How to reduce the CPU Frequency on iMX8M
For some applications, we need to reduce the CPU Frequency, but if you are not familiar with our BSP or our devices probably you need some help to do some configurations.
In this post, I will share the configuration to set up lower frequencies (100MHz, 200MHz, 400Mhz, 600MHz, 800MHz, and 1000MHz) on iMX8MP, iMX8MN, and iMX8MM.
Note: Works on Kernel 6.1.xx (not tested on oldest BSP)
1- We have to modify the PLL driver to set the proper parameters to lower frequencies.
The file to modify is "clk-pll14xx.c" adding the following lines:
https://github.com/nxp-imx/linux-imx/blob/770c5fe2c1d1529fae21b7043911cd50c6cf087e/drivers/clk/imx/c...
static const struct imx_pll14xx_rate_table imx_pll1416x_tbl[] = {
        PLL_1416X_RATE(1800000000U, 225, 3, 0),
        PLL_1416X_RATE(1600000000U, 200, 3, 0),
        PLL_1416X_RATE(1500000000U, 375, 3, 1),
        PLL_1416X_RATE(1400000000U, 350, 3, 1),
        PLL_1416X_RATE(1200000000U, 300, 3, 1),
        PLL_1416X_RATE(1000000000U, 250, 3, 1),
        PLL_1416X_RATE(800000000U, 200, 3, 1),
        PLL_1416X_RATE(750000000U, 250, 2, 2),
        PLL_1416X_RATE(700000000U, 350, 3, 2),
        PLL_1416X_RATE(600000000U, 300, 3, 2),
+ PLL_1416X_RATE(400000000U, 200, 3, 2),
+ PLL_1416X_RATE(200000000U, 200, 3, 3),
+ PLL_1416X_RATE(100000000U, 200, 3, 4),
2- Once the pll driver has been modified, only we have to add the values on the opp-table according to the device that you will use.
2.1- For iMX 8MP:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/boot/dts/freescale/imx8mp.dtsi
 a53_opp_table: opp-table {
                compatible = "operating-points-v2";
                opp-shared;
+ opp-100000000 {
+ opp-hz = /bits/ 64 <100000000>;
+ opp-microvolt = <850000>;
+ opp-supported-hw = <0x8a0>, <0x7>;
+ clock-latency-ns = <150000>;
+ opp-suspend;
+ opp-200000000 {
+ opp-hz = /bits/ 64 <200000000>;
+ opp-suspend;
+ opp-400000000 {
+ opp-hz = /bits/ 64 <400000000>;
+ opp-suspend;
+ opp-600000000 {
+ opp-hz = /bits/ 64 <600000000>;
+ opp-suspend;
+ opp-800000000 {
+ opp-hz = /bits/ 64 <800000000>;
+ opp-suspend;
+ opp-1000000000 {
+ opp-hz = /bits/ 64 <1000000000>;
+ opp-suspend;
                opp-1200000000 {
                        opp-hz = /bits/ 64 <1200000000>;
2.2 For iMX8MM:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/boot/dts/freescale/imx8mm.dtsi
      a53_opp_table:
                opp-table {
                opp-shared;
+ opp-100000000 {
+ opp-supported-hw = <0xe>, <0x7>;
+ opp-suspend;
+ opp-200000000 {
+ opp-suspend;
+ opp-400000000 {
+ opp-suspend;
+ opp-600000000 {
+ opp-suspend;
+ opp-800000000 {
+ opp-suspend;
+ opp-1000000000 {
+ opp-suspend;
                opp-1200000000 {
2.3- For iMX8MN:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm64/boot/dts/freescale/imx8mn.dtsi
 		opp-shared;
+                opp-100000000 {
+                        opp-supported-hw = <0xb00>, <0x7>;
+                        opp-suspend;
+                opp-200000000 {
+                        opp-suspend;
+                opp-400000000 {
+                        opp-suspend;
+                opp-600000000 {
+                        opp-suspend;
+                opp-800000000 {
+                        opp-suspend;
+                opp-1000000000 {
+                        opp-suspend;
 		opp-1200000000 {
After that, you should note the changes under Linux.
These commands return information about the system and the current settings.
• The kernel is pre-configured to support only certain frequencies. The list of frequencies currently supported
can be obtained from:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
• To get the available scaling governors:
cat /sys/devices/system/cpu/*/cpufreq/scaling_available_governors
• To check the current CPU frequency:
cat /sys/devices/system/cpu/*/cpufreq/cpuinfo_cur_freq
The frequency is displayed depending on the governor set.
• To check the maximum frequency:
cat /sys/devices/system/cpu/*/cpufreq/cpuinfo_max_freq
• To check the minimum frequency:
cat /sys/devices/system/cpu/*/cpufreq/cpuinfo_min_freq
These commands set a constant CPU frequency:
• Use the maximum frequency:
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
• Use the current frequency to be the constant frequency:
echo userspace > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
• The following two commands set the scaling governor to a specified frequency, if that frequency is supported.
If the frequency is not supported, the closest supported frequency is used:
echo <frequency> > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
Comments
This is really useful & helpful information.
I used a similar method to enable 800 MHz, 1 GHz and 1.5 GHz on an IMX8M CPU.
When running on different frequencies did you notice the power consumption change? I'm not seeing any change.
%3CLINGO-SUB%20id%3D%22lingo-sub-1813190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20reduce%20the%20CPU%20Frequency%20on%20iMX8M%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EFor%20some%20applications%2C%20we%20need%20to%20reduce%20the%20CPU%20Frequency%2C%20but%20if%20you%20are%20not%20familiar%20with%20our%20BSP%20or%20our%20devices%20probably%20you%20need%20some%20help%20to%20do%20some%20configurations.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EIn%20this%20post%2C%20I%20will%20share%20the%20configuration%20to%20set%20up%20lower%20frequencies%20(100MHz%2C%20200MHz%2C%20400Mhz%2C%20600MHz%2C%20800MHz%2C%20and%201000MHz)%20on%20iMX8MP%2C%20iMX8MN%2C%20and%20iMX8MM.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3ENote%3A%20Works%20on%20Kernel%206.1.xx%20(not%20tested%20on%20oldest%20BSP)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E1-%20We%20have%20to%20modify%20the%20PLL%20driver%20to%20set%20the%20proper%20parameters%20to%20lower%20frequencies.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EThe%20file%20to%20modify%20is%20%22clk-pll14xx.c%22%20adding%20the%20following%20lines%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CA%20class%3D%22editor-rtfLink%22%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20%3B%20color%3A%20%234a6ee0%3B%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2F770c5fe2c1d1529fae21b7043911cd50c6cf087e%2Fdrivers%2Fclk%2Fimx%2Fclk-pll14xx.c%23L57%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2F770c5fe2c1d1529fae21b7043911cd50c6cf087e%2Fdrivers%2Fclk%2Fimx%2Fclk-pll14xx.c%23L57%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Estatic%20const%20struct%20imx_pll14xx_rate_table%20imx_pll1416x_tbl%5B%5D%20%3D%20%7B%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1800000000U%2C%20225%2C%203%2C%200)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1600000000U%2C%20200%2C%203%2C%200)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1500000000U%2C%20375%2C%203%2C%201)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1400000000U%2C%20350%2C%203%2C%201)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1200000000U%2C%20300%2C%203%2C%201)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(1000000000U%2C%20250%2C%203%2C%201)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(800000000U%2C%20200%2C%203%2C%201)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(750000000U%2C%20250%2C%202%2C%202)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(700000000U%2C%20350%2C%203%2C%202)%2C%0A%0A%20%20%20%20%20%20%20%20PLL_1416X_RATE(600000000U%2C%20300%2C%203%2C%202)%2C%0A%0A%2B%20PLL_1416X_RATE(400000000U%2C%20200%2C%203%2C%202)%2C%0A%0A%2B%20PLL_1416X_RATE(200000000U%2C%20200%2C%203%2C%203)%2C%0A%0A%2B%20PLL_1416X_RATE(100000000U%2C%20200%2C%203%2C%204)%2C%0A%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E2-%20Once%20the%20pll%20driver%20has%20been%20modified%2C%20only%20we%20have%20to%20add%20the%20values%20on%20the%20opp-table%20according%20to%20the%20device%20that%20you%20will%20use.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E2.1-%20For%20iMX%208MP%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CA%20class%3D%22editor-rtfLink%22%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20%3B%20color%3A%20%234a6ee0%3B%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20a53_opp_table%3A%20opp-table%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22operating-points-v2%22%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-shared%3B%0A%0A%20%0A%0A%2B%20opp-100000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B100000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-200000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B200000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-400000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B400000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-600000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B600000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-800000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B800000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-1000000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1000000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0x8a0%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-1200000000%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1200000000%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E2.2%20For%20iMX8MM%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CA%20class%3D%22editor-rtfLink%22%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20%3B%20color%3A%20%234a6ee0%3B%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20%20%20%20%20%20a53_opp_table%3A%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-table%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22operating-points-v2%22%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-shared%3B%0A%0A%20%0A%0A%2B%20opp-100000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B100000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-200000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B200000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-400000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B400000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-600000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B600000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-800000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B800000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%2B%20opp-1000000000%20%7B%0A%0A%2B%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1000000000%26gt%3B%3B%0A%0A%2B%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%0A%2B%20opp-supported-hw%20%3D%20%26lt%3B0xe%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%0A%2B%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%0A%2B%20opp-suspend%3B%0A%0A%2B%20%7D%3B%0A%0A%20%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-1200000000%20%7B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1200000000%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E2.3-%20For%20iMX8MN%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CA%20class%3D%22editor-rtfLink%22%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%20%3B%20color%3A%20%234a6ee0%3B%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mn.dtsi%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.1.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mn.dtsi%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecompatible%20%3D%20%22operating-points-v2%22%3B%0A%20%09%09opp-shared%3B%0A%20%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-100000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B100000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-200000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B200000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-400000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B400000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-600000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B600000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-800000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B800000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-1000000000%20%7B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1000000000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-supported-hw%20%3D%20%26lt%3B0xb00%26gt%3B%2C%20%26lt%3B0x7%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-latency-ns%20%3D%20%26lt%3B150000%26gt%3B%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20opp-suspend%3B%0A%2B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%2B%0A%20%09%09opp-1200000000%20%7B%0A%20%09%09%09opp-hz%20%3D%20%2Fbits%2F%2064%20%26lt%3B1200000000%26gt%3B%3B%0A%20%09%09%09opp-microvolt%20%3D%20%26lt%3B850000%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EAfter%20that%2C%20you%20should%20note%20the%20changes%20under%20Linux.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EThese%20commands%20return%20information%20about%20the%20system%20and%20the%20current%20settings.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20The%20kernel%20is%20pre-configured%20to%20support%20only%20certain%20frequencies.%20The%20list%20of%20frequencies%20currently%20supported%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3Ecan%20be%20obtained%20from%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecat%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_available_frequencies%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20To%20get%20the%20available%20scaling%20governors%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecat%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2F*%2Fcpufreq%2Fscaling_available_governors%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20To%20check%20the%20current%20CPU%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecat%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2F*%2Fcpufreq%2Fcpuinfo_cur_freq%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EThe%20frequency%20is%20displayed%20depending%20on%20the%20governor%20set.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20To%20check%20the%20maximum%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecat%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2F*%2Fcpufreq%2Fcpuinfo_max_freq%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20To%20check%20the%20minimum%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecat%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2F*%2Fcpufreq%2Fcpuinfo_min_freq%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EThese%20commands%20set%20a%20constant%20CPU%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20Use%20the%20maximum%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eecho%20performance%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_governor%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20Use%20the%20current%20frequency%20to%20be%20the%20constant%20frequency%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eecho%20userspace%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_governor%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3E%E2%80%A2%20The%20following%20two%20commands%20set%20the%20scaling%20governor%20to%20a%20specified%20frequency%2C%20if%20that%20frequency%20is%20supported.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20data-preserver-spaces%3D%22true%22%3EIf%20the%20frequency%20is%20not%20supported%2C%20the%20closest%20supported%20frequency%20is%20used%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%230e101a%3B%20background%3A%20transparent%3B%20margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eecho%20userspace%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_governor%0Aecho%20%3CFREQUENCY%3E%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_setspeed%3C%2FFREQUENCY%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_0-1708555234422.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_0-1708555234422.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264378iA53EBE096E9647FF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_0-1708555234422.png%22%20alt%3D%22Chavira_0-1708555234422.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChavira_0-1708555234422.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1813190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1836622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20reduce%20the%20CPU%20Frequency%20on%20iMX8M%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1836622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20really%20useful%20%26amp%3B%20helpful%20information.%3C%2FP%3E%3CP%3EI%20used%20a%20similar%20method%20to%20enable%20800%20MHz%2C%201%20GHz%20and%201.5%20GHz%20on%20an%20IMX8M%20CPU.%3C%2FP%3E%3CP%3EWhen%20running%20on%20different%20frequencies%20did%20you%20notice%20the%20power%20consumption%20change%3F%20I'm%20not%20seeing%20any%20change.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
50% helpful (2/4)
Version history
Last update:
‎02-22-2024 11:24 AM
Updated by:
