Getting Android5.1.1 Source Code (For China only)
Some Chinese customers using i.MX series SoC maybe encounter some issues when they download android , u-boot & kernel source code by 'git' command, the following steps will show customer how to get them:
1. Getting repo
--No.1 methord
# cd ~
# mkdir myandroid
# mkdir bin
# cd bin
# git clone git://aosp.tuna.tsinghua.edu.cn/android/git-repo.git/
<if git failed, use : git clone https://aosp.tuna.tsinghua.edu.cn/android/git-repo.git/>
# cd git-repo
# cp ./repo ../
--No.2 methord
# cd ~
# mkdir bin
# curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
# chmod a+x ~/bin/repo
[Note]Customers can select one of above to get "repo"
2. Modifying repo File
Open ~/bin/repo file with 'gedit' and Change google address
From
       REPO_URL = 'https://gerrit.googlesource.com/git-repo'
To
       REPO_URL = 'git://aosp.tuna.tsinghua.edu.cn/android/git-repo'
       like following:
## repo default configuration
REPO_REV = 'stable'
3、Setting email address
# cd ~/myandroid
# git config --global user.email "[email protected]"
# git config --global user.name "weidong.sun"
[ Email & Name should be yours]
4、Getting manifest
# ~/bin/repo init -u https://aosp.tuna.tsinghua.edu.cn/android/platform/manifest -b android-5.1.1_r1
# cd ~/myandroid/.repo
# gedit manifest.xml
       Then change the value of fetch to " git://aosp.tuna.tsinghua.edu.cn/android/ ", like following:
<manifest>
  <remote name="aosp"
           fetch="git://aosp.tuna.tsinghua.edu.cn/android/" />
  <default revision="refs/tags/android-5.1.1_r1"
[Note] android-5.1.1_r1 is version of branch,customer can change it to another.
5、# ~/bin/repo sync
         [Note] During runing repo sync, maybe errors will occur like the following:
* [new tag]         studio-1.4 -> studio-1.4
error: Exited sync due to fetch errors
         Then 'repo sync' exits. But don't worry about it, continue to run the command please !
" ~/bin/repo sync", downloading source code will be continous.
6、Getting Cross Compiler
# cd ~/myandroid/prebuilts/gcc/linux-x86/arm
# git clone https://aosp.tuna.tsinghua.edu.cn/android/platform/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6
# cd arm-eabi-4.6
# git checkout android-4.4.3_r1
7、Getting linux kernel source code
       Probably, customer can't normally get linux kernel by using "git clone" command, she can download it directly from the following weblink:
       http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/
       At first, create a temperary directory, then download kernel into the directory. see following steps:
# cd ~ /Downloads
# mkdir linux-kernel
  Atfer downloading l5.1.1_2.1.0-ga.tar.gz, use 'tar zxvf l5.1.1_2.1.0-ga.tar.gz' command to decompress it.
       Then you can find a subdirectory name " l5.1.1_2.1.0-ga" is created, linux source code is in the directory, we should copy all files in the directory to ~/myandroid/kernel_imx/
# cd ~/myandroid
# mkdir kernel_imx
# cd kernel_imx
# cp -a ~ /Downloads/linux-kernel/l5.1.1_2.1.0-ga ./
8、Getting uboot source code
      http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/
       We can use similar way to that of linux kernel to get u-boot source code:
# cd ~ /Downloads
# mkdir u-boot
       Download l5.1.1_2.1.0-ga.tar.gz file, and save it in ~ /Downloads/ u-boot, then decompress it, then u-boot source code will be in ~ /Downloads/ u-boot / l5.1.1_2.1.0-ga/, we should copy all file in the path to ~/myandroid/bootable/bootloader/uboot-imx/
# cd ~/myandroid/bootable/bootloader
# mkdir uboot-imx
# cd uboot-imx
# cp -a ~ /Downloads/u-boot/l5.1.1_2.1.0-ga/* ./
9、Patch android BSP source code
       android_L5.1.1_2.1.0_consolidated-ga_core_source.gz is the name of patch. Run following command to patch android.
# copy android_L5.1.1_2.1.0_consolidated-ga_core_source.gz /opt/
# tar zxvf android_L5.1.1_2.1.0_consolidated-ga_core_source.gz
# cd /opt/ android_L5.1.1_2.1.0_consolidated-ga_core_source/code/
# tar zxvf L5.1.1_2.1.0_consolidated-ga.tar.gz
# cd ~/myandroid
# source /opt/ android_L5.1.1_2.1.0_consolidated-ga_core_source/code/ L5.1.1_2.1.0_consolidated-ga/ and_patch.sh
# help
# c_patch /opt/ android_L5.1.1_2.1.0_consolidated-ga_core_source/code/ L5.1.1_2.1.0_consolidated-ga/ imx_L5.1.1_2.1.0-ga
       If everything is OK, the following logs will display on console:
       Success: Now you can build the Android code for FSL i.MX platform
10、Patch Freescale extended feathures code
       Please refer to chapter 3.3 of Android_User's_Guide.pdf to patch another 2 files:
       (1) android_L5.1.1_2.1.0_consolidated-ga_omxplayer_source.gz
       (2) android_L5.1.1_2.1.0_consolidated-ga_wfdsink_source.gz
[Note]
      As for other steps, such as compiling etc, please refer to Android_User's_Guide.pdf that released by NXP.
TICS team
Weidong Sun
04/01/2016
コメント
mark
%3CLINGO-SUB%20id%3D%22lingo-sub-1123127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAndroid5.1.1%E3%81%AE%E5%85%A5%E6%89%8B%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89(%E4%B8%AD%E5%9B%BD%E3%81%AE%E3%81%BF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX%20%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BASoC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%B8%80%E9%83%A8%E3%81%AE%E4%B8%AD%E5%9B%BD%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81'git'%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7android%E3%80%81u-boot%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2016.0pt%3B%22%3E1.%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E2%97%8FNo.1%E3%83%A1%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23CD~%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20mkdir%20myandroid%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20mkdir%20bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20cd%20bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Egit%20clone%20git%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fgit-repo.git%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26lt%3B%3CSTRONG%3Egit%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3C%2FSTRONG%3E%3CSPAN%3Egit%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Faosp.tuna.tsinghua.edu.cn%252Fandroid%252Fgit-repo.git%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fgit-repo.git%2F%3C%2FA%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23%20cd%20git-repo%3C%2FP%3E%3CP%3E%23%20cp%20.%2Frepo%20..%2F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E2%97%8FNo.2%20%E3%83%A1%E3%83%88%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23CD~%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20mkdir%20bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%3CSPAN%3E%23%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fstorage.googleapis.com%2Fgit-repo-downloads%2Frepo%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fstorage.googleapis.com%2Fgit-repo-downloads%2Frepo%3C%2FA%3E%3CSPAN%3E%20%26gt%3B%20~%2Fbin%2Frepo%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%23%20chmod%20a%2Bx%20~%2Fbin%2Frepo%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%5B%3CSTRONG%3E%E5%8F%82%E8%80%83%3C%2FSTRONG%3E%5D%3CSTRONG%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%80%8C%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%80%8D%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E2.%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E3%80%8Cgedit%E3%80%8D%E3%81%A7~%2Fbin%2Frepo%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81Google%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20REPO_URL%20%3D%20'%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%3C%2FA%3E%3CSPAN%3E'%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3ETo%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3C%2FSTRONG%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20REPO_URL%20%3D%20'git%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fgit-repo'%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%23%23%3C%2FP%3E%3CP%3EREPO_URL%20%3D%20'%3CSTRONG%3Egit%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fgit-repo%3C%2FSTRONG%3E'%3C%2FP%3E%3CP%3EREPO_REV%20%3D%20'%E5%AE%89%E5%AE%9A'%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E3%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%23%20cd%20~%2Fmyandroid%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%3CSPAN%3E%23%20git%20config%20--global%20user.email%20%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aweidong.sun%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eweidong.sun%40nxp.com%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Verdana'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%23%20git%20config%20--global%20user.name%20%22weidong.sun%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%5B%20Email%20%26amp%3B%20Name%20should%20be%20yours%5D%20(%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E5%90%8D%E5%89%8D%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99)%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2015.0pt%3B%22%3E4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2015.0pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2015.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%20%E3%81%AE%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20CourierStd%3B%22%3E~%2Fbin%2Frepo%20init%20-u%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fplatform%2Fmanifest%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fplatform%2Fmanifest%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20CourierStd%3B%22%3E%20-b%20android-5.1.1_r1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%2Fmyandroid%2F.repo%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20gedit%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3Emanifest.xml%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%20%E6%AC%A1%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20fetch%20%E3%81%AE%E5%80%A4%E3%82%92%E3%80%8C%3C%2FSPAN%3E%20%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3Egit%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%20%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%3CMANIFEST%3E%3C%2FMANIFEST%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%20%3CREMOTE%20name%3D%22aosp%22%3E%3C%2FREMOTE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fetch%3D%22%3CSTRONG%3Egit%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2F%3C%2FSTRONG%3E%22%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%20%3CDEFAULT%20revision%3D%22refs%2Ftags%2Fandroid-5.1.1_r1%22%3E%3C%2FDEFAULT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E......%3C%2FP%3E%3CP%3E%5B%E5%8F%82%E8%80%83%5D%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20CourierStd%3B%22%3E%3CSTRONG%3Eandroid-5.1.1_r1%E3%81%AF%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E5%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E~%2Fbin%2Frepo%20sync%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%E5%8F%82%E8%80%83%5D%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E......%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20red%3B%22%3E*%E3%80%90%E6%96%B0%E8%A6%8F%E3%82%BF%E3%82%B0%E3%80%91studio-1.4%20-%26gt%3B%20studio-1.4%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20red%3B%22%3Eerror%3A%20%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E5%90%8C%E6%9C%9F%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81'repo%20sync'%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%BF%83%E9%85%8D%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E7%B6%9A%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%22%20~%2Fbin%2Frepo%20sync%22%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AF%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20CourierStd%3B%22%3Ecd%20~%2Fmyandroid%2Fprebuilts%2Fgcc%2Flinux-x86%2Farm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%22%3E%3CSPAN%3E%23%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fplatform%2Fprebuilts%2Fgcc%2Flinux-x86%2Farm%2Farm-eabi-4.6%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Faosp.tuna.tsinghua.edu.cn%2Fandroid%2Fplatform%2Fprebuilts%2Fgcc%2Flinux-x86%2Farm%2Farm-eabi-4.6%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%22%3E%23cd%E3%81%AEarm-eabi-4.6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%22%3E%23%20git%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%20android-4.4.3_r1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%80%8Cgit%20clone%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AEWeb%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2F%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F33571i68C253D8F720E3D9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%81%BE%E3%81%9A%E3%80%81%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AA%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%20%2F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20mkdir%20linux-kernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EAtfer%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89l5.1.1_2.1.0-ga.tar.gz%E3%80%81%E3%80%8Ctar%20zxvf%20l5.1.1_2.1.0-ga.tar.gz%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%20%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%B5%E3%83%96%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%90%8D%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3El5.1.1_2.1.0-ga%E3%80%8D%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%80%81Linux%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92~%2Fmyandroid%2Fkernel_imx%2F%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%2Fmyandroid%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20mkdir%20kernel_imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20kernel_imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cp%20-a%20~%20%2FDownloads%2Flinux-kernel%2Fl5.1.1_2.1.0-ga%20.%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3Euboot%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%80%8Cgit%20clone%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AEWeb%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2F%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F33657iC7ADC9631C2B4651%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%9811.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81u-boot%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%20%2F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20mkdir%20u-boot%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3El5.1.1_2.1.0-ga.tar.gz%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81~%2FDownloads%2F%20u-boot%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%80%81%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81u-boot%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF~%2FDownloads%2F%20u-boot%20%2F%20l5.1.1_2.1.0-ga%2F%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%82%B9%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20~%2Fmyandroid%2Fbootable%2Fbootloader%2Fuboot-imx%2F%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%2Fmyandroid%2Fbootable%2Fbootloader%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20mkdir%20uboot-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20uboot-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cp%20-a%20%3CSPAN%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E~%20%2F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%2Fu-boot%2F%3CSPAN%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3El5.1.1_2.1.0-ga%2F%3C%2FSPAN%3E%3C%2FSPAN%3E*.%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E9%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EPatch%20android%20BSP%20source%20code%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3Eandroid_L5.1.1_2.1.0_consolidated-ga_core_source.gz%E3%81%AF%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81Android%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20%E3%82%B3%E3%83%94%E3%83%BC%20android_L5.1.1_2.1.0_consolidated-ga_core_source.gz%20%2Fopt%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%E3%82%BF%E3%83%BC%E3%83%ABzxvf%20android_L5.1.1_2.1.0_consolidated-ga_core_source.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20%2Fopt%2F%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3Eandroid_L5.1.1_2.1.0_consolidated-ga_core_source%2Fcode%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%E3%82%BF%E3%83%BC%E3%83%ABzxvf%20L5.1.1_2.1.0_consolidated-ga.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20cd%20~%2Fmyandroid%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C%20serif%3B%22%3E%20%E3%82%BD%E3%83%BC%E3%82%B9%20%2Fopt%2F%20android_L5.1.1_2.1.0_consolidated-ga_core_source%2Fcode%2F%20L5.1.1_2.1.0_consolidated-ga%2F%20and_patch.sh%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%20%E3%83%98%E3%83%AB%E3%83%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C%20serif%3B%22%3Ec_patch%20%2Fopt%2F%20android_L5.1.1_2.1.0_consolidated-ga_core_source%2Fcode%2F%20L5.1.1_2.1.0_consolidated-ga%2F%20imx_L5.1.1_2.1.0-ga%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8C%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20**************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%88%90%E5%8A%9F%3A%20%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81FSL%20i.MX%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8%E3%81%AE%20Android%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20**************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E10%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20%E5%AE%8B%E4%BD%93%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EAndroid_User%E3%81%AE3.3%E7%AB%A0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8Bs_Guide.pdf%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E(1)android_L5.1.1_2.1.0_consolidated-ga_omxplayer_source.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E(2)android_L5.1.1_2.1.0_consolidated-ga_wfdsink_source.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%5B%E6%B3%A8%5D%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AA%E3%81%A9%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81NXP%E3%81%8C%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BAndroid_User%20s_Guide.pdf%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETICS%E3%83%81%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EWeidong%20Sun%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E04%2F01%2F2016%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DualPlus6QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SoloX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6UL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Solo%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid5.1.1%E3%81%AE%E5%85%A5%E6%89%8B%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89(%E4%B8%AD%E5%9B%BD%E3%81%AE%E3%81%BF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8D%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-03-2016 09:51 PM
更新者:
