%2F%3E%205f80%3A%2080b11c40%2080000093%2000000001%2000000000%3CBR%20%2F%3E%205fa0%EF%BC%9Abffb4000%2080b0a744%2080abba70%208051d870%2080abef0c%20412fc09a%2000000000%2000000000%3CBR%20%2F%3E%205fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E9%94%99%E8%AF%AF%E4%BD%8D%E4%BA%8E%20arch%2Farm%2Fplat-mxc%2Fclock.c%3A101%EF%BC%81%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80%2000000000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E7%A9%BA%E6%8C%87%E9%92%88%E5%8F%96%E6%B6%88%E5%BC%95%E7%94%A8%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%20%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BF%85%E9%A1%BB%E8%BF%9B%E8%A1%8C%E7%A1%AC%E4%BB%B6%E4%BF%AE%E6%94%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%20REF%20CLK%20%E6%9D%A5%E8%87%AA%E5%8E%9F%E5%A7%8B%20imx6%3CSPAN%20class%3D%22SpellE%22%3E%20pcie%3C%2FSPAN%3E%20hw%20%E8%AE%BE%E8%AE%A1%E4%B8%AD%E7%9A%84%3CSPAN%20class%3D%22SpellE%22%3E%20pll%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%AD%A4%E8%87%B4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%3C%2FA%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3E%E6%9C%B1%20keytwo%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E4%B8%A4%E5%9D%97%20Sabre_Lite%20%E6%9D%BF%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E4%BA%86%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%AD%A3%E5%B0%9D%E8%AF%95%E4%B8%8E%E5%85%B6%E4%BB%96%E6%A0%B9%E8%81%94%E5%90%88%E4%BD%93%EF%BC%88%E5%A6%82%20PC%EF%BC%89%E4%B8%80%E8%B5%B7%E8%BF%90%E8%A1%8C%20PCIe%20%E7%AB%AF%E7%82%B9%EF%BC%88Sabre_Lite%EF%BC%89%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%E6%88%91%E7%9A%84%20EP%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20Sabre_Lite%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%85%B6%E4%BB%96%20RC%20%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E9%93%BE%E6%8E%A5%E6%B2%A1%E6%9C%89%E5%BB%BA%E7%AB%8B%E3%80%82%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E5%8F%82%E8%80%83%20125Mhz%20%E6%97%B6%E9%92%9F%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20Sabre_Lite%20PCIe%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%B2%A1%E6%9C%89%E8%BE%93%E5%85%A5%20CLK%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%BF%85%E9%A1%BB%E5%B0%86%20RC%20%E5%8F%82%E8%80%83%E6%97%B6%E9%92%9F%E4%BC%A0%E9%80%92%E7%BB%99%20EP%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E7%A1%AC%E4%BB%B6%E4%BF%AE%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%98%B2%E6%AD%A2%E7%A1%AC%E4%BB%B6%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%B5%B7%E5%BE%B7%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%9A%3CBR%20%2F%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8Cimx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%E7%9A%84%20MAX_PAY_LOAD_SIZE%20%E6%98%AF%20128%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%B8%80%E4%B8%AA%3CSPAN%20class%3D%22SpellE%22%3Etlp%3C%2FSPAN%3E%E4%B8%8A%E7%9A%84%E5%AE%9E%E9%99%85%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E7%94%B1%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%E4%B8%BB%E8%AE%BE%E5%A4%87%E7%9A%84%E7%BC%93%E5%AD%98%E7%AA%81%E5%8F%91%E8%83%BD%E5%8A%9B%E5%86%B3%E5%AE%9A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%E5%BD%93%E4%BD%BF%E7%94%A8%20arm%20%E6%A0%B8%E5%BF%83%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E6%97%B6%EF%BC%8Cimx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%20%2F%20%3CSPAN%20class%3D%22SpellE%22%3Erc%3C%2FSPAN%3E%E9%AA%8C%E8%AF%81%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E4%B8%BA%2032%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BD%93IPU%EF%BC%88DMA%EF%BC%89%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%9C%BA%E6%97%B6%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E4%B8%BA64%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%AD%A4%E8%87%B4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%9D%A5%E9%AA%8C%E8%AF%81%E4%BB%8E%20imx6%20%E7%AB%AF%E7%82%B9%E5%88%B0%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%E7%9A%84%20PCIe%20%E5%90%9E%E5%90%90%E9%87%8F%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%BD%93%E4%BD%BF%E7%94%A8%20arm%20%E6%A0%B8%E5%BF%83%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E6%97%B6%E5%A6%82%E4%BD%95%E6%94%B9%E5%8F%98%20TLP%20%E5%A4%A7%E5%B0%8F%E3%80%82%E6%9B%B4%E9%87%8D%E8%A6%81%E7%9A%84%E6%98%AF%EF%BC%8C%E5%BD%93%20arm%20%E6%A0%B8%E5%BF%83%E4%B8%80%E6%AC%A1%E5%8F%AA%E8%83%BD%E8%AF%BB%E5%8F%96%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E6%97%B6%EF%BC%8Ctlp%20paload%20%E5%A4%A7%E5%B0%8F%E5%A6%82%E4%BD%95%E5%BD%B1%E5%93%8D%E8%AF%BB%E5%8F%96%E5%90%9E%E5%90%90%E9%87%8F%E3%80%82%E5%BD%93%E4%BD%BF%E7%94%A8%20arm%20%E6%A0%B8%E5%BF%83%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E6%97%B6%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%BB%AC%E8%A6%81%E5%B0%86%20TLP%20%E5%A4%A7%E5%B0%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA%2032%20%E5%AD%97%E8%8A%82%EF%BC%9F%E5%AE%83%E5%AF%B9%E8%AF%BB%E5%8F%96%E6%80%A7%E8%83%BD%E6%9C%89%E5%BD%B1%E5%93%8D%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E6%97%A0%E8%AE%BA%20TLP%20%E5%A4%A7%E5%B0%8F%E6%88%91%E4%BB%AC%E9%83%BD%E4%BC%9A%E5%BE%97%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E6%95%B0%E5%AD%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%B0%9D%E8%AF%95%E5%9C%A8%20i.MX6DL%20%E8%AE%BE%E7%BD%AE%E4%B8%8A%E9%87%8D%E5%A4%8D%E6%AD%A4%E9%AA%8C%E8%AF%81%EF%BC%8C%E4%BD%86%E8%BF%84%E4%BB%8A%E4%B8%BA%E6%AD%A2%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E6%82%A8%E8%83%BD%E7%9C%8B%E5%87%BA%E8%BF%99%E7%A7%8D%E8%AE%BE%E7%BD%AE%E5%A4%B1%E8%B4%A5%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%A5%BD%E5%83%8F%E5%9C%A8%E9%93%BE%E8%B7%AF%E8%AE%AD%E7%BB%83%E5%BC%80%E5%A7%8B%E5%90%8E%E7%A1%AC%E4%BB%B6%E8%AE%BF%E9%97%AE%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E5%BE%88%E5%A4%9A%E4%BB%A3%E7%A0%81%E8%A2%AB%E6%A0%87%E8%AE%B0%E4%B8%BA%20iMX6Q%EF%BC%8C%E4%BD%86%E7%94%A8%E4%BA%8E%20iMX6DL%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E8%BF%87%E5%AE%83%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E6%98%8E%E6%98%BE%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A4%A7%E5%A4%9A%E6%95%B0%E5%B7%AE%E5%BC%82%E6%98%AF%E9%80%9A%E8%BF%87%20iMX6Q%20%E6%88%96%20iMX6DL%20%E6%9D%A5%E5%A4%84%E7%90%86%E7%9A%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E7%A4%BE%E5%8C%BA%E4%B8%AD%E5%B0%B1%E6%AD%A4%E4%BA%8B%E5%8F%91%E5%B8%96%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F330406%22%20target%3D%22_blank%22%3E%E6%9C%89%E4%BA%BA%E5%9C%A8%20i.MX6DL%20%E8%AE%BE%E7%BD%AE%E4%B8%8A%E6%88%90%E5%8A%9F%E5%A4%8D%E5%88%B6%E4%BA%86%20i.MX6Q%20PCIe%20EP%2FRC%20%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%E5%90%97%EF%BC%9F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A2%E8%BF%8E%E4%BB%BB%E4%BD%95%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A5%9D%E5%A5%BD%3C%2FP%3E%3CP%3EAndreas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E5%B0%9D%E8%AF%95%E5%B0%86%E9%AB%98%E5%B8%A6%E5%AE%BD%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E4%BB%8E%20Xilinx%20Artix7%20FPGA%20%E5%AD%98%E6%A1%A3%E5%88%B0%20iMX6%20%E7%9A%84%20DDR%E3%80%82%E6%88%91%E4%BB%AC%E7%BB%88%E4%BA%8E%E8%AE%A9%E4%B8%80%E4%BA%9B%E4%B8%9C%E8%A5%BF%E8%BF%90%E8%A1%8C%E8%B5%B7%E6%9D%A5%E4%BA%86%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E5%B8%A6%E5%AE%BD%E5%B9%B6%E4%B8%8D%E5%83%8F%E6%88%91%E4%BB%AC%E9%A2%84%E6%9C%9F%E7%9A%84%E9%82%A3%E6%A0%B7%E5%A5%BD%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E6%97%B6%E9%92%9F%E8%AE%A1%E6%95%B0%E5%99%A8%E5%9C%A8%20FPGA%20%E5%86%85%E7%94%9F%E6%88%90%E6%95%B0%E6%8D%AE%E6%B5%81%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20FPGA%20%E4%BD%9C%E4%B8%BA%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E5%99%A8%E5%B0%86%E5%85%B6%E5%8F%91%E9%80%81%E5%88%B0%20iMX6%20RC%E3%80%82%E9%80%9A%E8%BF%87%E4%BB%8E%E7%AC%AC%E4%B8%80%E4%B8%AA%E4%BC%A0%E8%BE%93%E7%9A%84%E6%95%B0%E6%8D%AE%E5%AD%97%E4%B8%AD%E5%87%8F%E5%8E%BB%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E4%BC%A0%E8%BE%93%E7%9A%84%E6%95%B0%E6%8D%AE%E5%AD%97%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AE%A1%E7%AE%97%E5%87%BA%E4%BA%86%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E9%80%9F%E5%BA%A6%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%AE%A1%E7%AE%97%E4%B8%8D%E5%BA%94%E8%AF%A5%E4%BE%9D%E8%B5%96%E4%BA%8E%E4%BB%BB%E4%BD%95%20CPU%20%E5%BB%B6%E8%BF%9F%E3%80%82%E7%94%B1%E4%BA%8E%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%E6%97%B6%E9%92%9F%E5%80%BC%E5%8F%91%E9%80%81%E5%88%B0%E7%BC%93%E5%86%B2%E5%AE%83%E4%BB%AC%E7%9A%84%20FPGA%20%E7%9A%84%20PCIe%20%E6%A0%B8%E5%BF%83%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AF%E8%83%BD%E4%BC%9A%E4%B8%A2%E5%A4%B1%E4%B8%80%E4%BA%9B%E7%B2%BE%E5%BA%A6%E3%80%82%E6%AD%A3%E5%A6%82%E6%88%91%E4%BB%AC%E5%9C%A8%20chipscope%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%EF%BC%8CiMX6%20%E5%9C%A8%20128%20%E5%AD%97%E8%8A%82%E4%B9%8B%E5%90%8E%E7%9A%84%20PCIe%20%E6%80%BB%E7%BA%BF%E4%B8%8A%E6%80%BB%E6%98%AF%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E5%81%9C%E9%A1%BF%EF%BC%88%E5%8F%AF%E8%83%BD%E6%98%AF%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E5%A4%A7%E5%B0%8F%E9%99%90%E5%88%B6%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E5%8F%AA%E8%83%BD%E5%9C%A8%E5%A4%A7%E7%BA%A6%202048%20%E5%AD%97%E8%8A%82%E4%B9%8B%E5%90%8E%E5%9C%A8%20iMX6'%20DDR%20%E4%B8%8A%E7%9C%8B%E5%88%B0%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E5%AD%97%E4%B8%AD%E7%9A%84%E9%97%B4%E9%9A%99%EF%BC%8C%E5%9B%A0%E6%AD%A4%20Xilinx%20PCIe%20%E6%A0%B8%E5%BF%83%E4%B8%AD%E4%BC%BC%E4%B9%8E%E6%9C%89%E4%B8%80%E4%B8%AA%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%E8%BF%99%E4%BD%BF%E5%BE%97%E6%97%B6%E5%BA%8F%E5%80%BC%E4%B8%8E%E7%9C%9F%E6%AD%A3%E7%9A%84%20PCIe%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%8D%E5%90%8C%E6%AD%A5%E3%80%82%E4%BD%86%E5%AE%83%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%AF%B9%E5%B8%A6%E5%AE%BD%E9%80%9F%E5%BA%A6%E7%9A%84%E6%95%B4%E4%BD%93%E8%AE%A1%E7%AE%97%E4%BA%A7%E7%94%9F%E5%BE%88%E5%A4%A7%E7%9A%84%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E5%BD%93%E5%B0%86%20512KByte%20%E7%BC%93%E5%86%B2%E5%8C%BA%E4%BB%8E%20FPGA%20%E4%BC%A0%E8%BE%93%E5%88%B0%20i.MX6%20%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E8%8E%B7%E5%BE%97%E4%BA%86%20270MB%2Fs%EF%BC%8C%E8%80%8C%E5%9C%A8%E5%85%B7%E6%9C%89%E4%B8%80%E4%B8%AA%20PCIe%202.0%20%E9%80%9A%E9%81%93%E7%9A%84%20x86%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E8%8E%B7%E5%BE%97%E4%BA%86%20~400MB%2Fs%E3%80%82%20%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E4%BC%A0%E8%BE%93%E9%80%9F%E7%8E%87%E5%A6%82%E6%AD%A4%E4%BD%8E%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%9C%89%E9%82%A3%E4%BA%9B%EF%BC%88%E9%99%A4%E4%BA%86%20i.MX6%20%E4%B8%8A%E7%9A%84%E6%9C%80%E5%A4%A7%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E5%A4%A7%E5%B0%8F%E4%B8%BA%20128%20%E5%AD%97%E8%8A%82%E4%B9%8B%E5%A4%96%EF%BC%89%EF%BC%9F%E7%94%B1%E4%BA%8E%20FPGA%20%E4%B8%8A%E7%9A%84%E6%9C%80%E5%A4%A7%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E5%A4%A7%E5%B0%8F%E7%9B%AE%E5%89%8D%E9%99%90%E5%88%B6%E4%B8%BA%20256%20%E5%AD%97%E8%8A%82%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8E%20x86%20%E7%B3%BB%E7%BB%9F%E7%9B%B8%E6%AF%94%EF%BC%8C%E5%AE%83%E4%B8%8D%E5%BA%94%E8%AF%A5%E4%BA%A7%E7%94%9F%E5%A4%AA%E5%A4%A7%E7%9A%84%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E6%88%91%E8%BF%98%E6%83%B3%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E6%82%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9C%80%E9%AB%98%E5%8F%AA%E8%83%BD%E8%BE%BE%E5%88%B0%20344MB%2Fs%E3%80%82PCIe%20%E6%8E%A5%E5%8F%A3%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%85%81%E8%AE%B8%E6%9B%B4%E9%AB%98%E7%9A%84%E5%B8%A6%E5%AE%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E6%9C%89%E6%B2%A1%E6%9C%89%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E5%B0%86%20PCIe%20%E4%B8%AD%E6%96%AD%E4%BB%8E%20EP%20%E5%8F%91%E9%80%81%E5%88%B0%20RC%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9F%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20iATU%20%E6%B5%8B%E8%AF%95%E4%BA%86%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BD%86%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%E8%BF%98%E6%B2%A1%E6%9C%89%E7%BB%93%E6%9E%9C%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%EF%BC%8C%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%8F%E9%97%AE%E9%A2%98%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20BAR0%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%BA%9B%204K%20IO%EF%BC%8C%E5%AE%83%E4%BB%AC%E4%BC%9A%E5%9C%A8%20RC%20%E4%B8%8A%E6%98%BE%E7%A4%BA%E4%B8%BA%200x1E00000%E3%80%82%E6%B2%A1%E5%85%B3%E7%B3%BB%E3%80%82%E4%BD%86%E6%98%AF%E5%A6%82%E4%BD%95%E4%BB%8E%E7%AB%AF%E7%82%B9%E6%9C%AC%E8%BA%AB%E8%AF%BB%E5%8F%96%2F%E5%86%99%E5%85%A5%20IO%20%E7%A9%BA%E9%97%B4%EF%BC%9F%E5%88%86%E9%85%8D%E5%88%B0%E5%93%AA%E4%BA%86%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3A%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%93%8D%E5%BA%94%E7%9A%84%20sw%20%E4%BF%AE%E6%94%B9%E4%B9%8B%E5%90%8E%EF%BC%8Cimx%20pcie%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20100m%20ref%20clk%E3%80%82%3C%2FP%3E%3CP%3E%E4%BF%AE%E6%94%B9%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%9C%AC%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%A4%96%E9%83%A8OSC%E4%BD%BF%E7%94%A8%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E8%87%AA%E5%8D%8E%E4%B8%BA%E6%89%8B%E6%9C%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ealeksandr%20Muraviov%20%3CADMIN%3E%E7%BC%96%E5%86%99%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ealeksandr%20Muraviov%20%E7%9A%84%E6%96%B0%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%E6%9F%A5%E7%9C%8B%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9D%A5%E8%87%AA%20PC%20%E7%9A%84%20PCIe%20%E5%A7%8B%E7%BB%88%E5%8F%91%E9%80%81%20CLK%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E9%80%89%E9%A1%B9%EF%BC%8C%E8%80%8C%E6%98%AF%E5%BC%BA%E5%88%B6%E6%80%A7%E7%9A%84%EF%BC%81%3C%2FP%3E%3CP%3EEP%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%20CLK%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E6%88%96%E8%80%85%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%AE%83%E7%9A%84%E5%86%85%E9%83%A8%E6%97%B6%E9%92%9F%EF%BC%8C%E5%B9%B6%E4%B8%AD%E7%BB%A7%208b10b%20%E6%97%B6%E9%92%9F%E6%81%A2%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20MX6Q%20%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%AE%83%E5%BD%93%E5%89%8D%E5%9C%A8%E5%86%85%E6%A0%B8%E4%B8%AD%E7%9A%84%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E6%98%AF%E4%BD%BF%E7%94%A8%E5%AE%83%E7%9A%84%E5%86%85%E9%83%A8%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%B8%BA%20MX6%20%E6%8F%90%E4%BE%9B%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%EF%BC%88%E6%9D%A5%E8%87%AA%20PC%EF%BC%89%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BF%AE%E8%A1%A5%E5%86%85%E6%A0%B8%E6%89%8D%E8%83%BD%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E8%BF%90%E8%A1%8C%E2%80%9C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ewhile(true)%20%3B%20do%20sleep%201%20%3B%20.%2Fmemtool%20-32%2001ffc72c%201%20%7C%20grep%20-v%20add%20%7C%20grep%200x%3B%20done%3C%2FSPAN%3E%20%E2%80%9D%E5%B9%B6%E6%9F%A5%E7%9C%8B%E8%8E%B7%E5%BE%97%E7%9A%84%E5%80%BC%E3%80%82%E5%A6%82%E6%9E%9C%E5%AE%83%E6%98%AF%E7%B1%BB%E4%BC%BC%E2%80%9Cxxxxxx1x%E2%80%9D%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%8C%E9%82%A3%E4%B9%88%E9%93%BE%E6%8E%A5%E5%B0%B1%E8%BF%9E%E6%8E%A5%E4%B8%8A%E4%BA%86%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%AE%83%E6%98%AF%E7%B1%BB%E4%BC%BC%E2%80%9Cxxxxxx0x%E2%80%9D%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%8C%E9%82%A3%E4%B9%88%E9%93%BE%E6%8E%A5%E5%B0%B1%E6%96%AD%E5%BC%80%E4%BA%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20_jive_internal%3D%22true%22%20data-avatarid%3D%221013%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%22207066%22%20data-username%3D%22richard.zhu%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2012px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%238b8b8b%3B%20background-color%3A%20%23f6f6f6%3B%22%20target%3D%22_blank%22%3E%E6%9C%B1%E7%BA%A2%E6%98%9F%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AFPC%E4%B8%8D%E6%8F%90%E4%BE%9B%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%89%80%E9%9C%80%E7%9A%84LVDS%E5%B7%AE%E5%88%86%E6%97%B6%E9%92%9F%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E8%AE%A9%20PC%20%E6%8F%90%E4%BE%9B%E8%BF%99%E4%B8%AA%E4%BF%A1%E5%8F%B7%E5%90%97%EF%BC%9F%E6%88%91%E5%9C%A8%20PC%20%E7%9A%84%E5%86%85%E6%A0%B8%E8%8F%9C%E5%8D%95%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E7%9B%B8%E5%85%B3%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E7%A1%AE%E5%AE%9E%EF%BC%8C%E5%A6%82%E6%9E%9C%20EP%20%E5%92%8C%20RC%20%E5%90%84%E8%87%AA%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%B6%E9%92%9F%EF%BC%8C%E9%82%A3%E4%B9%9F%E6%B2%A1%E5%85%B3%E7%B3%BB%EF%BC%8C%E4%BD%86%E5%B0%B1%20PC%20%E8%80%8C%E8%A8%80%EF%BC%8C%E5%85%85%E5%BD%93%20RC%20%E7%9A%84%20PC%20%E4%B8%BA%20EP%EF%BC%88%E8%BF%99%E9%87%8C%E6%98%AF%20imx%EF%BC%89%E6%8F%90%E4%BE%9B%20CLK%EF%BC%8C%E6%88%91%E7%9B%B8%E4%BF%A1%E8%BF%99%E4%B8%AA%E6%97%B6%E9%92%9F%E7%9A%84%E6%A0%87%E5%87%86%E6%98%AF%20100Mhz%E3%80%82%EF%BC%88%E9%99%A4%E9%9D%9E%E6%88%91%E9%94%99%E4%BA%86%EF%BC%9F%EF%BC%89%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E8%BF%99%E9%87%8C%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%20IMX%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20125Mhz%EF%BC%8C%E5%AE%83%E5%8F%AA%E4%BD%BF%E7%94%A8%20TX%2FRX%EF%BC%8C%E4%BD%86%E4%B8%8D%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20100Mhz%20%E7%9A%84%20RC%20%E7%9A%84%20CLK%E3%80%82%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%20%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E5%AE%83%E5%8F%AA%E8%83%BD%E5%9C%A8%201%20%E5%8F%B0%20PC%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%E9%94%AE%E4%BA%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%83%BD%E5%A4%9F%E5%9C%A8%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%E8%A7%82%E7%9C%8B%20imx%20ep%20%E7%9C%9F%E6%98%AF%E5%A4%AA%E5%A5%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%A4%A9%E6%88%91%E5%BF%99%E4%BA%8E%E4%B8%80%E4%B8%AA%E5%86%85%E9%83%A8%E5%85%B3%E9%94%AE%E7%89%88%E6%9C%AC%E7%9A%84%E5%8F%91%E5%B8%83%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%A4%AA%E5%A4%9A%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EImx6q%20pcie%20%E4%BD%BF%E7%94%A8%20125mhz%20%E4%BD%9C%E4%B8%BA%E5%86%85%E9%83%A8%E5%8F%82%E8%80%83%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E5%BD%93%20ep%20%E5%92%8C%20rc%20%E4%BD%BF%E7%94%A8%E7%8B%AC%E7%AB%8B%E5%8F%82%E8%80%83%E6%97%B6%E9%92%9F%E6%97%B6%EF%BC%8C%E8%BF%99%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%E4%B8%80%E4%B8%AAref%20clk%E6%96%B9%E6%A1%88%EF%BC%8Cimx6q%20pcie%20ep%E7%90%86%E8%AE%BA%E4%B8%8A%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8pc%20pcie%20rc%E6%8F%90%E4%BE%9B%E7%9A%84100m%20clk%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%9C%AC%E7%A4%BE%E5%8C%BA%E5%AE%9E%E7%8E%B0100m%E5%A4%96%E7%BD%AEOSC%E6%97%B6%E7%9A%84%E4%B8%93%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%202013-11-28%EF%BC%8C%E4%B8%8B%E5%8D%886%3A38%EF%BC%8C%22key%20two%22%20%3CADMIN%3E%26gt%3B%20%E5%86%99%E9%81%93%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%B3%E9%94%AE%E4%BA%8C%E7%9A%84%E6%96%B0%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%E6%9F%A5%E7%9C%8B%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%E5%BE%AA%E7%8E%AF%E4%B8%AD%E6%A3%80%E6%9F%A5%E4%B8%8A%E8%A1%8C%E9%93%BE%E8%B7%AF%E5%AF%84%E5%AD%98%E5%99%A8%E5%90%8E%EF%BC%8C%E6%88%91%E6%84%8F%E8%AF%86%E5%88%B0%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E5%AE%9E%E9%99%85%E4%B8%8A%E6%AD%A3%E5%9C%A8%E4%B8%A2%E5%A4%B1%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%86%B3%E5%AE%9A%E5%88%B6%E4%BD%9C%E4%B8%80%E6%9D%A1%E6%96%B0%E7%94%B5%E7%BC%86%EF%BC%8C%E5%B0%86%E8%BD%A8%E9%81%93%E7%B4%A7%E6%8C%A8%E7%9D%80%E6%94%BE%E7%BD%AE%EF%BC%8C%E4%BB%A5%E4%BF%9D%E8%AF%81%20TX%2FRX%20%E7%BA%BF%E8%B7%AF%E7%9A%84%E6%8E%A5%E8%BF%91%E5%BA%A6%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%B8%80%E7%A7%8D%E6%96%B0%E5%9E%8B%E8%BF%9E%E6%8E%A5%E5%99%A8%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42393i9068253606BDD390%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(2).jpeg%22%20alt%3D%22image%20(2).jpeg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage%20(2).jpeg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9%E9%9D%A2%EF%BC%8C%E6%88%91%E4%BB%8E%20SABRE%20Lite%20J23%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%E5%B0%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9E%E6%8E%A5%E5%88%B0%20KZ-B21%EF%BC%88%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%3C%2FA%3E%20%EF%BC%89%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%87%A0%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%E6%B5%8B%E8%AF%95%E4%BA%86%E8%BF%99%E4%B8%AA%EF%BC%8C%E5%9C%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E5%8F%B0%EF%BC%88%E5%8F%AA%E6%9C%89%E4%B8%80%E5%8F%B0%EF%BC%89%E4%B8%8A%EF%BC%8C%E5%BD%93%E6%88%91%E6%89%A7%E8%A1%8C%E2%80%9Clspci%E2%80%9D%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E6%88%91%E7%9A%84%20dead%3Abeaf%20%E8%AE%BE%E5%A4%87%E4%BD%9C%E4%B8%BA%20RAM%20pcie%20%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20Sabrelite%20%E4%B8%8A%EF%BC%8C%E9%93%BE%E6%8E%A5%E4%BF%9D%E6%8C%81%20UP%EF%BC%880x00000310%EF%BC%89%E7%9C%8B%E8%B5%B7%E6%9D%A5%E7%94%B5%E7%BC%86%E7%A1%AE%E5%AE%9E%E6%98%AF%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E7%94%B5%E8%84%91%E7%9A%84%E5%86%85%E5%AD%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8D%E7%84%B6%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E8%AE%BE%E5%A4%87%E6%98%AF%E5%90%A6%E4%BB%A5%20100Mhz%20%E6%88%96%20125Mhz%20%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%88%91%E6%98%AF%E5%90%A6%E6%B2%A1%E6%9C%89%E6%97%B6%E9%92%9F%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%A1%AE%E4%BF%A1%E7%9A%84%E6%98%AF%EF%BC%8C%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%EF%BC%8C%E9%93%BE%E6%8E%A5%E4%B8%8D%E5%81%9C%E5%9C%B0%E6%96%AD%E5%BC%80%E5%92%8C%E8%BF%9E%E6%8E%A5%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%8D%E7%84%B6%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E6%98%AF%E5%90%A6%E6%B2%A1%E6%9C%89%E6%97%B6%E9%92%9F%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E6%9B%B4%E5%A4%9A%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%EF%BC%9F%E6%88%91%E7%9F%A5%E9%81%93%E7%9A%84%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%9F%90%E4%BA%9B%20EP%20%E5%AE%9E%E7%8E%B0%E4%B8%AD%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%BF%80%E6%B4%BB%E8%BE%93%E5%85%A5%E4%B8%AD%20LVDS%20%E7%AB%AF%E5%8F%A3%E7%9A%84%20CLK1%E3%80%82%E5%AE%83%E6%98%AF%E5%90%A6%E5%88%87%E6%8D%A2%E5%88%B0%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%87%B3%E4%BA%8E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%20%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E7%9A%84%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%EF%BC%88%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E5%8F%A5%EF%BC%8C%E8%A6%81%E5%9C%A8%E8%BF%99%E9%87%8C%E5%8F%91%E5%B8%83%E5%9B%BE%E7%89%87%EF%BC%8C%E5%8F%AA%E9%9C%80%E6%8B%96%E6%94%BE%E5%8D%B3%E5%8F%AF%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3E%E5%85%B3%E9%94%AE%3C%2FA%3E%E5%9C%A8%E4%BA%8E%20-%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98614%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-98614%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%AD%A4%E5%A4%84%E7%B2%98%E8%B4%B4%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%80%E5%86%99%E7%9A%84%E6%83%85%E5%86%B5%E6%98%AF%E9%80%82%E9%85%8D%E5%99%A8%E4%B8%8A%E6%B2%A1%E6%9C%89%E7%B2%89%E8%89%B2%E5%92%8C%E6%A9%99%E8%89%B2%E6%8F%92%E5%A4%B4%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%B7%BB%E5%8A%A0%E5%AE%83%E6%98%AF%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E4%B8%BA%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%8F%90%E4%BE%9B%E6%97%B6%E9%92%9F%E3%80%82%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E6%9D%A5%E8%87%AA%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%E7%9A%84%E4%BF%A1%E5%8F%B7%E3%80%82%E5%86%85%E6%A0%B8%E5%8A%A0%E8%BD%BD%E6%8C%82%E6%96%AD%E6%B6%88%E6%81%AF%E2%80%9CPCIe%20EP%EF%BC%9A%E7%AD%89%E5%BE%85%E9%93%BE%E6%8E%A5...%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E7%94%A8%20memtool%20%E6%A3%80%E6%9F%A5%E4%BA%86%E6%88%91%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E2%80%9Cwhile%EF%BC%88true%EF%BC%89%EF%BC%9B%E6%89%A7%E8%A1%8C%E7%9D%A1%E7%9C%A01%EF%BC%9B.%2Fmemtool-32%2001ffc72c%201%20%7C%20grep%20-v%20%E6%B7%BB%E5%8A%A0%20%7C%20grep%200x%EF%BC%9B%E5%AE%8C%E6%88%90%E2%80%9D%3C%2FP%3E%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E7%AC%AC%204%20%E4%BD%8D%E4%BC%9A%E4%BB%8E%201%20%E5%8F%98%E4%B8%BA%200%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E5%8F%98%E4%B8%BA%201%E2%80%A6%E2%80%A6%E9%9A%8F%E6%9C%BA%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E4%B9%9F%E8%AE%B8%E6%88%91%E7%9A%84%E7%94%B5%E7%BC%86%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E6%88%96%E8%80%85%EF%BC%8C%E4%BA%8B%E5%AE%9E%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E5%8F%AF%E8%83%BD%E4%BB%A5%20125Mhz%20%E5%90%8C%E6%AD%A5%EF%BC%8C%E8%80%8C%E6%AD%A3%E5%B8%B8%E7%9A%84%20PCI%20%E6%80%BB%E7%BA%BF%E4%BB%A5%20100Mhz%20%E5%90%8C%E6%AD%A5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E4%B8%8D%E5%90%8C%E6%AD%A5%E5%B9%B6%E4%B8%94%E9%93%BE%E6%8E%A5%E6%96%AD%E5%BC%80%E3%80%82%20%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%E6%88%91%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%E6%88%91%E5%A4%84%E4%BA%8E%20125Mhz%20%E8%BF%98%E6%98%AF%20100Mhz%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%BC%94%E7%A4%BA%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%99%AE%E9%80%9A%20PC%20%E8%80%8C%E4%B8%8D%E6%98%AF%202%20%E4%B8%AA%20Sabre%20%E6%9D%BF%E5%B0%86%E8%AE%BE%E5%A4%87%E5%8F%98%E6%88%90%20EP%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%82%A8%E8%83%BD%E5%8F%91%E5%B8%83%E4%B8%80%E5%BC%A0%E6%82%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%9B%BE%E7%89%87%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%9C%A8%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%8D%95%E9%9D%A2%20PCB%EF%BC%8C%E5%9B%A0%E6%AD%A4%20TX%2B%2FTX-%20%E4%BF%A1%E5%8F%B7%E7%9B%B8%E8%B7%9D%E5%87%A0%E5%8E%98%E7%B1%B3%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E4%B8%8E%E2%80%9C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E%20%E2%80%9D%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E7%9F%AD%E7%94%B5%E7%BC%86%E5%B8%AE%E5%8A%A9%E6%88%91%E9%81%BF%E5%85%8D%E4%BA%86%E5%86%85%E6%A0%B8%E5%9C%A8%E6%B6%88%E6%81%AF%E2%80%9CPCIE%EF%BC%9A%E7%AD%89%E5%BE%85%E9%93%BE%E6%8E%A5...%E2%80%9D%EF%BC%88%E6%88%96%E7%B1%BB%E4%BC%BC%E6%B6%88%E6%81%AF%EF%BC%89%E5%90%8E%E6%8C%82%E6%96%AD%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%86%E6%98%AF%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%E4%B8%8A%E6%B2%A1%E6%9C%89%E2%80%9Cdead_beaf%E2%80%9D%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%A0%B9%E5%A4%8D%E5%90%88%E4%BD%93%E7%AB%AF%E4%BD%BF%E7%94%A8%20PC%E3%80%82%3CSTRONG%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FSTRONG%3E%E2%80%9C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%AE%A9%E4%B8%BB%E6%9D%BF%E4%BD%9C%E4%B8%BA%20EP%20%E4%B8%8E%E6%99%AE%E9%80%9A%20PC%20%E5%92%8C%E6%99%AE%E9%80%9A%20Linux%203.11%20%E4%B8%80%E8%B5%B7%E5%B7%A5%E4%BD%9C%EF%BC%9F%E2%80%9D%E6%88%91%E6%B2%A1%E6%9C%89%E6%9B%B4%E5%A4%9A%E7%9A%84%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%B8%BB%E6%9D%BF%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%E5%A6%82%E6%9E%9C%E5%AE%83%E6%98%BE%E7%A4%BA%E9%93%BE%E8%B7%AF%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%AE%83%E7%9C%9F%E7%9A%84%E8%BF%9E%E6%8E%A5%E4%B8%8A%E4%BA%86%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E4%BB%85%E4%BB%85%E6%98%AF%E5%9B%A0%E4%B8%BA%20RX%20%E8%B7%AF%E5%BE%84%E4%B8%8A%E6%9C%89%E4%B8%80%E4%BA%9B%E7%94%B5%E6%B0%94%E6%B4%BB%E5%8A%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E7%9B%B8%E4%BF%A1%E4%B8%BB%E6%9D%BF%E7%9A%84%E9%A2%91%E7%8E%87%E6%98%AF%20125Mhz%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20100Mhz%EF%BC%88%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%EF%BC%9F%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%94%E7%94%B1%E4%BA%8E%E5%AE%83%E6%8F%92%E5%85%A5%20PC%20%E5%86%85%E9%83%A8%EF%BC%8C%E6%89%80%E4%BB%A5%20PC%20%E4%B8%AD%E6%80%BB%E7%BA%BF%E7%9A%84%E9%A2%91%E7%8E%87%E5%BA%94%E8%AF%A5%E6%98%AF%20100Mhz%EF%BC%8C%E4%B8%8D%E6%98%AF%E5%90%97%EF%BC%9F%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E9%93%BE%E6%8E%A5%E5%A6%82%E4%BD%95%E5%BB%BA%E7%AB%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%9C%A8%20PC%20%E7%AB%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%8F%91%E5%87%BA%E2%80%9Clspci%E2%80%9D%E6%97%B6%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E4%B8%8E%E4%B8%BB%E6%9D%BF%E5%AF%B9%E5%BA%94%E7%9A%84%E4%BD%9C%E4%B8%BA%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E7%9A%84%20PCI%20%E6%8E%A5%E5%8F%A3%E3%80%82%E9%82%A3%E4%B9%88%EF%BC%8C%E6%82%A8%E9%92%88%E5%AF%B9%20EP%20%E5%92%8C%E2%80%9C%E6%A8%A1%E6%8B%9F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E2%80%9D%E7%9A%84%E8%A1%A5%E4%B8%81%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%8F%A6%E4%B8%80%E7%AB%AF%E8%A2%AB%E8%A7%86%E4%B8%BA%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%93%87%EF%BC%8C%E5%A4%AA%E7%A5%9E%E5%A5%87%E4%BA%86%EF%BC%8C%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%E9%93%BE%E6%8E%A5%E4%BB%8D%E7%84%B6%E7%95%85%E9%80%9A%EF%BC%8C%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%9A%84%E7%94%B5%E7%BC%86%E6%AF%94%E4%BD%A0%E7%9A%84%E7%A1%AC%E4%BB%B6%E7%A8%8D%E9%95%BF%E4%B8%80%E4%BA%9B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%85%B3%E4%BA%8E%E9%93%BE%E6%8E%A5%E6%98%AF%E5%90%A6%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E8%B0%83%E8%AF%95%E5%AF%84%E5%AD%98%E5%99%A8%201%EF%BC%880x01ff_c72c%EF%BC%89%E7%9A%84%E4%BD%8D%204%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%AD%A4%E4%BD%8D%EF%BC%8C%E5%88%99%E9%93%BE%E6%8E%A5%E5%B7%B2%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20IMX6Q%20%E7%9A%84%20Sabrelite%20%E6%9D%BF%E4%BD%9C%E4%B8%BA%20PCIe%20EP%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E6%9D%A1%20PCIe%20%E7%94%B5%E7%BC%86%EF%BC%8C%E4%BB%8E%20PCIe%20%E7%AB%AF%E5%8F%A3%20(j23)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%80%E5%9D%97%E5%B8%A6%E6%9C%89%20Molex%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%9A%84%E5%B0%8F%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%20Raiser%20%E5%B0%86%E5%85%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%20FPC%20Flex%20%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%8C%E4%B8%80%E7%9B%B4%E5%88%B0%20PCIe%20%E9%87%91%E6%89%8B%E6%8C%87%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%3C%2FA%3E%E6%AD%A4%20Raiser%20%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%E5%8F%AF%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%89%BE%E5%88%B0%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%E6%88%91%E5%9C%A8%20PCIe%20%E9%87%91%E6%89%8B%E6%8C%87%E9%83%A8%E5%88%86%E8%BF%9E%E6%8E%A5%20PRSNT1%23%20--%20PRSNT2%23%20%E6%9D%A5%E5%91%8A%E8%AF%89%E4%B8%BB%E6%9C%BA%20PC%20%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%20x1%20pcie%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%8F%AF%E4%BB%A5%E6%81%A2%E5%A4%8D%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3EGND%20--%26nbsp%3B%20GND%3C%2FP%3E%3CP%3ETXP%20--%20RXP%3C%2FP%3E%3CP%3ETXM%20--%20RXM%3C%2FP%3E%3CP%3ERXP%20--%20TXP%3C%2FP%3E%3CP%3ERXM%20--%20TXM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41453iBEAB397888E054DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(1).jpeg%22%20alt%3D%22image%20(1).jpeg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage%20(1).jpeg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(%3CA%20href%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20title%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%3C%2FA%3E)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20BOOT%20%E7%9A%84%E8%A7%86%E5%9B%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%8E%8B%20Linux...%E5%AE%8C%E6%88%90%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3E%5B0.000000%5DLinux%20%E7%89%88%E6%9C%AC%203.0.35-2508-g54750ff%EF%BC%88xavier%40ubuntu%EF%BC%89%EF%BC%88gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88Freescale%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%89%EF%BC%89%2324%20SMP%20PREEMPT%20%E5%91%A8%E6%97%A5%2011%20%E6%9C%88%203%20%E6%97%A5%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c53c7d%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%9C%BA%E5%99%A8%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX%206Quad%20Sabre-Lite%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3E%5B0.000000%5DPERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A227328%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aenable_wait_mode%3Doff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20console%3Dttymxc1%2C115200%20vmalloc%3D400M%20consoleblank%3D0%20rootwait%20root%3D%2Fdev%2Fmmcblk0p1%3C%2FP%3E%3CP%3E%5B0.000000%5DPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5DDentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5DInode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%EF%BC%9A640MB%20%2B%20256MB%20%3D%20%E5%85%B1%E8%AE%A1%20896MB%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%EF%BC%9A896756k%2F896756k%E5%8F%AF%E7%94%A8%EF%BC%8C151820k%E4%BF%9D%E7%95%99%EF%BC%8C0K%20highmem%3C%2FP%3E%3CP%3E%5B0.000000%5D%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B0.000000%5DDMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%5B0.000000%5D%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xc0000000%EF%BC%881024%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003b000%26nbsp%3B%26nbsp%3B%20(%20204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003b000%20-%200x80aa62cc%26nbsp%3B%26nbsp%3B%20(10669%20kB)%3C%2FP%3E%3CP%3E%5B0.000000%5D%E3%80%82%E6%95%B0%E6%8D%AE%EF%BC%9A0x80aa8000-0x80b072c0%EF%BC%88381%20KB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b072e4%20-%200x80b556ac%26nbsp%3B%26nbsp%3B%20(%20313%20kB)%3C%2FP%3E%3CP%3E%5B0.000000%5DSLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%8F%AF%E6%8A%A2%E5%8D%A0%E7%9A%84%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B0.000000%5DMXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3C%2FP%3E%3CP%3E%5B0.000000%5Dsched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B0.000000%5DMXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x21e8000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc1%5D%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3C%2FP%3E%3CP%3E%5B0.224540%5D%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.312867%5Dpid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3C%2FP%3E%3CP%3E%5B0.317802%5D%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3C%2FP%3E%3CP%3E%5B0.323097%5DCPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3C%2FP%3E%3CP%3E%5B0.328254%5Dhw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.428774%5DCPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.508778%5DCPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.588792%5DCPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.628290%5D%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3C%2FP%3E%3CP%3E%5B0.644115%5DSMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%5B0.667822%5D%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%20%3C%2FP%3E%3CP%3E%5B0.671823%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3C%2FP%3E%3CP%3E%5B0.680477%5Dprint_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.688013%5Dprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.695751%5Dprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.703438%5Dprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.711197%5Dprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.718839%5Dprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.727742%5D**%E8%B0%83%E8%AF%95%20mx6_sabrelite_board_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.790388%5D%20**DEBUG%20imx_add_pcie%3C%2FP%3E%3CP%3E%5B0.793966%5Dhw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%5B0.800798%5Dhw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%5B0.808143%5Dhw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%5B0.814042%5D%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.818071%5Dl2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3C%2FP%3E%3CP%3E%5B0.849718%5Dbio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B0.857066%5Dmxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.861759%5D%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%20%3C%2FP%3E%3CP%3E%5B0.866817%5Dvgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B0.870369%5DSCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.874931%5Dspi_imx%20imx6q-ecspi.0%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3E%5B0.879688%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3C%2FP%3E%3CP%3E%5B0.885314%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.890798%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3C%2FP%3E%3CP%3E%5B0.895867%5D%E5%B7%B2%E5%8A%A0%E8%BD%BD%20Freescale%20USB%20OTG%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.918287%5D%20imx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.938282%5D%20imx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B0.946109%5Dmxc_mipi_csi2%20mxc_mipi_csi2%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%20i.MX%20MIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B0.952586%5Dmxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%E7%89%88%E6%9C%AC%E4%B8%BA0x3130302a%3C%2FP%3E%3CP%3E%5B0.960308%5DMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B0.964632%5D%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0.24%E3%80%82%3C%2FP%3E%3CP%3E%5B0.971833%5D%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.16%3C%2FP%3E%3CP%3E%5B0.975533%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F31%3C%2FP%3E%3CP%3E%5B0.980001%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.986377%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.991277%5D%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.996429%5D%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B1.001760%5Dcfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3C%2FP%3E%3CP%3E%5B1.008652%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmax17135%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B1.014941%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B1.021168%5D%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3C%2FP%3E%3CP%3E%5B1.037670%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3C%2FP%3E%3CP%3E%5B1.042238%5DIP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.050180%5DTCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.059505%5DTCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.067234%5DTCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.073869%5DTCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B1.077034%5DUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.082999%5DUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.089789%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3E%5B1.094454%5DRPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B1.100408%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B1.105126%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B1.109852%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B1.117195%5D%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3E%5B1.122438%5Di.MX6%20%E7%9A%84%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%5B1.126812%5Dcpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3E%5B1.132223%5DPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.135722%5D%20**DEBUG%20imx_pcie_drv_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.174919%5D%20**DEBUG%20imx_pcie_pltfm_probe%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.178171%5D%20iMX6%20PCIe%20PCIe%20EP%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B1.184380%5DPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B1.189459%5DPCIe%20EP%EF%BC%9A%E7%AD%89%E5%BE%85%E9%93%BE%E6%8E%A5%E2%80%A6%E2%80%A6%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B15.540166%5DPCIe%20EP%EF%BC%9A%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%5B15.543512%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B15.547195%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3E%5B15.554446%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B15.557952%5DCPU%E8%B0%83%E8%8A%82%E5%99%A8%E6%A8%A1%E5%BC%8F%EF%BC%9Aldo_enable%3C%2FP%3E%3CP%3E%5B15.562170%5Di.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FP%3E%3CP%3E%5B15.590899%5DJFFS2%20%E7%89%88%E6%9C%AC%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3E%5B15.597527%5Dmsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201751%3C%2FP%3E%3CP%3E%5B15.602766%5Dalg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E%5B15.607030%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B15.610966%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B15.615331%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3E%5B15.621043%5DMIPI%20DSI%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B15.625229%5Dmxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20mxcfb0%20%E7%9A%84%20fb%20%E9%80%89%E9%A1%B9%EF%BC%81%3C%2FP%3E%3CP%3E%5B15.631641%5Dmxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20mxcfb1%20%E7%9A%84%20fb%20%E9%80%89%E9%A1%B9%EF%BC%81%3C%2FP%3E%3CP%3E%5B15.638041%5Dmxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20mxcfb2%20%E7%9A%84%20fb%20%E9%80%89%E9%A1%B9%EF%BC%81%3C%2FP%3E%3CP%3E%5B15.644430%5Dmxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E%5B15.650830%5D_regulator_get%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3E%5B15.667087%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E8%AE%BE%E5%A4%87%20160x50%3C%2FP%3E%3CP%3E%5B15.682241%5Dimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3C%2FP%3E%3CP%3E%5B15.690972%5Dimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B15.814091%5D%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B15.817281%5DIMX-UART.0%EF%BC%9AMMIO%200x2020000%20(irq%20%3D%2058)%20%E5%A4%84%E7%9A%84%20ttymxc0%20%E6%98%AF%20IMX%3C%2FP%3E%3CP%3E%5B15.824129%5DIMX-UART.1%EF%BC%9Attymxc1%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21e8000%20(irq%20%3D%2059)%20%E6%98%AF%20IMX%3C%2FP%3E%3CP%3E%5B15.830620%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc1%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%5B15.830620%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc1%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%5B15.846998%5D%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B15.884600%5D%E6%B2%A1%E6%9C%89%20SATA%20%E7%A3%81%E7%9B%98%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.888429%5D%20m25p80%20spi0.0%3A%20sst25vf016b%20(2048%20Kbytes)%3C%2FP%3E%3CP%3E%5B15.893400%5D%E5%9C%A8%E2%80%9Cm25p80%E2%80%9D%E4%B8%8A%E5%88%9B%E5%BB%BA%202%20%E4%B8%AA%20MTD%20%E5%88%86%E5%8C%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%5B15.898209%5D0x000000000000-0x000000100000%EF%BC%9A%E2%80%9C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E2%80%9D%3C%2FP%3E%3CP%3E%5B15.904579%5D0x000000100000-0x000000200000%EF%BC%9A%E2%80%9C%E5%86%85%E6%A0%B8%E2%80%9D%3C%2FP%3E%3CP%3E%5B15.910711%5DGPMI%20NAND%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%EF%BC%88IMX%EF%BC%89%3C%2FP%3E%3CP%3E%5B15.916014%5Dvcan%EF%BC%9A%E8%99%9A%E6%8B%9F%20CAN%20%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B15.920464%5DCAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3CP%3E%5B15.924304%5Dflexcan%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B15.928752%5Dflexcan%20imx6q-flexcan.0%EF%BC%9A%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88reg_base%3Dc09e8000%EF%BC%8Cirq%3D142%EF%BC%89%3C%2FP%3E%3CP%3E%5B15.936542%5DFEC%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B15.941717%5Dfec_enet_mii_bus%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3E%5B15.946292%5Dehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.952944%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B15.959594%5Dfsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.995767%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.015757%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B2008%E5%B9%B42%E6%9C%8816%E6%97%A5%5D%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B16.025780%5D%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B16.029901%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.033602%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B16.040243%5Dfsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.075767%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.095755%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B16.101938%5D%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B16.105702%5D%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B16.109947%5D%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FP%3E%3CP%3E%5B16.114988%5Dusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3C%2FP%3E%3CP%3E%5B16.121010%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%5B16.125632%5DARC%20USBOTG%20%E8%AE%BE%E5%A4%87%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%882005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5%EF%BC%89%3C%2FP%3E%3CP%3E%5B16.132344%5Dmousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84%20PS%2F2%20%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%5B16.138373%5D%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%5B16.145762%5Degalax_ts%202-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%5B16.152477%5Degalax_ts%EF%BC%9A2-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3C%2FP%3E%3CP%3E%5B16.158557%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.164830%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.171586%5Dsnvs_rtc%20snvs_rtc.0%EF%BC%9Artc%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B0%86%20snvs_rtc%20%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3C%2FP%3E%3CP%3E%5B16.178258%5Di2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.182461%5DLinux%E8%A7%86%E9%A2%91%E9%87%87%E9%9B%86%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3C%2FP%3E%3CP%3E%5B16.187446%5Dmxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video16%3C%2FP%3E%3CP%3E%5B16.195068%5Dmxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video17%3C%2FP%3E%3CP%3E%5B16.202918%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.209139%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.215645%5Dimx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3C%2FP%3E%3CP%3E%5B16.223761%5D%E8%93%9D%E7%89%99%EF%BC%9A%E8%99%9A%E6%8B%9F%20HCI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%5B16.228680%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.2%3C%2FP%3E%3CP%3E%5B16.233128%5D%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B16.238105%5D%E8%93%9D%E7%89%99%EF%BC%9A%E9%80%9A%E7%94%A8%E8%93%9D%E7%89%99%20USB%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.6%3C%2FP%3E%3CP%3E%5B16.243804%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3C%2FP%3E%3CP%3E%5B16.249437%5Dsdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.255623%5Dsdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3E%5B16.260386%5Dmmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.3%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3E%5B16.267756%5Dmmc1%3A%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.2%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3E%5B16.275002%5Dmxc_vdoa%20mxc_vdoa%EF%BC%9A%E6%8E%A2%E6%B5%8Bi.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%88VDOA%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.286210%5DVPU%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B16.289955%5Dmxc_asrc%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B16.317073%5D%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x5874c87d%3C%2FP%3E%3CP%3E%5B16.321870%5D%E6%AF%94%E7%8E%87%20%3D%20183%20%E7%9A%84%E7%83%AD%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3E%5B16.345881%5DAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3C%2FP%3E%3CP%3E%5B16.351169%5Danatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3C%2FP%3E%3CP%3E%5B16.358317%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3C%2FP%3E%3CP%3E%5B16.363893%5Dusbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.368144%5Dusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20snd-usb-audio%3C%2FP%3E%3CP%3E%5B16.374848%5Dmxc_hdmi_soc%20mxc_hdmi_soc.0%EF%BC%9AMXC%20HDMI%20%E9%9F%B3%E9%A2%91%3C%2FP%3E%3CP%3E%5B16.380296%5DCirrus%20Logic%20CS42888%20ALSA%20SoC%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.385539%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.387149%5Dmmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20SDHC%20%E5%8D%A1%3C%2FP%3E%3CP%3E%5B16.397244%5Di2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B16.403550%5Dmmcblk0%3A%20mmc0%3A0001%2000000%207.44%20GiB%20%3C%2FP%3E%3CP%3E%5B16.404126%5Dimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CP%3E%5B16.404881%5Dimx_3stack%20asoc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B16.405497%5D%E5%88%9D%E5%A7%8B%E5%8C%96%20HDMI%20%E9%9F%B3%E9%A2%91%E5%A4%B1%E8%B4%A5%E3%80%82%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%EF%BC%81%3C%2FP%3E%3CP%3E%5B16.405505%5DALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%5B16.405510%5D%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A3%B0%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3E%5B16.405716%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3C%2FP%3E%3CP%3E%5B16.406295%5DTCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B16.406303%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3C%2FP%3E%3CP%3E%5B16.406320%5DCAN%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E6%A0%B8%E5%BF%83%EF%BC%88rev%2020090105%20abi%208%EF%BC%89%3C%2FP%3E%3CP%3E%5B16.406391%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2029%3C%2FP%3E%3CP%3E%5B16.406407%5Dcan%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%EF%BC%89%3C%2FP%3E%3CP%3E%5B16.406413%5Dcan%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%20t%EF%BC%89%3C%2FP%3E%3CP%3E%5B16.425829%5Dusb%202-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%202%3C%2FP%3E%3CP%3E%5B16.470303%5D%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B16.471595%5Dmmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%5B16.477735%5D%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B16.482876%5D%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3C%2FP%3E%3CP%3E%5B16.486635%5D%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%5B16.491949%5D%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3C%2FP%3E%3CP%3E%5B16.497189%5D%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E7%95%8C%E9%9D%A2%E6%A8%A1%E6%8B%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3E%5B16.503241%5Dlib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3C%2FP%3E%3CP%3E%5B16.508958%5DVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3C%2FP%3E%3CP%3E%5B16.516994%5D%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B16.521011%5D%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%5B16.526514%5Dmxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%5B16.529846%5D%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3E%5B16.535886%5Dsnvs_rtc%20snvs_rtc.0%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01%2005%3A59%3A54%20UTC%20(21594)%3C%2FP%3E%3CP%3E%5B16.549411%5DEXT3-fs%EF%BC%9A%E6%9C%AA%E5%90%AF%E7%94%A8%E5%B1%8F%E9%9A%9C%3C%2FP%3E%3CP%3E%5B16.554225%5Dkjournald%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3E%5B16.558984%5DEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%5B16.558996%5DEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BB%A5%E5%9B%9E%E5%86%99%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E6%8C%82%E8%BD%BD%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E%5B16.559027%5DVFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%20179%3A1%20%E4%B8%8A%E6%8C%82%E8%BD%BD%E6%A0%B9%EF%BC%88ext3%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%5B16.559086%5D%E9%87%8A%E6%94%BE%E5%88%9D%E5%A7%8B%E5%86%85%E5%AD%98%EF%BC%9A204K%3C%2FP%3E%3CP%3E%5B16.648921%5D%E6%9E%A2%E7%BA%BD%202-1%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B16.652848%5D%E9%9B%86%E7%BA%BF%E5%99%A8%202-1%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%203%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%201354%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%20%2Fproc%20%E5%92%8C%20%2Fsys%20%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20udevd%3C%2FP%3E%3CP%3E%5B16.886688%5Dudevd%EF%BC%881372%EF%BC%89%EF%BC%9A%2Fproc%2F1372%2Foom_adj%20%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E6%94%B9%E7%94%A8%2Fproc%2F1372%2Foom_score_adj%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%88%E6%88%90%E5%88%9D%E5%A7%8B%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%3C%2FP%3E%3CP%3E%E5%B0%86%E4%B8%BB%E6%9C%BA%E5%90%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BE%B9%E7%95%8C%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3Emount%EF%BC%9A%E5%9C%A8%20%2Fproc%2Fbus%2Fusb%20%E4%B8%8A%E5%AE%89%E8%A3%85%20usbfs%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%E8%BF%90%E8%A1%8C%20sysctl%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%8E%AF%E5%9B%9E%E8%AE%BE%E5%A4%87%E4%B8%8A%E8%AE%BE%E7%BD%AE%E7%BD%91%E7%BB%9C%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E5%9C%A8%20eth0%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E7%BD%91%E7%BB%9C%EF%BC%9A%20%3C%2FP%3E%3CP%3Eudhcpc%EF%BC%88v1.20.2%EF%BC%89%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FP%3E%3CP%3E%5B19.039687%5Deth0%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20FEC%20PHY%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5BMicrel%20KSZ9021%20%E5%8D%83%E5%85%86%20PHY%5D%EF%BC%88mii_bus%EF%BC%9Aphy_addr%3D1%3A06%EF%BC%8Cirq%3D-1%EF%BC%89%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FP%3E%3CP%3E%E6%97%A0%E7%A7%9F%E8%B5%81%EF%BC%8C%E5%88%86%E5%8F%89%E8%87%B3%E5%90%8E%E5%8F%B0%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8dropbear%20ssh%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%203060%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%203068%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%894.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%206%20%E6%9C%88%2018%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C%2012%3A28%3A53%20-0700%3C%2FP%3E%3CP%3EFreescale%20Semiconductor%2C%20Inc.%3C%2FP%3E%3CP%3E%E8%BE%B9%E7%95%8C%E7%99%BB%E5%BD%95%EF%BC%9A%20%3C%2FP%3E%3CP%3EU-Boot%202013.01-rc1-00120-g7c28db0%EF%BC%882012%E5%B9%B411%E6%9C%8812%E6%97%A5%20-%2009%3A15%3A04%EF%BC%89%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%A1%8C%E4%B8%BA%E6%98%AF%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%B9%B6%E9%98%BB%E5%A1%9E%E5%9C%A8%EF%BC%9A%E2%80%9C%20%3CSTRONG%3EPCIe%20EP%EF%BC%9A%E7%AD%89%E5%BE%85%E9%93%BE%E6%8E%A5......%3C%2FSTRONG%3E%20%E2%80%9D%E5%B9%B6%E4%B8%94%E5%8F%AA%E8%A6%81%E6%88%91%E6%89%93%E5%BC%80%E7%94%B5%E8%84%91%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%BC%9A%E4%B8%80%E7%9B%B4%E7%BB%A7%E7%BB%AD%E5%88%B0%E7%99%BB%E5%BD%95%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%82%A3%E4%B8%AA%E9%98%B6%E6%AE%B5%EF%BC%8C%E7%9F%A5%E9%81%93%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%20IMX6q%20%E4%B8%BA%20125Mhz%EF%BC%8C%E5%B9%B6%E4%B8%94%20CLK%20%E4%BF%A1%E5%8F%B7%E6%9C%AA%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E7%9A%84%20PCIe%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%20PLL%EF%BC%8C%E5%B9%B6%E4%B8%94%20PCIe%20%E7%9A%84%E6%A0%87%E5%87%86%E4%B8%BA%20100Mhz%E3%80%82%E7%A1%AE%E5%AE%9A%E9%93%BE%E6%8E%A5%E7%A1%AE%E5%AE%9E%E5%B7%B2%E6%89%93%E5%BC%80%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%BE%E7%84%B6%EF%BC%8C%E5%9C%A8%20PC%20%E7%AB%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%8F%91%E5%87%BA%E2%80%9Clspci%E2%80%9D%EF%BC%8C%E6%88%91%E4%BB%80%E4%B9%88%E4%B9%9F%E7%9C%8B%E4%B8%8D%E5%88%B0%E3%80%82%3A%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%A0%B9%E6%8D%AE%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E5%B0%86%20VID%2FPID%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9CDEADBEAF%E2%80%9D%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E6%9F%A5%E7%9C%8B%E5%86%85%E5%AD%98%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E7%9A%84%E6%98%AF%E9%BB%98%E8%AE%A4%E7%9A%84%20VID%2FPID%EF%BC%9A%3C%2FP%3E%3CP%3E%24.%2Fmemtool-32%2001FFC000%2020%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BB%8E%E5%9C%B0%E5%9D%80%200x01FFC000%20%E5%BC%80%E5%A7%8B%E8%AF%BB%E5%8F%96%200x20%20%E4%B8%AA%E8%AE%A1%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E0x01FFC000%3A%20%3CSTRONG%3EABCD16C3%3C%2FSTRONG%3E%2000100000%2000000001%2000000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0x01FFC010%3A%200000000C%2000000000%2000000008%2000000001%3C%2FP%3E%3CP%3E0x01FFC020%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC030%3A%2000000000%2000000040%2000000000%20000001FF%3C%2FP%3E%3CP%3E0x01FFC040%3A%20DBC35001%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC050%3A%2001807005%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC060%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC070%3A%2000020010%2000008700%2000102010%200001CC12%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E8%82%AF%E5%AE%9A%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%E6%AC%A2%E8%BF%8E%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%85%E4%BE%9B%E5%8F%82%E8%80%83%EF%BC%8C%E6%88%91%E7%94%9A%E8%87%B3%E5%83%8F%E8%BF%99%E6%A0%B7%E4%BF%AE%E8%A1%A5%E4%BA%86%E6%88%91%E7%9A%84%20sabrelite%20%E6%96%87%E4%BB%B6%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%9E%B6%E6%9E%84%2F%E8%87%82%2Fmach-mx6%2Fboard-mx6q_sabrelite.c%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_MAX7310_1_BASE_ADDR%26nbsp%3B%26nbsp%3B%20IMX_GPIO_NR(8%2C%200)%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_PCIE_RST_B_REVB%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(SABREAUTO_MAX7310_1_BASE_ADDR%20%2B%202)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%E9%9D%99%E6%80%81const%E7%BB%93%E6%9E%84imx_pcie_platform_data%20mx6_sabrelite_pcie_data%20__initconst%20%3D%20%7B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_pwr_en%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_rst%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20SABREAUTO_PCIE_RST_B_REVB%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_wake_up%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_dis%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%23ifdef%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3C%2FP%3E%3CP%3E%2B%20.type_ep%3D%201%EF%BC%8C%3C%2FP%3E%3CP%3E%2B%23else%3C%2FP%3E%3CP%3E%2B%20.type_ep%3D%200%EF%BC%8C%3C%2FP%3E%3CP%3E%2B%23endif%3C%2FP%3E%3CP%3E%2B%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E6%80%81void%20__init%20mx6_sabrelite_board_init%EF%BC%88void%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%2F*%20%E6%B7%BB%E5%8A%A0%20PCIe%20RC%20%E6%8E%A5%E5%8F%A3%E6%94%AF%E6%8C%81%20*%2F%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_pcie(%26amp%3Bmx6_sabrelite_pcie_data)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(0)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(1)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(2)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F362575%23362575%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F362575%23362575%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%9A%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%8F%91%E5%B8%83%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E6%9D%A5%E8%AE%A8%E8%AE%BA%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E4%B8%8E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%2FRC%20%E9%AA%8C%E8%AF%81%E5%AE%8C%E5%85%A8%E6%97%A0%E5%85%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%91%E5%B8%83%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%91%E8%AE%B0%E5%BE%97%201.1.0%E7%89%88%E6%9C%AC%E5%B0%9A%E4%B8%8D%E6%94%AF%E6%8C%81%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%88%91%E9%80%89%E6%8B%A9%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E6%9C%89%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fbuilt-in.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%9Cdefault_setup_msi_irqs%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Eclkdev.c%3A%EF%BC%88.%E6%96%87%E6%9C%AC%2B0x10ca4%EF%BC%89%EF%BC%9A%E5%AF%B9%E2%80%9Carch_setup_msi_irq%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fbuilt-in.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%9Cdefault_teardown_msi_irqs%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Eclkdev.c%3A%EF%BC%88.%E6%96%87%E6%9C%AC%2B0x10d18%EF%BC%89%EF%BC%9A%E5%AF%B9%E2%80%9Carch_teardown_msi_irq%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3Emake%EF%BC%9A***%20%5B.tmp_vmlinux1%5D%20%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%5B%20%5D%20Message%20Signaled%20Interrupts%20(MSI%20and%20MSI-X)%3C%2FSPAN%3E%E5%9C%A8%20make%20menuconfig%20%E4%B8%AD%E9%9C%80%E8%A6%81%E9%80%89%E6%8B%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eroot%40freescale%20~%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E7%B1%BB%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%EF%BC%9A00.0%20%E7%B1%BB%200400%EF%BC%9A14f1%EF%BC%9A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20%E7%B1%BB%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%EF%BC%9A00.0%20%E7%B1%BB%200400%EF%BC%9A14f1%EF%BC%9A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%98%AF%3C%2FP%3E%3CP%3E%E9%9D%99%E6%80%81%E7%BB%93%E6%9E%84%20pci_device_id%20cx25858_pci_tbl%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CX25858%20Atlas%20Plus%20*%2F%3C%2FP%3E%3CP%3E.%E4%BE%9B%E5%BA%94%E5%95%86%3D0x14f1%EF%BC%8C%3C%2FP%3E%3CP%3E.%E8%AE%BE%E5%A4%87%3D0x8580%EF%BC%8C%3C%2FP%3E%3CP%3E.%E5%AD%90%E4%BE%9B%E5%BA%94%E5%95%86%3D0x14f1%EF%BC%8C%3C%2FP%3E%3CP%3E.%E5%AD%90%E8%AE%BE%E5%A4%87%20%3D%200x0950%EF%BC%8C%3C%2FP%3E%3CP%3E%7D%2C%20%3C%2FP%3E%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5id%E6%98%AF%E5%AF%B9%E7%9A%84%EF%BC%8C%E4%BD%86%E6%98%AF%E4%BB%8Elog%E4%B8%AD%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ecx25858%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.0.111%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ecx25858%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%20%E6%88%91%E5%9C%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%89%93%E5%8D%B0%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%EF%BC%88%EF%BC%81pci_register_driver%EF%BC%88%26amp%3Bcx25858_pci_driver%EF%BC%89%EF%BC%89%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pci_unregister_driver(%26amp%3Bcx25858_pci_driver)%3B%3C%2FP%3E%3CP%3Eprintk(KERN_INFO%20%22cx25858%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E6%88%90%E5%8A%9F%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20-ENODEV%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3Eprintk(KERN_INFO%20%22cx25858%20%E9%A9%B1%E5%8A%A8%E6%88%90%E5%8A%9F%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E6%B3%A8%E5%86%8C%E9%94%99%E8%AF%AF%EF%BC%8C%E6%82%A8%E8%83%BD%E7%BB%99%E5%87%BA%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%E8%BF%94%E5%9B%9Epci_register_driver(%26amp%3Bcx25858_pci_driver)%3B*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BD%A0%E5%A5%BD%3CBR%20%2F%3E%E7%9C%8B%E6%9D%A5%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8CEP%E8%AE%BE%E5%A4%87%E6%89%80%E9%9C%80%E7%9A%84%E5%86%85%E5%AD%98%E7%A9%BA%E9%97%B4%E5%B7%B2%E7%BB%8F%E7%94%B1%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20RC%E5%88%86%E9%85%8D%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%99%BB%E5%BD%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E2%80%9C%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%20-v%E2%80%9D%E5%91%BD%E4%BB%A4%E8%8E%B7%E5%8F%96%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E8%A6%81%20stdpci%20%E5%B9%B6%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMini%20PCIe%20%E5%88%B0%20STD%20PCIe%20%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%3C%2FSPAN%3E%E6%88%91%E4%BD%BF%E7%94%A8%20Linux%203.0.35_1.1.0_121218%E4%BB%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%B8%8B%E8%BD%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%EF%BC%882013%E5%B9%B49%E6%9C%8817%E6%97%A5%20-%2020%3A02%3A02%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9AFreescale%20i.MX6%E7%B3%BB%E5%88%97TO1.2%EF%BC%8C792MHz%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%EF%BC%9A29%E2%84%83%EF%BC%8C%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE0x5784c37d%3C%2FP%3E%3CP%3EMX6Q%20PLL1%EF%BC%9A792MHz%3C%2FP%3E%3CP%3EMX6Q%20PLL2%EF%BC%9A528MHz%3C%2FP%3E%3CP%3EMX6Q%20PLL3%EF%BC%9A480MHz%3C%2FP%3E%3CP%3EMX6Q%20PLL8%EF%BC%9A50MHz%3C%2FP%3E%3CP%3Eipg%E6%97%B6%E9%92%9F%EF%BC%9A66000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3EUART%E6%97%B6%E9%92%9F%EF%BC%9A80000000Hz%3C%2FP%3E%3CP%3Ecspi%E6%97%B6%E9%92%9F%EF%BC%9A60000000Hz%3C%2FP%3E%3CP%3Eahb%E6%97%B6%E9%92%9F%EF%BC%9A132000000Hz%3C%2FP%3E%3CP%3E%E8%BD%B4%E6%97%B6%E9%92%9F%EF%BC%9A264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%E6%97%B6%E9%92%9F%EF%BC%9A132000000Hz%3C%2FP%3E%3CP%3EDDR%E6%97%B6%E9%92%9F%EF%BC%9A528000000Hz%3C%2FP%3E%3CP%3EUSDHHC1%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3C%2FP%3E%3CP%3EUSDHHC2%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3C%2FP%3E%3CP%3EUSDHC3%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3C%2FP%3E%3CP%3EUSDHC4%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3C%2FP%3E%3CP%3ENFC%E6%97%B6%E9%92%9F%EF%BC%9A24000000Hz%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9Ai.MX6Q-SABRESD%EF%BC%9A%E6%9C%AA%E7%9F%A5%E4%B8%BB%E6%9D%BF%EF%BC%9A0x63012%20%5BPOR%5D%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%E8%AE%BE%E5%A4%87%EF%BC%9AMMC%3C%2FP%3E%3CP%3EI2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A1%20GB%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%2CFSL_USDHC%3A%202%2CFSL_USDHC%3A%203%3C%2FP%3E%3CP%3E%23%23%23%20lcd_enable%20%E5%86%85%E9%83%A8%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3E%E6%89%BE%E5%88%B0%E4%BA%86%20PFUZE100%EF%BC%81%E8%AE%BE%E5%A4%87%20ID%3D10%EF%BC%8Crevid%3D11%3C%2FP%3E%3CP%3E%E7%BD%91%E7%BB%9C%EF%BC%9A%E4%BB%8E%20IIM%20%E8%8E%B7%E5%8F%96%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%20%3C%2FP%3E%3CP%3Emmc3%EF%BC%88%E7%AC%AC%200%20%E9%83%A8%E5%88%86%EF%BC%89%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMC%20%E8%AF%BB%E5%8F%96%EF%BC%9A%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%203%EF%BC%8C%E5%9D%97%E7%BC%96%E5%8F%B7%202048%EF%BC%8C%E8%AE%A1%E6%95%B0%208192...%E8%AF%BB%E5%8F%96%208192%20%E4%B8%AA%E5%9D%97%EF%BC%9AOK%3C%2FP%3E%3CP%3E%23%23%20%E4%BB%8E%2010800000%20%E5%A4%84%E7%9A%84%E6%97%A7%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%E6%98%A0%E5%83%8F%E5%90%8D%E7%A7%B0%EF%BC%9ALinux-3.0.35-2310-gc27cb38%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E7%B1%BB%E5%9E%8B%EF%BC%9AARM%20Linux%20%E5%86%85%E6%A0%B8%E5%9B%BE%E5%83%8F%EF%BC%88%E6%9C%AA%E5%8E%8B%E7%BC%A9%EF%BC%89%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%EF%BC%9A4147924%20%E5%AD%97%E8%8A%82%20%3D%204%20MB%3C%2FP%3E%3CP%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%EF%BC%9A10008000%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8F%A3%E7%82%B9%EF%BC%9A10008000%3C%2FP%3E%3CP%3E%E9%AA%8C%E8%AF%81%E6%A0%A1%E9%AA%8C%E5%92%8C...%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F...%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3EOK%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20%E7%89%88%E6%9C%AC%203.0.35-2310-gc27cb38(lyc%40ubuntu)%20(gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%89%EF%BC%89%2322%20SMP%20PREEMPT%202013%20%E5%B9%B4%2011%20%E6%9C%88%2013%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%2000%3A56%3A32%20PST%3C%2FP%3E%3CP%3ECPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3C%2FP%3E%3CP%3E%E6%9C%BA%E5%99%A8%EF%BC%9AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E%E5%BF%BD%E7%95%A5%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%E6%A0%87%E7%AD%BE%200x54410008%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3C%2FP%3E%3CP%3ECPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3EPERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A227328%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc2%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20ldb%3Dsin0%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-WXGA%2Cif%3DRGB666%3C%2FP%3E%3CP%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EDentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EInode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A640MB%20%2B%20256MB%20%3D%20%E5%85%B1%E8%AE%A1%20896MB%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A896280k%2F896280k%E5%8F%AF%E7%94%A8%EF%BC%8C152296k%E4%BF%9D%E7%95%99%EF%BC%8C0K%20highmem%3C%2FP%3E%3CP%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xc0000000%EF%BC%881024%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E6%96%87%E6%9C%AC%EF%BC%9A0x8003d000-0x80b1309c%EF%BC%8811097%20KB%EF%BC%89%3C%2FP%3E%3CP%3E%E3%80%82%E6%95%B0%E6%8D%AE%EF%BC%9A0x80b14000%20-%200x80b7e0c0%EF%BC%88425%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b7e0e4%20-%200x80bccfec%26nbsp%3B%26nbsp%3B%20(%20316%20kB)%3C%2FP%3E%3CP%3ESLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E7%9A%84%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A496%3C%2FP%3E%3CP%3EMXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3C%2FP%3E%3CP%3Esched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3C%2FP%3E%3CP%3Earm_max_freq%3D2%3C%2FP%3E%3CP%3EMXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x21ec000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc2%5D%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3C%2FP%3E%3CP%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3C%2FP%3E%3CP%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3C%2FP%3E%3CP%3Ehw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3ECPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3C%2FP%3E%3CP%3ESMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%20%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%EF%BC%8C700%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Emx6_sabresd_board_init%20%E5%86%85%E9%83%A8%E8%A1%8C%EF%BC%9A1809%3C%2FP%3E%3CP%3Emx6_sabresd_board_init%20%E5%86%85%E9%83%A8%E8%A1%8C%EF%BC%9A1832%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3El2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3C%2FP%3E%3CP%3Ebio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9ASPKVDD%EF%BC%9A4200%20mV%20%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3ESCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BD%20Freescale%20USB%20OTG%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2C%E5%85%A8%E5%B1%82%3A%201%2C%E9%87%91%E5%B1%9E%E5%B1%82%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%20300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20%E5%9C%A8%205000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20%E8%87%B3%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203300%20mV%20%3C%2FP%3E%3CP%3Ei2c%20i2c-1%EF%BC%9A%E5%A3%B0%E6%98%8E%20irq%2069%3C%2FP%3E%3CP%3Ei2c%20i2c-1%EF%BC%9A%E8%AE%BE%E5%A4%87%E8%B5%84%E6%BA%90%E4%BB%8E0x21a4000%E5%88%B00x21a4fff%3C%2FP%3E%3CP%3Ei2c%20i2c-1%EF%BC%9A%E5%9C%A80x21a4000%E5%A4%84%E5%88%86%E9%85%8D%E4%BA%864096%E5%AD%97%E8%8A%82%20%3C%2FP%3E%3CP%3Ei2c%20i2c-1%EF%BC%9A%E9%80%82%E9%85%8D%E5%99%A8%E5%90%8D%E7%A7%B0%EF%BC%9A%E2%80%9Cimx-i2c%E2%80%9D%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20IMX%20I2C%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Ei2c%20i2c-2%EF%BC%9A%E5%A3%B0%E6%98%8E%20irq%2070%3C%2FP%3E%3CP%3Ei2c%20i2c-2%EF%BC%9A%E8%AE%BE%E5%A4%87%E8%B5%84%E6%BA%90%E4%BB%8E0x21a8000%E5%88%B00x21a8fff%3C%2FP%3E%3CP%3Ei2c%20i2c-2%EF%BC%9A%E5%9C%A80x21a8000%E5%A4%84%E5%88%86%E9%85%8D%E4%BA%864096%E5%AD%97%E8%8A%82%20%3C%2FP%3E%3CP%3Ei2c%20i2c-2%EF%BC%9A%E9%80%82%E9%85%8D%E5%99%A8%E5%90%8D%E7%A7%B0%EF%BC%9A%E2%80%9Cimx-i2c%E2%80%9D%3C%2FP%3E%3CP%3Ei2c%20i2c-2%EF%BC%9AIMX%20I2C%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%20i.MX%20MIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%E7%89%88%E6%9C%AC%E4%B8%BA0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0.24%E3%80%82%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.16%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F31%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Ecfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmax17135%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3C%2FP%3E%3CP%3EIP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3EPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3Ei.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EIMX%20PCIe%20%E7%AB%AF%E5%8F%A3%EF%BC%9A%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%EF%BC%9Abus0%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%EF%BC%9A%E6%80%BB%E7%BA%BF1%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3ABAR%2014%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5B%E5%86%85%E5%AD%98%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01100000-0x011fffff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1100000-0x11fffff%5D%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3ABAR%206%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01400000-0x0140ffff%20pref%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01200000-0x013fffff%2064%E4%BD%8D%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01200000-0x013fffff%2064bit%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1200000-0x13fffff%5D%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3APCI%20%E6%A1%A5%E6%8E%A5%E8%87%B3%20%5B%E6%80%BB%E7%BA%BF%2001-01%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bio%20%E5%B7%B2%E7%A6%81%E7%94%A8%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bmem%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%20%5B%E5%86%85%E5%AD%98%E9%A6%96%E9%80%89%E9%A1%B9%E5%B7%B2%E7%A6%81%E7%94%A8%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3ECPU%E8%B0%83%E8%8A%82%E5%99%A8%E5%88%9D%E5%A7%8B%E5%8C%96ldo%3D1%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96pu%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FP%3E%3CP%3EJFFS2%20%E7%89%88%E6%9C%AC%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20%E7%BA%A2%E5%B8%BD%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3Emsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201750%3C%2FP%3E%3CP%3Ealg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%E7%9A%84%20i.MX%20MIPI%20DSI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3Aldb_clk%20%E5%88%B0%20di%20clk%3Aldb_di0_clk%20-%26gt%3B%20ipu1_di0_clk%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%8D%95%E6%A8%A1%E5%BC%8F%E9%80%9A%E9%81%930%E8%B7%AF%E7%94%B1%E8%87%B3IPU0-DI0%3C%2FP%3E%3CP%3Eldb_disp_setup%20%E5%86%85%E9%83%A8%E7%9A%84pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%23%23%23%20fb_%E7%A9%BA%E7%99%BD%E8%A1%8C%EF%BC%9A1039%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E7%A9%BA%E7%99%BD%20%3D%200%3C%2FP%3E%3CP%3Eldb_disp_setup%20%E5%86%85%E9%83%A8%E7%9A%84pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E8%AE%BE%E5%A4%87%20170x48%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9Amxcfb_pan_display%20%E8%A1%8C%EF%BC%9A1399%3C%2FP%3E%3CP%3E%23%23%23%20%E8%B0%83%E7%94%A8%20fb_pan_display%20%E9%94%99%E8%AF%AF%3A-22%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Flcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9Aipu0-di0%20%E5%B7%B2%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%AD%3C%2FP%3E%3CP%3Emxc_sdc_fb%EF%BC%9Amxc_sdc_fb.2%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-16%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EIMX-UART.2%EF%BC%9Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21ec000%20(irq%20%3D%2060)%20%E6%98%AF%E4%B8%80%E4%B8%AA%20IMX%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc2%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc2%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E4%BB%8E%20RESET%20HBA%20%E4%B8%AD%E6%81%A2%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%20SATA%20%E7%A3%81%E7%9B%98%E3%80%82%3C%2FP%3E%3CP%3Em25p80%20spi0.0%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%20JEDEC%20id%20206a56%3C%2FP%3E%3CP%3EGPMI%20NAND%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%EF%BC%88IMX%EF%BC%89%3C%2FP%3E%3CP%3Evcan%EF%BC%9A%E8%99%9A%E6%8B%9F%20CAN%20%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3CP%3Eflexcan%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EFEC%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Efec_enet_mii_bus%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E7%AD%89%E5%BE%85otg%20vbus%E6%94%B9%E5%8F%98%E8%B6%85%E6%97%B6%EF%BC%81%20%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3C%2FP%3E%3CP%3E%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E8%AE%BE%E5%A4%87%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%882005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5%EF%BC%89%3C%2FP%3E%3CP%3Emousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84%20PS%2F2%20%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9Artc%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B0%86%20snvs_rtc%20%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Elirc_dev%3A%20%E7%BA%A2%E5%A4%96%E9%81%A5%E6%8E%A7%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E4%B8%BB%E8%A6%81%20252%20%3C%2FP%3E%3CP%3EIR%20NEC%20%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20RC5(x)%20%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20RC6%20%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20JVC%20%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20Sony%20%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20RC5%EF%BC%88streamzap%EF%BC%89%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3EIR%20LIRC%E6%A1%A5%E6%8E%A5%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3ELinux%E8%A7%86%E9%A2%91%E9%87%87%E9%9B%86%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3C%2FP%3E%3CP%3E%E5%9C%A8%20MVC%20%E4%B8%AD%EF%BC%9Ainit_camera_struct%3C%2FP%3E%3CP%3E%E5%9C%A8%20MVC%20%E4%B8%AD%EF%BC%9Ainit_camera_struct%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20prp_enc_init%20%E5%86%85%E9%83%A8%E8%A1%8C%EF%BC%9A584%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20Inside%20csi_enc_init%20line%3A423%3C%2FP%3E%3CP%3E%E5%9C%A8%20adv7180_init%20%E4%B8%AD%3C%2FP%3E%3CP%3EDBG%20%E4%BC%A0%E6%84%9F%E5%99%A8%E6%95%B0%E6%8D%AE%E4%BD%8D%E4%BA%8E%2080b9f718%3C%2FP%3E%3CP%3E%E5%9C%A8%20adv7180_probe%20%E4%B8%AD%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A564%3C%2FP%3E%3CP%3Emx6q_csi0_io_init_adv7441%20%E8%A1%8C%E5%86%85%EF%BC%9A577%20init%20high%3C%2FP%3E%3CP%3Emx6q_csi0_io_init_adv7441%20%E8%A1%8C%E5%86%85%EF%BC%9A581%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%8E%3C%2FP%3E%3CP%3Emx6q_csi0_io_init_adv7441%20%E8%A1%8C%E5%86%85%EF%BC%9A588%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%AB%98%3C%2FP%3E%3CP%3Emx6q_csi0_cam_powerdown_adv7441%20%E5%86%85%E9%83%A8%E8%A1%8C%EF%BC%9A559%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180_probe%3Aadv7180%20%E6%8E%A2%E6%B5%8B%E5%99%A8%20i2c%20%E5%9C%B0%E5%9D%80%E4%B8%BA%200x21%3C%2FP%3E%3CP%3Eadv7441a%201-0021%EF%BC%9Aadv7180_probe%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E6%A8%A1%E6%8B%9F%E8%AE%BE%E5%A4%87%20adv7%2000%EF%BC%81%3C%2FP%3E%3CP%3Eadv7441a%201-0021%EF%BC%9A%E5%9C%A8%20adv7180%3Aadv7180_hard_reset%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x0%20val%3A0xe%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x3%20%E5%80%BC%EF%BC%9A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x4%20%E5%80%BC%EF%BC%9A0x47%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x5%20%E5%80%BC%EF%BC%9A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x3c%20val%EF%BC%9A0xad%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x17%20%E5%80%BC%EF%BC%9A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x67%20%E5%80%BC%EF%BC%9A0x2%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x68%20val%EF%BC%9A0xf0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x1d%20%E5%80%BC%EF%BC%9A0x40%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E6%B3%A8%E5%86%8C%E5%8F%B7%EF%BC%9A0x31%20%E5%80%BC%EF%BC%9A0x1a%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x32%20%E5%80%BC%EF%BC%9A0x81%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x33%20%E5%80%BC%EF%BC%9A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x34%20%E5%80%BC%EF%BC%9A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x35%20%E5%80%BC%EF%BC%9A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x36%20val%EF%BC%9A0x7d%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x37%20val%EF%BC%9A0xa1%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x3a%20val%EF%BC%9A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E6%B3%A8%E5%86%8C%E5%8F%B7%EF%BC%9A0x3c%20%E5%80%BC%EF%BC%9A0xa8%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E6%B3%A8%E5%86%8C%E5%8F%B7%EF%BC%9A0x47%20%E5%80%BC%EF%BC%9A0xa%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xba%20val%3A0xa0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0xf3%20val%EF%BC%9A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0x69%20%E5%80%BC%EF%BC%9A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe8%20val%3A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe9%20val%3A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%EF%BC%9A0xea%20val%EF%BC%9A0x6%3C%2FP%3E%3CP%3E%E7%B1%BB%E5%9E%8B%E4%B8%BA%202%EF%BC%88%E9%A2%84%E6%9C%9F%E4%B8%BA%202%EF%BC%89%3C%2FP%3E%3CP%3Enum%20ioctls%20%E4%B8%BA%2011%3C%2FP%3E%3CP%3Eadv7441a%201-0021%EF%BC%9Aadv7180%EF%BC%9Aioctl_s_power%3C%2FP%3E%3CP%3Eadv7441a%201-0021%EF%BC%9Aadv7180%EF%BC%9Aioctl_g_fmt_cap%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%E5%B0%BA%E5%AF%B8%20720x625%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E7%BB%93%E6%9D%9F%EF%BC%9A%E8%AE%BE%E5%A4%87%E7%B1%BB%E5%9E%8B1%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%20%E7%BB%93%E6%9D%9F%EF%BC%9Av2f%20pix%20%E5%AE%BD%E5%BA%A6%20x%20%E9%AB%98%E5%BA%A6%20288%20x%20352%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%20%E7%BB%93%E6%9D%9F%EF%BC%9Acrop_bounds%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%20%E7%BB%93%E6%9D%9F%EF%BC%9Acrop_defrect%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%20%E7%BB%93%E6%9D%9F%EF%BC%9Acrop_current%20widthxheight%20720%20x%20625%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video17%3C%2FP%3E%3CP%3Egspca%3A%20v2.13.0%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Ecx25858%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.0.111%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Ecx25858%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20uvcvideo%3C%2FP%3E%3CP%3EUSB%20%E8%A7%86%E9%A2%91%E7%B1%BB%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(v1.1.0)%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E8%99%9A%E6%8B%9F%20HCI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.2%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E9%80%9A%E7%94%A8%E8%93%9D%E7%89%99%20USB%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.3%EF%BC%9A%E6%94%AF%E6%8C%81_8%E4%BD%8D%EF%BC%9A1%3C%2FP%3E%3CP%3Emmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.3%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.1%EF%BC%9A%E6%94%AF%E6%8C%81_8%E4%BD%8D%EF%BC%9A1%3C%2FP%3E%3CP%3Emmc1%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.1%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.2%EF%BC%9A%E6%94%AF%E6%8C%81_8%E4%BD%8D%EF%BC%9A1%3C%2FP%3E%3CP%3Emmc2%3A%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5Bsdhci-esdhc-imx.2%5D%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%EF%BC%9A%E6%8E%A2%E6%B5%8Bi.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%88VDOA%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EVPU%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Emxc_asrc%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x5784c37d%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3C%2FP%3E%3CP%3Eusbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%EF%BC%9AMXC%20HDMI%20%E9%9F%B3%E9%A2%91%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%3A%20imx-hdmi-soc-dai.0%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA-12%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A3%B0%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3Emmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E5%8D%A1%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20%E5%88%86%E5%8C%BA%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%EF%BC%9Ammc0%EF%BC%9A0001%20SEM08G%20%E5%88%86%E5%8C%BA%202%202.00%20MiB%3C%2FP%3E%3CP%3ETCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3C%2FP%3E%3CP%3ECAN%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E6%A0%B8%E5%BF%83%EF%BC%88rev%2020090105%20abi%208%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2029%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%EF%BC%89%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%20t%EF%BC%89%3C%2FP%3E%3CP%3E%20mmcblk0boot1%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%20mmcblk0boot0%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E7%95%8C%E9%9D%A2%E6%A8%A1%E6%8B%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3Elib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3C%2FP%3E%3CP%3EVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN6%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN3%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN2%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN1%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20SPKVDD%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01%2008%3A04%3A21%20UTC%20(29061)%3C%2FP%3E%3CP%3EEXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%AE%89%E8%A3%85%E6%9C%AA%E7%BB%8F%E6%A3%80%E6%9F%A5%E7%9A%84%20fs%EF%BC%8C%E5%BB%BA%E8%AE%AE%E8%BF%90%E8%A1%8C%20e2fsck%3C%2FP%3E%3CP%3EVFS%3A%20%E5%9C%A8%E8%AE%BE%E5%A4%87%20179%3A1%20%E4%B8%8A%E6%8C%82%E8%BD%BD%E6%A0%B9%20(ext2%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F)%E3%80%82%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E5%88%9D%E5%A7%8B%E5%86%85%E5%AD%98%EF%BC%9A212K%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%201440%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%20%2Fproc%20%E5%92%8C%20%2Fsys%20%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20udevd%3C%2FP%3E%3CP%3Eudevd%EF%BC%881449%EF%BC%89%EF%BC%9A%2Fproc%2F1449%2Foom_adj%20%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E6%94%B9%E7%94%A8%2Fproc%2F1449%2Foom_score_adj%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%88%E6%88%90%E5%88%9D%E5%A7%8B%E7%83%AD%E6%8F%92%E6%8B%94%E4%BA%8B%E4%BB%B6%3C%2FP%3E%3CP%3Emmc2%EF%BC%9A%E5%9C%B0%E5%9D%80%201234%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20SDHC%20%E5%8D%A1%3C%2FP%3E%3CP%3Emmcblk1%3A%20mmc2%3A1234%20SA08G%207.28%20GiB%20%3C%2FP%3E%3CP%3E%20mmcblk1%3A%20p1%3C%2FP%3E%3CP%3E%E5%B0%86%E4%B8%BB%E6%9C%BA%E5%90%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%20freescale%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9AEXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84%20inode%EF%BC%9A234449%3C%2FP%3E%3CP%3E%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87EXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84inode%EF%BC%9A234449%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%20EXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84%20inode%EF%BC%9A234449%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Ecp%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3Eln%EF%BC%9A%2Fetc%2Fmtab%EF%BC%9A%E8%BE%93%E5%85%A5%2F%E8%BE%93%E5%87%BA%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3Emount%EF%BC%9A%E5%9C%A8%20%2Fproc%2Fbus%2Fusb%20%E4%B8%8A%E5%AE%89%E8%A3%85%20usbfs%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%E7%AB%AF%E5%8F%A3%E6%98%A0%E5%B0%84%E5%99%A8%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20boa%20%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E9%87%8D%E5%BB%BA%20rpm%20%E6%95%B0%E6%8D%AE%E5%BA%93%3C%2FP%3E%3CP%3Erpmdb%EF%BC%9A%E5%86%99%E5%85%A5%EF%BC%9A0x7e977654%2C8192%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Adb4%20%E9%94%99%E8%AF%AF%EF%BC%8828%EF%BC%89%E6%9D%A5%E8%87%AA%20dbenv-%26gt%3Bopen%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%B2%A1%E6%9C%89%E5%89%A9%E4%BD%99%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%8C%85%E7%B4%A2%E5%BC%95%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%202772%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3EEXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84%20inode%EF%BC%9A363702%3C%2FP%3E%3CP%3EEXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84%20inode%EF%BC%9A363702%3C%2FP%3E%3CP%3EEXT2-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Aext2_lookup%EF%BC%9A%E5%88%A0%E9%99%A4%E4%BA%86%E5%BC%95%E7%94%A8%E7%9A%84%20inode%EF%BC%9A363702%3C%2FP%3E%3CP%3Eln%3A%20%2Fusr%2Flib%2FlibOpenVG.so%3A%E8%BE%93%E5%85%A5%2F%E8%BE%93%E5%87%BA%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20pid%202779%EF%BC%8Ctty''%EF%BC%9A'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%894.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%207%20%E6%9C%88%2028%20%E6%97%A5%EF%BC%88%E6%98%9F%E6%9C%9F%E6%97%A5%EF%BC%8902%3A45%3A43%20%2B0800%3C%2FP%3E%3CP%3EFreescale%20Semiconductor%2C%20Inc.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%99%BB%E5%BD%95%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epcie%20%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%9C%A8%20RC%20%E6%9D%BF%E4%B8%8A%E5%88%9B%E5%BB%BA%E8%B7%AF%E7%BA%BF%E5%A4%8D%E6%9D%82%E9%9B%86%E6%88%90%E7%BB%88%E7%82%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E6%82%A8%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E8%AE%BF%E9%97%AE%20RC%20%E6%9D%BF%E5%86%85%E5%AD%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E9%80%9A%E8%BF%87%E5%B8%A6%E6%9C%89%E8%8A%AF%E7%89%87%EF%BC%88mcs9990%EF%BC%89%E7%9A%84%20pcie%20%E6%89%A9%E5%B1%95%20usb%E3%80%82%E6%9C%89%E4%B8%80%E4%BB%B6%E5%A5%87%E6%80%AA%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8C%E5%A6%82%E6%9E%9C%20pcie%20%E8%AE%BE%E7%BD%AE%E8%89%AF%E5%A5%BD%EF%BC%8C%E9%82%A3%E4%B9%88%E7%B3%BB%E7%BB%9F%E4%BC%9A%E5%9C%A8%E5%A4%A7%E7%BA%A6%2010%20%E7%A7%92%E5%90%8E%E5%81%9C%E6%AD%A2%EF%BC%8C%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E5%B9%B6%E6%98%BE%E7%A4%BA%E2%80%9Cpcie%20link%20up%20failed%E2%80%9D%E3%80%82%E5%A6%82%E6%9E%9C%20pcie%20%E8%AE%BE%E7%BD%AE%E6%88%90%E5%8A%9F%EF%BC%8C%E5%88%99%E8%BF%99%E6%98%AF%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%88%9D%E5%A7%8B%E5%8C%96%20cgroup%20%E5%AD%90%E7%B3%BB%E7%BB%9F%20cpu%3C%2FP%3E%3CP%3E%5B0.000000%5DLinux%20%E7%89%88%E6%9C%AC%203.0.35-2666-gbdde708(oser%40macbook)%20(gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%3C%2FP%3E%3CP%3E%2F10%2009%3A20)%20)%20%236%20SMP%20Tue%20Sep%2017%2009%3A04%3A37%20CEST%202013%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c5387d%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%9C%BA%E5%99%A8%EF%BC%9ADynsense%20DS7109%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3C%2FP%3E%3CP%3E%5B0.000000%5DCPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3E%5B0.000000%5DPERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%40cc006000%20s5728%20r8192%20d14752%20u32768%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A260096%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk0p3%20rootwait%20rw%3C%2FP%3E%3CP%3E%5B0.000000%5DPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5DDentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5DInode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%EF%BC%9A1024MB%20%3D%20%E5%85%B11024MB%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%86%85%E5%AD%98%EF%BC%9A1033972k%2F1033972k%E5%8F%AF%E7%94%A8%EF%BC%8C14604k%E4%BF%9D%E7%95%99%EF%BC%8C360448K%E9%AB%98%E5%86%85%E5%AD%98%3C%2FP%3E%3CP%3E%5B0.000000%5D%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B0.000000%5DDMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xea800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20120%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200xc0000000%20-%200xea000000%26nbsp%3B%26nbsp%3B%20(%20672%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200xbfe00000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200xbf000000%20-%200xbfe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200xc0008000%20-%200xc0033000%26nbsp%3B%26nbsp%3B%20(%20172%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200xc0033000%20-%200xc04ce188%26nbsp%3B%26nbsp%3B%20(4717%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200xc04d0000%20-%200xc05149e0%26nbsp%3B%26nbsp%3B%20(%20275%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200xc0514a04%20-%200xc05570a8%26nbsp%3B%26nbsp%3B%20(%20266%20kB)%3C%2FP%3E%3CP%3E%5B0.000000%5DSLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B0.000000%5DMXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3C%2FP%3E%3CP%3E%5B0.000000%5Dsched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B0.000000%5DMXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x21f0000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.000000%5D%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc3%5D%3C%2FP%3E%3CP%3E%5B0.000000%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3C%2FP%3E%3CP%3E%5B0.217079%5D%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.305391%5Dpid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3C%2FP%3E%3CP%3E%5B0.310317%5D%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3C%2FP%3E%3CP%3E%5B0.315667%5DCPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.320824%5Dhw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.330207%5DCPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.361619%5DCPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.401646%5DCPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.440862%5D%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3C%2FP%3E%3CP%3E%5B0.456684%5DSMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%5B0.463648%5Ddevtmpfs%3A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.485974%5D%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%20%3C%2FP%3E%3CP%3E%5B0.489947%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3C%2FP%3E%3CP%3E%5B0.498839%5Dprint_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.506463%5Dprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.514251%5Dprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.521978%5Dprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.529772%5Dprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.537479%5Dprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3E%5B0.549656%5Dhw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%5B0.556488%5Dhw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%5B0.563843%5Dhw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%5B0.569727%5D%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.573764%5Dl2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3C%2FP%3E%3CP%3E%5B0.583862%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B0.587238%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B0.599086%5Dbio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B0.606129%5Dmxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.610956%5D%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%20%3C%2FP%3E%3CP%3E%5B0.616092%5DSCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B0.620426%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3C%2FP%3E%3CP%3E%5B0.626188%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B0.631680%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3C%2FP%3E%3CP%3E%5B0.638581%5D%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3C%2FP%3E%3CP%3E%5B0.643177%5Dcfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3C%2FP%3E%3CP%3E%5B0.657854%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3C%2FP%3E%3CP%3E%5B0.662438%5DIP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.670374%5DTCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.679660%5DTCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.687383%5DTCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.694025%5DTCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B0.697184%5DUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.703180%5DUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.710009%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3E%5B0.714674%5DRPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B0.720613%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%20%3C%2FP%3E%3CP%3E%5B0.725342%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B0.730061%5DRPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%5B0.737627%5DPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%5B0.742741%5D%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3E%5B0.747994%5Di.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.752315%5D%20cpaddr%20%3D%20ea880000%20suspend_iram_base%3Dea828000%3C%2FP%3E%3CP%3E%5B0.757735%5DPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761300%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B0.873230%5DPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%5B0.896452%5DIMX%20PCIe%20%E7%AB%AF%E5%8F%A3%EF%BC%9A%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%5B0.900472%5DPCI%EF%BC%9Abus0%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3E%5B0.923438%5DPCI%EF%BC%9A%E6%80%BB%E7%BA%BF1%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3E%5B0.931153%5DPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01000000-0x010fffff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FP%3E%3CP%3E%5B0.938948%5DPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1000000-0x10fffff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.949687%5DPCI%200000%3A00%3A00.0%3ABAR%208%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5B%E5%86%85%E5%AD%98%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B0.956506%5DPCI%200000%3A00%3A00.0%3ABAR%206%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FP%3E%3CP%3E%5B0.963769%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01100000-0x01100fff%5D%3C%2FP%3E%3CP%3E%5B0.970587%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01100000-0x01100fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1100000-0x1100fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.980365%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01101000-0x01101fff%5D%3C%2FP%3E%3CP%3E%5B0.987190%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01101000-0x01101fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1101000-0x1101fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B0.996968%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.2%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01102000-0x01102fff%5D%3C%2FP%3E%3CP%3E%5B1.003804%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.2%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01102000-0x01102fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1102000-0x1102fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.013582%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01103000-0x01103fff%5D%3C%2FP%3E%3CP%3E%5B1.020399%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01103000-0x01103fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1103000-0x1103fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.030177%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.4%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01104000-0x01104fff%5D%3C%2FP%3E%3CP%3E%5B1.037001%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.4%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01104000-0x01104fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1104000-0x1104fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.046779%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01105000-0x01105fff%5D%3C%2FP%3E%3CP%3E%5B1.053603%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01105000-0x01105fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1105000-0x1105fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.063380%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.6%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01106000-0x01106fff%5D%3C%2FP%3E%3CP%3E%5B1.070198%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.6%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01106000-0x01106fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1106000-0x1106fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.079976%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01107000-0x01107fff%5D%3C%2FP%3E%3CP%3E%5B1.086799%5DPCI%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01107000-0x01107fff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1107000-0x1107fff%5D%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.096577%5DPCI%200000%3A00%3A00.0%3APCI%20%E6%A1%A5%E6%8E%A5%E8%87%B3%20%5B%E6%80%BB%E7%BA%BF%2001-01%5D%3C%2FP%3E%3CP%3E%5B1.101819%5DPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bio%20%E5%B7%B2%E7%A6%81%E7%94%A8%5D%3C%2FP%3E%3CP%3E%5B1.107509%5DPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bmem%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B1.114327%5DPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%20%5B%E5%86%85%E5%AD%98%E9%A6%96%E9%80%89%E9%A1%B9%E5%B7%B2%E7%A6%81%E7%94%A8%5D%3C%2FP%3E%3CP%3E%5B1.120837%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B1.124593%5DIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%5B1.128126%5DCPU%E8%B0%83%E8%8A%82%E5%99%A8%E6%A8%A1%E5%BC%8F%EF%BC%9Aldo_enable%3C%2FP%3E%3CP%3E%5B1.132342%5Di.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.151254%5Dhighmem%20%E5%8F%8D%E5%BC%B9%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A64%20%E9%A1%B5%3C%2FP%3E%3CP%3E%5B1.169381%5Dmsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201315%20%3C%2FP%3E%3CP%3E%5B1.174837%5Dalg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E%5B1.179101%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B1.183040%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B1.187408%5Dio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.192486%5DIMX-PCIe%3A%20MSI%200x3f00%20%400x0%3A0x1ff8000%EF%BC%8Cirq%20%3D%20496%3C%2FP%3E%3CP%3E%5B1.199230%5Dimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3C%2FP%3E%3CP%3E%5B1.208696%5Dimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%5B1.350226%5D%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B1.353438%5DIMX-UART.3%EF%BC%9Attymxc3%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21f0000%20(irq%20%3D%2061)%20%E5%A4%84%EF%BC%8C%E6%98%AF%20IMX%3C%2FP%3E%3CP%3E%5B1.359919%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc3%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%5B1.359919%5D%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc3%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%5B1.376725%5D%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B1.381551%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fasix%3C%2FP%3E%3CP%3E%5B1.387076%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fcdc_ether%3C%2FP%3E%3CP%3E%5B1.393037%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20smsc75xx%3C%2FP%3E%3CP%3E%5B1.398920%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20smsc95xx%3C%2FP%3E%3CP%3E%5B1.404788%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fnet1080%3C%2FP%3E%3CP%3E%5B1.410575%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Frndis_host%3C%2FP%3E%3CP%3E%5B1.416620%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fcdc_subset%3C%2FP%3E%3CP%3E%5B1.422669%5Dusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fzaurus%3C%2FP%3E%3CP%3E%5B1.428266%5Dcdc_ncm%EF%BC%9A2011%E5%B9%B48%E6%9C%884%E6%97%A5%3C%2FP%3E%3CP%3E%5B1.431611%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fcdc_ncm%3C%2FP%3E%3CP%3E%5B1.437410%5Dusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20rndis_wlan%3C%2FP%3E%3CP%3E%5B1.443872%5Dehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B1.450527%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2073%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.454227%5D%20fsl-ehci%20fsl-ehci.2%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B1.461279%5Dfsl-ehci%20fsl-ehci.2%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.493211%5D%20fsl-ehci%20fsl-ehci.2%3A%20irq%2073%2C%20io%20base%200x02184400%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.513186%5D%20fsl-ehci%20fsl-ehci.2%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B1.518851%5Dusb%20usb1%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B1.525654%5Dusb%20usb1%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B1.532881%5Dusb%20usb1%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.539331%5Dusb%20usb1%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.545955%5D%20usb%20usb1%3A%20SerialNumber%3A%20fsl-ehci.2%3C%2FP%3E%3CP%3E%5B1.551056%5D%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.554824%5D%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B1.559261%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2074%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.562943%5D%20fsl-ehci%20fsl-ehci.3%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B1.569893%5Dfsl-ehci%20fsl-ehci.3%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.603198%5D%20fsl-ehci%20fsl-ehci.3%3A%20irq%2074%2C%20io%20base%200x02184600%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.623181%5D%20fsl-ehci%20fsl-ehci.3%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B1.628832%5Dusb%20usb2%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%20%3C%2FP%3E%3CP%3E%5B1.635632%5Dusb%20usb2%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B1.642858%5Dusb%20usb2%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.649306%5Dusb%20usb2%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.655934%5D%20usb%20usb2%3A%20SerialNumber%3A%20fsl-ehci.3%3C%2FP%3E%3CP%3E%5B1.660988%5D%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.664755%5D%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B1.669192%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.677670%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B1.684575%5Dfsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%203%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.713200%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.733180%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B1.738830%5Dusb%20usb3%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B1.745631%5Dusb%20usb3%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B1.752859%5Dusb%20usb3%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.759307%5Dusb%20usb3%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.765934%5D%20usb%20usb3%3A%20SerialNumber%3A%20fsl-ehci.0%3C%2FP%3E%3CP%3E%5B1.770988%5D%E9%9B%86%E7%BA%BF%E5%99%A8%203-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.774755%5D%E9%9B%86%E7%BA%BF%E5%99%A8%203-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B1.779164%5D%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.782865%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B1.789777%5Dfsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.823201%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.843185%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B1.848835%5Dusb%20usb4%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B1.855637%5Dusb%20usb4%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B1.862863%5Dusb%20usb4%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8A%20EHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.869312%5Dusb%20usb4%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.875940%5D%20usb%20usb4%3A%20SerialNumber%3A%20fsl-ehci.1%3C%2FP%3E%3CP%3E%5B1.880997%5D%E6%9E%A2%E7%BA%BD%204-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.884765%5D%E9%9B%86%E7%BA%BF%E5%99%A8%204-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B1.889282%5DPCI%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%880140%20-%26gt%3B%200142%EF%BC%89%3C%2FP%3E%3CP%3E%5B1.894989%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.900490%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%205%3C%2FP%3E%3CP%3E%5B1.908034%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9A%E5%BA%94%E7%94%A8%20MosChip%20%E5%B8%A7%E7%B4%A2%E5%BC%95%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.943222%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20irq%20155%2C%20io%20mem%200x01101000%3C%2FP%3E%3CP%3E%5B1.963182%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.1%EF%BC%9AUSB%202.0%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3C%2FP%3E%3CP%3E%5B1.969010%5Dusb%20usb5%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B1.975816%5Dusb%20usb5%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B1.983043%5Dusb%20usb5%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.987930%5Dusb%20usb5%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B1.994553%5Dusb%20usb5%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A0000%EF%BC%9A01%EF%BC%9A00.1%3C%2FP%3E%3CP%3E%5B1.999488%5D%2B%2B%2B%20hub_port_connect_change%EF%BC%9Audev-%26gt%3B%E7%BA%A7%E5%88%AB%EF%BC%9A1%20%3C%2FP%3E%3CP%3E%5B1.999747%5D%E4%B8%AD%E5%BF%83%205-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B1.999759%5D%E9%9B%86%E7%BA%BF%E5%99%A8%205-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B2.000187%5DPCI%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%880140%20-%26gt%3B%200142%EF%BC%89%3C%2FP%3E%3CP%3E%5B2.000214%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.000509%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%206%3C%2FP%3E%3CP%3E%5B2.000737%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9A%E5%BA%94%E7%94%A8%20MosChip%20%E5%B8%A7%E7%B4%A2%E5%BC%95%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.023241%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20irq%20154%2C%20io%20mem%200x01103000%3C%2FP%3E%3CP%3E%5B2.043189%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.3%EF%BC%9AUSB%202.0%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3C%2FP%3E%3CP%3E%5B2.043272%5Dusb%20usb6%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B2.043280%5Dusb%20usb6%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B2.043287%5Dusb%20usb6%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.043293%5Dusb%20usb6%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B2.043300%5Dusb%20usb6%EF%BC%9A%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A0000%EF%BC%9A01%EF%BC%9A00.3%3C%2FP%3E%3CP%3E%5B2.043862%5D%E8%BD%AE%E6%AF%82%206-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.043875%5D%E9%9B%86%E7%BA%BF%E5%99%A8%206-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B2.044307%5DPCI%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%880140%20-%26gt%3B%200142%EF%BC%89%3C%2FP%3E%3CP%3E%5B2.044334%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.044597%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA%207%3C%2FP%3E%3CP%3E%5B2.044811%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9A%E5%BA%94%E7%94%A8%20MosChip%20%E5%B8%A7%E7%B4%A2%E5%BC%95%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.113240%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20irq%20153%2C%20io%20mem%200x01105000%3C%2FP%3E%3CP%3E%5B2.223212%5Dusb%203-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%202%3C%2FP%3E%3CP%3E%5B2.243203%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.5%EF%BC%9AUSB%202.0%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3C%2FP%3E%3CP%3E%5B2.249029%5Dusb%20usb7%EF%BC%9A%E5%8F%91%E7%8E%B0%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8CidVendor%3D1d6b%EF%BC%8CidProduct%3D0002%3C%2FP%3E%3CP%3E%5B2.255832%5Dusb%20usb7%EF%BC%9A%E6%96%B0%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%9AMfr%3D3%E3%80%81Product%3D2%E3%80%81SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B2.263059%5Dusb%20usb7%EF%BC%9A%E4%BA%A7%E5%93%81%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.267946%5Dusb%20usb7%EF%BC%9A%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B2.274570%5Dusb%20usb7%3A%E5%BA%8F%E5%88%97%E5%8F%B7%3A0000%3A01%3A00.5%3C%2FP%3E%3CP%3E%5B2.279804%5D%E4%B8%AD%E5%BF%83%207-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.283572%5D%E9%9B%86%E7%BA%BF%E5%99%A8%207-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%5B2.287948%5DPCI%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%880140%20-%26gt%3B%200142%EF%BC%89%3C%2FP%3E%3CP%3E%5B2.293641%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9AEHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.299165%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%208%3C%2FP%3E%3CP%3E%5B2.306717%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9A%E5%BA%94%E7%94%A8%20MosChip%20%E5%B8%A7%E7%B4%A2%E5%BC%95%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%5B2.343213%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9A%E8%AF%B7%E6%B1%82%E4%B8%AD%E6%96%AD%20152%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%5B2.349138%5Dehci_hcd%200000%EF%BC%9A01%EF%BC%9A00.7%EF%BC%9AUSB%20%E6%80%BB%E7%BA%BF%208%20%E5%B7%B2%E6%B3%A8%E9%94%80%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.354820%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20init%200000%3A01%3A00.7%20fail%2C%20-22%3C%2FP%3E%3CP%3E%5B2.360665%5Dehci_hcd%EF%BC%9A0000%EF%BC%9A01%EF%BC%9A00.7%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3E%5B2.366899%5DUSB%E5%AF%84%E5%AD%98%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%8C0%3C%2FP%3E%3CP%3E%5B2.370703%5Dusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20arc%20hset%3C%2FP%3E%3CP%3E%5B2.376462%5Dusb%20hset%20init%20%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%5B2.380273%5Dimx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3C%2FP%3E%3CP%3E%5B2.388450%5Dcpuidle%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%B0%83%E9%80%9F%E6%A2%AF%20%3C%2FP%3E%3CP%3E%5B2.392551%5Dcpuidle%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%B0%83%E8%8A%82%E5%99%A8%E8%8F%9C%E5%8D%95%3C%2FP%3E%3CP%3E%5B2.394974%5D%E4%B8%8D%E6%94%AF%E6%8C%81%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%9A%E4%B8%8D%E5%9C%A8%E7%99%BD%E5%90%8D%E5%8D%95%E4%B8%AD%3C%2FP%3E%3CP%3E%5B2.395019%5D%2B%2B%2B%20hub_port_connect_change%EF%BC%9Audev-%26gt%3B%E7%BA%A7%E5%88%AB%EF%BC%9A1%3C%2FP%3E%3CP%3E%5B2.406435%5Dsdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B2.412619%5Dsdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3E%5B2.417084%5Dsdhci%20sdhci-esdhc-imx.1%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E5%86%99%E4%BF%9D%E6%8A%A4%E5%AF%86%E7%A0%81%EF%BC%81%3C%2FP%3E%3CP%3E%5B2.423491%5Dmmc0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20vmmc%20%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.427681%5Dmmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.1%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3E%5B2.434999%5D%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x59c50d69%3C%2FP%3E%3CP%3E%5B2.439791%5D%E6%AF%94%E7%8E%87%20%3D%20186%20%E7%9A%84%E7%83%AD%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3E%5B2.463188%5DAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3C%2FP%3E%3CP%3E%5B2.468495%5Danatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3C%2FP%3E%3CP%3E%5B2.475415%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3C%2FP%3E%3CP%3E%5B2.480355%5DTCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%5B2.483599%5DNET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3C%2FP%3E%3CP%3E%5B2.488055%5Dlib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3C%2FP%3E%3CP%3E%5B2.494497%5DVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3C%2FP%3E%3CP%3E%5B2.502176%5D%E6%94%AF%E6%8C%81%20ThumbEE%20CPU%20%E6%89%A9%E5%B1%95%E3%80%82%3C%2FP%3E%3CP%3E%5B2.506470%5D%E6%B3%A8%E5%86%8C%20SWP%2FSWPB%20%E4%BB%BF%E7%9C%9F%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%5B2.511407%5D%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%5B2.513199%5Dusb%204-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%202%3C%2FP%3E%3CP%3E%5B2.521949%5D%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%5B2.527136%5D%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3E%5B2.532045%5Dregulater_init_complete%3A%20vmmc%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%82%E8%B5%B7%E5%B9%B6%E9%87%8D%E5%90%AF%E5%90%8E%EF%BC%8Cpci%20%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761407%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B0.873253%5DPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%5B1.483143%5D%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%8CDB_R0%EF%BC%9A0xdc998200%EF%BC%8CDB_R1%EF%BC%9A0x0820f700%EF%BC%81%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.489108%5D%20IMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3E%E4%BD%86%E7%8E%B0%E5%9C%A8%E7%B3%BB%E7%BB%9F%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%AE%A4%E4%B8%BA%E6%98%AF%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%E6%88%91%E5%B0%86%E5%AF%B9%20imx6%20%E4%B8%8A%E7%9A%84%20pcie%20%E5%BC%80%E5%85%B3%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BC%9F%E5%A4%A7%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%B8%80%E4%B8%AA%3CSPAN%20class%3D%22SpellE%22%3EPericom%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E4%BA%A4%E6%8D%A2%E6%9C%BA%EF%BC%88PI7C9X2G303EL%EF%BC%89%E5%B7%B2%E5%9C%A8%20imx_3.0.35.4.0%20%E5%92%8C%204.1.0%20%E4%B8%8A%E9%AA%8C%E8%AF%81%E5%8F%91%E5%B8%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%A5%9D%E6%82%A8%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ehi%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%9A%84%E7%94%B5%E6%BA%90%E5%AE%B9%E9%87%8F%E4%B8%8D%E8%B6%B3%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%A3%80%E6%B5%8B%E4%B8%8D%E5%88%B0%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%8E%B0%E5%9C%A8%E8%BF%99%E6%98%AF%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3ECLK%20%E8%AE%BE%E7%BD%AE%EF%BC%8C%E7%94%B1%20OpenEmbed---%3C%2FP%3E%3CP%3ECLK%20%E8%AE%BE%E7%BD%AE%EF%BC%8C%E7%94%B1%20OpenEmbed%20%E6%8F%90%E4%BE%9B%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%200.%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%201.%3C%2FP%3E%3CP%3EPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3EIMX%20PCIe%20%E7%AB%AF%E5%8F%A3%EF%BC%9A%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3EPCI%EF%BC%9Abus0%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3EPCI%EF%BC%9A%E6%80%BB%E7%BA%BF1%EF%BC%9A%E7%A6%81%E7%94%A8%E5%BF%AB%E9%80%9F%E8%83%8C%E9%9D%A0%E8%83%8C%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01100000-0x011fffff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1100000-0x11fffff%5D%EF%BC%89%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%209%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01200000-0x012fffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%206%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01300000-0x0130ffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%207%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bio%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%204%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01200000-0x0120ffff%2064%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%204%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01200000-0x0120ffff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1200000-0x120ffff%5D%EF%BC%89%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%206%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01210000-0x0121ffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bmem%200x01220000-0x01220fff%2064%E4%BD%8D%E5%89%8D%E7%BC%80%5D%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%202%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bmem%200x01220000-0x01220fff%2064bit%20pref%5D%EF%BC%88PCI%20%E5%9C%B0%E5%9D%80%20%5B0x1220000-0x1220fff%5D%EF%BC%89%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%5Bio%200x1000000-0x10000ff%5D%3C%2FP%3E%3CP%3EPCI%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%9ABAR%200%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%5Bio%200x1000000-0x10000ff%5D%EF%BC%88PCI%E5%9C%B0%E5%9D%80%5B0x1000000-0x10000ff%5D%EF%BC%89%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3APCI%20%E6%A1%A5%E6%8E%A5%E8%87%B3%20%5B%E6%80%BB%E7%BA%BF%2001-01%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bio%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5B%E5%86%85%E5%AD%98%E7%A6%81%E7%94%A8%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E6%A1%A5%E6%8E%A5%E7%AA%97%E5%8F%A3%5Bmem%200x01200000-0x012fffff%20pref%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Er8169%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%202.3LK-NAPI%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3EPCI%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%200000%EF%BC%9A01%EF%BC%9A00.0%EF%BC%880140%20-%26gt%3B%200143%EF%BC%89%3C%2FP%3E%3CP%3EIMX-PCIe%3A%20MSI%200x3f01%20%400x0%3A0x1ff8000%EF%BC%8Cirq%20%3D%20497%3C%2FP%3E%3CP%3Er8169%200000%3A01%3A00.0%3A%20eth1%3A%20RTL8168c%2F8111c%20at%200xc09e4000%2C%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%2C%20XID%201c4000c0%20IRQ%20497%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20%E7%B1%BB%E5%88%AB%200604%EF%BC%9A%E8%AE%BE%E5%A4%87%2016c3%3Aabcd%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2001%EF%BC%89%3C%2FP%3E%3CP%3E%E6%A0%87%E5%BF%97%EF%BC%9A%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E3%80%81%E5%BF%AB%E9%80%9F%E8%AE%BE%E5%A4%87%E3%80%81%E5%BB%B6%E8%BF%9F%200%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E4%BD%8D%E4%BA%8E%2001100000%20(64%20%E4%BD%8D%EF%BC%8C%E5%8F%AF%E9%A2%84%E5%8F%96)%20%5B%E5%A4%A7%E5%B0%8F%3D1M%5D%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%EF%BC%9A%E4%B8%BB%3D00%EF%BC%8C%E6%AC%A1%3D01%EF%BC%8C%E4%BB%8E%E5%B1%9E%3D01%EF%BC%8Csec-latency%3D0%3C%2FP%3E%3CP%3E%E6%A1%A5%E5%90%8E%20I%2FO%EF%BC%9A00000000-00000fff%3C%2FP%3E%3CP%3E%E6%A1%A5%E5%90%8E%E5%8F%AF%E9%A2%84%E5%8F%96%E5%86%85%E5%AD%98%EF%BC%9A01200000-012fffff%3C%2FP%3E%3CP%3E%5B%E8%99%9A%E6%8B%9F%5D%20%E6%89%A9%E5%B1%95%20ROM%20%E4%BD%8D%E4%BA%8E%2001300000%20%5B%E5%B7%B2%E7%A6%81%E7%94%A8%5D%20%5B%E5%A4%A7%E5%B0%8F%3D64K%5D%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B40%5D%20%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E7%89%88%E6%9C%AC%203%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B50%5D%20MSI%EF%BC%9A%E5%90%AF%E7%94%A8%2B%E8%AE%A1%E6%95%B0%3D1%2F1%20%E5%8F%AF%E5%B1%8F%E8%94%BD%2B64%E4%BD%8D%2B%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B70%5D%20Express%20%E6%A0%B9%E7%AB%AF%E5%8F%A3%EF%BC%88Slot-%EF%BC%89%EF%BC%8CMSI%2000%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B100%5D%20%E9%AB%98%E7%BA%A7%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B140%5D%20%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%20%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9Apcieport%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E01%EF%BC%9A00.0%20%E7%B1%BB%E5%88%AB%200200%EF%BC%9A%E8%AE%BE%E5%A4%87%2010ec%EF%BC%9A8168%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2002%EF%BC%89%3C%2FP%3E%3CP%3E%E5%AD%90%E7%B3%BB%E7%BB%9F%EF%BC%9A%E8%AE%BE%E5%A4%87%2010ec%3A8168%3C%2FP%3E%3CP%3E%E6%A0%87%E5%BF%97%EF%BC%9A%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%8E%A7%E3%80%81%E5%BF%AB%E9%80%9F%E8%AE%BE%E5%A4%87%E3%80%81%E5%BB%B6%E8%BF%9F%200%E3%80%81IRQ%20497%3C%2FP%3E%3CP%3EI%2FO%20%E7%AB%AF%E5%8F%A3%E6%95%B0%E4%B8%BA%201000000%20%5Bsize%3D256%5D%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E4%BD%8D%E4%BA%8E%2001220000%20(64%20%E4%BD%8D%EF%BC%8C%E5%8F%AF%E9%A2%84%E5%8F%96)%20%5B%E5%A4%A7%E5%B0%8F%3D4K%5D%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E4%BD%8D%E4%BA%8E%2001200000%20(64%20%E4%BD%8D%EF%BC%8C%E5%8F%AF%E9%A2%84%E5%8F%96)%20%5B%E5%A4%A7%E5%B0%8F%3D64K%5D%3C%2FP%3E%3CP%3E%5B%E8%99%9A%E6%8B%9F%5D%20%E6%89%A9%E5%B1%95%20ROM%20%E4%BD%8D%E4%BA%8E%2001210000%20%5B%E5%B7%B2%E7%A6%81%E7%94%A8%5D%20%5B%E5%A4%A7%E5%B0%8F%3D64K%5D%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B40%5D%20%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E7%89%88%E6%9C%AC%203%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B50%5D%20MSI%EF%BC%9A%E5%90%AF%E7%94%A8%2B%E8%AE%A1%E6%95%B0%3D1%2F2%20%E5%8F%AF%E5%B1%8F%E8%94%BD-%2064%20%E4%BD%8D%2B%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B70%5D%20Express%20Endpoint%EF%BC%8CMSI%2001%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5Bb0%5D%20MSI-X%EF%BC%9A%E5%90%AF%E7%94%A8-%E8%AE%A1%E6%95%B0%3D2%E5%B1%8F%E8%94%BD-%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5Bd0%5D%20%E9%87%8D%E8%A6%81%E4%BA%A7%E5%93%81%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B100%5D%20%E9%AB%98%E7%BA%A7%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B140%5D%20%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%20%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%5B160%5D%20%E8%AE%BE%E5%A4%87%E5%BA%8F%E5%88%97%E5%8F%B7%2000-00-00-00-00-00-00-00-00%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9Ar8169%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E7%B1%BB%E5%88%AB%200604%EF%BC%9A%E8%AE%BE%E5%A4%87%2016c3%3Aabcd%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2001%EF%BC%89%3C%2FP%3E%3CP%3E01%EF%BC%9A00.0%20%E7%B1%BB%E5%88%AB%200200%EF%BC%9A%E8%AE%BE%E5%A4%87%2010ec%EF%BC%9A8168%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2002%EF%BC%89%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E9%95%BF%E6%9C%9F%E4%BB%A5%E6%9D%A5%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E4%B8%8D%E6%83%B3%E4%BD%BF%E7%94%A8%20pcie%20%E4%BA%A4%E6%8D%A2%E6%9C%BA%20pex8608%EF%BC%8C%E6%82%A8%E5%81%9A%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%B5%8B%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E%E5%8F%AF%E4%BB%A5%E5%8F%91%E5%90%8D%E7%89%87%E5%88%B0%E6%88%91%E9%82%AE%E7%AE%B1%E5%90%97%EF%BC%9F%E9%82%AE%E5%AF%84BCM5751%E9%9C%80%E8%A6%81%E5%A1%AB%E5%86%99%E4%BD%A0%E7%9A%84%E7%94%B5%E8%AF%9D%E5%8F%B7%E7%A0%81%E3%80%82%E6%88%91%E7%9A%84%E9%82%AE%E7%AE%B1%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aluhao89%40me.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%98%AFluhao89%40me.com%3C%2FA%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%9A%3CBR%20%2F%3E%E4%B8%8A%E6%B5%B7%E5%B8%82%3CSPAN%20class%3D%22SpellE%22%3E%E6%B5%A6%E4%B8%9C%3C%2FSPAN%3E%E6%96%B0%E5%8C%BA%E8%89%AF%E6%B3%BE%E8%B7%AF192%E5%8F%B7A%E6%A0%8B2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%82%AE%E6%94%BF%E7%BC%96%E7%A0%81%20201203%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E6%A0%87%E5%87%86%20PCIE%20EP%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AFimx6%E7%9A%84%E6%9D%BF%E5%AD%90%E6%98%AF%E6%88%91%E4%BB%AC%E8%87%AA%E5%B7%B1%E8%AE%BE%E8%AE%A1%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E4%B8%8D%E9%9C%80%E8%A6%81%E8%BD%AC%E6%8D%A2%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E8%AE%A4%E4%B8%BA%20pcie%20%E6%80%BB%E7%BA%BF%E8%BF%98%E6%B2%A1%E6%9C%89%E5%90%AF%E5%8A%A8%E3%80%82%E4%B8%8E%20PCIE%20NIC%20%E8%AE%BE%E5%A4%87%E6%B2%A1%E6%9C%89%E5%85%B3%E7%B3%BB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%93%A6%EF%BC%8C%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E6%A0%87%E5%87%86%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20%E8%AE%BE%E5%A4%87%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%20STD-%3CSPAN%20class%3D%22SpellE%22%3E%20PCIe%3C%2FSPAN%3E%20EP%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%20mini-%3CSPAN%20class%3D%22SpellE%22%3E%20PCIe%3C%2FSPAN%3E%20%E5%88%B0%20STD-%3CSPAN%20class%3D%22SpellE%22%3E%20PCIe%20%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%BD%AC%E6%8E%A5%E5%8D%A1%E5%AF%B9%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E7%9A%84%E8%B4%A8%E9%87%8F%E5%BD%B1%E5%93%8D%E5%BE%88%E5%A4%A7%EF%BC%8C%E8%AF%B7%E5%A4%A7%E5%AE%B6%E6%B3%A8%E6%84%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E6%8E%A8%E8%8D%90%E7%9A%84%E8%BD%AC%E6%8D%A2%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%3CBR%20%2F%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%87%8C%E9%9D%A2%E6%9C%89%E5%87%A0%E4%B8%AA%20pcie%20nic%EF%BC%8C%E6%AF%94%E5%A6%82%20BCM5751%E3%80%82%E6%88%91%E4%BC%9A%E9%82%AE%E5%AF%84%E7%BB%99%E4%BD%A0%EF%BC%8C%E8%AF%B7%E7%BB%99%E6%88%91%E4%BD%A0%E7%9A%84%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8Epcie%E7%BD%91%E5%8D%A1%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%88%91%E5%9C%A8TI%E7%9A%84DM8168%E4%B8%8A%E5%AE%9E%E7%8E%B0%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%E5%8A%9F%E8%80%97%E5%A4%AA%E9%AB%98%EF%BC%8C%E6%89%80%E4%BB%A5%E6%89%93%E7%AE%97%E6%8D%A2%E6%88%90IMX6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%85%B3%E4%BA%8E%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%8CDB_R0%EF%BC%9A0x00b4f900%EF%BC%8CDB_R1%EF%BC%9A0x08200000%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EIMX%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20port%3A%20link%20down!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E9%93%BE%E8%B7%AF%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%8F%90%E4%BE%9B%E4%BA%86%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20%E8%AE%BE%E5%A4%87%E6%89%80%E9%9C%80%E7%9A%84%E5%BC%BA%E5%88%B6%E6%80%A7%E8%A6%81%E6%B1%82%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%A4%96%E9%83%A8%E7%94%B5%E6%BA%90%E7%AD%89%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E8%83%BD%E5%B0%86%E4%B8%80%E4%B8%AA%E6%82%A8%E4%BD%BF%E7%94%A8%E8%BF%87%E7%9A%84%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20%E5%AF%84%E7%BB%99%E6%88%91%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%84%B6%E5%90%8E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%8E%8B%20Linux...%E5%AE%8C%E6%88%90%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3ELinux%20%E7%89%88%E6%9C%AC%203.0.35-2508-g54750ff(root%40ubuntu)%20(gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%89%EF%BC%89%231%20SMP%20PREEMPT%202013%20%E5%B9%B4%209%20%E6%9C%88%205%20%E6%97%A5%E6%98%9F%E6%9C%9F%E5%9B%9B%2012%3A46%3A34%20CST%3C%2FP%3E%3CP%3ECPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3C%2FP%3E%3CP%3E%E6%9C%BA%E5%99%A8%EF%BC%9AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E%E5%BF%BD%E7%95%A5%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%E6%A0%87%E7%AD%BE%200x54410008%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3C%2FP%3E%3CP%3ECPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3EPERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A227328%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EDentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EInode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A640MB%20%2B%20256MB%20%3D%20%E5%85%B1%E8%AE%A1%20896MB%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A896688k%2F896688k%E5%8F%AF%E7%94%A8%EF%BC%8C151888k%E4%BF%9D%E7%95%99%EF%BC%8C0K%20highmem%3C%2FP%3E%3CP%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xc0000000%EF%BC%881024%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E6%96%87%E6%9C%AC%EF%BC%9A0x8003d000-0x80ab36f8%EF%BC%8810714%20KB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80ab4000%20-%200x80b18300%26nbsp%3B%26nbsp%3B%20(%20401%20kB)%3C%2FP%3E%3CP%3E.bss%EF%BC%9A0x80b18324-0x80b6678c%EF%BC%88314%20KB%EF%BC%89%3C%2FP%3E%3CP%3ESLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E7%9A%84%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3C%2FP%3E%3CP%3Esched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x2020000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc0%5D%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3C%2FP%3E%3CP%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3C%2FP%3E%3CP%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3C%2FP%3E%3CP%3Ehw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3ECPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3C%2FP%3E%3CP%3ESMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%20%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%EF%BC%8C700%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3El2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3C%2FP%3E%3CP%3Ebio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9ASPKVDD%EF%BC%9A4200%20mV%20%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3ESCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BD%20Freescale%20USB%20OTG%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2C%E5%85%A8%E5%B1%82%3A%201%2C%E9%87%91%E5%B1%9E%E5%B1%82%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%20300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20%E5%9C%A8%205000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20%E8%87%B3%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%20i.MX%20MIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%E7%89%88%E6%9C%AC%E4%B8%BA0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0.24%E3%80%82%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.16%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F31%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Ecfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3C%2FP%3E%3CP%3Emax17135%202-0048%EF%BC%9A%E7%94%A8%E4%BA%8E%E7%94%B5%E5%AD%90%E5%A2%A8%E6%B0%B4%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%20PMIC%20MAX17135%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmax17135%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3C%2FP%3E%3CP%3EIP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3EPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3Ei.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%8CDB_R0%EF%BC%9A0x00b4f900%EF%BC%8CDB_R1%EF%BC%9A0x08200000%EF%BC%81%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3ECPU%E8%B0%83%E8%8A%82%E6%A8%A1%E5%BC%8F%EF%BC%9Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96pu%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FP%3E%3CP%3EJFFS2%20%E7%89%88%E6%9C%AC%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20%E7%BA%A2%E5%B8%BD%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3Emsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201751%3C%2FP%3E%3CP%3Ealg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%E7%9A%84%20i.MX%20MIPI%20DSI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%B0%86%20LDB%20%E9%80%9A%E9%81%93%200%20%E7%9A%84%20IPU%20DI1%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20IPU%20DI0%E3%80%82%3C%2FP%3E%3CP%3Efbcvt%EF%BC%9A%E7%BA%B5%E6%A8%AA%E6%AF%94%E4%B8%8D%E7%AC%A6%E5%90%88%20CVT%20%E6%A0%87%E5%87%86%3C%2FP%3E%3CP%3Efbcvt%EF%BC%9A1024x600%4060%EF%BC%9ACVT%20%E5%90%8D%E7%A7%B0%20-%20%E9%9D%9E%20CVT%20%E6%A0%87%E5%87%86%20-%200.614%20%E7%99%BE%E4%B8%87%E5%83%8F%E7%B4%A0%E5%9B%BE%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E8%AE%BE%E5%A4%87%20128x37%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Flcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EIMX-UART.2%EF%BC%9Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21ec000%20(irq%20%3D%2060)%20%E6%98%AF%E4%B8%80%E4%B8%AA%20IMX%3C%2FP%3E%3CP%3EIMX-UART.0%EF%BC%9AMMIO%200x2020000%20(irq%20%3D%2058)%20%E5%A4%84%E7%9A%84%20ttymxc0%20%E6%98%AF%20IMX%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Eahci%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%BA%86%20SSS%20%E6%A0%87%E5%BF%97%EF%BC%8C%E7%A6%81%E7%94%A8%E4%BA%86%E5%B9%B6%E8%A1%8C%E6%80%BB%E7%BA%BF%E6%89%AB%E6%8F%8F%3C%2FP%3E%3CP%3Eahci%20ahci.0%EF%BC%9AAHCI%200001.0300%2032%20%E4%B8%AA%E6%8F%92%E6%A7%BD%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%203%20Gbps%200x1%20impl%20%E5%B9%B3%E5%8F%B0%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_%E5%B9%B3%E5%8F%B0%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3Em25p80%20spi0.0%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%20JEDEC%20id%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%EF%BC%88IMX%EF%BC%89%3C%2FP%3E%3CP%3Evcan%EF%BC%9A%E8%99%9A%E6%8B%9F%20CAN%20%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3CP%3Eflexcan%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EFEC%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Efec_enet_mii_bus%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3C%2FP%3E%3CP%3E%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E8%AE%BE%E5%A4%87%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%882005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5%EF%BC%89%3C%2FP%3E%3CP%3Emousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84%20PS%2F2%20%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9Amax11801_ts%E4%BD%9C%E4%B8%BA%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3Eegalax_ts%EF%BC%9A1-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3Eegalax_ts%EF%BC%9A2-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20link%20up%203.0%20Gbps%20(SStatus%20123%20SControl%20300)%3C%2FP%3E%3CP%3Eata1.00%3A%20ATA-8%3A%20WDC%20WD3200BPVT-00JJ5T0%2C%2001.01A01%2C%20max%20UDMA%2F133%3C%2FP%3E%3CP%3Eata1.00%EF%BC%9A625142448%E6%89%87%E5%8C%BA%EF%BC%8C%E5%A4%9A0%EF%BC%9ALBA48%20NCQ%EF%BC%88%E6%B7%B1%E5%BA%A631%2F32%EF%BC%89%3C%2FP%3E%3CP%3Eata1.00%EF%BC%9A%E9%85%8D%E7%BD%AE%E4%B8%BAUDMA%2F133%3C%2FP%3E%3CP%3Escsi%200%3A0%3A0%3A0%3A%20Direct-Access%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20WDC%20WD3200BPVT-0%2001.0%20PQ%3A%200%20ANSI%3A%205%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20625142448%20512%20%E5%AD%97%E8%8A%82%E9%80%BB%E8%BE%91%E5%9D%97%3A%20(320%20GB%2F298%20GiB)%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%204096%20%E5%AD%97%E8%8A%82%E7%89%A9%E7%90%86%E5%9D%97%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E5%86%99%E4%BF%9D%E6%8A%A4%E5%B7%B2%E5%85%B3%E9%97%AD%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E5%86%99%E5%85%A5%E7%BC%93%E5%AD%98%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E8%AF%BB%E5%8F%96%E7%BC%93%E5%AD%98%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%B8%8D%E6%94%AF%E6%8C%81%20DPO%20%E6%88%96%20FUA%3C%2FP%3E%3CP%3E%20sda%EF%BC%9Asda1%20sda2%20sda3%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E8%BF%9E%E6%8E%A5%E7%9A%84%20SCSI%20%E7%A3%81%E7%9B%98%3C%2FP%3E%3CP%3Eusb%202-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E5%85%A8%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3Eelan-%E8%AF%BB%E5%8F%96%20Hello%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3Eelan-touch%EF%BC%9A2-0010%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9Artc%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B0%86%20snvs_rtc%20%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3ELinux%E8%A7%86%E9%A2%91%E9%87%87%E9%9B%86%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video17%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video18%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video19%3C%2FP%3E%3CP%3E%E6%9E%A2%E7%BA%BD%202-1%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-1%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%EF%BC%9A%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200xfffffffb%E4%B8%8D%E7%AD%89%E4%BA%8E0xc4%EF%BC%81%3C%2FP%3E%3CP%3Emag3110%EF%BC%9A2-000e%20%E6%8E%A2%E5%A4%B4%E6%95%85%E9%9A%9C%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200x1%E4%B8%8D%E7%AD%89%E4%BA%8E0x1a%E6%88%960x2a%EF%BC%81%3C%2FP%3E%3CP%3Emma8451%EF%BC%9A0-001c%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E8%99%9A%E6%8B%9F%20HCI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.2%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E9%80%9A%E7%94%A8%E8%93%9D%E7%89%99%20USB%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Emmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.3%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emmc1%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.1%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emmc2%3A%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5Bsdhci-esdhc-imx.2%5D%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%EF%BC%9A%E6%8E%A2%E6%B5%8Bi.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%88VDOA%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EVPU%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Emxc_asrc%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x5894f069%3C%2FP%3E%3CP%3E%E6%AF%94%E7%8E%87%20%3D%20183%20%E7%9A%84%E7%83%AD%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3C%2FP%3E%3CP%3Eusbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%EF%BC%9AMXC%20HDMI%20%E9%9F%B3%E9%A2%91%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CP%3Emmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E5%8D%A1%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%EF%BC%9Ammc0%EF%BC%9A0001%20SEM04G%20%E5%88%86%E5%8C%BA%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%EF%BC%9Ammc0%EF%BC%9A0001%20SEM04G%20%E5%88%86%E5%8C%BA%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3E%20mmcblk0boot0%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3Eusb%202-1.3%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E4%BD%8E%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%203%3C%2FP%3E%3CP%3Ewm8962%200-001a%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8D%E6%98%AF%20WM8962%EF%BC%8CID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20%E6%97%A0%E6%B3%95%E6%8E%A2%E6%B5%8B%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20wm8962.0-001a%3A-22%3C%2FP%3E%3CP%3Easoc%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%9E%E4%BE%8B%E5%8C%96%E5%8D%A1%20wm8962-audio%EF%BC%9A-22%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20HDMI%20%E9%9F%B3%E9%A2%91%E5%A4%B1%E8%B4%A5%E3%80%82%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%EF%BC%81%3C%2FP%3E%3CP%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A3%B0%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3C%2FP%3E%3CP%3ETCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3C%2FP%3E%3CP%3ECAN%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E6%A0%B8%E5%BF%83%EF%BC%88rev%2020090105%20abi%208%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2029%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%EF%BC%89%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%20t%EF%BC%89%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9AHID%2004b3%3A310d%20%E4%BD%9C%E4%B8%BA%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3E%E9%80%9A%E7%94%A8%20USB%200003%EF%BC%9A04B3%EF%BC%9A310D.0001%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%8Chidraw0%EF%BC%9AUSB%20HID%20v1.11%20%E9%BC%A0%E6%A0%87%20%5BHID%2004b3%3A310d%5D%20%E4%BD%8D%E4%BA%8E%20usb-fsl-ehci.1-1.3%2Finput0%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E7%95%8C%E9%9D%A2%E6%A8%A1%E6%8B%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3Elib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3C%2FP%3E%3CP%3EVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN6%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN3%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN2%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN1%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01%2000%3A00%3A00%20UTC%20(0)%3C%2FP%3E%3CP%3Eusb%202-1.4%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E4%BD%8E%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%204%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%9A%E6%9C%AA%E5%90%AF%E7%94%A8%E5%B1%8F%E9%9A%9C%3C%2FP%3E%3CP%3Ekjournald%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%B7%B2%E8%BE%BE%E5%88%B0%E6%9C%80%E5%A4%A7%E6%8C%82%E8%BD%BD%E6%95%B0%EF%BC%8C%E5%BB%BA%E8%AE%AE%E8%BF%90%E8%A1%8C%20e2fsck%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BB%A5%E5%9B%9E%E5%86%99%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E6%8C%82%E8%BD%BD%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3EVFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%20179%3A1%20%E4%B8%8A%E5%AE%89%E8%A3%85%E6%A0%B9%EF%BC%88ext3%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E5%88%9D%E5%A7%8B%E5%86%85%E5%AD%98%EF%BC%9A212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84uImage%EF%BC%8C%E5%AE%83%E6%B2%A1%E6%9C%89%E6%89%93%E4%BB%BB%E4%BD%95%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%8F%AA%E9%9C%80%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E9%81%B5%E5%BE%AA%E4%BB%A5%E4%B8%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3ECONFIG_IMX_PCIE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E4%BD%86%20pcie%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E5%9C%A8%20lspci%20%E5%91%BD%E4%BB%A4%E4%B9%8B%E5%90%8E%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BE%93%E5%87%BA%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E9%85%8D%E7%BD%AE%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%97%A5%E5%BF%97%E6%80%BB%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3EPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3Ei.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%8CDB_R0%EF%BC%9A0x00ff5100%EF%BC%8CDB_R1%EF%BC%9A0x08200000%EF%BC%81%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20***%20MX6%20Options%3A%20***%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%20%E6%94%AF%E6%8C%81%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20IMX6%20RC%2FEP%E4%BA%92%E8%BF%9E%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84PCI%20Express%20EP%E6%A8%A1%E5%BC%8F%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20IMX6%20RC%2FEP%E4%BA%92%E8%81%94%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84PCI%20Express%20RC%E6%A8%A1%E5%BC%8F%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B*%26gt%3B%20USB%20Host%201%20%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20%E6%B6%88%E6%81%AF%E4%BF%A1%E5%8F%B7%E4%B8%AD%E6%96%AD%EF%BC%88MSI%20%E5%92%8C%20MSI-X%EF%BC%89%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B%20%26gt%3B%20PCI%20Stub%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20PCI%20IOV%20%E6%94%AF%E6%8C%81%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%20%E6%94%AF%E6%8C%81%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20%E6%A0%B9%E7%AB%AF%E5%8F%A3%E9%AB%98%E7%BA%A7%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E6%94%AF%E6%8C%81%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20PCI%20Express%20ECRC%20%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B%20%26gt%3B%20PCIe%20AER%20%E9%94%99%E8%AF%AF%E6%B3%A8%E5%85%A5%E5%99%A8%E6%94%AF%E6%8C%81%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%20ASPM%20%E6%8E%A7%E5%88%B6%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Debug%20PCI%20Express%20ASPM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EHi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E4%BD%A0%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E5%9C%A8%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%E4%BB%85%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E6%9C%AA%E8%AE%BE%E7%BD%AE%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22outline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EBS%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3EHi%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3E%E6%88%91%E6%83%B3%E5%9C%A8IMX6%E4%B8%8A%E9%80%9A%E8%BF%87PCIE%E8%BF%9E%E6%8E%A5%E4%B8%80%E4%B8%AAPCIE%E5%8D%A1%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%3B%20font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20text-decoration%3A%20underline%3B%22%3E%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E6%AF%94%E5%A6%82RTL8111E%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E4%BD%86%E6%98%AF%E6%88%91%E7%9A%84%20imx6%20pcie%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%9A%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E6%97%A5%E5%BF%97%EF%BC%8C%E6%82%A8%E8%BF%99%E8%BE%B9%E6%A0%B9%E6%9C%AC%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%88%91%E8%BF%99%E9%87%8C%E7%B2%98%E8%B4%B4%E7%9A%84%E8%BF%99%E4%B8%AA%E9%AA%8C%E8%AF%81%E7%B3%BB%E7%BB%9F%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%E9%AA%8C%E8%AF%81i.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E6%B5%8B%E8%AF%95i.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%E5%90%9E%E5%90%90%E9%87%8F%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%82%A8%E8%AF%B4%E7%9A%84%E2%80%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E6%88%91%E6%83%B3%E8%BD%AC%E4%B8%80%E4%B8%AAPCIE%E5%8D%83%E5%85%86%E7%BD%91%E5%8F%A3%E2%80%9D%E7%9A%84%E5%85%B7%E4%BD%93%E5%9C%BA%E6%99%AF%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%82%A8%E8%83%BD%E6%8F%8F%E8%BF%B0%E4%B8%80%E4%B8%8B%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E5%AE%9E%E7%8E%B0%E7%9A%84%E7%BB%86%E8%8A%82%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%85%B3%E4%BA%8E%20rc%20%E7%9A%84%20pcie%20%E6%A8%A1%E5%BC%8F%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%8E%8B%20Linux...%E5%AE%8C%E6%88%90%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3ELinux%20%E7%89%88%E6%9C%AC%203.0.35(root%40ubuntu)%20(gcc%20%E7%89%88%E6%9C%AC%204.6.220110630%EF%BC%88%E9%A2%84%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20MAD%20--%20Linaro%202011.07%20--%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202011%2F08%2F10%2009%3A20%EF%BC%89%EF%BC%89%233%20SMP%20PREEMPT%202013%20%E5%B9%B4%209%20%E6%9C%88%204%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%2014%3A20%3A01%20CST%3C%2FP%3E%3CP%3ECPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%2010%20(ARMv7)%EF%BC%8Ccr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%EF%BC%9AVIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E3%80%81VIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3C%2FP%3E%3CP%3E%E6%9C%BA%E5%99%A8%EF%BC%9AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E%E5%BF%BD%E7%95%A5%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%E6%A0%87%E7%AD%BE%200x54410008%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9AECC%E7%A6%81%E7%94%A8%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98writealloc%3C%2FP%3E%3CP%3ECPU%20%E6%A0%87%E8%AF%86%E4%B8%BA%20i.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3EPERCPU%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%207%20%E9%A1%B5%2Fcpu%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%BA%86%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A227328%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EDentry%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EInode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A640MB%20%2B%20256MB%20%3D%20%E5%85%B1%E8%AE%A1%20896MB%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A896372k%2F896372k%E5%8F%AF%E7%94%A8%EF%BC%8C152204k%E4%BF%9D%E7%95%99%EF%BC%8C0K%20highmem%3C%2FP%3E%3CP%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%EF%BC%884%20kB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%EF%BC%9A0xf4600000%20-%200xffe00000%EF%BC%88184%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xc0000000%EF%BC%881024%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80b01d14%26nbsp%3B%26nbsp%3B%20(11028%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80b02000%20-%200x80b67420%26nbsp%3B%26nbsp%3B%20(%20406%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b67444%20-%200x80bb58ec%26nbsp%3B%26nbsp%3B%20(%20314%20kB)%3C%2FP%3E%3CP%3ESLUB%EF%BC%9AGenslabs%3D13%E3%80%81HWalign%3D32%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81%E8%8A%82%E7%82%B9%3D1%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E7%9A%84%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%20%E7%A1%AC%E4%BB%B6%3C%2FP%3E%3CP%3Esched_clock%EF%BC%9A32%20%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20333ns%EF%BC%8C%E6%AF%8F%201431655ms%20%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMXC_Early%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8E%20MMIO%200x2020000%EF%BC%88%E9%80%89%E9%A1%B9%E2%80%9C115200%E2%80%9D%EF%BC%89%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20bootconsole%5Bttymxc0%5D%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%3C%2FP%3E%3CP%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF...1581.05%20BogoMIPS%EF%BC%88lpj%3D7905280%EF%BC%89%3C%2FP%3E%3CP%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3C%2FP%3E%3CP%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3C%2FP%3E%3CP%3Ehw%20perfevents%EF%BC%9A%E5%90%AF%E7%94%A8%20ARMv7%20Cortex-A9%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%8F%90%E4%BE%9B%207%20%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3ECPU1%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU2%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3ECPU3%EF%BC%9A%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%3C%2FP%3E%3CP%3E%E6%90%AD%E8%BD%BD%204%20%E4%B8%AA%20CPU%3C%2FP%3E%3CP%3ESMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%886324.22%20BogoMIPS%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9A%E8%99%9A%E6%8B%9F%EF%BC%9A%20%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F16%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201300%20mV%EF%BC%8C700%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E8%87%B3%201150%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddsoc%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20%E5%9C%A8%201200%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%EF%BC%9Avdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202775%20mV%20%E5%9C%A8%202400%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd1p1%3A%20800%20%26lt%3B--%26gt%3B%201400%20mV%20%E5%9C%A8%201100%20mV%20%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd3p0%3A%202625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%9C%A8%203000%20mV%20%E6%97%B6%E5%BF%AB%E9%80%9F%E6%AD%A3%E5%B8%B8%20%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%92%8C%201%20%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E4%B8%BA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%8D%95%E6%AD%A5%E4%BF%9D%E7%95%99%201%20%E4%B8%AA%E6%96%AD%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20L310%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3El2x0%EF%BC%9A16%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x02070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1048576%20B%3C%2FP%3E%3CP%3Ebio%EF%BC%9A%E5%9C%A8%200%20%E5%A4%84%E5%88%9B%E5%BB%BA%20slab%20%3CBIO-0%3E%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Emxs-dma%20mxs-dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9ASPKVDD%EF%BC%9A4200%20mV%20%3C%2FP%3E%3CP%3E%E6%89%93%E5%8D%B0%E7%BA%A6%E6%9D%9F%EF%BC%9Avmmc%EF%BC%9A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3ESCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BD%20Freescale%20USB%20OTG%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%2C%E5%85%A8%E5%B1%82%3A%201%2C%E9%87%91%E5%B1%9E%E5%B1%82%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1A%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1B%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%20300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E5%9C%A8%201300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW2%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203300%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E5%9C%A8%201500%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SW4%3A%20800%20%26lt%3B--%26gt%3B%203950%20mV%20%E5%9C%A8%203150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_SWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20%E5%9C%A8%205000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VSNVS%3A%201200%20%26lt%3B--%26gt%3B%203000%20mV%20%E8%87%B3%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VREFDDR%3A%20750%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E8%87%B3%201500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%202800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%201800%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203000%20mV%20%E5%A4%84%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20PFUZE100_VGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E5%9C%A8%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%20i.MX%20MIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20dphy%E7%89%88%E6%9C%AC%E4%B8%BA0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.0.24%E3%80%82%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.16%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F31%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Ecfg80211%EF%BC%9A%E5%91%BC%E5%90%81%20CRDA%20%E6%9B%B4%E6%96%B0%E4%B8%96%E7%95%8C%E7%9B%91%E7%AE%A1%E9%A2%86%E5%9F%9F%3C%2FP%3E%3CP%3Emax17135%202-0048%EF%BC%9A%E7%94%A8%E4%BA%8E%E7%94%B5%E5%AD%90%E5%A2%A8%E6%B0%B4%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%20PMIC%20MAX17135%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmax17135%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20mxc_timer1%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F2%3C%2FP%3E%3CP%3EIP%E8%B7%AF%E7%94%B1%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%20131072%20%E7%BB%91%E5%AE%9A%2065536%EF%BC%89%3C%2FP%3E%3CP%3ETCP%20reno%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3EUDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%20%E5%AD%97%E8%8A%82%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%971%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BA%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20udp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3EPMU%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%200%20%E5%9E%8B%20PMU%20%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6%20%E7%9A%84%E9%9D%99%E6%80%81%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3Ei.MX6%20%E5%90%AF%E7%94%A8%E7%AD%89%E5%BE%85%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%3CSTRONG%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPCIE%EF%BC%9Aimx_pcie_pltfm_probe%20%E5%BC%80%E5%A7%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%8CDB_R0%EF%BC%9A0x009d9700%EF%BC%8CDB_R1%EF%BC%9A0x08200000%EF%BC%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2075%3C%2FP%3E%3CP%3EIMX%20USB%E5%94%A4%E9%86%92%E6%8E%A2%E9%92%88%3C%2FP%3E%3CP%3ECPU%E8%B0%83%E8%8A%82%E6%A8%A1%E5%BC%8F%EF%BC%9Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96pu%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FP%3E%3CP%3EJFFS2%20%E7%89%88%E6%9C%AC%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20%E7%BA%A2%E5%B8%BD%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3Emsgmni%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA%201750%3C%2FP%3E%3CP%3Ealg%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%AF%B9%20stdrng%20(krng)%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%88%AA%E6%AD%A2%E6%9C%9F%E9%99%90%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3Eio%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20cfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%88%B0%E7%9A%84%20i.MX%20MIPI%20DSI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3E_regulator_get%EF%BC%9A%E4%B8%8D%E5%B8%A6%E6%A0%87%E8%AF%86%E7%AC%A6%E7%9A%84%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%B0%86%20LDB%20%E9%80%9A%E9%81%93%200%20%E7%9A%84%20IPU%20DI1%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20IPU%20DI0%E3%80%82%3C%2FP%3E%3CP%3Efbcvt%EF%BC%9A%E7%BA%B5%E6%A8%AA%E6%AF%94%E4%B8%8D%E7%AC%A6%E5%90%88%20CVT%20%E6%A0%87%E5%87%86%3C%2FP%3E%3CP%3Efbcvt%EF%BC%9A1024x600%4060%EF%BC%9ACVT%20%E5%90%8D%E7%A7%B0%20-%20%E9%9D%9E%20CVT%20%E6%A0%87%E5%87%86%20-%200.614%20%E7%99%BE%E4%B8%87%E5%83%8F%E7%B4%A0%E5%9B%BE%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E8%AE%BE%E5%A4%87%20128x37%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Flcd%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%EF%BC%9A%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20ldb%20displdb%20%E6%A8%A1%E5%BC%8F%E5%BA%94%E8%AF%A5%E5%A4%84%E4%BA%8E%E5%8D%95%E7%8B%AC%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20mxc%20%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%201.1%3C%2FP%3E%3CP%3Eimx-sdma%20imx-sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AIMX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EIMX-UART.2%EF%BC%9Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x21ec000%20(irq%20%3D%2060)%20%E6%98%AF%E4%B8%80%E4%B8%AA%20IMX%3C%2FP%3E%3CP%3EIMX-UART.0%EF%BC%9AMMIO%200x2020000%20(irq%20%3D%2058)%20%E5%A4%84%E7%9A%84%20ttymxc0%20%E6%98%AF%20IMX%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3Eahci%EF%BC%9A%E8%AE%BE%E7%BD%AE%E4%BA%86%20SSS%20%E6%A0%87%E5%BF%97%EF%BC%8C%E7%A6%81%E7%94%A8%E4%BA%86%E5%B9%B6%E8%A1%8C%E6%80%BB%E7%BA%BF%E6%89%AB%E6%8F%8F%3C%2FP%3E%3CP%3Eahci%20ahci.0%EF%BC%9AAHCI%200001.0300%2032%20%E4%B8%AA%E6%8F%92%E6%A7%BD%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%203%20Gbps%200x1%20impl%20%E5%B9%B3%E5%8F%B0%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_%E5%B9%B3%E5%8F%B0%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3Em25p80%20spi0.0%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%20JEDEC%20id%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%EF%BC%88IMX%EF%BC%89%3C%2FP%3E%3CP%3Ee1000e%EF%BC%9A%E8%8B%B1%E7%89%B9%E5%B0%94(R)%20PRO%2F1000%20%E7%BD%91%E7%BB%9C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20-%201.3.10-k2%3C%2FP%3E%3CP%3Ee1000e%3A%20Copyright(c)%201999%20-%202011%20Intel%20Corporation.%3C%2FP%3E%3CP%3Evcan%EF%BC%9A%E8%99%9A%E6%8B%9F%20CAN%20%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3CP%3Eflexcan%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EFEC%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Efec_enet_mii_bus%EF%BC%9A%E6%8E%A2%E6%B5%8B%3C%2FP%3E%3CP%3Eehci_hcd%EF%BC%9AUSB%202.0%E2%80%98%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%99%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%201%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%94%A4%E9%86%92%E6%BA%90%20irq%2072%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%20USB%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-0%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3C%2FP%3E%3CP%3E%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E8%AE%BE%E5%A4%87%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%882005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5%EF%BC%89%3C%2FP%3E%3CP%3Emousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84%20PS%2F2%20%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9Amax11801_ts%E4%BD%9C%E4%B8%BA%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3Eegalax_ts%EF%BC%9A1-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%EF%BC%9Aegalax_ts%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3Eegalax_ts%EF%BC%9A2-0004%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-5%3C%2FP%3E%3CP%3Eusb%202-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E5%85%A8%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%202%3C%2FP%3E%3CP%3Eelan-%E8%AF%BB%E5%8F%96%20Hello%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3Eelan-touch%EF%BC%9A2-0010%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bisl29023%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9Artc%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B0%86%20snvs_rtc%20%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3ELinux%E8%A7%86%E9%A2%91%E9%87%87%E9%9B%86%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video16%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video17%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video18%3C%2FP%3E%3CP%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BA%20video19%3C%2FP%3E%3CP%3E%E6%9E%A2%E7%BA%BD%202-1%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3C%2FP%3E%3CP%3E%E9%9B%86%E7%BA%BF%E5%99%A8%202-1%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%EF%BC%9A%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200xfffffffb%E4%B8%8D%E7%AD%89%E4%BA%8E0xc4%EF%BC%81%3C%2FP%3E%3CP%3Emag3110%EF%BC%9A2-000e%20%E6%8E%A2%E5%A4%B4%E6%95%85%E9%9A%9C%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bmag3110%5D%20%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200x1%E4%B8%8D%E7%AD%89%E4%BA%8E0x1a%E6%88%960x2a%EF%BC%81%3C%2FP%3E%3CP%3Emma8451%EF%BC%9A0-001c%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-22%3C%2FP%3E%3CP%3Eimx2-wdt%20imx2-wdt.0%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92%EF%BC%88%E6%97%A0%E8%B6%85%E6%97%B6%3D1%EF%BC%89%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E8%99%9A%E6%8B%9F%20HCI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.2%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9A%E9%80%9A%E7%94%A8%E8%93%9D%E7%89%99%20USB%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Esdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%20Pierre%20Ossman%3C%2FP%3E%3CP%3Emmc0%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.3%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emmc1%3A%20%E5%B9%B3%E5%8F%B0%5Bsdhci-esdhc-imx.1%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emmc2%3A%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5Bsdhci-esdhc-imx.2%5D%E4%BD%BF%E7%94%A8%20DMA%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%EF%BC%9A%E6%8E%A2%E6%B5%8Bi.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%88VDOA%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3EVPU%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3Emxc_asrc%E5%B7%B2%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3E%E7%83%AD%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE%E4%B8%BA0x5894f069%3C%2FP%3E%3CP%3E%E6%AF%94%E7%8E%87%20%3D%20183%20%E7%9A%84%E7%83%AD%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E6%B3%A8%E5%86%8C%E4%B8%BAthermal_zone0%3C%2FP%3E%3CP%3Eanatop_thermal_probe%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%86%B7%E5%8D%B4%E8%AE%BE%E5%A4%87%E6%98%AFcpufreq%EF%BC%81%3C%2FP%3E%3CP%3Eusbcore%3A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3C%2FP%3E%3CP%3Eusbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Eusbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%9A%84%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20snd-usb-audio%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%EF%BC%9AMXC%20HDMI%20%E9%9F%B3%E9%A2%91%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5Bcs42888%5D%20%E4%BD%BF%E7%94%A8%E6%97%A7%E5%BC%8F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CP%3Emmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E7%9A%84%E6%96%B0%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E5%8D%A1%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%EF%BC%9Ammc0%EF%BC%9A0001%20SEM04G%20%E5%88%86%E5%8C%BA%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%EF%BC%9Ammc0%EF%BC%9A0001%20SEM04G%20%E5%88%86%E5%8C%BA%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3E%20mmcblk0boot0%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3Eusb%202-1.3%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E4%BD%8E%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%203%3C%2FP%3E%3CP%3Ewm8962%200-001a%EF%BC%9A%E8%AE%BE%E5%A4%87%E4%B8%8D%E6%98%AF%20WM8962%EF%BC%8CID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20%E6%97%A0%E6%B3%95%E6%8E%A2%E6%B5%8B%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20wm8962.0-001a%3A-22%3C%2FP%3E%3CP%3Easoc%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%9E%E4%BE%8B%E5%8C%96%E5%8D%A1%20wm8962-audio%EF%BC%9A-22%3C%2FP%3E%3CP%3Eimx_3stack%20asoc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20HDMI%20%E9%9F%B3%E9%A2%91%E5%A4%B1%E8%B4%A5%E3%80%82%E9%A6%96%E5%85%88%E5%8A%A0%E8%BD%BD%20HDMI%20%E8%A7%86%E9%A2%91%EF%BC%81%3C%2FP%3E%3CP%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A3%B0%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2026%3C%2FP%3E%3CP%3ETCP%E7%AB%8B%E6%96%B9%E6%B3%A8%E5%86%8C%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F17%3C%2FP%3E%3CP%3ECAN%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E6%A0%B8%E5%BF%83%EF%BC%88rev%2020090105%20abi%208%EF%BC%89%3C%2FP%3E%3CP%3ENET%3A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E5%AE%B6%E6%97%8F%2029%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%EF%BC%89%3C%2FP%3E%3CP%3Ecan%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%2020090105%20t%EF%BC%89%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E7%95%8C%E9%9D%A2%E6%A8%A1%E6%8B%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3C%2FP%3E%3CP%3Elib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%3C%2FP%3E%3CP%3EVFP%20%E6%94%AF%E6%8C%81%20v0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E5%88%86%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9AHID%2004b3%3A310d%20%E4%BD%9C%E4%B8%BA%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3C%2FP%3E%3CP%3E%E9%80%9A%E7%94%A8%20USB%200003%EF%BC%9A04B3%EF%BC%9A310D.0001%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%8Chidraw0%EF%BC%9AUSB%20HID%20v1.11%20%E9%BC%A0%E6%A0%87%20%5BHID%2004b3%3A310d%5D%20%E4%BD%8D%E4%BA%8E%20usb-fsl-ehci.1-1.3%2Finput0%3C%2FP%3E%3CP%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%8A%A0%E8%BD%BDDVFS%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN6%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN3%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN2%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Eregulate_init_complete%3A%20PFUZE100_VGEN1%3A%20%E7%BA%A6%E6%9D%9F%E4%B8%8D%E5%AE%8C%E6%95%B4%EF%BC%8C%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01%2000%3A00%3A00%20UTC%20(0)%3C%2FP%3E%3CP%3Eusb%202-1.4%EF%BC%9A%E4%BD%BF%E7%94%A8%20fsl-ehci%20%E7%9A%84%E6%96%B0%E4%BD%8E%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B7%204%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20%E9%94%AE%E7%9B%98%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.0%2Finput%2Finput3%3C%2FP%3E%3CP%3E%E9%80%9A%E7%94%A8%20USB%200003%EF%BC%9A04D9%EF%BC%9A1702.0002%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%8Chidraw1%EF%BC%9AUSB%20HID%20v1.10%20%E9%94%AE%E7%9B%98%5BUSB%20%E9%94%AE%E7%9B%98%5D%20%E4%BD%8D%E4%BA%8E%20usb-fsl-ehci.1-1.4%2Finput0%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20%E9%94%AE%E7%9B%98%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.1%2Finput%2Finput4%3C%2FP%3E%3CP%3E%E9%80%9A%E7%94%A8%20USB%200003%EF%BC%9A04D9%EF%BC%9A1702.0003%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%8Chidraw2%EF%BC%9AUSB%20HID%20v1.10%20%E8%AE%BE%E5%A4%87%20%5BUSB%20%E9%94%AE%E7%9B%98%5D%20%E4%BD%8D%E4%BA%8E%20usb-fsl-ehci.1-1.4%2Finput1%3C%2FP%3E%3CP%3Eata1%EF%BC%9ASATA%20%E9%93%BE%E6%8E%A5%E6%96%AD%E5%BC%80%EF%BC%88SStatus%201%20SControl%20300%EF%BC%89%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%9A%E6%9C%AA%E5%90%AF%E7%94%A8%E5%B1%8F%E9%9A%9C%3C%2FP%3E%3CP%3Ekjournald%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3EEXT3-fs%EF%BC%88mmcblk0p1%EF%BC%89%EF%BC%9A%E4%BB%A5%E5%9B%9E%E5%86%99%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E6%8C%82%E8%BD%BD%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3EVFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%20179%3A1%20%E4%B8%8A%E5%AE%89%E8%A3%85%E6%A0%B9%EF%BC%88ext3%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E5%88%9D%E5%A7%8B%E5%86%85%E5%AD%98%EF%BC%9A212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E6%96%B9%E6%B3%95%E7%BB%99%E5%86%85%E6%A0%B8%E6%89%93%E4%BA%86%E4%B8%80%E4%B8%AA%E8%A1%A5%E4%B8%81%EF%BC%880001-ENGR00257661-pcie-imx-pcie-ep-rc-validation.patch%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%92%8C%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%23CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E6%83%B3%E8%BD%AC%E4%B8%80%E4%B8%AAPCIE%E5%8D%83%E5%85%86%E7%BD%91%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AC%A2%E8%BF%8E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%90%86%E6%9F%A5%E5%BE%B7%C2%B7%E6%9C%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%20%EF%BC%8C%E6%84%9F%E8%B0%A2%E8%BF%99%E4%B8%AA%E5%87%BA%E8%89%B2%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3Evers%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%89%BE%E5%88%B0%E8%AF%A5%E9%97%AE%E9%A2%98%E7%9A%84%E6%9D%A1%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%E5%BE%B7%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎06-20-2013 06:36 PM
更新人:
