HDMI Dongle Reference Design Release
HDMI Dongle SW:
The attachment is an HDMI dongle patch based on R13.4 GA. The patches include r13.4-ga-add-on-patches. You can patch it after applying R13.4 GA patch such as add-on patches. You can run script to revb_dongle_patch_install.sh to apply these patches.
How to apply the hdmidongle_REVB_R13.4_patch-20121115.tgz:
1. Suppose your android source top is ~/myandroid
2. tar zfvx hdmidongle_REVB_R13.4_patch-20121115.tgz -C ~/
3. copy revb_dongle_patch_install.sh to ~/
4. cd hdmidongle_REVB_R13.4_patch
5. ~/revb_dongle_patch_install.sh
6. The  revb_dongle_patch_install.sh will take ~/myandroid as default directory to do patch
7. If your android source tree top is not ~/myandroid. For example, ~/myandroid_ICS, please run ~/revb_dongle_patch_install.sh ~/myandroid_ICS
The following is the release notes for  hdmidongle_REVB_R13.4_patch-20130118.tgz
1. New features:
   a. uboot fastboot
   b. ldo bypass
   c. ntfs support
   d. bluetooth A2DP
2. Bug fix
   a. WifiDirect connect issue
   b. realtek throughput issue with TPLink AP
3. File list:
   README.TXT                                      --- this file
   0001-uboot_fastboot.patch                       --- uboot fastboot  patch
   0002-LDOBYPASS.patch                            --- enable ldo bypass  patch
   0003-WifiDirect.patch                           --- wifi direct connect patch
   0004-ntfs_support.patch                         --- ntfs support patch
   0005-BT_enable.patch                            --- enable bluetooth A2DP
   0006-1G_boot_stable.patch                       --- make 1G bootup stable
   ntfs-3g.tar.gz                                  --- open source ntfs-3g for ntfs support
   rtl8192ce_v4.0.0_6239.20121226_TPIOT1.tgz       --- realtek new driver for TPLink AP throughput issue
   MD5SUM.TXT                                      --- md5 check sum
4. Patch guide
   Please run md5sum -c MD5SUM.TXT first to confirm all the files received are ok.
   All these patches are based on the patch release hdmidongle_REVB_R13.4_patch-20121115.tgz
   You need to do as following: R13.4 GA--->patch hdmidongle_REVB_R13.4_patch-20121115.tgz --> patch hdmidongle_REVB_R13.4_patch-20130118.tgz
   Supposed the ~/myandroid is your top directory of the android source tree.
   Please run the following command to apply the patches .
   $tar zfvx hdmidongle_REVB_R13.4_patch-20130118.tgz -C ~/
   $cd ~/myandroid
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0001-uboot_fastboot.patch --verbose
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0002-LDOBYPASS.patch --verbose
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0003-WifiDirect.patch --verbose
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0004-ntfs_support.patch --verbose
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0005-BT_enable.patch --verbose
   $git apply  ~/hdmidongle_REVB_R13.4_patch-20130118/0006-1G_boot_stable.patch --verbose
   $rm -rf kernel_imx/drivers/net/wireless/rtl8192ce
   $tar zfvx ~/hdmidongle_REVB_R13.4_patch-20130118/rtl8192ce_v4.0.0_6239.20121226_TPIOT1.tgz
   $tar zfvx ~/hdmidongle_REVB_R13.4_patch-20130118/ntfs-3g.tar.gz -C external
5. Build and run
new patch 0007-battery_always_full.patch:
Some games check the battery capacity to determine, it could run or not. But on the hdmi dongle we have no real battery, it makes some games can not run on the hdmi dongle.  We enable the fake battery let the andorid feel it has battery and it is 100% full.
1. Please use this patch after patch hdmidongle_REVB_R13.4_patch-20130118.tgz
2. suppose your android top directory is ~/myandroid and you put he 0007-battery_always_full.patch in your home directory ~
3. cd ~/myandroid
4. git apply --verbose ~/0007-battery_always_full.patch
5. please rebuild bootimage and run
patch   0008-boot_unlock_screen.patch:
When bootup, it goes into desktop rather than screen locker.
1. suppose your android top directory is ~/myandroid and you put the 0008-boot_unlock_screen.patch in your home directory ~
2. cd ~/myandroid
3. git apply --verbose ~/0008-boot_unlock_screen.patch
4. please rebuild systemtimage and run
2. cd ~/myandroid
patch 0009-uboot-enable-mmu-fix.patch:
This patch is for some issue in mmu enable.
It will improve all the modules in uboot.
1. suppose your android top directory is ~/myandroid and you put the 0009-uboot-enable-mmu-fix.patch in your home directory ~
2. cd ~/myandroid
3. git apply --verbose ~/0009-uboot-enable-mmu-fix.patch
4. please rebuild uboot  and rub
patch tarball   hdmidongle_REVB_R13.4_patch-20130123.tgz:
hdmidongle_REVB_R13.4_patch-20130123.tgz contains 0007-battery_always_full.patch  0008-boot_unlock_screen.patch 0009-uboot-enable-mmu-fix.patch
remove attached files here: 0007-battery_always_full.patch  0008-boot_unlock_screen.patch 0009-uboot-enable-mmu-fix.patch
Remove hdmidongle_REVB_R13.4_patch-20130123.tgz, hdmidongle_REVB_R13.4_patch-20130118.tgz and upload hdmidongle_REVB_R13.4_patch-20130124.tgz
hdmidongle_REVB_R13.4_patch-20130124.tgz  contains all patches in hdmidongle_REVB_R13.4_patch-20130123.tgz, hdmidongle_REVB_R13.4_patch-20130118.tgz.
Please use the  hdmidongle_REVB_R13.4_patch-20130124.tgz.
hdmidongle_REVB_R13.4_patch-20130131.tgz:
Besides all the patches released before.
Three more patches are added in this patch tar ball.
0010-boot_disable_screenlocker.patch                     --- For fix  0008-boot_unlock_screen.patch
0011-wm8326-DC_CONTROL_RATE.patch                        --- Change the wm8326 pmic rate to immediate voltage change
0012-Added-default-video-mode-check-make-sur.patch       --- Video mode check
hdmidongle_REVB_R13.4_patch-20130201.tgz:
Just change the readme  to place emphasis on   the 0006-1G_boot_stable.patch reverse
Reverse patch 0008-boot_unlock_screen.patch and 0006-1G_boot_stable.patch
0008-boot_unlock_screen.patch: it has some problem but doesn't do any harm to the hdmi dongle.
                                                 Please use 0010-boot_disable_screenlocker.patch, instead.
0006-1G_boot_stable.patch:  The patch take more cpu delay to adapt the pmic, we change the pmic setting
                                            in  0010-boot_disable_screenlocker.patch. This patch is no needed. And it will lower
                                           the performance. Please reverse it.
                                           cd ~/myandroid
                                           git apply --verbose ~/0006-1G_boot_stable.patch
hdmidongle_REVB_R13.4_patch-20130221.tgz:
There are three important fixes include in this release. They make the dongle stable.
1. lowmem killer issue fix
2. Update realtek wifi driver to fix the soft ap issue
3. Wifi p2p framework fix to resovle wifi direct only one side work issue
Please read the README.TXT for detail and the other changes.
hdmidongle_REVB_R13.4_patch-20130308.tgz:
This patch tar ball include all the patches in hdmidongle_REVB_R13.4_patch-20130221.tgz.
Besides, it has a new patches 0020-DL_WifiDirect_Concunrrent_crash_fix.patch to fix the crash issue on DL board.
HDMI Dongle HW:
HDMI Dongle schematic, pcb, gerber and BOM have been attached, the detailed hardware feature has been list below:
Android 4.x HDMI Dongle SPECIFICATION
Core Configure
Operating SystemAndroid 4.x Operating System Based on Micro-PC Platform
CPU ProcessorFreescale i.MX6x DualLite/Quad Core
DRAM StorageDDR3 1GigaByte Size, Data rate 1066MT/s
Flash Storage4GigaByte NAND flash ROM
Power System
Power SupplyDC JACK / Micro USB : 5V/2A
LED StatusGreen: Power ON; Red: System Run
Socket/Connector
MicroSD SocketSDXC Support, Up to 32GB size
USB HOST 2.0USB 2.0 HOST Support
USB OTG 2.0USB 2.0 OTG Support
Display/Audio
HDMI OutputHDMI TypeA Plug connector, 1080p@60Hz output
Video DecoderSupport Variety of Video Format: MPEG4/H.263/H.264/MJPEG/Xvid/VC-1/WMV/MPEG2/VP8...
Audio DecoderSupport Variety of Audio Format: MP3/AAC/LPCM/FLAC/AMR/AC3/WMA/Vorbis
GPU SupportGC2000 GPU core,2D/3D engine support,OpenGL support
Wireless Network
WiFi NetworkIEEE 802.11b/g/n,Up to 300Mbps,AP/P2P/Sta Mode Support
Others
KeyRecovery key support
RevB2
OTT TV BOX LINK: https://community.freescale.com/docs/DOC-94561
JB4.2 patches link : Patches for HDMI Dongle JB4.2.2_1.0.0-GA Release
タグ(2)
添付
コメント
We are designing this products, how to get your support?
Thank you very much, how can I get you and Mr.Jiang Wei's contact details?
Is the HDMI dongle available as a reference design?
Please contact our marking or sale guys.
Can you provide the contacts?
I contacted freescale sale support they said the only reference design were for the MCIMX6Q-SDP and MCIMX6Q-SDB eval boards.
This solution is completely made by chinese team.  You'd better ask the local sales ship from China.
I'd be interested in add support for it in Yocto; that's why I asked.
Someone I can contact to discuss it?
So far, we have no support for Yocto, but  unbuntu and android.   system is ready there.
How can we get uboot source and  ubuntu image?
There are two ways you can choose. you can use the last release you have and we can provide patch.
Another way is you can wait for the next release. The next release will have hdmi dongle support.
Do you know when next full release is planned for?
Also how can we get your contact details?
Should be soon in next month. You can call our sale to get the release plan.
For the contact detail, you can visit our support webpage and find the local sale.
Thanks for that. I've provided more instructions to build it in Ubuntu 12.04 64-bit in case some are interested.
http://www.cnx-software.com/2013/02/06/u-boot-linux-kernel-and-android-patches-for-freescale-i-mx6-h...
Great work! The schematics include additional circuity for LVDS, SATA etc, it doesn't look like the pcb layout include the io lines for theses? Furthermore what type of cooling heatsink would be the preferred option considering the small dimensions of the device.
Hi Jas, the NVCC_LVDS2P5 must be powered for this power is not only for LVDS display interface, but also for DDR I/O. This pin cannot be disconnected, even if the LVDS interface is not used. The SATA circuits are reserved for POWER ESATA interface which has not been used on revB2. As to the thermal design, aluminium is preferred for the heatsink.
It would be good if there was a TV box reference design with HDMI, USB, Ethernet and SATA.
The R13.4 GA release is no longer available and the patches don't seem to work with R13.4.1.  Is there another way to obtain the R13.4 GA Android source code?
Is this board available now ?
I'd like to buy this mini PC for evaluation.
M.Phuong
The board is available, you can ask fae to get it.
Dear Sir,
Sorry, what fae means ?
Could you please show me the contact ?
Hi Sir,
Sorry, you can not get the board for we do not sale the board, you can make the PCB by yourself.
please refer to link https://community.freescale.com/docs/DOC-94817 to get patches for JB4.2 hdmi dongle
Dear all,this is henry ,According to the freescales data ,we bulit  the PCBA samples ,if any body need this type samples ,pls contact with me .or you can leave some information .
[email protected]
How much cost each sample?
Cost 1~10 pcs     300USD/Unit
        11~50pcs    200USD/Unit
        51~100pcs   150USD/Uint
       >100pcs      Negotiate the Price .
For the first bacth had been sold out ,we begin the second bacth booking . And get the 50 pcs order total ,we will run the batch .
Hello Mr. Jiangwei,
Could you please provide the WM8326 config EEPROM data ?
Thank you very much.
Hi ,
         I am having imx6q sabrelite board.
Is HDMI dongle android is same as normal android runs on imx6?
If want to make same thing on sabrelite board,What will be changes i need to do?
Pratik
Hi Pratik,
Is there a reason you're not using our (Boundary Devices') Android?
We fully support Android on the SABRE Lite platform:
The latest published binary release is '4.3-beta', but our source trees have been updated to include 4.3-ga.
     http://boundarydevices.com/second-release-jellybean-4-3-beta-mx6/
If you follow our blog, you'll see that we're documenting most of the steps we take:
     http://boundarydevices.com/tag/android/
Hi Eric,
     Thanks for fast reply, I am using imx6-jb-sdcard-20130628.img.gz on Board.
when I go through HDMI Dongle Design I Think to try same think out of sabrelite.
But you are saying Boundary Device's android is doing same thing as this dongle is doing , if I am right.
Will you please clarify that.
Thanks ,
Pratik.
Hi Pratik,
The image you listed is one of ours (a Boundary Devices' version), though a bit out-dated. Our latest Jellybean version is the second release pointed to above.
I haven't gone through the details, but I suspect the HDMI dongle release has the same origin, but has been tailored for different hardware.
Dear Wei:
   Dose you have config file of wm8326? Is it same with OTT  TV box?
Hi All:
hdmi dongle board can't bring up. When I use DDR_Stress_Tester_V1.0.2 to test the ddr, the board can't pass the DQS  gating, read/write delay calibration.  Pls see the log below:
What ARM core speed would you like to run?
Type 0 for 650MHz, 1 for 800MHz, 2 for 1GHz, 3 for 1.2GHz
  ARM set to 650MHz
Please select the DDR density per chip select (in bytes) on the board
Type 0 for 2GB; 1 for 1GB; 2 for 512MB; 3 for 256MB; 4 for 128MB; 5 for 64MB; 6
for 32MB
For maximum supported density (4GB), we can only access up to 3.75GB.  Type 9 to
select this
  DDR density selected (MB): 1024
Calibration will run at DDR frequency 528MHz. Type 'y' to continue.
If you want to run at other DDR frequency. Type 'n'
Enter the DDR frequency for calibration [350MHz to 528MHz]:
350
  The freq you entered was: 350
  DDR Freq: 352 MHz
Would you like to run the write leveling calibration? (y/n)
  Please enter the MR1 value on the initilization script
  This will be re-programmed into MR1 after write leveling calibration
  Enter as a 4-digit HEX value, example 0004, then hit enter
0004 You have entered: 0x0004
Start write leveling calibration
Write leveling calibration completed
MMDC_MPWLDECTRL0 ch0 after write level cal: 0x00010001
MMDC_MPWLDECTRL1 ch0 after write level cal: 0x00180018
MMDC_MPWLDECTRL0 ch1 after write level cal: 0x000A0013
MMDC_MPWLDECTRL1 ch1 after write level cal: 0x000A0015
Would you like to run the DQS gating, read/write delay calibration? (y/n)
Starting DQS gating calibration...
. . . . . . . . . . . . . . ERROR FOUND, we can't get suitable value !!!!
dram test fails for all values.
The DDR stress test can run with an incrementing frequency or at a static freq
To run at a static freq, simply set the start freq and end freq to the same valu
e
Would you like to run the DDR Stress Test (y/n)?
End of Test !
^C
D:\DDR_Stress_Tester_V1.0.2\DDR_Stress_Tester_V1.0.2\Binary>
When I use MFG tools of OTT TV box, It stopped at Loading uboot
Inline image 2
So, What's wrong? DDR is not ok?
%3CLINGO-SUB%20id%3D%22lingo-sub-1110802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%ABSW%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20font-size%3A%2018pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AFR13.4%20GA%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9FHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF%20r13.4-ga-add-on-patches%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82R13.4%20GA%E3%83%91%E3%83%83%E3%83%81(%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%E3%83%91%E3%83%83%E3%83%81%E3%81%AA%E3%81%A9)%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8B%E3%82%89revb_dongle_patch_install.sh%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20121115.tgz%E3%81%AE%E9%81%A9%E7%94%A8%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%3CP%3E1.%20Android%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%81%8C%20~%2Fmyandroid%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E2.%20tar%20zfvx%20hdmidongle_REVB_R13.4_patch-20121115.tgz%20-C%20~%2F%3C%2FP%3E%3CP%3E3.%20revb_dongle_patch_install.sh%E3%82%92~%2F%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E4.%20cd%20hdmidongle_REVB_R13.4_patch%3C%2FP%3E%3CP%3E5.%20~%2Frevb_dongle_patch_install.sh%3C%2FP%3E%3CP%3E6.%20revb_dongle_patch_install.sh%E3%81%AF%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A8%E3%81%97%E3%81%A6~%2Fmyandroid%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E7.%20Android%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%83%88%E3%83%83%E3%83%97%E3%81%8C~%2Fmyandroid%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81~%2Fmyandroid_ICS%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81~%2Frevb_dongle_patch_install.sh%20~%2Fmyandroid_ICS%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81hdmidongle_REVB_R13.4_patch-20130118.tgz%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E1.%E6%96%B0%E6%A9%9F%E8%83%BD%3A%3CBR%20%2F%3E%E3%81%82%E3%82%8B%E3%80%82uboot%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3Eb.LDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%3CBR%20%2F%3Ec.NTFS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3Ed.%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20A2DP%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E2.%E3%83%90%E3%82%B0%E4%BF%AE%E6%AD%A3%3CBR%20%2F%3E%E3%81%82%E3%82%8B%E3%80%82WifiDirect%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Eb.TPLink%20AP%E3%81%A7%E3%81%AErealtek%E3%81%AE%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E3.%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AA%E3%82%B9%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABREADME.TXT%20---%3CBR%20%2F%3E0001-uboot_fastboot.patch%20---%20uboot%20fastboot%20%E3%83%91%E3%83%83%E3%83%81%3CBR%20%2F%3E0002-LDOBYPASS.%E3%83%91%E3%83%83%E3%83%81---%20LDO%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E0003-WifiDirect.%E3%83%91%E3%83%83%E3%83%81---%20WiFi%20%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%83%91%E3%83%83%E3%83%81%3CBR%20%2F%3E0004-ntfs_support.patch%20---%20NTFS%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%83%81%3CBR%20%2F%3E0005-BT_enable.patchBluetoothA2DP%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B---%3CBR%20%2F%3E0006-1G_boot_stable.patch%20---%201G%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%AE%89%E5%AE%9A%E3%81%95%E3%81%9B%E3%82%8B%3CBR%20%2F%3Entfs-3g.tar.gz---%20NTFS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9NTFS-3G%3CBR%20%2F%3Ertl8192ce_v4.0.0_6239.20121226_TPIOT1.tgz---%20realtek%20TPLink%20AP%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EMD5SUM.TXT%20---%20md5%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E4.%20%E3%83%91%E3%83%83%E3%83%81%E3%82%AC%E3%82%A4%E3%83%89%3CBR%20%2F%3E%E6%9C%80%E5%88%9D%E3%81%ABmd5sum%20-c%20MD5SUM.TXT%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E3%83%91%E3%83%83%E3%83%81%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20hdmidongle_REVB_R13.4_patch-20121115.tgz%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3BR13.4%20GA---%26gt%3Bpatch%20hdmidongle_REVB_R13.4_patch-20121115.tgz%20--%26gt%3B%20patch%20hdmidongle_REVB_R13.4_patch-20130118.tgz%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B~%2Fmyandroid%20%E3%81%8C%20android%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%9C%80%E4%B8%8A%E4%BD%8D%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%24tar%20zfvx%20hdmidongle_REVB_R13.4_patch-20130118.tgz%20-C%20~%2F%3CBR%20%2F%3E%24cd%20~%2Fmyandroid%3CBR%20%2F%3E%24git%20%E9%81%A9%E7%94%A8%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0001-uboot_fastboot.patch%20--verbose%3CBR%20%2F%3E%E9%81%A9%E7%94%A8%24git%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0002-LDOBYPASS.patch%20--verbose%3CBR%20%2F%3E%24git%20%E9%81%A9%E7%94%A8%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0003-WifiDirect.patch%20--verbose%3CBR%20%2F%3E%24git%20%E9%81%A9%E7%94%A8%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0004-ntfs_support.patch%20--verbose%3CBR%20%2F%3E%24git%20%E9%81%A9%E7%94%A8%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0005-BT_enable.patch%20--verbose%3CBR%20%2F%3E%24git%20%E9%81%A9%E7%94%A8%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2F0006-1G_boot_stable.patch%20--verbose%3CBR%20%2F%3E%24rm%20-RF%20kernel_imx%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2F%E3%83%8D%E3%83%83%E3%83%88%2F%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%2FRTL8192CE%3CBR%20%2F%3E%24tar%20zfvx%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2Frtl8192ce_v4.0.0_6239.20121226_TPIOT1.tgz%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%24tar%20zfvx%20~%2Fhdmidongle_REVB_R13.4_patch-20130118%2Fntfs-3g.tar.gz%20-C%20%E5%A4%96%E9%83%A8%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E5.%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%83%E3%83%810007-battery_always_full.patch%3A%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%A0%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E5%AE%B9%E9%87%8F%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AB%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%A0%E3%81%AFHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%81%BD%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AA%E3%83%83%E3%83%89%E3%81%AB%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81100%25%E3%81%84%E3%81%A3%E3%81%B1%E3%81%84%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%84%9F%E3%81%98%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E3%83%91%E3%83%83%E3%83%81%20hdmidongle_REVB_R13.4_patch-20130118.tgz%20%E3%81%AE%E5%BE%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E2.%20Android%E3%81%AE%E3%83%88%E3%83%83%E3%83%97%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C~%2FmyAndroid%E3%81%A7%E3%80%81%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB0007-battery_always_full.patch%E3%82%92%E7%BD%AE%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99~%3C%2FP%3E%3CP%3E3.%20cd%20~%2Fmyandroid%3C%2FP%3E%3CP%3E4.%20git%20apply%20--verbose%20~%2F0007-battery_always_full.patch%3C%2FP%3E%3CP%3E5.%20bootimage%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%810008-boot_unlock_screen.patch%3A%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%AD%E3%83%83%E3%82%AB%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%20Android%E3%81%AE%E3%83%88%E3%83%83%E3%83%97%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C~%2FmyAndroid%E3%81%A7%E3%80%810008-boot_unlock_screen.patch%E3%82%92%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%BD%AE%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99~%3C%2FP%3E%3CP%3E2.%20cd%20~%2Fmyandroid%3C%2FP%3E%3CP%3E3.%20git%20apply%20--verbose%20~%2F0008-boot_unlock_screen.patch%3C%2FP%3E%3CP%3E4.%20SystemtImage%E3%82%92%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E2.%20cd%20~%2Fmyandroid%3C%2FP%3E%3CP%3E3.%20git%20apply%20--verbose%20~%2F0008-boot_unlock_screen.patch%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%200009-uboot-enable-mmu-fix.patch%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81mmu%20enable%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81uboot%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E6%94%B9%E5%96%84%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%20Android%E3%81%AE%E3%83%88%E3%83%83%E3%83%97%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C~%2FmyAndroid%E3%81%A7%E3%80%810009-uboot-enable-mmu-fix.patch%E3%82%92%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%BD%AE%E3%81%84%E3%81%9F%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99~%3C%2FP%3E%3CP%3E2.%20cd%20~%2Fmyandroid%3C%2FP%3E%3CP%3E3.%20git%20apply%20--verbose%20~%2F0009-uboot-enable-mmu-fix.patch%3C%2FP%3E%3CP%3E4.%20uboot%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6RUB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%20tarball%20hdmidongle_REVB_R13.4_patch-20130123.tgz%3A%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130123.tgz%20%E3%81%AB%E3%81%AF%200007-battery_always_full.patch%200008-boot_unlock_screen.patch%200009-uboot-enable-mmu-fix.patch%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3A%200007-battery_always_full.patch%200008-boot_unlock_screen.patch%200009-uboot-enable-mmu-fix.patch%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130123.tgz%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82hdmidongle_REVB_R13.4_patch-20130118.tgz%20%E3%81%A8%20hdmidongle_REVB_R13.4_patch-20130124.tgz%20%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130124.tgzhdmidongle_REVB_R13.4_patch-20130123.tgz%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82hdmidongle_REVB_R13.4_patch-20130118.tgz%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130124.tgz%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130131.tgz%3A%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%BF%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%81%95%E3%82%89%E3%81%AB3%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E0010-boot_disable_screenlocker.patch%20---%200008-boot_unlock_screen.patch%20%E3%82%92%E4%BF%AE%E6%AD%A3%3C%2FP%3E%3CP%3E0011-wm8326-DC_CONTROL_RATE.patch%20---%20wm8326%20pmic%20%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E5%8D%B3%E6%99%82%E9%9B%BB%E5%9C%A7%E5%A4%89%E6%9B%B4%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E0012-%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF----default-video-mode-check-make-sur.patch%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130201.tgz%3A%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ereadme%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%810006-1G_boot_stable.patch%E3%81%AE%E9%80%86%E3%81%AB%E9%87%8D%E7%82%B9%E3%82%92%E7%BD%AE%E3%81%8F%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B9%20%E3%83%91%E3%83%83%E3%83%81%200008-boot_unlock_screen.patch%20%E3%81%A8%200006-1G_boot_stable.patch%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E0008-boot_unlock_screen.patch%3A%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AB%E5%AE%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E0010-boot_disable_screenlocker.patch%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%82%3C%2FP%3E%3CP%3E0006-1G_boot_stable.patch%3A%E3%83%91%E3%83%83%E3%83%81%E3%81%AFpmic%E3%82%92%E9%81%A9%E5%BF%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AECPU%E9%81%85%E5%BB%B6%E3%82%92%E8%A6%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFpmic%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E0010-boot_disable_screenlocker.patch%E3%81%A7%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E4%B8%8B%E3%81%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%80%82%E9%80%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cd%20~%2Fmyandroid%3C%2FP%3E%3CP%3Egit%20apply%20--verbose%20~%2F0006-1G_boot_stable.patch%20%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130221.tgz%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%813%20%E3%81%A4%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E4%BF%AE%E6%AD%A3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%92%E5%AE%89%E5%AE%9A%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20LowMem%20%E3%82%AD%E3%83%A9%E3%83%BC%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%3C%2FP%3E%3CP%3E2.%20realtek%20wifi%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%80%81%E3%82%BD%E3%83%95%E3%83%88AP%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E3.%20Wifi%20p2p%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81Wi-Fi%E3%81%AF%E7%89%87%E5%81%B4%E3%81%AE%E3%81%BF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%9B%B4%E6%8E%A5%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81README.TXT%E3%82%92%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ehdmidongle_REVB_R13.4_patch-20130308.tgz%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%20tar%20%E3%83%9C%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81hdmidongle_REVB_R13.4_patch-20130221.tgz%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81DL%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%83%E3%83%810020-DL_WifiDirect_Concunrrent_crash_fix.patch%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381416186%22%20id%3D%22toc-hId-1304216531%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2024px%3B%22%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%ABHW%3A%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%80%81PCB%E3%80%81%E3%82%AC%E3%83%BC%E3%83%90%E3%83%BC%E3%80%81BOM%E3%81%8C%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A9%9F%E8%83%BD%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22width%3A%20731px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22xl77%22%20colspan%3D%222%22%20height%3D%2280%22%20style%3D%22border%3A0px%20solid%20black%3Btext-align%3A%20center%3Bborder-right-color%3A%20black%3Bborder-right-style%3A%20solid%3Bborder-right-width%3A%201.5pt%3B%22%20width%3D%22731%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font18%22%3EAndroid%204.x%20HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E4%BB%95%E6%A7%98%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl70%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E3%82%B3%E3%82%A2%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl72%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl68%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font17%22%3EMicro-PC%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FAndroid%204.x%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3ECPU%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl69%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font17%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6x%20DualLite%2F%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EDRAM%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font11%22%3EDDR3%201%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%881066MT%2Fs%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3E4%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88NAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5ROM%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl70%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E9%9B%BB%E6%BA%90%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl72%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E9%9B%BB%E6%BA%90%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3EDC%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%2F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADUSB%20%3A%205V%2F2A%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3ELED%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3E%E7%B7%91%3A%E9%9B%BB%E6%BA%90%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%B5%A4%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%AE%9F%E8%A1%8C%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl70%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%2F%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl72%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EMicroSD%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3ESDXC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E6%9C%80%E5%A4%A732GB%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font5%22%3EUSB%E3%83%9B%E3%82%B9%E3%83%882.0%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3EUSB%202.0%20HOST%20%E5%AF%BE%E5%BF%9C%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EUSB%20OTG%202.0%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3EUSB%202.0%20OTG%E5%AF%BE%E5%BF%9C%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl70%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%2F%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl72%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EHDMI%E5%87%BA%E5%8A%9B%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3EHDMI%20TypeA%E3%83%97%E3%83%A9%E3%82%B0%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%80%811080p%4060Hz%E5%87%BA%E5%8A%9B%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl75%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%93%E3%83%87%E3%82%AA%E5%BD%A2%E5%BC%8F%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3AMPEG4%20%2F%20H.263%20%2F%20H.264%20%2F%20MJPEG%20%2F%20Xvid%20%2F%20VC-1%20%2F%20WMV%20%2F%20MPEG2%20%2F%20VP8%20...%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl75%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E5%BD%A2%E5%BC%8F%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3AMP3%20%2F%20AAC%20%2F%20LPCM%20%2F%20FLAC%20%2F%20AMR%20%2F%20AC3%20%2F%20WMA%20%2F%20Vorbis%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EGPU%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl75%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EGC2000%20GPU%E3%82%B3%E3%82%A2%E3%80%812D%2F3D%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E5%AF%BE%E5%BF%9C%E3%80%81OpenGL%E5%AF%BE%E5%BF%9C%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl71%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl72%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3EWiFi%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3EIEEE%20802.11b%20%2F%20g%20%2F%20n%E3%80%81%E6%9C%80%E5%A4%A7300Mbps%E3%80%81AP%20%2F%20P2P%20%2F%20Sta%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl70%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22153%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22font26%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20class%3D%22xl74%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl73%22%20height%3D%2244%22%20style%3D%22border%3A0px%20solid%20black%3Bpadding-left%3A%2030px%3B%22%20width%3D%22153%22%3E%3CSPAN%20class%3D%22font10%22%3E%E3%82%AD%E3%83%BC%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22border%3A0px%20solid%20black%3B%22%20width%3D%22578%22%3E%3CSPAN%20class%3D%22font9%22%3E%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%AD%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22xl67%22%20height%3D%2242%22%20style%3D%22border%3A0px%20solid%20black%3B%22%3E%3C%2FTD%3E%3CTD%20class%3D%22xl76%22%20style%3D%22border%3A0px%20solid%20black%3Btext-align%3A%20center%3B%22%20width%3D%22578%22%3E%E3%83%AC%E3%83%96B2%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223620_3620.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223620_3620.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117160i1861C24529611315%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223620_3620.jpg%22%20alt%3D%223620_3620.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3620_3620.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1080.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1080.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F79753iF5EAC6DB3F944075%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG1080.jpg%22%20alt%3D%22IMG1080.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG1080.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223621_3621.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223621_3621.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117161i96C0C49DC0E7481D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223621_3621.jpg%22%20alt%3D%223621_3621.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3621_3621.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1335.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1335.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F11811iCFBD362D8EB4BC12%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG1335.jpg%22%20alt%3D%22IMG1335.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG1335.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223624_3624.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223624_3624.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117162iB97D1EFF1444B8A4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223624_3624.jpg%22%20alt%3D%223624_3624.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3624_3624.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1138.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG1138.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25012i63D3D5906368158B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG1138.jpg%22%20alt%3D%22IMG1138.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG1138.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOTT%20TV%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294561%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94561%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%3Ahttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94561%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJB4.2%20%E3%83%91%E3%83%83%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%20%3A%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211235%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294817%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94817%22%20target%3D%22_blank%22%3EHDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20JB4.2.2_1.0.0-GA%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FA%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%20HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82DDR_Stress_Tester_V1.0.2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ddr%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%20DQS%20%E3%82%B2%E3%83%BC%E3%83%88%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%81%85%E5%BB%B6%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%90%88%E6%A0%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Pls%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3C%2FP%3E%3CDIV%3E%E3%81%A9%E3%81%AEARM%E3%82%B3%E3%82%A2%E9%80%9F%E5%BA%A6%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CP%3E%3C%2FP%3E%3CP%3E650MHz%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%970%E3%80%81800MHz%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF1%E3%80%811GHz%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF2%E3%80%811.2GHz%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF3%3C%2FP%3E%3CP%3EARM%E3%82%92650MHz%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%AC%E3%82%AF%E3%83%88%E3%81%94%E3%81%A8%E3%81%AEDDR%E5%AF%86%E5%BA%A6%EF%BC%88%E3%83%90%E3%82%A4%E3%83%88%E5%8D%98%E4%BD%8D%EF%BC%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E2GB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF0%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%821GB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF1%E3%80%82512MB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF2%E3%80%82256MB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF3%E3%80%82128MB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF4%E3%80%8264MB%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF5%E3%80%826%3C%2FP%3E%3CP%3E32MB%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%80%E5%A4%A7%E5%AF%86%E5%BA%A6(4GB)%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%80%E5%A4%A73.75GB%E3%81%BE%E3%81%A7%E3%81%97%E3%81%8B%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%BF%E3%82%A4%E3%83%979%E3%81%8B%E3%82%89%3C%2FP%3E%3CP%3E%20%E3%81%93%E3%82%8C%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%26nbsp%3B%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9FDDR%E5%AF%86%E5%BA%A6%EF%BC%88MB%EF%BC%89%EF%BC%9A1024%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFDDR%E5%91%A8%E6%B3%A2%E6%95%B0528MHz%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cy%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E7%B6%9A%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%20DDR%20%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%82%E3%80%8Cn%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AEDDR%E5%91%A8%E6%B3%A2%E6%95%B0%5B350MHz%E3%80%9C528MHz%5D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E350%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%9F%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%3A%20350%3C%2FP%3E%3CP%3EDDR%E5%91%A8%E6%B3%A2%E6%95%B0%3A352MHz%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F(Y%2FN)%3C%2FP%3E%3CP%3E%26nbsp%3B%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%ABMR1%E3%81%AE%E5%80%A4%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%26nbsp%3B%E3%81%93%E3%82%8C%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%BE%8C%E3%81%ABMR1%E3%81%AB%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B4%E6%A1%81%E3%81%AE16%E9%80%B2%E6%95%B0%E5%80%A4%EF%BC%88%E4%BE%8B%EF%BC%9A0004%EF%BC%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E0004%20%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%AF%EF%BC%9A0x0004%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%BE%8C%E3%81%AEMMDC_MPWLDECTRL0%20ch0%20%E3%83%AC%E3%83%99%E3%83%AB%20CAL%3A%200x00010001%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%BE%8C%E3%81%AEMMDC_MPWLDECTRL1%20ch0%20%E3%83%AC%E3%83%99%E3%83%AB%20CA%3A%20CAL%3A%200x00180018%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%BE%8C%E3%81%AEMMDC_MPWLDECTRL0%20ch1%20%E3%83%AC%E3%83%99%E3%83%AB%20CA%3A%200x000A0013%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%BE%8C%E3%81%AEMMDC_MPWLDECTRL1%20ch1%20%E3%83%AC%E3%83%99%E3%83%AB%20CAL%3A%200x000A0015%3C%2FP%3E%3CP%3EDQS%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%81%85%E5%BB%B6%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F(Y%2FN)%3C%2FP%3E%3CP%3EDQS%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E.%20.%20.%20.%20.%20.%20.%20.%20.%20.%20.%20.%20.%20.%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%81%A9%E5%88%87%E3%81%AA%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDRAM%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%80%A4%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDDR%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%B8%8A%E6%98%87%E3%81%95%E3%81%9B%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%9D%99%E6%AD%A2%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E3%81%AA%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E9%96%8B%E5%A7%8B%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E7%B5%82%E4%BA%86%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%90%8C%E3%81%98%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Ee%3C%2FP%3E%3CP%3EDDR%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%83%86%E3%82%B9%E3%83%88(y%2Fn)%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%82%E4%BA%86!%3C%2FP%3E%3CP%3E%5EC%3C%2FP%3E%3CP%3ED%3A%5CDDR_Stress_Tester_V1.0.2%5CDDR_Stress_Tester_V1.0.2%5CBinary%26gt%3B%3C%2FP%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3EOTT%20TV%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AEMFG%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81uboot%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3CIMG%20alt%3D%22%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E7%94%BB%E5%83%8F%202%22%20class%3D%22jiveImage%22%20data-surl%3D%22https%3A%2F%2Fmail.google.com%2Fmail%2Fu%2F0%2F%3Fui%3D2%26amp%3Bik%3D8a66955361%26amp%3Bview%3Datt%26amp%3Bth%3D14496798bbeaa307%26amp%3Battid%3D0.1%26amp%3Bdisp%3Dsafe%26amp%3Brealattid%3Dii_144967960eb189e9%26amp%3Bzw%22%20src%3D%22https%3A%2F%2Fmail.google.com%2Fmail%2Fu%2F0%2F%3Fui%3D2%26amp%3Bik%3D8a66955361%26amp%3Bview%3Datt%26amp%3Bdisp%3Dsafe%26amp%3Brealattid%3Dii_144967960eb189e9%26amp%3Bzw%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%3B%20font-size%3A%20small%3B%22%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%80%81%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FDDR%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E9%AD%8F%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewm8326%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FOTT%20TV%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Pratik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%82%E3%81%AE(Boundary%20Devices%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%B0%91%E3%81%97%E5%8F%A4%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E6%9C%80%E6%96%B0%E3%81%AEJellybean%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%E8%B5%B7%E6%BA%90%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%AA%BF%E6%95%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eric%2C%3C%2FP%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Feula%3Ffile%3Dimx6-jb-sdcard-20130628.img.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eimx6-jb-sdcard-20130628.img.gz%20%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%92%E9%80%9A%E9%81%8E%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%BF%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81Boundary%20Device%E3%81%AEAndroid%E3%81%AF%E3%81%93%E3%81%AE%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%8C%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPratik.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Pratik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE(Boundary%20Devices%E3%81%AE)Android%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESABRE%20Lite%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%AEAndroid%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE%E5%85%AC%E9%96%8B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%20'4.3-beta'%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%204.3-ga%20%E3%82%92%E5%90%AB%E3%82%80%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fsecond-release-jellybean-4-3-beta-mx6%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fsecond-release-jellybean-4-3-beta-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%96%E3%83%AD%E3%82%B0%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Ftag%2Fandroid%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Ftag%2Fandroid%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFimx6q%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%ABAndroid%E3%81%AF%E3%80%81imx6%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E9%80%9A%E5%B8%B8%E3%81%AEAndroid%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%A4%E3%83%96%E3%83%A9%E3%82%A4%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%95%E3%82%92%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EPratik%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangwei%22%20target%3D%22_blank%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E6%B1%9F%E5%81%89%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWM8326%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0EEPROM%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-381416277%22%20id%3D%22toc-hId--503237932%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F340818%23340818%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%233778c7%3B%22%20target%3D%22_blank%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%20fresscale.com%20%E3%81%8B%E3%82%89%20gk802%20%E3%81%BE%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FH1%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F309881%22%20target%3D%22_blank%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%20fresscale.com%20%E3%81%8B%E3%82%89%20gk802%20%E3%81%BE%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8C%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EGK802%20%E3%81%AF%20HDMIDONGLE%20%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%84%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E8%B2%BB%E7%94%A8%E3%81%AF%E3%81%84%E3%81%8F%E3%82%89%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%98%E3%83%B3%E3%83%AA%E3%83%BC%E3%81%A7%E3%81%99%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFPCBA%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92bulit%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%82%82%E3%81%97%E4%BD%93%E3%81%8C%E3%81%93%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81pls%E3%81%AF%E7%A7%81%E3%81%A8%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E6%AE%8B%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22mailto%3Ahenry.sun%40dmautotech.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehenry.sun%40dmautotech.com%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJB4.2%20HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94817%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94817%3C%2FA%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B2%A9%E5%A3%B2%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7PCB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%20%E3%81%AA%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81fae%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E9%80%A3%E7%B5%A1%E5%85%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABfae%E3%82%92%E9%A0%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E7%8F%BE%E5%9C%A8%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9F%E3%83%8BPC%E3%82%92%E8%A9%95%E4%BE%A1%E7%94%A8%E3%81%AB%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EM.%E3%83%95%E3%82%A9%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ER13.4%20GA%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%20R13.4.1%20%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82R13.4%20GA%20Android%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%E3%80%81USB%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%80%81SATA%E3%82%92%E5%82%99%E3%81%88%E3%81%9FTV%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFJas%E3%80%81NVCC_LVDS2P5%E3%81%93%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%AFLVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81DDR%20I%20%2F%20O%E3%81%AB%E3%82%82%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%80%81LVDS%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E5%88%87%E6%96%AD%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SATA%E5%9B%9E%E8%B7%AF%E3%81%AF%E3%80%81revB2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84POWER%20ESATA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%86%B1%E8%A8%AD%E8%A8%88%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%92%E3%83%BC%E3%83%88%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%AF%20%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%20small%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%A2%E3%83%AB%E3%83%9F%E3%83%8B%E3%82%A6%E3%83%A0%3C%2FSPAN%3E%20%E3%81%8C%E5%A5%BD%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E7%96%B2%E3%82%8C%E6%A7%98%E3%81%A7%E3%81%97%E3%81%9F!%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E3%81%AFLVDS%E3%82%84SATA%E3%81%AA%E3%81%A9%E3%81%AE%E5%9B%9E%E8%B7%AF%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81PCB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AEio%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AF%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%AF%B8%E6%B3%95%E3%81%8C%E5%B0%8F%E3%81%95%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%A9%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%92%E3%83%BC%E3%83%88%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%8C%E5%A5%BD%E3%81%BE%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E9%83%A8%E3%81%AE%E4%BA%BA%E3%81%8C%E8%88%88%E5%91%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E5%82%99%E3%81%88%E3%81%A6%E3%80%81Ubuntu%2012.04%2064%E3%83%93%E3%83%83%E3%83%88%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.cnx-software.com%2F2013%2F02%2F06%2Fu-boot-linux-kernel-and-android-patches-for-freescale-i-mx6-hdmi-tv-dongles%2F%22%20title%3D%22http%3A%2F%2Fwww.cnx-software.com%2F2013%2F02%2F06%2Fu-boot-linux-kernel-and-android-patches-for-freescale-i-mx6-hdmi-tv-dongles%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.cnx-software.com%2F2013%2F02%2F06%2Fu-boot-linux-kernel-and-android-patches-for-freescale-i-mx6-hdmi-tv-dongles%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9D%A5%E6%9C%88%E3%81%AB%E3%81%AF%E3%82%82%E3%81%86%E3%81%99%E3%81%90%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E8%A8%88%E7%94%BB%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%B2%A9%E5%A3%B2%E3%81%AB%E9%9B%BB%E8%A9%B1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%80%A3%E7%B5%A1%E5%85%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88Web%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%80%81%E6%9C%80%E5%AF%84%E3%82%8A%E3%81%AE%E8%B2%A9%E5%A3%B2%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%95%E3%83%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%84%E3%81%A4%E4%BA%88%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E9%80%A3%E7%B5%A1%E5%85%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF2%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E5%BE%85%E3%81%A4%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81HDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Euboot%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8ubuntu%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81Yocto%E3%81%AB%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81unbuntu%E3%81%A8android%E3%81%AB%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EYocto%E3%81%A7%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E3%81%BF%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B1%E3%81%97%E5%90%88%E3%81%86%E3%81%9F%E3%82%81%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%A7%E3%81%8D%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E4%B8%AD%E5%9B%BD%E3%81%AE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%B8%AD%E5%9B%BD%E3%81%8B%E3%82%89%E3%81%AE%E7%8F%BE%E5%9C%B0%E8%B2%A9%E5%A3%B2%E8%88%B9%E3%81%AB%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9F%E6%96%B9%E3%81%8C%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%BB%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AFMCIMX6Q-SDP%E3%81%8A%E3%82%88%E3%81%B3MCIMX6Q-SDB%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fhomepage.jsp%3FnodeId%3D05%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fhomepage.jsp%3FnodeId%3D05%3C%2FA%3E%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%8F%97%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%80%A3%E7%B5%A1%E5%85%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9E%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E8%B2%A9%E5%A3%B2%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%E3%81%AF%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8Jiang%20Wei%E6%B0%8F%E3%81%AE%E9%80%A3%E7%B5%A1%E5%85%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HDMI%20%E3%83%89%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%82%92%E8%A8%AD%E8%A8%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-22-2012 06:41 PM
更新者:
