Sample code for iMX6 SabreSD to use MIPI CSI camera with virtual channel 3
It is based on 3.0.35 GA 4.1.0 BSP.
0001-Correct-mipi-camera-virtual-channel-setting-in-ipu_c.patch
It is the updated IPU code for MIPI ID and SMFC setting in ipu_capture.c. These setting should not be combined with MIPI virtual channel value, they shoule be fixed with ID 0.
0002-Use-virtual-channel-3-for-ov5640-mipi-camera-on-iMX6.patch
The sample code to modify ov5640_mipi camera to use virtual channel 3 on SabreSD board.
The followed command can be used to verify the mipi camera function after booted into Linux:
$ gst-launch mfw_v4lsrc capture-mode=1 device=/dev/video1 ! mfw_v4lsink
2014-09-30 update:
Added the patch for 3.10.17_GA1.0.0 BSP. "L3.10.17_1.0.0_mipi_camera_virtual_channel_3.zip"
附件
评论
Hi Qiang_FSL
Do you know which virtual channel number using in OV5640_mipi.c base on 3.14.28 BSP ?
Apollo Chang.
It is vc=1 in default BSP for ov5640_mipi.
Hi Qiang Li
Thanks....
But why our device tree is define (i.MX6Q)
&mipi_csi {
    status = "okay";
    ipu_id = <0>;
    csi_id = <1>;
    v_channel = <0>;
    lanes = <2>;
In default BSP, the v_channel from mipi_csi of the device tree is not used as real virtual channel setting, it must be 0.
And the csi_id from ov5640_mipi of the device tree is used as the real virtual channel setting in driver.
They will make user confused, that's why I created these patches to make everything more reasonable.
Hi Qiang_FSL​
Thanks...
It is very help us to know more detail.
Hi, Qiang Li:
     DI include vc and datatype. why the ipu driver ignore vc. like follow:
VC is not used in IPU side, it must be filled with 0.
I knew that, DI create by camera in the packet. But ipu-csi CSI_DI register is a match value, route the packet where to go?
No, the DI tells the IPU to capture which kind of data, for example YUV422 or RGB888.
%3CLINGO-SUB%20id%3D%22lingo-sub-1113316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%83%E5%9F%BA%E4%BA%8E%203.0.35GA%204.1.0BSP%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E0001-ipu_c.patch%E4%B8%AD%E6%AD%A3%E7%A1%AE%E7%9A%84mipi%E6%91%84%E5%83%8F%E5%A4%B4%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20ipu_capture.c%20%E4%B8%AD%20MIPI%20ID%20%E5%92%8C%20SMFC%20%E8%AE%BE%E7%BD%AE%E7%9A%84%E6%9B%B4%E6%96%B0%20IPU%20%E4%BB%A3%E7%A0%81%E3%80%82%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%E4%B8%8D%E5%BA%94%E4%B8%8E%20MIPI%20%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E5%80%BC%E7%BB%93%E5%90%88%EF%BC%8C%E5%AE%83%E4%BB%AC%E5%BA%94%E5%9B%BA%E5%AE%9A%E4%B8%BA%20ID%200%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E0002-%E5%9C%A8iMX6%E4%B8%8A%E4%BD%BF%E7%94%A8ov5640-mipi%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%933.patch%3C%2FP%3E%3CP%3E%E4%BF%AE%E6%94%B9%20ov5640_mipi%20%E7%9B%B8%E6%9C%BA%E4%BB%A5%E4%BD%BF%E7%94%A8%20SabreSD%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%9C%A8%E5%90%AF%E5%8A%A8Linux%E5%90%8E%E9%AA%8C%E8%AF%81mipi%E6%91%84%E5%83%8F%E5%A4%B4%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%24gst-launch%20mfw_v4lsrc%E6%8D%95%E8%8E%B7%E6%A8%A1%E5%BC%8F%3D1%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo1%EF%BC%81mfw_v4lsink%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E2014-09-30%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E4%BA%86%203.10.17_GA1.0.0%20BSP%20%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%E2%80%9CL3.10.17_1.0.0_mipi_camera_virtual_channel_3.zip%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1113316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%EF%BC%8CDI%20%E5%91%8A%E8%AF%89%20IPU%20%E6%8D%95%E8%8E%B7%E5%93%AA%E7%A7%8D%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BE%8B%E5%A6%82%20YUV422%20%E6%88%96%20RGB888%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%EF%BC%8CDI%E6%98%AF%E5%9C%A8%E5%8C%85%E9%87%8C%E7%94%A8%E7%9B%B8%E6%9C%BA%E5%88%9B%E5%BB%BA%E7%9A%84%E3%80%82%E4%BD%86%E6%98%AFipu-csi%E7%9A%84CSI_DI%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%AF%E5%8C%B9%E9%85%8D%E5%80%BC%EF%BC%8C%E8%B7%AF%E7%94%B1%E8%AF%A5%E6%95%B0%E6%8D%AE%E5%8C%85%E5%8E%BB%E5%93%AA%E9%87%8C%E5%91%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EVC%E5%9C%A8IPU%E4%BE%A7%E4%B8%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%A1%AB%E5%85%850%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qiang%20Li%3A%3C%2FP%3E%3CP%3EDI%20%E5%8C%85%E6%8B%AC%20vc%20%E5%92%8C%E6%95%B0%E6%8D%AE%E7%B1%BB%E5%9E%8B%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%20ipu%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BF%BD%E7%95%A5%20vc%E3%80%82%E5%96%9C%E6%AC%A2%E5%85%B3%E6%B3%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20382px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F26389iBB9CB09FA5BE757A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E8%B0%A2%E8%B0%A2...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E8%BF%99%E5%AF%B9%E6%88%91%E4%BB%AC%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E9%BB%98%E8%AE%A4BSP%E4%B8%AD%EF%BC%8C%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%ADmipi_csi%E7%9A%84v_channel%E4%B8%8D%E4%BD%9C%E4%B8%BA%E7%9C%9F%E6%AD%A3%E7%9A%84%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%BF%85%E9%A1%BB%E4%B8%BA0%E3%80%82%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%94%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%ADov5640_mipi%E7%9A%84csi_id%E8%A2%AB%E7%94%A8%E4%BD%9C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9C%9F%E6%AD%A3%E7%9A%84%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E4%BB%AC%E4%BC%9A%E8%AE%A9%E7%94%A8%E6%88%B7%E6%84%9F%E5%88%B0%E5%9B%B0%E6%83%91%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E5%88%9B%E5%BB%BA%E8%BF%99%E4%BA%9B%E8%A1%A5%E4%B8%81%E4%BB%A5%E4%BD%BF%E4%B8%80%E5%88%87%E5%8F%98%E5%BE%97%E6%9B%B4%E5%8A%A0%E5%90%88%E7%90%86%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-objectid%3D%2236648%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang%20Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E5%AE%9A%E4%B9%89%EF%BC%88i.MX6Q%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26amp%3Bmipi_csi%20%7B%3C%2FP%3E%3CP%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FP%3E%3CP%3Ev_channel%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lanes%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20ov5640_mipi%20%E7%9A%84%E9%BB%98%E8%AE%A4%20BSP%20%E4%B8%AD%EF%BC%8Cvc%3D1%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX6%20SabreSD%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%203%20%E7%9A%84%20MIPI%20CSI%20%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93OV5640_mipi.c%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E8%99%9A%E6%8B%9F%E9%80%9A%E9%81%93%E5%8F%B7%E6%98%AF%E5%A4%9A%E5%B0%91%E5%90%97%E5%9F%BA%E4%BA%8E%203.14.28%20BSP%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E6%B3%A2%E7%BD%97%C2%B7%E5%BC%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-09-2014 12:54 AM
更新人:
