Flashing Linux BSP using UUU
Hello everyone, this document will explain on how to use the UUU (Universal Update Utility) tool to flash Linux to an i.MX device (i.MX 8MM).
Requirements:
UUU auto script
For this example is used the L4.14.98_2.0.0_ga demo image for the i.MX 8MM, inside the demo image we will find the auto script, which by default flash the eMMC of the board, the structure of the script is as following
uuu_version 1.2.39
# This command will be run when i.MX6/7 i.MX8MM, i.MX8MQ
SDP: boot -f imx-boot-imx8mmevk-sd.bin-flash_evk
# This command will be run when ROM support stream mode
# i.MX8QXP, i.MX8QM
SDPS: boot -f imx-boot-imx8mmevk-sd.bin-flash_evk
# These commands will be run when use SPL and will be skipped if no spl
# SDPU will be deprecated. please use SDPV instead of SDPU
SDPU: delay 1000
SDPU: write -f imx-boot-imx8mmevk-sd.bin-flash_evk -offset 0x57c00
SDPU: jump
# if (SPL support SDPV)
SDPV: delay 1000
SDPV: write -f imx-boot-imx8mmevk-sd.bin-flash_evk -skipspl
SDPV: jump
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv mmcdev ${emmc_dev}
FB: ucmd mmc dev ${emmc_dev}
FB: flash -raw2sparse all fsl-image-validation-imx-imx8mmevk.sdcard
FB: flash bootloader imx-boot-imx8mmevk-sd.bin-flash_evk
FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
FB: ucmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
FB: done
In short, when the board goes into serial downloader mode UUU downloads the bootloader to internal RAM, once done and uboot is running, through fastboot utility it will flash .sdcard file and uboot to the eMMC on the board.
More information about the protocol UUU use please refer to the UUU documentation (UUU.pdf) section 5 Supported protocol.
Running the tool
In order to run the tool the binary of uuu needs to be downloaded, the binary files can be downloaded from the link above, uuu.exe is for Windows and uuu is for Linux.
Once downloaded it can be placed inside the same file as the demo image, this so it is easy to run and cleaner on the shell commands.
Windows
In windows OS the tool should be run using the Windows PowerShell in administrator mode, once open we will run the next commands:
> .\uuu.exe uuu.auto
Linux
>$ sudo ./uuu uuu.auto
The tool will start running and should be waiting for any i.MX device to be detected by host pc
Preparing the board
For the board to be flashed it is needed to be in download mode, the switch configuration (i.MX 8MM EVK) is as following:
SW1101  -  1010XXXXXX
SW1102  -  XXXXXXXXX0
Connect a USB cable from the host pc which will run the tool to the USB OTG/TYPE C port, usually specified as download, on the board.
Connect a USB cable from the host to the OTG-to-UART for console output, usually specified as debug, on the board.
Open terminal emulator program with the following settings:
Bits per second - 115200
Data bits - 8
Parity - None
Stop bits - 1
Flow control - None
Power on the board, the download will start and the serial prompt will show the progress in uboot, wait until the tool show success.
Finally power off the board and change the switch configuration to boot from the eMMC, power on the board again and it should boot successfully!
Built in scripts
One can use the built in scripts using the -b option to burn the bootloader  and the rootfs to the target flash, just type the command accordingly to the target flash device.
 SD
Write bootloader only:
Windows:
> .\uuu.exe -b sd <bootloader>
Linux:
$ sudo ./uuu -b sd <bootloader>
Replace <bootloader> for your .imx/.bin file, example using the i.MX 8MM for Windows and Linux respectively below.
> .\uur.exe -b sd imx-boot-imx8mmevk-sd.bin-flash_evk
$ sudo ./uuu -b sd imx-boot-imx8mmevk-sd.bin-flash_evk
Write whole Linux image
Windows:
> .\uuu.exe -b sd_all <bootloader> <rootfs>.sdcard
Linux:
$ sudo ./uuu -b sd_all <bootloader> <rootfs>.sdcard
Replace <bootloader> and <rootfs> for the name of your .imx/.bin and .sdcard files respectively, example using the i.MX 8MM below.
> .\uuu.exe -b sd_all  imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard
$ sudo ./uuu -b sd_all  imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard
eMMC
Windows:
> .\uuu.exe -b emmc <bootloader>
Linux:
$ sudo ./uuu -b emmc <bootloader>
Example using i.MX 8MM
> .\uuu.exe -b emmc imx-boot-imx8mmevk-sd.bin-flash_evk
$ sudo ./uuu -b emmc imx-boot-imx8mmevk-sd.bin-flash_evk
Windows:
> .\uuu.exe -b emmc_all <bootloader> <rootfs>.sdcard
Linux:
$ sudo ./uuu -b emmc_all <bootloader> <rootfs>.sdcard
> .\uuu.exe -b emmc_all imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard
$ sudo ./uuu -b emmc_all imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard
Hope this will helpful for everyone who is starting to use this flashing tool.
评论
I compiled uboot, image and rootfs with yocto source. He is not in .sdcard and .bin-flash_evk format. How do I do this?
Do you know if the OP-TEE project is integrated in L4.14.98_2.0.0_ga_images_MX8MMEVK? TFA too?
%3CLINGO-SUB%20id%3D%22lingo-sub-1110679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20UUU%20%E5%88%B7%E5%86%99%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%E6%9C%AC%E6%96%87%E4%BB%B6%E5%B0%86%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8UUU%EF%BC%88Universal%20Update%20Utility%EF%BC%89%E5%B7%A5%E5%85%B7%E5%B0%86Linux%E5%88%B7%E5%86%99%E5%88%B0i.MX%E8%AE%BE%E5%A4%87%EF%BC%88i.MX%208MM%EF%BC%89%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E8%A6%81%E6%B1%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fevaluation-kit-for-thebr-i.mx-8m-mini-applications-processor%3A8MMINILPD4-EVK%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMX%208M%20Mini%20EVK%3C%2FA%3E%3C%2FLI%3E%3CLI%3EUUU%20%E5%B7%A5%E5%85%B7%E6%96%87%E6%A1%A3%E8%A7%81%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPmicro%2Fmfgtools%2Freleases%2Fdownload%2Fuuu_1.2.135%2FUUU.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%AD%A4%E5%A4%84%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL4.14.98_2.0.0_MX8MM%26amp%3BappType%3Dlicense%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELinux%20Binary%20Demo%20Files%20-%20i.MX%208MMini%20EVK%20%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPmicro%2Fmfgtools%2Freleases%2Ftag%2Fuuu_1.2.135%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUUU%201.2.135%20%E4%BA%8C%E8%BF%9B%E5%88%B6%20%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%E4%B8%B2%E5%8F%A3%E7%BB%88%E7%AB%AF%E6%A8%A1%E6%8B%9F%E5%99%A8%EF%BC%88Tera%20Term%20%E6%88%96%20PuTTY%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSTRONG%3EUUU%20auto%20script%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%BD%BF%E7%94%A8%20i.MX%208MM%20%E7%9A%84%20L4.14.98_2.0.0_ga%20%E6%BC%94%E7%A4%BA%E9%95%9C%E5%83%8F%EF%BC%8C%E8%AF%A5%E9%95%9C%E5%83%8F%E5%8C%85%E5%90%AB%E8%87%AA%E5%8A%A8%E7%83%A7%E5%BD%95%E8%84%9A%E6%9C%AC%EF%BC%8C%E9%BB%98%E8%AE%A4%E4%BC%9A%E7%83%A7%E5%BD%95%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20eMMC%20%E4%B8%AD%E3%80%82%E8%84%9A%E6%9C%AC%E7%BB%93%E6%9E%84%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%2F***********************************************************************************%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3Euuu_version%201.2.39%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%E5%BD%93%20i.MX6%2F7%E3%80%81i.MX8MM%E3%80%81i.MX8MQ%20%E6%97%B6%EF%BC%8C%E5%B0%86%E8%BF%90%E8%A1%8C%E6%AD%A4%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDP%EF%BC%9Aboot%20-f%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%E5%BD%93%20ROM%20%E6%94%AF%E6%8C%81%E6%B5%81%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8C%E6%89%A7%E8%A1%8C%E6%AD%A4%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20i.MX8QXP%2C%20i.MX8QM%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPS%EF%BC%9Aboot%20-f%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%9C%A8%E5%90%AF%E7%94%A8%20SPL%20%E6%97%B6%E6%89%A7%E8%A1%8C%EF%BC%8C%E8%8B%A5%E6%9C%AA%E4%BD%BF%E7%94%A8%20SPL%20%E5%88%99%E8%B7%B3%E8%BF%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20SDPU%20%E5%B0%86%E8%A2%AB%E5%BC%83%E7%94%A8%E3%80%82%E8%AF%B7%E4%BD%BF%E7%94%A8%20SDPV%20%E8%80%8C%E4%B8%8D%E6%98%AF%20SDPU%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPU%EF%BC%9A%E5%BB%B6%E8%BF%9F%201000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPU%3A%20write%20-f%20imx-boot-imx8mmevk-sd.bin-flash_evk%20-offset%200x57c00%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPU%3A%20jump%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%9C%A8%E5%90%AF%E7%94%A8%20SPL%20%E6%97%B6%E6%89%A7%E8%A1%8C%EF%BC%8C%E8%8B%A5%E6%9C%AA%E4%BD%BF%E7%94%A8%20SPL%20%E5%88%99%E8%B7%B3%E8%BF%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%E5%A6%82%E6%9E%9C%20(SPL%20%E6%94%AF%E6%8C%81%20SDPV)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPV%EF%BC%9A%E5%BB%B6%E8%BF%9F%201000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPV%3A%20write%20-f%20imx-boot-imx8mmevk-sd.bin-flash_evk%20-skipspl%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESDPV%3A%20jump%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%23%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%3A%20ucmd%20setenv%20fastboot_dev%20mmc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%3A%20ucmd%20setenv%20mmcdev%20%24%7Bemmc_dev%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%EF%BC%9Aucmd%20mmc%20dev%20%24%7Bemmc_dev%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%EF%BC%9Aflash%20-raw2sparse%20all%20fsl-image-validation-imx-imx8mmevk.sdcard%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%3A%20flash%20bootloader%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%EF%BC%9Aucmd%20%E5%A6%82%E6%9E%9C%20env%20%E5%AD%98%E5%9C%A8%20emmc_ack%EF%BC%9B%E9%82%A3%E4%B9%88%EF%BC%9B%E5%90%A6%E5%88%99%20setenv%20emmc_ack%200%EF%BC%9Bfi%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%3A%20ucmd%20mmc%20partconf%20%24%7Bemmc_dev%7D%20%24%7Bemmc_ack%7D%201%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFB%EF%BC%9A%E5%B7%B2%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%2F***********************************************************************************%2F%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E7%AE%80%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%8C%E5%BD%93%E5%BC%80%E5%8F%91%E6%9D%BF%E8%BF%9B%E5%85%A5%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8CUUU%20%E5%B7%A5%E5%85%B7%E4%BC%9A%E5%B0%86%E5%BC%95%E5%AF%BC%20bootloader%20%E4%B8%8B%E8%BD%BD%E8%87%B3%E5%86%85%E9%83%A8%20RAM%E3%80%82%E5%BE%85%20uboot%20%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8C%E9%80%9A%E8%BF%87%20fastboot%20%E5%B7%A5%E5%85%B7%E5%B0%86%20.sdcard%20%E6%A0%BC%E5%BC%8F%E6%96%87%E4%BB%B6%E5%92%8C%20uboot%20%E5%88%B7%E5%86%99%E8%87%B3%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20eMMC%20%E5%AD%98%E5%82%A8%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%85%B3%E4%BA%8E%20UUU%20%E5%B7%A5%E5%85%B7%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8D%8F%E8%AE%AE%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%20UUU%20%E6%96%87%E6%A1%A3%20(UUU.pdf)%E7%AC%AC%205%20%E8%8A%82%E2%80%9C%E6%94%AF%E6%8C%81%E7%9A%84%E5%8D%8F%E8%AE%AE%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSTRONG%3E%E8%BF%90%E8%A1%8C%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E9%9C%80%E5%85%88%E4%B8%8B%E8%BD%BD%20UUU%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%8F%AF%E4%BB%8E%E4%B8%8A%E8%BF%B0%E9%93%BE%E6%8E%A5%E8%8E%B7%E5%8F%96%EF%BC%88Windows%20%E7%89%88%E4%B8%BA%20uuu.exe%EF%BC%8CLinux%20%E7%89%88%E4%B8%BA%20uuu%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%B8%8B%E8%BD%BD%E5%90%8E%E5%BB%BA%E8%AE%AE%E5%B0%86%E5%85%B6%E4%B8%8E%E6%BC%94%E7%A4%BA%E9%95%9C%E5%83%8F%E6%96%87%E4%BB%B6%E5%AD%98%E6%94%BE%E4%BA%8E%E5%90%8C%E4%B8%80%E7%9B%AE%E5%BD%95%EF%BC%8C%E4%BE%BF%E4%BA%8E%E5%90%8E%E7%BB%AD%E6%89%A7%E8%A1%8C%E5%91%BD%E4%BB%A4%E4%B8%94%E4%BF%9D%E6%8C%81%E6%93%8D%E4%BD%9C%E6%95%B4%E6%B4%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EWindows%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%9C%A8%20Windows%20%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E9%9C%80%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20Windows%20PowerShell%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BE%9D%E6%AC%A1%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20uuu.auto%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ELinux%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%24%20sudo%20.%2Fuuu%20uuu.auto%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E8%AF%A5%E5%B7%A5%E5%85%B7%E5%B0%86%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E5%BA%94%E7%AD%89%E5%BE%85%E4%B8%BB%E6%9C%BA%E7%94%B5%E8%84%91%E6%A3%80%E6%B5%8B%E5%88%B0%E4%BB%BB%E4%BD%95i.MX%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSTRONG%3E%E5%87%86%E5%A4%87%E5%BC%80%E5%8F%91%E6%9D%BF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E8%A6%81%E5%AF%B9%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9B%E8%A1%8C%E5%88%B7%E5%86%99%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%A4%84%E4%BA%8E%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%BC%80%E5%85%B3%E9%85%8D%E7%BD%AE%EF%BC%88i.MX%208MM%20EVK%EF%BC%89%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESW1101%26nbsp%3B%20-%26nbsp%3B%201010XXXXXX%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESW1102%20-%20XXXXXXXXX0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%E8%BF%90%E8%A1%8C%E5%B7%A5%E5%85%B7%E7%9A%84%E4%B8%BB%E6%9C%BA%20PC%20%E9%80%9A%E8%BF%87%20USB%20%E7%BA%BF%E8%BF%9E%E6%8E%A5%E8%87%B3%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20USB%20OTG%2FTYPE-C%20%E6%8E%A5%E5%8F%A3%EF%BC%88%E9%80%9A%E5%B8%B8%E6%A0%87%E6%B3%A8%E4%B8%BA%20%22download%22%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%E4%B8%BB%E6%9C%BA%20PC%20%E9%80%9A%E8%BF%87%20USB%20%E7%BA%BF%E8%BF%9E%E6%8E%A5%E8%87%B3%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20OTG-to-UART%20%E8%BD%AC%E6%8E%A5%E5%99%A8%EF%BC%88%E7%94%A8%E4%BA%8E%E4%B8%B2%E5%8F%A3%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%EF%BC%8C%E9%80%9A%E5%B8%B8%E6%A0%87%E6%B3%A8%E4%B8%BA%20%22debug%22%EF%BC%89%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%89%93%E5%BC%80%E7%BB%88%E7%AB%AF%E6%A8%A1%E6%8B%9F%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%AE%BE%E7%BD%AE%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%B3%A2%E7%89%B9%E7%8E%87%20-%20115200%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%95%B0%E6%8D%AE%E4%BD%8D%20-%208%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%A0%A1%E9%AA%8C%E4%BD%8D%20-%20%E6%97%A0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%81%9C%E6%AD%A2%E4%BD%8D%20-%201%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%20.0001pt%2027.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%20-%20%E6%97%A0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%B8%BA%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%94%B5%EF%BC%8C%E4%B8%8B%E8%BD%BD%E8%BF%87%E7%A8%8B%E5%B0%86%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%8C%E4%B8%B2%E5%8F%A3%E7%BB%88%E7%AB%AF%E4%BC%9A%E6%98%BE%E7%A4%BA%20uboot%20%E9%98%B6%E6%AE%B5%E7%9A%84%E6%93%8D%E4%BD%9C%E8%BF%9B%E5%BA%A6%EF%BC%8C%E8%AF%B7%E7%AD%89%E5%BE%85%E5%B7%A5%E5%85%B7%E6%8F%90%E7%A4%BA%E6%93%8D%E4%BD%9C%E6%88%90%E5%8A%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%9C%80%E5%90%8E%E5%85%B3%E9%97%AD%E5%BC%80%E5%8F%91%E6%9D%BF%E7%94%B5%E6%BA%90%EF%BC%8C%E5%B0%86%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E5%BC%80%E5%85%B3%E5%88%87%E6%8D%A2%E4%B8%BA%E4%BB%8E%20eMMC%20%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%EF%BC%8C%E9%87%8D%E6%96%B0%E4%B8%8A%E7%94%B5%E5%90%8E%E5%BA%94%E8%83%BD%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSTRONG%3E%E5%86%85%E7%BD%AE%E8%84%9A%E6%9C%AC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%8F%AF%E4%BD%BF%E7%94%A8%E5%86%85%E7%BD%AE%E8%84%9A%E6%9C%AC%E9%80%9A%E8%BF%87%20-b%20%E9%80%89%E9%A1%B9%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%26nbsp%3B%E5%92%8C%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%83%A7%E5%BD%95%E8%87%B3%E7%9B%AE%E6%A0%87%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%8F%AA%E9%9C%80%E6%A0%B9%E6%8D%AE%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E7%B1%BB%E5%9E%8B%E8%BE%93%E5%85%A5%E5%AF%B9%E5%BA%94%E5%91%BD%E4%BB%A4%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ESD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%BB%85%E5%86%99%E5%85%A5%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EWindows%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20sd%20%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ELinux%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20sd%20%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%20%3CSTRONG%3E%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSTRONG%3E%20%E6%9B%BF%E6%8D%A2%E4%B8%BA%E5%AE%9E%E9%99%85%E7%9A%84%20.imx%2F.bin%20%E6%96%87%E4%BB%B6%E5%90%8D%EF%BC%8C%E4%BB%A5%E4%B8%8B%E4%BB%A5%20i.MX%208MM%20%E4%B8%BA%E4%BE%8B%E5%88%86%E5%88%AB%E5%B1%95%E7%A4%BA%20Windows%20%E5%92%8C%20Linux%20%E5%91%BD%E4%BB%A4%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuur.exe%20-b%20sd%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20sd%20imx-boot-imx8mmevk-sd.bin-flash_evk%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%86%99%E5%85%A5%E6%95%B4%E4%B8%AA%20Linux%20%E9%95%9C%E5%83%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EWindows%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20sd_all%20%3CBOOTLOADER%3E%20%3CROOTFS%3E.sdcard%3C%2FROOTFS%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ELinux%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20sd_all%20%3CBOOTLOADER%3E%20%3CROOTFS%3E.sdcard%3C%2FROOTFS%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%20%3CSTRONG%3E%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSTRONG%3E%20%E5%92%8C%20%3CSTRONG%3E%3CROOTFS%3E%3C%2FROOTFS%3E%3C%2FSTRONG%3E%20%E5%88%86%E5%88%AB%E6%9B%BF%E6%8D%A2%E4%B8%BA%20.imx%2F.bin%20%E5%92%8C%20.sdcard%20%E7%9A%84%E5%AE%9E%E9%99%85%E5%90%8D%E7%A7%B0%EF%BC%88%E4%BB%A5%E4%B8%8B%E4%BB%A5%20i.MX%208MM%20%E4%B8%BA%E4%BE%8B%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20sd_all%26nbsp%3B%20imx-boot-imx8mmevk-sd.bin-flash_evk%20fsl-image-validation-imx-imx8mmevk.sdcard%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20sd_all%26nbsp%3B%20imx-boot-imx8mmevk-sd.bin-flash_evk%20fsl-image-validation-imx-imx8mmevk.sdcard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EeMMC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%BB%85%E5%86%99%E5%85%A5%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EWindows%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20emmc%20%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ELinux%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20emmc%20%3CBOOTLOADER%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%20i.MX%208MM%20%E7%9A%84%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20emmc%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20emmc%20imx-boot-imx8mmevk-sd.bin-flash_evk%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%86%99%E5%85%A5%E6%95%B4%E4%B8%AA%20Linux%20%E9%95%9C%E5%83%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EWindows%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20emmc_all%20%3CBOOTLOADER%3E%20%3CROOTFS%3E.sdcard%3C%2FROOTFS%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3ELinux%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20emmc_all%20%3CBOOTLOADER%3E%20%3CROOTFS%3E.sdcard%3C%2FROOTFS%3E%3C%2FBOOTLOADER%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%20i.MX%208MM%20%E7%9A%84%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26gt%3B%20.%5Cuuu.exe%20-b%20emmc_all%20imx-boot-imx8mmevk-sd.bin-flash_evk%20fsl-image-validation-imx-imx8mmevk.sdcard%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%24%20sudo%20.%2Fuuu%20-b%20emmc_all%20imx-boot-imx8mmevk-sd.bin-flash_evk%20fsl-image-validation-imx-imx8mmevk.sdcard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22margin%3A%200in%200in%208.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E5%AF%B9%E5%88%9A%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%88%B7%E6%9C%BA%E5%B7%A5%E5%85%B7%E7%9A%84%E6%AF%8F%E4%B8%AA%E4%BA%BA%E9%83%BD%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1110679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EWindows%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%85%B3%E4%BA%8E%EF%BC%9A%E4%BD%BF%E7%94%A8UUU%E7%83%A7%E5%BD%95Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%20OP-TEE%20%E9%A1%B9%E7%9B%AE%E6%98%AF%E5%90%A6%E5%B7%B2%E9%9B%86%E6%88%90%E5%88%B0%E9%92%88%E5%AF%B9%20i.MX%208MM%20EVK%20%E7%9A%84%20L4.14.98_2.0.0_ga_images_MX8MMEVK%20%E4%B8%AD%EF%BC%9FTFA%20%E6%98%AF%E5%90%A6%E4%B9%9F%E5%8C%85%E5%90%AB%E5%9C%A8%E5%86%85%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%85%B3%E4%BA%8E%EF%BC%9A%E4%BD%BF%E7%94%A8UUU%E7%83%A7%E5%BD%95Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20Yocto%20%E6%BA%90%E7%A0%81%E7%BC%96%E8%AF%91%E4%BA%86uboot%E3%80%81%E9%95%9C%E5%83%8F%E5%92%8C%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BD%86%E7%94%9F%E6%88%90%E7%9A%84%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E4%B8%8D%E6%98%AF%20.sdcard%20%E6%A0%BC%E5%BC%8F%EF%BC%8C%E4%B9%9F%E4%B8%8D%E6%98%AF%20.bin-flash_evk%20%E6%A0%BC%E5%BC%8F%E3%80%82%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-10-2019 09:21 AM
更新人:
