Yocto Application Development Using Eclipse IDE
  1. INTRODUCTION
  2. REQUIREMENTS
  3. CREATE A NEW PROJECT
  4. GPU EXAMPLE
  5. GSTREAMER EXAMPLE
1. INTRODUCTION:
     The below steps show how to create different application examples using Elipse IDE.
2. REQUIREMENTS:
     To demonstrate the steps, L3.14.28  BSP, fsl-image-qt5 image and i.MX6Q SABRE-SDP board were used.
     Follow the section Creating a Hello World Project of this document Setting up the Eclipse IDE for Yocto Application Development
4. GPU EXAMPLE
          For this project we use the source code found in the fsl-gpu-sdk that can be downloaded from:
     https://www.freescale.com/webapp/Download?colCode=IMX6_GPU_SDK&location=null&Parent_nodeId=133763715...
  •      Follow section 3 and create a new project named gputest.
  •      From the IMX6_GPU_SDK choose one of the examples of GLES2.0 folder. In this case the 01_SimpleTriangle is chosen.
  •      Copy the .c and .h files to the src directory of the gputest project. The Project Explorer window should look like this:
  •    Add the needed files and libraries to compile and link in the Makefile.am file found in the ´src´ folder. The Makefile.am file should have the below content:
         bin_PROGRAMS = gputest
         gputest_SOURCES = gputest.c fsl_egl.c fslutil.c
         AM_CFLAGS = @gputest_CFLAGS@
         AM_LDFLAGS = @gputest_LIBS@ -lstdc++ -lm -lGLESv2 -lEGL -lX11 -ldl
         CLEANFILES = *~
  • ​    Add the PATH to CFLAGS where the compiler will look for the headers at Project->Properties->Autotools->configure:
          In this project there is no need to add extra PATHs for the headers.
  • Apply the changes by clicking on Reconfigure Project.
  • Build the project
  • To test the file you can send the executable to the board with:
     $ scp gputest root@<board_ip>:/home/root
     $./gputest
     You should get the next output in the display:
For this project we use the source code found at Basic tutorial 1: Hello world! - GStreamer SDK documentation - GStreamer SDK documentation
  •    Follow section 3 and create a new project named Gstreamer.
  •    Copy the code of the basic tutorial to your Gstreamer.c file.
     bin_PROGRAMS = Gstreamer
     Gstreamer_SOURCES = Gstreamer.c
     AM_CFLAGS = @Gstreamer_CFLAGS@
     AM_LDFLAGS = @Gstreamer_LIBS@ -lstdc++  -lVDK -lm -lGLESv2 -lGAL -lEGL  -ldl -lgstreamer-0.10 -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lxml2 -lglib-2.0
     CLEANFILES = *~
          For this example the next lines are added
       -I${Sysroot}/usr/include/gstreamer-1.0
       -I${Sysroot}/usr/include/glib-2.0
       -I${Sysroot}/usr/include/libxml2
       -I${Sysroot}/usr/lib/glib-2.0/include
  • Build the project
     $ scp Gstreamer root@<board_ip>:/home/root
  • To execute the application on the board:
     $./Gstreamer
The board should have internet access and the application should play the video found at http://docs.gstreamer.com/media/sintel_trailer-480p.webm
标签 (5)
评论
I have follow above tutorial, it was showing "Missing PROG dlltool", "Missing arm-poky-linux-gnueabi-mt", "Missing arm-poky-linux-gnueabi-dlltool", what could be error@alejandrolozano
How to create a shared libray or a static library using Eclipse IDE in the Yocto project.
I want to create those, but failed.
Hi all,
I am working with a SABRESD with an iMX6SX.
I am able to cross compile the gputest example in Eclipse and everything seems to be OK.
However, when I try to execute the resulting file from the target, I get the following error:
init: Assertion `eglNativeWindow' failed.
Aborted
Has anybody found a similar situation? I am using X11.
Thank you in advance for your collaboration.
Alvaro Martinez
I have been able to fix the problem.
I just had to add #define EGL_USE_X11 in fsl_egl.c and everything seems to work.
It is a very helpful post, thank you very much alejandro lozano!
%3CLINGO-SUB%20id%3D%22lingo-sub-1111047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E5%BC%80%E5%8F%91%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3COL%3E%3CLI%3E%3CSTRONG%3E%E7%AE%80%E4%BB%8B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%A6%81%E6%B1%82%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EGPU%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EGSTREAMER%20%E7%A4%BA%E4%BE%8B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%E5%BC%95%E8%A8%80%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E5%B1%95%E7%A4%BA%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20Elipse%20IDE%20%E5%88%9B%E5%BB%BA%E4%B8%8D%E5%90%8C%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%E8%A6%81%E6%B1%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EYocto%20%E4%B8%AD%E7%94%9F%E6%88%90%E7%9A%84%E5%AE%8C%E6%95%B4%E5%B7%A5%E4%BD%9C%E5%9B%BE%E5%83%8F%E5%92%8C%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%85%B3%E6%B3%A8%E4%B8%8B%E4%B8%80%E6%9C%9F%E5%9F%B9%E8%AE%AD%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20%E5%9F%B9%E8%AE%AD%20-%20%E4%B8%BB%E9%A1%B5%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%E5%AE%89%E8%A3%85%E5%B9%B6%E9%85%8D%E7%BD%AE%20Yocto%20Eclipse%20%E6%8F%92%E4%BB%B6%E3%80%82%E6%9C%89%E5%85%B3%E6%AD%A4%E8%A6%81%E6%B1%82%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%BA%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-172840%22%20target%3D%22_blank%22%3EYocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%E8%AE%BE%E7%BD%AE%20Eclipse%20IDE%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E6%BC%94%E7%A4%BA%E6%AD%A5%E9%AA%A4%EF%BC%8C%20%3CEM%3E%3CSTRONG%3EL3.14.28%3C%2FSTRONG%3E%3C%2FEM%3EBSP%EF%BC%8C%20%3CEM%3E%3CSTRONG%3Efsl-image-qt5%3C%2FSTRONG%3E%3C%2FEM%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E4%BA%86%E5%9B%BE%E5%83%8F%E5%92%8C%3CSTRONG%3Ei.MX6Q%20SABRE-SDP%3C%2FSTRONG%3E%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%20%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E7%85%A7%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%3CSTRONG%3E%E5%88%9B%E5%BB%BA%20Hello%20World%20%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%E9%83%A8%E5%88%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-172840%22%20target%3D%22_blank%22%3E%E8%AE%BE%E7%BD%AE%20Eclipse%20IDE%20%E4%BB%A5%E8%BF%9B%E8%A1%8C%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.%20GPU%E7%A4%BA%E4%BE%8B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20fsl-gpu-sdk%20%E4%B8%AD%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E4%B8%8B%E8%BD%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DIMX6_GPU_SDK%26amp%3Blocation%3Dnull%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DIMX6_GPU_SDK%26amp%3Blocation%3Dnull%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%EF%BC%9FcolCode%3DIMX6_GPU_SDK%26amp%3Blocation%3Dnull%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent%E2%80%A6%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8C%89%E7%85%A7%E7%AC%AC%203%20%E9%83%A8%E5%88%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%20gputest%20%E7%9A%84%E6%96%B0%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%8E%20IMX6_GPU_SDK%20%E4%B8%AD%E9%80%89%E6%8B%A9%20GLES2.0%20%E6%96%87%E4%BB%B6%E5%A4%B9%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%B9%8B%E4%B8%80%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E9%80%89%E6%8B%A9%2001_SimpleTriangle%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%A4%8D%E5%88%B6.c%E5%92%8C.h%E6%96%87%E4%BB%B6%E5%88%B0%20gputest%20%E9%A1%B9%E7%9B%AE%E7%9A%84%20src%20%E7%9B%AE%E5%BD%95%E3%80%82%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E5%BA%94%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20425px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F53859i0EEF658C9E475108%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%E5%9C%A8%E2%80%9Csrc%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%20Makefile.am%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%BC%96%E8%AF%91%E5%92%8C%E9%93%BE%E6%8E%A5%E6%89%80%E9%9C%80%E7%9A%84%E6%96%87%E4%BB%B6%E5%92%8C%E5%BA%93%E3%80%82Makefile.am%20%E6%96%87%E4%BB%B6%E5%BA%94%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ebin_PROGRAMS%20%3D%20gputest%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egputest_SOURCES%20%3D%20gputest.cfsl_egl.cfslutil.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EAM_CFLAGS%20%3D%20%40gputest_CFLAGS%40%40%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20AM_LDFLAGS%20%3D%20%40gputest_LIBS%40%20-lstdc%2B%2B%20-lm%20-lGLESv2%20-lEGL%20-lX11%20-ldl%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E6%B8%85%E7%90%86%E6%96%87%E4%BB%B6%20%3D%20*~%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E2%80%8B%20%E5%B0%86%20PATH%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20CFLAGS%EF%BC%8C%E7%BC%96%E8%AF%91%E5%99%A8%E5%B0%86%E5%9C%A8%20Project-%26gt%3BProperties-%26gt%3BAutotools-%26gt%3Bconfigure%20%E4%B8%AD%E6%9F%A5%E6%89%BE%E6%A0%87%E5%A4%B4%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E4%B8%BA%E6%A0%87%E9%A2%98%E6%B7%BB%E5%8A%A0%E9%A2%9D%E5%A4%96%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55219i92A707880F82BE9F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E5%8D%95%E5%87%BB%E2%80%9C%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%E2%80%9D%E4%BB%A5%E5%BA%94%E7%94%A8%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E8%A6%81%E6%B5%8B%E8%AF%95%E8%AF%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%B0%86%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E5%8F%91%E9%80%81%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%24%20scp%20gputest%20root%40%3CBOARD_IP%3E%3A%2Fhome%2Froot%3C%2FBOARD_IP%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%24.%2Fgputest%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%B8%8B%E4%B8%80%E4%B8%AA%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55221iA48B47F5736115A0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSTRONG%3E5.%20GSTREAMER%20%E7%A4%BA%E4%BE%8B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%9C%A8%3CA%20href%3D%22http%3A%2F%2Fdocs.gstreamer.com%2Fpages%2Fviewpage.action%3FpageId%3D327735%22%20title%3D%22http%3A%2F%2Fdocs.gstreamer.com%2Fpages%2Fviewpage.action%3FpageId%3D327735%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%9F%BA%E7%A1%80%E6%95%99%E7%A8%8B%201%EF%BC%9AHello%20world!%20%E4%B8%AD%E6%89%BE%E5%88%B0%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%20-%20GStreamer%20SDK%20%E6%96%87%E6%A1%A3%20-%20GStreamer%20SDK%20%E6%96%87%E6%A1%A3%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8C%89%E7%85%A7%E7%AC%AC%203%20%E9%83%A8%E5%88%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%20Gstreamer%20%E7%9A%84%E6%96%B0%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B0%86%E5%9F%BA%E7%A1%80%E6%95%99%E7%A8%8B%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%8D%E5%88%B6%E5%88%B0%E4%BD%A0%E7%9A%84%20Gstreamer.c%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%E5%9C%A8%E2%80%9Csrc%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%20Makefile.am%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%BC%96%E8%AF%91%E5%92%8C%E9%93%BE%E6%8E%A5%E6%89%80%E9%9C%80%E7%9A%84%E6%96%87%E4%BB%B6%E5%92%8C%E5%BA%93%E3%80%82Makefile.am%20%E6%96%87%E4%BB%B6%E5%BA%94%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%234fcddc%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ebin_PROGRAMS%20%3D%20Gstreamer%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EGstreamer_SOURCES%20%3D%20Gstreamer.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EAM_CFLAGS%20%3D%20%40Gstreamer_CFLAGS%40%40%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20AM_LDFLAGS%20%3D%20%40Gstreamer_LIBS%40%20-lstdc%2B%2B%26nbsp%3B%20-lVDK%20-lm%20-lGLESv2%20-lGAL%20-lEGL%26nbsp%3B%20-ldl%20-lgstreamer-0.10%20-lgobject-2.0%20-lgmodule-2.0%20-lgthread-2.0%20-lrt%20-lxml2%20-lglib-2.0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E6%B8%85%E7%90%86%E6%96%87%E4%BB%B6%20%3D%20*~%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E2%80%8B%20%E5%B0%86%20PATH%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20CFLAGS%EF%BC%8C%E7%BC%96%E8%AF%91%E5%99%A8%E5%B0%86%E5%9C%A8%20Project-%26gt%3BProperties-%26gt%3BAutotools-%26gt%3Bconfigure%20%E4%B8%AD%E6%9F%A5%E6%89%BE%E6%A0%87%E5%A4%B4%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E5%AF%B9%E4%BA%8E%E6%AD%A4%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E-I%20%24%7BSysroot%7D%20%2Fusr%2Finclude%2Fgstreamer-1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E-I%20%24%7BSysroot%7D%20%2Fusr%2Finclude%2Fglib-2.0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E-I%20%24%7BSysroot%7D%20%2Fusr%2Finclude%2Flibxml2%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E-I%20%24%7BSysroot%7D%20%2Fusr%2Flib%2Fglib-2.0%2Finclude%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55226i0E021B5ECA6BBB79%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E5%8D%95%E5%87%BB%E2%80%9C%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%E2%80%9D%E4%BB%A5%E5%BA%94%E7%94%A8%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E8%A6%81%E6%B5%8B%E8%AF%95%E8%AF%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%B0%86%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E5%8F%91%E9%80%81%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%24%20scp%20Gstreamer%20root%40%3CBOARD_IP%3E%3A%2Fhome%2Froot%3C%2FBOARD_IP%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E8%A6%81%E5%9C%A8%E4%B8%BB%E6%9D%BF%E4%B8%8A%E6%89%A7%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24.%2FGstreamer%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E4%B8%BB%E6%9D%BF%E5%BA%94%E5%85%B7%E6%9C%89%E4%BA%92%E8%81%94%E7%BD%91%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BA%94%E6%92%AD%E6%94%BE%3CA%20href%3D%22http%3A%2F%2Fdocs.gstreamer.com%2Fmedia%2Fsintel_trailer-480p.webm%22%20title%3D%22http%3A%2F%2Fdocs.gstreamer.com%2Fmedia%2Fsintel_trailer-480p.webm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdocs.gstreamer.com%2Fmedia%2Fsintel_trailer-480p.webm%3C%2FA%3E%E4%B8%8A%E7%9A%84%E8%A7%86%E9%A2%91%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1111047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E8%BF%9B%E8%A1%8C%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%83%BD%E5%A4%9F%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E5%9C%A8%20fsl_egl.c%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%20%23define%20EGL_USE_X11%E4%B8%80%E5%88%87%E4%BC%BC%E4%B9%8E%E9%83%BD%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%20alejandro%20lozano%EF%BC%81%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E8%BF%9B%E8%A1%8C%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20iMX6SX%20%E7%9A%84%20SABRESD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Eclipse%20%E4%B8%AD%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%20gputest%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%B8%80%E5%88%87%E4%BC%BC%E4%B9%8E%E9%83%BD%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%E7%9B%AE%E6%A0%87%E6%89%A7%E8%A1%8C%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9A%E6%96%AD%E8%A8%80%E2%80%9CeglNativeWindow%E2%80%9D%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E4%B8%AD%E6%AD%A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E8%B0%81%E5%8F%91%E7%8E%B0%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20X11%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%90%88%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E7%93%A6%E7%BD%97%C2%B7%E9%A9%AC%E4%B8%81%E5%86%85%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E8%BF%9B%E8%A1%8C%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Yocto%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E5%88%9B%E5%BB%BA%E5%85%B1%E4%BA%AB%E5%BA%93%E6%88%96%E9%9D%99%E6%80%81%E5%BA%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%88%9B%E5%BB%BA%E8%BF%99%E4%BA%9B%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E8%BF%9B%E8%A1%8C%20Yocto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%95%99%E7%A8%8B%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E2%80%9C%E7%BC%BA%E5%B0%91%20PROG%20dlltool%E2%80%9D%EF%BC%8C%E2%80%9C%E7%BC%BA%E5%B0%91%20arm-poky-linux-gnueabi-mt%E2%80%9D%EF%BC%8C%E2%80%9C%E7%BC%BA%E5%B0%91%20arm-poky-linux-gnueabi-dlltool%E2%80%9D%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%80%E4%B9%88%E9%94%99%E8%AF%AF%40%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22205882%22%20data-username%3D%22alejandrolozano%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Falejandrolozano%22%20target%3D%22_blank%22%3Ealejandrolozano%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-28-2015 12:44 PM
更新人:
