How to build U-Boot, Kernel and Linux application(s) without Yocto
 This article uses i.MX Linux® User's Guide, Rev. L4.1.15_2.1.0-ga, 05/2017
as an example (it may be found as attachment), please refer to section 4.5.12 (How to build
U-Boot and Kernel in standalone environment).
  First, generate a development SDK, which includes the tools, toolchain, and small rootfs to compile against
to put on the host machine.
  • Generate an SDK from the Yocto Project build environment with the following command. To set up the Yocto Project build
environment, follow the steps in the i.MX Yocto Project User's Guide (IMXLXYOCTOUG). In the following command,
set <Target-Machine> to the machine you are building for.
<Target-Machine> may be one of the following :
• imx6qpsabreauto
• imx6qpsabresd
• imx6ulevk
• imx6ull14x14evk
• imx6ull9x9evk
• imx6dlsabreauto
• imx6dlsabresd
• imx6qsabreauto
• imx6qsabresd
• imx6slevk
• imx6sllevk
• imx6solosabreauto
• imx6solosabresd
• imx6sxsabresd
• imx6sxsabreauto
• imx7dsabresd
 The «populate_sdk» generates an script file that sets up environment without Yocto Project. This SDK should be updated for each release
to pick up the latest headers, toolchain, and tools from the current release.
$ DISTRO=fsl-imx-fb MACHINE=<Target-Machine> source fsl-setup-release.sh -b build-fb
$ DISTRO=fsl-imx-fb MACHINE=<Target-Machine> bitbake core-image-minimal -c populate_sdk
or
$ bitbake meta-toolchain
  • From the build directory, the bitbake was run in, copy the sh file in tmp/deploy/sdk to the host machine to build on and execute the
script to install the SDK. The default location is in /opt but can be placed anywhere on the host machine.
  Note. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
 $ . /opt/fsl-imx-fb/4.1.15-2.0.0/environment-setup-cortexa9hf-neon-poky-linux-gnueabi
or
 $ source /opt/fsl-imx-fb/4.1.15-2.0.0/environment-setup-cortexa9hf-neon-poky-linux-gnueabi
From  Yocto Project Mega-Manual
Note
By default, this toolchain does not build static binaries. If you want to use the toolchain to build these types of libraries, you need to be sure your image has the appropriate static development libraries. Use the IMAGE_INSTALL variable inside your local.conf file to install the appropriate library packages. Following is an example using glibc static development libraries:
     IMAGE_INSTALL_append = " glibc-staticdev"
On the host machine, these are the steps to build U-Boot and Kernel:
 • On the host machine, set the environment with the following command before building.
$ export CROSS_COMPILE=/opt/fsl-imx-fb/4.1.15/environment-setup-cortexa9hf-vfp-neon-pokylinux-gnueabi
$ export ARCH=arm
• To build U-Boot, find the configuration for the target boot. In the following example,
i.MX 6ULL is the target.
  Download source by cloning with
$ git clone http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git -b imx_v2016.03_4.1.15_2.0.0_ga
$ cd uboot-imx
$ make clean
$ make mx6ull_14x14_evk_defconfig
$ make u-boot.imx
• To build the kernel, execute the following commands:
$ git clone http://git.freescale.com/git/cgit.cgi/imx/linux-imx.git -b imx_4.1.15_2.0.0_ga
$ cd linux-imx
$ make defconfig
$ make
• To build an application (Hello World) as test.c:
$ cd ~/test/
$ arm-poky-linux-gnueabi-gcc --sysroot=/opt/fsl-imx-fb/4.1.15-2.0.0/sysroots/cortexa9hf-neon-poky-linux-gnueabi -mfloat-abi=hard test.c
To check if the the compiled code (a.out) is ARM executable
$ file ./a.out
./a.out: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=0e5c22dcf021748ead2c0bd51a4553cb7d38f6f2, not stripped
Copy file a.out to target Linux filesystem and before run it check again :
root@imx6ul7d:/unit_tests/1# file a.out
To define what Linux libs are needed to run our application :
root@imx6ul7d:/unit_tests/1# ldd a.out
  linux-vdso.so.1 (0x7ee93000)
  libc.so.6 => /lib/libc.so.6 (0x76e64000)
  /lib/ld-linux-armhf.so.3 (0x76f9d000)
If some libs are not located in the filesystem you can observe the following message :
-sh: root@imx6ul7d:/unit_tests/1#./a.out: No such file or directory
Finally - run a.out:
root@imx6ul7d:/unit_tests/1# ./a.out
Hello World
附件
评论
Hi Yuri,
I was reading the post DOC-334814 and would like to mention once the environment has been setup from sourcing the meta-toolchain environment script, the variable CC can be used  for the section "To build an application (Hellow World) as test.c;  here is an example of the definition for CC which will be unique based on MACHINE used:    CC=arm-poky-linux-gnueabi-gcc  -march=armv7ve -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/opt/fsl-imx-x11/4.1.30-7ULP_alpha/sysroots/cortexa7hf-neon-poky-linux-gnueabi
This example is provided:
But this could be used instead:
$ $CC test.c -o test
Using $CC adds a few more definitions as you can see above.
-Curtis
I have problem can you check and help me how can i fix this.
goko@PC:~/fsl-release-bsp/uboot-imx$ make clean
make: /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabigcc: Command not found
/bin/sh: 1: /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabigcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
goko@PC:~/fsl-release-bsp/uboot-imx$ make mx6ull_14x14_evk_defconfig
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
goko@PC:~/fsl-release-bsp/uboot-imx$ make u-boot.imx
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config.h
  UPD     include/config.h
  GEN     include/autoconf.mk
make[1]: *** [include/autoconf.mk] Error 1
make: *** No rule to make target `include/config/auto.conf', needed by `include/config/uboot.release'.  Stop.
or
Yuri.
%3CLINGO-SUB%20id%3D%22lingo-sub-1117574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E6%B2%A1%E6%9C%89%20Yocto%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%20U-Boot%E3%80%81%E5%86%85%E6%A0%B8%E5%92%8C%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%AC%E6%96%87%E5%8F%82%E8%80%83%E4%BA%86%E3%80%8Ai.MX%20Linux%C2%AE%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%8B%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%20L4.1.15_2.1.0-ga%EF%BC%8C2017%20%E5%B9%B4%205%20%E6%9C%88%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%9C%E4%B8%BA%E7%A4%BA%E4%BE%8B%EF%BC%88%E5%8F%AF%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%89%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E7%AC%AC%204.5.12%20%E8%8A%82%EF%BC%88%E5%A6%82%E4%BD%95%E6%9E%84%E5%BB%BA%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EU-Boot%20%E5%92%8C%20Kernel%20%E5%9C%A8%E7%8B%AC%E7%AB%8B%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E9%A6%96%E5%85%88%EF%BC%8C%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E5%BC%80%E5%8F%91%20SDK%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E6%8B%AC%E7%94%A8%E4%BA%8E%E7%BC%96%E8%AF%91%E7%9A%84%E5%B7%A5%E5%85%B7%E3%80%81%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%E5%B0%8F%E5%9E%8B%20rootfs%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%94%BE%E7%BD%AE%E5%88%B0%E4%B8%BB%E6%9C%BA%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%BB%8E%20Yocto%20Project%20%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E7%94%9F%E6%88%90%20SDK%E3%80%82%E5%A6%82%E8%A6%81%E8%AE%BE%E7%BD%AE%20Yocto%20Project%20%E6%9E%84%E5%BB%BA%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%8E%AF%E5%A2%83%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%20i.MX%20Yocto%20Project%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%88IMXLXYOCTOUG%EF%BC%89%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E5%9C%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%B8%AD%EF%BC%8C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%B0%86%20%3CTARGET-MACHINE%3E%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%82%A8%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%E7%9A%84%E6%9C%BA%E5%99%A8%E3%80%82%20%3C%2FTARGET-MACHINE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CTARGET-MACHINE%3E%20%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%A5%E4%B8%8B%E4%B9%8B%E4%B8%80%EF%BC%9A%3C%2FTARGET-MACHINE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6qpsabreauto%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6qpsabresd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6ulevk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6ull14x14evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6ull9x9evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6dlsabreauto%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6dlsabresd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6qsabreauto%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6qsabresd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6slevk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6sllevk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6solosabreauto%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6solosabresd%3CBR%20%2F%3E%E2%80%A2%20imx6sxsabresd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx6sxsabreauto%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20imx7dsabresd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%9Cpopulate_sdk%E2%80%9D%E4%BC%9A%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%9C%A8%E6%B2%A1%E6%9C%89%20Yocto%20Project%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E3%80%82%E6%AD%A4%20SDK%20%E5%BA%94%E5%9C%A8%E6%AF%8F%E6%AC%A1%E5%8F%91%E5%B8%83%E6%97%B6%E6%9B%B4%E6%96%B0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%8E%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%9C%80%E6%96%B0%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%E3%80%81%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20DISTRO%3Dfsl-imx-fb%20MACHINE%3D%3CTARGET-MACHINE%3E%20source%20fsl-setup-release.sh%20-b%20build-fb%3C%2FTARGET-MACHINE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20DISTRO%3Dfsl-imx-fb%20MACHINE%3D%3CTARGET-MACHINE%3E%20bitbake%20core-image-minimal%20-c%20populate_sdk%3C%2FTARGET-MACHINE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%96%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20bitbake%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Emeta-toolchain%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%8E%E8%BF%90%E8%A1%8C%20bitbake%20%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%8C%E5%B0%86%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Etmp%2Fdeploy%2Fsdk%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%E7%9B%AE%E5%BD%95%E4%B8%8B%E7%9A%84%20sh%20%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E7%9A%84%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%8C%E5%B9%B6%E6%89%A7%E8%A1%8C%E8%AF%A5%E8%84%9A%E6%9C%AC%E5%AE%89%E8%A3%85%20SDK%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E9%BB%98%E8%AE%A4%E5%AE%89%E8%A3%85%E4%BD%8D%E7%BD%AE%E4%B8%BA%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%2Fopt%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E4%BD%86%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%94%BE%E7%BD%AE%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%9A%84%E4%BB%BB%E6%84%8F%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%AF%8F%E6%AC%A1%E5%9C%A8%E6%96%B0%E7%9A%84%20shell%20%E4%BC%9A%E8%AF%9D%E4%B8%AD%E4%BD%BF%E7%94%A8%20SDK%20%E5%89%8D%EF%BC%8C%E9%83%BD%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%20source%20%E5%91%BD%E4%BB%A4%E5%8A%A0%E8%BD%BD%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%E3%80%82%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fenvironment-setup-cortexa9hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%96%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20source%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fenvironment-setup-cortexa9hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%A5%E8%87%AA%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CA%20class%3D%22%22%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F2.1%2Fmega-manual%2Fmega-manual.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F2.1%2Fmega-manual%2Fmega-manual.html%22%20target%3D%22_blank%22%3EYocto%20Project%20Mega-Manual%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20class%3D%22%22%20id%3D%22toc-hId-1082686637%22%20style%3D%22color%3A%20%2300557d%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20bold%3B%20font-size%3A%20large%3B%20margin%3A%200em%3B%20padding%3A%200em%3B%22%20id%3D%22toc-hId-1082686637%22%20id%3D%22toc-hId-2004209625%22%3E%E6%B3%A8%3C%2FH3%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f0f0f2%3B%20font-size%3A%20medium%3B%22%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%AD%A4%E5%B7%A5%E5%85%B7%E9%93%BE%E4%B8%8D%E4%BC%9A%E6%9E%84%E5%BB%BA%E9%9D%99%E6%80%81%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%B7%A5%E5%85%B7%E9%93%BE%E6%9E%84%E5%BB%BA%E6%AD%A4%E7%B1%BB%E5%BA%93%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%82%A8%E7%9A%84%E9%95%9C%E5%83%8F%E5%B7%B2%E5%8C%85%E5%90%AB%E7%9B%B8%E5%BA%94%E7%9A%84%E9%9D%99%E6%80%81%E5%BC%80%E5%8F%91%E5%BA%93%E3%80%82%E4%BD%BF%E7%94%A8%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20class%3D%22%22%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F2.1%2Fmega-manual%2Fmega-manual.html%23var-IMAGE_INSTALL%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20text-decoration%3A%20underline%3B%20font-size%3A%20medium%3B%22%20target%3D%22_top%22%3E%3CCODE%20class%3D%22%22%20style%3D%22font-size%3A%20medium%3B%22%3EIMAGE_INSTALL%3C%2FCODE%3E%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f0f0f2%3B%20font-size%3A%20medium%3B%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%8F%98%E9%87%8F%E5%9C%A8%E6%82%A8%E7%9A%84%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%20medium%3B%22%3Elocal.conf%3C%2FCODE%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f0f0f2%3B%20font-size%3A%20medium%3B%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%89%E8%A3%85%E7%9B%B8%E5%BA%94%E7%9A%84%E5%BA%93%E5%8C%85%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%BD%BF%E7%94%A8%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%20medium%3B%22%3Eglibc%3C%2FCODE%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20%23f0f0f2%3B%20font-size%3A%20medium%3B%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E9%9D%99%E6%80%81%E5%BC%80%E5%8F%91%E5%BA%93%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%22%3EIMAGE_INSTALL_append%20%3D%20%E2%80%9Cglibc-staticdev%E2%80%9D%3C%2FPRE%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%9E%84%E5%BB%BA%20U-Boot%20%E5%92%8C%E5%86%85%E6%A0%B8%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%8C%E6%9E%84%E5%BB%BA%E4%B9%8B%E5%89%8D%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20export%20CROSS_COMPILE%3D%2Fopt%2Ffsl-imx-fb%2F4.1.15%2Fenvironment-setup-cortexa9hf-vfp-neon-pokylinux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20export%20ARCH%3Darm%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20%E5%A6%82%E8%A6%81%E6%9E%84%E5%BB%BA%20U-Boot%EF%BC%8C%E8%AF%B7%E6%9F%A5%E6%89%BE%E7%9B%AE%E6%A0%87%E5%90%AF%E5%8A%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%E5%9C%A8%E4%BB%A5%E4%B8%8B%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ei.MX%206ULL%20%E6%98%AF%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E9%80%9A%E8%BF%87%E5%85%8B%E9%9A%86%E4%B8%8B%E8%BD%BD%E6%BA%90%E4%BB%A3%E7%A0%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20git%20clone%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E-b%20imx_v2016.03_4.1.15_2.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20cd%20uboot-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20make%20clean%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20make%20mx6ull_14x14_evk_defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20make%20u-boot.imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20%E5%A6%82%E8%A6%81%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%EF%BC%8C%E8%AF%B7%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E9%80%9A%E8%BF%87%E5%85%8B%E9%9A%86%E4%B8%8B%E8%BD%BD%E6%BA%90%E4%BB%A3%E7%A0%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fgit.freescale.com%252Fgit%252Fcgit.cgi%252Fimx%252Flinux-imx.git%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-imx.git%3C%2FA%3E%3CSPAN%3E%20-b%20imx_4.1.15_2.0.0_ga%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20cd%20linux-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20make%20defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20make%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%A2%20%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20(Hello%20World)%20%E6%9E%84%E5%BB%BA%E4%B8%BA%20test.c%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20source%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fenvironment-setup-cortexa9hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20cd%20~%2Ftest%2F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20arm-poky-linux-gnueabi-gcc%20--sysroot%3D%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fsysroots%2Fcortexa9hf-neon-poky-linux-gnueabi%20-mfloat-abi%3Dhard%20test.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%A3%80%E6%9F%A5%E7%BC%96%E8%AF%91%E5%90%8E%E7%9A%84%E4%BB%A3%E7%A0%81%20(a.out)%20%E6%98%AF%E5%90%A6%E4%B8%BA%20ARM%20%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%24%20file%20.%2Fa.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E.%2Fa.out%3A%20ELF%2032%20%E4%BD%8D%20LSB%20%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8CARM%20%E6%9E%B6%E6%9E%84%EF%BC%8CEABI5%20%E7%89%88%E6%9C%AC%201%EF%BC%88SYSV%EF%BC%89%EF%BC%8C%E5%8A%A8%E6%80%81%E9%93%BE%E6%8E%A5%EF%BC%8C%E8%A7%A3%E9%87%8A%E5%99%A8%20%2Flib%2Fld-linux-armhf.so.3%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20GNU%2FLinux%202.6.32%E3%80%82BuildID%5Bsha1%5D%3D0e5c22dcf021748ead2c0bd51a4553cb7d38f6f2%EF%BC%8C%E6%9C%AA%E5%89%A5%E7%A6%BB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%B0%86%E6%96%87%E4%BB%B6%20a.out%20%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%AE%E6%A0%87%20Linux%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%B9%B6%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%B9%8B%E5%89%8D%E5%86%8D%E6%AC%A1%E6%A3%80%E6%9F%A5%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eroot%40imx6ul7d%3A%2Funit_tests%2F1%23%20file%20a.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Ea.out%3A%20ELF%2032%E4%BD%8DLSB%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8CARM%EF%BC%8CEABI5%E7%89%88%E6%9C%AC1%EF%BC%88SYSV%EF%BC%89%EF%BC%8C%E5%8A%A8%E6%80%81%E9%93%BE%E6%8E%A5%EF%BC%8C%E8%A7%A3%E9%87%8A%E5%99%A8%2Flib%2Fld-linux-armhf.so.3%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8EGNU%2FLinux%202.6.32%EF%BC%8CBuildID%5Bsha1%5D%3D0e5c22dcf021748ead2c0bd51a4553cb7d38f6f2%EF%BC%8C%E6%9C%AA%E5%89%A5%E7%A6%BB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E8%A6%81%E7%A1%AE%E5%AE%9A%E8%BF%90%E8%A1%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%89%80%E9%9C%80%E7%9A%84%20Linux%20%E5%BA%93%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eroot%40imx6ul7d%3A%2Funit_tests%2F1%23%20ldd%20a.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20linux-vdso.so.1%20(0x7ee93000)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20libc.so.6%20%3D%26gt%3B%20%2Flib%2Flibc.so.6%20(0x76e64000)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%2Flib%2Fld-linux-armhf.so.3%20(0x76f9d000)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%9F%90%E4%BA%9B%E5%BA%93%E6%96%87%E4%BB%B6%E6%9C%AA%E4%BD%8D%E4%BA%8E%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E-sh%3A%20root%40imx6ul7d%3A%2Funit_tests%2F1%23.%2Fa.out%3A%20%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E8%BF%90%E8%A1%8C%20a.out%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eroot%40imx6ul7d%3A%2Funit_tests%2F1%23%20.%2Fa.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B8%96%E7%95%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eroot%40imx6ul7d%3A%2Funit_tests%2F1%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7%20%E5%8D%95%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E6%B2%A1%E6%9C%89%20Yocto%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%20U-Boot%E3%80%81%E5%86%85%E6%A0%B8%E5%92%8C%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AF%8F%E6%AC%A1%E6%82%A8%E6%83%B3%E5%9C%A8%E6%96%B0%E7%9A%84%20shell%20%E4%BC%9A%E8%AF%9D%E4%B8%AD%E4%BD%BF%E7%94%A8%20SDK%20%E6%97%B6%EF%BC%8C%E9%83%BD%E9%9C%80%E8%A6%81%20source%20%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%E3%80%82%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fenvironment-setup-cortexa9hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E6%88%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20source%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fenvironment-setup-cortexa9hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%B0%A4%E9%87%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E6%B2%A1%E6%9C%89%20Yocto%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%20U-Boot%E3%80%81%E5%86%85%E6%A0%B8%E5%92%8C%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E6%9F%A5%E7%9C%8B%E5%B9%B6%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egoko%40PC%3A~%2Ffsl-release-bsp%2Fuboot-imx%24%20make%20cleanmake%3A%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.1.0%2Fenvironment-setup-cortexa7hf-neon-poky-linux-gnueabigcc%3A%E5%91%BD%E4%BB%A4%E6%9C%AA%E6%89%BE%E5%88%B0%2Fbin%2Fsh%3A%201%3A%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.1.0%2Fenvironment-setup-cortexa7hf-neon-poky-linux-gnueabigcc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0dirname%EF%BC%9A%E7%BC%BA%E5%B0%91%E6%93%8D%E4%BD%9C%E6%95%B0%E5%B0%9D%E8%AF%95%20'dirname%20--help'%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82goko%40PC%3A~%2Ffsl-release-bsp%2Fuboot-imx%24%20make%20mx6ull_14x14_evk_defconfig%3CBR%20%2F%3E%26nbsp%3B%20HOSTCC%26nbsp%3B%20scripts%2Fbasic%2Ffixdep%3CBR%20%2F%3E%26nbsp%3B%20HOSTCC%26nbsp%3B%20scripts%2Fkconfig%2Fconf.o%3CBR%20%2F%3E%26nbsp%3B%20HOSTCC%26nbsp%3B%20scripts%2Fkconfig%2Fzconf.tab.o%3CBR%20%2F%3E%26nbsp%3B%20HOSTLD%26nbsp%3B%20scripts%2Fkconfig%2Fconf%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E9%85%8D%E7%BD%AE%E5%B7%B2%E5%86%99%E5%85%A5%20.config%3CBR%20%2F%3E%23goko%40PC%EF%BC%9A~%2Ffsl-release-bsp%2Fuboot-imx%24%20make%20u-boot.imxmake%3A%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.1.0%2Fenvironment-setup-cortexa7hf-neon-poky-linux-gnueabigcc%EF%BC%9A%E5%91%BD%E4%BB%A4%E6%9C%AA%E6%89%BE%E5%88%B0%2Fbin%2Fsh%3A%201%3A%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.1.0%2Fenvironment-setup-cortexa7hf-neon-poky-linux-gnueabigcc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0dirname%EF%BC%9A%E7%BC%BA%E5%B0%91%E6%93%8D%E4%BD%9C%E6%95%B0%E5%B0%9D%E8%AF%95%20'dirname%20--help'%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82scripts%2Fkconfig%2Fconf%20--silentoldconfig%20Kconfig%20CHK%20include%2Fconfig.h%20UPD%20include%2Fconfig.h%20GEN%20include%2Fautoconf.mk%2Fbin%2Fsh%3A%201%3A%20%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.1.0%2Fenvironment-setup-cortexa7hf-neon-poky-linux-gnueabigcc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0make%5B1%5D%3A%20***%20%5Binclude%2Fautoconf.mk%5D%E9%94%99%E8%AF%AF%201make%3A%20***%20%E6%B2%A1%E6%9C%89%E8%A7%84%E5%88%99%E6%9D%A5%E7%94%9F%E6%88%90%E7%9B%AE%E6%A0%87%20%60include%2Fconfig%2Fauto.conf'%EF%BC%8C%E8%AF%A5%E7%9B%AE%E6%A0%87%E8%A2%AB%20%60include%2Fconfig%2Fuboot.release'%20%E6%89%80%E9%9C%80%E3%80%82%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E6%B2%A1%E6%9C%89%20Yocto%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%20U-Boot%E3%80%81%E5%86%85%E6%A0%B8%E5%92%8C%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20class%3D%22%22%20data-author-id%3D%22204418%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%200px%3B%20border-bottom%3A%20none%3B%20border-left%3A%200px%3B%20border-right%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%20margin%3A%200px%200px%205px%3B%22%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FCurtisWald%22%20target%3D%22_blank%22%3ECurtisWald%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20data-id%3D%2245240%22%20data-ts%3D%222017-07-17T21%3A03%3A34.060%2B0000%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%200px%3B%20border-bottom%3A%20none%3B%20border-left%3A%200px%3B%20border-right%3A%200px%3B%20font-size%3A%2014px%3B%20padding%3A%205px%20100px%205px%200px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8CYuri%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E6%88%91%E5%9C%A8%E9%98%85%E8%AF%BB%E5%B8%96%E5%AD%90%20DOC-334814%20%E6%97%B6%E6%83%B3%E6%8F%90%E5%88%B0%EF%BC%8C%E4%B8%80%E6%97%A6%E4%BB%8E%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%E7%8E%AF%E5%A2%83%E8%84%9A%E6%9C%AC%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E7%8E%AF%E5%A2%83%EF%BC%8C%E5%8F%98%E9%87%8F%20CC%20%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8E%E2%80%9C%E6%9E%84%E5%BB%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%88Hello%20World%EF%BC%89%E4%BD%9C%E4%B8%BA%20test.c%E2%80%9D%E9%83%A8%E5%88%86%EF%BC%9B%E4%BB%A5%E4%B8%8B%E6%98%AF%20CC%20%E7%9A%84%E5%AE%9A%E4%B9%89%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%A5%E5%AE%9A%E4%B9%89%E5%B0%86%E6%A0%B9%E6%8D%AE%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%20MACHINE%20%E8%80%8C%E5%94%AF%E4%B8%80%EF%BC%9A%26nbsp%3B%20%26nbsp%3BCC%3Darm-poky-linux-gnueabi-gcc%20%26nbsp%3B-march%3Darmv7ve%20-mfpu%3Dneon%20%26nbsp%3B-mfloat-abi%3Dhard%20-mcpu%3Dcortex-a7%20--sysroot%3D%2Fopt%2Ffsl-imx-x11%2F4.1.30-7ULP_alpha%2Fsysroots%2Fcortexa7hf-neon-poky-linux-gnueabi%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E6%8F%90%E4%BE%9B%E5%A6%82%E4%B8%8B%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%24%20arm-poky-linux-gnueabi-gcc%20--sysroot%3D%2Fopt%2Ffsl-imx-fb%2F4.1.15-2.0.0%2Fsysroots%2Fcortexa9hf-neon-poky-linux-gnueabi%20-mfloat-abi%3Dhard%20test.c%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E4%BD%86%E6%98%AF%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%24%20%24CC%20test.c%20-o%20test%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E4%BD%BF%E7%94%A8%20%24CC%20%E4%BC%9A%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E5%AE%9A%E4%B9%89%EF%BC%8C%E5%A6%82%E4%B8%8A%E6%89%80%E7%A4%BA%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E-Curtis%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
0% 有帮助 (0/1)
版本历史
最后更新:
‎09-10-2020 02:36 AM
更新人:
